Orange Pi Plus 2e
so,emin orange ist nu auch angekommen…
aber somanche probleme:
ich hab hormorans image genommen.
beim adapter update wirft der immer:
iobroker 2017-05-31 22:42:50.954 info exit 0 iobroker 2017-05-31 22:42:50.911 info Adapter "socketio" updated iobroker 2017-05-31 22:42:50.836 info upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html iobroker 2017-05-31 22:42:50.680 info upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png iobroker 2017-05-31 22:42:50.644 info got /opt/iobroker/node_modules/iobroker.socketio/admin iobroker 2017-05-31 22:42:01.686 info npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.socketio" iobroker 2017-05-31 22:42:01.608 info SKIPPING OPTIONAL DEPENDENCY: Exit status 1 iobroker 2017-05-31 22:42:01.600 info optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: `node-gyp rebuild`npm WARN optional iobroker 2017-05-31 22:42:01.597 info WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):npm WARN iobroker 2017-05-31 22:42:01.595 info npm iobroker 2017-05-31 22:41:54.504 info gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok iobroker 2017-05-31 22:41:54.499 info gyp ERR! node -v v6.10.2 iobroker 2017-05-31 22:41:54.499 info ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/mdns iobroker 2017-05-31 22:41:54.497 info ERR! System Linux 3.4.113-sun8igyp iobroker 2017-05-31 22:41:54.494 info ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)gyp iobroker 2017-05-31 22:41:54.491 info gyp iobroker 2017-05-31 22:41:54.491 info gyp ERR! stack at ChildProcess.emit (events.js:191:7) iobroker 2017-05-31 22:41:54.491 info gyp ERR! stack at emitTwo (events.js:106:13) iobroker 2017-05-31 22:41:54.491 info ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23) iobroker 2017-05-31 22:41:54.488 info gyp iobroker 2017-05-31 22:41:54.472 info ERR! build error iobroker 2017-05-31 22:41:54.469 info iobroker 2017-05-31 22:41:54.463 info gyp iobroker 2017-05-31 22:41:54.450 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1 iobroker 2017-05-31 22:41:52.804 info compilation terminated. iobroker 2017-05-31 22:41:52.799 info ^ iobroker 2017-05-31 22:41:52.799 info #include iobroker 2017-05-31 22:41:52.799 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory admin.0 2017-05-31 22:41:06.349 info Repository received successfully. iobroker 2017-05-31 22:40:48.567 info npm install iobroker.socketio@1.7.5 --production --prefix "/opt/iobroker" (System call) iobroker 2017-05-31 22:40:45.059 info upgrade socketiowas kann das sein ? recht ratlos bin
Probier mal folgendes
sudo apt-get install libavahi-compat-libdnssd-devUnd dann nochmal socket.io updaten
Hi zusammen.
Da ich mittlerweile auch im Besitz eines OPI bin wollte ich natürlich meine bisherigen Adapter nutzen.
Darunter ist auch der rpi2.
Da gibt es aber zum einen die falsche Anzeige der Temperatur, die 1k-Fehlermeldung im log, und die GPIOs werden da nicht unterstützt (glaube ich zumindest hier gelesen zu haben).
Ok, GPIOs nutze ich persönlich nicht. Kann ich also verschmerzen.
Worauf ich jetzt hinaus will ist, das ich mich hingesetzt habe, ne Kopie vom rpi2 auf meinen Git gelegt habe und diesen angepasst habe (hoffe mal ich bekomme da jetzt nicht ärger vom Urheber).
Ich hab die Bezeichnungen geändert auf OPI, GPIOs entfernt, 1k-Fehler bereinigt, Temperatur wird jetzt richtig angezeigt, die Funktion "Raspberry" hab ich rausgenommen (Auslesen Kernspannung),
sdcard hab ich umbenannt in emmc.
Wer möchte kann sich das gerne installieren.
cd /opt/iobroker iobroker stop npm install https://github.com/PrinzEisenherz1/iobroker.opi/tarball/master --production iobroker upload opi iobroker startSieht jetzt unter ioBroker so aus
Johnny
Schön!
Ich habe sowas auch für den pine64 gemacht auch wenn ich kein js kann :D
http://forum.iobroker.net/viewtopic.php … =20#p40193
Vielen Dank, @PrinzEisenherz, hab da Teil installiert und mir erlaubt im Eingangspost auf Deinen Beitrag zu verlinken.
Klasse das "Monitoring-Modul" habe nur eine Kleinigkeit im Log gesehen:
opi.PNG `
Muss ich mir später nochmal ankucken. Bei mir taucht der Fehler nicht auf aber schau nochmal nach.Super,danke!
dir auch mal vielen Dank… Ich habs auch mal ausprobiert... läuft... soweit.
bei mir ist es ein anderer Error:
opi.0 2017-06-01 21:12:45.591 error Cannot evaluate: total used free shared buff/cache available Mem: 2062608 505872 1521136 5000 35600 1528914 Swap: 131068ich hab mir dir objecte mal eingeschaut.
memory_available beschreibt er wohl nicht….
das ist das raw von memory_available
{ "common": { "name": "opi.0.memory.memory_available", "state": "state", "role": "value", "type": "mixed", "read": true, "write": true }, "native": {}, "acl": { "object": 1638, "owner": "system.user.admin", "ownerGroup": "system.group.administrator", "state": 1638 }, "_id": "opi.0.memory.memory_available", "type": "state" }gruss, Black
Ich schau mir das morgen mal an!
Habe den Fehler mit der cpu_freq gefunden.
Bei mir läuft iobroker mit dem User iobroker. Die Frequenz ist bei dem Image aus dem Forum nur für Root lesbar, der rest geht auch so!?
ls -l /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq -r-------- 1 root root 4096 Jun 2 17:41 /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freqSo gehts es dann:
sudo chmod 444 /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq -
Alles klar, danke für die Rückmeldung
hmm. ich kämpfe mit der Installation. Ganz genu, wird jetzt min. eine 4.x Version von node.js benötigt!
ich habe zuvor eine alte geladen, jedoch läuft IOBroker damit wie Sack Nüsse…
wget http://download.iobroker.net/nodejs0_12_6_armhf.deb
dpkg -i nodejs0_12_6_armhf.deb
rm nodejs0_12_6_armhf.deb
Wie kann ich eine neuere Node Version installieren?
danke, jetzt geht es weiter… :P
bei mir taucht ein Lizenz Fehler im Log auf...
vis.0 2017-06-04 08:18:02.000 error No license found for vis. Please get one on https://iobroker.net !
Momentan lufen zwei Systeme gleichzeitig RPI und Orange PI
Unter dem Link https://iobroker.net soll man sich eine Lizense besorgen können. Beim Eingabe der E-Mail Adresse kommt ein Fehler, dass bereits die Mailadresse existiert...
Was tun?
habt Ihr den RFLink-Adapter am laufen? Ich sehe die USB Schnittstelle nicht!
root@orangepiplus2e:~# node -v
v4.2.1
root@orangepiplus2e:~# v4.2.1^C
root@orangepiplus2e:~# npm -v
2.14.7
Wie komme ich auf Node 6 ??? Kannjemand Helfen?
1526_unbenannt.png -
Wie komme ich auf Node 6 ??? `
Selbst deine 4.2 ist nicht die neueste in der 4er Reihe. Die solltest du wenigstens updaten.Ansonsten
http://www.iobroker.net/docu/?page_id=5 … ion_Nodejs
Und dort 4.x gegen 6.x austauschen.
habt Ihr den RFLink-Adapter am laufen? Ich sehe die USB Schnittstelle nicht! `
Ich habe ähnliche Probleme bei dem Tinkerboard.Du bist zwar bereits root, versuche es dennoch mal mit einem zusätzlichen sudo bei der Installation des Adapters. Beim pine64 hatte das geholfen.
Hast du die Version aus Github genommen?
Rainer `
danke Rainer.
o.k,
bin jetzt auf Node 6
v6.10.3
3.10.10
Den RFLink Adapter habe ich gelöscht und erneut installiert.
Im Log kommt ein Fehler:
rflink.0 2017-06-04 13:05:41.533 warn Module serialport is not available
Den Adapter habe ich aus dem IOBroker Admin installiert….
Wie kann ich den Adapter aus der Konsole installieren?
