  4. Anfrage Tahoma/Somfy IO Adapter
611 Beiträge 103 Kommentatoren 306.2k Aufrufe 86 Beobachtet
  • S SaschaS
    Einen Schritt weiter bin ich bereits.
    Der Login scheint zu funktionieren.
    tahoma.0
    2022-06-23 19:08:44.641	info	eventRegisterID = ce2d82fd-f947-4772-a55a-dc12a783aa67
    tahoma.0
    2022-06-23 19:08:42.792	info	Using stored bearer token 62b478eb520258e534d6
    tahoma.0
    2022-06-23 19:08:42.789	info	Adapter will connect to Tahoma Box via local API.
    Aber nach paar Minuten bzw. nach Ausführen von Befehlen folgt:
    tahoma.0
    2022-06-23 19:10:44.859	info	https://ha101-1.overkiz.com/enduser-mobile-web/enduserAPI/exec/0901341f-16ae-41b4-8452-c274edcd0432
    tahoma.0
    2022-06-23 19:10:44.846	info	https://ha101-1.overkiz.com/enduser-mobile-web/enduserAPI/exec/6dcbc8d9-f4ba-4e26-aec2-536bfda088c9
    tahoma.0
    2022-06-23 19:10:44.742	warn	Failed getting execution state for 124e5492-e241-4561-8174-c595b38fc207
    tahoma.0
    2022-06-23 19:10:44.741	warn	Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
    tahoma.0
    2022-06-23 19:10:44.740	warn	Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Thu, 23 Jun 2022 17:10:44 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1208-XXXX-3451.local:8443","port":"8443","hostname":"gateway-1208-XXXX-3451.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/124e5492-e241-4561-8174-c595b38fc207","path":"/enduser-mobile-web/1/enduserAPI/history/executions/124e5492-e241-4561-8174-c595b38fc207","href":"https://gateway-1208-XXXX-3451.local:8443/enduser-mobile-web/1/enduserAPI/history/executions/124e5492-e241-4561-8174-c595b38fc207"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 62b478eb520258e534d6","Content-type":"application/json"}}}
    tahoma.0
    2022-06-23 19:10:44.739	warn	error during request: null, request path: history/executions/124e5492-e241-4561-8174-c595b38fc207 with payload:{}
    Insbesondere finde ich verwirrend, dass in der Fehlermeldung der PIN der Tahoma-Box und nicht die lokale IP genannt wird. Soll das so sein?
    @wusa @dakusk Das scheint die gleiche Fehlermeldung wie bei euch in #317 gewesen in Konntet ihr das Problem bereits beheben?
    puls200
    #336
    Morgen!
    Ich klinke mich auch mal hier ein...
    Problem: die Jalousien lassen sich seit ein paar Tagen nicht mehr ansteuern.
    • ioBroker-Adapter, App und Connexoon-Box sind up-to-date
    • Connexoon-Box-Pin habe ich im Adapter eingetragen und unter Objekte finde ich nun die PIN inkl. (angeblicher) stabiler Verbindung
    • die Geräte senden aber keinen Status
    Bis auf die Pin habe ich sonst nichts geändert. Muss ich sonst noch was ändern (App oder Box)? Ich habe hier nämlich was von Entwicklermodus? Wo finde ich den?
    Gruss
    Puls
    • P puls200
      Morgen!
      Gruss
      Puls
      SaschaS
      #337
      @puls200 Den Entwicklermodus findest du wenn du dich bei somfy.de einloggst.
      P 1 Antwort Letzte Antwort
      • S SaschaS
        puls200
        #338
        @saschas Mmmh... ich kann da nichts aktivieren:
        K M 2 Antworten Letzte Antwort
        • P puls200
          kassmann
          #339
          • P puls200
            Murphys234d
            schrieb am zuletzt editiert von Murphys234d
            #340
            @puls200 Connexoon ist die Schuldige. Dort gibt es weder den Enwicklermodus noch die lokale Api. Als ich den Pin im iobroker eingetragen habe, konnte ich mich auch nicht mehr verbinden. Selbst als ich ihn dann wieder rausgenommen habe.
            Wie ich es letztlich lösen konnte, kann ich dir aber nicht sagen, da ich den broker in eier virtuellen Maschine hoste und somit einfach ein Backup aus der Nacht einspielen konnte.
            ps: Gestern ging die Verbindung auch nicht mehr, musste die Box updaten, dann ging der login wieder.
            ExcodiburE P 2 Antworten Letzte Antwort
            • L Offline
              lucky256
              #341
              Hallo zusammen, Ich bin nicht ganz sicher, ob ich hier im richtigen Topic bin, habe aber kein Passenderes gefunden. Ich möchte die lokale API nutzen und habe (nachdem ich den Entwicklermodus auf somfy.de aktiviert habe) veruscht mich durch die Anleitung auf https://github.com/Somfy-Developer/Somfy-TaHoma-Developer-Mode durchzukämpfen ... bin aber bereits im ersten Schritt kläglich gescheitert.. Da steht "In order to use this now available local API, you need to negociate a token with our cloud API to authenticate your calls to the local API...." Mein Problem ist, dass ich keine Ahnung habe wie und wo genau ich dieses Token erstellen muss. Hat jemand vieleicht eine (halb- oder voll-) DAU-taugliche Anleitung nach welcher ich vorgehen könnte? Danke euch schon mal für eure Hilfe..
              ExcodiburE 1 Antwort Letzte Antwort
              • L lucky256
                ExcodiburE Offline
                ExcodiburE Offline
                Excodibur
                #342
                @lucky256 Leider ist das dort recht schlecht beschrieben.
                Wenn du eine Tahoma-Box hast, dann musst du dich zuerst (einmalig) auf somfy.de (nicht accounts.somfy.de o.Ä.) mit deinen Zugangsdaten einloggen, dort "Meine Bestellungen" und dann "Meine Bestellung anzeigen" aufrufen. Dort siehst du dann deine Box und kannst links unten den "Entwicklermodus aktivieren". Danach sollte unter dem Bild deiner Box ein PIN-Code stehen - das ist deine individuelle Gateway-PIN (notieren!).
                Diese dann im Tahoma-Adapter (ideal ab Version 0.7.2), zusammen mit deinen üblichen Zugangsdaten für Tahomalink.com angeben. Den Rest macht dann der Adapter für dich.
                Was im Hintergrund dann passiert:
                • Der Adapter sucht (offline) mit der Gateway-PIN in deinem lokalen Netzwerk nach der Tahoma-Box und kann diese i.d.R. auch finden, wenn diese gepatcht ist und es keine Probleme mit der DNS-Auflösung gibt.
                • Der Adapter benutzt deine regulären Zugangsdaten und die Gateway-PIN um sich online bei den Somfy Servern zu authentifizieren und einmalig ein Token zu holen, mit dem er dann zukünftig direkt berechtigt ist auf deine Tahoma-Box rein über das lokale Netzwerk (z.B. zur Geräte-Steuerung) zuzugreifen.
                • M Murphys234d
                  ExcodiburE Offline
                  ExcodiburE Offline
                  Excodibur
                  #343
                  @murphys234d Bei Version 0.7.1 gibt es einen Bug, bei dem nach dem Löschen der PIN der Zugriff auf die Online-API nicht möglich ist. Das ist mit 0.7.2 (aktuell nur im Beta-Repo) behoben.
                  L M W 3 Antworten Letzte Antwort
                  • ExcodiburE Excodibur
                    lucky256
                    #344
                    @excodibur Super! Herzlichen Dank für die schnelle Hilfe. Es scheint geklappt zu haben, (den PIN hatte ich mir ja schon bei meinen ersten Versuchen besorgt) jedenfalls hab ich im Log den Eintrag "Adapter will connect to Tahoma Box via local API." und anschliessend: "Using stored bearer token 62..." und eine EventRegisterID. Ich nehme mal an, dass das gute Anzeichen sind dass ich nun via die lokale API darauf zugreife.
                    Ein Problem scheine ich aber bei Somfy noch zu haben. Wenn ich mich auf Somfy.de einloggen will, kriege ich eine ellenlange Fehlermeldung bei welcher fast zuoberst der Eintrag "Message: JSON parsing failure at character 1:'Y' in You exceeded the rate limit" steht. Was bedeutet das genau? (Über tahomalink kann ich mich einloggen und der Adapter scheint auch ok zu sein)
                    • L lucky256
                      ExcodiburE Offline
                      ExcodiburE Offline
                      Excodibur
                      #345
                      @lucky256 Ja, die gleiche Fehlermeldung kriege ich im Moment auch. Scheint mir aber ein Server-seitiges Problem (gibt es ja schonmal öfters bei Somfy 🙄 ) zu sein.
                      L 1 Antwort Letzte Antwort
                        lucky256
                        #346
                        @excodibur Das ist ja "beruhigend" ... ;-)
                        Ich hab mir nun mal das Log etwas genauer angeschaut und dabei gesehen, dass es Warnmeldungen bei meinen Somfy Lichtschaltern gibt, bei welchen ich vermute, dass die vom Adapter aus kommen. In meinen Skripten nutze ich den State core:ManufacturerSettingsState.wired_input_type eigentlich nicht. Ist zwar nur ne info, ist aber ev. etwas, das sich leicht korrigieren lässt?
                        2022-06-25 13:05:22.115 - info: host.ds-iobroker stopInstance system.adapter.tahoma.0 (force=false, process=true)
                        2022-06-25 13:05:22.161 - info: tahoma.0 (653102) Got terminate signal TERMINATE_YOURSELF
                        2022-06-25 13:05:22.161 - info: host.ds-iobroker stopInstance system.adapter.tahoma.0 send kill signal
                        2022-06-25 13:05:22.164 - info: tahoma.0 (653102) terminating
                        2022-06-25 13:05:22.165 - info: tahoma.0 (653102) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2022-06-25 13:05:22.783 - info: host.ds-iobroker instance system.adapter.tahoma.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2022-06-25 13:05:25.305 - info: host.ds-iobroker instance system.adapter.tahoma.0 started with pid 656416
                        2022-06-25 13:05:25.663 - info: host.ds-iobroker instance system.adapter.mobile-alerts.0 terminated with code 0 (NO_ERROR)
                        2022-06-25 13:05:28.350 - info: tahoma.0 (656416) starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.tahoma, node: v14.19.0, js-controller: 4.0.23
                        2022-06-25 13:05:28.407 - info: tahoma.0 (656416) [START] Starting adapter tahoma v0.7.2.3
                        2022-06-25 13:05:28.410 - info: tahoma.0 (656416) Configured polling interval: 60000
                        2022-06-25 13:05:28.416 - info: tahoma.0 (656416) Adapter will connect to Tahoma Box via local API.
                        2022-06-25 13:05:28.421 - info: tahoma.0 (656416) Using stored bearer token 62b494e200422b6a4b38
                        2022-06-25 13:05:31.337 - info: tahoma.0 (656416) eventRegisterID = 04186a9f-8124-4bc3-b36e-a121903ad04f
                        2022-06-25 13:08:31.413 - info: tahoma.0 (656416) State value to set for "tahoma.0.devices.Gartenbeleuchtung.states.core:ManufacturerSettingsState.wired_input_type" has to be type "string" but received type "object"
                        2022-06-25 13:08:31.420 - info: tahoma.0 (656416) State value to set for "tahoma.0.devices.Gartenbeleuchtung.states.core:ManufacturerSettingsState.wired_input_type" has to be type "string" but received type "object"
                        2022-06-25 13:08:31.426 - info: tahoma.0 (656416) State value to set for "tahoma.0.devices.Frühbeet_HQI.states.core:ManufacturerSettingsState.wired_input_type" has to be type "string" but received type "object"
                        2022-06-25 13:08:31.432 - info: tahoma.0 (656416) State value to set for "tahoma.0.devices.Frühbeet_HQI.states.core:ManufacturerSettingsState.wired_input_type" has to be type "string" but received type "object"
                        2022-06-25 13:08:31.439 - info: tahoma.0 (656416) State value to set for "tahoma.0.devices.Sitzplatzbeleuchtung.states.core:ManufacturerSettingsState.wired_input_type" has to be type "string" but received type "object"
                        2022-06-25 13:08:31.444 - info: tahoma.0 (656416) State value to set for "tahoma.0.devices.Sitzplatzbeleuchtung.states.core:ManufacturerSettingsState.wired_input_type" has to be type "string" but received type "object"
                        Hast du ev. eine Idee, wie ich das korrigieren kann? Danke schon mal
                        • L lucky256
                          lucky256
                          #347
                          @excodibur und diese Warnung erhalte ich ebenfalls. Hat das ev einen Zusammenhang?
                          2022-06-25 13:14:31.561 - warn: tahoma.0 (656416) error during request: null, request path: history/executions/82a707c7-60b2-4059-b9d5-c1604f053590 with payload:{}
                          2022-06-25 13:14:31.570 - warn: tahoma.0 (656416) Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Sat, 25 Jun 2022 11:14:31 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1224-3740-5129.local:8443","port":"8443","hostname":"gateway-1224-3740-5129.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/82a707c7-60b2-4059-b9d5-c1604f053590","path":"/enduser-mobile-web/1/enduserAPI/history/executions/82a707c7-60b2-4059-b9d5-c1604f053590","href":"https://gateway-1224-3740-5129.local:8443/enduser-mobile-web/1/enduserAPI/history/executions/82a707c7-60b2-4059-b9d5-c1604f053590"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 62b494e200422b6a4b38","Content-type":"application/json"}}}
                          2022-06-25 13:14:31.576 - warn: tahoma.0 (656416) Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                          2022-06-25 13:14:31.577 - warn: tahoma.0 (656416) Failed getting execution state for 82a707c7-60b2-4059-b9d5-c1604f053590
                            Murphys234d
                            #348
                            @excodibur ah, danke für die Info.
                            ps. ansonsten bin ich mit dem Adapter rundum glücklich 👍 . Wenn es Probleme gibt, liegt es eigentlich immer an Somfy. Auch deshalb bin ich schwer am überlegen, von connexoon auf Tahoma (switch) zu wechseln um dann die lokale api zu nutzen
                            W 1 Antwort Letzte Antwort
                            • M Murphys234d
                              W Offline
                              W Offline
                              Willi-Wunder
                              #349
                              Hi, hab mir jetzt auch mal die neuste Beta Version drauf gemacht, bekomme auch den Fehler und der Adapter wird irgendwann mal beendet und muss wieder manuell neu gestartet werden. Ich habe keine Lichtschalter, nur Motoren im Betrieb. Kann ich etwas loggen und damit @Excodibur weiterhelfen den Fehler zu finden? Somfy hat diese Woche ja ein neues Update für die Box raus gebracht und vermutlich wieder an der API etwas geändert. Gib bescheid, wenn ich etwas tun kann, bin aber leider kein programmierer und kenne mich damit nicht aus. Testen kann ich aber :-)
                              Vielen Dank nochmal, dass du den Adapter wieder belebt hast 👍
                              host.raspberrypi
                              	2022-06-26 02:48:58.795	warn	Do not restart adapter system.adapter.tahoma.0 because restart loop detected
                              host.raspberrypi
                              	2022-06-26 02:48:58.795	info	Restart adapter system.adapter.tahoma.0 because enabled
                              host.raspberrypi
                              	2022-06-26 02:48:58.794	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              tahoma.0
                              	2022-06-26 02:48:58.130	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                              tahoma.0
                              	2022-06-26 02:48:58.130	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                              tahoma.0
                              	2022-06-26 02:48:58.129	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                              tahoma.0
                              	2022-06-26 02:48:58.128	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              tahoma.0
                              	2022-06-26 02:48:58.125	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              tahoma.0
                              	2022-06-26 02:48:58.124	info	terminating
                              tahoma.0
                              	2022-06-26 02:48:58.118	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                              tahoma.0
                              	2022-06-26 02:48:58.117	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                              tahoma.0
                              	2022-06-26 02:48:58.109	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                              tahoma.0
                              	2022-06-26 02:48:58.107	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              tahoma.0
                              	2022-06-26 02:40:38.076	info	eventRegisterID = 10b7c50d-2db3-45ef-xxxx-cd81473454b7
                              tahoma.0
                              	2022-06-26 02:40:37.878	info	State value to set for "tahoma.0.devices.4__Balkontüre.states.core:ManufacturerSettingsState.open_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:40:37.877	info	State value to set for "tahoma.0.devices.4__Balkontüre.states.core:ManufacturerSettingsState.smart_protect" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:40:37.876	info	State value to set for "tahoma.0.devices.4__Balkontüre.states.core:ManufacturerSettingsState.security_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:40:37.874	info	State value to set for "tahoma.0.devices.3__Esszimmer.states.core:ManufacturerSettingsState.open_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:40:37.872	info	State value to set for "tahoma.0.devices.3__Esszimmer.states.core:ManufacturerSettingsState.smart_protect" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:40:37.866	info	State value to set for "tahoma.0.devices.3__Esszimmer.states.core:ManufacturerSettingsState.security_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:40:37.862	info	State value to set for "tahoma.0.devices.5__Wohnzimmer.states.core:ManufacturerSettingsState.open_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:40:37.860	info	State value to set for "tahoma.0.devices.5__Wohnzimmer.states.core:ManufacturerSettingsState.security_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:40:36.753	info	Using stored bearer token 6263c4b71f21561axxxx
                              tahoma.0
                              	2022-06-26 02:40:36.750	info	Adapter will connect to Tahoma Box via local API.
                              tahoma.0
                              	2022-06-26 02:40:36.747	info	Configured polling interval: 500000
                              tahoma.0
                              	2022-06-26 02:40:36.746	info	[START] Starting adapter tahoma v0.7.2.3
                              tahoma.0
                              	2022-06-26 02:40:36.708	info	starting. Version 0.7.2 (non-npm: Excodibur/ioBroker.tahoma) in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.12, js-controller: 4.0.23
                              host.raspberrypi
                              	2022-06-26 02:40:34.552	info	instance system.adapter.tahoma.0 started with pid 27510
                              host.raspberrypi
                              	2022-06-26 02:40:04.372	info	Restart adapter system.adapter.tahoma.0 because enabled
                              host.raspberrypi
                              	2022-06-26 02:40:04.371	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              tahoma.0
                              	2022-06-26 02:40:03.769	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                              tahoma.0
                              	2022-06-26 02:40:03.769	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                              tahoma.0
                              	2022-06-26 02:40:03.768	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                              tahoma.0
                              	2022-06-26 02:40:03.768	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              tahoma.0
                              	2022-06-26 02:40:03.765	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              tahoma.0
                              	2022-06-26 02:40:03.762	info	terminating
                              tahoma.0
                              	2022-06-26 02:40:03.753	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                              tahoma.0
                              	2022-06-26 02:40:03.752	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                              tahoma.0
                              	2022-06-26 02:40:03.744	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                              tahoma.0
                              	2022-06-26 02:40:03.742	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              tahoma.0
                              	2022-06-26 02:31:43.853	info	eventRegisterID = 73427a7f-921b-464e-8678-c2376e8f9d28
                              tahoma.0
                              	2022-06-26 02:31:43.513	info	State value to set for "tahoma.0.devices.4__Balkontüre.states.core:ManufacturerSettingsState.open_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:31:43.511	info	State value to set for "tahoma.0.devices.4__Balkontüre.states.core:ManufacturerSettingsState.smart_protect" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:31:43.510	info	State value to set for "tahoma.0.devices.4__Balkontüre.states.core:ManufacturerSettingsState.security_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:31:43.502	info	State value to set for "tahoma.0.devices.3__Esszimmer.states.core:ManufacturerSettingsState.open_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:31:43.500	info	State value to set for "tahoma.0.devices.3__Esszimmer.states.core:ManufacturerSettingsState.smart_protect" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:31:43.485	info	State value to set for "tahoma.0.devices.3__Esszimmer.states.core:ManufacturerSettingsState.security_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:31:43.484	info	State value to set for "tahoma.0.devices.5__Wohnzimmer.states.core:ManufacturerSettingsState.open_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:31:43.482	info	State value to set for "tahoma.0.devices.5__Wohnzimmer.states.core:ManufacturerSettingsState.security_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:31:42.302	info	Using stored bearer token 6263c4b71f21561a9245
                              tahoma.0
                              	2022-06-26 02:31:42.298	info	Adapter will connect to Tahoma Box via local API.
                              tahoma.0
                              	2022-06-26 02:31:42.295	info	Configured polling interval: 500000
                              tahoma.0
                              	2022-06-26 02:31:42.294	info	[START] Starting adapter tahoma v0.7.2.3
                              tahoma.0
                              	2022-06-26 02:31:42.255	info	starting. Version 0.7.2 (non-npm: Excodibur/ioBroker.tahoma) in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.12, js-controller: 4.0.23
                              host.raspberrypi
                              	2022-06-26 02:31:40.098	info	instance system.adapter.tahoma.0 started with pid 27068
                              host.raspberrypi
                              	2022-06-26 02:31:09.938	info	Restart adapter system.adapter.tahoma.0 because enabled
                              host.raspberrypi
                              	2022-06-26 02:31:09.936	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              tahoma.0
                              	2022-06-26 02:31:09.257	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              tahoma.0
                              	2022-06-26 02:31:09.255	info	terminating
                              tahoma.0
                              	2022-06-26 02:31:09.247	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                              tahoma.0
                              	2022-06-26 02:31:09.247	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                              tahoma.0
                              	2022-06-26 02:31:09.242	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                              tahoma.0
                              	2022-06-26 02:31:09.239	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              tahoma.0
                              	2022-06-26 02:06:09.189	info	eventRegisterID = 43f47f50-5e67-4a5a-b4e3-90e0a4a90e34
                              tahoma.0
                              	2022-06-26 02:06:08.968	info	State value to set for "tahoma.0.devices.4__Balkontüre.states.core:ManufacturerSettingsState.open_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:06:08.964	info	State value to set for "tahoma.0.devices.4__Balkontüre.states.core:ManufacturerSettingsState.smart_protect" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:06:08.962	info	State value to set for "tahoma.0.devices.4__Balkontüre.states.core:ManufacturerSettingsState.security_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:06:08.961	info	State value to set for "tahoma.0.devices.3__Esszimmer.states.core:ManufacturerSettingsState.open_level" has to be type "number" but received type "string"
                              tahoma.0
                              	2022-06-26 02:06:08.936	info	State value to set for "tahoma.0.devices.3__Esszimmer.states.core:ManufacturerSettingsState.smart_protect" has to be type "number" but received type "string"
                                W Offline
                                W Offline
                                wusa
                                #350
                                @excodibur sagte in Anfrage Tahoma/Somfy IO Adapter:
                                Kann man schon sagen, wann die Version aus dem Beta raus kommt?
                                • W wusa
                                  W Offline
                                  W Offline
                                  Willi-Wunder
                                  schrieb am zuletzt editiert von Willi-Wunder
                                  #351
                                  Du könntest dir auch die Beta installieren und testen. Expertenmodus - Installieren aus eigender URL - von Github
                                  • W Offline
                                    W Offline
                                    Willi-Wunder
                                    #352
                                    @Excodibur
                                    Weiß nicht ob dir das hilft, hänge hier mal etwas ran.
                                    tahoma.0
                                    	2022-06-27 02:49:08.680	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                                    tahoma.0
                                    	2022-06-27 02:49:08.680	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                                    tahoma.0
                                    	2022-06-27 02:49:08.674	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                                    tahoma.0
                                    	2022-06-27 02:49:08.673	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    • ExcodiburE Offline
                                      ExcodiburE Offline
                                      Excodibur
                                      #353
                                      @willi-wunder Du kannst mir gerne nochmal DEBUG-Logs (inkl. Adapter Neustart schicken, dann kann ich mal schauen.
                                      @Murphys234d Das Release ins Stable-Repo dauert noch etwas. Aktuell gibt es noch einige Probleme mit dem Adapter und der lokalen API (hauptsächlich "Unknown Object", was mit fehlenden API-Funktionen zusammenhängt), die erst behoben werden sollten, aber doch etwas aufwändiger sind.
                                      • M Murphys234d
                                        puls200
                                        schrieb am zuletzt editiert von puls200
                                        #354
                                        @murphys234d Hi... was heisst das jetzt? Müsste es theoretisch mit der Connexoon Box auch funktionieren?
                                        Ich bin nun von der Connexoon-App zur Tahoma-App gewechselt. Soweit geht auch alles über die Tahoma App. Der Adapter hat eine Verbindung zur Connexoon Box aber weiterhin kann ich die Jalousien nicht ansprechen, egal, ob ich die PIN eingebe oder nicht.
                                        Und noch was anderes: falls die Connexoon Box nun nicht mehr mit dem Adapter funktioniert: sind sowohl die Tahoma Box als auch das Connectivity Kit kompatibel mit dem Adapter (Unterschiede siehe HIER). Und dann gibt es ja noch die Tahoma Switch. Oder wurde die Tahoma Box mit der Switch ersetzt? Mir ist das Update etwas schleierhaft...
                                        • P puls200
                                          blackeagle998
                                          #355
                                          @puls200
                                          Ich habe auch eine Connexoon und bin letzte Woche von der Connexoon App auf die Tahoma App gewechselt.
                                          Aktuell habe ich die Adapterversion 0.7.2 im Einsatz und kann weiterhin meine Rollladen über die Connexoon Box und den Adapter steuern.
                                          Lediglich eine lokale API bietet die Connexoon (noch) nicht, vielleicht kommt da ja noch was, die Hoffnung stirbt zuletzt.
