  4. Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **
esphome
165 Beiträge 41 Kommentatoren 61.9k Aufrufe 45 Beobachtet
  • OpenSourceNomadO OpenSourceNomad
    @tontechniker siehst du irgendwas unanständiges in dem log von adapter bzw. in esphome logs?
    Tontechniker
    schrieb am zuletzt editiert von Tontechniker
    @opensourcenomad Ich hab mal den Programmiervorgang protokolliert. Wenn ich die Oberfläche von ESPhome mit der Darstellung beider Geräte anschaue und da den Log anwähle, sind beide gleich??
    Using 'COM7' as serial port.
    Connecting....
    Detecting chip type... Unsupported detection protocol, switching and trying again...
    Connecting....
    Detecting chip type... ESP8266
    Connecting. (94 %)Writing at 0x00061200... (100 %)Wrote 415328 bytes (290163 compressed) at 0x00000000 in 6.8 seconds (effective 489.8 kbit/s)...
    Hash of data verified.
    Leaving...
    Hard Resetting...
    Hard resetting via RTS pin...
    Done! Flashing is complete!
    Showing logs:
    [21:49:52][I][logger:242]: Log initialized
    [21:49:52][C][ota:461]: There have been 0 suspected unsuccessful boot attempts.
    [21:49:52][I][app:029]: Running through setup()...
    [21:49:52][I][i2c.arduino:161]: Performing I2C bus recovery
    [21:49:52][C][bmp280.sensor:056]: Setting up BMP280...
    [21:49:52][C][wifi:037]: Setting up WiFi...
    [21:49:52][D][wifi:373]: Starting scan...
    [21:49:52][D][bmp280.sensor:149]: Got temperature=27.1°C pressure=991.4hPa
    [21:49:52][D][sensor:124]: 'Aussentemperatur': Sending state 27.07000 °C with 1 decimals of accuracy
    [21:49:52][D][sensor:124]: 'Luftdruck': Sending state 991.35236 hPa with 1 decimals of accuracy
    [21:49:58][D][wifi:388]: Found networks:
    [21:49:58][I][wifi:431]: - 'Eisenbahn' (F0:B0:14:B0:E8:97) ▂▄▆█
    [21:49:58][D][wifi:433]:     Channel: 1
    [21:49:58][D][wifi:434]:     RSSI: -68 dB
    [21:49:58][I][wifi:431]: - 'Eisenbahn' (C8:0E:14:5B:01:ED) ▂▄▆█
    [21:49:58][D][wifi:434]:     RSSI: -70 dB
    [21:49:58][D][wifi:436]: - 'Eisenbahn Gastzugang' (F2:B0:14:B0:E8:97) ▂▄▆█
    [21:49:58][D][wifi:436]: - 'Eisenbahn Gastzugang' (CA:0E:14:5B:01:ED) ▂▄▆█
    [21:49:58][D][wifi:436]: - 'FRITZ!Box 7560 XH' (DC:15:C8:D7:BB:66) ▂▄▆█
    [21:49:58][D][wifi:436]: - 'Ansorge' (E8:DF:70:33:48:E6) ▂▄▆█
    [21:49:58][D][wifi:436]: - 'Ansorge Gastzugang' (EA:DF:70:33:48:E6) ▂▄▆█
    [21:49:58][I][wifi:248]: WiFi Connecting to 'Eisenbahn'...
    [21:49:59][I][wifi:505]: WiFi Connected!
    [21:49:59][C][wifi:353]:   Local MAC: 3C:71:BF:32:7E:26
    [21:49:59][C][wifi:354]:   SSID: 'Eisenbahn'
    [21:49:59][C][wifi:355]:   IP Address: 192.168.178.100
    [21:49:59][C][wifi:356]:   BSSID: F0:B0:14:B0:E8:97
    [21:49:59][C][wifi:358]:   Hostname: 'temp-pres-01'
    [21:49:59][C][wifi:360]:   Signal strength: -70 dB ▂▄▆█
    [21:49:59][C][wifi:364]:   Channel: 1
    [21:49:59][C][wifi:365]:   Subnet: 255.255.255.0
    [21:49:59][C][wifi:366]:   Gateway: 192.168.178.1
    [21:49:59][C][wifi:367]:   DNS1: 0.0.0.0
    [21:49:59][C][wifi:368]:   DNS2: 0.0.0.0
    [21:49:59][D][wifi:514]: Disabling AP...
    [21:49:59][C][ota:085]: Over-The-Air Updates:
    [21:49:59][C][ota:086]:   Address: 192.168.178.100:8266
    [21:49:59][C][ota:089]:   Using Password.
    [21:49:59][C][api:025]: Setting up Home Assistant API server...
    [21:49:59][I][app:062]: setup() finished successfully!
    [21:49:59][I][app:102]: ESPHome version 2022.5.1 compiled on Jun 15 2022, 21:27:44
    [21:49:59][C][wifi:491]: WiFi:
    [21:49:59][C][logger:274]: Logger:
    [21:49:59][C][logger:275]:   Level: DEBUG
    [21:49:59][C][logger:276]:   Log Baud Rate: 115200
    [21:49:59][C][logger:277]:   Hardware UART: UART0
    [21:49:59][C][i2c.arduino:038]: I2C Bus:
    [21:49:59][C][i2c.arduino:039]:   SDA Pin: GPIO4
    [21:49:59][C][i2c.arduino:040]:   SCL Pin: GPIO5
    [21:49:59][C][i2c.arduino:041]:   Frequency: 100000 Hz
    [21:49:59][C][i2c.arduino:044]:   Recovery: bus successfully recovered
    [21:49:59][I][i2c.arduino:054]: Results from i2c bus scan:
    [21:49:59][I][i2c.arduino:060]: Found i2c device at address 0x76
    [21:49:59][C][bmp280.sensor:098]: BMP280:
    [21:49:59][C][bmp280.sensor:099]:   Address: 0x76
    [21:49:59][C][bmp280.sensor:111]:   IIR Filter: OFF
    [21:49:59][C][bmp280.sensor:112]:   Update Interval: 10.0s
    [21:49:59][C][bmp280.sensor:114]:   Temperature 'Aussentemperatur'
    [21:49:59][C][bmp280.sensor:114]:     Device Class: 'temperature'
    [21:49:59][C][bmp280.sensor:114]:     State Class: 'measurement'
    [21:49:59][C][bmp280.sensor:114]:     Unit of Measurement: '°C'
    [21:49:59][C][bmp280.sensor:114]:     Accuracy Decimals: 1
    [21:49:59][C][bmp280.sensor:115]:     Oversampling: 16x
    [21:49:59][C][bmp280.sensor:116]:   Pressure 'Luftdruck'
    [21:49:59][C][bmp280.sensor:116]:     Device Class: 'pressure'
    [21:49:59][C][bmp280.sensor:116]:     State Class: 'measurement'
    [21:49:59][C][bmp280.sensor:116]:     Unit of Measurement: 'hPa'
    [21:49:59][C][bmp280.sensor:116]:     Accuracy Decimals: 1
    [21:49:59][C][bmp280.sensor:117]:     Oversampling: 16x
    [21:49:59][C][captive_portal:088]: Captive Portal:
    [21:49:59][C][mdns:084]: mDNS:
    [21:49:59][C][mdns:085]:   Hostname: temp-pres-01
    [21:49:59][C][api:138]: API Server:
    [21:49:59][C][api:139]:   Address: 192.168.178.100:6053
    [21:49:59][C][api:143]:   Using noise encryption: NO
    [21:50:00][D][bmp280.sensor:149]: Got temperature=27.0°C pressure=991.3hPa
    [21:50:00][D][sensor:124]: 'Aussentemperatur': Sending state 27.04000 °C with 1 decimals of accuracy
    [21:50:00][D][sensor:124]: 'Luftdruck': Sending state 991.28705 hPa with 1 decimals of accuracy
    [21:50:10][D][bmp280.sensor:149]: Got temperature=27.3°C pressure=991.7hPa
    [21:50:10][D][sensor:124]: 'Aussentemperatur': Sending state 27.26000 °C with 1 decimals of accuracy
    [21:50:10][D][sensor:124]: 'Luftdruck': Sending state 991.69330 hPa with 1 decimals of accuracy
    [21:50:20][D][bmp280.sensor:149]: Got temperature=27.2°C pressure=991.7hPa
    [21:50:20][D][sensor:124]: 'Aussentemperatur': Sending state 27.25000 °C with 1 decimals of accuracy
    [21:50:20][D][sensor:124]: 'Luftdruck': Sending state 991.65674 hPa with 1 decimals of accuracy
    [21:50:30][D][bmp280.sensor:149]: Got temperature=27.3°C pressure=991.7hPa
    [21:50:30][D][sensor:124]: 'Aussentemperatur': Sending state 27.30000 °C with 1 decimals of accuracy
    [21:50:30][D][sensor:124]: 'Luftdruck': Sending state 991.68585 hPa with 1 decimals of accuracy
    [21:50:40][D][bmp280.sensor:149]: Got temperature=27.3°C pressure=991.7hPa
    [21:50:40][D][sensor:124]: 'Aussentemperatur': Sending state 27.30000 °C with 1 decimals of accuracy
    [21:50:40][D][sensor:124]: 'Luftdruck': Sending state 991.67389 hPa with 1 decimals of accuracy
    Und der andere (ist der "normale" Log:
    INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/test01.yaml...
    WARNING GPIO2 is a Strapping PIN and should be avoided.
    Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
    See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
    INFO Starting log output from 192.168.178.100 using esphome API
    INFO Successfully connected to 192.168.178.100
    [21:42:06][I][app:102]: ESPHome version 2022.5.1 compiled on Jun 14 2022, 20:35:50
    [21:42:06][C][status_led:019]: Status LED:
    [21:42:06][C][status_led:020]:   Pin: GPIO2
    [21:42:06][C][wifi:491]: WiFi:
    [21:42:06][C][wifi:353]:   Local MAC: 3C:71:BF:AA:80:80
    [21:42:06][C][wifi:354]:   SSID: [redacted]
    [21:42:06][C][wifi:355]:   IP Address: 192.168.178.100
    [21:42:06][C][wifi:357]:   BSSID: [redacted]
    [21:42:06][C][wifi:358]:   Hostname: 'test01'
    [21:42:06][C][wifi:360]:   Signal strength: -73 dB ▂▄▆█
    [21:42:06][C][wifi:364]:   Channel: 1
    [21:42:06][C][wifi:365]:   Subnet: 255.255.255.0
    [21:42:06][C][wifi:366]:   Gateway: 192.168.178.1
    [21:42:06][C][wifi:367]:   DNS1: 0.0.0.0
    [21:42:06][C][wifi:368]:   DNS2: 0.0.0.0
    [21:42:06][C][logger:274]: Logger:
    [21:42:06][C][logger:275]:   Level: DEBUG
    [21:42:06][C][logger:276]:   Log Baud Rate: 115200
    [21:42:06][C][logger:277]:   Hardware UART: UART0
    [21:42:06][C][i2c.arduino:038]: I2C Bus:
    [21:42:06][C][i2c.arduino:039]:   SDA Pin: GPIO21
    [21:42:06][C][i2c.arduino:040]:   SCL Pin: GPIO22
    [21:42:06][C][i2c.arduino:041]:   Frequency: 100000 Hz
    [21:42:06][C][i2c.arduino:044]:   Recovery: bus successfully recovered
    [21:42:06][I][i2c.arduino:054]: Results from i2c bus scan:
    [21:42:06][I][i2c.arduino:060]: Found i2c device at address 0x40
    [21:42:06][C][hdc1080:031]: HDC1080:
    [21:42:06][C][hdc1080:032]:   Address: 0x40
    [21:42:06][C][hdc1080:036]:   Update Interval: 60.0s
    [21:42:06][C][hdc1080:037]:   Temperature 'Wintergarten Temperature'
    [21:42:06][C][hdc1080:037]:     Device Class: 'temperature'
    [21:42:06][C][hdc1080:037]:     State Class: 'measurement'
    [21:42:06][C][hdc1080:037]:     Unit of Measurement: '°C'
    [21:42:06][C][hdc1080:037]:     Accuracy Decimals: 1
    [21:42:06][C][hdc1080:038]:   Humidity 'Wintergarten Feuchte'
    [21:42:06][C][hdc1080:038]:     Device Class: 'humidity'
    [21:42:06][C][hdc1080:038]:     State Class: 'measurement'
    [21:42:06][C][hdc1080:038]:     Unit of Measurement: '%'
    [21:42:06][C][hdc1080:038]:     Accuracy Decimals: 0
    [21:42:06][C][captive_portal:088]: Captive Portal:
    [21:42:06][C][web_server:129]: Web Server:
    [21:42:06][C][web_server:130]:   Address: 192.168.178.100:80
    [21:42:06][C][mdns:084]: mDNS:
    [21:42:06][C][mdns:085]:   Hostname: test01
    [21:42:06][C][ota:085]: Over-The-Air Updates:
    [21:42:06][C][ota:086]:   Address: 192.168.178.100:3232
    [21:42:06][C][ota:089]:   Using Password.
    [21:42:06][C][api:138]: API Server:
    [21:42:06][C][api:139]:   Address: 192.168.178.100:6053
    [21:42:06][C][api:143]:   Using noise encryption: NO
    [21:42:13][D][sensor:125]: 'Wintergarten Temperature': Sending state 26.44714 °C with 1 decimals of accuracy
    [21:42:13][D][sensor:125]: 'Wintergarten Feuchte': Sending state 54.81568 % with 0 decimals of accuracy
    [21:42:13][D][hdc1080:069]: Got temperature=26.4°C humidity=54.8%
    Endlich fertig!
    OpenSourceNomadO 1 Antwort Letzte Antwort
    • T Tontechniker
      Connecting....
      Connecting....
      Leaving...
      Hard Resetting...
      Showing logs:
      Endlich fertig!
      OpenSourceNomadO Offline
      OpenSourceNomad
      Most Active Gesperrt
      @tontechniker said in Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **:
      sind beide gleich??
      also die haben zwei verschiedene Namen und sind offensichtlich auch zwei verschiedene Geräte aber die haben die gleiche statische IP Adresse konfiguriert? 🤔
      T 2 Antworten Letzte Antwort
        sind beide gleich??
        Tontechniker
        @opensourcenomad Manche Dinge sind soooo einfach!!!
        Danke für Deine Hilfe!
        Ich hatte im Laufe meiner Versuche schon mal ohne Erfolg eine andere Webadresse eingegeben. Da war aber bestimmt noch etwas anderes nicht O.K.!
        Dir noch einen schönen Abend!
        Hans
          sind beide gleich??
          Tontechniker
          #66
          @opensourcenomad Hast Du mal ein yaml-Beispiel für mich, um eine LED auf dem Board blinken zu lassen? Habe schon einiges getestet, aber leider nicht erfolgreich.
          • T Tontechniker
            OpenSourceNomad
            #67
            Einfach so permanent direkt nach dem start oder soll es irgendeinen "Auslöser" (z.B. wenn er mit der Zentrale verbunden ist) geben?
              Tontechniker
              #68
              @opensourcenomad Ohne Auslöser,nach dem Start.
              • T Tontechniker
                OpenSourceNomad
                schrieb am zuletzt editiert von OpenSourceNomad
                #69
                Okay, sprich wir machen das on_boot, dieser gehört in deinen vorhanden esphome: block 👇
                # https://esphome.io/components/esphome.html#on-boot
                esphome:
                  on_boot:
                    then:
                      - light.turn_on:
                          effect: pulse
                Aber natürlich brauchen wir auch noch das light (monochromatic) mit der id meinetolleled (und den passenden output 👉 hier muss du deinen Pin definieren an dem die LED hängt!) 💡
                # https://esphome.io/components/light/monochromatic.html
                light:
                  - platform: monochromatic
                    name: "Meine tolle LED"
                    output: led_output
                    effects:
                      - pulse:
                # Example output entry
                output:
                  - platform: esp8266_pwm
                    pin: D1
                  esphome:
                    on_boot:
                      then:
                        - light.turn_on:
                            effect: pulse
                  light:
                      output: led_output
                      effects:
                        - pulse:
                  output:
                      pin: D1
                  Tontechniker
                  #70
                  @opensourcenomad Vielen Dank! Es funktioniert bei der esp8266, aber wie mache ich das bei der esp32 (er meckert "8266_pwm" an). Habe in esphome.io gesucht und habe nicht das Richtige gefunden.
                  • T Tontechniker
                    OpenSourceNomad
                    #71
                    Der esp32 macht pwm in hardware, die passende Komponente hierfür schimpt sich ledc (zu finden unter den output components).
                      Tontechniker
                      #72
                      @opensourcenomad
                      Ich habe mal das "Enable fallback hotspot (captive portal) in case wifi connection fails" getestet (falsche wifi-Adresse eingegeben). Nach einer Minute ist das entsprechende Gerät im wifi-Netzwerk zu sehen. Wenn ich mich dann einlogge, erscheint immer die msn-Seite (Microsoft-Network) im Browser. Es sollte doch das "captive portal" im Browser erscheinen??
                      • T Tontechniker
                        @opensourcenomad
                        OpenSourceNomad
                        #73
                        Internet Explorer 6 vielleicht?
                        Du solltest per DHCP eine IP bekommen (nach dem du dich mit dem Fallback AP verbunden hast) und im Browser dann die 192.168.4.1 auflösen können wo sich das captive portal befindet.
                          Tontechniker
                          #74
                          @opensourcenomad said in Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **:
                          192.168.4.1
                          Auf meinem PC läuft Windows 10 und firefox. Habe als gateway die Adresse meiner FritzBox angegeben. Eben auch nochmal anstelle der FritzBox-Adresse mit 192.168.4.1 vesucht - keinen Erfolg!
                          • T Tontechniker
                            192.168.4.1
                            OpenSourceNomad
                            #75
                            @tontechniker nein, nix an der Fritze doktorn.
                            Wenn ein ESP eine Fallback AP öffnet dann verbindest du dich aktiv mit deinem Endgerät (sprich Mobilfunkdelefen, Laptop, Computer) per WLAN mit genau diesem ESP. Du hast dann kein Internet (weil du nicht mehr mit deiner Fritze verbunden bist), aber dafür die Möglichkeit eben die WLAN Daten des esp's zu ändern. 💡
                              Tontechniker
                              #76
                              @opensourcenomad Habe das entspr. Video auf youtube mehrfach angesehen und alles so gemacht wie angegeben. Leider keinen Erfolg!
                              EDIT:
                              Ursache der Fehlfunktion war eine falsche WLAN-Einstellung.
                                Im Listing stand
                                api:
                                  encryption:
                                    key: "mgsu8AZtuXCm9x4mlcOFv3lPgTLZc1tX8Y/rjrowr1M="
                                Das habe ich gelöscht und für api ein Passwort eingefügt.
                                Interessant! Die (Transport)-Verschlüsselung für die native api gibt es tatsächlich schon länger (September 2021) aber ist mit der aktuellsten Version vom 18. Mai nun automatisch in einer neuen yaml vorhanden.
                                Sieht so aus als unterstützt der esphome adapater von @Dutchman die Verschlüsselung leider noch nicht 🙄
                                draexlerD Offline
                                draexlerD Offline
                                draexler
                                schrieb am zuletzt editiert von draexler
                                #77
                                @opensourcenomad @Tontechniker: Das verstehe ich nicht… Ich habe das nicht in meinen Code. Ich habe den ESP OTA geupdatet und seitdem bekomme ich ich diesen nicht mehr in die esphome.0 Instanz. Es kommt immer die Meldung: „Bad format. Expected 0 at the begin“
                                Was kann ich machen?
                                EDIT: hat sich erledigt. Problem war das ich einen Button eingebaut habe. Das wird nicht unterstützt. Habe einen Switch reingepackt und schon geht es.
                                • ? Offline
                                  #78
                                  wer kann einem esphome Neuling helfen?
                                  Ich habe den Adapter installiert und einen Wemos d1 mini geflasht. Dieser verbindet sich auch und wird als online im esphome Dashboard angezeigt.
                                  Ich habe einen PN532 Rfid Tag Leser an Gpio4 und 5 angelötet und dieser wird auch laut Log erkannt. Ich bekomme es aber einfach nicht hin das der auch Tags liest. Wenn ich einen Tag auflege passiert einfach nichts. Auch keine Log ausgabe. Hat jemand eine Idee was ich falsch mache?
                                  Die Config:
                                  esphome:
                                  esp8266:
                                    board: esp01_1m
                                  # Enable logging
                                  logger:
                                  # Enable Home Assistant API
                                  api:
                                    password: "xxx"
                                  # OTA Update
                                  ota:
                                    password: "xxx"
                                  web_server:
                                    port: 80
                                  wifi:
                                    ssid: !secret wifi_ssid
                                    password: !secret wifi_password
                                    # Enable fallback hotspot (captive portal) in case wifi connection fails
                                    ap:
                                      ssid: "Esphome-Web-6Eed9A"
                                      password: "xxx"
                                  captive_portal:
                                  i2c:
                                    scan: false
                                    frequency: 400kHz
                                  pn532_i2c:
                                    update_interval: 1s
                                    on_tag:
                                      then:
                                        - text_sensor.template.publish:
                                           state: !lambda 'return x;'
                                  text_sensor:
                                    - platform: template
                                  Das Log:
                                  INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-6eed9a.yaml...
                                  INFO Starting log output from esphome-web-6eed9a.local using esphome API
                                  INFO Successfully connected to esphome-web-6eed9a.local
                                  [20:27:06][I][app:102]: ESPHome version 2022.2.6 compiled on Jul 20 2022, 20:11:31
                                  [20:27:06][C][wifi:491]: WiFi:
                                  [20:27:06][C][wifi:353]:   Local MAC: EC:FA:BC:6E:ED:9A
                                  [20:27:06][C][wifi:354]:   SSID: [redacted]
                                  [20:27:06][C][wifi:355]:   IP Address: 192.168.178.34
                                  [20:27:06][C][wifi:356]:   BSSID: [redacted]
                                  [20:27:06][C][wifi:358]:   Hostname: 'esphome-web-6eed9a'
                                  [20:27:06][C][wifi:360]:   Signal strength: -62 dB ▂▄▆█
                                  [20:27:06][C][wifi:364]:   Channel: 2
                                  [20:27:06][C][wifi:365]:   Subnet: 255.255.255.0
                                  [20:27:06][C][wifi:366]:   Gateway: 192.168.178.1
                                  [20:27:06][C][wifi:367]:   DNS1: 192.168.178.1
                                  [20:27:06][C][wifi:368]:   DNS2: 0.0.0.0
                                  [20:27:06][C][logger:233]: Logger:
                                  [20:27:06][C][logger:234]:   Level: DEBUG
                                  [20:27:06][C][logger:235]:   Log Baud Rate: 115200
                                  [20:27:06][C][logger:236]:   Hardware UART: UART0
                                  [20:27:06][C][i2c.arduino:038]: I2C Bus:
                                  [20:27:06][C][i2c.arduino:039]:   SDA Pin: GPIO4
                                  [20:27:06][C][i2c.arduino:040]:   SCL Pin: GPIO5
                                  [20:27:06][C][i2c.arduino:041]:   Frequency: 400000 Hz
                                  [20:27:06][C][i2c.arduino:044]:   Recovery: bus successfully recovered
                                  [20:27:06][C][template.text_sensor:021]: Template Sensor 'RFID Tag'
                                  [20:27:06][C][pn532:347]: PN532:
                                  [20:27:06][C][pn532:359]:   Update Interval: 1.0s
                                  [20:27:06][C][pn532_i2c:128]:   Address: 0x24
                                  [20:27:06][C][captive_portal:144]: Captive Portal:
                                  [20:27:06][C][web_server:179]: Web Server:
                                  [20:27:06][C][web_server:180]:   Address: esphome-web-6eed9a.local:80
                                  [20:27:06][C][mdns:084]: mDNS:
                                  [20:27:06][C][mdns:085]:   Hostname: esphome-web-6eed9a
                                  [20:27:06][C][ota:085]: Over-The-Air Updates:
                                  [20:27:06][C][ota:086]:   Address: esphome-web-6eed9a.local:8266
                                  [20:27:06][C][ota:089]:   Using Password.
                                  [20:27:06][C][api:138]: API Server:
                                  [20:27:06][C][api:139]:   Address: esphome-web-6eed9a.local:6053
                                  [20:27:06][C][api:143]:   Using noise encryption: NO
                                  T FredFF 2 Antworten Letzte Antwort
                                    Die Config:
                                    esphome:
                                    esp8266:
                                      board: esp01_1m
                                    # Enable logging
                                    logger:
                                    api:
                                      password: "xxx"
                                    # OTA Update
                                    ota:
                                      password: "xxx"
                                    web_server:
                                      port: 80
                                    wifi:
                                      ap:
                                        password: "xxx"
                                    captive_portal:
                                    i2c:
                                      scan: false
                                      frequency: 400kHz
                                    pn532_i2c:
                                      update_interval: 1s
                                      on_tag:
                                        then:
                                    text_sensor:
                                    Das Log:
                                    Tontechniker
                                    #79
                                    @david83 said in Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **:
                                    esp01_1m
                                    Hast Du das 532-Board im Set mit den RFID-Tags gekauft, oder separat? Ich frage, da es RFID-Tags mit unterschiedlichen Frequenzen gibt.
                                    • T Tontechniker
                                      esp01_1m
                                      #80
                                      @tontechniker
                                      Ich habe das Board und die Tags getrennt gekauft. Allerdings habe ich das gleiche Setting schon im Einsatz mit EspEasy. Gleicher RFID Leser gleiche Tags und gleicher Ds Mini.
                                      Irgendwie hängt das aus meiner Sicht mit esphome zusammen. Vielleicht ist die config falsch?
                                        Die Config:
                                        esphome:
                                        esp8266:
                                          board: esp01_1m
                                        # Enable logging
                                        logger:
                                        api:
                                          password: "xxx"
                                        # OTA Update
                                        ota:
                                          password: "xxx"
                                        web_server:
                                          port: 80
                                        wifi:
                                          ap:
                                            password: "xxx"
                                        captive_portal:
                                        i2c:
                                          scan: false
                                          frequency: 400kHz
                                        pn532_i2c:
                                          update_interval: 1s
                                          on_tag:
                                            then:
                                        text_sensor:
                                        Das Log:
                                        FredFF Online
                                        FredFF Online
                                        FredF
                                        Most Active Forum Testing
                                        #81
                                        @david83 sagte in Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **:
                                        PN532
                                        Hab den nicht in Benutzung, wenn ich aber hier nach gehe, fehlt dir der komplette Zweig binary sensor mit der eindeutigen ID des Tags.
                                        Y 1 Antwort Letzte Antwort
                                        • FredFF FredF
                                          PN532
                                          Y Offline
                                          Y Offline
                                          Yoshi
                                          schrieb am zuletzt editiert von Yoshi
                                          #82
                                          Hallo Leute,
                                          ich komme einfach nicht mehr weiter. Ich habe einen ESP und einen mmwave Radar Sensor verlötet.
                                          Wenn ich nun alles überspiele, dann baut der ESP zum ESPHome keine richtige Verbindung auf. Immer kommen diese Fehermeldungen.
                                          Was ich auch komisch finde ist. In der Anleitung oben soll ich ja das Passwort für OTA vergeben und dann bei zufügen des Devices eingeben, aber er sagt immer falsches Passwort und wenn ich keins eingebe, dann nimmt er es. Baut sich kurz auf und dann warst das.
                                          esphome.0
                                          2022-07-22 17:15:41.347	warn	Client 192.168.0.88 Timeout, connection Lost, will reconnect automatically when device is available!
                                          esphome.0
                                          2022-07-22 17:15:36.384	error	ESPHome client 192.168.0.88 TypeError: Cannot read property 'deserializeBinary' of undefined
                                          esphome.0
                                          2022-07-22 17:15:36.370	error	ESPHome client 192.168.0.88 TypeError: Cannot read property 'deserializeBinary' of undefined
                                          esphome.0
                                          2022-07-22 17:15:06.315	warn	Client 192.168.0.88 Timeout, connection Lost, will reconnect automatically when device is available!
                                          esphome.0
                                          2022-07-22 17:15:01.348	error	ESPHome client 192.168.0.88 TypeError: Cannot read property 'deserializeBinary' of undefined
                                          esphome.0
                                          2022-07-22 17:15:01.330	error	ESPHome client 192.168.0.88 TypeError: Cannot read property 'deserializeBinary' of undefined
                                          Wenn ich mich über Web draufwähle läuft es an sich. Ich sehe wie sich die Zustände ändern, aber auch hier bekomme ich das die Verbindung schliesst.
                                          [16:02:53][D][api:102]: Accepted 192.168.0.64
                                          [16:02:54][D][api:102]: Accepted 192.168.0.64
                                          [16:02:54][W][api.connection:083]: raspberrypi4-iob (192.168.0.64): Connection closed
                                          [16:02:58][W][api.connection:083]: raspberrypi4-iob (192.168.0.64): Connection closed
                                          [16:02:59][W][api.connection:083]: raspberrypi4-iob (192.168.0.64): Connection closed
                                          [16:03:03][D][api:102]: Accepted 192.168.0.64
                                          [16:03:03][W][api.connection:083]: raspberrypi4-iob (192.168.0.64): Connection closed
                                          [16:03:19][D][api:102]: Accepted 192.168.0.64
                                          [16:03:19][W][api.connection:083]: raspberrypi4-iob (192.168.0.64): Connection closed
                                          [16:03:21][D][api:102]: Accepted 192.168.0.64
                                          mein Yaml
                                          esphome:
                                            platform: ESP8266
                                            board: esp01_1m
                                          substitutions:
                                            device_name: tinypico-mmwave
                                          # Enable logging
                                          logger:
                                          api:
                                          ota:
                                            password: "yadda"
                                          mdns:
                                            disabled: false
                                          wifi:
                                            power_save_mode: none
                                          web_server:
                                            port: 80
                                            ota: false
                                          switch:
                                            - platform: safe_mode
                                              internal: true
                                              optimistic: true
                                              restore_state: true
                                              assumed_state: true
                                              turn_on_action:
                                                - uart.write: "sensorStart"
                                                - delay: 1s
                                              turn_off_action:
                                                - uart.write: "sensorStop"
                                                - delay: 1s
                                              optimistic: true
                                              restore_state: true
                                              assumed_state: true
                                              turn_on_action:
                                                - switch.turn_off: mmwave_sensor
                                                - delay: 1s
                                                - uart.write: "setLedMode 1 0"
                                                - delay: 1s
                                                - uart.write: "saveConfig"
                                                - delay: 3s
                                                - switch.turn_on: mmwave_sensor
                                              turn_off_action:
                                                - delay: 1s
                                                - uart.write: "setLedMode 1 1"
                                                - delay: 1s
                                                - delay: 3s
                                              optimistic: true
                                              restore_state: true
                                              assumed_state: true
                                              turn_on_action:
                                                - delay: 1s
                                                - uart.write: "setUartOutput 1 1"
                                                - delay: 1s
                                                - delay: 3s
                                              turn_off_action:
                                                - delay: 1s
                                                - uart.write: "setUartOutput 1 0"
                                                - delay: 1s
                                                - delay: 3s
                                              optimistic: true
                                              restore_state: true
                                              assumed_state: false
                                              turn_on_action:
                                                - delay: 1s
                                                - uart.write: "setUartOutput 2 1 1 1"
                                                - delay: 1s
                                                - delay: 3s
                                              turn_off_action:
                                                - delay: 1s
                                                - uart.write: "setUartOutput 2 0"
                                                - delay: 1s
                                                - delay: 3s
                                          binary_sensor:
                                          - platform: gpio
                                            pin:
                                              number: GPIO16
                                              mode: INPUT_PULLDOWN
                                          uart:
                                            tx_pin: GPIO4
                                            rx_pin: GPIO5
                                            baud_rate: 115200
                                            debug:
                                              direction: BOTH
                                              dummy_receiver: true
                                              after:
                                                delimiter: "\n"
                                              sequence:
                                                - lambda: UARTDebug::log_string(direction, bytes);
                                          number:
                                              min_value: 0
                                              max_value: 1350
                                              initial_value: 315
                                              optimistic: true
                                              step: 15
                                              restore_value: true
                                              unit_of_measurement: cm
                                              mode: box
                                              set_action:
                                                - delay: 1s
                                                - uart.write: !lambda
        int cm = (int)ceil(x / 15.0);
        std::string cms = "detRangeCfg -1 0 " + to_string(cm);
        return std::vector<unsigned char>(cms.begin(), cms.end());
                                                - delay: 1s
                                                - uart.write: "saveCfg 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
                                                - delay: 1s
                                              min_value: 0
                                              max_value: 65000
                                              initial_value: 12500
                                              optimistic: true
                                              step: 25
                                              restore_value: true
                                              unit_of_measurement: ms
                                              mode: box
                                              set_action:
                                                - delay: 1s
        int ms = (int)ceil(x / 25.0);
        std::string mss = "outputLatency -1 0 " + to_string(ms);
        return std::vector<unsigned char>(mss.begin(), mss.end());
                                                - delay: 1s
                                                - delay: 1s
                                              min_value: 0
                                              max_value: 9
                                              initial_value: 7
                                              optimistic: true
                                              step: 1
                                              restore_value: true
                                              set_action:
                                                - delay: 1s
        std::string mss = "setSensitivity " + to_string((int)x);
                                                - delay: 1s
                                                - delay: 1s
                                          button:
                                            - platform: restart
                                              name: Restart $device_name
                                              on_press:
                                                - delay: 1s
                                                - uart.write: "resetCfg"
                                                - delay: 3s
