  4. Test Adapter OpenKNX 0.6.x
587 Beiträge 74 Kommentatoren 216.5k Aufrufe 73 Beobachtet
    @chrischros
    iobroker update
    iobroker upgrade openknx@0.2.4
    iobroker upload openknx
    ChrisChros
    #336
    @thomas-braun bringt leider nicht den gewünschten erfolg.
    Cache vom Browser habe ich auch mal gelöscht, nicht das da noch was ist.
    Hier mal die Terminal-Ausgabe:
    pi@raspberrypi:~ $ iobroker update
    Used repository: Beta (latest)
    Adapter    "admin"        : 6.0.0    , installed 5.4.9  [Updatable]
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "history"      : 2.1.2    , installed 2.1.2
    Adapter    "influxdb"     : 3.1.3    , installed 3.1.3
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "modbus"       : 5.0.3    , installed 5.0.3
    Adapter    "myvbus"       : 0.2.2    , installed 0.2.2
    Adapter    "openknx"      : 0.2.4    , installed 0.2.3  [Updatable]
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "smartgarden"  : 1.0.6    , installed 1.0.6
    Adapter    "socketio"     : 6.1.4    , installed 6.1.4
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "web"          : 5.2.0    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.1.0    , installed 2.1.0
    pi@raspberrypi:~ $ iobroker upgrade openknx@0.2.4
    This upgrade of "openknx" will at least introduce the following changes:
    -> 0.2.4:
    see https://www.npmjs.com/package/iobroker.openknx
    Would you like to upgrade openknx from @0.2.3 to @0.2.4 now? [(y)es, (n)o]: y
    Update openknx from @0.2.3 to @0.2.4
    NPM version: 6.14.17
    Installing iobroker.openknx@0.2.4... (System call)
    + iobroker.openknx@0.2.4
    updated 2 packages in 19.563s
    54 packages are looking for funding
      run `npm fund` for details
    upload [14] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/exportGA.png exportGA.png image/png
    upload [13] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/index_m.html index_m.html text/html
    upload [2] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/openknx.png openknx.png image/png
    upload [1] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/style.css style.css text/css
    upload [0] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/words.js words.js application/javascript
    pi@raspberrypi:~ $ iobroker upload openknx
    • C ChrisChros
      -> 0.2.4:
      Tontechniker
      schrieb am zuletzt editiert von Tontechniker
      #337
      @chrischros Habe auf das Problem schon in meinem Beitrag vom 28. Mai hingewiesen. Leider noch keine Reaktion vom Entwickler des Adapters (@killroy2 ).
      • P Offline
        ple
        #338
        Kurze Frage in die Runde,
        aktuell ändere ich ja fast täglich was an meine GA´s und Räume dabei auf.
        Nun kann ich ja die Objekte durch den Adapter komplett neu erzeugen lassen oder halt nur neue hinzufügen.
        Besteht die Möglichkeit, dass der Adapter die aktuellen zu den neu importierenden vergleicht und nur die löscht, die nicht mehr im neuen Ga Export auftauchen?
        Hatte es jetzt, dass ich einige Beschriftungen geändert habe, die wurden auch richtig angelegt, aber die alten, die falsch beschrieben waren, waren halt auch noch da.
        Komplett neu erzeugen könnte ich, aber dann sind die Smarthomegeräte nicht mehr verlinkt sowie die History Daten. Das ist echt viel Aufwand, wenn man mal was ändert.
        Gruß und Danke und ganz viel Lob für den tollen Adapter.
        Intel Nuc + Proxmox
        T K 2 Antworten Letzte Antwort
        • P ple
          Tontechniker
          #339
          @ple Ist eventuell nicht sinnvoll. Ich habe schon öfter GA-Änderungen eingespielt, anschließend von der vorherigen GA teile der Objektdaten kopiert und in die aktuelle GA eingefügt. Anschließend die alte GA gelöscht.
          themuckT 1 Antwort Letzte Antwort
          • T Tontechniker
            themuckT Offline
            themuckT Offline
            themuck
            #340
            ich hab den Adapter in meiner Testumgebung am laufen. Er zieht sich Werte vom KNX Bus wenn ich einen Taster drücke, nur wie schreibe ich dort Werte? Mit blockly habe ich die Temperatur der Wetter Station in ein KNX Objekt geschrieben, das wird auch unter Objekte aktualisiert aber geht dann nicht auf den KNX Bus. Umgekehrt, schreibe ich auf die Adresse über den Bus Monitor einen Wert, aktualisiert sich der der Wert in Smart Taster, aber im IObroker kommt an der Stelle der Wert nicht an.
            Ich vermute ich habe da einen Denkfehler... Vielleicht kann mir da jemand kurz auf die Sprünge helfen?
            • themuckT themuck
              Tontechniker
              #341
              @themuck Du kannst Dir die Nodes "KNX Ultimate" in Node Red installieren (von Node Red-Webseite). Anschließend die Node "KNX-Device" in den Flow einfügen und in dieser die Parameter einstellen (Gateway, Gruppenadresse, Datenpunkt, usw). Dann im Flow z.B. mit der Node "IoBroker-In" mit Deiner Variablen verbinden. Wenn Du da nicht weiter kommst, kann ich Dir das in einem Beispiel zeigen (morgen!).
              • T Tontechniker
                themuckT Offline
                themuckT Offline
                themuck
                #342
                @tontechniker danke für die Info. Also funktioniert der Weg über blockly + den KNX Adapter so nicht? Sowas dachte ich mir... Das mit NodeRed werde ich dann Mal ausprobieren.
                • themuckT themuck
                  Tontechniker
                  #343
                  @themuck Um auf den KNX-Bus zu schreiben, mußt Du den Wert der Variablen auf die entsprechende Gruppenadresse schreiben. Das geschieht mit der Node "KNX-Device". Die Einstellungen sind etwas kompliziert, deshalb melde Dich bitte und investiere nicht zu viel Zeit für das Ausprobieren. Ich kann Dir gern ein Beispiel schicken.
                  Hans
                  • K killroy2
                    @tro Ich glaube ich kann es nachvollziehen, ich melde mich wieder wenn das Problem demnächst behoben ist.
                    tro
                    #344
                    @killroy2 Hast Du hierzu inzwischen schon was gefunden?
                    • T Tontechniker
                      Hans
                      themuckT Offline
                      themuckT Offline
                      themuck
                      #345
                      @tontechniker hat auf anhieb geklappt... die Temperatur von der IP Wetterstation liegt jetzt auf dem Glastaster ;).
                      • N Offline
                        N Offline
                        netfriend
                        #346
                        ich habe ein akutes Problem:
                        Hatte den Adapter neu gestartet und nun ein Problem, mit dem ich nichts anzufangen weiß. Diese Konstellation lief nun monatelang, im Log steht folgendes:
                        host.Raspi4
                        2022-06-14 18:21:21.139	info	Restart adapter system.adapter.openknx.0 because enabled
                        host.Raspi4
                        2022-06-14 18:21:21.139	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.Raspi4
                        2022-06-14 18:21:21.138	error	Caught by controller[0]: }
                        host.Raspi4
                        2022-06-14 18:21:21.138	error	Caught by controller[0]: ]
                        host.Raspi4
                        2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
                        host.Raspi4
                        2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
                        host.Raspi4
                        2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
                        host.Raspi4
                        2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js',
                        host.Raspi4
                        2022-06-14 18:21:21.137	error	Caught by controller[0]: requireStack: [
                        host.Raspi4
                        2022-06-14 18:21:21.137	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                        host.Raspi4
                        2022-06-14 18:21:21.137	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19) {
                        host.Raspi4
                        2022-06-14 18:21:21.137	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                        host.Raspi4
                        2022-06-14 18:21:21.137	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                        host.Raspi4
                        2022-06-14 18:21:21.137	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                        host.Raspi4
                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                        host.Raspi4
                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js:8:16)
                        host.Raspi4
                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                        host.Raspi4
                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                        host.Raspi4
                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                        host.Raspi4
                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                        host.Raspi4
                        2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
                        host.Raspi4
                        2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
                        host.Raspi4
                        2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
                        host.Raspi4
                        2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js
                        host.Raspi4
                        2022-06-14 18:21:21.135	error	Caught by controller[0]: Require stack:
                        host.Raspi4
                        2022-06-14 18:21:21.135	error	Caught by controller[0]: Error: Cannot find module 'binary-parser'
                        host.Raspi4
                        2022-06-14 18:21:21.134	error	Caught by controller[0]: ^
                        host.Raspi4
                        2022-06-14 18:21:21.134	error	Caught by controller[0]: throw err;
                        host.Raspi4
                        2022-06-14 18:21:21.134	error	Caught by controller[0]: internal/modules/cjs/loader.js:905
                        host.Raspi4
                        2022-06-14 18:21:20.245	info	instance system.adapter.openknx.0 started with pid 30715
                        Kann mir bitte jemand weiterhelfen. Was soll mir der Fehlereintrag sagen?
                        • N Offline
                          N Offline
                          netfriend
                          #347
                          Nach längerem Suchen und Probieren habe ich openknx nochmal aktualisiert (wieder auf die selbe Version) und siehe da, es funktioniert wieder alles. Hier scheint es irgendwas zerlegt zu haben.
                          • T Tontechniker
                            @killroy2 Habe versucht von 0.2.3 auf 0.2.4 ein Update zu machen. Update laüft ohne Fehlermeldung durch, Versionsnummer wird aber in "Adapter" nicht aktualisiert.
                            In "Instanzen" steht in der obersten Zeile "Instanzeinstellungen: openknx.0 v0.2.3" obwohl ich ohne Fehlermeldung ("Process exited with code 0") die 0.2.4 installiert habe.
                            killroy2
                            #348
                            @tontechniker ich habs nicht genauer untersucht, ich bringe demnächst ein Update heraus und hoffe dass es dadurch automatisch behoben ist.
                              killroy2
                              #349
                              @themuck sicher geht das, genauso wie du mit Blockly auf andere Objekte schreibst, so kannst du auf KNX Objekte schreiben und damit eine Aktion auf dem Bus auslösen.
                              • T tro
                                killroy2
                                #350
                                @tro bisher bei mir nichts weiter aufgefallen; kannst du dein Setup so exakt wie möglich beschreiben, und wann der Fehler auftritt? Am besten eine Möglichkeit zum Reproduzieren. Mach am besten einen Issue im Github auf, dann sind alle Infos zusammen
                                • P ple
                                  killroy2
                                  #351
                                  @ple habe ich eingebaut, schau es dir mal an, ab Version 0.2.5
                                  T P 2 Antworten Letzte Antwort
                                  • K killroy2
                                    Tontechniker
                                    #352
                                    @killroy2 Habe eben die Version 0.2.5 installiert - funktioniert soweit!
                                    Vielen Dank!!
                                    • K killroy2
                                      ple
                                      #353
                                      @killroy2 sagte in Test Adapter OpenKNX 0.2.x:
                                      Das klappt schon mal, kannst das für die Alias dann auch einbauen?
                                      Gruß und Danke
                                      Intel Nuc + Proxmox
                                      • P ple
                                        Gruß und Danke
                                        killroy2
                                        #354
                                        @ple Alias Generierung berücksichtigt ja beim nächsten Lauf nach Import die Namen neu und aktualisiert ggf.
                                          adb
                                          #355
                                          Guten Abend,
                                          ich habe ein Problem, dass bei einigen KNX Teilnehmern die Werte gemäß Log vom KNX-Bux gelesen werden, aber nicht in dem zugehörigen Objekt gespeichert werden.
                                          Beispiel 4/0/114:
                                          Wenn die ETS einen Wert an die 4/0/114 sendet, wird es korrekt erkannt und im Objekt eingetragen.
                                          Wenn der Teilnehmer (GA: 1.1.1) den Wert sendet, wird der Wert noch erkannt, eine Wertänderung festgestellt, aber kein Wert im Objekt eingetragen.
                                          Im ersten Versuch habe ich die Objekte über einen XML-Import erzeugen lassen. Zum Testen habe ich jetzt aber eine eigene Instanz angelegt und den Wert manuell angelegt.
                                          Vermutlich nur eine Kleinigkeit.... Aber alle meine Versuche sind bis jetzt gescheitert.
                                          Schon vorab vielen Dank.
