  4. Test Adapter OpenKNX 0.6.x
587 Beiträge 74 Kommentatoren 216.5k Aufrufe 73 Beobachtet
  • N Offline
    N Offline
    netfriend
    #346
    ich habe ein akutes Problem:
    Hatte den Adapter neu gestartet und nun ein Problem, mit dem ich nichts anzufangen weiß. Diese Konstellation lief nun monatelang, im Log steht folgendes:
    host.Raspi4
    2022-06-14 18:21:21.139	info	Restart adapter system.adapter.openknx.0 because enabled
    host.Raspi4
    2022-06-14 18:21:21.139	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.Raspi4
    2022-06-14 18:21:21.138	error	Caught by controller[0]: }
    host.Raspi4
    2022-06-14 18:21:21.138	error	Caught by controller[0]: ]
    host.Raspi4
    2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
    host.Raspi4
    2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
    host.Raspi4
    2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
    host.Raspi4
    2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js',
    host.Raspi4
    2022-06-14 18:21:21.137	error	Caught by controller[0]: requireStack: [
    host.Raspi4
    2022-06-14 18:21:21.137	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.Raspi4
    2022-06-14 18:21:21.137	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19) {
    host.Raspi4
    2022-06-14 18:21:21.137	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    host.Raspi4
    2022-06-14 18:21:21.137	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.Raspi4
    2022-06-14 18:21:21.137	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.Raspi4
    2022-06-14 18:21:21.136	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.Raspi4
    2022-06-14 18:21:21.136	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js:8:16)
    host.Raspi4
    2022-06-14 18:21:21.136	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    host.Raspi4
    2022-06-14 18:21:21.136	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    host.Raspi4
    2022-06-14 18:21:21.136	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
    host.Raspi4
    2022-06-14 18:21:21.136	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
    host.Raspi4
    2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
    host.Raspi4
    2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
    host.Raspi4
    2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
    host.Raspi4
    2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js
    host.Raspi4
    2022-06-14 18:21:21.135	error	Caught by controller[0]: Require stack:
    host.Raspi4
    2022-06-14 18:21:21.135	error	Caught by controller[0]: Error: Cannot find module 'binary-parser'
    host.Raspi4
    2022-06-14 18:21:21.134	error	Caught by controller[0]: ^
    host.Raspi4
    2022-06-14 18:21:21.134	error	Caught by controller[0]: throw err;
    host.Raspi4
    2022-06-14 18:21:21.134	error	Caught by controller[0]: internal/modules/cjs/loader.js:905
    host.Raspi4
    2022-06-14 18:21:20.245	info	instance system.adapter.openknx.0 started with pid 30715
    Kann mir bitte jemand weiterhelfen. Was soll mir der Fehlereintrag sagen?
    • N Offline
      N Offline
      netfriend
      #347
      Nach längerem Suchen und Probieren habe ich openknx nochmal aktualisiert (wieder auf die selbe Version) und siehe da, es funktioniert wieder alles. Hier scheint es irgendwas zerlegt zu haben.
      • T Tontechniker
        @killroy2 Habe versucht von 0.2.3 auf 0.2.4 ein Update zu machen. Update laüft ohne Fehlermeldung durch, Versionsnummer wird aber in "Adapter" nicht aktualisiert.
        In "Instanzen" steht in der obersten Zeile "Instanzeinstellungen: openknx.0 v0.2.3" obwohl ich ohne Fehlermeldung ("Process exited with code 0") die 0.2.4 installiert habe.
        killroy2
        #348
        @tontechniker ich habs nicht genauer untersucht, ich bringe demnächst ein Update heraus und hoffe dass es dadurch automatisch behoben ist.
          killroy2
          #349
          @themuck sicher geht das, genauso wie du mit Blockly auf andere Objekte schreibst, so kannst du auf KNX Objekte schreiben und damit eine Aktion auf dem Bus auslösen.
          • T tro
            @killroy2 Hast Du hierzu inzwischen schon was gefunden?
            killroy2
            #350
            @tro bisher bei mir nichts weiter aufgefallen; kannst du dein Setup so exakt wie möglich beschreiben, und wann der Fehler auftritt? Am besten eine Möglichkeit zum Reproduzieren. Mach am besten einen Issue im Github auf, dann sind alle Infos zusammen
            • P ple
              Kurze Frage in die Runde,
              aktuell ändere ich ja fast täglich was an meine GA´s und Räume dabei auf.
              Nun kann ich ja die Objekte durch den Adapter komplett neu erzeugen lassen oder halt nur neue hinzufügen.
              Besteht die Möglichkeit, dass der Adapter die aktuellen zu den neu importierenden vergleicht und nur die löscht, die nicht mehr im neuen Ga Export auftauchen?
              Hatte es jetzt, dass ich einige Beschriftungen geändert habe, die wurden auch richtig angelegt, aber die alten, die falsch beschrieben waren, waren halt auch noch da.
              Komplett neu erzeugen könnte ich, aber dann sind die Smarthomegeräte nicht mehr verlinkt sowie die History Daten. Das ist echt viel Aufwand, wenn man mal was ändert.
              Gruß und Danke und ganz viel Lob für den tollen Adapter.
              killroy2
              #351
              @ple habe ich eingebaut, schau es dir mal an, ab Version 0.2.5
              T P 2 Antworten Letzte Antwort
              • K killroy2
                Tontechniker
                #352
                @killroy2 Habe eben die Version 0.2.5 installiert - funktioniert soweit!
                Vielen Dank!!
                • K killroy2
                  ple
                  #353
                  @killroy2 sagte in Test Adapter OpenKNX 0.2.x:
                  Das klappt schon mal, kannst das für die Alias dann auch einbauen?
                  Gruß und Danke
                  Intel Nuc + Proxmox
                  • P ple
                    Gruß und Danke
                    killroy2
                    #354
                    @ple Alias Generierung berücksichtigt ja beim nächsten Lauf nach Import die Namen neu und aktualisiert ggf.
                      adb
                      #355
                      Guten Abend,
                      ich habe ein Problem, dass bei einigen KNX Teilnehmern die Werte gemäß Log vom KNX-Bux gelesen werden, aber nicht in dem zugehörigen Objekt gespeichert werden.
                      Beispiel 4/0/114:
                      Wenn die ETS einen Wert an die 4/0/114 sendet, wird es korrekt erkannt und im Objekt eingetragen.
                      Wenn der Teilnehmer (GA: 1.1.1) den Wert sendet, wird der Wert noch erkannt, eine Wertänderung festgestellt, aber kein Wert im Objekt eingetragen.
                      Im ersten Versuch habe ich die Objekte über einen XML-Import erzeugen lassen. Zum Testen habe ich jetzt aber eine eigene Instanz angelegt und den Wert manuell angelegt.
                      Vermutlich nur eine Kleinigkeit.... Aber alle meine Versuche sind bis jetzt gescheitert.
                      Schon vorab vielen Dank.
                      • A adb
                        Guten Abend,
                        Beispiel 4/0/114:
                        killroy2
                        #356
                        @adb zeig mal die Json Objektdaten von Test-01 welches den Fehler hat.
                        A 2 Antworten Letzte Antwort
                        • K killroy2
                          adb
                          schrieb am zuletzt editiert von adb
                          #357
                          @killroy2
                          Sorry - wollte ich eigentlich noch eingefügt haben.. Aber jetzt:
                            "common": {
                              "name": "Test-01",
                              "desc": "Manuell erzeugt",
                              "role": "state",
                              "type": "number",
                              "read": true,
                              "write": false,
                              "def": 0
                            "native": {
                              "address": "4/0/114",
                              "dpt": "DPT9.001",
                              "answer_groupValueResponse": true,
                              "autoread": true,
                              "bitlength": 16
                            "type": "state",
                            "_id": "openknx.1.Test.Test-01",
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                              "owner": "system.user.admin",
                            "user": "system.user.admin",
                            "ts": 1656963969899
                          • K killroy2
                            adb
                            #358
                            @killroy2
                            Hatte eben noch etwas probiert und bin noch mehr verwundert.
                            Wenn der Wert direkt vom Taster gesendet wird, erkennt der Adapter die Wertänderung, schreibt diese aber scheinbar nicht in das Objekt. Wenn ich die KNX-Variable per ETS schreibe, kommen die Werte ebenfalls an und werde in das Objekt übernommen.
                            [trace] 2022-07-08 18:42:00.954 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"1.1.1","dest_addr":"4/0/114","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,12,123]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[12,123]}}}}
                            [trace] 2022-07-08 18:42:00.954 2022-07-08 18:42:00 **** (4/0/114) 22.94 °C DATAPOINT CHANGE (was: 22.96)
                            *** per ETS den Wert 22 an die GA 4/0/114 geschickt ***
                            [trace] 2022-07-08 18:42:28.255 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"15.15.255","dest_addr":"4/0/114","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,12,76]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[12,76]}}}}
                            [trace] 2022-07-08 18:42:28.255 2022-07-08 18:42:28 **** (4/0/114) 22 °C DATAPOINT CHANGE (was: 22.94)
                            Inbound GroupValue_Write from 15.15.255 GA 4/0/114 to Object: openknx.1.Test.Test-01 val: 22 dpt: DPT9.001
                            [trace] 2022-07-08 18:43:00.945 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"1.1.1","dest_addr":"4/0/114","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,12,123]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[12,123]}}}}
                            [trace] 2022-07-08 18:43:00.946 2022-07-08 18:43:00 **** (4/0/114) 22.94 °C DATAPOINT CHANGE (was: 22)
                              killroy2
                              #359
                              @adb
                              ich habe einen Fehler gefunden,
                              als Quickfix versuche mal die Adresse 1.1.1 vom Taster auf irgend einen anderen Wert zu ändern oder
                              lade die Config runter, entferne die Zeile mit "eibadr" und lade sie wieder hoch.
                              • K killroy2
                                @adb
                                adb
                                #360
                                @killroy2
                                Die Adresse wollte gerne beibehalten, daher habe ich zunächst probiert die "eibadr" auf einen anderen Wert zu setzen (wäre ja schön im Busmonitor zu sehen, wer die Telegramme abschickt). Hatte aber nicht funktioniert. Nach dem löschen des Eintrages in der Config funktioniert es jetzt.
                                Vielen Dank
                                • P Offline
                                  ple
                                  #361
                                  Hallo noch mal zusammen,
                                  Ich bin zwar noch lange nicht fertig mit den Logiken und teste gerade aus, ob ich beim Gira X1 bleibe oder doch eher auf iobroker gehe, da kenne ich mich wenigsten mit aus und liegt mir deutlich besser für Automatismen mit Javascript.
                                  Aktuell versuche ich mich an Jarvis, meine letzte Visu stammt von vor 4 Jahren, da hat sich anscheinend viel getan in letzter Zeit.
                                  Jetzt mal zur Frage.
                                  Könnten vielleicht die Importierten Datenpunkte vielleicht mit mehr Infos gefüllt werden wie
                                  "role": "value.temperature"
                                  Anhand der DTP´s vielleicht mappen?
                                  Gruß und Danke.
                                  Intel Nuc + Proxmox
                                  J P 2 Antworten Letzte Antwort
                                  • P ple
                                    Gruß und Danke.
                                    jampr
                                    #362
                                    Hi zusammen,
                                    ich versuche gerade einen Wert vom Aktor abzurufen.
                                    So sieht er aus:
                                      "_id": "openknx.0.Obergeschoss.Heizungsraum.Wirkleistung_A",
                                      "type": "state",
                                      "common": {
                                        "name": "Wirkleistung A",
                                        "type": "number",
                                        "read": true,
                                        "write": false,
                                        "role": "value"
                                      "native": {
                                        "dpt": "DPT14.056",
                                        "address": "2/5/11",
                                        "answer_groupValueResponse": false,
                                        "autoread": true
                                      "acl": {
                                        "object": 1636,
                                        "state": 1636,
                                      "ts": 1646756139273
                                    wenn ich den aber abrufe mit setState(Wirkleistung_A, {val: 0, ack: false, q:0x10}); wird mein Log zugespammt mit
                                    	Read-only state "openknx.0.Obergeschoss.Heizungsraum.Wirkleistung_A" has been written without ack-flag with value "0"
                                    Wenn ich ACK auf true setze, bekomme ich nur die 0 ausgelesen. Ist also keine Option. Hat jemand einen Tipp, wie ich die Meldung im Log weg bekomme?
                                    LG
                                      killroy2
                                      #363
                                      @jampr said in Test Adapter OpenKNX 0.2.x:
                                      Bei dir steht
                                      "write": false,
                                      setze mal auf true, dann sollte die Meldung nicht kommen.
                                      • K killroy2
                                        Bei dir steht
                                        "write": false,
                                        jampr
                                        #364
                                        @killroy2
                                        danke, jetzt ist es Ok. Das war noch vom KNX-Objekte-Laden. Ich habe mich nicht getraut, daran was zu verändern.
                                        • P ple
                                          Gruß und Danke.
                                          ple
                                          #365
                                          @ple sagte in Test Adapter OpenKNX 0.2.x:
                                          Gruß und Danke.
                                          Wollte kurz pushen, ob es möglich wäre die so ein mapping zu machen, um die Datenpunkte mit mehr Infos zu füllen.
                                          Gruß und Danke
                                          Intel Nuc + Proxmox
