  4. Adapter "smartmeter"
    apollon77A
3.6k Beiträge 281 Kommentatoren 3.5m Aufrufe 162 Beobachtet
  • M MichaelW 0
    @klassisch
    Inf on ist ebenfalls eingestellt.
    @apollon77 kannst du da bitte mal drüberschaun ob mein Zähler die Leistung in Watt auch sendet bzw der Adapter etwas empfängt
    host.raspberrypi
    2022-06-04 07:16:14.219	info	instance system.adapter.smartmeter.0 started with pid 27327
    host.raspberrypi
    2022-06-04 07:16:11.702	info	instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    smartmeter.0
    2022-06-04 07:16:11.180	debug	connected set to false
    smartmeter.0
    2022-06-04 07:16:11.156	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    smartmeter.0
    2022-06-04 07:16:11.155	debug	Plugin sentry destroyed
    smartmeter.0
    2022-06-04 07:16:11.153	info	terminating
    smartmeter.0
    2022-06-04 07:16:11.145	info	Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi
    2022-06-04 07:16:11.140	info	stopInstance system.adapter.smartmeter.0 send kill signal
    host.raspberrypi
    2022-06-04 07:16:11.128	info	stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    smartmeter.0
    2022-06-04 07:16:07.778	debug	SERIALPORT CLOSE
    smartmeter.0
    2022-06-04 07:16:07.772	debug	SCHEDULE NEXT RUN IN 5s
    smartmeter.0
    2022-06-04 07:16:07.769	debug	RESUME READING SERIALPORT
    smartmeter.0
    2022-06-04 07:16:07.769	debug	SET MESSAGE TIMEOUT TIMER: 5000
    smartmeter.0
    2022-06-04 07:16:07.769	info	Received 6 values, 0 updated
    smartmeter.0
    2022-06-04 07:16:07.768	debug	Data for 1-0:2_8_0__255 unchanged
    smartmeter.0
    2022-06-04 07:16:07.768	debug	1-0:2.8.0*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (Total) = 20 kWh
    smartmeter.0
    2022-06-04 07:16:07.768	debug	Data for 1-0:1_8_2__255 unchanged
    smartmeter.0
    2022-06-04 07:16:07.766	debug	1-0:1.8.2*255: Zählerstand 1 Summe Wirkarbeit Bezug + (T2) = 1980 kWh
    smartmeter.0
    2022-06-04 07:16:07.765	debug	Data for 1-0:1_8_1__255 unchanged
    smartmeter.0
    2022-06-04 07:16:07.765	debug	1-0:1.8.1*255: Zählerstand 1 Summe Wirkarbeit Bezug + (T1) = 2953 kWh
    smartmeter.0
    2022-06-04 07:16:07.765	debug	Data for 1-0:1_8_0__255 unchanged
    smartmeter.0
    2022-06-04 07:16:07.764	debug	1-0:1.8.0*255: Zählerstand 1 Summe Wirkarbeit Bezug + (Total) = 4933 kWh
    smartmeter.0
    2022-06-04 07:16:07.764	debug	Data for 1-0:96_1_0__255 unchanged
    smartmeter.0
    2022-06-04 07:16:07.764	debug	1-0:96.1.0*255: Serialnumber = 0a01445a47000399c129
    smartmeter.0
    2022-06-04 07:16:07.763	debug	Data for 1-0:96_50_1__1 unchanged
    smartmeter.0
    2022-06-04 07:16:07.763	debug	1-0:96.50.1*1: Wartungseintrag (T1) letztes Jahr = DZG
    smartmeter.0
    2022-06-04 07:16:07.762	debug	STORE DATA
    smartmeter.0
    2022-06-04 07:16:07.761	debug	SML MESSAGE: START SML-File START SmlMessage Transaction-ID: �p (eb700700) Group-No: 0 Abort On Error: 0 Message-Body: SmlPublicOpenResponse Codepage: undefined Client-ID: undefined Req-FileId: 1 (31) Server-ID: 0a01445a47000399c129 (Sec-Index): 39019029 Sml-Version: 2 CRC 16: valid END SmlMessage START SmlMessage Transaction-ID: �p (ec700700) Group-No: 0 Abort On Error: 0 Message-Body: SmlGetListResponse Client-ID: undefined Server-ID: DZG��) List-Name: b�� Act-Sensor-Time: (Sec-Index): 39019029 ValList: [ Obj-Name: 1-0:96.50.1*1 Status: undefined Val-Time: (Sec-Index): 0 Unit: 0 Scaler: 0 Value: DZG Value-Signature: undefined, Obj-Name: 1-0:96.1.0*255 Status: undefined Val-Time: (Sec-Index): 0 Unit: 0 Scaler: 0 Value: DZG��) Value-Signature: undefined, Obj-Name: 1-0:1.8.0*255 Status: 1ca104 Val-Time: (Sec-Index): 0 Unit: 30 Scaler: 3 Value: 4933 Value-Signature: undefined, Obj-Name: 1-0:1.8.1*255 Status: undefined Val-Time: (Sec-Index): 0 Unit: 30 Scaler: 3 Value: 2953 Value-Signature: undefined, Obj-Name: 1-0:1.8.2*255 Status: undefined Val-Time: (Sec-Index): 0 Unit: 30 Scaler: 3 Value: 1980 Value-Signature: undefined, Obj-Name: 1-0:2.8.0*255 Status: undefined Val-Time: (Sec-Index): 0 Unit: 30 Scaler: 3 Value: 20 Value-Signature: undefined, ] List-Signature: undefined Act-Gateway-Time: CRC 16: valid END SmlMessage START SmlMessage Transaction-ID: �p (ed700700) Group-No: 0 Abort On Error: 0 Message-Body: SmlPublicCloseResponse Global Signature: CRC 16: valid END SmlMessageEND SML-File
    smartmeter.0
    2022-06-04 07:16:07.760	debug	MSG IDX 0
    smartmeter.0
    2022-06-04 07:16:07.760	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
    smartmeter.0
    2022-06-04 07:16:07.760	debug	MATCH-RESULT MESSAGE: "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" -> [ "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", "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", "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", "0"]
    smartmeter.0
    2022-06-04 07:16:07.759	debug	ADD NEW DATA (271 + NEW 1)
    smartmeter.0
    2022-06-04 07:16:07.758	debug	MATCH-RESULT MESSAGE: "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" -> null
    smartmeter.0
    2022-06-04 07:16:07.758	debug	ADD NEW DATA (270 + NEW 1)
    smartmeter.0
    2022-06-04 07:16:07.756	debug	MATCH-RESULT MESSAGE: "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" -> null
    smartmeter.0
    2022-06-04 07:16:07.756	debug	ADD NEW DATA (268 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.754	debug	MATCH-RESULT MESSAGE: "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" -> null
    smartmeter.0
    2022-06-04 07:16:07.754	debug	ADD NEW DATA (266 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.752	debug	MATCH-RESULT MESSAGE: "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" -> null
    smartmeter.0
    2022-06-04 07:16:07.752	debug	ADD NEW DATA (264 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.751	debug	MATCH-RESULT MESSAGE: "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" -> null
    smartmeter.0
    2022-06-04 07:16:07.750	debug	ADD NEW DATA (263 + NEW 1)
    smartmeter.0
    2022-06-04 07:16:07.749	debug	MATCH-RESULT MESSAGE: "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" -> null
    smartmeter.0
    2022-06-04 07:16:07.748	debug	ADD NEW DATA (261 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.747	debug	MATCH-RESULT MESSAGE: "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" -> null
    smartmeter.0
    2022-06-04 07:16:07.746	debug	ADD NEW DATA (259 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.745	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff017262016200621e52036214010101632ca0007605ed700700620062007263020171" -> null
    smartmeter.0
    2022-06-04 07:16:07.745	debug	ADD NEW DATA (257 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.743	debug	MATCH-RESULT MESSAGE: "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" -> null
    smartmeter.0
    2022-06-04 07:16:07.743	debug	ADD NEW DATA (255 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.741	debug	MATCH-RESULT MESSAGE: "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" -> null
    smartmeter.0
    2022-06-04 07:16:07.740	debug	ADD NEW DATA (244 + NEW 11)
    smartmeter.0
    2022-06-04 07:16:07.739	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff017262016200621e52036214010101632ca000" -> null
    smartmeter.0
    2022-06-04 07:16:07.729	debug	ADD NEW DATA (242 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.727	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff017262016200621e52036214010101632c" -> null
    smartmeter.0
    2022-06-04 07:16:07.727	debug	ADD NEW DATA (240 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.725	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff017262016200621e52036214010101" -> null
    smartmeter.0
    2022-06-04 07:16:07.725	debug	ADD NEW DATA (239 + NEW 1)
    smartmeter.0
    2022-06-04 07:16:07.723	debug	ADD NEW DATA (237 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.722	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff017262016200621e52036214" -> null
    smartmeter.0
    2022-06-04 07:16:07.723	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff017262016200621e520362140101" -> null
    smartmeter.0
    2022-06-04 07:16:07.721	debug	ADD NEW DATA (235 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.720	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff017262016200621e5203" -> null
    smartmeter.0
    2022-06-04 07:16:07.720	debug	ADD NEW DATA (233 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.718	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff017262016200621e" -> null
    smartmeter.0
    2022-06-04 07:16:07.718	debug	ADD NEW DATA (232 + NEW 1)
    smartmeter.0
    2022-06-04 07:16:07.716	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff01726201620062" -> null
    smartmeter.0
    2022-06-04 07:16:07.716	debug	ADD NEW DATA (231 + NEW 1)
    smartmeter.0
    2022-06-04 07:16:07.715	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff017262016200" -> null
    smartmeter.0
    2022-06-04 07:16:07.714	debug	ADD NEW DATA (230 + NEW 1)
    smartmeter.0
    2022-06-04 07:16:07.713	debug	ADD NEW DATA (228 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.712	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff017262" -> null
    smartmeter.0
    2022-06-04 07:16:07.713	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff0172620162" -> null
    smartmeter.0
    2022-06-04 07:16:07.712	debug	ADD NEW DATA (227 + NEW 1)
    smartmeter.0
    2022-06-04 07:16:07.711	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff0172" -> null
    smartmeter.0
    2022-06-04 07:16:07.710	debug	ADD NEW DATA (225 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.709	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177070100020800ff" -> null
    smartmeter.0
    2022-06-04 07:16:07.709	debug	ADD NEW DATA (223 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.707	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc01770701000208" -> null
    smartmeter.0
    2022-06-04 07:16:07.707	debug	ADD NEW DATA (222 + NEW 1)
    smartmeter.0
    2022-06-04 07:16:07.706	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc017707010002" -> null
    smartmeter.0
    2022-06-04 07:16:07.705	debug	ADD NEW DATA (220 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.704	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc01770701" -> null
    smartmeter.0
    2022-06-04 07:16:07.703	debug	ADD NEW DATA (218 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.702	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e52036307bc0177" -> null
    smartmeter.0
    2022-06-04 07:16:07.702	debug	ADD NEW DATA (214 + NEW 4)
    smartmeter.0
    2022-06-04 07:16:07.698	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e520363" -> null
    smartmeter.0
    2022-06-04 07:16:07.697	debug	ADD NEW DATA (213 + NEW 1)
    smartmeter.0
    2022-06-04 07:16:07.696	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e5203" -> null
    smartmeter.0
    2022-06-04 07:16:07.696	debug	ADD NEW DATA (211 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.695	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200621e" -> null
    smartmeter.0
    2022-06-04 07:16:07.694	debug	ADD NEW DATA (209 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.693	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262016200" -> null
    smartmeter.0
    2022-06-04 07:16:07.692	debug	ADD NEW DATA (207 + NEW 2)
    smartmeter.0
    2022-06-04 07:16:07.691	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff01726201" -> null
    smartmeter.0
    2022-06-04 07:16:07.690	debug	ADD NEW DATA (206 + NEW 1)
    smartmeter.0
    2022-06-04 07:16:07.689	debug	MATCH-RESULT MESSAGE: "1b1b1b1b010101017605eb700700620062007263010176010102310b0a01445a47000399c12972620165025362156202635d24007605ec700700620062007263070177010b0a01445a47000399c129070100620affff72620165025362157677070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a47000399c1290177070100010800ff641ca1047262016200621e52036313450177070100010801ff017262016200621e5203630b890177070100010802ff017262" -> null
    smartmeter.0
    2022-06-04 07:16:07.688	debug	ADD NEW DATA (204 + NEW 2)
    Mod-Edit: Code in </> Code-Tag gepackt!
    apollon77A
    apollon77A
    #2640
    @michaelw-0 nee tut er nicht. Das log ist da sehr eindeutig. Ggf zeig deinem Netzbetreiber die sml rohdaten und das gepaarte Ergebnis.
    • L
      L
      LJSven
      #2641
      ich habe eine PV Anlage bekommen und in der Zusammenhang auch einen neuen Zähler. Nach einigen Test habe ich irgendwo gelesen, dass der Lesekopf oben angebracht werden muss. Da bekomme ich jetzt auch Werte. Ist das bei anderen auch so? Über die Schnittstelle vorne bekomme ich nichts rein.
      Der Zähler ist ein eBZ DD3!
      • L LJSven
        #2642
        @ljsven sagte in Adapter "smartmeter":
        bitte ausreichend Infos liefern
        L 1 Antwort Letzte Antwort
          L
          L
          LJSven
          #2643
          @homoran sagte in Adapter "smartmeter":
          Ich will nur wissen, ob es richtig ist, dass die Werte von oben (wie es auf dem Bild installiert ist) auszulesen sind, und wofür die Schnittstelle vorn ist. Die geht bei mir nicht.
          K HomoranH 2 Antworten Letzte Antwort
          • L LJSven
            K
            K
            klassisch
            #2644
            @ljsven Kommen die Werte über die obige Schnittstelle richtig an?
            Falls ja, dann ist das Ziel erreicht.
            Es gibt viele verschiedene Zähler und eine Vielzahl von Konfigurationen durch die Meßstellenbetreiber.
            Wenn ich mir die Beschriftung auf dem Bild ansehe, würde ich behaupten. die Info Schnittstelle sei vorne.
            Aber am Ende hat aber das Experiment recht. Und wenn Du die Werte oben korrekt abgreifen kannst, dann ist das bei Deinem Zähler und Deinem Betreiber halt so. Hauptsache es funktioniert.
            L HomoranH 2 Antworten Letzte Antwort
            • K klassisch
              L
              L
              LJSven
              #2645
              @klassisch Ja, die Werte kommen richtig an.
              • L LJSven
                K
                K
                klassisch
                #2646
                @ljsven Prima! Seltsames Verhalten. Vielleicht hilt diese Info einem anderen Nutzer dieses Meters.
                • L LJSven
                  #2647
                  was steht denn in der Anleitung von deinem Netzbetreiber?
                  Ich habe diesen Zähler nicht.
                  und von welchem Hersteller?
                  bitte due notwendigen Informationen zur Verfügung stellen
                  • K klassisch
                    #2648
                    @klassisch sagte in Adapter "smartmeter":
                    hier im Forum wurde ein solcher Zähler beschrieben, dessen Schnittstlle oben sein soll.
                    • N
                      N
                      novregen
                      #2649
                      ich lese meinen Stromzähler mit einem Weidmann Lesekopf aus und bekomme über Smartmeter auch zuverlässig den Zählerstand.
                      Mein Frage gibt es auch irgendwie die Möglichkeit einen Momentanwert in Watt auszulesen ?
                      In den Objekten gibt es zwar drei Einträge mit Momentanwert Wartungseingang T1 / T2 / T3 aber damit kann ich nichts anfangen bzw. wurden diese Datenpunkte auch schon ewig nicht aktualisiert.
                      Wahrscheinlich geht hier nicht mehr, aber vielleicht hat ja noch jemand von euch einen Tipp oder ihr könnt einfach nur bestätigen das es so ist. Danke
                      • N novregen
                        K
                        K
                        klassisch
                        #2650
                        @novregen sagte in Adapter "smartmeter":
                        Das klingt schon mal gut. Verbindung steht und funmtioniert
                        Bei einer "modernen Meßeinrichtung" mit optischer Info-Schnittstelle sollte laut FNN Lastenheft der Momentanwert der Leistung zur Verfügung gestellt werden wenn die PIN eingegeben ist udn die Info Schnittstelle freigeschaltet ist.
                        Handelt es sich hier um eine intelligente Meßeinrichtung oder ist es ein anderer Zähler?
                        Ist die Pin eingegeben und alles laut Anleitung freigeschaltet?
                        Der Wartungseintrag ist irgendetwas anderes. Für mich scheint der nutzlos
                        Die Momentanleistung kommt bei mir in einem Register bzw. Datenpunkt, der so heißt:
                        smartmeter.0.1-0:16_7_0__255
                        N 1 Antwort Letzte Antwort
                        • K klassisch
                          N
                          N
                          novregen
                          schrieb am zuletzt editiert von novregen
                          #2651
                          @klassisch
                          Den Datenpunkt habe ich definitiv nicht.
                          Wahrscheinlich gibt es der Zähler nicht her ? Ist ein LOGARE X Smart Metering Drehstromzähler aus 2015 vom Netzbetreiber Avacon. Einen Pin habe ich seinerzeit nicht eingegeben.
                          • N novregen
                            @klassisch
                            K
                            K
                            klassisch
                            schrieb am zuletzt editiert von klassisch
                            #2652
                            @novregen In 2015 wurde wohl noch an dem FNN Lastenheft zur modernen Meßeinrichtung Lastenheft gearbeitet. Das laientaugliche Dokument "FNN-Basiszähler Moderne Messeinrichtung - Fragen und Antworten" stammt von 2017.
                            Ein user aus dem KNX-Forum hat dennoch von seinem Betreiber auf Nachfrage eine PIN bekommen und konnte die Momentanleistung auslesen.
                            Ein Anfrage beim Betreiber könnte also helfen, muß es aber nicht. Was da gesendet wird, kann der Netzbetreiber bestimmen udn limitieren. Und eine moderne Meßeinrichtung ist erst ab 2032 Pflicht.
                            Und wenn der Jahresverbrauch > 6000kWh oder eine große Erzeugerleistung vorliegt, dann gibt es statt der "modernen Meßeinrichtung" das "intelligente Meßsystem" mit Smartmeter Gateway und die Info Schnittstelle scheint nicht mehr garantiert zu sein. Die Daten gehen dann alle 15 Minuten zum Netzbetreiber, wo man sie abholen kann. Lokal gibt es dann noch eine Schnittstelle für das PTB/BMI Programm "Trudi". Also schön unter 6000kWh bleiben.
                            Der o.g. Thread endet derzeit auch mit der Mitteilung, daß es beim Logarex Zähler zur Alterung dr optischen Schnittstelle kam - ähnlich wie dies hier von Chinesischen Zählern berichtet wird.
                            • M
                              M
                              mauseb
                              #2653
                              bin gerade am verzweifeln mit dem Smartmeter und einen Weidmann USB IR Schreib/Lesekopf. (FTDI FT232R / FT230x)
                              Bekomme den Adapter nicht grün, mit den Testprogramm unter Windows komme ich Daten von Stromzähler.
                              Was ich herausgefunden habe, ist der Stromzähler nur in diesen Obis Format die Daten ausgibt.
                              300 7E1 bidirektional
                              Aber wo gebe ich das Aufforderungskommando und den 2 Befehl ein in Smartmeter 🤔 ein?
                              Könnt ihr mir das helfen
                              *** *OBIS (ASCII Format) OBIS ist ein sofort lesbares Datenformat.
                              Die meisten Zähler mit OBIS Protokoll senden bidirektional. Das Standard Aufforderungskommando ist:
                              (in Hex: 2F3F210D0A) Innerhalb von 2 Sekunden muss dieser Befehl folgen:
                              (in Hex: 063030300D0A)***
                              danke schon mal vorab
                              • M mauseb
                                apollon77A
                                apollon77A
                                #2654
                                @mauseb waren das Auszüge aus der Anleitung vom Zähler oder wie? Das ganze klingt nach D0 Protokoll. Also mal frische instanz und einfach nur als Protokoll d0. Dann mal versuchen. Maximal wenn das nicht direkt geht noch das 7e1 bei den seriellen Einstellungen setzen (Finger weg von der baud rate).
                                Wenn das nicht tut dann mit diesen Einstellungen (und bitte Screenshot davon) mal das loglevel der Instanz auf debug Stellen und log anschauen. Was kommt denn rein?
                                • apollon77A apollon77
                                  M
                                  M
                                  mauseb
                                  #2655
                                  @apollon77
                                  danke dir....🤗 🤗
                                  eine neue Instanz , DO und die Baudrate auf 300 dann ging es.
                                  • M mauseb
                                    @apollon77
                                    danke dir....🤗 🤗
                                    apollon77A
                                    apollon77A
                                    #2656
                                    @mauseb manchmal einfach die defaults versuchen ;-))
                                      amg_666A
                                      amg_666A
                                      amg_666
                                      #2657
                                      Stark:
                                      @apollon77 sagt "finger weg von der baud rate" und
                                      @mauseb antwortet "Baudrate auf 300 dann ging es"
                                      Ich liebe dieses Forum :-) :-)
                                      • amg_666A amg_666
                                        Stark:
                                        M
                                        M
                                        mauseb
                                        #2658
                                        @amg_666 ja schon komisch, aber mit leeren Feld ging es nicht, dann die 300 reingeschrieben und es klappte :-)
                                        amg_666A apollon77A 2 Antworten Letzte Antwort
                                        • M mauseb
                                          amg_666A
                                          amg_666A
                                          amg_666
                                          #2659
                                          @mauseb sagte in Adapter "smartmeter":
                                          Die Baudrate ist die Übertragungsrate, die darf nicht leer sein. Mich wundert, dass sie es war, die sollte eigentlich vorbelegt gewesen sein...
                                          84.0k
