  3. Off Topic
  4. *Buster* 32bit -> *Bullseye* 64bit mit *BackItUp*
51 Beiträge 6 Kommentatoren 4.9k Aufrufe 4 Beobachtet
    @legro sagte in *Buster* 32bit -> *Bullseye* 64bit mit *BackItUp*:
    Es ist in der Tat so, dass der systemctl Befehl aus /bin heraus ausgeführt werden muss.
    Kann ich nicht bestätigen:
    echad@chet:~ $ which systemctl
    /usr/bin/systemctl
    echad@chet:~ $ sudo systemctl status grafana-server
    ● grafana-server.service - Grafana instance
         Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; vendor preset: enabled)
         Active: inactive (dead)
           Docs: http://docs.grafana.org
    echad@chet:~ $ sudo systemctl start grafana-server.service
         Active: active (running) since Fri 2022-06-10 19:44:45 CEST; 12s ago
       Main PID: 77680 (grafana-server)
          Tasks: 13 (limit: 8986)
            CPU: 2.564s
         CGroup: /system.slice/grafana-server.service
                 └─77680 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths>
    Jun 10 19:44:56 chet grafana-server[77680]: logger=sqlstore t=2022-06-10T19:44:56.46+0200 lvl=info msg="Created default organization"
    Jun 10 19:44:56 chet grafana-server[77680]: logger=plugin.manager t=2022-06-10T19:44:56.58+0200 lvl=info msg="Plugin registered" pluginId=input
    Jun 10 19:44:56 chet grafana-server[77680]: logger=plugin.finder t=2022-06-10T19:44:56.58+0200 lvl=warn msg="Skipping finding plugins as directory does not>
    Jun 10 19:44:56 chet grafana-server[77680]: logger=query_data t=2022-06-10T19:44:56.59+0200 lvl=info msg="Query Service initialization"
    Jun 10 19:44:56 chet grafana-server[77680]: logger=live.push_http t=2022-06-10T19:44:56.6+0200 lvl=info msg="Live Push Gateway initialization"
    Jun 10 19:44:56 chet grafana-server[77680]: logger=server t=2022-06-10T19:44:56.84+0200 lvl=info msg="Writing PID file" path=/run/grafana/grafana-server.pi>
    Jun 10 19:44:56 chet grafana-server[77680]: logger=ngalert t=2022-06-10T19:44:56.84+0200 lvl=info msg="warming cache for startup"
    Jun 10 19:44:56 chet grafana-server[77680]: logger=grafanaStorageLogger t=2022-06-10T19:44:56.85+0200 lvl=info msg="storage starting"
    Jun 10 19:44:56 chet grafana-server[77680]: logger=http.server t=2022-06-10T19:44:56.85+0200 lvl=info msg="HTTP Server Listen" address=[::]:3000 protocol=h>
    Jun 10 19:44:56 chet grafana-server[77680]: logger=ngalert.multiorg.alertmanager t=2022-06-10T19:44:56.9+0200 lvl=info msg="starting MultiOrg Alertmanager"
    legro
    schrieb am zuletzt editiert von legro
    Wie du oben an meinen zitierten Auszügen aus der Terminalsitzung sehen kannst, war dem bei mir nicht so.
    Den Grund dafür dürfte ich bei der Suche nach diesem Fehler ebenfalls gefunden haben: Es kommt wohl darauf an, ob man die Schritte zur allgemeinen Linux-Installation oder jene von der speziellen für den Raspberry Pi verwendet hat. In dieser wird explizit angeraten, sudo /bin/systemctl start grafana-server zu verwenden.
    Stopp! Da fällt mir ein, dass du von Pfad sprichst. Ich kenne eine solche globale Systemvariable Path aus der MSDOS/Windows-Welt. In dieser kann man Pfade zu einzelnen Ressourcen hinterlegen, die immer dann durchsucht werden, wenn eine Referenzierung nicht aufgelöst werden konnte. Gibt es so etwas auch in Linux?
    Sei‘s d‘rum! Es funktioniert ja jetzt alles.
    Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
    • E Einstein67
      @legro said in *Buster* 32bit -> *Bullseye* 64bit mit *BackItUp*:
      Dann will ich darangehen die aus der Version 1.8.x vorhandenen Daten zu migrieren
      Und dann musst du all deine Dashboards/Panels in einer recht seltsamen Syntax (zumindest für mich) neu erstellen ....
      legro
      @einstein67 said in *Buster* 32bit -> *Bullseye* 64bit mit *BackItUp*:
      Danke fürs Mutmachen!😉
      Ja, davon habe ich bereits gelesen. Von abwärts kompatibel halten die Macher von Grafana offenbar nicht das Gringste.🙁
      • L legro
        Offen gesagt sehe ich da nur einen Befehl, der so eingegeben nicht funktionieren kann.
        L 1 Antwort Letzte Antwort
          legro
          @thomas-braun said in *Buster* 32bit -> *Bullseye* 64bit mit *BackItUp*:
          Stimmt. Da habe ich offenbar die falschen Zeilen rauskopiert. Selbstverständlich wollte ich die Zeilen zum Befehl sudo systemctl start grafana-server zitieren.
          • L legro
            Natürlich.
            echo $PATH
            gibt dir die zu durchlaufenden Pfade an.
            Zu systemctl:
            echad@chet:/opt/iobroker $ echo $PATH
            /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
            echad@chet:/opt/iobroker $ which systemctl
            /usr/bin/systemctl
            • simatecS simatec
              @legro die Migration von Influxdb v1 zu v2 ist kein großes Ding.
              Ist alles in der Doku sehr gut beschrieben.
              Glaub auch hier im Forum gib es ein Howto.
              legro
              @simatec said in *Buster* 32bit -> *Bullseye* 64bit mit *BackItUp*:
              Von wegen! Du bist offenbar ein gnadenloser Optimist.😉 Da bin ich wohl eher der Pessimist. Egal, ob Opti- oder Pessi- am Ende steht immer Mist.😂
              Da ich piVCCU3 verwende und Alexander Reinert ausführt, dass seine virtuelle CCU3-Software nicht in einer gemischten Umgebung 32/64Bit läuft, scheidet bei mir schonmal ein „in place update“ aus. Mithin kann ich nur InfluxDB 2.2 in einem reinen 64Bit-System installieren und manuell die Daten aus der Version 7.5.5 zu übertragen versuchen.
              Die Anleitung von Influxdata habe ich gefunden und bin dabei sie durchzuackern. Von einfach kann da keine Rede sein.😞
              Wenn ich das Ganze richtig verstanden habe, muss ich in meinem Fall für meine von ioBroker erzeugten zeitlichen Datensequenzen die Anleitung zu Migration time series data durchführen.🤔
              Aber ich muss wohl erstmal noch weiter grübeln. Ich habe das Gefühl, das Ganze noch nicht richtig verstanden zu haben.
              • L legro
                legro
                Bevor ich mich nun an der Datenmigration von InfluxDB 2.2 wage, möchte ich noch verstehen, wie ich's hinbekomme, mittels BackItUp die Migration aller Adapter, Objekte, .. von meiner alten 32Bit-Installation auf mein neues Bullseye System zu retten.
                Der Weg über CLI, wie er von Matthias Kleine beschrieben wird, ist mir auf die Dauer einfach zu aufwendig.
                Was ich bisher probiert habe ..
                • Ich habe BackItUp so konfiguriert, dass die Backups über NAS/kopieren gespeichert werden.
                • Zum Test habe ich ein Backup des Bullseye-Systems erstellt. Das hat funktioniert.
                • Anschließend habe ich ein Backup des alten Buster-Systems in das Verzeichnis kopiert.
                • Der Versuch dieses Backup im Bullseye-System wiederherzustellen scheiterte.
                • Also versuchte ich das Ganze mit dem neu erstellten Backup des Bullseye-Systems. Auch dies scheiterte.
                Ich erhielt im Log folgende Fehlermeldung:
                [DEBUG] [iobroker] Start ioBroker Restore ...
                [ERROR] [iobroker] host.raspberrypi-dev Cannot extract from file "/opt/iobroker/backups/iobroker_2022_06_06-03_40_20_Gro_backupiobroker.tar.gz": Unknown system error -116: Unknown system error -116, open '/opt/iobroker/backups/iobroker_2022_06_06-03_40_20_Gro_backupiobroker.tar.gz'
                [DEBUG] [iobroker] ioBroker Restore completed successfully
                [EXIT] 9
                Wenn ich das richtig lese, versucht er lokal in /opt/iobroker/backups nach der Backup-Datei zu suchen. Die ist jedoch nicht dort, sondern auf der Fritz!Box und über CIFS zugänglich.
                Ich bin ratlos.
                • L legro
                  [EXIT] 9
                  Ich bin ratlos.
                  Keine Ahnung wo du da ein Problem hast.
                  Neuen Backitup mit CIFS einrichten, dann von dort das auf dem CIFS liegende Backup referenzieren, Backup einspielen.
                  Da /opt/iobroker/backups/ bei Verwendung von CIFS als Mountpunkt fungiert muss der Adapter auch nirgendwo anders schauen.
                    legro
                    Das habe ich alles gemacht. Dennoch funktioniert's nicht.
                    Vielleicht kannst du an dem Log-Eintrag ja etwas erkennen. Ich bin nach wie vor ratlos.
                    backitup.0
                    2022-06-11 12:34:51.320	error	umount: /opt/iobroker/backups: not mounted.
                    backitup.0
                    2022-06-11 12:32:51.305	error	Error: Command failed: sudo mount -t cifs -o username=AdminLocal,password=****,domain=galegro,rw,file_mode=0777,dir_mode=0777 //fritz.nas/fritz.nas/SanDisk/SmartHomeBackup/ioBrokerDev /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                    backitup.0
                    2022-06-11 12:32:50.809	info	[iobroker] backup was activated at 02:40 every 1 day(s)
                    backitup.0
                    2022-06-11 12:32:50.778	warn	Cannot read log file: Error: UNKNOWN: unknown error, open '/opt/iobroker/backups/logs.txt'
                    • L legro
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      @legro
                      Direkt auf der FritzBox? Mit welchen Einstellungen im Adapter angelegt?
                      Die Fritzbox braucht die Option 'noserverino' und SMB-Dialekt 3.1.1
                      L 2 Antworten Letzte Antwort
                        @legro
                        legro
                        Vielen Dank! Das war's.👍
                        Ich erinnere mich daran, dass ich das Problem schon einmal vor ewig langer Zeit hier vortrug. Da es damals keine Lösung gab, verwendete ich einfach weiter fleißig ApplePiBaker.
                        Und die Moral von der Geschicht',
                        ohne kluge Leute geht es nicht.🙂
                          @legro
                          legro
                          Nun habe ich bereits den zweiten Versuch hinter mir, meine ioBroker-Installation von Buster (32Bit) zu Bullseye (64Bit) mittels BackItUp zu übertragen. Ergebnis: Alle Adapter scheinen in Ordnung zu sein, nur der VIS-Adapter will einfach nicht.
                          2022-06-11 17:08:50.013	error	Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                          2022-06-11 17:08:49.012	info	iobroker npm-install: exit 25
                          2022-06-11 17:08:47.978	error	iobroker npm-install: host.raspberrypi-dev Cannot install iobroker.vis@1.4.15: 6
                          vis.0
                          2022-06-11 17:08:45.358	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          vis.0
                          2022-06-11 17:08:45.357	info	terminating
                          vis.0
                          2022-06-11 17:08:44.851	error	Not exists
                          vis.0
                          2022-06-11 17:08:44.850	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:466:21)
                          vis.0
                          2022-06-11 17:08:44.848	error	unhandled promise rejection: Not exists
                          vis.0
                          2022-06-11 17:08:44.847	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          vis.0
                          2022-06-11 17:08:44.542	info	vis license is OK.
                          vis.0
                          2022-06-11 17:08:44.405	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.3, js-controller: 4.0.23
                          2022-06-11 17:08:42.890	info	iobroker npm-install: > iobroker.vis@1.4.15 install /opt/iobroker/node_modules/iobroker.vis> node main.js --install
                          2022-06-11 17:08:42.888	info	iobroker npm-install:
                          2022-06-11 17:08:24.206	info	iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                          2022-06-11 17:08:24.204	info	iobroker npm-install: NPM version: 6.14.17
                          2022-06-11 17:08:21.717	info	iobroker install vis@1.4.15 using installedVersion
                          2022-06-11 17:08:21.716	warn	startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
                          Mal wieder bin ich ratlos.😞
                          Thomas BraunT E 2 Antworten Letzte Antwort
                          • L legro
                            vis.0
                            vis.0
                            vis.0
                            vis.0
                            vis.0
                            vis.0
                            vis.0
                            vis.0
                            @legro
                            Versuch mal eine der Vorversionen zu installieren. Wenn ich das richtig mitbekommen habe klemmt es u.U. bei der aktuellen Vis-Version.
                              @legro
                              legro
                              Versuch mal eine der Vorversionen ..
                              Aber wie kann ich das erreichen? Die Version ist doch durch das verwendete Backup festgelegt.
                              Da fällt mir noch etwas ein ..
                              Es gibt ja zwei Versionen: Ich habe jene erworben, die sich beim Start nicht über das Internet authentifizieren muss. Könnte es auch daran liegen?
                              • L legro
                                @legro
                                Ich hab keine Vis laufen, daher weiß ich auch nicht wie das mit den Lizenzen da genau geregelt ist.
                                  @legro
                                  legro
                                  Da sitze ich wohl in der Falle: Entfernen lässt sich vis.0 nicht und eine weitere Instanz lässt sich ebenfalls nicht installieren.
                                  • L legro
                                    @legro
                                    iobroker upgrade vis@GEWÜNSCHTE.VERSION.NUMMER
                                    • L legro
                                      vis.0
                                      vis.0
                                      vis.0
                                      vis.0
                                      vis.0
                                      vis.0
                                      vis.0
                                      vis.0
                                      Einstein67
                                      schrieb am zuletzt editiert von Einstein67
                                      Du musst nur einfach vor dem Restore mit BackitUp, den Vis-Adapter (Version ist egal) manuell installieren. Dann läuft er auch nach dem Restore.
                                      • E Einstein67
                                        legro
                                        @einstein67
                                        Verstehe ich das richtig ..
                                        • Im alten System (Buster 32Bit) ein Downgrade auf eine ältere Version machen.
                                        • Neues Backup erstellen
                                        • Das neue Backup erneut per Restore auf das neue System (Bullseye 64Bit) bringen
                                        E 1 Antwort Letzte Antwort
                                        • L legro
                                          @einstein67
                                          Einstein67
                                          @legro Nein, am "neuem" System einfach vor dem Restore, den VIS-Adapter installieren. Lizenzfenster wegklicken und Restore starten.
