  4. Test Adapter Govee v0.0.x
    6.5k
313 Beiträge 49 Kommentatoren 88.6k Aufrufe 48 Beobachtet
  • chucky666C chucky666
    @nbuenger
    Hallo
    Danke für den Adapter, wird der Tv Hintergrund stripe Govee DreamView T1
    Unterstützt?
    #151
    @chucky666
    Ist das
    Produktmodell H6199 ?
    Das Ding läuft hier nämlich.
    chucky666C 1 Antwort Letzte Antwort
      @chucky666
      Ist das
      chucky666C Online
      chucky666C Online
      chucky666
      #152
      Ja genau , ist das Teil gut ?
        #153
        @chucky666
        Ja, für mich funktioniert das gut.
        Datenpunkte:
        • D DocGame
          Ich habe gestern eine Mail mit folgendem Inhalt von Govee erhalten:
          Dear User,
          Thank you for choosing Govee and for your constant support!
          For 2022, we have some important updates for our Govee API to inform you about.
          1. “Govee API” has been officially renamed to the more standard “Govee Developer API”.
          2. We have updated the Terms of Service for the Govee Developer API to better protect the legitimate rights and interests of both parties. Terms of Service documentation can be accessed here.
          3. Due to the limited resources of the API server, the flow of some high-frequency API calls will be limited in order to make the API server more stable and serve more users.
          •	If your current usage scenario does not call the API frequently, your applications will not be affected.
          •	If your current usage scenario calls the API frequently, your application might be affected and may not function properly. Therefore, you will need to modify your applications to call the API less frequently. Specific rules related to this are listed in the latest API reference document.
          •	The limit on API call frequency will be implemented started May 5, 2022. We hope you can complete any needed modification of your API applications before this date so your applications will continue to run normally.
          If you have any question, please contact us via api-support@govee.com.
          Best Regards,
          Govee Team
          Hat da irgendwelche Auswirkungen...kann man dadurch was verbessern?
          lindi200000
          #154
          @docgame Hallo, nun ist es eingetroffen. Die API kommt nicht mehr durch, weil das Limit erreicht ist (Fehler 429 in den Logs).
          Die neuen Limits lassen nur noch alle 90 Sekunden eine Abfrage durch.
          • L lindi200000
            #155
            @lindi200000 ist in meinem Anwendungsfall doch nicht schlimm, ich habs auf 720 sek. stehen.. ich schalte damit nur Licht an/aus... von 2 Devices bekomm ich den Status sowieso nicht von der API, nur von einem, und das seh ich auch selbst, ob das an oder aus ist.
            Fuer was brauchst du die Werte denn so schnell ?
            Klar, je mehr Clients und Zugriffe, desto groesser die Serverlast..
            L 1 Antwort Letzte Antwort
              lindi200000
              #156
              @ilovegym so wie ich das verstanden habe wird das auch dann gesendet, oder?
              Ich hab es noch nicht getestet. Wenn ich schalte, wird dann instant geschaltet oder wenn die nächste API Abfrage ist.
              • L lindi200000
                #157
                @lindi200000
                wenn du einen Datenpunkt aenderst, wird das sofort gesendet, das funktioniert einwandfrei.
                Nur die Abfrage des Adapters von der API ist in dem Intervall.
                Ich setze diese immer recht hoch, um die API zu schonen, sofern es sinnvoll im Anwendungsfall ist.
                  @lindi200000
                  lindi200000
                  #158
                  Irgendwas ist jetzt anders. Mein H6159 LED Stripe funktioniert nicht mehr.
                  Log zeigt
                  govee.0 2022-05-08 17:14:40.855	error	H6159
                  Was mich wundert, seit der API Änderung ist das Problem erst, vorher konnte ich den Stripe ohne weiteres über IOB steuern.
                  • andiko2A Online
                    andiko2A Online
                    andiko2
                    #159
                    Ist dieser Adapter nur für die LED Strips von Covee oder gehen auch Thermometer mit Hygrometer?
                    M ? 2 Antworten Letzte Antwort
                    • andiko2A andiko2
                      maxpd
                      #160
                      Mein API Key hat scheinbar aufgehört. Musste mir einen neuen beantragen.
                      Hattet ihr das auch schon?
                      maxpd
                      • ? Offline
                        #161
                        @maxpd nee, laeuft noch ohne Probleme..
                        • andiko2A andiko2
                          #162
                          @andiko2 Hi, der Adapter arbeitet mit der API, wenn dein Device da auch mit eingepflegt ist, ja.
                          andiko2A 2 Antworten Letzte Antwort
                            andiko2A Online
                            andiko2A Online
                            andiko2
                            #163
                            @ilovegym Danke für die Antwort. Dann werde ich das mal testen.
                              andiko2A Online
                              andiko2A Online
                              andiko2
                              #164
                              @ilovegym So habe den Adapter installiert, eine Inztanz hinzugefügt, Den API eingetragen und Adapter ist auch grün. Es werden aber keines meiner Thermo- Hygrometer angezeigt.
                              • andiko2A andiko2
                                #165
                                @andiko2
                                Prima! Wie gesagt, der Adapter zeigt nur devices an, die von der api unterstützt werden.
                                Wird deins denn??? Sollte in der docu stehen..
                                  @andiko2
                                  andiko2A Online
                                  andiko2A Online
                                  andiko2
                                  #166
                                  @ilovegym da muss ich mal suchen und nachlesen. Dachte die sind ja in der Handy App zu sehen und im WLAN. Bluetooth sind die auch verbunden.
                                    maxpd
                                    #167
                                    Bei mir hat er wieder die Verbindung verloren und ich muss einen neuen API Schlüssel beantragen
                                    maxpd
                                      @andiko2
                                      andiko2A Online
                                      andiko2A Online
                                      andiko2
                                      schrieb am zuletzt editiert von andiko2
                                      #168
                                      @ilovegym wo finde ich das, welche Geräte von der API unterstützt werden? Habe Thermometer H5179 und H5075. Das 5179 hat Verbindung mit WLAN und Bluetooth. Das H5075 nur Bluetooth. Beide kann ich in der App von Govee, wo man auch LED Strips zufügen kann sehen.
                                      • andiko2A andiko2
                                        Michi_Pi
                                        #169
                                        @andiko2 Siehe diesen Post
                                        andiko2A 1 Antwort Letzte Antwort
                                        • M Michi_Pi
                                          andiko2A Online
                                          andiko2A Online
                                          andiko2
                                          #170
                                          @michi_pi kann den Link dort nicht öffnen.
