  4. Test Adapter Govee v0.0.x
    6.5k
313 Beiträge 49 Kommentatoren 88.6k Aufrufe 48 Beobachtet
    DocGame
    schrieb am zuletzt editiert von DocGame
    #149
    Ich habe gestern eine Mail mit folgendem Inhalt von Govee erhalten:
    Dear User,
    Thank you for choosing Govee and for your constant support!
    For 2022, we have some important updates for our Govee API to inform you about.
    1. “Govee API” has been officially renamed to the more standard “Govee Developer API”.
    2. We have updated the Terms of Service for the Govee Developer API to better protect the legitimate rights and interests of both parties. Terms of Service documentation can be accessed here.
    3. Due to the limited resources of the API server, the flow of some high-frequency API calls will be limited in order to make the API server more stable and serve more users.
    •	If your current usage scenario does not call the API frequently, your applications will not be affected.
    •	If your current usage scenario calls the API frequently, your application might be affected and may not function properly. Therefore, you will need to modify your applications to call the API less frequently. Specific rules related to this are listed in the latest API reference document.
    •	The limit on API call frequency will be implemented started May 5, 2022. We hope you can complete any needed modification of your API applications before this date so your applications will continue to run normally.
    If you have any question, please contact us via api-support@govee.com.
    Best Regards,
    Govee Team
    Hat da irgendwelche Auswirkungen...kann man dadurch was verbessern?
    L 1 Antwort Letzte Antwort
    • nbuengerN nbuenger
      Aktuelle Test Version 0.0.5
      Veröffentlichungsdatum 27.06.2021
      Github Link https://github.com/nbuenger/ioBroker.govee
      NPM Link https://www.npmjs.com/package/iobroker.govee
      Beschreibung https://github.com/nbuenger/ioBroker.govee/blob/main/README.md
      Hey, ich habe mich mal ran gesetzt und einein Adapter für die Govee Familie gebastelt.
      Mich hat es tierisch aufgeregt meine WLAN LED Leisten von Govee nicht in den ioBroker zu bekommen.
      Ich habe bereits mit ein paar Leuten getestet und nun wollte ich ihn euch allen für Tests zur Verfügung stellen.
      Der Adapter basiert auf der API 1.2 von Govee also benötigt ihr wenn ihr ihn testen möchtet einen API Key. Den bekommt ihr ganz einfach über die Govee App unter Profil -> Einstellungen -> Über uns -> API-Schlüssel beantragen.
      Dann müsst ihr einfach euren Namen und den Grund weshalb ihr den API Key haben möchtet eintragen. (Als Grund sollte SmartHome Control reichen)
      Ich freue mich auf euer Feddback👍
      chucky666C Online
      chucky666C Online
      chucky666
      #150
      @nbuenger
      Hallo
      Danke für den Adapter, wird der Tv Hintergrund stripe Govee DreamView T1
      Unterstützt?
      • chucky666C chucky666
        @nbuenger
        Hallo
        Unterstützt?
        #151
        @chucky666
        Ist das
        Produktmodell H6199 ?
        Das Ding läuft hier nämlich.
        chucky666C 1 Antwort Letzte Antwort
          @chucky666
          Ist das
          chucky666C Online
          chucky666C Online
          chucky666
          #152
          Ja genau , ist das Teil gut ?
            #153
            @chucky666
            Ja, für mich funktioniert das gut.
            Datenpunkte:
            • D DocGame
              Dear User,
              Best Regards,
              Govee Team
              lindi200000
              #154
              @docgame Hallo, nun ist es eingetroffen. Die API kommt nicht mehr durch, weil das Limit erreicht ist (Fehler 429 in den Logs).
              Die neuen Limits lassen nur noch alle 90 Sekunden eine Abfrage durch.
              • L lindi200000
                #155
                @lindi200000 ist in meinem Anwendungsfall doch nicht schlimm, ich habs auf 720 sek. stehen.. ich schalte damit nur Licht an/aus... von 2 Devices bekomm ich den Status sowieso nicht von der API, nur von einem, und das seh ich auch selbst, ob das an oder aus ist.
                Fuer was brauchst du die Werte denn so schnell ?
                Klar, je mehr Clients und Zugriffe, desto groesser die Serverlast..
                  lindi200000
                  #156
                  @ilovegym so wie ich das verstanden habe wird das auch dann gesendet, oder?
                  Ich hab es noch nicht getestet. Wenn ich schalte, wird dann instant geschaltet oder wenn die nächste API Abfrage ist.
                  • L lindi200000
                    #157
                    @lindi200000
                    wenn du einen Datenpunkt aenderst, wird das sofort gesendet, das funktioniert einwandfrei.
                    Nur die Abfrage des Adapters von der API ist in dem Intervall.
                    Ich setze diese immer recht hoch, um die API zu schonen, sofern es sinnvoll im Anwendungsfall ist.
                      @lindi200000
                      lindi200000
                      #158
                      Irgendwas ist jetzt anders. Mein H6159 LED Stripe funktioniert nicht mehr.
                      Log zeigt
                      govee.0 2022-05-08 17:14:40.855	error	H6159
                      Was mich wundert, seit der API Änderung ist das Problem erst, vorher konnte ich den Stripe ohne weiteres über IOB steuern.
                      • andiko2A Online
                        andiko2A Online
                        andiko2
                        #159
                        Ist dieser Adapter nur für die LED Strips von Covee oder gehen auch Thermometer mit Hygrometer?
                        M ? 2 Antworten Letzte Antwort
                        • andiko2A andiko2
                          maxpd
                          #160
                          Mein API Key hat scheinbar aufgehört. Musste mir einen neuen beantragen.
                          Hattet ihr das auch schon?
                          maxpd
                          • ? Offline
                            #161
                            @maxpd nee, laeuft noch ohne Probleme..
                            • andiko2A andiko2
                              #162
                              @andiko2 Hi, der Adapter arbeitet mit der API, wenn dein Device da auch mit eingepflegt ist, ja.
                              andiko2A 2 Antworten Letzte Antwort
                                andiko2A Online
                                andiko2A Online
                                andiko2
                                #163
                                @ilovegym Danke für die Antwort. Dann werde ich das mal testen.
                                  andiko2A Online
                                  andiko2A Online
                                  andiko2
                                  #164
                                  @ilovegym So habe den Adapter installiert, eine Inztanz hinzugefügt, Den API eingetragen und Adapter ist auch grün. Es werden aber keines meiner Thermo- Hygrometer angezeigt.
                                  • andiko2A andiko2
                                    #165
                                    @andiko2
                                    Prima! Wie gesagt, der Adapter zeigt nur devices an, die von der api unterstützt werden.
                                    Wird deins denn??? Sollte in der docu stehen..
                                      @andiko2
                                      andiko2A Online
                                      andiko2A Online
                                      andiko2
                                      #166
                                      @ilovegym da muss ich mal suchen und nachlesen. Dachte die sind ja in der Handy App zu sehen und im WLAN. Bluetooth sind die auch verbunden.
                                        maxpd
                                        #167
                                        Bei mir hat er wieder die Verbindung verloren und ich muss einen neuen API Schlüssel beantragen
                                        maxpd
                                          @andiko2
                                          andiko2A Online
                                          andiko2A Online
                                          andiko2
                                          schrieb am zuletzt editiert von andiko2
                                          #168
                                          @ilovegym wo finde ich das, welche Geräte von der API unterstützt werden? Habe Thermometer H5179 und H5075. Das 5179 hat Verbindung mit WLAN und Bluetooth. Das H5075 nur Bluetooth. Beide kann ich in der App von Govee, wo man auch LED Strips zufügen kann sehen.
