  4. Kein Bluetooth nach Bullseye update und neuem Nodejs
    5.8k
12 Beiträge 4 Kommentatoren 561 Aufrufe 3 Beobachtet
  • jmeister79J jmeister79
    ich habe auf meinem Raspberry pi mal von Buster auf Bullseye upgedatet und danach dann das neuese nodejs.
    Jetzt geht mein BT Adapter aber nicht mehr.
    Die Instanz zeigt
    verbunden mit host und lebenszeichen rot aber verbunden mit Dienst grün.
    ble.0
    2022-06-03 11:57:00.299	error	Terminating because A dependency requires a rebuild.
    ble.0
    2022-06-03 11:56:59.678	info	starting scanner process...
    ble.0
    2022-06-03 11:56:59.655	info	monitored services: fe95
    ble.0
    2022-06-03 11:56:59.653	info	enabled plugins: Xiaomi, _default
    ble.0
    2022-06-03 11:56:59.651	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    ble.0
    2022-06-03 11:56:59.580	info	starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v14.19.3, js-controller: 4.0.23
    pi@iobrokerpi:~ $ /etc/init.d/bluetooth status
    ● bluetooth.service - Bluetooth service
         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
         Active: active (running) since Wed 2022-06-01 19:43:06 CEST; 1 day 16h ago
           Docs: man:bluetoothd(8)
       Main PID: 591 (bluetoothd)
         Status: "Running"
          Tasks: 1 (limit: 4915)
            CPU: 174ms
         CGroup: /system.slice/bluetooth.service
                 └─591 /usr/libexec/bluetooth/bluetoothd
    Jun 01 19:43:06 iobrokerpi systemd[1]: Starting Bluetooth service...
    Jun 01 19:43:06 iobrokerpi bluetoothd[591]: Bluetooth daemon 5.55
    Jun 01 19:43:06 iobrokerpi systemd[1]: Started Bluetooth service.
    Jun 01 19:43:06 iobrokerpi bluetoothd[591]: Starting SDP server
    Jun 01 19:43:06 iobrokerpi bluetoothd[591]: Bluetooth management interface 1.21 initialized
    Jun 01 19:43:07 iobrokerpi bluetoothd[591]: profiles/sap/server.c:sap_server_register() Sap driver initializa…failed.
    Jun 01 19:43:07 iobrokerpi bluetoothd[591]: sap-server: Operation not permitted (1)
    Jun 01 19:43:07 iobrokerpi bluetoothd[591]: Failed to set privacy: Rejected (0x0b)
    Hint: Some lines were ellipsized, use -l to show in full.
    pi@iobrokerpi:~ $
    iobroker fix hilft leider auch nicht...
    Wasn nu wieder...
    Nils
    @jmeister79
    Abwarten.
    Da wird ble neugebaut.
    Wenn das nicht automagisch funktioniert von Hand machen. Oder ble deinstallieren und nochmal frisch drauf.
    jmeister79J 1 Antwort Letzte Antwort
      @jmeister79
      Abwarten.
      jmeister79J Offline
      jmeister79J Offline
      jmeister79
      @thomas-braun mehr als ein tag Geduld? Hab gestern mittag geupdated und den fixer vor einer halben stunde angestoßen und iobroker neu gestartet
        @jmeister79
        Einen Tag dauert das nicht. Dann die manuelle Variante nehmen.
          Die Instanz zeigt
          ble.0
          ble.0
          ble.0
          ble.0
          ble.0
          ble.0
               Status: "Running"
                  CPU: 174ms
          pi@iobrokerpi:~ $
          Wasn nu wieder...
          Nils
          crunchipC Abwesend
          crunchipC Abwesend
          @jmeister79 sagte in Kein Bluetooth nach Bullseye update und neuem Nodejs:
          das neuese nodejs
          wenn der Adapter fertig ist, ggf aufgrund von node.js Update nochmals ausführen
          sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
          was zeigt info.driverStateStatus
          • jmeister79J Offline
            jmeister79J Offline
            jmeister79
            Bluettooth hat keine elemente im Info Adapter, da ist nix.
            im log stand:
            host.iobrokerpi
            2022-06-03 12:09:12.795	info	Rebuild for adapter system.adapter.ble.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
            host.iobrokerpi
            2022-06-03 12:09:12.794	info	instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
            ble.0
            2022-06-03 12:09:12.672	error	Terminating because A dependency requires a rebuild.
            hab den Befehlt mal ausgeführt aber brachte nix. Wo muss der ausgeführt werden?
            Nils
              im log stand:
              host.iobrokerpi
              host.iobrokerpi
              ble.0
              Nils
              crunchipC Abwesend
              crunchipC Abwesend
              Es war auch nicht die Rede vom info Adapter, sondern von
              ble.0.info.driverState
              Im ioBroker Verzeichnis ein
              npm install iobroker.adaptername@version --production
              ausführen.
              Danach nochmals "npm rebuild".
                jmeister79J Offline
                jmeister79
                @crunchip Verschuldigung. Ich arbeite grad nebenher noch. Sollte das lassen.
                driverstate is poweredOn
                alle rebuilds etc haben nicht geholfen.
                Irgendwo im LOG hieß es, dass das ding mit nem anderen node installiert wurde.
                Habs jetzt deinstalliert und reinstalliert.
                Muss natürlich alle objekte wieder anlegen, benennen etc.
                LG und danke für die Hilfe
                Nils
                  Nils
                  wo sind diese Ausgaben?
                  stand da vielleicht auch etwas mehr?
                  möglicherwrise etwas von package-lock.json?
                    jmeister79J Offline
                    jmeister79J Offline
                    jmeister79
                    Sorry, die meldugn kommt ja nun nicht mehr. hatte das nur gelesen und bin dann dem tipp der neuinstallation gefolgt.
                    LG
                    Nils
                      LG
                      Nils
                      @jmeister79 bitte immer alle Informationen mitliefern.
                      Nur dann kann eine ggf. versteckte Ursache richtig eingegrenzt werden.
                        jmeister79J Offline
                        jmeister79J Offline
                        jmeister79
                        @homoran Ja, werde ich beherzigen. Danke für den hinweis
