<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Kein Bluetooth nach Bullseye update und neuem Nodejs]]></title><description><![CDATA[<p dir="auto">Hi,<br />
ich habe auf meinem Raspberry pi  mal von Buster auf Bullseye upgedatet und danach dann das neuese nodejs.</p>
<p dir="auto">Jetzt geht mein BT Adapter aber nicht mehr.<br />
Die Instanz zeigt<br />
verbunden mit host und lebenszeichen rot aber verbunden mit Dienst grün.</p>
<pre><code>
ble.0
2022-06-03 11:57:00.299	error	Terminating because A dependency requires a rebuild.
ble.0
2022-06-03 11:56:59.678	info	starting scanner process...
ble.0
2022-06-03 11:56:59.655	info	monitored services: fe95
ble.0
2022-06-03 11:56:59.653	info	enabled plugins: Xiaomi, _default
ble.0
2022-06-03 11:56:59.651	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
ble.0
2022-06-03 11:56:59.580	info	starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v14.19.3, js-controller: 4.0.23
</code></pre>
<pre><code>
pi@iobrokerpi:~ $ /etc/init.d/bluetooth status
● bluetooth.service - Bluetooth service
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
     Active: active (running) since Wed 2022-06-01 19:43:06 CEST; 1 day 16h ago
       Docs: man:bluetoothd(8)
   Main PID: 591 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 4915)
        CPU: 174ms
     CGroup: /system.slice/bluetooth.service
             └─591 /usr/libexec/bluetooth/bluetoothd
Jun 01 19:43:06 iobrokerpi systemd[1]: Starting Bluetooth service...
Jun 01 19:43:06 iobrokerpi bluetoothd[591]: Bluetooth daemon 5.55
Jun 01 19:43:06 iobrokerpi systemd[1]: Started Bluetooth service.
Jun 01 19:43:06 iobrokerpi bluetoothd[591]: Starting SDP server
Jun 01 19:43:06 iobrokerpi bluetoothd[591]: Bluetooth management interface 1.21 initialized
Jun 01 19:43:07 iobrokerpi bluetoothd[591]: profiles/sap/server.c:sap_server_register() Sap driver initializa…failed.
Jun 01 19:43:07 iobrokerpi bluetoothd[591]: sap-server: Operation not permitted (1)
Jun 01 19:43:07 iobrokerpi bluetoothd[591]: Failed to set privacy: Rejected (0x0b)
Hint: Some lines were ellipsized, use -l to show in full.
pi@iobrokerpi:~ $
</code></pre>
<p dir="auto">iobroker fix hilft leider auch nicht...</p>
<p dir="auto">Wasn nu wieder...</p>
<p dir="auto">Nils</p>
]]></description><link>https://forum.iobroker.net/topic/55369/kein-bluetooth-nach-bullseye-update-und-neuem-nodejs</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 06:10:28 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/55369.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Jun 2022 09:58:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Kein Bluetooth nach Bullseye update und neuem Nodejs on Mon, 06 Jun 2022 17:04:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> Ja, werde ich  beherzigen. Danke für den hinweis</p>
]]></description><link>https://forum.iobroker.net/post/811121</link><guid isPermaLink="true">https://forum.iobroker.net/post/811121</guid><dc:creator><![CDATA[jmeister79]]></dc:creator><pubDate>Mon, 06 Jun 2022 17:04:12 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Bluetooth nach Bullseye update und neuem Nodejs on Sun, 05 Jun 2022 16:12:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmeister79" aria-label="Profile: jmeister79">@<bdi>jmeister79</bdi></a> bitte <em>immer</em> alle Informationen mitliefern.<br />
Nur dann kann eine ggf. versteckte Ursache richtig eingegrenzt werden.</p>
]]></description><link>https://forum.iobroker.net/post/810531</link><guid isPermaLink="true">https://forum.iobroker.net/post/810531</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 05 Jun 2022 16:12:33 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Bluetooth nach Bullseye update und neuem Nodejs on Sun, 05 Jun 2022 10:13:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a><br />
Sorry, die meldugn kommt ja nun nicht mehr. hatte das nur gelesen und bin dann dem tipp der neuinstallation gefolgt.</p>
<p dir="auto">LG<br />
Nils</p>
]]></description><link>https://forum.iobroker.net/post/810323</link><guid isPermaLink="true">https://forum.iobroker.net/post/810323</guid><dc:creator><![CDATA[jmeister79]]></dc:creator><pubDate>Sun, 05 Jun 2022 10:13:44 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Bluetooth nach Bullseye update und neuem Nodejs on Fri, 03 Jun 2022 13:28:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmeister79" aria-label="Profile: jmeister79">@<bdi>jmeister79</bdi></a> sagte in <a href="/post/809637">Kein Bluetooth nach Bullseye update und neuem Nodejs</a>:</p>
<blockquote>
<p dir="auto">Irgendwo im LOG hieß es,</p>
</blockquote>
<p dir="auto">wo sind diese Ausgaben?</p>
<p dir="auto">stand da vielleicht auch etwas mehr?<br />
möglicherwrise etwas von package-lock.json?</p>
]]></description><link>https://forum.iobroker.net/post/809642</link><guid isPermaLink="true">https://forum.iobroker.net/post/809642</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 03 Jun 2022 13:28:41 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Bluetooth nach Bullseye update und neuem Nodejs on Fri, 03 Jun 2022 13:23:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> Verschuldigung. Ich arbeite grad nebenher noch. Sollte das lassen.</p>
<p dir="auto">driverstate is poweredOn</p>
<p dir="auto">alle rebuilds etc haben nicht geholfen.</p>
<p dir="auto">Irgendwo im LOG hieß es, dass das ding mit nem anderen node installiert wurde.<br />
Habs jetzt deinstalliert und reinstalliert.</p>
<p dir="auto">Muss natürlich alle objekte wieder anlegen, benennen etc.</p>
<p dir="auto">LG und danke für die Hilfe</p>
]]></description><link>https://forum.iobroker.net/post/809637</link><guid isPermaLink="true">https://forum.iobroker.net/post/809637</guid><dc:creator><![CDATA[jmeister79]]></dc:creator><pubDate>Fri, 03 Jun 2022 13:23:36 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Bluetooth nach Bullseye update und neuem Nodejs on Fri, 03 Jun 2022 10:55:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmeister79" aria-label="Profile: jmeister79">@<bdi>jmeister79</bdi></a> sagte in <a href="/post/809511">Kein Bluetooth nach Bullseye update und neuem Nodejs</a>:</p>
<blockquote>
<p dir="auto">Bluettooth hat keine elemente im Info Adapter, da ist nix.</p>
</blockquote>
<p dir="auto">Es war auch nicht die Rede vom info Adapter, sondern von<br />
ble.0.info.driverState</p>
<p dir="auto">Im ioBroker Verzeichnis ein</p>
<p dir="auto">npm install iobroker.adaptername@version --production<br />
ausführen.</p>
<p dir="auto">Danach nochmals "npm rebuild".</p>
]]></description><link>https://forum.iobroker.net/post/809521</link><guid isPermaLink="true">https://forum.iobroker.net/post/809521</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Fri, 03 Jun 2022 10:55:02 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Bluetooth nach Bullseye update und neuem Nodejs on Fri, 03 Jun 2022 10:27:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
<p dir="auto">im log stand:</p>
<pre><code>host.iobrokerpi
2022-06-03 12:09:12.795	info	Rebuild for adapter system.adapter.ble.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
host.iobrokerpi
2022-06-03 12:09:12.794	info	instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
ble.0
2022-06-03 12:09:12.672	error	Terminating because A dependency requires a rebuild.
</code></pre>
<p dir="auto">hab den Befehlt mal ausgeführt aber brachte nix. Wo muss der ausgeführt werden?</p>
]]></description><link>https://forum.iobroker.net/post/809511</link><guid isPermaLink="true">https://forum.iobroker.net/post/809511</guid><dc:creator><![CDATA[jmeister79]]></dc:creator><pubDate>Fri, 03 Jun 2022 10:27:39 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Bluetooth nach Bullseye update und neuem Nodejs on Fri, 03 Jun 2022 10:08:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmeister79" aria-label="Profile: jmeister79">@<bdi>jmeister79</bdi></a> sagte in <a href="/post/809490">Kein Bluetooth nach Bullseye update und neuem Nodejs</a>:</p>
<blockquote>
<p dir="auto">das neuese nodejs</p>
</blockquote>
<p dir="auto">wenn der Adapter fertig ist, ggf aufgrund von node.js Update nochmals ausführen</p>
<pre><code>sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
</code></pre>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmeister79" aria-label="Profile: jmeister79">@<bdi>jmeister79</bdi></a> sagte in <a href="/post/809495">Kein Bluetooth nach Bullseye update und neuem Nodejs</a>:</p>
<blockquote>
<p dir="auto">Hab gestern mittag geupdated</p>
</blockquote>
<p dir="auto">was zeigt <code>info.driverStateStatus</code></p>
]]></description><link>https://forum.iobroker.net/post/809499</link><guid isPermaLink="true">https://forum.iobroker.net/post/809499</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Fri, 03 Jun 2022 10:08:49 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Bluetooth nach Bullseye update und neuem Nodejs on Fri, 03 Jun 2022 10:07:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmeister79" aria-label="Profile: jmeister79">@<bdi>jmeister79</bdi></a></p>
<p dir="auto">Einen Tag dauert das nicht. Dann die manuelle Variante nehmen.</p>
]]></description><link>https://forum.iobroker.net/post/809497</link><guid isPermaLink="true">https://forum.iobroker.net/post/809497</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 03 Jun 2022 10:07:01 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Bluetooth nach Bullseye update und neuem Nodejs on Fri, 03 Jun 2022 10:05:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> mehr als ein tag Geduld? Hab gestern mittag geupdated und den fixer vor einer halben stunde angestoßen und iobroker neu gestartet</p>
]]></description><link>https://forum.iobroker.net/post/809495</link><guid isPermaLink="true">https://forum.iobroker.net/post/809495</guid><dc:creator><![CDATA[jmeister79]]></dc:creator><pubDate>Fri, 03 Jun 2022 10:05:55 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Bluetooth nach Bullseye update und neuem Nodejs on Fri, 03 Jun 2022 10:03:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmeister79" aria-label="Profile: jmeister79">@<bdi>jmeister79</bdi></a></p>
<p dir="auto">Abwarten.<br />
Da wird ble neugebaut.</p>
<p dir="auto">Wenn das nicht automagisch funktioniert von Hand machen. Oder ble deinstallieren und nochmal frisch drauf.</p>
]]></description><link>https://forum.iobroker.net/post/809493</link><guid isPermaLink="true">https://forum.iobroker.net/post/809493</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 03 Jun 2022 10:03:11 GMT</pubDate></item></channel></rss>
