Zigbee Adapter stürzt ständig ab
Nochmal
uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejspi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && ap t policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.3 v14.19.3 6.14.17 pi /home/pi Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease Get:4 https://phoscon.de/apt/deconz bullseye InRelease [2,873 B] Fetched 2,873 B in 3s (981 B/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.5' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.4' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension nodejs: Installed: 14.19.3-deb-1nodesource1 Candidate: 14.19.3-deb-1nodesource1 Version table: *** 14.19.3-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages 100 /var/lib/dpkg/status 12.22.5~dfsg-2~11u1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.5' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.4' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension -
pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && ap t policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.3 v14.19.3 6.14.17 pi /home/pi Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease Get:4 https://phoscon.de/apt/deconz bullseye InRelease [2,873 B] Fetched 2,873 B in 3s (981 B/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.5' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.4' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension nodejs: Installed: 14.19.3-deb-1nodesource1 Candidate: 14.19.3-deb-1nodesource1 Version table: *** 14.19.3-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages 100 /var/lib/dpkg/status 12.22.5~dfsg-2~11u1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.5' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.4' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extensionsudo rm /etc/apt/sources.list.d/nodesource.list.save.* -
sudo rm /etc/apt/sources.list.d/nodesource.list.save.*@thomas-braun muss ich diese zeile auch eingeben ?
sudo rm /etc/apt/sources.list.d/nodesource.list.save.* -bash: pi@raspberrypi:~: command not found -bash: armv7l: command not found Welcome to Node.js v14.19.3. Type ".help" for more information. -
sudo rm /etc/apt/sources.list.d/nodesource.list.save.* -bash: pi@raspberrypi:~: command not found -bash: armv7l: command not found Welcome to Node.js v14.19.3. Type ".help" for more information.Ja. Das beseitigt diese 'Ignoring...'-Meldungen.
[Edit:] Du kleisterst da irgendwas wild in die Konsole. Schau genauer was du da reinknallst.
@thomas-braun said in Zigbee Adapter stürzt ständig ab:
sieht schon mal alles super aus !!!! ich tippe auch nix mehr in die konsole rein
ich mache ein backup und gut ist !!! ich beobachte es mal über nacht ...
hofentlich läuft der zigbee adapter ohne absturze ..soll ich den zigbee adapter updaten auf 1.7.5?
Noch mal ein grosses DANKE im voraus.... -
Noch mal ein grosses DANKE im voraus....@klaris sagte in Zigbee Adapter stürzt ständig ab:
iobroker update -u iobroker upgrade all -
Noch mal ein grosses DANKE im voraus....Ist das jetzt suaber?
uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejsTip am Rande:
Wenn die ersten```alleine in einer eigenen Zeile stehen wird da auch ein schöner Code Block draus. -
Wenn die ersten```alleine in einer eigenen Zeile stehen wird da auch ein schöner Code Block draus.@thomas-braun sagte in Zigbee Adapter stürzt ständig ab:
pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && ap t policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.3 v14.19.3 6.14.17 pi /home/pi Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Get:3 https://phoscon.de/apt/deconz bullseye InRelease [2,873 B] Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease Fetched 2,873 B in 4s (693 B/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.5' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.4' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension nodejs: Installed: 14.19.3-deb-1nodesource1 Candidate: 14.19.3-deb-1nodesource1 Version table: *** 14.19.3-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages 100 /var/lib/dpkg/status 12.22.5~dfsg-2~11u1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.5' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.4' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension N: Ignoring file 'nodesource.list.save.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension -
pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/nodesource.list.sav* pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && ap t policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.3 v14.19.3 6.14.17 pi /home/pi Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease Get:4 https://phoscon.de/apt/deconz bullseye InRelease [2,873 B] Fetched 2,873 B in 3s (942 B/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. nodejs: Installed: 14.19.3-deb-1nodesource1 Candidate: 14.19.3-deb-1nodesource1 Version table: *** 14.19.3-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages 100 /var/lib/dpkg/status 12.22.5~dfsg-2~11u1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages -
pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/nodesource.list.sav* pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && ap t policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.3 v14.19.3 6.14.17 pi /home/pi Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease Get:4 https://phoscon.de/apt/deconz bullseye InRelease [2,873 B] Fetched 2,873 B in 3s (942 B/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. nodejs: Installed: 14.19.3-deb-1nodesource1 Candidate: 14.19.3-deb-1nodesource1 Version table: *** 14.19.3-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages 100 /var/lib/dpkg/status 12.22.5~dfsg-2~11u1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packagesiobroker update -i -
iobroker update -iAdapter "zigbee" : 1.7.5 , installed 1.7.5komisch ist nur wenn ich im iobroker unter adapter gehe steht :
Verfügbare Version:1.7.5 Installierte Version:1.6.18 obwohl ich ja 1.7.5 instaliert habe ...aber läuft ... das ist wichtig -
pi@raspberrypi:~ $ iobroker update -i Used repository: stable Adapter "admin" : 5.3.8 , installed 5.3.8 Adapter "alexa2" : 3.11.2 , installed 3.11.2 Adapter "backitup" : 2.4.6 , installed 2.4.6 Adapter "countdown" : 1.2.5 , installed 1.2.5 Adapter "daswetter" : 3.1.2 , installed 3.1.2 Adapter "discovery" : 3.0.3 , installed 3.0.3 Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.4 , installed 1.11.4 Adapter "javascript" : 5.7.0 , installed 5.7.0 Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "meross" : 1.10.5 , installed 1.10.5 Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "shelly" : 5.3.2 , installed 5.3.2 Adapter "simple-api" : 2.6.5 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.12.6 , installed 1.12.6 Adapter "tr-064" : 4.2.16 , installed 4.2.16 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "vis-hqwidgets": 1.2.0 , installed 1.2.0 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.1.7, installed 1.1.7 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "whatsapp-cmb" : 0.2.2 , installed 0.2.2 Adapter "ws" : 1.3.0 , installed 1.3.0 Adapter "zigbee" : 1.7.5 , installed 1.7.5 -
pi@raspberrypi:~ $ iobroker update -i Used repository: stable Adapter "admin" : 5.3.8 , installed 5.3.8 Adapter "alexa2" : 3.11.2 , installed 3.11.2 Adapter "backitup" : 2.4.6 , installed 2.4.6 Adapter "countdown" : 1.2.5 , installed 1.2.5 Adapter "daswetter" : 3.1.2 , installed 3.1.2 Adapter "discovery" : 3.0.3 , installed 3.0.3 Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.4 , installed 1.11.4 Adapter "javascript" : 5.7.0 , installed 5.7.0 Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "meross" : 1.10.5 , installed 1.10.5 Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "shelly" : 5.3.2 , installed 5.3.2 Adapter "simple-api" : 2.6.5 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "telegram" : 1.12.6 , installed 1.12.6 Adapter "tr-064" : 4.2.16 , installed 4.2.16 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "vis-hqwidgets": 1.2.0 , installed 1.2.0 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.1.7, installed 1.1.7 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "whatsapp-cmb" : 0.2.2 , installed 0.2.2 Adapter "ws" : 1.3.0 , installed 1.3.0 Adapter "zigbee" : 1.7.5 , installed 1.7.5iobroker upload allUnd starte den Browser mal neu. Zumindest die Admin-Seite nochmal richtig neuladen.
läuft -
läuft@klaris heute morgen ..leider das gleiche ...
daswetter.0 7089 2022-06-03 09:00:35.846 info Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment daswetter.0 7089 2022-06-03 09:00:29.165 info still wrong data structure from server received! repaired... daswetter.0 7089 2022-06-03 09:00:03.641 info starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.19.3, js-controller: 4.0.23 host.raspberrypi 2022-06-03 09:00:00.150 info instance system.adapter.daswetter.0 started with pid 7089 host.raspberrypi 2022-06-03 08:59:39.971 warn Do not restart adapter system.adapter.zigbee.0 because restart loop detected host.raspberrypi 2022-06-03 08:59:39.970 info Restart adapter system.adapter.zigbee.0 because enabled host.raspberrypi 2022-06-03 08:59:39.969 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.raspberrypi 2022-06-03 08:59:39.968 info Restart adapter system.adapter.zigbee.0 because enabled host.raspberrypi 2022-06-03 08:59:39.967 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.raspberrypi 2022-06-03 08:59:39.967 error Caught by controller[3]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12 host.raspberrypi 2022-06-03 08:59:39.967 error Caught by controller[3]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) host.raspberrypi 2022-06-03 08:59:39.966 error Caught by controller[3]: at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) host.raspberrypi 2022-06-03 08:59:39.966 error Caught by controller[3]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' host.raspberrypi 2022-06-03 08:59:39.965 error Caught by controller[2]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12 host.raspberrypi 2022-06-03 08:59:39.965 error Caught by controller[2]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) host.raspberrypi 2022-06-03 08:59:39.965 error Caught by controller[2]: at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) host.raspberrypi 2022-06-03 08:59:39.964 error Caught by controller[2]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' host.raspberrypi 2022-06-03 08:59:39.964 error Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.raspberrypi 2022-06-03 08:59:39.963 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: zigbee.0 7060 2022-06-03 08:59:39.207 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 7060 2022-06-03 08:59:39.204 info terminating zigbee.0 7060 2022-06-03 08:59:39.195 info Zigbee: disabling joining new devices. zigbee.0 7060 2022-06-03 08:59:39.064 info cleaned everything up... zigbee.0 7060 2022-06-03 08:59:39.050 error Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' zigbee.0 7060 2022-06-03 08:59:39.050 error Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12 zigbee.0 7060 2022-06-03 08:59:39.048 error unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' zigbee.0 7060 2022-06-03 08:59:39.047 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). web.0 2689 2022-06-03 08:59:33.060 info <== Disconnect system.user.admin from ::ffff:192.168.178.40 zigbee.0 7060 2022-06-03 08:59:19.680 error Error herdsman start zigbee.0 7060 2022-06-03 08:59:19.679 error Failed to start Zigbee zigbee.0 7060 2022-06-03 08:59:19.676 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'" zigbee.0 7060 2022-06-03 08:59:19.393 info Installed Version: iobroker.zigbee@1.7.5 zigbee.0 7060 2022-06-03 08:59:19.367 info Starting Zigbee npm ... zigbee.0 7060 2022-06-03 08:59:19.365 info Try to reconnect. 1 attempts left zigbee.0 7060 2022-06-03 08:59:09.371 info Installed Version: iobroker.zigbee@1.7.5 zigbee.0 7060 2022-06-03 08:59:09.359 error Error herdsman start zigbee.0 7060 2022-06-03 08:59:09.357 error Failed to start Zigbee zigbee.0 7060 2022-06-03 08:59:09.355 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'" zigbee.0 7060 2022-06-03 08:59:08.095 info Starting Zigbee npm ... zigbee.0 7060 2022-06-03 08:59:08.090 info delete old Backup files. keep only last 10 zigbee.0 7060 2022-06-03 08:59:07.908 info starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 host.raspberrypi 2022-06-03 08:59:00.487 info instance system.adapter.zigbee.0 started with pid 7060 host.raspberrypi 2022-06-03 08:59:00.484 info instance system.adapter.zigbee.0 started with pid 7060 host.raspberrypi 2022-06-03 08:59:00.173 info "system.adapter.zigbee.0" enabled host.raspberrypi 2022-06-03 08:58:59.002 info instance system.adapter.zigbee.0 terminated with code null () host.raspberrypi 2022-06-03 08:58:59.001 warn instance system.adapter.zigbee.0 terminated due to SIGTERM host.raspberrypi 2022-06-03 08:58:58.900 info stopInstance system.adapter.zigbee.0 killing pid 7053 host.raspberrypi 2022-06-03 08:58:57.898 info stopInstance system.adapter.zigbee.0 send kill signal host.raspberrypi 2022-06-03 08:58:57.822 info stopInstance system.adapter.zigbee.0 (force=false, process=true) host.raspberrypi 2022-06-03 08:58:57.821 info "system.adapter.zigbee.0" disabled host.raspberrypi 2022-06-03 08:58:57.148 info stopInstance system.adapter.zigbee.0 send kill signal host.raspberrypi 2022-06-03 08:58:57.075 info stopInstance system.adapter.zigbee.0 (force=false, process=true) host.raspberrypi 2022-06-03 08:58:56.777 info instance system.adapter.zigbee.0 started with pid 7053 host.raspberrypi 2022-06-03 08:58:54.713 info instance system.adapter.zigbee.0 terminated with code null () host.raspberrypi 2022-06-03 08:58:54.712 warn instance system.adapter.zigbee.0 terminated due to SIGTERM host.raspberrypi 2022-06-03 08:58:54.607 info stopInstance system.adapter.zigbee.0 killing pid 7046 host.raspberrypi 2022-06-03 08:58:53.605 info stopInstance system.adapter.zigbee.0 send kill signal host.raspberrypi 2022-06-03 08:58:53.592 info stopInstance system.adapter.zigbee.0 (force=false, process=true) host.raspberrypi 2022-06-03 08:58:52.424 info instance system.adapter.zigbee.0 started with pid 7046 host.raspberrypi 2022-06-03 08:58:26.981 info Restart adapter system.adapter.zigbee.0 because enabled host.raspberrypi 2022-06-03 08:58:26.980 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.raspberrypi 2022-06-03 08:58:26.979 error Caught by controller[0]: at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12 host.raspberrypi 2022-06-03 08:58:26.979 error Caught by controller[0]: at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) host.raspberrypi 2022-06-03 08:58:26.978 error Caught by controller[0]: at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) host.raspberrypi 2022-06-03 08:58:26.977 error Caught by controller[0]: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' host.raspberrypi 2022-06-03 08:58:26.976 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: zigbee.0 7029 2022-06-03 08:58:26.300 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 7029 2022-06-03 08:58:26.297 info terminating zigbee.0 7029 2022-06-03 08:58:26.278 info Zigbee: disabling joining new devices. zigbee.0 7029 2022-06-03 08:58:26.116 info cleaned everything up... zigbee.0 7029 2022-06-03 08:58:26.097 error Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' zigbee.0 7029 2022-06-03 08:58:26.096 error Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12 zigbee.0 7029 2022-06-03 08:58:26.093 error unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0' zigbee.0 7029 2022-06-03 08:58:26.091 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). host.raspberrypi 2022-06-03 08:58:13.379 error instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR) daswetter.0 7013 2022-06-03 08:58:13.348 error Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.Hour_3.symbol": Connection is closed. daswetter.0 7013 2022-06-03 08:58:13.345 error exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_1.current.temp: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.temp": Connection is closed.] daswetter.0 7013 2022-06-03 08:58:13.343 error Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.temp": Connection is closed. daswetter.0 7013 2022-06-03 08:58:13.340 error exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_1.Hour_3.temp: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.Hour_3.temp": Connection is closed.] daswetter.0 7013 2022-06-03 08:58:13.338 error Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.Hour_3.temp": Connection is closed. daswetter.0 7013 2022-06-03 08:58:13.336 error exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_1.current.hour: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.hour": Connection is closed.] daswetter.0 7013 2022-06-03 08:58:13.333 error Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_1.current.hour": Connection is closed. daswetter.0 7013 2022-06-03 08:58:13.329 error exception in await insertIntoList [Error: DB closed] daswetter.0 7013 2022-06-03 08:58:13.325 warn get state error: Connection is closed. daswetter.0 7013 2022-06-03 08:58:12.808 warn Terminated (UNKNOWN_ERROR): Without reason daswetter.0 7013 2022-06-03 08:58:12.805 error force terminate daswetter.0 7013 2022-06-03 08:58:12.738 info still wrong data structure from server received! repaired... zigbee.0 7029 2022-06-03 08:58:06.750 error Error herdsman start zigbee.0 7029 2022-06-03 08:58:06.749 error Failed to start Zigbee zigbee.0 7029 2022-06-03 08:58:06.745 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'" zigbee.0 7029 2022-06-03 08:58:06.424 info Installed Version: iobroker.zigbee@1.7.5 zigbee.0 7029 2022-06-03 08:58:06.386 info Starting Zigbee npm ... zigbee.0 7029 2022-06-03 08:58:06.384 info Try to reconnect. 1 attempts left zigbee.0 7029 2022-06-03 08:57:56.384 info Installed Version: iobroker.zigbee@1.7.5 zigbee.0 7029 2022-06-03 08:57:56.378 error Error herdsman start zigbee.0 7029 2022-06-03 08:57:56.377 error Failed to start Zigbee zigbee.0 7029 2022-06-03 08:57:56.375 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'" zigbee.0 7029 2022-06-03 08:57:54.880 info Starting Zigbee npm ... zigbee.0 7029 2022-06-03 08:57:54.873 info delete old Backup files. keep only last 10 zigbee.0 7029 2022-06-03 08:57:54.612 info starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23 host.raspberrypi 2022-06-03 08:57:44.648 info instance system.adapter.zigbee.0 started with pid 7029 daswetter.0 7013 2022-06-03 08:57:12.755 info starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.19.3, js-controller: 4.0.23 web.0 2689 2022-06-03 08:57:09.172 info ==> Connected system.user.admin from ::ffff:192.168.178.40 iot.2 983 2022-06-03 08:57:07.961 info Connection changed: connect host.raspberrypi 2022-06-03 08:57:06.801 info instance system.adapter.daswetter.0 started with pid 7013 host.raspberrypi 2022-06-03 08:57:06.681 info Restart adapter system.adapter.zigbee.0 because enabled host.raspberrypi 2022-06-03 08:57:06.674 info instance system.adapter.zigbee.0 terminated with code NaN () host.raspberrypi -
