  4. Sicherung influxDB - Fehlermeldung
    5.9k
27 Beiträge 4 Kommentatoren 2.9k Aufrufe 4 Beobachtet
  • crunchipC Abwesend
    crunchipC Abwesend
    und natürlich den influxdb service nach der Änderung neu starten
      Beowolf
      @crunchip
      Ich bekomme immer noch diese Meldung.
      Started iobroker ...
      [DEBUG] [mount] - Wake on LAN wait 25 Seconds for NAS!
      [DEBUG] [mount] - Wake on LAN MAC-Address: 38:EA:A7:A0:22:2B
      [DEBUG] [mount] - mount activ... umount is started before mount!!
      [DEBUG] [mount] - umount successfully completed
      [DEBUG] [mount] - noserverino option: false
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Administrator,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.49.31/Software/Backups/ioBroker /opt/iobroker/backups"
      [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Administrator,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.49.31/Software/Backups/ioBroker /opt/iobroker/backups"
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] - host.raspberrypi 6776 states saved
      [DEBUG] [iobroker] - host.raspberrypi 6907 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_06_01-10_18_56_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [influxDB] - InfluxDB-Backup started ...
      [DEBUG] [influxDB] - Start InfluxDB Backup ...
      [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
      [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
      [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
      [DEBUG] [influxDB] - 2022/06/01 10:19:09 backing up metastore to /opt/iobroker/backups/influxDB_2022_06_01-10_19_09_backupiobroker/meta.00
      [ERROR] [influxDB] - Error: Command failed: influxd backup -portable -database InfluxDB -host 192.168.49.43:8088 "/opt/iobroker/backups/influxDB_2022_06_01-10_19_09_backupiobroker"
      2022/06/01 10:19:09 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (0)...
      2022/06/01 10:19:11 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (1)...
      2022/06/01 10:19:13 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (2)...
      2022/06/01 10:19:15 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (3)...
      2022/06/01 10:19:17 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (4)...
      2022/06/01 10:19:19 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (5)...
      2022/06/01 10:19:21 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 3.01s and retrying (6)...
      2022/06/01 10:19:24 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 11.441s and retrying (7)...
      2022/06/01 10:19:36 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 43.477s and retrying (8)...
      2022/06/01 10:20:19 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2m45.216s and retrying (9)...
      backup: dial tcp 192.168.49.43:8088: connect: connection refused
        crunchipC Abwesend
        @beowolf installiert hast du aber den influxdb-service auf deinem iobroker und der Dienst läuft auch?
        Den influxdb-service hast du auf deinem anderen Pi (influxDB ist mit Grafana auf "Pi2-2 192.168.49.43)
        neu gestartet?
          neu gestartet?
          Beowolf
          @crunchip
          jepp. gerade noch mal gemacht.
          • B Beowolf
            @crunchip
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @beowolf
            ich hab in meiner influxdb.conf folgendes noch eingetragen geändert:
            # Bind address to use for the RPC service for backup and restore.
            bind-address = "192.168.178.21:8088"
            also die IP natürlich anpassen
            edit: Zeile 15
            Einstellungen in Backitup
            Lehrling seit 1975 !!!
            • DJMarc75D DJMarc75
              @beowolf
              edit: Zeile 15
              Beowolf
              @djmarc75
              habe ich auch so
              • B Beowolf
                @djmarc75
                habe ich auch so
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @beowolf
                auch die bind-adress in Zeile 15 in der influxdb.conf?
                  @beowolf
                  Beowolf
                  @djmarc75
                  jepp
                  • B Beowolf
                    @djmarc75
                    jepp
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    @beowolf
                    Also ich hab quasi die selbe Konstellation wie Du aber ich habe in der influxdb.conf nichts ausser die binding-adress in Zeile 15 und unter HTML die binding-adress aktiviert und angepasst.
                    Das ganze andere was Du aktiviert hast ist bei mir nicht aktiviert (# davor) und es funktioniert tadellos.
                    EDIT: Sorry für die Frage: von welchem Rechner hast du die influxdb.conf bearbeitet?
                      @beowolf
                      Beowolf
                      @djmarc75
                      ioBroker pi
                      • B Beowolf
                        @djmarc75
                        ioBroker pi
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @beowolf na das kann nicht funktionieren. Du musst die auf dem influx läuft bearbeiten.
                          Beowolf
                          @djmarc75
                          Kaum macht man es richtig - funktioniert es. 👍 👍 👍 👍 👍 👍 👍 👍 👍 👍
                          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_06_01-12_19_31_backupiobroker.tar.gz
                          [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2022_06_01-12_19_43_backupiobroker.tar.gz
                          [DEBUG] [influxDB] - InfluxDB-Backup for is finish
                          [DEBUG] [influxDB] - done
                          [DEBUG] [grafana] - Start Grafana Backup ...
                          [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                          [DEBUG] [grafana] - Created dashboard directory
                          [DEBUG] [grafana] - Created dashboards_manually_restore directory
                          [DEBUG] [grafana] - Created datasource directory
                          [DEBUG] [grafana] - start Grafana request ...
                          [DEBUG] [grafana] - Grafana is available ... Status: 200
                          [DEBUG] [grafana] - found Dashboard: olheizung
                          [DEBUG] [grafana] - found Dashboard: pflanzstreifen-garage
                          [DEBUG] [grafana] - found Dashboard: brutkasten
                          [DEBUG] [grafana] - found Dashboard: rosenpflanzkasten
                          [DEBUG] [grafana] - found Dashboard: pflanzstreifen-eingang
                          [DEBUG] [grafana] - found Dashboard: umweltdaten-stall
                          [DEBUG] [grafana] - found Dashboard: obergeschoss
                          [DEBUG] [grafana] - found Dashboard: dachgeschoss
                          [DEBUG] [grafana] - found Dashboard: wohnhaus
                          [DEBUG] [grafana] - found Dashboard: wetterdaten-stall
                          [DEBUG] [grafana] - found Dashboard: pflanzbeet-pflox
                          [DEBUG] [grafana] - found Dashboard: wasserspiel
                          [DEBUG] [grafana] - found Dashboard: phase-1
                          [DEBUG] [grafana] - found Dashboard: erdgeschoss
                          [DEBUG] [grafana] - found Dashboard: pflanzkasten-pflox
                          [DEBUG] [grafana] - start Grafana backup compress ...
                          [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2022_06_01-12_19_49_backupiobroker.tar.gz
                          [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                          [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                          [DEBUG] [grafana] - done
                          [DEBUG] [cifs] - done
                          [DEBUG] [clean] - done
                          [DEBUG] [pushover] - done
                          [DEBUG] [historyHTML] - new history html values created
                          [DEBUG] [historyHTML] - done
                          [DEBUG] [historyJSON] - new history json values created
                          [DEBUG] [historyJSON] - done
                          [DEBUG] [umount] - mount activ, umount is started ...
                          [DEBUG] [umount] - umount successfully completed
                          [DEBUG] [umount] - done
                          [EXIT] 0
                          • B Beowolf
                            @djmarc75
                            [EXIT] 0
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            @beowolf sagte in Sicherung influxDB - Fehlermeldung:
                            Geht mir oft auch so 🙄
                              Beowolf
                              @djmarc75
                              Vielen Dank für die Hilfe.
                              • B Beowolf
                                @djmarc75
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
