  4. Sicherung influxDB - Fehlermeldung
    5.9k
27 Beiträge 4 Kommentatoren 2.9k Aufrufe 4 Beobachtet
  • B Beowolf
    ### Welcome to the InfluxDB configuration file.
    # The values in this file override the default values used by the system if
    # a config option is not specified. The commented out lines are the configuration
    # field and the default value used. Uncommenting a line and changing the value
    # will change the value used at runtime when the process is restarted.
    # Once every 24 hours InfluxDB will report usage data to usage.influxdata.com
    # The data includes a random ID, os, arch, version, the number of series and other
    # usage data. No data from user databases is ever transmitted.
    # Change this option to true to enable reporting.
    reporting-enabled = false
    # Bind address to use for the RPC service for backup and restore.
    bind-address = "192.168.49.31:8088"
    ### [meta]
    ### Controls the parameters for the Raft consensus group that stores metadata
    ### about the InfluxDB cluster.
    [meta]
      # Where the metadata/raft database is stored
      dir = "/var/lib/influxdb/meta"
      # Automatically create a default retention policy when creating a database.
      # retention-autocreate = true
      # If log messages are printed for the meta service
      # logging-enabled = true
    ### [data]
    ### Controls where the actual shard data for InfluxDB lives and how it is
    ### flushed from the WAL. "dir" may need to be changed to a suitable place
    ### for your system, but the WAL settings are an advanced configuration. The
    ### defaults should work for most systems.
    [data]
      # The directory where the TSM storage engine stores TSM files.
      dir = "/var/lib/influxdb/data"
      # The directory where the TSM storage engine stores WAL files.
      wal-dir = "/var/lib/influxdb/wal"
      # The amount of time that a write will wait before fsyncing.  A duration
      # greater than 0 can be used to batch up multiple fsync calls.  This is useful for slower
      # disks or when WAL write contention is seen.  A value of 0s fsyncs every write to the WAL.
      # Values in the range of 0-100ms are recommended for non-SSD disks.
      # wal-fsync-delay = "0s"
      # The type of shard index to use for new shards.  The default is an in-memory index that is
      # recreated at startup.  A value of "tsi1" will use a disk based index that supports higher
      # cardinality datasets.
      # index-version = "inmem"
      # Trace logging provides more verbose output around the tsm engine. Turning
      # this on can provide more useful output for debugging tsm engine issues.
      # trace-logging-enabled = false
      # Whether queries should be logged before execution. Very useful for troubleshooting, but will
      # log any sensitive data contained within a query.
      # query-log-enabled = true
      # Settings for the TSM engine
      # CacheMaxMemorySize is the maximum size a shard's cache can
      # reach before it starts rejecting writes.
      # Valid size suffixes are k, m, or g (case insensitive, 1024 = 1k).
      # Values without a size suffix are in bytes.
      # cache-max-memory-size = "1g"
      # CacheSnapshotMemorySize is the size at which the engine will
      # snapshot the cache and write it to a TSM file, freeing up memory
      # cache-snapshot-memory-size = "25m"
      # CacheSnapshotWriteColdDuration is the length of time at
      # which the engine will snapshot the cache and write it to
      # a new TSM file if the shard hasn't received writes or deletes
      # cache-snapshot-write-cold-duration = "10m"
      # CompactFullWriteColdDuration is the duration at which the engine
      # will compact all TSM files in a shard if it hasn't received a
      # write or delete
      # compact-full-write-cold-duration = "4h"
      # The maximum number of concurrent full and level compactions that can run at one time.  A
      # value of 0 results in 50% of runtime.GOMAXPROCS(0) used at runtime.  Any number greater
      # than 0 limits compactions to that value.  This setting does not apply
      # to cache snapshotting.
      # max-concurrent-compactions = 0
      # The threshold, in bytes, when an index write-ahead log file will compact
      # into an index file. Lower sizes will cause log files to be compacted more
      # quickly and result in lower heap usage at the expense of write throughput.
      # Higher sizes will be compacted less frequently, store more series in-memory,
      # and provide higher write throughput.
      # max-index-log-file-size = "1m"
      # The maximum series allowed per database before writes are dropped.  This limit can prevent
      # high cardinality issues at the database level.  This limit can be disabled by setting it to
      # 0.
      # max-series-per-database = 1000000
      # The maximum number of tag values per tag that are allowed before writes are dropped.  This limit
      # can prevent high cardinality tag values from being written to a measurement.  This limit can be
      # disabled by setting it to 0.
      # max-values-per-tag = 100000
      # If true, then the mmap advise value MADV_WILLNEED will be provided to the kernel with respect to
      # TSM files. This setting has been found to be problematic on some kernels, and defaults to off.
      # It might help users who have slow disks in some cases.
      # tsm-use-madv-willneed = false
    ### [coordinator]
    ### Controls the clustering service configuration.
    [coordinator]
      # The default time a write request will wait until a "timeout" error is returned to the caller.
      # write-timeout = "10s"
      # The maximum number of concurrent queries allowed to be executing at one time.  If a query is
      # executed and exceeds this limit, an error is returned to the caller.  This limit can be disabled
      # by setting it to 0.
      # max-concurrent-queries = 0
      # The maximum time a query will is allowed to execute before being killed by the system.  This limit
      # can help prevent run away queries.  Setting the value to 0 disables the limit.
      # query-timeout = "0s"
      # The time threshold when a query will be logged as a slow query.  This limit can be set to help
      # discover slow or resource intensive queries.  Setting the value to 0 disables the slow query logging.
      # log-queries-after = "0s"
      # The maximum number of points a SELECT can process.  A value of 0 will make
      # the maximum point count unlimited.  This will only be checked every second so queries will not
      # be aborted immediately when hitting the limit.
      # max-select-point = 0
      # The maximum number of series a SELECT can run.  A value of 0 will make the maximum series
      # count unlimited.
      # max-select-series = 0
      # The maxium number of group by time bucket a SELECT can create.  A value of zero will max the maximum
      # number of buckets unlimited.
      # max-select-buckets = 0
    ### [retention]
    ### Controls the enforcement of retention policies for evicting old data.
    [retention]
      # Determines whether retention policy enforcement enabled.
      # enabled = true
      # The interval of time when retention policy enforcement checks run.
      # check-interval = "30m"
    ### [shard-precreation]
    ### Controls the precreation of shards, so they are available before data arrives.
    ### Only shards that, after creation, will have both a start- and end-time in the
    ### future, will ever be created. Shards are never precreated that would be wholly
    ### or partially in the past.
    [shard-precreation]
      # Determines whether shard pre-creation service is enabled.
      # enabled = true
      # The interval of time when the check to pre-create new shards runs.
      # check-interval = "10m"
      # The default period ahead of the endtime of a shard group that its successor
      # group is created.
      # advance-period = "30m"
    ### Controls the system self-monitoring, statistics and diagnostics.
    ### The internal database for monitoring data is created automatically if
    ### if it does not already exist. The target retention within this database
    ### is called 'monitor' and is also created with a retention period of 7 days
    ### and a replication factor of 1, if it does not exist. In all cases the
    ### this retention policy is configured as the default for the database.
    [monitor]
      # Whether to record statistics internally.
      # store-enabled = true
      # The destination database for recorded statistics
      # store-database = "_internal"
      # The interval at which to record statistics
      # store-interval = "10s"
    ### [http]
    ### Controls how the HTTP endpoints are configured. These are the primary
    ### mechanism for getting data into and out of InfluxDB.
    [http]
      # Determines whether HTTP endpoint is enabled.
    enabled = true
      # The bind address used by the HTTP service.
    bind-address = ":8086"
      # Determines whether user authentication is enabled over HTTP/HTTPS.
    auth-enabled = true
      # The default realm sent back when issuing a basic auth challenge.
      # realm = "InfluxDB"
      # Determines whether HTTP request logging is enabled.
    log-enabled = true
      # Determines whether the HTTP write request logs should be suppressed when the log is enabled.
      # suppress-write-log = false
      # When HTTP request logging is enabled, this option specifies the path where
      # log entries should be written. If unspecified, the default is to write to stderr, which
      # intermingles HTTP logs with internal InfluxDB logging.
      # If influxd is unable to access the specified path, it will log an error and fall back to writing
      # the request log to stderr.
      # access-log-path = ""
      # Determines whether detailed write logging is enabled.
    write-tracing = false
      # Determines whether the pprof endpoint is enabled.  This endpoint is used for
      # troubleshooting and monitoring.
    pprof-enabled = false
      # Enables a pprof endpoint that binds to localhost:6060 immediately on startup.
      # This is only needed to debug startup issues.
      # debug-pprof-enabled = false
      # Determines whether HTTPS is enabled.
    https-enabled = false
      # The SSL certificate to use when HTTPS is enabled.
    https-certificate = "/etc/ssl/influxdb.pem"
      # Use a separate private key location.
      # https-private-key = ""
      # The JWT auth shared secret to validate requests using JSON web tokens.
      # shared-secret = ""
      # The default chunk size for result sets that should be chunked.
      # max-row-limit = 0
      # The maximum number of HTTP connections that may be open at once.  New connections that
      # would exceed this limit are dropped.  Setting this value to 0 disables the limit.
      # max-connection-limit = 0
      # Enable http service over unix domain socket
      # unix-socket-enabled = false
      # The path of the unix domain socket.
      # bind-socket = "/var/run/influxdb.sock"
      # The maximum size of a client request body, in bytes. Setting this value to 0 disables the limit.
      # max-body-size = 25000000
      # The maximum number of writes processed concurrently.
      # Setting this to 0 disables the limit.
      # max-concurrent-write-limit = 0
      # The maximum number of writes queued for processing.
      # max-enqueued-write-limit = 0
      # The maximum duration for a write to wait in the queue to be processed.
      # Setting this to 0 or setting max-concurrent-write-limit to 0 disables the limit.
      # enqueued-write-timeout = 0
    ### [ifql]
    ### Configures the ifql RPC API.
    [ifql]
      # Determines whether the RPC service is enabled.
      # enabled = true
      # Determines whether additional logging is enabled.
      # log-enabled = true
      # The bind address used by the ifql RPC service.
      # bind-address = ":8082"
    ### [logging]
    ### Controls how the logger emits logs to the output.
    [logging]
      # Determines which log encoder to use for logs. Available options
      # are auto, logfmt, and json. auto will use a more a more user-friendly
      # output format if the output terminal is a TTY, but the format is not as
      # easily machine-readable. When the output is a non-TTY, auto will use
      # logfmt.
      # format = "auto"
      # Determines which level of logs will be emitted. The available levels
      # are error, warn, info, and debug. Logs that are equal to or above the
      # specified level will be emitted.
      # level = "info"
      # Suppresses the logo output that is printed when the program is started.
      # The logo is always suppressed if STDOUT is not a TTY.
      # suppress-logo = false
    ### [subscriber]
    ### Controls the subscriptions, which can be used to fork a copy of all data
    ### received by the InfluxDB host.
    [subscriber]
      # Determines whether the subscriber service is enabled.
      # enabled = true
      # The default timeout for HTTP writes to subscribers.
      # http-timeout = "30s"
      # Allows insecure HTTPS connections to subscribers.  This is useful when testing with self-
      # signed certificates.
      # insecure-skip-verify = false
      # The path to the PEM encoded CA certs file. If the empty string, the default system certs will be used
      # ca-certs = ""
      # The number of writer goroutines processing the write channel.
      # write-concurrency = 40
      # The number of in-flight writes buffered in the write channel.
      # write-buffer-size = 1000
    ### [[graphite]]
    ### Controls one or many listeners for Graphite data.
    [[graphite]]
      # Determines whether the graphite endpoint is enabled.
      # enabled = false
      # database = "graphite"
      # retention-policy = ""
      # bind-address = ":2003"
      # protocol = "tcp"
      # consistency-level = "one"
      # These next lines control how batching works. You should have this enabled
      # otherwise you could get dropped metrics or poor performance. Batching
      # will buffer points in memory if you have many coming in.
      # Flush if this many points get buffered
      # batch-size = 5000
      # number of batches that may be pending in memory
      # batch-pending = 10
      # Flush at least this often even if we haven't hit buffer limit
      # batch-timeout = "1s"
      # UDP Read buffer size, 0 means OS default. UDP listener will fail if set above OS max.
      # udp-read-buffer = 0
      ### This string joins multiple matching 'measurement' values providing more control over the final measurement name.
      # separator = "."
      ### Default tags that will be added to all metrics.  These can be overridden at the template level
      ### or by tags extracted from metric
      # tags = ["region=us-east", "zone=1c"]
      ### Each template line requires a template pattern.  It can have an optional
      ### filter before the template and separated by spaces.  It can also have optional extra
      ### tags following the template.  Multiple tags should be separated by commas and no spaces
      ### similar to the line protocol format.  There can be only one default template.
      # templates = [
      #   "*.app env.service.resource.measurement",
      #   # Default template
      #   "server.*",
    ### [collectd]
    ### Controls one or many listeners for collectd data.
    [[collectd]]
      # enabled = false
      # bind-address = ":25826"
      # database = "collectd"
      # The collectd service supports either scanning a directory for multiple types
      # db files, or specifying a single db file.
      # typesdb = "/usr/local/share/collectd"
      # security-level = "none"
      # auth-file = "/etc/collectd/auth_file"
      # batch-size = 5000
      # Number of batches that may be pending in memory
      # batch-timeout = "10s"
      # read-buffer = 0
      # Multi-value plugins can be handled two ways.
      # "split" will parse and store the multi-value plugin data into separate measurements
      # "join" will parse and store the multi-value plugin as a single multi-value measurement.
      # "split" is the default behavior for backward compatability with previous versions of influxdb.
      # parse-multivalue-plugin = "split"
    ### [opentsdb]
    ### Controls one or many listeners for OpenTSDB data.
    [[opentsdb]]
      # enabled = false
      # bind-address = ":4242"
      # database = "opentsdb"
      # tls-enabled = false
      # certificate= "/etc/ssl/influxdb.pem"
      # Log an error for every malformed point.
      # log-point-errors = true
      # otherwise you could get dropped metrics or poor performance. Only points
      # metrics received over the telnet protocol undergo batching.
      # batch-size = 1000
      # batch-pending = 5
    ### [[udp]]
    ### Controls the listeners for InfluxDB line protocol data via UDP.
    [[udp]]
      # enabled = false
      # bind-address = ":8089"
      # database = "udp"
      # InfluxDB precision for timestamps on received points ("" or "n", "u", "ms", "s", "m", "h")
      # precision = ""
      # batch-size = 5000
      # Will flush at least this often even if we haven't hit buffer limit
      # read-buffer = 0
    ### [continuous_queries]
    ### Controls how continuous queries are run within InfluxDB.
      # Determines whether the continuous query service is enabled.
      # enabled = true
      # Controls whether queries are logged when executed by the CQ service.
      # Controls whether queries are logged to the self-monitoring data store.
      # query-stats-enabled = false
      # interval for how often continuous queries will be checked if they need to run
      # run-interval = "1s"
    ### [tls]
    ### Global configuration settings for TLS in InfluxDB.
    [tls]
      # Determines the available set of cipher suites. See https://golang.org/pkg/crypto/tls/#pkg-constants
      # for a list of available ciphers, which depends on the version of Go (use the query
      # SHOW DIAGNOSTICS to see the version of Go used to build InfluxDB). If not specified, uses
      # the default settings from Go's crypto/tls package.
      # ciphers = [
      #   "TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305",
      #   "TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256",
      # Minimum version of the tls protocol that will be negotiated. If not specified, uses the
      # default settings from Go's crypto/tls package.
      # min-version = "tls1.2"
      # Maximum version of the tls protocol that will be negotiated. If not specified, uses the
      # max-version = "tls1.2"
    @beowolf
    Wenn die InfluxDB von einem entfernten Server gesichert werden soll, müssen in der influxdb.conf auf dem entfernten Server die Remote-Rechte für den RPC-Dienst angepasst werden.
    bind-address = "<InfluxDB-IP>:8088"
    oder
    bind-address = "0.0.0.0:8088"
    Die ist bei dir nicht richtig eingetragen.
    • B Beowolf
      ### [meta]
      [meta]
      ### [data]
      [data]
        # write or delete
        # 0.
      ### [coordinator]
      [coordinator]
        # count unlimited.
      ### [retention]
      [retention]
        # enabled = true
      [shard-precreation]
        # enabled = true
        # group is created.
      [monitor]
      ### [http]
      [http]
      enabled = true
      auth-enabled = true
      log-enabled = true
        # max-row-limit = 0
      ### [ifql]
      [ifql]
        # enabled = true
      ### [logging]
      [logging]
        # logfmt.
        # format = "auto"
        # level = "info"
      ### [subscriber]
      [subscriber]
        # enabled = true
        # ca-certs = ""
      ### [[graphite]]
      [[graphite]]
        # enabled = false
        # protocol = "tcp"
        # batch-size = 5000
        # separator = "."
        # templates = [
        #   "server.*",
      ### [collectd]
      [[collectd]]
        # enabled = false
        # batch-size = 5000
        # read-buffer = 0
      ### [opentsdb]
      [[opentsdb]]
        # enabled = false
        # batch-size = 1000
        # batch-pending = 5
      ### [[udp]]
      [[udp]]
        # enabled = false
        # database = "udp"
        # precision = ""
        # batch-size = 5000
        # read-buffer = 0
        # enabled = true
      ### [tls]
      [tls]
        # ciphers = [
      Beowolf
      Muß dort
      die ipadresse vom influxdb rechner rein?
      • B Beowolf
        Muß dort
        @beowolf
        192.168.49.43
        oder
        0.0.0.0
        • crunchipC Abwesend
          crunchipC Abwesend
          und natürlich den influxdb service nach der Änderung neu starten
            Beowolf
            @crunchip
            Ich bekomme immer noch diese Meldung.
            Started iobroker ...
            [DEBUG] [mount] - Wake on LAN wait 25 Seconds for NAS!
            [DEBUG] [mount] - Wake on LAN MAC-Address: 38:EA:A7:A0:22:2B
            [DEBUG] [mount] - mount activ... umount is started before mount!!
            [DEBUG] [mount] - umount successfully completed
            [DEBUG] [mount] - noserverino option: false
            [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Administrator,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.49.31/Software/Backups/ioBroker /opt/iobroker/backups"
            [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
            [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Administrator,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.49.31/Software/Backups/ioBroker /opt/iobroker/backups"
            [DEBUG] [mount] - mount successfully completed
            [DEBUG] [mount] - done
            [DEBUG] [iobroker] - host.raspberrypi 6776 states saved
            [DEBUG] [iobroker] - host.raspberrypi 6907 objects saved
            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_06_01-10_18_56_backupiobroker.tar.gz
            [DEBUG] [iobroker] - done
            [DEBUG] [influxDB] - InfluxDB-Backup started ...
            [DEBUG] [influxDB] - Start InfluxDB Backup ...
            [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
            [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
            [DEBUG] [influxDB] - 2022/06/01 10:19:09 backing up metastore to /opt/iobroker/backups/influxDB_2022_06_01-10_19_09_backupiobroker/meta.00
            [ERROR] [influxDB] - Error: Command failed: influxd backup -portable -database InfluxDB -host 192.168.49.43:8088 "/opt/iobroker/backups/influxDB_2022_06_01-10_19_09_backupiobroker"
            2022/06/01 10:19:09 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (0)...
            2022/06/01 10:19:11 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (1)...
            2022/06/01 10:19:13 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (2)...
            2022/06/01 10:19:15 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (3)...
            2022/06/01 10:19:17 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (4)...
            2022/06/01 10:19:19 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2s and retrying (5)...
            2022/06/01 10:19:21 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 3.01s and retrying (6)...
            2022/06/01 10:19:24 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 11.441s and retrying (7)...
            2022/06/01 10:19:36 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 43.477s and retrying (8)...
            2022/06/01 10:20:19 Download shard 0 failed dial tcp 192.168.49.43:8088: connect: connection refused.  Waiting 2m45.216s and retrying (9)...
            backup: dial tcp 192.168.49.43:8088: connect: connection refused
              crunchipC Abwesend
              @beowolf installiert hast du aber den influxdb-service auf deinem iobroker und der Dienst läuft auch?
              Den influxdb-service hast du auf deinem anderen Pi (influxDB ist mit Grafana auf "Pi2-2 192.168.49.43)
              neu gestartet?
                neu gestartet?
                Beowolf
                @crunchip
                jepp. gerade noch mal gemacht.
                • B Beowolf
                  @crunchip
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  @beowolf
                  ich hab in meiner influxdb.conf folgendes noch eingetragen geändert:
                  bind-address = "192.168.178.21:8088"
                  also die IP natürlich anpassen
                  edit: Zeile 15
                  Einstellungen in Backitup
                  Lehrling seit 1975 !!!
                  • DJMarc75D DJMarc75
                    @beowolf
                    edit: Zeile 15
                    Beowolf
                    @djmarc75
                    habe ich auch so
                    • B Beowolf
                      @djmarc75
                      habe ich auch so
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      @beowolf
                      auch die bind-adress in Zeile 15 in der influxdb.conf?
                        @beowolf
                        Beowolf
                        @djmarc75
                        jepp
                        • B Beowolf
                          @djmarc75
                          jepp
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @beowolf
                          Also ich hab quasi die selbe Konstellation wie Du aber ich habe in der influxdb.conf nichts ausser die binding-adress in Zeile 15 und unter HTML die binding-adress aktiviert und angepasst.
                          Das ganze andere was Du aktiviert hast ist bei mir nicht aktiviert (# davor) und es funktioniert tadellos.
                          EDIT: Sorry für die Frage: von welchem Rechner hast du die influxdb.conf bearbeitet?
                            @beowolf
                            Beowolf
                            @djmarc75
                            ioBroker pi
                            • B Beowolf
                              @djmarc75
                              ioBroker pi
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              @beowolf na das kann nicht funktionieren. Du musst die auf dem influx läuft bearbeiten.
                                Beowolf
                                @djmarc75
                                Kaum macht man es richtig - funktioniert es. 👍 👍 👍 👍 👍 👍 👍 👍 👍 👍
                                [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_06_01-12_19_31_backupiobroker.tar.gz
                                [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2022_06_01-12_19_43_backupiobroker.tar.gz
                                [DEBUG] [influxDB] - InfluxDB-Backup for is finish
                                [DEBUG] [influxDB] - done
                                [DEBUG] [grafana] - Start Grafana Backup ...
                                [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                [DEBUG] [grafana] - Created dashboard directory
                                [DEBUG] [grafana] - Created dashboards_manually_restore directory
                                [DEBUG] [grafana] - Created datasource directory
                                [DEBUG] [grafana] - start Grafana request ...
                                [DEBUG] [grafana] - Grafana is available ... Status: 200
                                [DEBUG] [grafana] - found Dashboard: olheizung
                                [DEBUG] [grafana] - found Dashboard: pflanzstreifen-garage
                                [DEBUG] [grafana] - found Dashboard: brutkasten
                                [DEBUG] [grafana] - found Dashboard: rosenpflanzkasten
                                [DEBUG] [grafana] - found Dashboard: pflanzstreifen-eingang
                                [DEBUG] [grafana] - found Dashboard: umweltdaten-stall
                                [DEBUG] [grafana] - found Dashboard: obergeschoss
                                [DEBUG] [grafana] - found Dashboard: dachgeschoss
                                [DEBUG] [grafana] - found Dashboard: wohnhaus
                                [DEBUG] [grafana] - found Dashboard: wetterdaten-stall
                                [DEBUG] [grafana] - found Dashboard: pflanzbeet-pflox
                                [DEBUG] [grafana] - found Dashboard: wasserspiel
                                [DEBUG] [grafana] - found Dashboard: phase-1
                                [DEBUG] [grafana] - found Dashboard: erdgeschoss
                                [DEBUG] [grafana] - found Dashboard: pflanzkasten-pflox
                                [DEBUG] [grafana] - start Grafana backup compress ...
                                [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2022_06_01-12_19_49_backupiobroker.tar.gz
                                [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                                [DEBUG] [grafana] - done
                                [DEBUG] [cifs] - done
                                [DEBUG] [clean] - done
                                [DEBUG] [pushover] - done
                                [DEBUG] [historyHTML] - new history html values created
                                [DEBUG] [historyHTML] - done
                                [DEBUG] [historyJSON] - new history json values created
                                [DEBUG] [historyJSON] - done
                                [DEBUG] [umount] - mount activ, umount is started ...
                                [DEBUG] [umount] - umount successfully completed
                                [DEBUG] [umount] - done
                                [EXIT] 0
                                • B Beowolf
                                  @djmarc75
                                  [EXIT] 0
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  @beowolf sagte in Sicherung influxDB - Fehlermeldung:
                                  Geht mir oft auch so 🙄
                                    Beowolf
                                    @djmarc75
                                    Vielen Dank für die Hilfe.
                                    • B Beowolf
                                      @djmarc75
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
