  3. Off Topic
  4. Proxmox
  5. Fehler bei gnupg Installation
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
33 Beiträge 6 Kommentatoren 3.8k Aufrufe 5 Beobachtet
  • F Fridolin01
    @thomas-braun said in Fehler bei gnupg Installation:
    sudo apt update
    sudo apt update
    sudo: setrlimit(RLIMIT_CORE): Operation not permitted
    Err:1 http://archive.ubuntu.com/ubuntu focal InRelease
      Temporary failure resolving 'archive.ubuntu.com'
    Err:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
    Err:3 http://archive.ubuntu.com/ubuntu focal-security InRelease
    Reading package lists... Done
    All packages are up to date.
    W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease  Temporary failure resolving 'archive.ubuntu.com'
    W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease  Temporary failure resolving 'archive.ubuntu.com'
    W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-security/InRelease  Temporary failure resolving 'archive.ubuntu.com'
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    @fridolin01
    Und das ist die vollständige, ungekürzte Ausgabe?
    Wenn nein, bitte vollständige, ungekürzte Ein- und Ausgaben inkl. login prompt posten, wenn ja fehlt das nodesource-Repository.
    F 1 Antwort Letzte Antwort
      @fridolin01
      Fridolin01
      @thomas-braun Ja Vollständig und ungekürzt
      • F Fridolin01
        crunchipC Offline
        crunchipC Offline
        @fridolin01
        @thomas-braun sagte in Fehler bei gnupg Installation:
          @fridolin01
          Fridolin01
          @crunchip
          Ubuntu 20.04 LTS Grafana tty1
          Grafana login: root
          Password:
          Welcome to Ubuntu 20.04 LTS (GNU/Linux 5.4.34-1-pve x86_64)
           * Documentation:  https://help.ubuntu.com
           * Management:     https://landscape.canonical.com
           * Support:        https://ubuntu.com/advantage
          Failed to connect to https://changelogs.ubuntu.com/meta-release-lts. Check your Internet connection or proxy settings
          Last login: Sun May 22 18:45:38 UTC 2022 on tty1
          root@Grafana:~# sudo apt update
          root@Grafana:~#
          crunchipC Meister MopperM 2 Antworten Letzte Antwort
          • F Fridolin01
            @crunchip
            Grafana login: root
            Password:
            root@Grafana:~#
            crunchipC Offline
            crunchipC Offline
            @fridolin01 sagte in Fehler bei gnupg Installation:
            Grafana login: root
            https://www.iobroker.net/#de/documentation/install/proxmox.md
              Grafana login: root
              @crunchip sagte in Fehler bei gnupg Installation:
              Grafana login: root
              und dann auch noch:
              • F Fridolin01
                @crunchip
                Grafana login: root
                Password:
                root@Grafana:~#
                Meister MopperM Online
                Meister Mopper
                @fridolin01
                Was man Dir mit präattentiver Visualisierung sagen möchte:
                • Leg Dir für den Container einen User an und arbeite nicht als root.
                • Gib die Kommandos mit sudo ein, wenn Du root-Rechte benötigst.
                *duckundwech
                Proxmox und HA - dank KI/AI endlich "blocklyfrei"
                  @fridolin01
                  *duckundwech
                  @meister-mopper sagte in Fehler bei gnupg Installation:
                  aber nicht wenn du schon root bist!
                    Dann bist du superroot: Neu, jetzt noch rootiger.
                    @Fridolin01: Verfummel das System nicht! Bei Ubuntu gibt es keinen root-account. Hat es noch nie, wird es auch nie geben. Hier wird immer mit einem Standarduser hantiert, der Fallweise per sudo kurz die erforderlichen Rechte erlangen kann.
                    Und kümmer dich um das Netzwerk, das scheint grundsätzlich falsch aufgesetzt zu sein. Also kein Problem mit den Repos sondern bei dir lokal.
                      Grafana login: root
                      und dann auch noch:
                      crunchipC Offline
                      crunchipC Offline
                      @homoran sagte in Fehler bei gnupg Installation:
                      und dann auch noch:
                      soweit hab ich gar nimmer gelesen😁
                        Meister Mopper
                        Da ist es wieder, das Container-Problem. Gibbet doch!
                        Ubuntu 20.04.4 LTS pihole tty1
                        pihole login: root
                        Password:
                        Welcome to Ubuntu 20.04.4 LTS (GNU/Linux 5.15.35-1-pve x86_64)
                        Last login: Mi Sep 15 07:51:29 CEST 2021 on tty1
                        root@pihole:~# lsb_release -a
                        No LSB modules are available.
                        Distributor ID: Ubuntu
                        Description:    Ubuntu 20.04.4 LTS
                        Release:        20.04
                        Codename:       focal
                          pihole login: root
                          Password:
                          Release:        20.04
                          Codename:       focal
                          @meister-mopper
                          Es wird trotzdem als Standarduser über das System gerutscht und nicht als root. In einer Standard-Installation von Ubuntu ist das auch immer der Fall. Bei den Müll-Containern sollte das auch Standard sein.
                          Aber das ist offenbar ja nicht die einzige Fehlkonfiguration hier.
                          Edit:
                          Wenn ich mir anschaue, dass lt. Statistik Docker nicht mal 8% Anteil an den Installationen hat kommt es da zumindest gefühlt überproportional zu Problemen:
                            @meister-mopper
                            Edit:
                            Meister Mopper
                            Ja natürlich! @Fridolin01 benötigt vielleicht eine Hilfe, wie er den normalen User anlegt?
                            @Fridolin01 : Hier könntest Du jetzt was schreiben :man-shrugging:
                              @meister-mopper
                              Edit:
                              Meister Mopper
                              Edit:
                              Hast Du Dich verirrt? Docker?
                                Edit:
                                @meister-mopper
                                Nein, hab mich nicht verirrt. Nur keine Statistik zu Proxmurks gefunden. Da muss der Docker-Container halt als negatives Beispiel herhalten.
                                  @meister-mopper
                                  Meister Mopper
                                  @thomas-braun 😂 😂
                                    @thomas-braun 😂 😂
                                    So grundsätzlich halte ich es nicht für eine gute Idee, ohne ein Mindestmaß an Linux-Kenntnissen sich mit den Besonderheiten eines Containers noch zusätzlich auseinanderzusetzen.
                                    Einen 40-Tonner-LKW darfst du auch nicht mit dem PKW-Führerschein fahren, da braucht es mehr Erfahrung und mehr Wissen wie das alles funktioniert.
                                      Meister Mopper
                                      Offtopic:
                                      Na ja, aber angefangen haben wir doch alle mal. Ich kam als reiner Windows-User über den Pi und bin mittlerweile mit 'nem Proxmox-Cluster unterwegs.
                                      Geholfen wurde mir hier in diesem Forum (sehr viel habe ich dabei für Linux von Dir gelernt 😀 ).
                                        crunchipC Offline
                                        crunchipC Offline
                                        @meister-mopper LXC sind root, anders als bei VM,
                                        Hilfe hab ich doch oben schon Verlinkt
                                        HomoranH Meister MopperM 2 Antworten Letzte Antwort
                                          LXC sind root,
                                          Wieder was gelernt, Danke!
                                          Aber ein Grund mehr, warum Einsteiger diese nicht nutzen sollten.
