  4. Keine Verbindung nach admin-update am 06.05
    5.9k
56 Beiträge 4 Kommentatoren 5.7k Aufrufe 3 Beobachtet
    @oliver1972
    iobroker restart
    iobroker list instances
    Shakira1972
    @thomas-braun ```
    pi@raspberrypi:~ $ iobroker restart
    pi@raspberrypi:~ $ iobroker list instances
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
      system.adapter.bosesoundtouch.0         : bosesoundtouch        : raspberrypi                              - disabled
      system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
      system.adapter.harmony.0                : harmony               : raspberrypi                              - disabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.178.72 (SSL)
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
    + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
    + system.adapter.virtualpowermeter.0      : virtualpowermeter     : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0afb8cee4fc9eb119b7a8b4f1d69213e-if00-port0
    + instance is alive
    • GlasfaserG Glasfaser
      @oliver1972 sagte in Keine Verbindung nach admin-update am 06.05:
      ich habe gestern meinen Admin-Adapter, geupdatet.
      Bist du im Beta Kanal unterwegs !?
      Shakira1972
      @glasfaser said in Keine Verbindung nach admin-update am 06.05:
      Nein kein Beta
      • S Shakira1972
        @thomas-braun ```
        + instance is alive
        GlasfaserG Offline
        GlasfaserG Offline
        @oliver1972
        Zeige mal bitte :
        uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        • Thomas BraunT Online
          @oliver1972
          Der admin läuft ja auch nicht.
          iobroker start admin.0
            @oliver1972
            Zeige mal bitte :
            Shakira1972
            @oliver1972
            Zeige mal bitte :
            pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.19.2
            v14.19.2
            6.14.17
            pi
            /home/pi
            OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:2 http://archive.raspberrypi.org/debian buster InRelease
            OK:3 https://deb.nodesource.com/node_14.x buster InRelease
            Alle Pakete sind aktuell.
            nodejs:
              Installiert:           14.19.2-deb-1nodesource1
              Installationskandidat: 14.19.2-deb-1nodesource1
              Versionstabelle:
             *** 14.19.2-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                 10.24.0~dfsg-1~deb10u1 500
              @oliver1972
              Shakira1972
              @thomas-braun said in Keine Verbindung nach admin-update am 06.05:
              pi@raspberrypi:~ $ iobroker start admin.0
              pi@raspberrypi:~ $
              Öfnnet sich immer noch nicht...
              GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
              • S Shakira1972
                pi@raspberrypi:~ $
                GlasfaserG Offline
                GlasfaserG Offline
                @oliver1972
                Zeige mal :
                iobroker update -i
                • S Shakira1972
                  pi@raspberrypi:~ $
                    @oliver1972
                    Zeige mal :
                    iobroker update -i
                    Shakira1972
                    @glasfaser sagte in Keine Verbindung nach admin-update am 06.05:
                    Zeige mal :
                    iobroker update -i
                    pi@raspberrypi:~ $ iobroker update -i
                    Used repository: latest
                    hash changed or no sources cached => force download of new sources
                    update done
                    Adapter    "admin"         : 5.4.4    , installed 5.4.2 [Updateable]
                    Adapter    "backitup"      : 2.4.6    , installed 2.4.6
                    Adapter    "bosesoundtouch": 0.10.0   , installed 0.10.0
                    Adapter    "discovery"     : 3.0.3    , installed 3.0.3
                    Adapter    "flot"          : 1.10.7   , installed 1.10.7
                    Adapter    "fritzbox"      : 0.5.0    , installed 0.5.0
                    Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                    Adapter    "history"       : 1.11.1   , installed 1.11.1
                    Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
                    Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
                    Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
                    Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
                    Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
                    Adapter    "icons-mfd-svg" : 1.1.0    , installed 1.1.0
                    Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
                    Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                    Adapter    "iogopro"       : 0.2.6    , installed 0.2.6
                    Adapter    "javascript"    : 5.7.0    , installed 5.6.0 [Updateable]
                    Controller "js-controller" : 4.0.23   , installed 3.3.22 [Updateable]
                    Adapter    "node-red"      : 3.3.0    , installed 3.3.0
                    Adapter    "ping"          : 1.5.3    , installed 1.5.3
                    Adapter    "rpi2"          : 1.3.2    , installed 1.3.2
                    Adapter    "simple-api"    : 2.6.5    , installed 2.6.5
                    Adapter    "socketio"      : 4.2.0    , installed 4.2.0
                    Adapter    "sonoff"        : 2.5.1    , installed 2.5.1
                    Adapter    "sourceanalytix": 0.4.14   , installed 0.4.14
                    Adapter    "telegram"      : 1.12.6   , installed 1.12.6
                    Adapter    "tr-064"        : 4.2.16   , installed 4.2.16
                    Adapter    "tuya"          : 3.6.15   , installed 3.6.15
                    Adapter    "tvspielfilm"   : 2.0.4    , installed 2.0.4
                    Adapter    "upnp"          : 1.0.21   , installed 1.0.21
                    Adapter    "virtualpowermeter": 1.4.6   , installed 1.4.6
                    Adapter    "vis"           : 1.4.15   , installed 1.4.15
                    Adapter    "vis-3dmodel"   : 0.0.10   , installed 0.0.10
                    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
                    Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                    Adapter    "vis-hqwidgets" : 1.2.0    , installed 1.2.0
                    Adapter    "vis-icontwo"   : 0.87.0   , installed 0.87.0
                    Adapter    "vis-inventwo"  : 3.3.3    , installed 3.3.3
                    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
                    Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                    Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
                    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
                    Adapter    "vis-material-advanced": 1.7.2   , installed 1.7.2
                    Adapter    "vis-material-webfont": 0.0.3   , installed 0.0.3
                    Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.9
                    Adapter    "vis-metro"     : 1.2.0    , installed 1.2.0
                    Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
                    Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
                    Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
                    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                    Adapter    "vis-weather"   : 2.5.5    , installed 2.5.5
                    Adapter    "web"           : 4.3.0    , installed 4.3.0
                    Adapter    "ws"            : 1.3.0    , installed 1.3.0
                    Adapter    "zigbee"        : 1.6.18   , installed 1.6.18
                      Shakira1972
                      @thomas-braun sagte in Keine Verbindung nach admin-update am 06.05:
                      + instance is alive
                      • S Shakira1972
                        Zeige mal :
                        iobroker update -i
                        update done
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Doch in Beta , habe ich mir doch gedacht !!!
                        S GlasfaserG 2 Antworten Letzte Antwort
                          Shakira1972
                          Ok, wie komme ich zur Beta und warum?
                          Wie kann ich zurrück zur normalen?
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @glasfaser
                            gehe erstmal zurück
                            iobroker upgrade admin@5.3.8
                            • S Shakira1972
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Von alleine kommt das nicht , das wurde so von dir in ioBroker (Verwahrungsort ) so angebenen , verändert von Stable in Beta
                              • S Shakira1972
                                Zeige mal :
                                iobroker update -i
                                update done
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Du hast auch noch den alten Controller !
                                Stelle dein Verwahrungsort auf Stable und aktuallisiere erstmal dein ioBroker auf den neusten Stand !
                                S 2 Antworten Letzte Antwort
                                  Shakira1972
                                  @glasfaser Danke für die Hilfe,
                                  es funktioniert wieder,
                                  kann mich nicht errinnern das ich irgendwo Beta eingestellt habe.
                                  Bei "Repositories", steht bei mir in der Zeile 1 Default und dieser Link:
                                  download.iobroker.net/sources-dist.json
                                  Wo Default steht schreibe ich Stable, bleibt der Link dieser?
                                  In Zeile 2 steht: latest und dieser link: download.iobroker.net/sources-dist-latest.json
                                  • S Shakira1972
                                    @oliver1972
                                    iobroker repo list
                                    anschauen.
                                      @oliver1972
                                      iobroker repo list
                                      anschauen.
                                      Shakira1972
                                      pi@raspberrypi:~ $ iobroker repo list
                                      default     : http://download.iobroker.net/sources-dist.json
                                      latest      : http://download.iobroker.net/sources-dist-latest.json
                                      Active repo: latest
                                      pi@raspberrypi:~ $
                                      • S Shakira1972
                                        Active repo: latest
                                        pi@raspberrypi:~ $
                                        @oliver1972
                                        iobroker repo set default
                                        iobroker repo unset latest
                                          @oliver1972
                                          Shakira1972
                                          Active repo: default
