  4. Keine Verbindung nach admin-update am 06.05
    5.9k
56 Beiträge 4 Kommentatoren 5.7k Aufrufe 3 Beobachtet
    @oliver1972 sagte in Keine Verbindung nach admin-update am 06.05:
    Öfnnet sich immer noch nicht...
    iobroker list instances
    Shakira1972
    @thomas-braun sagte in Keine Verbindung nach admin-update am 06.05:
    pi@raspberrypi:~ $ iobroker list instances
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
      system.adapter.bosesoundtouch.0         : bosesoundtouch        : raspberrypi                              - disabled
      system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
      system.adapter.harmony.0                : harmony               : raspberrypi                              - disabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.178.72 (SSL)
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
    + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
    + system.adapter.virtualpowermeter.0      : virtualpowermeter     : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0afb8cee4fc9eb119b7a8b4f1d69213e-if00-port0
    + instance is alive
    • S Shakira1972
      @glasfaser sagte in Keine Verbindung nach admin-update am 06.05:
      Zeige mal :
      iobroker update -i
      pi@raspberrypi:~ $ iobroker update -i
      Used repository: latest
      hash changed or no sources cached => force download of new sources
      update done
      Adapter    "admin"         : 5.4.4    , installed 5.4.2 [Updateable]
      Adapter    "backitup"      : 2.4.6    , installed 2.4.6
      Adapter    "bosesoundtouch": 0.10.0   , installed 0.10.0
      Adapter    "discovery"     : 3.0.3    , installed 3.0.3
      Adapter    "flot"          : 1.10.7   , installed 1.10.7
      Adapter    "fritzbox"      : 0.5.0    , installed 0.5.0
      Adapter    "harmony"       : 1.2.2    , installed 1.2.2
      Adapter    "history"       : 1.11.1   , installed 1.11.1
      Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
      Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
      Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
      Adapter    "icons-mfd-svg" : 1.1.0    , installed 1.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "iogopro"       : 0.2.6    , installed 0.2.6
      Adapter    "javascript"    : 5.7.0    , installed 5.6.0 [Updateable]
      Controller "js-controller" : 4.0.23   , installed 3.3.22 [Updateable]
      Adapter    "node-red"      : 3.3.0    , installed 3.3.0
      Adapter    "ping"          : 1.5.3    , installed 1.5.3
      Adapter    "rpi2"          : 1.3.2    , installed 1.3.2
      Adapter    "simple-api"    : 2.6.5    , installed 2.6.5
      Adapter    "socketio"      : 4.2.0    , installed 4.2.0
      Adapter    "sonoff"        : 2.5.1    , installed 2.5.1
      Adapter    "sourceanalytix": 0.4.14   , installed 0.4.14
      Adapter    "telegram"      : 1.12.6   , installed 1.12.6
      Adapter    "tr-064"        : 4.2.16   , installed 4.2.16
      Adapter    "tuya"          : 3.6.15   , installed 3.6.15
      Adapter    "tvspielfilm"   : 2.0.4    , installed 2.0.4
      Adapter    "upnp"          : 1.0.21   , installed 1.0.21
      Adapter    "virtualpowermeter": 1.4.6   , installed 1.4.6
      Adapter    "vis"           : 1.4.15   , installed 1.4.15
      Adapter    "vis-3dmodel"   : 0.0.10   , installed 0.0.10
      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
      Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
      Adapter    "vis-hqwidgets" : 1.2.0    , installed 1.2.0
      Adapter    "vis-icontwo"   : 0.87.0   , installed 0.87.0
      Adapter    "vis-inventwo"  : 3.3.3    , installed 3.3.3
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
      Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
      Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
      Adapter    "vis-material-advanced": 1.7.2   , installed 1.7.2
      Adapter    "vis-material-webfont": 0.0.3   , installed 0.0.3
      Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.9
      Adapter    "vis-metro"     : 1.2.0    , installed 1.2.0
      Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
      Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
      Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "vis-weather"   : 2.5.5    , installed 2.5.5
      Adapter    "web"           : 4.3.0    , installed 4.3.0
      Adapter    "ws"            : 1.3.0    , installed 1.3.0
      Adapter    "zigbee"        : 1.6.18   , installed 1.6.18
      GlasfaserG Offline
      GlasfaserG Offline
      Doch in Beta , habe ich mir doch gedacht !!!
      S GlasfaserG 2 Antworten Letzte Antwort
      • GlasfaserG Glasfaser
        Shakira1972
        Ok, wie komme ich zur Beta und warum?
        Wie kann ich zurrück zur normalen?
          GlasfaserG Offline
          GlasfaserG Offline
          @glasfaser
          gehe erstmal zurück
          iobroker upgrade admin@5.3.8
          • S Shakira1972
            GlasfaserG Offline
            GlasfaserG Offline
            Von alleine kommt das nicht , das wurde so von dir in ioBroker (Verwahrungsort ) so angebenen , verändert von Stable in Beta
            • S Shakira1972
              Zeige mal :
              iobroker update -i
              update done
              GlasfaserG Offline
              GlasfaserG Offline
              Du hast auch noch den alten Controller !
              Stelle dein Verwahrungsort auf Stable und aktuallisiere erstmal dein ioBroker auf den neusten Stand !
              S 2 Antworten Letzte Antwort
                Shakira1972
                @glasfaser Danke für die Hilfe,
                es funktioniert wieder,
                kann mich nicht errinnern das ich irgendwo Beta eingestellt habe.
                Bei "Repositories", steht bei mir in der Zeile 1 Default und dieser Link:
                download.iobroker.net/sources-dist.json
                Wo Default steht schreibe ich Stable, bleibt der Link dieser?
                In Zeile 2 steht: latest und dieser link: download.iobroker.net/sources-dist-latest.json
                • S Shakira1972
                  @oliver1972
                  iobroker repo list
                  anschauen.
                    @oliver1972
                    iobroker repo list
                    anschauen.
                    Shakira1972
                    pi@raspberrypi:~ $ iobroker repo list
                    default     : http://download.iobroker.net/sources-dist.json
                    latest      : http://download.iobroker.net/sources-dist-latest.json
                    Active repo: latest
                    pi@raspberrypi:~ $
                    • S Shakira1972
                      Active repo: latest
                      pi@raspberrypi:~ $
                      @oliver1972
                      iobroker repo set default
                      iobroker repo unset latest
                        @oliver1972
                        Shakira1972
                        Active repo: default
                          Shakira1972
                          Habe nun umgestellt auf Default,
                          die Adapter zeigen mir keine Updates an.
                          Wie Aktualisiere ich den Controller?
                          • S Shakira1972
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @oliver1972
                            https://forum.iobroker.net/topic/52886/js-controller-4-0-x-jetzt-für-alle-user-im-stable
                            • S Shakira1972
                              und einen Reiter vorher (Grundeinstellungen?) suchst du dir das Repo aus.
                              was du da hast sind nur die Pfade
                                Shakira1972
                                Expertenmodus ist auf OFF (default)
                                  @oliver1972
                                  Shakira1972
                                  Hat funktioniert!
                                  Danke vielmals!
                                  • S Shakira1972
                                    Hat funktioniert!
                                    Danke vielmals!
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Hat funktioniert!
                                    Sicherlich ,
                                    deshalb hab ich dir den Link genannt , damit kann man nichts falsch machen !
                                      es geht im die Verwahrungsorte!
                                        Shakira1972
                                        GlasfaserG HomoranH 2 Antworten Letzte Antwort
                                        • S Shakira1972
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @oliver1972
                                          wo hast du ioBroker her , denn off gab es noch nie
