  5. Tür verriegeln wenn Wohnung verlassen wird
blocklyjavascript
36 Beiträge 7 Kommentatoren 1.6k Aufrufe 8 Beobachtet
  • DJMarc75D DJMarc75
    @biker1602
    Gehen wir das Ganze erstmal ohne Zeitsteuerung an:
    Hier das Blockly:
     <block type="on_ext" id="q:I{n.;cQU0GkU#sVZ#~" x="237" y="38">
       <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation>
       <value name="OID0">
         <shadow type="field_oid" id=")f?ck_}we*Q/ffx3pW(r">
         </shadow>
       </value>
       <value name="OID1">
         <shadow type="field_oid" id="rPC`I0MOvB@C.)Ec|q]K">
         </shadow>
       </value>
       <statement name="STATEMENT">
         <block type="controls_if" id="4B5.v.0J8u!D}w1dU.[k">
           <value name="IF0">
             <block type="logic_operation" id="ii)@P^*7AE^sem$J3z}r" inline="false">
               <field name="OP">AND</field>
               <value name="A">
                 <block type="logic_compare" id="v+wl7rCV3V3/!vNe#-3v">
                   <field name="OP">EQ</field>
                   <value name="A">
                     <block type="get_value" id="STEMc/J=qJq7v0%Qir_^">
                       <field name="OID">ID auswählen</field>
                     </block>
                   </value>
                   <value name="B">
                     <block type="logic_boolean" id="%~r@~vLc%h5~=Cs]f?BZ">
                     </block>
                   </value>
                 </block>
               </value>
               <value name="B">
                 <block type="logic_compare" id="6O?4e4@BPLQ_`E|lXsR|">
                   <value name="A">
                     <block type="get_value" id="Qdq[!q980iE@]@Kie/f{">
                     </block>
                   </value>
                   <value name="B">
                     <block type="logic_boolean" id="X.%J0En85~Covno]P%!E">
                     </block>
                   </value>
                 </block>
               </value>
             </block>
           </value>
           <statement name="DO0">
             <block type="control" id="ppFN0lLsd5I+2A117#.b">
               <value name="VALUE">
                 <block type="math_number" id=")UG)hsrA_|Y?fh~G51)D">
                   <field name="NUM">2</field>
                 </block>
               </value>
             </block>
           </statement>
           <value name="IF1">
             <block type="logic_operation" id="mIOBRc4ONJv;_p:~8,;+" inline="false">
               <field name="OP">OR</field>
               <value name="A">
                 <block type="logic_compare" id="?j0N`w1q!p=sLY/%r=UD">
                   <value name="A">
                     <block type="get_value" id="%YWY=ewXw)SCG%]CLbk]">
                     </block>
                   </value>
                   <value name="B">
                     <block type="logic_boolean" id="4OJADRykOOYAYALZWQ|S">
                     </block>
                   </value>
                 </block>
               </value>
               <value name="B">
                 <block type="logic_compare" id="rbO@Lw4%V?i}87iGz]VI">
                   <value name="A">
                     <block type="get_value" id="KOSc1Zmii|lR}Kn:2(+[">
                     </block>
                   </value>
                   <value name="B">
                     <block type="logic_boolean" id="sv=mEDg{MyQe7o+g2vR{">
                     </block>
                   </value>
                 </block>
               </value>
             </block>
           </value>
           <statement name="DO1">
             <block type="control" id="x~cBi|/rcB9OF:I[V/Iq">
                 <block type="math_number" id="ir36]/dG]:0W~Q/Bg{PI">
                   <field name="NUM">3</field>
                 </block>
               </value>
             </block>
           </statement>
         </block>
       </statement>
     </block>
    </xml>
    Teste mal ob das erstmal funktioniert.
    biker1602
    @djmarc75
    Ich glaube ich habe den Fehler gefunden
    Ich habe bei falls hinter dem 1. Objekt nicht "= falsch" gemacht wie Markiert, sondern gleich und dann das 2. Objekt und nur am Ende falsch.
    Das war wahrscheinlich der Fehler.
    Wenn ich jetzt mein Handy aus dem Netz nehme (das zweite ist schon raus) dann verriegelt er und wenn ich mich wieder anmelde dann entriegelt er die Tür.
    Mal heute Nachmittag testen wenn die Frau nach Hause kommt.
      biker1602
      @djmarc75
      Kannst du mir mal bitte sagen, wieso wenn es ausgelöst wurde ich bestimmt 75 Mal die Meldung an Telegramm bekommen habe?
      • B biker1602
        @djmarc75
        @biker1602 sagte: 75 Mal die Meldung an Telegramm bekommen habe?
        Weil mit dem Zeitplan jede Minute ein neuer Trigger erzeugt wird.
        Die Uhrzeit muss innerhalb des Triggers ausgewertet werden:
          biker1602
          @paul53 said in Tür verriegeln wenn Wohnung verlassen wird:
          Der Trigger soll eigentlich nur von 6-21 Uhr laufen. Was habe ich da denn falsch eingestellt?
          • B biker1602
            @biker1602
            Das macht man nicht über einen Zeitplan, sondern trägt das als weitere Bedingung innerhalb des Triggers ein.
              @biker1602
              biker1602
              Perfekt Danke 👍
                biker1602
                Ich habe nochmal eine Frage Es funktioniert alles Super aber eine Sache möchte ich nochmal fragen, ob es Möglich ist.
                Ich würde gerne bei jeder Veränderung am Türschloss auf und zu eine Nachricht als Telegramm bekommen.
                Zurzeit bekomme ich eine Meldung wie im Blockly eingetragen, wenn meine Frau und ich aus dem WLAN sind und die Tür automatisch schließt.
                Da aber in der App eingestellt ist das Abends auch automatisch um 21 Uhr abgeschlossen wird auch wenn wir da sind erhalte ich darüber natürlich keine Information. Auch wenn ich morgens aufschließe nicht.
                Wie kann ich das mit einem Blockly machen, dass ich diese Information immer als Telegramm-Nachricht bekomme wenn sich unter Objekte der Status ändert.
                mkshbM 1 Antwort Letzte Antwort
                • B biker1602
                  mkshbM Offline
                  mkshbM Offline
                  mkshb
                  Moin @biker1602,
                  dafür brauchst Du einen anderen Trigger. Das Türschloss.
                  Für die Übersichtlichkeit und um doppelte Nachrichten einfach zu verhindern würde ich es in zwei Blöcke (oder gar zwei Blocklys) aufteilen. Einmal das hier schon besprochenene zur Steuerung des Schlossen und dazu noch eines um bei Veränderungen des Schlosses Benachrichtigungen zu senden.
                  • mkshbM mkshb
                    Moin @biker1602,
                    biker1602
                    @mkshb
                    Ja das ist mir klar wollte ich auch mit einem zweiten Blockly machen aber mir fehlt da im Moment die Logik wie ich das anstellen kann. Das er eine Meldung geben soll wenn sich etwas geändert hat ist noch klar aber wie verpacke ich es mit dem was geändert wurde zugeschlossen aufgeschlossen oder geöffnet.
                    mkshbM paul53P 2 Antworten Letzte Antwort
                    • B biker1602
                      @mkshb
                      mkshbM Offline
                      mkshbM Offline
                      mkshb
                      @biker1602
                      Ich verstehe nicht ganz was Du mit
                      @biker1602 sagte in Tür verriegeln wenn Wohnung verlassen wird:
                      meinst. Du brauchst ein Blockly welches bei Änderung von lockState auslöst, dann fragst Du ab was in lockState steht und reagierst darauf.
                      • mkshbM mkshb
                        @biker1602
                        biker1602
                        @mkshb
                        Ja ich weiß was du meinst aber ich habe im Moment irgendwie leere im Kopf wie ich das abfragen soll oder das Blockly aufgebaut ist. Vielleicht fällt mir ja heute Abend etwas ein. Mal ein wenig googeln.
                        • B biker1602
                          @mkshb
                          @biker1602 sagte: was geändert wurde zugeschlossen aufgeschlossen oder geöffnet.
                          Trigger auf "lockState"
                          Die richtigen Vergleichswerte muss Du selbst heraus finden, denn ich habe kein HmIP.
                            biker1602
                            Sag mal eine Frage dazu
                            Ich hatte erst Wert = LOCKED drin dann bekomme ich keine Meldung erst wenn ich es wie angemarkert habe funktioniert es.
                            Ich habe Wert unter Variablen neu erstellt, das ist doch richtig oder? Ich muss sagen es hat bei mir noch nie nur mit Wert funktioniert.
                            Mache ich da etwas falsch?
                            • B biker1602
                              @biker1602 sagte: Ich habe Wert unter Variablen neu erstellt, das ist doch richtig oder?
                              Nein. Wert ist eine vordefinierte Variable unter "Trigger".
                              B 2 Antworten Letzte Antwort
                                biker1602
                                Mensch Danke es funktioniert, da habe ich ja heute wieder etwas dazu gelernt.
                                  biker1602
                                  Ich habe nochmal eine Frage dazu.
                                  Mit Wert habe ich ja so gemacht das funktioniert ja auch aber mit der Telegramm-Meldung stimmt es irgendwie nicht. Ich habe es mit Pause versucht aber das funktioniert auch nicht
                                  Wenn ich mit der App Aufschließe, dann kommt sofort über Telegramm die Meldung "die Wohnungstür wurde zugeschlossen" und 5 Sekunden später wie im Script mit der Pause "Die Wohnungstür wurde aufgeschlossen"
                                  Unter Objekte bei lockState ist beim Schließvorgang folgendes zu beobachten
                                  bei UNLOCKED und auch bei LOCKED wechselt es erst auf (null) und dann auf UNLOCKED bzw. LOCKED
                                  Deswegen habe ich es mit der Pause versucht. Aber es bringt nichts. Ich habe versucht die Pause auch versucht über, "falls" im Blockly zu setzen, aber leider alles ohne Erfolg.
                                  Vielleicht hast du ja noch einen Tipp.
                                  • B biker1602
                                    @biker1602 sagte: wechselt es erst auf (null) und dann auf UNLOCKED bzw. LOCKED
                                    Initialisiere erst die Variable msg mit einem Leerstring:
                                    und frage sie zum Schluss ab:
                                      biker1602
                                      @paul53 du bist ein Held👍 👍 👍
                                      • B biker1602
                                        biker1602
                                        Ich muss nochmal eine Frage stellen zu dem Thema
                                        Ich habe es ganz einfach gehalten, um Fehlerquellen auszuschließen.
                                        Wenn wir die Wohnung getrennt verlassen, damit meine ich z.B. ein oder zwei Stunden später funktioniert es tadellos mit dem verriegeln.
                                        Verlassen wir beide zur gleichen Zeit die Wohnung, dann funktioniert es zu 95 Prozent nicht. Ich kann mir nicht erklären, woran das liegen kann. Wenn ich zum Testen mal unterwegs im Broker nachschaue, stehen beide Objekte auf false, aber zugeschlossen wurde nicht.
                                        • B biker1602
                                          @biker1602 sagte: Verlassen wir beide zur gleichen Zeit die Wohnung
                                          Dann wird kurz nacheinander getriggert und erst der Wert 3 und dann der Wert 2 gesendet. Vielleicht hilft eine Verzögerung?
