  3. Einsteigerfragen
  4. iobroker läuft nicht mehr
    2.7k
    4.8k
    4.0k
87 Beiträge 4 Kommentatoren 8.8k Aufrufe 3 Beobachtet
    @emi-0
    Und es ist auch die dfsg-Version, nicht die von nodesource gepackte.
    Installier sauber node14, Anleitung in meiner Signatur.
    Emi 0
    Habe es nach Deiner Anleitung mehrfach versucht.
    micros02@smartmeter:~ $ sudo apt update
    Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [282 kB]
    Fetched 306 kB in 6s (48.4 kB/s)
    Reading package lists... Done
    1 package can be upgraded. Run 'apt list --upgradable' to see it.
    N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
    N: Ignoring file 'nodesource.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
    micros02@smartmeter:~ $ sudo apt upgrade
    Calculating upgrade... Done
    The following packages will be upgraded:
      rpi-eeprom
    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 2,037 kB of archives.
    After this operation, 1,574 kB of additional disk space will be used.
    Do you want to continue? [Y/n] Y
    Get:1 http://archive.raspberrypi.org/debian bullseye/main armhf rpi-eeprom armhf 13.13-1 [2,037 kB]
    Fetched 2,037 kB in 1s (1,540 kB/s)
    Reading changelogs... Done
    (Reading database ... 53199 files and directories currently installed.)
    Preparing to unpack .../rpi-eeprom_13.13-1_armhf.deb ...
    Unpacking rpi-eeprom (13.13-1) over (13.12-1) ...
    Setting up rpi-eeprom (13.13-1) ...
    Processing triggers for man-db (2.9.4-2) ...
    micros02@smartmeter:~ $ uname -a
    Linux smartmeter 5.15.32+ #1538 Thu Mar 31 19:37:58 BST 2022 armv6l GNU/Linux
    micros02@smartmeter:~ $ lsb_release -a
    No LSB modules are available.
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    micros02@smartmeter:~ $ nodejs -v
    v12.22.5
    Bleibt aber bei v12.22.5
    • E Emi 0
        rpi-eeprom
      Release:        11
      Codename:       bullseye
      v12.22.5
      @emi-0 sagte in iobroker läuft nicht mehr:
      Da fehlt die Datei nodesource.list
      Dafür hast du da nodesource.list.save.xy drin. Die werden nicht eingelesen, nur Dateiendungen .list werden berücksichtigt.
        sudo rm /etc/apt/sources.list.d/nodesource.li*
        sudo apt remove nodejs*
        curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash
        sudo apt update
        sudo apt install nodejs
        E 1 Antwort Letzte Antwort
          sudo apt update
          Emi 0
          habe alle Schritte wie beschrieben ausgeführt.
          Bleibt bei v12.22.5.
          Kann iobroker nicht starten.
          Kann es darab liegen, dass ich einen raspi zero verwende?
          micros02@smartmeter:~ $ iobroker start
          micros02@smartmeter:~ $ iob status
          Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
          micros02@smartmeter:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
          /usr/bin/nodejs
          /usr/bin/node
          v12.22.5
          micros02@smartmeter:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          /usr/bin/nodejs
          /usr/bin/node
          Release:        11
          Codename:       bullseye
          • E Emi 0
            /usr/bin/nodejs
            /usr/bin/node
            v12.22.5
            /usr/bin/nodejs
            /usr/bin/node
            Release:        11
            Codename:       bullseye
            @emi-0
            Das ist ein alter Raspberry.
            Der muss bezüglich nodejs besonders/anders angepackt werden. In meinem nodejs-HowTo wird das aber auch erwähnt. Schau mal rein
            Der hat 512MB RAM, oder? Das dürfte kaum für eine
            sinnvollen Betrieb ausreichen. Das Doppelte ist schon schwierig.
            E 2 Antworten Letzte Antwort
              @emi-0
              Emi 0
              Habe ich versucht aber v14 wird nicht gefunden:
              micros02@smartmeter:~ $ wget https://unofficial-builds.nodejs.org/download/release/14/node-v14-linux-armv6l.tar.xz
              --2022-04-30 16:45:25--  https://unofficial-builds.nodejs.org/download/release/14/node-v14-linux-armv6l.tar.xz
              Resolving unofficial-builds.nodejs.org (unofficial-builds.nodejs.org)... 45.55.98.129
              Connecting to unofficial-builds.nodejs.org (unofficial-builds.nodejs.org)|45.55.98.129|:443... connected.
              HTTP request sent, awaiting response... 404 Not Found
              2022-04-30 16:45:26 ERROR 404: Not Found.
              • E Emi 0
                VERSION muss ersetzt werden.
                Statt
                wget https://unofficial-builds.nodejs.org/download/release/VERSION/node-vVERSION-linux-armv6l.tar.xz
                also
                wget https://unofficial-builds.nodejs.org/download/release/v14.19.1/node-v14.19.1-linux-armv6l.tar.xz
                  @emi-0
                  Emi 0
                  ja, der hat 512MB. Hat, wie gesagt, seit März gut funktioniert. Er liest nur alle 5s die aktuelle Leistung und den Stromverbrauch über einen Infrarot-Lesekopf aus und schreibt die Werte in je eine json-Datei.
                    Statt
                    also
                    Emi 0
                    ich hatte VERSION durch 14 ersetzt.
                    Anscheinend ist die aktuelle Version 14.19.1
                    Das wusste ich nicht.
                    Jetzt habe ich dieses Ergebnis:
                    micros02@smartmeter:~ $ micros02@smartmeter:~ $ wget https://unofficial-builds.nodejs.org/download/release/14/node-v14-linux-armv6l.tar.xz
                    -bash: micros02@smartmeter:~: command not found
                    -bash: --2022-04-30: command not found
                    -bash: syntax error near unexpected token `('
                    -bash: HTTP: command not found
                    -bash: 2022-04-30: command not found
                    --2022-04-30 17:07:41--  https://unofficial-builds.nodejs.org/download/release/v14.19.1/node-v14.19.1-linux-armv6l.tar.xz
                    HTTP request sent, awaiting response... 200 OK
                    Length: 19453756 (19M) [application/x-xz]
                    Saving to: ‘node-v14.19.1-linux-armv6l.tar.xz’
                    node-v14.19.1-linux 100%[===================>]  18.55M  2.90MB/s    in 6.8s
                    2022-04-30 17:07:48 (2.73 MB/s) - ‘node-v14.19.1-linux-armv6l.tar.xz’ saved [19453756/19453756]
                    • E Emi 0
                      @emi-0
                      Dann ist das Archiv jetzt heruntergeladen worden.
                      Also weiter im Text.
                      VERSION wie gehabt ersetzen. Die Tab-Taste ist dein Freund.
                      tar -xvf node-vVERSION-linux-armv6l.tar.xz
                      cd node-vVERSION-linux-armv6l/
                      sudo cp -R * /usr/local/
                      sudo ln -s /usr/local/bin/node /usr/local/bin/nodejs
                      sudo reboot
                        @emi-0
                        sudo reboot
                        Emi 0
                        habe alle Schritte ausgeführt und die nodejs-Installation geprüft:
                        micros02@smartmeter:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                        ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                        /usr/local/bin/node
                        /usr/local/bin/npm
                        v14.19.1
                        v14.19.1
                        6.14.16
                        micros02
                        /home/micros02
                        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                        2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                        nodejs:
                          Installed: (none)
                          Candidate: 12.22.5~dfsg-2~11u1
                          Version table:
                             12.22.5~dfsg-2~11u1 500
                        • E Emi 0
                          /usr/local/bin/node
                          /usr/local/bin/npm
                          v14.19.1
                          v14.19.1
                          6.14.16
                          micros02
                          /home/micros02
                          nodejs:
                            Installed: (none)
                            Version table:
                          nodeJS passt nun.
                          Die beiden Updates noch einspielen:
                          sudo apt full-upgrade
                            nodeJS passt nun.
                            Emi 0
                            das hat funktioniert:
                            micros02@smartmeter:~ $ sudo apt full-upgrade
                            The following packages were automatically installed and are no longer required:
                              gyp javascript-common libc-ares2 libjs-highlight.js libjs-inherits
                              libjs-is-typedarray libjs-psl libjs-typedarray-to-buffer libnode-dev
                              libnode72 libssl-dev libuv1-dev xdg-utils
                            Use 'sudo apt autoremove' to remove them.
                              libexpat1 libexpat1-dev
                            2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 198 kB of archives.
                            After this operation, 3,072 B of additional disk space will be used.
                            Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libexpat1-dev armhf 2.2.10-2+deb11u3 [123 kB]
                            Get:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libexpat1 armhf 2.2.10-2+deb11u3 [74.9 kB]
                            Fetched 198 kB in 1s (182 kB/s)
                            (Reading database ... 49910 files and directories currently installed.)
                            Preparing to unpack .../libexpat1-dev_2.2.10-2+deb11u3_armhf.deb ...
                            Unpacking libexpat1-dev:armhf (2.2.10-2+deb11u3) over (2.2.10-2+deb11u2) ...
                            Preparing to unpack .../libexpat1_2.2.10-2+deb11u3_armhf.deb ...
                            Unpacking libexpat1:armhf (2.2.10-2+deb11u3) over (2.2.10-2+deb11u2) ...
                            Setting up libexpat1:armhf (2.2.10-2+deb11u3) ...
                            Setting up libexpat1-dev:armhf (2.2.10-2+deb11u3) ...
                            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u2) ...
                            • E Emi 0
                              Jetzt noch
                              sudo apt autoremove
                              um den überflüssigen Rest auch noch loszuwerden.
                                Jetzt noch
                                sudo apt autoremove
                                Emi 0
                                das hat jetzt auch funktioniert:
                                micros02@smartmeter:~ $ sudo apt autoremove
                                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                • E Emi 0
                                  @emi-0
                                  Dann dürfte die nodeJS-Laufzeitumgebung jetzt sauber sein.
                                    @emi-0
                                    Emi 0
                                    leider lässt sich iobroker immer noch nicht starten
                                    micros02@smartmeter:~ $ iobroker fix
                                    library: loaded
                                    Library version=2022-02-10
                                        Welcome to the ioBroker installation fixer!
                                        Script version: 2022-02-13
                                        You might need to enter your password a couple of times.
                                        Installing prerequisites (1/3)
                                    Installed gcc-c++
                                    Installed python-dev
                                        Checking ioBroker user and directory permissions (2/3)
                                        Checking autostart (3/3)
                                    Enabling autostart...
                                    Autostart enabled!
                                        Your installation was fixed successfully
                                        Run iobroker start to start ioBroker again!
                                    • E Emi 0
                                      library: loaded
                                      Installed gcc-c++
                                      Autostart enabled!
                                      ls  -l /opt/iobroker/iobroker-data/objects.jsonl
                                      sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                                        Emi 0
                                        micros02@smartmeter:~ $ ls  -l /opt/iobroker/iobroker-data/objects.jsonl
                                        -rw-rwxr--+ 1 iobroker iobroker 120034159 Apr 25 21:05 /opt/iobroker/iobroker-data/objects.jsonl
                                        micros02@smartmeter:~ $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                                        COMMAND    PID     USER   FD   TYPE DEVICE  SIZE/OFF   NODE NAME
                                        iobroker. 1919 iobroker   19u   REG  179,2 120034159 268535 /opt/iobroker/iobroker-data/objects.jsonl
                                        micros02@smartmeter:~ $ iob start
                                        • E Emi 0
                                          @emi-0
                                          getfacl /opt/iobroker/iobroker-data/objects.jsonl
