  3. Off Topic
  4. Grafana
  5. Grafana Update Probleme
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
104 Beiträge 7 Kommentatoren 13.1k Aufrufe 5 Beobachtet
  • Damrak2022D Damrak2022
    @thomas-braun sagte in Grafana Update Probleme:
    sudo apt update
    pi@homebridge:~ $ sudo apt update
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
    Hit:3 https://packages.grafana.com/oss/deb stable InRelease
    Hit:4 https://repos.influxdata.com/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
    Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [282 kB]
    Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Fetched 306 kB in 2s (147 kB/s)
    Reading package lists... Done
    3 packages can be upgraded. Run 'apt list --upgradable' to see them.
    pi@homebridge:~ $
    #75
    @damrak2022
    sudo apt-get clean --dry-run
    Wenn dry-run gut aussieht:
    sudo apt-get clean
      @damrak2022
      sudo apt-get clean
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      #76
      @thomas-braun Bei dem zweiten Befehl bekomme ich das:
      pi@homebridge:~ $ apt list --upgradable
      Listing... Done
      grafana/stable 8.5.0 armhf [upgradable from: 8.4.7]
      libcamera0/stable 0~git20220426+18e68a9b-1 armhf [upgradable from: 0~git20220303+e68e0f1e-1]
      raspi-config/stable 20220425 all [upgradable from: 20220419]
      pi@homebridge:~ $ sudo apt hold grafana
      E: Invalid operation hold
      pi@homebridge:~ $
      Mit besten Grüßen
      Andy
        Listing... Done
        pi@homebridge:~ $
        #77
        @damrak2022
        Mein Fehler.
        Statt
        muss das
        sudo apt-mark hold grafana
        lauten.
          @damrak2022
          Mein Fehler.
          Statt
          muss das
          lauten.
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #78
          Das ist die Ausgabe:
          pi@homebridge:~ $ sudo apt-mark hold grafana
          grafana set on hold.
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
          Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
          Hit:6 https://repos.influxdata.com/debian bullseye InRelease
          Listing... Done
          pi@homebridge:~ $ sudo apt-get clean --dry-run
          Del /var/cache/apt/archives/* /var/cache/apt/archives/partial/*
          Del /var/lib/apt/lists/partial/*
          Del /var/cache/apt/pkgcache.bin /var/cache/apt/srcpkgcache.bin
          pi@homebridge:~ $
          Mit besten Grüßen
          Andy
            Listing... Done
            pi@homebridge:~ $
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #79
            @damrak2022 Auf die Oberfläche komme ich noch nicht. Muss ich nochmal
            systemctl restart grafana-server
            machen?
            Mit besten Grüßen
            Andy
              machen?
              #80
              @damrak2022 sagte in Grafana Update Probleme:
              sudo systemctl restart grafana-server
              apt policy grafana*
              sagt?
                apt policy grafana*
                sagt?
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #81
                apt policy grafana*
                Leider immer noch das:
                pi@homebridge:~ $ sudo systemctl restart grafana-server
                pi@homebridge:~ $ apt policy grafana*
                N: Unable to locate package grafana-rpi_7.4.3_armhf.deb
                pi@homebridge:~ $
                Mit besten Grüßen
                Andy
                crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                  apt policy grafana*
                  pi@homebridge:~ $
                  crunchipC Offline
                  crunchipC Offline
                  #82
                  und täglich grüsst das Murmeltier
                    apt policy grafana*
                    pi@homebridge:~ $
                    #83
                    @damrak2022
                    Dann weiß ich auch nicht wo das noch hängt.
                    Muss man vielleicht mal mit find über das System schrubben.
                    Da weiß ich aber so aus dem Kopf nicht die Parameter.
                    Schau mal mit
                    sudo grep -rnw / -e 'grafana-rpi_7.4.3_armhf.deb'
                    danach.
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #84
                      @crunchip Ich google auch schon die ganze Zeit finde aber nichts zu diesem Problem.
                      Muss jetzt aufhören, da ich weg muss.
                      Danke an Euch, ich hoffe wir bekommen das hin
                      pi@homebridge:~ $ sudo grep -rnw / -e 'grafana-rpi_7.4.3_armhf.deb'
                      grep: /sys/kernel/tracing/per_cpu/cpu3/snapshot_raw: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/per_cpu/cpu3/trace_pipe_raw: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/per_cpu/cpu3/trace_pipe: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/per_cpu/cpu2/snapshot_raw: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/per_cpu/cpu2/trace_pipe_raw: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/per_cpu/cpu2/trace_pipe: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/per_cpu/cpu1/snapshot_raw: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/per_cpu/cpu1/trace_pipe_raw: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/per_cpu/cpu1/trace_pipe: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/per_cpu/cpu0/snapshot_raw: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/per_cpu/cpu0/trace_pipe_raw: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/per_cpu/cpu0/trace_pipe: Resource temporarily unavailable
                      grep: /sys/kernel/tracing/trace_marker_raw: Invalid argument
                      grep: /sys/kernel/tracing/trace_marker: Invalid argument
                      grep: /sys/kernel/tracing/free_buffer: Invalid argument
                      grep: /sys/kernel/tracing/trace_pipe: Resource temporarily unavailable
                      grep: /sys/kernel/debug/dri/1/Writeback-1/vrr_range: No such device
                      grep: /sys/kernel/debug/dri/1/HDMI-A-2/vrr_range: No such device
                      grep: /sys/kernel/debug/dri/1/HDMI-A-1/vrr_range: No such device
                      grep: /sys/kernel/debug/clear_warn_once: Permission denied
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu3/snapshot_raw: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu3/trace_pipe_raw: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu3/trace_pipe: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu2/snapshot_raw: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu2/trace_pipe_raw: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu2/trace_pipe: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu1/snapshot_raw: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu1/trace_pipe_raw: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu1/trace_pipe: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu0/snapshot_raw: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu0/trace_pipe_raw: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/per_cpu/cpu0/trace_pipe: Resource temporarily unavailable
                      grep: /sys/kernel/debug/tracing/trace_marker_raw: Invalid argument
                      grep: /sys/kernel/debug/tracing/trace_marker: Invalid argument
                      grep: /sys/kernel/debug/tracing/free_buffer: Invalid argument
                      grep: /sys/kernel/debug/tracing/trace_pipe: Resource temporarily unavailable
                      Segmentation fault
                      pi@homebridge:~ $
                      Message from syslogd@homebridge at Apr 26 17:43:42 ...
                       kernel:[ 2407.798031] Internal error: : 1211 [#1] SMP ARM
                       kernel:[ 2407.798600] Process grep (pid: 6264, stack limit = 0x4f745707)
                       kernel:[ 2407.798611] Stack: (0xc59c9d80 to 0xc59ca000)
                       kernel:[ 2407.798622] 9d80: c59c9dac c59c9d90 c0895498 c08953a4 c59c9dbc c59c9da0 c2308200 00000014
                       kernel:[ 2407.798635] 9da0: c59c9dbc c59c9db0 c088c124 c089546c c59c9dec c59c9dc0 c088f8f4 c088c10c
                       kernel:[ 2407.798648] 9dc0: 0000002e c2308200 00000014 c59c9e3c c7b80000 00018000 c59c9f58 00000efc
                       kernel:[ 2407.798660] 9de0: c59c9e0c c59c9df0 c088fa0c c088f890 0000004b c2308200 00000014 c7b80000
                       kernel:[ 2407.798673] 9e00: c59c9e7c c59c9e10 c0894804 c088f9cc 00000014 3391a86e c3a42010 c1205048
                       kernel:[ 2407.798685] 9e20: 01a39000 c0e8e918 c0e8e910 00000000 00000046 00000000 c59c9e54 00000000
                       kernel:[ 2407.798698] 9e40: 00000046 00000000 c59c9ee4 3391a86e c045c164 c3880540 c0894a5c c1c77c38
                       kernel:[ 2407.798710] 9e60: 01a39000 00018000 c59c9f58 c06545ec c59c9e94 c59c9e80 c0894a94 c08946bc
                       kernel:[ 2407.798723] 9e80: 00018000 c59c9f58 c59c9ebc c59c9e98 c0654650 c0894a68 c3880540 00018000
                       kernel:[ 2407.798735] 9ea0: c1205048 00000000 01a39000 c59c9f58 c59c9f54 c59c9ec0 c0455ae0 c06545f8
                       kernel:[ 2407.798748] 9ec0: c045c4a0 3391a86e c1205048 becee1e0 00000000 00000001 c59c9f94 c59c9ee8
                       kernel:[ 2407.798760] 9ee0: c045c584 c045bff4 000007ff 00008100 00000001 00001000 00000000 00000000
                       kernel:[ 2407.798773] 9f00: 00201000 00000000 00001eb5 c047ab64 3391a86e c1205048 b6fba500 7ff00000
                       kernel:[ 2407.798785] 9f20: 00000003 3391a86e 01a39000 c1205048 c3880540 00000000 00000000 c3880540
                       kernel:[ 2407.798798] 9f40: 01a39000 00018000 c59c9f94 c59c9f58 c0456240 c0455a38 00000000 00000000
                       kernel:[ 2407.798810] 9f60: 00000000 3391a86e 00000000 00000003 b6fba500 7ff00000 00000003 c0200244
                       kernel:[ 2407.798823] 9f80: c59c8000 00000003 c59c9fa4 c59c9f98 c04562d0 c04561e4 00000000 c59c9fa8
                       kernel:[ 2407.798835] 9fa0: c0200040 c04562c4 00000003 b6fba500 00000003 01a39000 00018000 00000000
                       kernel:[ 2407.798848] 9fc0: 00000003 b6fba500 7ff00000 00000003 00000003 01a39000 00000003 00018000
                       kernel:[ 2407.798860] 9fe0: 00046e38 becee138 b6e56134 b6e56150 60000010 00000003 00000000 00000000
                       kernel:[ 2407.798871] Backtrace:
                       kernel:[ 2407.798880] [<c0895398>] (regmap_mmio_read32le) from [<c0895498>] (regmap_mmio_read+0x38/0x74)
                       kernel:[ 2407.798900] [<c0895460>] (regmap_mmio_read) from [<c088c124>] (_regmap_bus_reg_read+0x24/0x28)
                       kernel:[ 2407.798920]  r5:00000014 r4:c2308200
                       kernel:[ 2407.798927] [<c088c100>] (_regmap_bus_reg_read) from [<c088f8f4>] (_regmap_read+0x70/0x13c)
                       kernel:[ 2407.798944] [<c088f884>] (_regmap_read) from [<c088fa0c>] (regmap_read+0x4c/0x6c)
                       kernel:[ 2407.798962]  r10:00000efc r9:c59c9f58 r8:00018000 r7:c7b80000 r6:c59c9e3c r5:00000014
                       kernel:[ 2407.798973]  r4:c2308200 r3:0000002e
                       kernel:[ 2407.798981] [<c088f9c0>] (regmap_read) from [<c0894804>] (regmap_read_debugfs+0x154/0x364)
                       kernel:[ 2407.799000]  r7:c7b80000 r6:00000014 r5:c2308200 r4:0000004b
                       kernel:[ 2407.799008] [<c08946b0>] (regmap_read_debugfs) from [<c0894a94>] (regmap_map_read_file+0x38/0x40)
                       kernel:[ 2407.799029]  r10:c06545ec r9:c59c9f58 r8:00018000 r7:01a39000 r6:c1c77c38 r5:c0894a5c
                       kernel:[ 2407.799040]  r4:c3880540
                       kernel:[ 2407.799047] [<c0894a5c>] (regmap_map_read_file) from [<c0654650>] (full_proxy_read+0x64/0x80)
                       kernel:[ 2407.799065] [<c06545ec>] (full_proxy_read) from [<c0455ae0>] (vfs_read+0xb4/0x344)
                       kernel:[ 2407.799085]  r9:c59c9f58 r8:01a39000 r7:00000000 r6:c1205048 r5:00018000 r4:c3880540
                       kernel:[ 2407.799095] [<c0455a2c>] (vfs_read) from [<c0456240>] (ksys_read+0x68/0xe0)
                       kernel:[ 2407.799111]  r10:00018000 r9:01a39000 r8:c3880540 r7:00000000 r6:00000000 r5:c3880540
                       kernel:[ 2407.799122]  r4:c1205048
                       kernel:[ 2407.799129] [<c04561d8>] (ksys_read) from [<c04562d0>] (sys_read+0x18/0x1c)
                       kernel:[ 2407.799145]  r10:00000003 r9:c59c8000 r8:c0200244 r7:00000003 r6:7ff00000 r5:b6fba500
                       kernel:[ 2407.799156]  r4:00000003
                       kernel:[ 2407.799162] [<c04562b8>] (sys_read) from [<c0200040>] (ret_fast_syscall+0x0/0x1c)
                       kernel:[ 2407.799179] Exception stack(0xc59c9fa8 to 0xc59c9ff0)
                       kernel:[ 2407.799190] 9fa0:                   00000003 b6fba500 00000003 01a39000 00018000 00000000
                       kernel:[ 2407.799202] 9fc0: 00000003 b6fba500 7ff00000 00000003 00000003 01a39000 00000003 00018000
                       kernel:[ 2407.799214] 9fe0: 00046e38 becee138 b6e56134 b6e56150
                       kernel:[ 2407.799225] Code: e5903000 e0831001 e5910000 f57ff04f (e89da800)
                      Mit besten Grüßen
                      Andy
                        Segmentation fault
                        pi@homebridge:~ $
                        #85
                        @damrak2022
                        Gut, die Idee war jetzt zugegeben nicht meine beste... :-D
                          Segmentation fault
                          pi@homebridge:~ $
                          crunchipC Offline
                          crunchipC Offline
                          #86
                          @damrak2022 vllt ist es doch eine Möglichkeit diese grafana-rpi_7.4.3_armhf.deb nochmal von Hand zu installieren und anschliessend deinstallieren.
                          Zuvor würde ich allerdings , den aktuellen Grafana Ordner wegsichern und die aktuelle Version runterwerfen.
                          Wenn das klappt, normal per apt wieder instalieren und die Config/Dashboard zurückspielen
                          Was anderes fällt mit da jetzt auch nicht mehr ein
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #87
                            @crunchip ja, das könnte ich probieren. Wie sichere ich den Ordner weg?
                            Mit besten Grüßen
                            Andy
                              crunchipC Offline
                              crunchipC Offline
                              #88
                              @damrak2022
                              edit:
                              das zeug liegt ja wo anders, muss ich mal suchen wo das liegt und ob man das überhaupt dann so wiederverwenden kann
                              z.b. so,
                              das ist der PATHS_DATA da liegt die grafana.db, die brauchst, denn da sind deine dashboards enthalten
                              cp  -r /var/lib/grafana/ /tmp/
                              die anderen Ordner wären
                              PATHS_CONFIG	/etc/grafana/grafana.ini
                              PATHS_DATA	/var/lib/grafana
                              PATHS_HOME	/usr/share/grafana
                              PATHS_LOGS	/var/log/grafana
                              PATHS_PLUGINS	/var/lib/grafana/plugins
                              PATHS_PROVISIONING	/etc/grafana/provisioning
                              eventuell wäre das eine Möglichkeit
                              deinstallieren
                              sudo apt-get remove --auto-remove grafana
                              Installation dann
                              sudo apt-get install -y adduser libfontconfig1
                              wget https://dl.grafana.com/oss/release/grafana-rpi_7.4.3_armhf.deb
                              sudo dpkg -i grafana-rpi_7.4.3_armhf.deb
                              anschliessend dies wieder deinstallieren
                              sudo apt-get purge grafana-rpi
                                @damrak2022
                                edit:
                                z.b. so,
                                deinstallieren
                                Installation dann
                                #89
                                @crunchip
                                Würde mich wundern, wenn das so funktionieren würde.
                                dpkg hat soweit ich mich erinnere eine von apt unabhängige Datenbank über die installierten Pakete.
                                Was gescheiteres fällt mir aber zugegeben im Moment auch nicht ein.
                                  @crunchip
                                  crunchipC Offline
                                  crunchipC Offline
                                  #90
                                  na wen dir nichts weiter einfällt, was soll ich da sagen 😂
                                  ich hoffe halt, das dadurch der Rest verschwindet
                                  • Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #91
                                    @crunchip Das hat leider nicht geholfen.
                                    Mittlerweile habe ich wieder die 8.4.7 drauf. Was mich wundert ist folgendes:
                                    Nach Eingabe des Befehls
                                    systemctl enable grafana-server
                                    muss ich 4 mal mein Passwort eingeben - siehe hier:
                                    Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
                                    Executing: /lib/systemd/systemd-sysv-install enable grafana-server
                                    ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
                                    Authentication is required to reload the systemd state.
                                    Authenticating as: ,,, (pi)
                                    Password:
                                    ==== AUTHENTICATION COMPLETE ===
                                    Password:
                                    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
                                    Authentication is required to manage system service or unit files.
                                    Password:
                                    Password:
                                    pi@homebridge:~ $
                                    Ist ja auch nicht normal, zumal der "reload-daemon" 3 mal auftaucht.
                                    Ich glaube das lag daran, das ich den Befehl zuerst ohne "sudo" ausgeführt habe
                                    Mit besten Grüßen
                                    Andy
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      #92
                                      @crunchip Da ich Euch nicht ewig mit diesem Mist nerven möchte, habe ich eine Frage zum Restore.
                                      Bei Google Drive liegen bei mir Backups von JavaScripts, Influxdb, HisoryDB und ioBroker
                                      Das älteste Backup ist vom 17.04.2022
                                      Da habe ich allerdings schon mit Grafana gearbeitet.
                                      Gibt es eine Möglichkeit mein ältestes Backup einzuspielen und dabei Grafana wegzulassen. Die OneClick Option wird da ja nicht gehen da ich dann wieder die Daten von Grafana mit drin habe.
                                      Falls ja, wie muss ich das dann genau machen?
                                      Mit besten Grüßen
                                      Andy
                                        #93
                                        Die Updates haben nichts mit der gekippten Installation auf dem System zu tun. Solange das auf Seiten des Paketmanager schief bleibt bringen dir die Backups des ioBrokers nichts.
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #94
                                          @thomas-braun Das ist nicht gut. Ich google schon wieder seit Stunden. Das einzige was mir aufgefallen ist das es im Netz einige Beiträge zu
                                          E: Unable to locate package grafana gibt
                                          aber nicht zu
                                          was bei mir erscheint
                                          Mit besten Grüßen
                                          Andy
