  3. Off Topic
  4. Grafana
  5. Grafana Update Probleme
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
104 Beiträge 7 Kommentatoren 13.1k Aufrufe 5 Beobachtet
  • Damrak2022D Damrak2022
    @thomas-braun sagte in Grafana Update Probleme:
    sudo apt update
    pi@homebridge:~ $ sudo apt update
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
    Hit:3 https://packages.grafana.com/oss/deb stable InRelease
    Hit:4 https://repos.influxdata.com/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
    Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [282 kB]
    Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Fetched 306 kB in 2s (147 kB/s)
    Reading package lists... Done
    3 packages can be upgraded. Run 'apt list --upgradable' to see them.
    pi@homebridge:~ $
    #74
    @damrak2022
    sudo apt hold grafana
    sudo apt update
      sudo apt update
      pi@homebridge:~ $
      #75
      @damrak2022
      sudo apt-get clean --dry-run
      Wenn dry-run gut aussieht:
      sudo apt-get clean
        @damrak2022
        sudo apt-get clean
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #76
        @thomas-braun Bei dem zweiten Befehl bekomme ich das:
        pi@homebridge:~ $ apt list --upgradable
        Listing... Done
        grafana/stable 8.5.0 armhf [upgradable from: 8.4.7]
        libcamera0/stable 0~git20220426+18e68a9b-1 armhf [upgradable from: 0~git20220303+e68e0f1e-1]
        raspi-config/stable 20220425 all [upgradable from: 20220419]
        pi@homebridge:~ $ sudo apt hold grafana
        E: Invalid operation hold
        pi@homebridge:~ $
        Mit besten Grüßen
        Andy
          Listing... Done
          pi@homebridge:~ $
          #77
          @damrak2022
          Mein Fehler.
          Statt
          muss das
          sudo apt-mark hold grafana
          lauten.
            @damrak2022
            Mein Fehler.
            Statt
            muss das
            lauten.
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #78
            Das ist die Ausgabe:
            pi@homebridge:~ $ sudo apt-mark hold grafana
            grafana set on hold.
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
            Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
            Hit:6 https://repos.influxdata.com/debian bullseye InRelease
            Listing... Done
            pi@homebridge:~ $ sudo apt-get clean --dry-run
            Del /var/cache/apt/archives/* /var/cache/apt/archives/partial/*
            Del /var/lib/apt/lists/partial/*
            Del /var/cache/apt/pkgcache.bin /var/cache/apt/srcpkgcache.bin
            pi@homebridge:~ $
            Mit besten Grüßen
            Andy
              Listing... Done
              pi@homebridge:~ $
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #79
              @damrak2022 Auf die Oberfläche komme ich noch nicht. Muss ich nochmal
              systemctl restart grafana-server
              machen?
              Mit besten Grüßen
              Andy
                machen?
                #80
                @damrak2022 sagte in Grafana Update Probleme:
                sudo systemctl restart grafana-server
                apt policy grafana*
                sagt?
                  apt policy grafana*
                  sagt?
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #81
                  apt policy grafana*
                  Leider immer noch das:
                  pi@homebridge:~ $ sudo systemctl restart grafana-server
                  pi@homebridge:~ $ apt policy grafana*
                  N: Unable to locate package grafana-rpi_7.4.3_armhf.deb
                  pi@homebridge:~ $
                  Mit besten Grüßen
                  Andy
                  crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                    apt policy grafana*
                    pi@homebridge:~ $
                    crunchipC Offline
                    crunchipC Offline
                    #82
                    und täglich grüsst das Murmeltier
                      apt policy grafana*
                      pi@homebridge:~ $
                      #83
                      @damrak2022
                      Dann weiß ich auch nicht wo das noch hängt.
                      Muss man vielleicht mal mit find über das System schrubben.
                      Da weiß ich aber so aus dem Kopf nicht die Parameter.
                      Schau mal mit
                      sudo grep -rnw / -e 'grafana-rpi_7.4.3_armhf.deb'
                      danach.
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        #84
                        @crunchip Ich google auch schon die ganze Zeit finde aber nichts zu diesem Problem.
                        Muss jetzt aufhören, da ich weg muss.
                        Danke an Euch, ich hoffe wir bekommen das hin
                        pi@homebridge:~ $ sudo grep -rnw / -e 'grafana-rpi_7.4.3_armhf.deb'
                        grep: /sys/kernel/tracing/per_cpu/cpu3/snapshot_raw: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/per_cpu/cpu3/trace_pipe_raw: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/per_cpu/cpu3/trace_pipe: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/per_cpu/cpu2/snapshot_raw: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/per_cpu/cpu2/trace_pipe_raw: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/per_cpu/cpu2/trace_pipe: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/per_cpu/cpu1/snapshot_raw: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/per_cpu/cpu1/trace_pipe_raw: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/per_cpu/cpu1/trace_pipe: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/per_cpu/cpu0/snapshot_raw: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/per_cpu/cpu0/trace_pipe_raw: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/per_cpu/cpu0/trace_pipe: Resource temporarily unavailable
                        grep: /sys/kernel/tracing/trace_marker_raw: Invalid argument
                        grep: /sys/kernel/tracing/trace_marker: Invalid argument
                        grep: /sys/kernel/tracing/free_buffer: Invalid argument
                        grep: /sys/kernel/tracing/trace_pipe: Resource temporarily unavailable
                        grep: /sys/kernel/debug/dri/1/Writeback-1/vrr_range: No such device
                        grep: /sys/kernel/debug/dri/1/HDMI-A-2/vrr_range: No such device
                        grep: /sys/kernel/debug/dri/1/HDMI-A-1/vrr_range: No such device
                        grep: /sys/kernel/debug/clear_warn_once: Permission denied
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu3/snapshot_raw: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu3/trace_pipe_raw: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu3/trace_pipe: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu2/snapshot_raw: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu2/trace_pipe_raw: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu2/trace_pipe: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu1/snapshot_raw: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu1/trace_pipe_raw: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu1/trace_pipe: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu0/snapshot_raw: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu0/trace_pipe_raw: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/per_cpu/cpu0/trace_pipe: Resource temporarily unavailable
                        grep: /sys/kernel/debug/tracing/trace_marker_raw: Invalid argument
                        grep: /sys/kernel/debug/tracing/trace_marker: Invalid argument
                        grep: /sys/kernel/debug/tracing/free_buffer: Invalid argument
                        grep: /sys/kernel/debug/tracing/trace_pipe: Resource temporarily unavailable
                        Segmentation fault
                        pi@homebridge:~ $
                        Message from syslogd@homebridge at Apr 26 17:43:42 ...
                         kernel:[ 2407.798031] Internal error: : 1211 [#1] SMP ARM
                         kernel:[ 2407.798600] Process grep (pid: 6264, stack limit = 0x4f745707)
                         kernel:[ 2407.798611] Stack: (0xc59c9d80 to 0xc59ca000)
                         kernel:[ 2407.798622] 9d80: c59c9dac c59c9d90 c0895498 c08953a4 c59c9dbc c59c9da0 c2308200 00000014
                         kernel:[ 2407.798635] 9da0: c59c9dbc c59c9db0 c088c124 c089546c c59c9dec c59c9dc0 c088f8f4 c088c10c
                         kernel:[ 2407.798648] 9dc0: 0000002e c2308200 00000014 c59c9e3c c7b80000 00018000 c59c9f58 00000efc
                         kernel:[ 2407.798660] 9de0: c59c9e0c c59c9df0 c088fa0c c088f890 0000004b c2308200 00000014 c7b80000
                         kernel:[ 2407.798673] 9e00: c59c9e7c c59c9e10 c0894804 c088f9cc 00000014 3391a86e c3a42010 c1205048
                         kernel:[ 2407.798685] 9e20: 01a39000 c0e8e918 c0e8e910 00000000 00000046 00000000 c59c9e54 00000000
                         kernel:[ 2407.798698] 9e40: 00000046 00000000 c59c9ee4 3391a86e c045c164 c3880540 c0894a5c c1c77c38
                         kernel:[ 2407.798710] 9e60: 01a39000 00018000 c59c9f58 c06545ec c59c9e94 c59c9e80 c0894a94 c08946bc
                         kernel:[ 2407.798723] 9e80: 00018000 c59c9f58 c59c9ebc c59c9e98 c0654650 c0894a68 c3880540 00018000
                         kernel:[ 2407.798735] 9ea0: c1205048 00000000 01a39000 c59c9f58 c59c9f54 c59c9ec0 c0455ae0 c06545f8
                         kernel:[ 2407.798748] 9ec0: c045c4a0 3391a86e c1205048 becee1e0 00000000 00000001 c59c9f94 c59c9ee8
                         kernel:[ 2407.798760] 9ee0: c045c584 c045bff4 000007ff 00008100 00000001 00001000 00000000 00000000
                         kernel:[ 2407.798773] 9f00: 00201000 00000000 00001eb5 c047ab64 3391a86e c1205048 b6fba500 7ff00000
                         kernel:[ 2407.798785] 9f20: 00000003 3391a86e 01a39000 c1205048 c3880540 00000000 00000000 c3880540
                         kernel:[ 2407.798798] 9f40: 01a39000 00018000 c59c9f94 c59c9f58 c0456240 c0455a38 00000000 00000000
                         kernel:[ 2407.798810] 9f60: 00000000 3391a86e 00000000 00000003 b6fba500 7ff00000 00000003 c0200244
                         kernel:[ 2407.798823] 9f80: c59c8000 00000003 c59c9fa4 c59c9f98 c04562d0 c04561e4 00000000 c59c9fa8
                         kernel:[ 2407.798835] 9fa0: c0200040 c04562c4 00000003 b6fba500 00000003 01a39000 00018000 00000000
                         kernel:[ 2407.798848] 9fc0: 00000003 b6fba500 7ff00000 00000003 00000003 01a39000 00000003 00018000
                         kernel:[ 2407.798860] 9fe0: 00046e38 becee138 b6e56134 b6e56150 60000010 00000003 00000000 00000000
                         kernel:[ 2407.798871] Backtrace:
                         kernel:[ 2407.798880] [<c0895398>] (regmap_mmio_read32le) from [<c0895498>] (regmap_mmio_read+0x38/0x74)
                         kernel:[ 2407.798900] [<c0895460>] (regmap_mmio_read) from [<c088c124>] (_regmap_bus_reg_read+0x24/0x28)
                         kernel:[ 2407.798920]  r5:00000014 r4:c2308200
                         kernel:[ 2407.798927] [<c088c100>] (_regmap_bus_reg_read) from [<c088f8f4>] (_regmap_read+0x70/0x13c)
                         kernel:[ 2407.798944] [<c088f884>] (_regmap_read) from [<c088fa0c>] (regmap_read+0x4c/0x6c)
                         kernel:[ 2407.798962]  r10:00000efc r9:c59c9f58 r8:00018000 r7:c7b80000 r6:c59c9e3c r5:00000014
                         kernel:[ 2407.798973]  r4:c2308200 r3:0000002e
                         kernel:[ 2407.798981] [<c088f9c0>] (regmap_read) from [<c0894804>] (regmap_read_debugfs+0x154/0x364)
                         kernel:[ 2407.799000]  r7:c7b80000 r6:00000014 r5:c2308200 r4:0000004b
                         kernel:[ 2407.799008] [<c08946b0>] (regmap_read_debugfs) from [<c0894a94>] (regmap_map_read_file+0x38/0x40)
                         kernel:[ 2407.799029]  r10:c06545ec r9:c59c9f58 r8:00018000 r7:01a39000 r6:c1c77c38 r5:c0894a5c
                         kernel:[ 2407.799040]  r4:c3880540
                         kernel:[ 2407.799047] [<c0894a5c>] (regmap_map_read_file) from [<c0654650>] (full_proxy_read+0x64/0x80)
                         kernel:[ 2407.799065] [<c06545ec>] (full_proxy_read) from [<c0455ae0>] (vfs_read+0xb4/0x344)
                         kernel:[ 2407.799085]  r9:c59c9f58 r8:01a39000 r7:00000000 r6:c1205048 r5:00018000 r4:c3880540
                         kernel:[ 2407.799095] [<c0455a2c>] (vfs_read) from [<c0456240>] (ksys_read+0x68/0xe0)
                         kernel:[ 2407.799111]  r10:00018000 r9:01a39000 r8:c3880540 r7:00000000 r6:00000000 r5:c3880540
                         kernel:[ 2407.799122]  r4:c1205048
                         kernel:[ 2407.799129] [<c04561d8>] (ksys_read) from [<c04562d0>] (sys_read+0x18/0x1c)
                         kernel:[ 2407.799145]  r10:00000003 r9:c59c8000 r8:c0200244 r7:00000003 r6:7ff00000 r5:b6fba500
                         kernel:[ 2407.799156]  r4:00000003
                         kernel:[ 2407.799162] [<c04562b8>] (sys_read) from [<c0200040>] (ret_fast_syscall+0x0/0x1c)
                         kernel:[ 2407.799179] Exception stack(0xc59c9fa8 to 0xc59c9ff0)
                         kernel:[ 2407.799190] 9fa0:                   00000003 b6fba500 00000003 01a39000 00018000 00000000
                         kernel:[ 2407.799202] 9fc0: 00000003 b6fba500 7ff00000 00000003 00000003 01a39000 00000003 00018000
                         kernel:[ 2407.799214] 9fe0: 00046e38 becee138 b6e56134 b6e56150
                         kernel:[ 2407.799225] Code: e5903000 e0831001 e5910000 f57ff04f (e89da800)
                        Mit besten Grüßen
                        Andy
                          Segmentation fault
                          pi@homebridge:~ $
                          #85
                          @damrak2022
                          Gut, die Idee war jetzt zugegeben nicht meine beste... :-D
                            Segmentation fault
                            pi@homebridge:~ $
                            crunchipC Offline
                            crunchipC Offline
                            #86
                            @damrak2022 vllt ist es doch eine Möglichkeit diese grafana-rpi_7.4.3_armhf.deb nochmal von Hand zu installieren und anschliessend deinstallieren.
                            Zuvor würde ich allerdings , den aktuellen Grafana Ordner wegsichern und die aktuelle Version runterwerfen.
                            Wenn das klappt, normal per apt wieder instalieren und die Config/Dashboard zurückspielen
                            Was anderes fällt mit da jetzt auch nicht mehr ein
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #87
                              @crunchip ja, das könnte ich probieren. Wie sichere ich den Ordner weg?
                              Mit besten Grüßen
                              Andy
                                crunchipC Offline
                                crunchipC Offline
                                #88
                                @damrak2022
                                edit:
                                das zeug liegt ja wo anders, muss ich mal suchen wo das liegt und ob man das überhaupt dann so wiederverwenden kann
                                z.b. so,
                                das ist der PATHS_DATA da liegt die grafana.db, die brauchst, denn da sind deine dashboards enthalten
                                cp  -r /var/lib/grafana/ /tmp/
                                die anderen Ordner wären
                                PATHS_CONFIG	/etc/grafana/grafana.ini
                                PATHS_DATA	/var/lib/grafana
                                PATHS_HOME	/usr/share/grafana
                                PATHS_LOGS	/var/log/grafana
                                PATHS_PLUGINS	/var/lib/grafana/plugins
                                PATHS_PROVISIONING	/etc/grafana/provisioning
                                eventuell wäre das eine Möglichkeit
                                deinstallieren
                                sudo apt-get remove --auto-remove grafana
                                Installation dann
                                sudo apt-get install -y adduser libfontconfig1
                                wget https://dl.grafana.com/oss/release/grafana-rpi_7.4.3_armhf.deb
                                sudo dpkg -i grafana-rpi_7.4.3_armhf.deb
                                anschliessend dies wieder deinstallieren
                                sudo apt-get purge grafana-rpi
                                  @damrak2022
                                  edit:
                                  z.b. so,
                                  deinstallieren
                                  Installation dann
                                  #89
                                  @crunchip
                                  Würde mich wundern, wenn das so funktionieren würde.
                                  dpkg hat soweit ich mich erinnere eine von apt unabhängige Datenbank über die installierten Pakete.
                                  Was gescheiteres fällt mir aber zugegeben im Moment auch nicht ein.
                                    @crunchip
                                    crunchipC Offline
                                    crunchipC Offline
                                    #90
                                    na wen dir nichts weiter einfällt, was soll ich da sagen 😂
                                    ich hoffe halt, das dadurch der Rest verschwindet
                                    • Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      #91
                                      @crunchip Das hat leider nicht geholfen.
                                      Mittlerweile habe ich wieder die 8.4.7 drauf. Was mich wundert ist folgendes:
                                      Nach Eingabe des Befehls
                                      systemctl enable grafana-server
                                      muss ich 4 mal mein Passwort eingeben - siehe hier:
                                      Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
                                      Executing: /lib/systemd/systemd-sysv-install enable grafana-server
                                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
                                      Authentication is required to reload the systemd state.
                                      Authenticating as: ,,, (pi)
                                      Password:
                                      ==== AUTHENTICATION COMPLETE ===
                                      Password:
                                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
                                      Authentication is required to manage system service or unit files.
                                      Password:
                                      Password:
                                      pi@homebridge:~ $
                                      Ist ja auch nicht normal, zumal der "reload-daemon" 3 mal auftaucht.
                                      Ich glaube das lag daran, das ich den Befehl zuerst ohne "sudo" ausgeführt habe
                                      Mit besten Grüßen
                                      Andy
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #92
                                        @crunchip Da ich Euch nicht ewig mit diesem Mist nerven möchte, habe ich eine Frage zum Restore.
                                        Bei Google Drive liegen bei mir Backups von JavaScripts, Influxdb, HisoryDB und ioBroker
                                        Das älteste Backup ist vom 17.04.2022
                                        Da habe ich allerdings schon mit Grafana gearbeitet.
                                        Gibt es eine Möglichkeit mein ältestes Backup einzuspielen und dabei Grafana wegzulassen. Die OneClick Option wird da ja nicht gehen da ich dann wieder die Daten von Grafana mit drin habe.
                                        Falls ja, wie muss ich das dann genau machen?
                                        Mit besten Grüßen
                                        Andy
                                          #93
                                          Die Updates haben nichts mit der gekippten Installation auf dem System zu tun. Solange das auf Seiten des Paketmanager schief bleibt bringen dir die Backups des ioBrokers nichts.
