  4. Installation defekt?
    1.0k
51 Beiträge 6 Kommentatoren 6.8k Aufrufe 4 Beobachtet
    @qqolli sagte in Installation defekt?:
    Und netstat zeigt ebenfalls an,
    Zeig mal den kompletten Output.
    qqolliQ Offline
    qqolliQ Offline
    qqolli
    Aktive Sockets in der UNIX-Domäne (Server und stehende Verbindungen)
    Proto RefCnt Flags       Type       State         I-Node   PID/Program name     Pfad
    unix  2      [ ]         DGRAM                    50757076 1436/systemd         /run/user/1000/systemd/notify
    unix  2      [ ACC ]     STREAM     HÖRT         50757079 1436/systemd         /run/user/1000/systemd/private
    unix  2      [ ACC ]     STREAM     HÖRT         50757086 1436/systemd         /run/user/1000/gnupg/S.dirmngr
    unix  2      [ ACC ]     STREAM     HÖRT         50757087 1436/systemd         /run/user/1000/bus
    unix  2      [ ACC ]     STREAM     HÖRT         50757088 1436/systemd         /run/user/1000/gnupg/S.gpg-agent.browser
    unix  2      [ ACC ]     STREAM     HÖRT         50757089 1436/systemd         /run/user/1000/gnupg/S.gpg-agent.extra
    unix  2      [ ACC ]     STREAM     HÖRT         12928    -                    /run/thd.socket
    unix  2      [ ACC ]     STREAM     HÖRT         50757090 1436/systemd         /run/user/1000/gnupg/S.gpg-agent.ssh
    unix  2      [ ACC ]     STREAM     HÖRT         50757091 1436/systemd         /run/user/1000/gnupg/S.gpg-agent
    unix  2      [ ACC ]     STREAM     HÖRT         12931    -                    /run/avahi-daemon/socket
    unix  2      [ ACC ]     STREAM     HÖRT         12933    -                    /var/run/dbus/system_bus_socket
    unix  3      [ ]         DGRAM                    9689     -                    /run/systemd/notify
    unix  2      [ ACC ]     STREAM     HÖRT         9692     -                    /run/systemd/private
    unix  2      [ ACC ]     STREAM     HÖRT         9702     -                    /run/systemd/fsck.progress
    unix  13     [ ]         DGRAM                    9705     -                    /run/systemd/journal/dev-log
    unix  2      [ ACC ]     SEQPAKET   HÖRT         9707     -                    /run/udev/control
    unix  2      [ ]         DGRAM                    9712     -                    /run/systemd/journal/syslog
    unix  2      [ ACC ]     STREAM     HÖRT         9714     -                    /run/systemd/journal/stdout
    unix  7      [ ]         DGRAM                    9716     -                    /run/systemd/journal/socket
    unix  2      [ ACC ]     STREAM     HÖRT         14919    -                    /var/run/dhcpcd.sock
    unix  2      [ ACC ]     STREAM     HÖRT         14920    -                    /var/run/dhcpcd.unpriv.sock
    unix  2      [ ]         DGRAM                    16625    -                    /var/run/wpa_supplicant/wlan0
    unix  2      [ ]         DGRAM                    16633    -                    /var/run/wpa_supplicant/p2p-dev-wlan0
    unix  3      [ ]         STREAM     VERBUNDEN     50711764 -
    unix  2      [ ]         DGRAM                    16429    -
    unix  3      [ ]         STREAM     VERBUNDEN     50724178 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719468 -
    unix  3      [ ]         STREAM     VERBUNDEN     13146    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50712278 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698849 -
    unix  3      [ ]         STREAM     VERBUNDEN     50724177 -
    unix  3      [ ]         STREAM     VERBUNDEN     16427    -
    unix  3      [ ]         STREAM     VERBUNDEN     50719472 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711762 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698851 -
    unix  2      [ ]         DGRAM                    14926    -
    unix  3      [ ]         STREAM     VERBUNDEN     50712279 -
    unix  3      [ ]         STREAM     VERBUNDEN     50720092 -
    unix  3      [ ]         STREAM     VERBUNDEN     50724176 -
    unix  3      [ ]         STREAM     VERBUNDEN     14745    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50719558 -
    unix  3      [ ]         STREAM     VERBUNDEN     50720090 -
    unix  3      [ ]         STREAM     VERBUNDEN     11239    -
    unix  3      [ ]         STREAM     VERBUNDEN     50712281 -
    unix  3      [ ]         STREAM     VERBUNDEN     18745    -
    unix  3      [ ]         STREAM     VERBUNDEN     50711761 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719559 -
    unix  3      [ ]         STREAM     VERBUNDEN     50724721 -
    unix  3      [ ]         STREAM     VERBUNDEN     19563    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     14730    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50698852 -
    unix  3      [ ]         STREAM     VERBUNDEN     11108    353/bash
    unix  3      [ ]         STREAM     VERBUNDEN     50719556 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719469 -
    unix  3      [ ]         STREAM     VERBUNDEN     14704    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50724722 -
    unix  3      [ ]         STREAM     VERBUNDEN     50720091 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698850 -
    unix  3      [ ]         STREAM     VERBUNDEN     11039    -
    unix  3      [ ]         STREAM     VERBUNDEN     50719471 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719557 -
    unix  3      [ ]         STREAM     VERBUNDEN     50724720 -
    unix  3      [ ]         STREAM     VERBUNDEN     50724723 -
    unix  3      [ ]         STREAM     VERBUNDEN     18776    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50712280 -
    unix  3      [ ]         STREAM     VERBUNDEN     50724175 -
    unix  3      [ ]         STREAM     VERBUNDEN     50720093 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711763 -
    unix  3      [ ]         STREAM     VERBUNDEN     16908    -
    unix  3      [ ]         STREAM     VERBUNDEN     50707437 -
    unix  3      [ ]         STREAM     VERBUNDEN     50709707 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716491 -
    unix  3      [ ]         STREAM     VERBUNDEN     50699612 -
    unix  3      [ ]         STREAM     VERBUNDEN     17460    -
    unix  2      [ ]         DGRAM                    14746    -
    unix  3      [ ]         STREAM     VERBUNDEN     50716628 -
    unix  3      [ ]         STREAM     VERBUNDEN     50702476 -
    unix  3      [ ]         STREAM     VERBUNDEN     50713879 -
    unix  3      [ ]         STREAM     VERBUNDEN     50715583 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716489 -
    unix  3      [ ]         STREAM     VERBUNDEN     17461    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50711420 -
    unix  3      [ ]         STREAM     VERBUNDEN     50715585 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711151 -
    unix  3      [ ]         STREAM     VERBUNDEN     50699613 -
    unix  3      [ ]         STREAM     VERBUNDEN     50709709 -
    unix  3      [ ]         STREAM     VERBUNDEN     50743274 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716406 -
    unix  3      [ ]         STREAM     VERBUNDEN     50714866 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719501 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716493 -
    unix  3      [ ]         STREAM     VERBUNDEN     50709668 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716629 -
    unix  3      [ ]         STREAM     VERBUNDEN     5060254  -
    unix  3      [ ]         STREAM     VERBUNDEN     50715632 -
    unix  3      [ ]         STREAM     VERBUNDEN     50713878 -
    unix  3      [ ]         STREAM     VERBUNDEN     50707436 -
    unix  3      [ ]         STREAM     VERBUNDEN     50709708 -
    unix  3      [ ]         STREAM     VERBUNDEN     50720316 -
    unix  3      [ ]         STREAM     VERBUNDEN     50693044 -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50714865 -
    unix  3      [ ]         STREAM     VERBUNDEN     50699614 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719500 -
    unix  2      [ ]         DGRAM                    16237    -
    unix  2      [ ]         DGRAM                    13284    -
    unix  3      [ ]         STREAM     VERBUNDEN     13286    -
    unix  3      [ ]         STREAM     VERBUNDEN     50703100 -
    unix  3      [ ]         STREAM     VERBUNDEN     50743272 -
    unix  3      [ ]         STREAM     VERBUNDEN     50714864 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716490 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711154 -
    unix  3      [ ]         STREAM     VERBUNDEN     50709670 -
    unix  3      [ ]         STREAM     VERBUNDEN     13299    -
    unix  3      [ ]         STREAM     VERBUNDEN     50719499 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716488 -
    unix  2      [ ]         DGRAM                    10396    -
    unix  3      [ ]         STREAM     VERBUNDEN     50720313 -
    unix  3      [ ]         STREAM     VERBUNDEN     16246    -
    unix  3      [ ]         STREAM     VERBUNDEN     16587    -                    /var/run/dbus/system_bus_socket
    unix  3      [ ]         STREAM     VERBUNDEN     50719473 -
    unix  3      [ ]         STREAM     VERBUNDEN     50709669 -
    unix  3      [ ]         STREAM     VERBUNDEN     50720315 -
    unix  3      [ ]         STREAM     VERBUNDEN     50713877 -
    unix  3      [ ]         STREAM     VERBUNDEN     12084    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50716627 -
    unix  3      [ ]         STREAM     VERBUNDEN     13075    -
    unix  3      [ ]         STREAM     VERBUNDEN     50711419 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719474 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716404 -
    unix  3      [ ]         STREAM     VERBUNDEN     50699615 -
    unix  3      [ ]         STREAM     VERBUNDEN     5060784  -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50715582 -
    unix  3      [ ]         STREAM     VERBUNDEN     14609    -
    unix  3      [ ]         STREAM     VERBUNDEN     50716495 -
    unix  3      [ ]         STREAM     VERBUNDEN     50743273 -
    unix  2      [ ]         DGRAM                    13076    -
    unix  3      [ ]         DGRAM                    9691     -
    unix  3      [ ]         STREAM     VERBUNDEN     50711418 -
    unix  2      [ ]         DGRAM                    13078    -
    unix  3      [ ]         STREAM     VERBUNDEN     16583    -                    /var/run/dbus/system_bus_socket
    unix  3      [ ]         STREAM     VERBUNDEN     14736    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     10962    -
    unix  3      [ ]         STREAM     VERBUNDEN     19211639 -                    /var/run/dbus/system_bus_socket
    unix  3      [ ]         DGRAM                    9690     -
    unix  3      [ ]         STREAM     VERBUNDEN     50711152 -
    unix  3      [ ]         STREAM     VERBUNDEN     50703102 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711421 -
    unix  3      [ ]         STREAM     VERBUNDEN     50707438 -
    unix  3      [ ]         STREAM     VERBUNDEN     5058343  -
    unix  3      [ ]         STREAM     VERBUNDEN     50716494 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711153 -
    unix  2      [ ]         DGRAM                    10945    -
    unix  3      [ ]         STREAM     VERBUNDEN     50716405 -
    unix  3      [ ]         DGRAM                    10947    -
    unix  3      [ ]         STREAM     VERBUNDEN     50716630 -
    unix  3      [ ]         STREAM     VERBUNDEN     50709706 -
    unix  3      [ ]         STREAM     VERBUNDEN     50703103 -
    unix  3      [ ]         STREAM     VERBUNDEN     50715633 -
    unix  3      [ ]         STREAM     VERBUNDEN     50715584 -
    unix  3      [ ]         DGRAM                    10948    -
    unix  3      [ ]         DGRAM                    10949    -
    unix  3      [ ]         STREAM     VERBUNDEN     50720314 -
    unix  3      [ ]         STREAM     VERBUNDEN     50695443 -
    unix  3      [ ]         STREAM     VERBUNDEN     19212750 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716496 -
    unix  3      [ ]         STREAM     VERBUNDEN     13285    -
    unix  3      [ ]         STREAM     VERBUNDEN     50714863 -
    unix  3      [ ]         STREAM     VERBUNDEN     50703101 -
    unix  3      [ ]         STREAM     VERBUNDEN     5060255  -                    /var/run/dbus/system_bus_socket
    unix  3      [ ]         STREAM     VERBUNDEN     50743275 -
    unix  2      [ ]         DGRAM                    13257    -
    unix  3      [ ]         DGRAM                    10950    -
    unix  3      [ ]         STREAM     VERBUNDEN     50716407 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719135 -
    unix  3      [ ]         STREAM     VERBUNDEN     50712235 -
    unix  3      [ ]         STREAM     VERBUNDEN     50713191 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698741 -
    unix  3      [ ]         STREAM     VERBUNDEN     16581    -
    unix  3      [ ]         DGRAM                    50757078 1436/systemd
    unix  3      [ ]         STREAM     VERBUNDEN     50722516 -
    unix  2      [ ]         DGRAM                    16744    -
    unix  3      [ ]         STREAM     VERBUNDEN     50719097 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711598 -
    unix  3      [ ]         STREAM     VERBUNDEN     50712236 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719096 -
    unix  3      [ ]         STREAM     VERBUNDEN     50722515 -
    unix  3      [ ]         STREAM     VERBUNDEN     50721481 -
    unix  3      [ ]         STREAM     VERBUNDEN     50754884 -                    /var/run/dbus/system_bus_socket
    unix  3      [ ]         STREAM     VERBUNDEN     50722513 -
    unix  3      [ ]         STREAM     VERBUNDEN     16515    -
    unix  3      [ ]         STREAM     VERBUNDEN     50757060 1436/systemd
    unix  3      [ ]         STREAM     VERBUNDEN     50713190 -
    unix  3      [ ]         STREAM     VERBUNDEN     50713880 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698739 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719134 -
    unix  3      [ ]         STREAM     VERBUNDEN     50712233 -
    unix  3      [ ]         STREAM     VERBUNDEN     50755762 -
    unix  3      [ ]         STREAM     VERBUNDEN     50722518 -
    unix  3      [ ]         STREAM     VERBUNDEN     50713188 -
    unix  3      [ ]         STREAM     VERBUNDEN     50757080 1436/systemd
    unix  3      [ ]         STREAM     VERBUNDEN     50709671 -
    unix  3      [ ]         STREAM     VERBUNDEN     50699126 -
    unix  3      [ ]         STREAM     VERBUNDEN     16441    -
    unix  2      [ ]         DGRAM                    50757070 1436/systemd
    unix  3      [ ]         STREAM     VERBUNDEN     50712234 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698771 -
    unix  3      [ ]         STREAM     VERBUNDEN     16585    -                    /var/run/dbus/system_bus_socket
    unix  2      [ ]         DGRAM                    16588    -
    unix  3      [ ]         STREAM     VERBUNDEN     50755763 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698768 -
    unix  2      [ ]         DGRAM                    50757067 -
    unix  3      [ ]         STREAM     VERBUNDEN     50722519 -
    unix  3      [ ]         STREAM     VERBUNDEN     50721478 -
    unix  3      [ ]         STREAM     VERBUNDEN     50715631 -
    unix  3      [ ]         STREAM     VERBUNDEN     50702479 -
    unix  3      [ ]         STREAM     VERBUNDEN     50702478 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719098 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698769 -
    unix  2      [ ]         DGRAM                    50755728 -
    unix  3      [ ]         STREAM     VERBUNDEN     50715630 -
    unix  3      [ ]         STREAM     VERBUNDEN     16582    -
    unix  3      [ ]         STREAM     VERBUNDEN     13296    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50699128 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698742 -
    unix  3      [ ]         STREAM     VERBUNDEN     50722521 -
    unix  3      [ ]         STREAM     VERBUNDEN     50702477 -
    unix  3      [ ]         STREAM     VERBUNDEN     16740    -
    unix  3      [ ]         STREAM     VERBUNDEN     13173    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50721479 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711600 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698770 -
    unix  3      [ ]         STREAM     VERBUNDEN     14911    -
    unix  3      [ ]         STREAM     VERBUNDEN     50698740 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711599 -
    unix  2      [ ]         STREAM     VERBUNDEN     50756665 -
    unix  3      [ ]         STREAM     VERBUNDEN     50713189 -
    unix  3      [ ]         STREAM     VERBUNDEN     50699127 -
    unix  3      [ ]         STREAM     VERBUNDEN     50722520 -
    unix  3      [ ]         STREAM     VERBUNDEN     50699125 -
    unix  3      [ ]         STREAM     VERBUNDEN     15283    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50757785 -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50722514 -
    unix  3      [ ]         STREAM     VERBUNDEN     16746    -
    unix  3      [ ]         STREAM     VERBUNDEN     50719095 -
    unix  3      [ ]         STREAM     VERBUNDEN     50721480 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719136 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711597 -
    unix  3      [ ]         DGRAM                    50757077 1436/systemd
    unix  3      [ ]         STREAM     VERBUNDEN     50716109 -
    unix  3      [ ]         STREAM     VERBUNDEN     50707203 -
    unix  3      [ ]         STREAM     VERBUNDEN     50725253 -
    unix  3      [ ]         STREAM     VERBUNDEN     43998456 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698060 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711575 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719040 -
    unix  3      [ ]         STREAM     VERBUNDEN     50725252 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716610 -
    unix  3      [ ]         DGRAM                    10004    -
    unix  3      [ ]         STREAM     VERBUNDEN     50725250 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719041 -
    unix  3      [ ]         DGRAM                    10003    -
    unix  3      [ ]         STREAM     VERBUNDEN     50697724 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719467 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716110 -
    unix  3      [ ]         STREAM     VERBUNDEN     50725263 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711577 -
    unix  3      [ ]         STREAM     VERBUNDEN     50707201 -
    unix  3      [ ]         STREAM     VERBUNDEN     50707439 -
    unix  3      [ ]         STREAM     VERBUNDEN     50707204 -
    unix  3      [ ]         STREAM     VERBUNDEN     43999544 -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     16586    -                    /var/run/dbus/system_bus_socket
    unix  3      [ ]         STREAM     VERBUNDEN     16584    -                    /var/run/dbus/system_bus_socket
    unix  3      [ ]         STREAM     VERBUNDEN     50697725 -
    unix  3      [ ]         STREAM     VERBUNDEN     15578    -
    unix  3      [ ]         STREAM     VERBUNDEN     50716608 -
    unix  3      [ ]         STREAM     VERBUNDEN     15371    -
    unix  2      [ ]         DGRAM                    10001    -
    unix  3      [ ]         STREAM     VERBUNDEN     14709    -                    /run/systemd/journal/stdout
    unix  2      [ ]         DGRAM                    9815     -
    unix  3      [ ]         STREAM     VERBUNDEN     50697726 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719466 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698061 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716107 -
    unix  3      [ ]         STREAM     VERBUNDEN     50697727 -
    unix  3      [ ]         STREAM     VERBUNDEN     50697487 -
    unix  3      [ ]         STREAM     VERBUNDEN     50725265 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716609 -
    unix  3      [ ]         STREAM     VERBUNDEN     50725262 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719039 -
    unix  3      [ ]         STREAM     VERBUNDEN     16332    -                    /var/run/dbus/system_bus_socket
    unix  3      [ ]         STREAM     VERBUNDEN     50698058 -
    unix  3      [ ]         STREAM     VERBUNDEN     50725264 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719137 -
    unix  3      [ ]         STREAM     VERBUNDEN     50697488 -
    unix  3      [ ]         STREAM     VERBUNDEN     50698059 -
    unix  3      [ ]         STREAM     VERBUNDEN     50697486 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719038 -
    unix  3      [ ]         STREAM     VERBUNDEN     50716108 -
    unix  3      [ ]         STREAM     VERBUNDEN     14739    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50711574 -
    unix  3      [ ]         STREAM     VERBUNDEN     15502    -
    unix  3      [ ]         STREAM     VERBUNDEN     9998     -
    unix  3      [ ]         STREAM     VERBUNDEN     50707202 -
    unix  3      [ ]         STREAM     VERBUNDEN     50719502 -
    unix  3      [ ]         STREAM     VERBUNDEN     50725251 -
    unix  3      [ ]         STREAM     VERBUNDEN     50711576 -
    unix  3      [ ]         STREAM     VERBUNDEN     11589    -                    /run/systemd/journal/stdout
    unix  3      [ ]         STREAM     VERBUNDEN     50716607 -
    unix  3      [ ]         STREAM     VERBUNDEN     50697485 -
    pi@ioBroker:~ $
    • qqolliQ qqolli
      @jan1
      Danke für den Tip, aber der iobroker läuft ja. Habe mal folgendes geprüft:
      pi@ioBroker:~ $ ps -A | grep iobroker
      15988 ?        00:13:42 iobroker.js-con
      Und netstat zeigt ebenfalls an, das die ports 9000 & 9001 verbunden sind (listen & verbunden).
      Jan1
      @qqolli
      Ja, aber die Frage ist so schon selbst beantwortet ;)
      • qqolliQ qqolli
        pi@ioBroker:~ $
        @qqolli
        Vielleicht läuft da einfach zu viel.
        Mach mal ein backup vom einem gestoppten iobroker.
        qqolliQ 1 Antwort Letzte Antwort
          @qqolli
          qqolliQ Offline
          qqolliQ Offline
          qqolli
          Meine Güte, was ist das denn schon wieder? Backup mit gestoppten iobroker:
          pi@ioBroker:~ $ iobroker stop
          pi@ioBroker:~ $ iobroker backup
          host.ioBroker 67430 states saved
          host.ioBroker 88111 objects saved
          <--- Last few GCs --->
          [5018:0x3f45df8]    61091 ms: Scavenge 772.3 (835.7) -> 771.3 (843.7) MB, 31.6 / 0.0 ms  (average mu = 0.963, current mu = 0.980) allocation failure
          [5018:0x3f45df8]    65074 ms: Mark-sweep (reduce) 1101.3 (1172.2) -> 771.8 (798.9) MB, 378.0 / 0.0 ms  (+ 0.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 1373 ms) (average mu = 0.938, current mu = 0.918) exte
          <--- JS stacktrace --->
          FATAL ERROR: MarkCompactCollector: young object promotion failed Allocation failed - JavaScript heap out of memory
          /usr/bin/iobroker: Zeile 8:  5013 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
          pi@ioBroker:~ $
          • qqolliQ qqolli
            pi@ioBroker:~ $
            @qqolli
            Dem node-Prozess geht der zugeteilte Speicher aus.
              @qqolli
              qqolliQ Offline
              qqolliQ Offline
              qqolli
              Also alles in allem, ich brauche entweder einen neuen Pi mit 8GB oder einen Mini-PC mit z. B. Proxmoxx, richtig?
              Oder kann man noch irgendetwas machen, ausser weitere Adapter, Instanzen, etc. zu löschen?
              • qqolliQ qqolli
                @qqolli
                free -ht --mega
                sagt?
                Mehr Speicher nutzt nichts, wenn auf dem sog. Heap der Speicher nicht ausreicht. Ist soweit ich weiß bei aktuellen node-Versionen erstmal auf 2GB begrenzt. Das kann man natürlich auch ändern, ich weiß aber nicht wo und wie.
                  @qqolli
                  free -ht --mega
                  sagt?
                  qqolliQ Offline
                  qqolliQ Offline
                  qqolli
                  pi@ioBroker:~ $ free -ht --mega
                  Mem:           3,8G        2,9G        230M        116M        670M        1,2G
                  Swap:           99M         99M        0,0K
                  Total:         3,9G        3,0G        230M
                  pi@ioBroker:~ $
                  • qqolliQ qqolli
                    Swap:           99M         99M        0,0K
                    pi@ioBroker:~ $
                    Swap: 99M 99M 0,0K
                    Die 'Überlaufanzeige' ist tiefrot.
                    sudo apt update
                    sudo apt install smem
                    sudo smem -t -p
                    Damit kannst du schauen was da so drin liegt.
                      Swap: 99M 99M 0,0K
                      sudo apt update
                      sudo smem -t -p
                      qqolliQ Offline
                      qqolliQ Offline
                      qqolli
                      Die Top 4 bzgl. des swap sind demnach 1.) deconz, 2.) influx, 3.) grafana und zuletzt 4.) root.
                      Bei USS, RSS & PSS (konnte die Bedeutung nicht finden) sind es 1.) io.javascript.0, 2.) io.admin.o und 3.) /usr/bin/influxd -c
                      Grafana könnte ich löschen, da ich es nochmal auf der NAS unter Docker laufen habe.
                      pi@ioBroker:~ $ sudo smem -t -p
                        PID User     Command                         Swap      USS      PSS      RSS
                        552 root     /usr/bin/hciattach /dev/ser    0.12%    0.00%    0.00%    0.00%
                        566 root     /usr/lib/bluetooth/bluetoot    0.36%    0.00%    0.00%    0.00%
                        718 root     /sbin/agetty -o -p -- \u --    0.10%    0.00%    0.00%    0.00%
                        412 avahi    avahi-daemon: chroot helper    0.23%    0.00%    0.00%    0.00%
                        361 nobody   /usr/sbin/thd --triggers /e    0.15%    0.00%    0.00%    0.00%
                        374 root     /usr/sbin/alsactl -E HOME=/    0.16%    0.00%    0.00%    0.00%
                        416 root     /sbin/wpa_supplicant -u -s     0.35%    0.00%    0.00%    0.01%
                        358 root     /usr/sbin/cron -f              0.12%    0.00%    0.00%    0.02%
                       6357 ?        ?                              0.00%    0.00%    0.00%    0.04%
                        362 root     /usr/sbin/rngd -r /dev/hwrn    0.04%    0.00%    0.00%    0.03%
                       6245 pi       timeout 66 nc -nlvw 1 -p 10    0.00%    0.00%    0.01%    0.04%
                       6247 pi       nc -nlvw 1 -p 1080             0.00%    0.00%    0.01%    0.04%
                        359 root     /bin/bash /usr/bin/deCONZ-u    0.06%    0.00%    0.01%    0.04%
                        719 root     /usr/sbin/sshd -D              0.44%    0.00%    0.01%    0.04%
                        704 root     /sbin/dhcpcd -q -w             0.23%    0.01%    0.01%    0.04%
                        312 systemd-timesync /lib/systemd/systemd-timesy    0.57%    0.00%    0.01%    0.06%
                       6246 pi       tail -1                        0.00%    0.01%    0.01%    0.04%
                       6244 pi       /bin/bash /home/iobroker/we    0.30%    0.01%    0.01%    0.05%
                        353 pi       /bin/bash /home/iobroker/we    0.30%    0.01%    0.01%    0.06%
                        351 avahi    avahi-daemon: running [ioBr    0.18%    0.01%    0.02%    0.04%
                        349 root     /lib/systemd/systemd-logind    0.49%    0.01%    0.02%    0.08%
                        155 root     /lib/systemd/systemd-udevd     0.65%    0.02%    0.02%    0.04%
                        386 root     /bin/bash /usr/bin/deCONZ-W    0.25%    0.01%    0.02%    0.06%
                        392 messagebus /usr/bin/dbus-daemon --syst    0.20%    0.02%    0.02%    0.05%
                        531 root     wpa_supplicant -B -c/etc/wp    0.41%    0.02%    0.03%    0.04%
                        350 root     /usr/sbin/rsyslogd -n -iNON    0.39%    0.03%    0.03%    0.04%
                       2630 pi       sshd: pi@pts/0                 0.00%    0.01%    0.03%    0.11%
                       6350 root     sudo smem -t -p                0.00%    0.03%    0.03%    0.09%
                       2631 pi       -bash                          0.00%    0.03%    0.04%    0.10%
                       2609 pi       (sd-pam)                       0.43%    0.03%    0.04%    0.08%
                      21487 root     /usr/lib/policykit-1/polkit    0.38%    0.03%    0.05%    0.08%
                          1 root     /sbin/init                     0.56%    0.02%    0.05%    0.14%
                       2550 root     sshd: pi [priv]                0.00%    0.02%    0.06%    0.16%
                       2608 pi       /lib/systemd/systemd --user    0.00%    0.05%    0.08%    0.19%
                       6351 root     /usr/bin/python /usr/bin/sm    0.00%    0.15%    0.15%    0.20%
                      22612 iobroker io.echarts.0                   0.00%    0.53%    0.54%    1.26%
                      18546 iobroker io.pushover.0                  0.00%    0.56%    0.58%    1.29%
                       1215 pi       /usr/bin/deCONZ -platform m    6.48%    0.56%    0.58%    0.67%
                      20824 iobroker io.discovery.0                 0.00%    0.57%    0.58%    1.30%
                      21890 iobroker io.sonos.0                     0.00%    0.59%    0.61%    1.32%
                      22365 iobroker io.time-switch.0               0.00%    0.59%    0.61%    1.32%
                      22224 iobroker io.text2command.0              0.00%    0.60%    0.61%    1.32%
                      21355 iobroker io.fritzdect.0                 0.00%    0.61%    0.63%    1.34%
                      22562 iobroker io.yeelight-2.0                0.00%    0.62%    0.63%    1.34%
                      18193 iobroker io.history.0                   0.00%    0.62%    0.63%    1.34%
                      22088 iobroker io.sourceanalytix.0            0.00%    0.65%    0.66%    1.38%
                      21506 iobroker io.pollenflug.0                0.00%    0.66%    0.68%    1.42%
                      22905 iobroker io.device-reminder.0           0.00%    0.67%    0.68%    1.39%
                      20365 iobroker io.countdown.0                 0.00%    0.70%    0.72%    1.44%
                      20443 iobroker io.cloud.0                     0.00%    0.72%    0.74%    1.47%
                      19017 iobroker io.hm-rpc.2                    0.00%    0.73%    0.74%    1.46%
                      18972 iobroker io.alexa2.0                    0.00%    0.74%    0.76%    1.49%
                      19737 iobroker io.rpi2.0                      0.00%    0.75%    0.76%    1.47%
                      19556 iobroker io.ping.0                      0.00%    0.76%    0.77%    1.48%
                      20193 iobroker io.backitup.0                  0.00%    0.74%    0.79%    1.59%
                      18982 iobroker io.hm-rpc.0                    0.00%    0.79%    0.80%    1.51%
                      22536 iobroker io.trashschedule.0             0.00%    0.79%    0.81%    1.53%
                      20330 iobroker io.bydhvs.0                    0.00%    0.80%    0.81%    1.52%
                      21541 iobroker io.heizoel.0                   0.00%    0.81%    0.82%    1.56%
                      19521 iobroker io.nut.0                       0.00%    0.83%    0.84%    1.55%
                      20199 iobroker io.bring.0                     0.00%    0.83%    0.85%    1.58%
                        119 root     /lib/systemd/systemd-journa   11.19%    0.17%    0.85%    1.58%
                      19497 iobroker io.mqtt.0                      0.00%    0.85%    0.86%    1.58%
                      18980 iobroker io.hm-rega.0                   0.00%    0.86%    0.87%    1.58%
                      12693 grafana  /usr/sbin/grafana-server --    5.01%    0.88%    0.88%    0.89%
                      21884 iobroker io.simple-api.0                0.00%    0.87%    0.88%    1.60%
                      22094 iobroker io.tankerkoenig.0              0.00%    0.89%    0.91%    1.64%
                      22550 iobroker io.yahka.0                     0.00%    0.90%    0.91%    1.63%
                      19000 iobroker io.hm-rpc.1                    0.00%    0.90%    0.91%    1.63%
                      21547 iobroker io.info.0                      0.00%    0.90%    0.92%    1.65%
                      21243 iobroker io.fronius.0                   0.00%    0.92%    0.93%    1.64%
                      21408 iobroker io.fullybrowser.0              0.00%    0.92%    0.93%    1.65%
                      18960 iobroker io.telegram.0                  0.00%    0.92%    0.94%    1.67%
                      22820 iobroker io.fronius-solarweb.0          0.00%    0.97%    0.99%    1.72%
                      23203 iobroker io.eusec.0                     0.00%    0.98%    1.01%    1.76%
                      20107 iobroker io.tr-064.0                    0.00%    1.01%    1.05%    1.86%
                      21402 iobroker io.fully-tablet-control.0      0.00%    1.05%    1.06%    1.78%
                      22706 iobroker io.web.0                       0.00%    1.10%    1.11%    1.84%
                      20101 iobroker io.synology.0                  0.00%    1.09%    1.11%    1.86%
                      20734 iobroker io.deconz.0                    0.00%    1.41%    1.42%    2.14%
                      18423 iobroker io.influxdb.0                  0.00%    1.64%    1.65%    2.37%
                      20003 iobroker io.shelly.0                    0.00%    1.74%    1.76%    2.47%
                      20088 iobroker io.sonoff.0                    0.00%    1.84%    1.86%    2.57%
                      21830 iobroker io.iot.0                       0.00%    2.23%    2.25%    2.98%
                      14305 iobroker io.mihome-vacuum.0             0.00%    2.32%    2.35%    3.12%
                        711 influxdb /usr/bin/influxd -config /e    5.56%    3.54%    3.54%    3.54%
                      18107 iobroker io.admin.0                     0.00%    3.60%    3.64%    4.46%
                      18464 iobroker io.javascript.0                0.00%    6.03%    6.05%    6.76%
                      17341 iobroker iobroker.js-controller         0.00%   14.34%   14.39%   15.19%
                         89 10                                     35.70%   73.24%   75.08%  113.49%
                      pi@ioBroker:~ $
