  4. Test Adapter OpenKNX 0.6.x
587 Beiträge 74 Kommentatoren 216.4k Aufrufe 73 Beobachtet
  • T tro
    keine eine Idee an was es liegen könnte?
    Heute wieder Stillstand, nach einem manuellen Neustart des openknx Adapter geht es wieder.
    2022-04-12 21:31:17.926 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:17.926 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:17.926 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:17.926 connection timed out, retrying...
    2022-04-12 21:31:17.927 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:17.927 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:17.927 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:17.927 connection timed out, retrying...
    2022-04-12 21:31:17.929 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:17.928 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:17.940 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:17.939 connection timed out, retrying...
    2022-04-12 21:31:17.940 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:17.940 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:17.983 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:17.983 connection timed out, retrying...
    2022-04-12 21:31:17.984 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:17.984 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:18.069 - warn: openknx.0 (2794457) Connection lost
    2022-04-12 21:31:18.070 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.070 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:18.086 - warn: openknx.0 (2794457) event received before initialisation
    2022-04-12 21:31:18.090 - info: host.server6 stopInstance system.adapter.openknx.0 (force=false, process=true)
    2022-04-12 21:31:18.086 - warn: openknx.0 (2794457) Connection lost
    2022-04-12 21:31:18.090 - warn: openknx.0 (2794457) Connection lost
    2022-04-12 21:31:18.091 - info: openknx.0 (2794457) Connected!
    2022-04-12 21:31:18.096 - info: openknx.0 (2794457) Got terminate signal TERMINATE_YOURSELF
    2022-04-12 21:31:18.098 - info: openknx.0 (2794457) terminating
    2022-04-12 21:31:18.099 - info: openknx.0 (2794457) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-04-12 21:31:18.107 - warn: openknx.0 (2794457) Connection lost
    2022-04-12 21:31:18.109 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.108 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:18.124 - info: host.server6 stopInstance system.adapter.openknx.0 send kill signal
    2022-04-12 21:31:18.151 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.151 connection timed out, retrying...
    2022-04-12 21:31:18.152 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.152 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:18.244 - warn: openknx.0 (2794457) Connection lost
    2022-04-12 21:31:18.245 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.245 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:18.259 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.259 connection timed out, retrying...
    2022-04-12 21:31:18.261 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.261 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:18.279 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.279 connection timed out, retrying...
    2022-04-12 21:31:18.280 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.280 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:18.362 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.362 connection timed out, retrying...
    2022-04-12 21:31:18.363 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.363 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:18.412 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.412 connection timed out, retrying...
    2022-04-12 21:31:18.413 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.413 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:18.439 - warn: openknx.0 (2794457) Connection lost
    2022-04-12 21:31:18.443 - warn: openknx.0 (2794457) [warn] 2022-04-12 19:31:18.443 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2022-04-12 21:31:22.516 - info: openknx.0 (2968339) starting. Version 0.1.24 in /opt/iobroker/node_modules/iobroker.openknx, node: v14.19.1, js-controller: 4.0.21
    2022-04-12 21:31:22.538 - info: openknx.0 (2968339) Connecting to knx gateway: 172.16.10.82:3671 with phy. Adr: 1.1.255 minimum send delay: 50 ms debug level: info
    2022-04-12 21:31:22.539 - info: openknx.0 (2968339) /opt/iobroker/node_modules/iobroker.js-controller
    2022-04-12 21:31:22.847 - info: openknx.0 (2968339) Connected!
    2022-04-12 21:31:22.972 - info: openknx.0 (2968339) Found 539 valid KNX objects of 541 objects in adapter.
    2022-04-12 21:33:48.170 - warn: openknx.0 (2968339) possible data loss due to gateway reset, consider increasing frame delay
    2022-04-12 21:33:48.171 - info: openknx.0 (2968339) [info] 2022-04-12 19:33:48.169 empty internal fsm queue due to inbound_DISCONNECT_REQUEST:
    2022-04-12 21:33:48.697 - info: openknx.0 (2968339) Connected!
    lessthanmore
    #300
    @tro said in Test Adapter OpenKNX 0.1.x:
    Hast du evtl. noch etwas anderes laufen, was auf KNX zugreift (node-red z. B.) bzw. den gleichen UDP port zugreift?
    • L lessthanmore
      tro
      #301
      @lessthanmore
      Node-Red läuft, aber KNX Daten beziehe ich über iob, also keinen eigenen KNX Zugriff über Node-Red.
      IOB über openKNX ist der einzige KNX Zugriff aus diesem System.
      L 1 Antwort Letzte Antwort
      • T tro
        @lessthanmore
        lessthanmore
        #302
        @lessthanmore
        In node red hast du keine aktive knx node?
        Hatte die Fehlermeldung mal beim ultimate knx node auf github gesehen.
        • L lessthanmore
          @lessthanmore
          tro
          #303
          @lessthanmore
          Nein, hole mir die KNX Daten ausnahmslos über die IOB Node in Node-Red
          • T tro
            @lessthanmore
            killroy2
            #304
            @tro Ich glaube ich kann es nachvollziehen, ich melde mich wieder wenn das Problem demnächst behoben ist.
            T 3 Antworten Letzte Antwort
            • K killroy2
              Aktuelle Testversion v0.7.3-alpha.1
              Stabile Version: 0.6.3
              Erstveröffentlichungsdatum 16.12.2021
              Github Link https://github.com/iobroker-community-adapters/ioBroker.openknx/
              NPM Link https://www.npmjs.com/package/iobroker.openknx
              Issues Board in GitHub https://github.com/iobroker-community-adapters/ioBroker.openknx/issues
              Installation der Testversion
              "Adapter", "Expertenmodus", "Octocat", "Benutzerdefiniert" und diesen Link:
              https://github.com/iobroker-community-adapters/ioBroker.openknx.git
              Adapter Beschreibung, Changelog etc.
              Hier ist die erste öffentliche Testversion des Open KNX Adapters. Der Adapter kommuniziert über ein IP Interface mit dem KNX Bus. Verschiedene KNX Telegrammtypen (GroupValue_Read, GroupValue_Write, GroupValue_Response) in Sende- und Empfangsrichtung werden in, dem IOB Anwender vertrauten Interaktionen mit IoBroker Objekten übersetzt.
              Motivation
              Ich habe den Adapter aus einer Not heraus erstellt, da der verfügbare Adapter nicht fehlerfrei lief und nicht kompatibel zu meinen IP Interfaces ist. Debuggen war aufgrund Closed Source nicht möglich. Da Adapter läuft so gut, dass ich ihn der Öffentlichkeit übergeben möchte.
              Der Adapter ist Quelloffen, Code kann gerne von Jedermann inspiziert und Pull Requests eingestellt werden.
              Eine Beschreibung des Adapters und dessen Verwendung ist auf den verlinkten Seiten zu finden.
              Ziel
              Der Adapter soll:
              • Stabil laufen und sich Standardkonform verhalten
              • möglich einfach und verständlich sein
              Thema umgesetzt ab Version Erwartung
              Release 0.1.x Release im stable repository
              Installation 0.1.6 Adapter lässt sich fehlerfrei über NPM installieren
              Installation 0.1.9 Adapter lässt sich über IOB Bordmittel installieren
              Betrieb 0.1.6 Adapter zeigt den Betriebszustand (rot,gelb,grün) korrekt an, bei Verbindungsabbrucht wird der Adapter gelb, keine Warnungen im Log die nicht zum Zustand passen
              Betrieb 0.1.8 keine Warnungen im Log die nicht zum Zustand passen
              Übersetzung 0.1.8 Admin Dialoge in alle Sprachen übersetzt, Logs nicht
              Alias 0.1.11 Generierung von Alias zur Zusammenbringen von Status und Ausgabe-GA zu einem Objekt eingebaut, noch nicht fehlerfrei
              Ich erhoffe mir Feedback zB zu
              • Bugs, Error Logs;
              • Verständlichkeit und Vollständigkeit der Doku
              • Verwendbarkeit des Adapters, sind die Features brauchbar, was fehlt essentielles
              • Code Reviews
              • Erfahrungen aus dem Betrieb
              • Ideen zur Geschäftslogik, zB werden aktuell Szenen DPTs von der Autoread Abfrage bei Start ausgeschlossen; gibt es bessere Filter?
              • Verbesserungsvorschläge am Interface, z.B. welche State roles eignen sich für welche DPTs, sind die Datentypen passend gewählt, ...
              Feature Anfragen, Fehlermeldungen dürfen gerne in GitHub erstellt werden. Umsetzung erfolgt immer nach Beschlusslage.
              killroy2
              #305
              @killroy2 0.1.25 ist verfügbar
              T T 2 Antworten Letzte Antwort
              • K killroy2
                Tontechniker
                schrieb am zuletzt editiert von Tontechniker
                #306
                @killroy2 Installiert/Update! Danke für deine Arbeit!
                • P Offline
                  petkoh
                  #307
                  ich habe den Adapter installiert und konfiguriert. Er verbindet sich, aber es werden weder Werte aus dem KNX-Bus empfangen, noch können Werte gesendet werden.
                  So sieht das Protokoll nach dem Start aus. Was mir aufgefallen ist, ist dass der Adapter jede Minute die Info "Connected" ausgibt.
                  Kann mir jemand bei dem Problem helfen? Ich denke es wird ein grundlegendes Problem sein. Ich habe bisher mit dem knx-Adapter gearbeitet, dieser funktioniert nur bis Version 1.0.39. Bei neueren Versionen habe ich ebenfalls Probleme mit der Verbindung.
                  openknx.0
                  2022-04-23 06:47:41.326	info	Connected!
                  openknx.0
                  2022-04-23 06:46:41.272	info	Connected!
                  openknx.0
                  2022-04-23 06:45:41.157	info	Connected!
                  openknx.0
                  2022-04-23 06:44:41.218	info	Connected!
                  openknx.0
                  2022-04-23 06:43:40.972	info	Connected!
                  openknx.0
                  2022-04-23 06:42:40.897	info	Connected!
                  openknx.0
                  2022-04-23 06:41:40.984	info	Connected!
                  openknx.0
                  2022-04-23 06:40:41.012	info	Connected!
                  openknx.0
                  2022-04-23 06:39:44.520	info	Found 228 valid KNX objects of 230 objects in adapter.
                  openknx.0
                  2022-04-23 06:39:43.408	info	Connected!
                  • P petkoh
                    openknx.0
                    openknx.0
                    openknx.0
                    openknx.0
                    openknx.0
                    openknx.0
                    openknx.0
                    openknx.0
                    openknx.0
                    openknx.0
                    killroy2
                    #308
                    @petkoh bitte mehr Daten liefern, welche Version, wie sind die Logs wenn du das Logging auf vollständig schaltest?
                    P 1 Antwort Letzte Antwort
                    • K killroy2
                      petkoh
                      #309
                      @killroy2 Ich nutze Version 0.1.22. Das Logging steht auf debug.
                      Ich habe nun als IP-Adresse die Routing Multicast Adresse 221.0.23.12 angegeben und damit hat es geklappt. Allerdings kann ich immer noch keine Werte senden.
                      so sieht der Start des Adapters aus:
                      openknx.0
                      2022-04-24 07:06:31.601	debug	Inbound GroupValue_Write from 2.1.3 GA 1/5/2 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_3 val: 20.4 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:06:27.578	debug	Inbound GroupValue_Write from 2.1.7 GA 1/5/6 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_7 val: 18.1 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:06:23.714	debug	Inbound GroupValue_Write from 2.1.10 GA 1/5/9 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_10 val: 18.4 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:06:14.009	debug	Inbound GroupValue_Write from 2.1.8 GA 1/5/7 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_8 val: 19.3 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:06:03.649	debug	Inbound GroupValue_Write from 2.1.10 GA 1/5/9 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_10 val: 18.5 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:06:01.148	debug	Inbound GroupValue_Write from 2.1.2 GA 1/5/1 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_2 val: 21.2 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:05:55.603	debug	Inbound GroupValue_Write from 2.1.3 GA 1/5/2 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_3 val: 20.5 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:05:54.473	debug	Inbound GroupValue_Write from 2.1.8 GA 1/5/7 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_8 val: 19.2 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:05:45.584	debug	Inbound GroupValue_Write from 2.1.7 GA 1/5/6 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_7 val: 18.2 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:05:43.741	debug	Inbound GroupValue_Write from 2.1.10 GA 1/5/9 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_10 val: 18.4 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:05:42.076	debug	Inbound GroupValue_Write from 2.1.1 GA 1/5/0 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_1 val: 20.9 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:05:41.162	debug	Inbound GroupValue_Write from 2.1.2 GA 1/5/1 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_2 val: 21.3 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:05:35.664	debug	Inbound GroupValue_Write from 2.1.3 GA 1/5/2 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_3 val: 20.4 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:05:23.880	debug	Inbound GroupValue_Write from 2.1.10 GA 1/5/9 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_10 val: 18.5 dpt: DPT9.001
                      openknx.0
                      openknx.0
                      2022-04-24 07:05:22.313	debug	Inbound GroupValue_Write from 2.1.1 GA 1/5/0 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_1 val: 21 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:05:21.599	debug	Inbound GroupValue_Write from 2.1.4 GA 1/5/3 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_4 val: 20 dpt: DPT9.001
                      openknx.0
                      2022-04-24 07:04:46.487	info	Connected!
                      openknx.0
                      2022-04-24 07:04:46.468	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/0 openknx.0.Haussteuerung.Taster_Schalter.Taster_1_1
                      openknx.0
                      2022-04-24 07:04:46.450	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/1 openknx.0.Haussteuerung.Taster_Schalter.Taster_1_2
                      openknx.0
                      2022-04-24 07:04:46.434	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/2 openknx.0.Haussteuerung.Taster_Schalter.Taster_1_3
                      openknx.0
                      2022-04-24 07:04:46.420	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/3 openknx.0.Haussteuerung.Taster_Schalter.Taster_1_4
                      openknx.0
                      2022-04-24 07:04:46.407	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/4 openknx.0.Haussteuerung.Taster_Schalter.Taster_2_1
                      openknx.0
                      2022-04-24 07:04:46.393	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/5 openknx.0.Haussteuerung.Taster_Schalter.Taster_2_2
                      openknx.0
                      2022-04-24 07:04:46.380	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/6 openknx.0.Haussteuerung.Taster_Schalter.Taster_2_3
                      openknx.0
                      2022-04-24 07:04:46.367	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/7 openknx.0.Haussteuerung.Taster_Schalter.Taster_2_4
                      openknx.0
                      2022-04-24 07:04:46.352	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/8 openknx.0.Haussteuerung.Taster_Schalter.Taster_3_1
                      openknx.0
                      2022-04-24 07:04:46.336	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/9 openknx.0.Haussteuerung.Taster_Schalter.Taster_3_2
                      openknx.0
                      2022-04-24 07:04:46.317	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/10 openknx.0.Haussteuerung.Taster_Schalter.Taster_3_3
                      openknx.0
                      2022-04-24 07:04:46.303	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/11 openknx.0.Haussteuerung.Taster_Schalter.Taster_3_4
                      openknx.0
                      2022-04-24 07:04:46.290	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/12 openknx.0.Haussteuerung.Taster_Schalter.Taster_4_1
                      openknx.0
                      2022-04-24 07:04:46.276	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/13 openknx.0.Haussteuerung.Taster_Schalter.Taster_4_2
                      openknx.0
                      2022-04-24 07:04:46.263	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/14 openknx.0.Haussteuerung.Taster_Schalter.Taster_4_3
                      openknx.0
                      2022-04-24 07:04:46.249	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/15 openknx.0.Haussteuerung.Taster_Schalter.Taster_4_4
                      openknx.0
                      2022-04-24 07:04:46.236	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/16 openknx.0.Haussteuerung.Taster_Schalter.Taster_5_1
                      openknx.0
                      2022-04-24 07:04:46.222	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/17 openknx.0.Haussteuerung.Taster_Schalter.Taster_5_2
                      openknx.0
                      2022-04-24 07:04:46.208	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/18 openknx.0.Haussteuerung.Taster_Schalter.Taster_5_3
                      openknx.0
                      2022-04-24 07:04:46.186	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/19 openknx.0.Haussteuerung.Taster_Schalter.Taster_5_4
                      openknx.0
                      2022-04-24 07:04:46.159	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/20 openknx.0.Haussteuerung.Taster_Schalter.Taster_5_5
                      openknx.0
                      2022-04-24 07:04:46.124	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/21 openknx.0.Haussteuerung.Taster_Schalter.Taster_5_6
                      openknx.0
                      2022-04-24 07:04:46.071	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/22 openknx.0.Haussteuerung.Taster_Schalter.Taster_5_7
                      openknx.0
                      2022-04-24 07:04:46.035	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/23 openknx.0.Haussteuerung.Taster_Schalter.Taster_5_8
                      openknx.0
                      2022-04-24 07:04:46.009	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/24 openknx.0.Haussteuerung.Taster_Schalter.Taster_6_1
                      openknx.0
                      2022-04-24 07:04:45.992	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/25 openknx.0.Haussteuerung.Taster_Schalter.Taster_6_2
                      openknx.0
                      2022-04-24 07:04:45.966	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/26 openknx.0.Haussteuerung.Taster_Schalter.Taster_6_3
                      openknx.0
                      2022-04-24 07:04:45.945	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/27 openknx.0.Haussteuerung.Taster_Schalter.Taster_6_4
                      openknx.0
                      2022-04-24 07:04:45.925	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/28 openknx.0.Haussteuerung.Taster_Schalter.Taster_6_5
                      openknx.0
                      2022-04-24 07:04:45.905	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/29 openknx.0.Haussteuerung.Taster_Schalter.Taster_6_6
                      openknx.0
                      2022-04-24 07:04:45.880	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/30 openknx.0.Haussteuerung.Taster_Schalter.Taster_6_7
                      openknx.0
                      2022-04-24 07:04:45.851	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/31 openknx.0.Haussteuerung.Taster_Schalter.Taster_6_8
                      openknx.0
                      2022-04-24 07:04:45.761	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/32 openknx.0.Haussteuerung.Taster_Schalter.Taster_7_1
                      openknx.0
                      2022-04-24 07:04:45.743	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/33 openknx.0.Haussteuerung.Taster_Schalter.Taster_7_2
                      openknx.0
                      2022-04-24 07:04:45.724	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/34 openknx.0.Haussteuerung.Taster_Schalter.Taster_7_3
                      openknx.0
                      2022-04-24 07:04:45.710	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/35 openknx.0.Haussteuerung.Taster_Schalter.Taster_7_4
                      openknx.0
                      2022-04-24 07:04:45.696	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/36 openknx.0.Haussteuerung.Taster_Schalter.Taster_7_5
                      openknx.0
                      2022-04-24 07:04:45.681	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/37 openknx.0.Haussteuerung.Taster_Schalter.Taster_7_6
                      openknx.0
                      2022-04-24 07:04:45.664	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/38 openknx.0.Haussteuerung.Taster_Schalter.Taster_7_7
                      openknx.0
                      2022-04-24 07:04:45.651	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/39 openknx.0.Haussteuerung.Taster_Schalter.Taster_7_8
                      openknx.0
                      2022-04-24 07:04:45.637	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/40 openknx.0.Haussteuerung.Taster_Schalter.Taster_8_1
                      openknx.0
                      2022-04-24 07:04:45.623	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/41 openknx.0.Haussteuerung.Taster_Schalter.Taster_8_2
                      openknx.0
                      2022-04-24 07:04:45.609	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/42 openknx.0.Haussteuerung.Taster_Schalter.Taster_8_3
                      openknx.0
                      2022-04-24 07:04:45.595	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/43 openknx.0.Haussteuerung.Taster_Schalter.Taster_8_4
                      openknx.0
                      2022-04-24 07:04:45.581	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/44 openknx.0.Haussteuerung.Taster_Schalter.Taster_9_1
                      openknx.0
                      2022-04-24 07:04:45.568	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/45 openknx.0.Haussteuerung.Taster_Schalter.Taster_9_2
                      openknx.0
                      2022-04-24 07:04:45.548	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/46 openknx.0.Haussteuerung.Taster_Schalter.Taster_9_3
                      openknx.0
                      2022-04-24 07:04:45.521	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/47 openknx.0.Haussteuerung.Taster_Schalter.Taster_9_4
                      openknx.0
                      2022-04-24 07:04:45.500	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/48 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_1
                      openknx.0
                      2022-04-24 07:04:45.482	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/49 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_2
                      openknx.0
                      2022-04-24 07:04:45.459	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/50 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_3
                      openknx.0
                      2022-04-24 07:04:45.428	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/51 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_4
                      openknx.0
                      2022-04-24 07:04:45.414	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/52 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_5
                      openknx.0
                      2022-04-24 07:04:45.400	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/53 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_6
                      openknx.0
                      2022-04-24 07:04:45.386	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/54 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_7
                      openknx.0
                      2022-04-24 07:04:45.372	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/55 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_8
                      openknx.0
                      2022-04-24 07:04:45.359	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/56 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_9
                      openknx.0
                      2022-04-24 07:04:45.344	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/57 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_10
                      openknx.0
                      2022-04-24 07:04:45.314	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/58 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_11
                      openknx.0
                      2022-04-24 07:04:45.276	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/59 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_12
                      openknx.0
                      2022-04-24 07:04:45.263	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/60 openknx.0.Haussteuerung.Taster_Schalter.Schalter_KNX_13
                      openknx.0
                      2022-04-24 07:04:45.250	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/61 openknx.0.Haussteuerung.Taster_Schalter.Taster_10_1
                      openknx.0
                      2022-04-24 07:04:45.236	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/62 openknx.0.Haussteuerung.Taster_Schalter.Taster_10_2
                      openknx.0
                      2022-04-24 07:04:45.223	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/63 openknx.0.Haussteuerung.Taster_Schalter.Taster_10_3
                      openknx.0
                      2022-04-24 07:04:45.187	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/64 openknx.0.Haussteuerung.Taster_Schalter.Taster_10_4
                      openknx.0
                      2022-04-24 07:04:45.124	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/65 openknx.0.Haussteuerung.Taster_Schalter.Taster_10_5
                      openknx.0
                      2022-04-24 07:04:45.082	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/66 openknx.0.Haussteuerung.Taster_Schalter.Taster_10_6
                      openknx.0
                      2022-04-24 07:04:45.065	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/67 openknx.0.Haussteuerung.Taster_Schalter.Taster_10_7
                      openknx.0
                      2022-04-24 07:04:45.049	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/68 openknx.0.Haussteuerung.Taster_Schalter.Taster_10_8
                      openknx.0
                      2022-04-24 07:04:45.033	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/80 openknx.0.Haussteuerung.Taster_Schalter.Kindersicherung_1
                      openknx.0
                      2022-04-24 07:04:45.016	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/81 openknx.0.Haussteuerung.Taster_Schalter.Kindersicherung_2
                      openknx.0
                      2022-04-24 07:04:44.999	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/82 openknx.0.Haussteuerung.Taster_Schalter.Kindersicherung_3
                      openknx.0
                      2022-04-24 07:04:44.939	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/83 openknx.0.Haussteuerung.Taster_Schalter.Kindersicherung_4
                      openknx.0
                      2022-04-24 07:04:44.926	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/84 openknx.0.Haussteuerung.Taster_Schalter.Kindersicherung_5
                      openknx.0
                      2022-04-24 07:04:44.907	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/85 openknx.0.Haussteuerung.Taster_Schalter.Kindersicherung_6
                      openknx.0
                      2022-04-24 07:04:44.890	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/86 openknx.0.Haussteuerung.Taster_Schalter.Kindersicherung_7
                      openknx.0
                      2022-04-24 07:04:44.869	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/87 openknx.0.Haussteuerung.Taster_Schalter.Kindersicherung_8
                      openknx.0
                      2022-04-24 07:04:44.833	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/88 openknx.0.Haussteuerung.Taster_Schalter.Kindersicherung_9
                      openknx.0
                      2022-04-24 07:04:44.794	debug	Datapoint autoread created and GroupValueWrite sent: 1/0/89 openknx.0.Haussteuerung.Taster_Schalter.Kindersicherung_10
                      openknx.0
                      2022-04-24 07:04:44.755	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/0 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_1_1
                      openknx.0
                      2022-04-24 07:04:44.707	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/1 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_1_2
                      openknx.0
                      2022-04-24 07:04:44.690	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/2 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_1_3
                      openknx.0
                      2022-04-24 07:04:44.674	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/3 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_1_4
                      openknx.0
                      2022-04-24 07:04:44.657	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/4 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_2_1
                      openknx.0
                      2022-04-24 07:04:44.642	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/5 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_2_2
                      openknx.0
                      2022-04-24 07:04:44.625	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/6 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_2_3
                      openknx.0
                      2022-04-24 07:04:44.593	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/7 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_2_4
                      openknx.0
                      2022-04-24 07:04:44.571	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/8 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_3_1
                      openknx.0
                      2022-04-24 07:04:44.558	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/9 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_3_2
                      openknx.0
                      2022-04-24 07:04:44.545	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/10 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_3_3
                      openknx.0
                      2022-04-24 07:04:44.532	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/11 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_3_4
                      openknx.0
                      2022-04-24 07:04:44.518	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/12 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_4_1
                      openknx.0
                      2022-04-24 07:04:44.504	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/13 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_4_2
                      openknx.0
                      2022-04-24 07:04:44.476	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/14 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_4_3
                      openknx.0
                      2022-04-24 07:04:44.411	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/15 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_4_4
                      openknx.0
                      2022-04-24 07:04:44.397	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/16 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_5_1
                      openknx.0
                      2022-04-24 07:04:44.385	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/17 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_5_2
                      openknx.0
                      2022-04-24 07:04:44.368	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/18 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_5_3
                      openknx.0
                      2022-04-24 07:04:44.351	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/19 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_5_4
                      openknx.0
                      2022-04-24 07:04:44.337	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/20 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_5_5
                      openknx.0
                      2022-04-24 07:04:44.313	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/21 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_5_6
                      openknx.0
                      2022-04-24 07:04:44.288	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/22 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_5_7
                      openknx.0
                      2022-04-24 07:04:44.270	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/23 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_5_8
                      openknx.0
                      2022-04-24 07:04:44.253	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/24 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_6_1
                      openknx.0
                      2022-04-24 07:04:44.236	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/25 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_6_2
                      openknx.0
                      2022-04-24 07:04:44.223	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/26 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_6_3
                      openknx.0
                      2022-04-24 07:04:44.210	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/27 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_6_4
                      openknx.0
                      2022-04-24 07:04:44.197	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/28 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_6_5
                      openknx.0
                      2022-04-24 07:04:44.183	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/29 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_6_6
                      openknx.0
                      2022-04-24 07:04:44.165	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/30 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_6_7
                      openknx.0
                      2022-04-24 07:04:44.152	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/31 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_6_8
                      openknx.0
                      2022-04-24 07:04:44.114	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/32 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_7_1
                      openknx.0
                      2022-04-24 07:04:44.098	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/33 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_7_2
                      openknx.0
                      2022-04-24 07:04:44.082	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/34 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_7_3
                      openknx.0
                      2022-04-24 07:04:44.052	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/35 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_7_4
                      openknx.0
                      2022-04-24 07:04:44.017	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/36 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_7_5
                      openknx.0
                      2022-04-24 07:04:43.998	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/37 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_7_6
                      openknx.0
                      2022-04-24 07:04:43.975	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/38 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_7_7
                      openknx.0
                      2022-04-24 07:04:43.956	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/39 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_7_8
                      openknx.0
                      2022-04-24 07:04:43.939	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/40 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_8_1
                      openknx.0
                      2022-04-24 07:04:43.923	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/41 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_8_2
                      openknx.0
                      2022-04-24 07:04:43.904	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/42 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_8_3
                      openknx.0
                      2022-04-24 07:04:43.882	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/43 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_8_4
                      openknx.0
                      2022-04-24 07:04:43.860	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/44 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_9_1
                      openknx.0
                      2022-04-24 07:04:43.842	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/45 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_9_2
                      openknx.0
                      2022-04-24 07:04:43.823	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/46 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_9_3
                      openknx.0
                      2022-04-24 07:04:43.804	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/47 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_9_4
                      openknx.0
                      2022-04-24 07:04:43.771	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/48 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_10_1
                      openknx.0
                      2022-04-24 07:04:43.730	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/49 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_10_2
                      openknx.0
                      2022-04-24 07:04:43.681	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/50 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_10_3
                      openknx.0
                      2022-04-24 07:04:43.640	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/51 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_10_4
                      openknx.0
                      2022-04-24 07:04:43.591	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/52 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_10_5
                      openknx.0
                      2022-04-24 07:04:43.533	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/53 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_10_6
                      openknx.0
                      2022-04-24 07:04:43.481	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/54 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_10_7
                      openknx.0
                      2022-04-24 07:04:43.449	debug	Datapoint autoread created and GroupValueWrite sent: 1/1/55 openknx.0.Haussteuerung.Taster_LED_Schalter_Status.LED_10_8
                      openknx.0
                      2022-04-24 07:04:43.418	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/0 openknx.0.Haussteuerung.Taster_Umgebungslicht.TN_1
                      openknx.0
                      2022-04-24 07:04:43.392	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/1 openknx.0.Haussteuerung.Taster_Umgebungslicht.TN_2
                      openknx.0
                      2022-04-24 07:04:43.314	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/2 openknx.0.Haussteuerung.Taster_Umgebungslicht.TN_3
                      openknx.0
                      2022-04-24 07:04:43.274	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/3 openknx.0.Haussteuerung.Taster_Umgebungslicht.TN_4
                      openknx.0
                      2022-04-24 07:04:43.212	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/4 openknx.0.Haussteuerung.Taster_Umgebungslicht.TN_5
                      openknx.0
                      2022-04-24 07:04:43.189	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/5 openknx.0.Haussteuerung.Taster_Umgebungslicht.TN_6
                      openknx.0
                      2022-04-24 07:04:43.125	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/6 openknx.0.Haussteuerung.Taster_Umgebungslicht.TN_7
                      openknx.0
                      2022-04-24 07:04:43.063	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/7 openknx.0.Haussteuerung.Taster_Umgebungslicht.TN_8
                      openknx.0
                      2022-04-24 07:04:43.043	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/8 openknx.0.Haussteuerung.Taster_Umgebungslicht.TN_9
                      openknx.0
                      2022-04-24 07:04:42.989	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/9 openknx.0.Haussteuerung.Taster_Umgebungslicht.U_1
                      openknx.0
                      2022-04-24 07:04:42.885	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/10 openknx.0.Haussteuerung.Taster_Umgebungslicht.U_2
                      openknx.0
                      2022-04-24 07:04:42.821	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/11 openknx.0.Haussteuerung.Taster_Umgebungslicht.U_3
                      openknx.0
                      2022-04-24 07:04:42.794	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/12 openknx.0.Haussteuerung.Taster_Umgebungslicht.U_4
                      openknx.0
                      2022-04-24 07:04:42.754	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/13 openknx.0.Haussteuerung.Taster_Umgebungslicht.U_5
                      openknx.0
                      2022-04-24 07:04:42.711	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/14 openknx.0.Haussteuerung.Taster_Umgebungslicht.U_6
                      openknx.0
                      2022-04-24 07:04:42.675	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/15 openknx.0.Haussteuerung.Taster_Umgebungslicht.U_7
                      openknx.0
                      2022-04-24 07:04:42.638	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/16 openknx.0.Haussteuerung.Taster_Umgebungslicht.U_8
                      openknx.0
                      2022-04-24 07:04:42.433	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/17 openknx.0.Haussteuerung.Taster_Umgebungslicht.U_9
                      openknx.0
                      2022-04-24 07:04:42.392	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/18 openknx.0.Haussteuerung.Taster_Umgebungslicht.TU_1
                      openknx.0
                      2022-04-24 07:04:42.371	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/19 openknx.0.Haussteuerung.Taster_Umgebungslicht.TU_2
                      openknx.0
                      2022-04-24 07:04:42.349	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/20 openknx.0.Haussteuerung.Taster_Umgebungslicht.TU_3
                      openknx.0
                      2022-04-24 07:04:42.327	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/21 openknx.0.Haussteuerung.Taster_Umgebungslicht.TU_4
                      openknx.0
                      2022-04-24 07:04:42.279	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/22 openknx.0.Haussteuerung.Taster_Umgebungslicht.TU_5
                      openknx.0
                      2022-04-24 07:04:42.141	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/23 openknx.0.Haussteuerung.Taster_Umgebungslicht.TU_6
                      openknx.0
                      2022-04-24 07:04:41.991	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/24 openknx.0.Haussteuerung.Taster_Umgebungslicht.TU_7
                      openknx.0
                      2022-04-24 07:04:41.933	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/25 openknx.0.Haussteuerung.Taster_Umgebungslicht.TU_8
                      openknx.0
                      2022-04-24 07:04:41.887	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/26 openknx.0.Haussteuerung.Taster_Umgebungslicht.TU_9
                      openknx.0
                      2022-04-24 07:04:41.855	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/27 openknx.0.Haussteuerung.Taster_Umgebungslicht.TN_10
                      openknx.0
                      2022-04-24 07:04:41.806	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/28 openknx.0.Haussteuerung.Taster_Umgebungslicht.U_10
                      openknx.0
                      2022-04-24 07:04:41.766	debug	Datapoint autoread created and GroupValueWrite sent: 1/2/29 openknx.0.Haussteuerung.Taster_Umgebungslicht.TU_10
                      openknx.0
                      2022-04-24 07:04:41.702	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/0 openknx.0.Haussteuerung.Dimmer.Dimmer_Kinderzimmer_1
                      openknx.0
                      2022-04-24 07:04:41.684	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/1 openknx.0.Haussteuerung.Dimmer.Dimmer_Kinderzimmer_2
                      openknx.0
                      2022-04-24 07:04:41.666	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/2 openknx.0.Haussteuerung.Dimmer.Dimmer_Küchentisch
                      openknx.0
                      2022-04-24 07:04:41.649	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/3 openknx.0.Haussteuerung.Dimmer.Dimmer_Tresen
                      openknx.0
                      2022-04-24 07:04:41.632	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/4 openknx.0.Haussteuerung.Dimmer.Dimmer_Wohnzimmertisch
                      openknx.0
                      2022-04-24 07:04:41.613	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/5 openknx.0.Haussteuerung.Dimmer.Dimmer_Flur
                      openknx.0
                      2022-04-24 07:04:41.591	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/6 openknx.0.Haussteuerung.Dimmer.Dimmer_Schlafzimmer_Decke
                      openknx.0
                      2022-04-24 07:04:41.547	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/7 openknx.0.Haussteuerung.Dimmer.Dimmer_Terasse
                      openknx.0
                      2022-04-24 07:04:41.488	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/8 openknx.0.Haussteuerung.Dimmer.Dimmer_Badezimmer_Decke
                      openknx.0
                      2022-04-24 07:04:41.475	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/9 openknx.0.Haussteuerung.Dimmer.Dimmer_Badezimmer_Dusche
                      openknx.0
                      2022-04-24 07:04:41.458	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/10 openknx.0.Haussteuerung.Dimmer.Dimmer_Badezimmer_Spiegel
                      openknx.0
                      2022-04-24 07:04:41.402	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/11 openknx.0.Haussteuerung.Dimmer.Dimmer_Gästezimmer_vorn
                      openknx.0
                      2022-04-24 07:04:41.292	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/12 openknx.0.Haussteuerung.Dimmer.Dimmer_Gästebadezimmer_Decke
                      openknx.0
                      2022-04-24 07:04:41.211	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/13 openknx.0.Haussteuerung.Dimmer.Dimmer_Gästebadezimmer_Dusche
                      openknx.0
                      2022-04-24 07:04:41.151	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/14 openknx.0.Haussteuerung.Dimmer.Dimmer_Gästebadezimmer_Spiegel
                      openknx.0
                      2022-04-24 07:04:41.070	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/15 openknx.0.Haussteuerung.Dimmer.Dimmer_Gästezimmer_hinten
                      openknx.0
                      2022-04-24 07:04:40.922	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/16 openknx.0.Haussteuerung.Dimmer.Dimmer_Boden
                      openknx.0
                      2022-04-24 07:04:40.821	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/17 openknx.0.Haussteuerung.Dimmer.Dimmer_Arbeitsplatte
                      openknx.0
                      2022-04-24 07:04:40.781	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/18 openknx.0.Haussteuerung.Dimmer.Dimmer_Treppe
                      openknx.0
                      2022-04-24 07:04:40.744	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/19 openknx.0.Haussteuerung.Dimmer.Dimmer_Wand_1
                      openknx.0
                      2022-04-24 07:04:40.727	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/20 openknx.0.Haussteuerung.Dimmer.Dimmer_Wand_2
                      openknx.0
                      2022-04-24 07:04:40.704	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/21 openknx.0.Haussteuerung.Dimmer.Dimmer_Büro_Keller_Schreibtisch_rechts
                      openknx.0
                      2022-04-24 07:04:40.681	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/22 openknx.0.Haussteuerung.Dimmer.Dimmer_Büro_Keller_Schreibtisch_links
                      openknx.0
                      2022-04-24 07:04:40.664	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/23 openknx.0.Haussteuerung.Dimmer.Dimmer_Büro_Keller_Säule_oben
                      openknx.0
                      2022-04-24 07:04:40.638	debug	Datapoint autoread created and GroupValueWrite sent: 1/3/24 openknx.0.Haussteuerung.Dimmer.Dimmer_Büro_Keller_Säule_unten
                      openknx.0
                      2022-04-24 07:04:40.619	debug	Datapoint autoread created and GroupValueWrite sent: 1/5/0 openknx.0.Haussteuerung.Temperatur_Ist.Temp_1
                      openknx.0
                      2022-04-24 07:04:40.597	debug	Datapoint autoread created and GroupValueWrite sent: 1/5/1 openknx.0.Haussteuerung.Temperatur_Ist.Temp_2
                      openknx.0
                      2022-04-24 07:04:40.573	debug	Datapoint autoread created and GroupValueWrite sent: 1/5/2 openknx.0.Haussteuerung.Temperatur_Ist.Temp_3
                      openknx.0
                      2022-04-24 07:04:40.555	debug	Datapoint autoread created and GroupValueWrite sent: 1/5/3 openknx.0.Haussteuerung.Temperatur_Ist.Temp_4
                      openknx.0
                      2022-04-24 07:04:40.526	debug	Datapoint autoread created and GroupValueWrite sent: 1/5/4 openknx.0.Haussteuerung.Temperatur_Ist.Temp_5
                      openknx.0
                      2022-04-24 07:04:40.507	debug	Datapoint autoread created and GroupValueWrite sent: 1/5/6 openknx.0.Haussteuerung.Temperatur_Ist.Temp_7
                      openknx.0
                      2022-04-24 07:04:40.488	debug	Datapoint autoread created and GroupValueWrite sent: 1/5/7 openknx.0.Haussteuerung.Temperatur_Ist.Temp_8
                      openknx.0
                      2022-04-24 07:04:40.464	debug	Datapoint autoread created and GroupValueWrite sent: 1/5/8 openknx.0.Haussteuerung.Temperatur_Ist.Temp_9
                      openknx.0
                      2022-04-24 07:04:40.440	debug	Datapoint autoread created and GroupValueWrite sent: 1/5/9 openknx.0.Haussteuerung.Temperatur_Ist.Temp_10
                      openknx.0
                      2022-04-24 07:04:40.420	debug	Datapoint autoread created and GroupValueWrite sent: 1/6/0 openknx.0.Haussteuerung.Temperatur_Soll.Temp_soll_1
                      openknx.0
                      2022-04-24 07:04:40.398	debug	Datapoint autoread created and GroupValueWrite sent: 1/6/1 openknx.0.Haussteuerung.Temperatur_Soll.Temp_soll_2
                      openknx.0
                      2022-04-24 07:04:40.349	debug	Datapoint autoread created and GroupValueWrite sent: 1/6/2 openknx.0.Haussteuerung.Temperatur_Soll.Temp_soll_3
                      openknx.0
                      2022-04-24 07:04:40.330	debug	Datapoint autoread created and GroupValueWrite sent: 1/6/3 openknx.0.Haussteuerung.Temperatur_Soll.Temp_soll_4
                      openknx.0
                      2022-04-24 07:04:40.308	debug	Datapoint autoread created and GroupValueWrite sent: 1/6/4 openknx.0.Haussteuerung.Temperatur_Soll.Temp_soll_5
                      openknx.0
                      2022-04-24 07:04:40.287	debug	Datapoint autoread created and GroupValueWrite sent: 1/6/6 openknx.0.Haussteuerung.Temperatur_Soll.Temp_soll_7
                      openknx.0
                      2022-04-24 07:04:40.260	debug	Datapoint autoread created and GroupValueWrite sent: 1/6/7 openknx.0.Haussteuerung.Temperatur_Soll.Temp_soll_8
                      openknx.0
                      2022-04-24 07:04:40.210	debug	Datapoint autoread created and GroupValueWrite sent: 1/6/8 openknx.0.Haussteuerung.Temperatur_Soll.Temp_soll_9
                      openknx.0
                      2022-04-24 07:04:40.185	debug	Datapoint autoread created and GroupValueWrite sent: 1/6/9 openknx.0.Haussteuerung.Temperatur_Soll.Temp_soll_10
                      openknx.0
                      2022-04-24 07:04:40.144	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/0 openknx.0.Haussteuerung.Rolladen.Rolladen_1C
                      openknx.0
                      2022-04-24 07:04:40.087	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/1 openknx.0.Haussteuerung.Rolladen.Rolladen_2C
                      openknx.0
                      2022-04-24 07:04:40.060	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/2 openknx.0.Haussteuerung.Rolladen.Rolladen_3C
                      openknx.0
                      2022-04-24 07:04:40.020	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/3 openknx.0.Haussteuerung.Rolladen.Rolladen_4C
                      openknx.0
                      2022-04-24 07:04:39.955	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/4 openknx.0.Haussteuerung.Rolladen.Rolladen_5_1C
                      openknx.0
                      2022-04-24 07:04:39.922	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/5 openknx.0.Haussteuerung.Rolladen.Rolladen_5_2C
                      openknx.0
                      2022-04-24 07:04:39.864	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/6 openknx.0.Haussteuerung.Rolladen.Rolladen_6_1C
                      openknx.0
                      2022-04-24 07:04:39.830	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/7 openknx.0.Haussteuerung.Rolladen.Rolladen_6_2C
                      openknx.0
                      2022-04-24 07:04:39.797	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/8 openknx.0.Haussteuerung.Rolladen.Rolladen_8C
                      openknx.0
                      2022-04-24 07:04:39.769	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/9 openknx.0.Haussteuerung.Rolladen.Rolladen_8O
                      openknx.0
                      2022-04-24 07:04:39.727	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/10 openknx.0.Haussteuerung.Rolladen.Rolladen_1O
                      openknx.0
                      2022-04-24 07:04:39.669	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/11 openknx.0.Haussteuerung.Rolladen.Rolladen_2O
                      openknx.0
                      2022-04-24 07:04:39.616	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/12 openknx.0.Haussteuerung.Rolladen.Rolladen_3O
                      openknx.0
                      2022-04-24 07:04:39.547	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/13 openknx.0.Haussteuerung.Rolladen.Rolladen_4O
                      openknx.0
                      2022-04-24 07:04:39.483	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/14 openknx.0.Haussteuerung.Rolladen.Rolladen_5_1O
                      openknx.0
                      2022-04-24 07:04:39.453	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/15 openknx.0.Haussteuerung.Rolladen.Rolladen_5_2O
                      openknx.0
                      2022-04-24 07:04:39.429	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/16 openknx.0.Haussteuerung.Rolladen.Rolladen_6_1O
                      openknx.0
                      2022-04-24 07:04:39.405	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/17 openknx.0.Haussteuerung.Rolladen.Rolladen_6_2O
                      openknx.0
                      2022-04-24 07:04:39.381	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/18 openknx.0.Haussteuerung.Rolladen.Rolladen_zentral_O
                      openknx.0
                      2022-04-24 07:04:39.346	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/19 openknx.0.Haussteuerung.Rolladen.Rolladen_zentral_C
                      openknx.0
                      2022-04-24 07:04:38.496	info	/opt/iobroker/node_modules/iobroker.js-controller
                      openknx.0
                      2022-04-24 07:04:38.492	info	Connecting to knx gateway: 224.0.23.12:3672 with phy. Adr: 1.1.255 minimum send delay: 50 ms debug level: silly
                      openknx.0
                      2022-04-24 07:04:38.300	info	starting. Version 0.1.22 in /opt/iobroker/node_modules/iobroker.openknx, node: v14.19.0, js-controller: 3.3.22
                      openknx.0
                      2022-04-24 07:04:36.384	debug	Plugin sentry Initialize Plugin (enabled=true)
                      openknx.0
                      2022-04-24 07:04:18.378	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      openknx.0
                      2022-04-24 07:04:18.356	info	terminating
                      openknx.0
                      2022-04-24 07:04:18.328	info	Got terminate signal TERMINATE_YOURSELF
                      So sieht es aus, wenn ich einen Wert ändere:
                      openknx.0
                      2022-04-24 07:08:07.455	debug	Outbound GroupValue_Write to 1/3/22 val: 10 from openknx.0.Haussteuerung.Dimmer.Dimmer_Büro_Keller_Schreibtisch_links
                      Es passiert aber nichts. Im Protokoll wird nichts weiter gemeldet.
                      • P petkoh
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        openknx.0
                        killroy2
                        #310
                        @petkoh setzte die Protokollstufe auf "Alles" und poste das Log hier.
                        • K killroy2
                          tro
                          #311
                          @killroy2 Danke! Heute installiert, werde nach ein paar Tagen berichten.
                          • K killroy2
                            petkoh
                            #312
                            @killroy2
                            Hier der Start:
                            openknx.0
                            2022-04-27 05:52:21.442	debug	Datapoint autoread created and GroupValueWrite sent: 1/7/19 openknx.0.Haussteuerung.Rolladen.Rolladen_zentral_C
                            openknx.0
                            2022-04-27 05:52:21.428	silly	[trace] 2022-04-27 03:52:21.427 Binding connection to GroupValue_Response_1/7/19
                            openknx.0
                            2022-04-27 05:52:21.420	silly	[trace] 2022-04-27 03:52:21.418 resolved DPT1.001 to {"basetype":{"bitlength":1,"valuetype":"basic","desc":"1-bit value"},"subtypes":{"100":{"use":"???","name":"DPT_Heat/Cool","desc":"heat/cool","enc":{"0":"???","1":"???"}},"001":{"use":"G","name":"DPT_Switch","desc":"switch","enc":{"0":"Off","1":"On"}},"002":{"use":"G","name":"DPT_Bool","desc":"bool","enc":{"0":"false","1":"true"}},"003":{"use":"G","name":"DPT_Enable","desc":"enable","enc":{"0":"disable","1":"enable"}},"004":{"use":"FB","name":"DPT_Ramp","desc":"ramp","enc":{"0":"No ramp","1":"Ramp"}},"005":{"use":"FB","name":"DPT_Alarm","desc":"alarm","enc":{"0":"No alarm","1":"Alarm"}},"006":{"use":"FB","name":"DPT_BinaryValue","desc":"binary value","enc":{"0":"Low","1":"High"}},"007":{"use":"FB","name":"DPT_Step","desc":"step","enc":{"0":"Decrease","1":"Increase"}},"008":{"use":"G","name":"DPT_UpDown","desc":"up/down","enc":{"0":"Up","1":"Down"}},"009":{"use":"G","name":"DPT_OpenClose","desc":"open/close","enc":{"0":"Open","1":"Close"}},"010":{"use":"G","name":"DPT_Start","desc":"start/stop","enc":{"0":"Stop","1":"Start"}},"011":{"use":"FB","name":"DPT_State","desc":"state","enc":{"0":"Inactive","1":"Active"}},"012":{"use":"FB","name":"DPT_Invert","desc":"invert","enc":{"0":"Not inverted","1":"inverted"}},"013":{"use":"FB","name":"DPT_DimSendStyle","desc":"dim send style","enc":{"0":"Start/stop","1":"Cyclically"}},"014":{"use":"FB","name":"DPT_InputSource","desc":"input source","enc":{"0":"Fixed","1":"Calculated"}},"015":{"use":"G","name":"DPT_Reset","desc":"reset","enc":{"0":"no action(dummy)","1":"reset command(trigger)"}},"016":{"use":"G","name":"DPT_Ack","desc":"ack","enc":{"0":"no action(dummy)","1":"acknowledge command(trigger)"}},"017":{"use":"G","name":"DPT_Trigger","desc":"trigger","enc":{"0":"trigger","1":"trigger"}},"018":{"use":"G","name":"DPT_Occupancy","desc":"occupancy","enc":{"0":"not occupied","1":"occupied"}},"019":{"use":"G","name":"DPT_WindowDoor","desc":"open window/door","enc":{"0":"closed","1":"open"}},"021":{"use":"FB","name":"DPT_LogicalFunction","desc":"and/or","enc":{"0":"logical function OR","1":"logical function AND"}},"022":{"use":"FB","name":"DPT_Scene_AB","desc":"scene A/B","enc":{"0":"scene A","1":"scene B"}},"023":{"use":"FB","name":"DPT_ShutterBlinds_Mode","desc":"shutter/blinds mode","enc":{"0":"only move Up/Down mode (shutter)","1":"move Up/Down + StepStop mode (blind)"}}},"id":"DPT1","subtypeid":"001","subtype":{"use":"G","name":"DPT_Switch","desc":"switch","enc":{"0":"Off","1":"On"}}}
                            openknx.0
                            2022-04-27 05:52:21.407	silly	[debug] 2022-04-27 03:52:21.406 (idle): zzzz...
                            openknx.0
                            2022-04-27 05:52:21.401	silly	[debug] 2022-04-27 03:52:21.400 --- Connected in ROUTING mode ---
                            openknx.0
                            2022-04-27 05:52:21.395	silly	[debug] 2022-04-27 03:52:21.393 useTunneling=false
                            openknx.0
                            2022-04-27 05:52:21.384	silly	[debug] 2022-04-27 03:52:21.382 IpRoutingConnection 192.168.2.15:3671, adding membership for 224.0.23.12
                            openknx.0
                            2022-04-27 05:52:21.351	silly	[trace] 2022-04-27 03:52:21.349 candidate interface: tun0 ({"address":"10.8.0.1","netmask":"255.255.255.0","family":"IPv4","mac":"00:00:00:00:00:00","internal":false,"cidr":"10.8.0.1/24"})
                            openknx.0
                            2022-04-27 05:52:21.346	silly	[trace] 2022-04-27 03:52:21.344 candidate interface: eth0 ({"address":"192.168.2.15","netmask":"255.255.255.0","family":"IPv4","mac":"02:81:0b:01:d3:12","internal":false,"cidr":"192.168.2.15/24"})
                            openknx.0
                            2022-04-27 05:52:21.322	silly	[debug] 2022-04-27 03:52:21.314 initializing multicast connection to 224.0.23.12
                            openknx.0
                            2022-04-27 05:52:21.262	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.info.connection:{"val":false,"ack":true,"ts":1651031541162,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031541162}
                            openknx.0
                            2022-04-27 05:52:21.178	silly	States system redis pmessage io.system.adapter.openknx.0.logLevel/io.system.adapter.openknx.0.logLevel:{"val":"silly","ack":true,"ts":1651031540956,"q":0,"from":"system.adapter.openknx.0","lc":1650776678514}
                            openknx.0
                            2022-04-27 05:52:20.925	info	/opt/iobroker/node_modules/iobroker.js-controller
                            openknx.0
                            2022-04-27 05:52:20.913	info	Connecting to knx gateway: 224.0.23.12:3672 with phy. Adr: 1.0.2 minimum send delay: 50 ms debug level: silly
                            openknx.0
                            2022-04-27 05:52:20.593	info	starting. Version 0.1.22 in /opt/iobroker/node_modules/iobroker.openknx, node: v14.19.0, js-controller: 3.3.22
                            openknx.0
                            2022-04-27 05:52:19.175	debug	Plugin sentry Initialize Plugin (enabled=true
                            Hier das Senden eines Wertes:
                            openknx.0
                            2022-04-27 05:55:26.442	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_4:{"val":19.9,"ack":true,"ts":1651031726428,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031726428}
                            openknx.0
                            2022-04-27 05:55:26.388	debug	Inbound GroupValue_Write from 2.1.4 GA 1/5/3 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_4 val: 19.9 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:55:26.384	silly	[trace] 2022-04-27 03:55:26.358 2022-04-27 03:55:26 **** (1/5/3) 19.9 °C DATAPOINT CHANGE (was: 19.8)
                            openknx.0
                            2022-04-27 05:55:26.354	silly	[trace] 2022-04-27 03:55:26.337 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.4","dest_addr":"1/5/3","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,198]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,198]}}}}
                            openknx.0
                            2022-04-27 05:55:26.333	silly	[debug] 2022-04-27 03:55:26.332 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021040d0303008007c6
                            openknx.0
                            2022-04-27 05:55:24.360	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_5:{"val":20.8,"ack":true,"ts":1651031724347,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031724347}
                            openknx.0
                            2022-04-27 05:55:24.293	debug	Inbound GroupValue_Write from 2.1.5 GA 1/5/4 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_5 val: 20.8 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:55:24.290	silly	[trace] 2022-04-27 03:55:24.289 2022-04-27 03:55:24 **** (1/5/4) 20.8 °C DATAPOINT CHANGE (was: 20.9)
                            openknx.0
                            2022-04-27 05:55:24.277	silly	[trace] 2022-04-27 03:55:24.276 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.5","dest_addr":"1/5/4","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,12,16]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[12,16]}}}}
                            openknx.0
                            2022-04-27 05:55:24.269	silly	[debug] 2022-04-27 03:55:24.268 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021050d040300800c10
                            openknx.0
                            2022-04-27 05:55:23.862	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_8:{"val":19.1,"ack":true,"ts":1651031723837,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031723837}
                            openknx.0
                            2022-04-27 05:55:23.767	debug	Inbound GroupValue_Write from 2.1.8 GA 1/5/7 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_8 val: 19.1 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:55:23.755	silly	[trace] 2022-04-27 03:55:23.722 2022-04-27 03:55:23 **** (1/5/7) 19.1 °C DATAPOINT CHANGE (was: 19.2)
                            openknx.0
                            2022-04-27 05:55:23.718	silly	[trace] 2022-04-27 03:55:23.716 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.8","dest_addr":"1/5/7","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,118]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,118]}}}}
                            openknx.0
                            2022-04-27 05:55:23.710	silly	[debug] 2022-04-27 03:55:23.709 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021080d070300800776
                            openknx.0
                            2022-04-27 05:55:14.416	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_7:{"val":18,"ack":true,"ts":1651031714399,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031714399}
                            openknx.0
                            2022-04-27 05:55:14.365	debug	Inbound GroupValue_Write from 2.1.7 GA 1/5/6 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_7 val: 18 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:55:14.362	silly	[trace] 2022-04-27 03:55:14.362 2022-04-27 03:55:14 **** (1/5/6) 18 °C DATAPOINT CHANGE (was: 17.9)
                            openknx.0
                            2022-04-27 05:55:14.359	silly	[trace] 2022-04-27 03:55:14.358 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.7","dest_addr":"1/5/6","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,8]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,8]}}}}
                            openknx.0
                            2022-04-27 05:55:14.354	silly	[debug] 2022-04-27 03:55:14.353 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021070d060300800708
                            openknx.0
                            2022-04-27 05:55:13.903	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_1:{"val":20.3,"ack":true,"ts":1651031713893,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031713893}
                            openknx.0
                            2022-04-27 05:55:13.870	debug	Inbound GroupValue_Write from 2.1.1 GA 1/5/0 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_1 val: 20.3 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:55:13.847	silly	[trace] 2022-04-27 03:55:13.846 2022-04-27 03:55:13 **** (1/5/0) 20.3 °C DATAPOINT CHANGE (was: 20.4)
                            openknx.0
                            2022-04-27 05:55:13.843	silly	[trace] 2022-04-27 03:55:13.842 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.1","dest_addr":"1/5/0","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,238]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,238]}}}}
                            openknx.0
                            2022-04-27 05:55:13.834	silly	[debug] 2022-04-27 03:55:13.833 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021010d0003008007ee
                            openknx.0
                            2022-04-27 05:55:12.583	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_2:{"val":20.9,"ack":true,"ts":1651031712564,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031712564}
                            openknx.0
                            2022-04-27 05:55:12.467	debug	Inbound GroupValue_Write from 2.1.2 GA 1/5/1 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_2 val: 20.9 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:55:12.463	silly	[trace] 2022-04-27 03:55:12.462 2022-04-27 03:55:12 **** (1/5/1) 20.9 °C DATAPOINT CHANGE (was: 21)
                            openknx.0
                            2022-04-27 05:55:12.455	silly	[trace] 2022-04-27 03:55:12.441 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.2","dest_addr":"1/5/1","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,12,21]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[12,21]}}}}
                            openknx.0
                            2022-04-27 05:55:12.431	silly	[debug] 2022-04-27 03:55:12.430 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021020d010300800c15
                            openknx.0
                            2022-04-27 05:55:11.365	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_3:{"val":20.2,"ack":true,"ts":1651031711336,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031711336}
                            openknx.0
                            2022-04-27 05:55:11.266	debug	Inbound GroupValue_Write from 2.1.3 GA 1/5/2 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_3 val: 20.2 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:55:11.253	silly	[trace] 2022-04-27 03:55:11.246 2022-04-27 03:55:11 **** (1/5/2) 20.2 °C DATAPOINT CHANGE (was: 20.1)
                            openknx.0
                            2022-04-27 05:55:11.123	silly	[trace] 2022-04-27 03:55:11.122 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.3","dest_addr":"1/5/2","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,228]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,228]}}}}
                            openknx.0
                            2022-04-27 05:55:11.114	silly	[debug] 2022-04-27 03:55:11.113 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021030d0203008007e4
                            openknx.0
                            2022-04-27 05:55:06.444	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_4:{"val":19.8,"ack":true,"ts":1651031706418,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031706418}
                            openknx.0
                            2022-04-27 05:55:06.394	debug	Inbound GroupValue_Write from 2.1.4 GA 1/5/3 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_4 val: 19.8 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:55:06.379	silly	[trace] 2022-04-27 03:55:06.377 2022-04-27 03:55:06 **** (1/5/3) 19.8 °C DATAPOINT CHANGE (was: 19.9)
                            openknx.0
                            2022-04-27 05:55:06.368	silly	[trace] 2022-04-27 03:55:06.355 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.4","dest_addr":"1/5/3","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,188]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,188]}}}}
                            openknx.0
                            2022-04-27 05:55:06.343	silly	[debug] 2022-04-27 03:55:06.342 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021040d0303008007bc
                            openknx.0
                            2022-04-27 05:55:05.244	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_10:{"val":18.1,"ack":true,"ts":1651031705235,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031705235}
                            openknx.0
                            2022-04-27 05:55:05.200	debug	Inbound GroupValue_Write from 2.1.10 GA 1/5/9 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_10 val: 18.1 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:55:05.197	silly	[trace] 2022-04-27 03:55:05.186 2022-04-27 03:55:05 **** (1/5/9) 18.1 °C DATAPOINT CHANGE (was: 18.2)
                            openknx.0
                            2022-04-27 05:55:05.182	silly	[trace] 2022-04-27 03:55:05.173 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.10","dest_addr":"1/5/9","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,18]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,18]}}}}
                            openknx.0
                            2022-04-27 05:55:05.168	silly	[debug] 2022-04-27 03:55:05.168 Inbound multicast message from 192.168.2.10: 0610053000132900bcd0210a0d090300800712
                            openknx.0
                            2022-04-27 05:55:04.371	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_5:{"val":20.9,"ack":true,"ts":1651031704355,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031704355}
                            openknx.0
                            2022-04-27 05:55:04.303	debug	Inbound GroupValue_Write from 2.1.5 GA 1/5/4 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_5 val: 20.9 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:55:04.284	silly	[trace] 2022-04-27 03:55:04.284 2022-04-27 03:55:04 **** (1/5/4) 20.9 °C DATAPOINT CHANGE (was: 20.8)
                            openknx.0
                            2022-04-27 05:55:04.280	silly	[trace] 2022-04-27 03:55:04.271 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.5","dest_addr":"1/5/4","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,12,21]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[12,21]}}}}
                            openknx.0
                            2022-04-27 05:55:04.263	silly	[debug] 2022-04-27 03:55:04.262 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021050d040300800c15
                            openknx.0
                            2022-04-27 05:55:03.820	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_8:{"val":19.2,"ack":true,"ts":1651031703797,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031703797}
                            openknx.0
                            2022-04-27 05:55:03.749	debug	Inbound GroupValue_Write from 2.1.8 GA 1/5/7 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_8 val: 19.2 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:55:03.733	silly	[trace] 2022-04-27 03:55:03.733 2022-04-27 03:55:03 **** (1/5/7) 19.2 °C DATAPOINT CHANGE (was: 19.1)
                            openknx.0
                            2022-04-27 05:55:03.729	silly	[trace] 2022-04-27 03:55:03.727 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.8","dest_addr":"1/5/7","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,128]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,128]}}}}
                            openknx.0
                            2022-04-27 05:55:03.713	silly	[debug] 2022-04-27 03:55:03.713 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021080d070300800780
                            openknx.0
                            2022-04-27 05:54:52.545	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_2:{"val":21,"ack":true,"ts":1651031692519,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031692519}
                            openknx.0
                            2022-04-27 05:54:52.524	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_7:{"val":17.9,"ack":true,"ts":1651031692428,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031692428}
                            openknx.0
                            2022-04-27 05:54:52.481	debug	Inbound GroupValue_Write from 2.1.2 GA 1/5/1 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_2 val: 21 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:54:52.467	silly	[trace] 2022-04-27 03:54:52.455 2022-04-27 03:54:52 **** (1/5/1) 21 °C DATAPOINT CHANGE (was: 20.9)
                            openknx.0
                            2022-04-27 05:54:52.446	silly	[trace] 2022-04-27 03:54:52.442 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.2","dest_addr":"1/5/1","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,12,26]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[12,26]}}}}
                            openknx.0
                            2022-04-27 05:54:52.438	silly	[debug] 2022-04-27 03:54:52.434 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021020d010300800c1a
                            openknx.0
                            2022-04-27 05:54:52.380	debug	Inbound GroupValue_Write from 2.1.7 GA 1/5/6 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_7 val: 17.9 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:54:52.377	silly	[trace] 2022-04-27 03:54:52.376 2022-04-27 03:54:52 **** (1/5/6) 17.9 °C DATAPOINT CHANGE (was: 18)
                            openknx.0
                            2022-04-27 05:54:52.372	silly	[trace] 2022-04-27 03:54:52.371 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.7","dest_addr":"1/5/6","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,6,254]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[6,254]}}}}
                            openknx.0
                            2022-04-27 05:54:52.366	silly	[debug] 2022-04-27 03:54:52.365 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021070d0603008006fe
                            openknx.0
                            2022-04-27 05:54:52.064	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_1:{"val":20.4,"ack":true,"ts":1651031692052,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031692052}
                            openknx.0
                            2022-04-27 05:54:51.944	debug	Inbound GroupValue_Write from 2.1.1 GA 1/5/0 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_1 val: 20.4 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:54:51.926	silly	[trace] 2022-04-27 03:54:51.925 2022-04-27 03:54:51 **** (1/5/0) 20.4 °C DATAPOINT CHANGE (was: 20.3)
                            openknx.0
                            2022-04-27 05:54:51.921	silly	[trace] 2022-04-27 03:54:51.917 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.1","dest_addr":"1/5/0","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,248]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,248]}}}}
                            openknx.0
                            2022-04-27 05:54:51.911	silly	[debug] 2022-04-27 03:54:51.910 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021010d0003008007f8
                            openknx.0
                            2022-04-27 05:54:46.408	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_4:{"val":19.9,"ack":true,"ts":1651031686393,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031686393}
                            openknx.0
                            2022-04-27 05:54:46.368	debug	Inbound GroupValue_Write from 2.1.4 GA 1/5/3 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_4 val: 19.9 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:54:46.364	silly	[trace] 2022-04-27 03:54:46.363 2022-04-27 03:54:46 **** (1/5/3) 19.9 °C DATAPOINT CHANGE (was: 19.8)
                            openknx.0
                            2022-04-27 05:54:46.343	silly	[trace] 2022-04-27 03:54:46.341 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.4","dest_addr":"1/5/3","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,198]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,198]}}}}
                            openknx.0
                            2022-04-27 05:54:46.337	silly	[debug] 2022-04-27 03:54:46.336 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021040d0303008007c6
                            openknx.0
                            2022-04-27 05:54:45.265	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_10:{"val":18.2,"ack":true,"ts":1651031685251,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031685251}
                            openknx.0
                            2022-04-27 05:54:45.228	debug	Inbound GroupValue_Write from 2.1.10 GA 1/5/9 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_10 val: 18.2 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:54:45.193	silly	[trace] 2022-04-27 03:54:45.192 2022-04-27 03:54:45 **** (1/5/9) 18.2 °C DATAPOINT CHANGE (was: null)
                            openknx.0
                            2022-04-27 05:54:45.181	silly	[trace] 2022-04-27 03:54:45.180 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.10","dest_addr":"1/5/9","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,28]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,28]}}}}
                            openknx.0
                            2022-04-27 05:54:45.168	silly	[debug] 2022-04-27 03:54:45.167 Inbound multicast message from 192.168.2.10: 0610053000132900bcd0210a0d09030080071c
                            openknx.0
                            2022-04-27 05:54:43.189	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_3:{"val":20.1,"ack":true,"ts":1651031683176,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031683176}
                            openknx.0
                            2022-04-27 05:54:43.152	debug	Inbound GroupValue_Write from 2.1.3 GA 1/5/2 to Object: openknx.0.Haussteuerung.Temperatur_Ist.Temp_3 val: 20.1 dpt: DPT9.001
                            openknx.0
                            2022-04-27 05:54:43.147	silly	[trace] 2022-04-27 03:54:43.141 2022-04-27 03:54:43 **** (1/5/2) 20.1 °C DATAPOINT CHANGE (was: 20.2)
                            openknx.0
                            2022-04-27 05:54:43.128	silly	[trace] 2022-04-27 03:54:43.127 (idle): Received ROUTING_INDICATION_L_Data.ind message: {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":19,"cemi":{"msgcode":41,"addinfo_length":0,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":5,"extendedFrame":0},"src_addr":"2.1.3","dest_addr":"1/5/2","apdu":{"apdu_length":3,"apdu_raw":{"type":"Buffer","data":[0,128,7,218]},"tpci":0,"apci":"GroupValue_Write","data":{"type":"Buffer","data":[7,218]}}}}
                            openknx.0
                            2022-04-27 05:54:43.120	silly	[debug] 2022-04-27 03:54:43.119 Inbound multicast message from 192.168.2.10: 0610053000132900bcd021030d0203008007da
                            openknx.0
                            2022-04-27 05:54:36.626	silly	[debug] 2022-04-27 03:54:36.625 (idle): zzzz...
                            openknx.0
                            2022-04-27 05:54:36.623	silly	[debug] 2022-04-27 03:54:36.623 (sendDatagram): >>>>>>> successfully sent seqnum: 228
                            openknx.0
                            2022-04-27 05:54:36.620	silly	[trace] 2022-04-27 03:54:36.620 (sendDatagram): UDP sent OK: ROUTING_INDICATION_L_Data.ind 0610053000122900bce010020b1602008080
                            openknx.0
                            2022-04-27 05:54:36.616	silly	[trace] 2022-04-27 03:54:36.615 (sendDatagram): Sending ROUTING_INDICATION_L_Data.ind ==> {"header_length":6,"protocol_version":16,"service_type":1328,"total_length":18,"hpai":{"protocol_type":1,"tunnel_endpoint":"0.0.0.0:0"},"cemi":{"msgcode":41,"ctrl":{"frameType":1,"reserved":0,"repeat":1,"broadcast":1,"priority":3,"acknowledge":0,"confirm":0,"destAddrType":1,"hopCount":6,"extendedFrame":0},"src_addr":"1.0.2","dest_addr":"1/3/22","apdu":{"apci":"GroupValue_Write","tpci":0,"data":{"type":"Buffer","data":[128]},"bitlength":8}}}
                            openknx.0
                            2022-04-27 05:54:36.588	debug	Outbound GroupValue_Write to 1/3/22 val: 50 from openknx.0.Haussteuerung.Dimmer.Dimmer_Büro_Keller_Schreibtisch_links
                            openknx.0
                            2022-04-27 05:54:36.566	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Dimmer.Dimmer_Büro_Keller_Schreibtisch_links:{"val":50,"ack":false,"ts":1651031676559,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1651031676559}
                            openknx.0
                            2022-04-27 05:54:32.442	silly	States user redis pmessage io.openknx.0.*/io.openknx.0.Haussteuerung.Temperatur_Ist.Temp_7:{"val":18,"ack":true,"ts":1651031672432,"q":0,"from":"system.adapter.openknx.0","user":"system.user.admin","lc":1651031672432}
                            • K killroy2
                              @tro Ich glaube ich kann es nachvollziehen, ich melde mich wieder wenn das Problem demnächst behoben ist.
                              tro
                              #313
                              @killroy2 Leider hat die 0.1.25 bei meinem Problem mit dem abstürzenden Adapter nichts gebracht, am Tag zwei das gleiche Problem wie beschrieben.
                              • P petkoh
                                @killroy2
                                Hier der Start:
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                openknx.0
                                killroy2
                                #314
                                @petkoh Ich sehe du verwendest einen Router. Ich kann das momentan leider nicht testen, weil ich kein solches Gerät zur Verfügung habe.
                                T 2 Antworten Letzte Antwort
                                • K killroy2
                                  tro
                                  #315
                                  @killroy2 Der 0.1.25 lässt sich bei Instanz über "Neu starten" nicht neu starten, er bleibt auf Stop, man muss Ihn manuell neu starten.
                                  • K killroy2
                                    Tontechniker
                                    schrieb am zuletzt editiert von Tontechniker
                                    #316
                                    @killroy2 Hallo Killroy2! Es gibt Probleme mit der API-Kommunikation über Internet mit Bosch.
                                    Hier sind die Beiträge der Nutzer im anderen Forum: https://forum.iobroker.net/topic/9915/adapter-für-bosch-indego-connect/185 (ist das das falsche Forum??)
                                    Hans
                                    EDIT: @killroy2 Tut mir sehr leid Dich belästigt zu haben! Liegt am Bosch-Adapter!! Neue Version verfügbar!
                                    • K killroy2
                                      Tontechniker
                                      #317
                                      @killroy2 Habe gerade Open KNX 0.2.3 installiert und läuft!
                                      Danke!
                                      • K killroy2
                                        Aktuelle Testversion v0.7.3-alpha.1
                                        Stabile Version: 0.6.3
                                        Erstveröffentlichungsdatum 16.12.2021
                                        Github Link https://github.com/iobroker-community-adapters/ioBroker.openknx/
                                        NPM Link https://www.npmjs.com/package/iobroker.openknx
                                        Issues Board in GitHub https://github.com/iobroker-community-adapters/ioBroker.openknx/issues
                                        Installation der Testversion
                                        "Adapter", "Expertenmodus", "Octocat", "Benutzerdefiniert" und diesen Link:
                                        https://github.com/iobroker-community-adapters/ioBroker.openknx.git
                                        Adapter Beschreibung, Changelog etc.
                                        Hier ist die erste öffentliche Testversion des Open KNX Adapters. Der Adapter kommuniziert über ein IP Interface mit dem KNX Bus. Verschiedene KNX Telegrammtypen (GroupValue_Read, GroupValue_Write, GroupValue_Response) in Sende- und Empfangsrichtung werden in, dem IOB Anwender vertrauten Interaktionen mit IoBroker Objekten übersetzt.
                                        Motivation
                                        Ich habe den Adapter aus einer Not heraus erstellt, da der verfügbare Adapter nicht fehlerfrei lief und nicht kompatibel zu meinen IP Interfaces ist. Debuggen war aufgrund Closed Source nicht möglich. Da Adapter läuft so gut, dass ich ihn der Öffentlichkeit übergeben möchte.
                                        Der Adapter ist Quelloffen, Code kann gerne von Jedermann inspiziert und Pull Requests eingestellt werden.
                                        Eine Beschreibung des Adapters und dessen Verwendung ist auf den verlinkten Seiten zu finden.
                                        Ziel
                                        Der Adapter soll:
                                        • Stabil laufen und sich Standardkonform verhalten
                                        • möglich einfach und verständlich sein
                                        Thema umgesetzt ab Version Erwartung
                                        Release 0.1.x Release im stable repository
                                        Installation 0.1.6 Adapter lässt sich fehlerfrei über NPM installieren
                                        Installation 0.1.9 Adapter lässt sich über IOB Bordmittel installieren
                                        Betrieb 0.1.6 Adapter zeigt den Betriebszustand (rot,gelb,grün) korrekt an, bei Verbindungsabbrucht wird der Adapter gelb, keine Warnungen im Log die nicht zum Zustand passen
                                        Betrieb 0.1.8 keine Warnungen im Log die nicht zum Zustand passen
                                        Übersetzung 0.1.8 Admin Dialoge in alle Sprachen übersetzt, Logs nicht
                                        Alias 0.1.11 Generierung von Alias zur Zusammenbringen von Status und Ausgabe-GA zu einem Objekt eingebaut, noch nicht fehlerfrei
                                        Ich erhoffe mir Feedback zB zu
                                        • Bugs, Error Logs;
                                        • Verständlichkeit und Vollständigkeit der Doku
                                        • Verwendbarkeit des Adapters, sind die Features brauchbar, was fehlt essentielles
                                        • Code Reviews
                                        • Erfahrungen aus dem Betrieb
                                        • Ideen zur Geschäftslogik, zB werden aktuell Szenen DPTs von der Autoread Abfrage bei Start ausgeschlossen; gibt es bessere Filter?
                                        • Verbesserungsvorschläge am Interface, z.B. welche State roles eignen sich für welche DPTs, sind die Datentypen passend gewählt, ...
                                        Feature Anfragen, Fehlermeldungen dürfen gerne in GitHub erstellt werden. Umsetzung erfolgt immer nach Beschlusslage.
                                        killroy2
                                        schrieb am zuletzt editiert von killroy2
                                        #318
                                        Version 0.2.3 ist released und wartet mit ein paar wesentlichen Änderungen:
                                        -Wert setzen auf ein iob objekt wird mit ack quittiert sofern jemand auf dem KNX Bus empfang bestätigt
                                        unbestätigtes Schreiben erzeugt einen Logeintrag
                                        und frühere Dialog um das Verhalten zu simulieren sind jetzt entfernt
                                        -Dialog für physical KNX Adresse vom Gateway entfernt, das GW kennt seine Adresse selbst
                                        • K killroy2
                                          Tontechniker
                                          #319
                                          @killroy2 Habe versucht von 0.2.3 auf 0.2.4 ein Update zu machen. Update laüft ohne Fehlermeldung durch, Versionsnummer wird aber in "Adapter" nicht aktualisiert.
                                          In "Instanzen" steht in der obersten Zeile "Instanzeinstellungen: openknx.0 v0.2.3" obwohl ich ohne Fehlermeldung ("Process exited with code 0") die 0.2.4 installiert habe.
