  4. Sonoff NSPanel
Sonoff NSPanel
1.5k Beiträge 78 Kommentatoren 1.2m Aufrufe 80 Beobachtet
  • H holgerwolf
    @mikewolf Hast du den MQTT Explorer laufen?
    Dann setze mal unter CustomSend z Bsp den Topic "time, 10:32" ab.
    MikewolfM
    MikewolfM
    Mikewolf
    #224
    @holgerwolf said in Sonoff NSPanel:
    "time, 10:32"
    hallo habe mit Mqtt Explorer gesendet
    10:41:56.641 MQT: panel1/STATE = {"Time":"2022-04-14T10:41:56","Uptime":"0T00:15:10","UptimeSec":910,"Heap":168,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":14,"Objects":220},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"UbiNes1","BSSId":"E0:63:DA:BA:48:54","Channel":13,"Mode":"11n","RSSI":86,"Signal":-57,"LinkCount":1,"Downtime":"0T00:00:04"}}
    10:41:56.675 MQT: panel1/SENSOR = {"Time":"2022-04-14T10:41:56","ANALOG":{"Temperature1":27.5},"ESP32":{"Temperature":51.7},"TempUnit":"C"}
    10:42:00.422 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
    10:42:06.319 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
    10:42:08.464 MQT: panel1/RESULT = {"Command":"Unknown"}
    10:42:11.666 MQT: panel1/RESULT = {"Command":"Unknown"}
    10:42:12.317 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
    10:42:17.115 MQT: panel1/RESULT = {"Command":"Unknown"}
    10:42:18.217 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
    10:42:21.131 MQT: panel1/RESULT = {"CustomSend":"Done"}
    10:42:24.116 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
    10:42:25.332 MQT: panel1/RESULT = {"CustomSend":"Done"}
    10:42:28.830 MQT: panel1/RESULT = {"CustomSend":"Done"}
    10:42:30.122 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
    10:42:36.030 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
    10:42:41.919 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
    mein Panel heißt panel1
    habe alle namen auch in Mqtt und Tasmota auf panel1 gesetzt um irrtümer zu vermeiden
    Homematic (ca450 Rf komponenten), FS20,Alexas,Sonoff,ESP,Arduino,Lightly,Milight,NEEO,Harmony,Synology,HP-Gen8
    RF-link,Dreamboxen,Raspi,Cubie,Odroid,Fritz,Xiaomi-Vaccum,
    H ArmilarA 2 Antworten Letzte Antwort
    • MikewolfM Mikewolf
      "time, 10:32"
      H
      H
      holgerwolf
      #225
      @mikewolf Also das muss im MQTT Explorer so aussehen:
      Und dann unter "CustomSend" mal einen beliebigen time Befehl abgeben.
      Der sollte in der Tasmota Console dann auch auftauchen.
      MikewolfM H 2 Antworten Letzte Antwort
      • H holgerwolf
        MikewolfM
        MikewolfM
        Mikewolf
        schrieb am zuletzt editiert von Mikewolf
        #226
        @holgerwolf
        Danke das Du mir hilfst !
        Wenn ich mit Mqtt explorer Befehls absetze kommt in Tasmota console
        11:57:51.154 MQT: panel1/RESULT = {"CustomSend":"Done"}
        Display weiterhin waiting for content...
        und kenne mich leider mit scipt nicht wirklich aus , bin eher HW fest
        H R ArmilarA britzelpufB 4 Antworten Letzte Antwort
          @holgerwolf
          H
          H
          holgerwolf
          #227
          @mikewolf Das war leider nur ein erfolgloser Versuch, weil ich auch die Problem nach dem Neustart des iobroker mqtt Adapters hab und die Kommunikation einen "Anschubser" über den Explorer braucht.
          Jetzt bin ich mit meiner Weisheit dann auch am Ende. Veilleicht hat @Armilar noch ne Idee...
          H 1 Antwort Letzte Antwort
            @holgerwolf
            R
            R
            ronny130286
            #228
            @mikewolf
            Du hast aber auch alles genau so gemacht wie es @Armilar hier
            @armilar said in Sonoff NSPanel:
            @armilar sagte in Sonoff NSPanel:
            @mikewolf sagte in Sonoff NSPanel:
            Hallo wenn ich ts script starte kommt
            Javascript.0 (1002) script.js.HPCLTEST.Skript_3NS: TypeScript compilation failed: var Icons = new IconsSelector(); ^ ERROR: Cannot find name 'IconsSelector'.
            Gibts eine step by step anleitung ?? probiere seit über einer Woche das zum laufen zu bekommen,
            und dieser Thread ist etwas unübersichtlich geworden ..Speziell für nen neuanfang !
            Mit freundlichen Grüßen
            mikewolf
            Ich versuche es mal:
            • Tasmota flashen (analog Anleitung @haus-automatisierung) Die ist schon echt super erklärt! - Vielleicht macht er ja hierzu auch ein Video ;-)
            • autoexec.be in Tasmota Konsole/Verwalte Dateisystem anlegen
            • Nachfolgenden Befehl in Tasmota-Konsole ausführen
            Backlog UpdateDriverVersion https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be; Restart 1
            • NSPanel TFT Flashen mit (aktuelle Version 2.0.7):
            FlashNextion http://nspanel.pky.eu/lui-release.tft
            Das NSPanel kurz rebooten - kann nicht schaden - Danach wartet es auf Infos von ioBroker
            • TypeScript unter ioBroker/Skripte anlegen analog Britzelpuf auf Github https://github.com/joBr99/nspanel-lovelace-ui/tree/main/ioBroker Inhalt aus der NsPanelTs.ts übernehmen oder mein Script verwenden:
            (@britzelpuf hat eine Anpassung auf das letzte Release 1.9.1 auf 2.0.7 von @joBr99 gemacht. Daher dringend das neueste TS-Script verwenden, sonst läuft es nicht)
            const Months = ["Januar", "Februar", "März", "April", "Mai", "Juni", "Juli", "August", "September", "Oktober", "November", "Dezember"];
            const Days = ["Sonntag", "Montag", "Dienstag", "Mittwoch", "Donnerstag", "Freitag", "Samstag"];
            const Red: RGB = { red: 255, green: 0, blue: 0 };
            const White: RGB = { red: 255, green: 255, blue: 255 };
            const Off: RGB = { red: 68, green: 115, blue: 158 };
            const On: RGB = { red: 253, green: 216, blue: 53 };
            const BatteryFull: RGB = { red: 96, green: 176, blue: 62 }
            const BatteryEmpty: RGB = { red: 179, green: 45, blue: 25 }
            //----Möglichkeit, im Screensaver zwischen Accu-Weather Forcast oder selbstdefinierten Werten zu wählen---------------------------------
            var weatherForecast = true; //true = WheatherForecast 5 Days --- false = Config --> firstScreensaverEntity - fourthScreensaverEntity ...
            //Spotify Instanz
            var spotifyInstanz = "spotify-premium.0"
            var Buero_Seite_1: PageEntities =
                "type": "cardEntities",
                "heading": "Büro",
                "useColor": true,
                "items": [
                    <PageItem>{ id: "alias.0.NSPanel_1.Schreibtischlampe"},
                    <PageItem>{ id: "alias.0.NSPanel_1.Deckenbeleuchtung"},
                    <PageItem>{ id: "alias.0.NSPanel_1.MyTestbutton", icon: "lightbulb", offColor: Off, onColor: On, name: "Taster"},
                    <PageItem>{ id: "alias.0.NSPanel_1.Luftreiniger", icon: "power" }
            var Buero_Seite_2: PageGrid =
                "type": "cardGrid",
                "heading": "Büro",
                "useColor": true,
                "items": [
                    <PageItem>{ id: "alias.0.NSPanel_1.Schreibtischlampe", name: "Schreibtisch"},
                    <PageItem>{ id: "alias.0.NSPanel_1.Deckenbeleuchtung", name: "Deckenlampe"},
                    <PageItem>{ id: "alias.0.NSPanel_1.Testlampe2"},
                    <PageItem>{ id: "alias.0.NSPanel_1.Luftreiniger", icon: "power"},
                    <PageItem>{ id: "alias.0.NSPanel_1.Radio.TuneIn", icon: "play"}
            var Spotify: PageMedia =
                "type": "cardMedia",
                "heading": "Spotify",
                "useColor": false,
                "items": [<PageItem>{ id: "alias.0.NSPanel_1.Spotify" }]
            var Buero_Themostat: PageThermo =
                "type": "cardThermo",
                "heading": "Thermostat",
                "useColor": true,
                "items": [<PageItem>{ id: "alias.0.NSPanel_1.Thermostat_Büro" }]
            var Buero_Alarm: PageAlarm =
                "type": "cardAlarm",
                "heading": "Alarm",
                "useColor": true,
                "items": [<PageItem>{ id: "alias.0.NSPanel_1.Alarm" }]
            var button1Page: PageGrid =
                "type": "cardGrid",
                "heading": "Radio",
                "useColor": true,
                "items": [
                    <PageItem>{ id: "alias.0.Radio.NJoy" },
                    <PageItem>{ id: "alias.0.Radio.Delta_Radio" },
                    <PageItem>{ id: "alias.0.Radio.NDR2" },
            var button2Page: PageEntities =
                "heading": "Knopf2",
                "useColor": true,
                "items": [
                    <PageItem>{ id: "alias.0.Schlafen" },
                    <PageItem>{ id: "alias.0.Stern" }
            export const config: Config = {
                panelRecvTopic: "mqtt.0.SmartHome.NSPanel_1.tele.RESULT",       //anpassen
                panelSendTopic: "mqtt.0.SmartHome.NSPanel_1.cmnd.CustomSend",   //anpassen
                firstScreensaverEntity: { ScreensaverEntity: "hmip.0.devices.3014F711A000185BE9922BCF.channels.1.humidity", ScreensaverEntityIcon: "water-percent", ScreensaverEntityText: "Luft", ScreensaverEntityUnitText: "%" },
                secondScreensaverEntity: { ScreensaverEntity: "accuweather.0.Daily.Day1.Day.PrecipitationProbability", ScreensaverEntityIcon: "weather-pouring", ScreensaverEntityText: "Regen", ScreensaverEntityUnitText: "%" },
                thirdScreensaverEntity: { ScreensaverEntity: "0_userdata.0.Wetter.Windstaerke_homaticIP", ScreensaverEntityIcon: "weather-windy", ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: "bft" },
                fourthScreensaverEntity: { ScreensaverEntity: "accuweather.0.Current.UVIndex", ScreensaverEntityIcon: "solar-power", ScreensaverEntityText: "UV", ScreensaverEntityUnitText: "" },
                timeoutScreensaver: 15,
                dimmode: 8,
                screenSaverDoubleClick: false,
                locale: "de_DE",
                timeFormat: "%H:%M",
                dateFormat: "%A, %d. %B %Y",
                weatherEntity: "alias.0.Wetter.Wetter",
                defaultOffColor: Off,
                defaultOnColor: On,
                defaultColor: Off,
                temperatureUnit: "°C",
                pages: [Buero_Seite_1,
                        Buero_Seite_2,
                        Spotify,
                        Buero_Themostat,
                        Buero_Alarm
                button1Page: button1Page,
                button2Page: button2Page
            // _________________________________ Ab hier keine Konfiguration mehr _____________________________________
            var subscriptions: any = {};
            var screensaverEnabled : boolean = false;
            var pageId = 0;
            schedule("* * * * *", function () {
                SendTime();
            schedule("0 * * * *", function () {
                SendDate();
            // Only monitor the extra nodes if present
            var updateArray: string[] = [];
            if (config.firstScreensaverEntity !== null && config.firstScreensaverEntity.ScreensaverEntity != null && existsState(config.firstScreensaverEntity.ScreensaverEntity)) {
                updateArray.push(config.firstScreensaverEntity.ScreensaverEntity)
            if (config.secondScreensaverEntity !== null && config.secondScreensaverEntity.ScreensaverEntity != null && existsState(config.secondScreensaverEntity.ScreensaverEntity)) {
                updateArray.push(config.secondScreensaverEntity.ScreensaverEntity)
            if (config.thirdScreensaverEntity !== null && config.thirdScreensaverEntity.ScreensaverEntity != null && existsState(config.thirdScreensaverEntity.ScreensaverEntity)) {
                updateArray.push(config.thirdScreensaverEntity.ScreensaverEntity)
            if (config.fourthScreensaverEntity !== null && config.fourthScreensaverEntity.ScreensaverEntity != null && existsState(config.fourthScreensaverEntity.ScreensaverEntity)) {
                updateArray.push(config.fourthScreensaverEntity.ScreensaverEntity)
            if (updateArray.length > 0) {
                on(updateArray, function () {
                    HandleScreensaverUpdate();
            on({ id: config.panelRecvTopic }, function (obj) {
                if (obj.state.val.startsWith('\{"CustomRecv":')) {
                    var json = JSON.parse(obj.state.val);
                    var split = json.CustomRecv.split(",");
                    HandleMessage(split[0], split[1], parseInt(split[2]), split);
            function SendToPanel(val: Payload | Payload[]): void {
                if (Array.isArray(val)) {
                    val.forEach(function (id, i) {
                        setState(config.panelSendTopic, id.payload);
                else
                    setState(config.panelSendTopic, val.payload);
            function HandleMessage(typ: string, method: string, page: number, words: Array<string>): void {
                if (typ == "event") {
                    switch (method) {
                        case "startup":
                            screensaverEnabled = false;
                            UnsubscribeWatcher();
                            HandleStartupProcess();
                            pageId = 0;
                            GeneratePage(config.pages[0]);
                            break;
                        case "sleepReached":
                            screensaverEnabled = true;
                            HandleScreensaver();
                            break;
                        case "pageOpenDetail":
                            let pageItem = config.pages[pageId].items.find(e => e.id === words[3]);
                            if (pageItem !== undefined)
                                SendToPanel(GenerateDetailPage(words[2], pageItem));
                        case "buttonPress2":
                            HandleButtonEvent(words);
                            break;
                        case "button1":
                        case "button2":
                            HandleHardwareButton(method);
                        default:
                            break;
            function GeneratePage(page: Page): void {
                switch (page.type) {
                    case "cardEntities":
                        SendToPanel(GenerateEntitiesPage(<PageEntities>page));
                        break;
                    case "cardThermo":
                        SendToPanel(GenerateThermoPage(<PageThermo>page));
                        break;
                    case "cardGrid":
                        SendToPanel(GenerateGridPage(<PageGrid>page));
                        break;
                    case "cardMedia":
                        SendToPanel(GenerateMediaPage(<PageMedia>page));
                        break;
                    case "cardAlarm":
                        SendToPanel(GenerateAlarmPage(<PageAlarm>page));
                        break;
            function HandleHardwareButton(method: string): void {
                let page: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid);
                if (config.button1Page !== null && method == "button1") {
                    page = config.button1Page;
                else if (config.button2Page !== null && method == "button2") {
                    page = config.button2Page;
                else {
                    return;
                // Set pageId to -1, because of the navigation arrows
                let tempPageId = pageId;
                pageId = -1;
                GeneratePage(page);
                pageId = tempPageId;
            function HandleStartupProcess(): void {
                SendDate();
                SendTime();
                SendToPanel({ payload: "timeout~" + config.timeoutScreensaver });
                SendToPanel({ payload: "dimmode~" + config.dimmode });
            function SendDate(): void {
                var d = new Date();
                var day = Days[d.getDay()];
                var date = d.getDate();
                var month = Months[d.getMonth()];
                var year = d.getFullYear();
                var _sendDate = "date~" + day + " " + date + " " + month + " " + year;
                SendToPanel(<Payload>{ payload: _sendDate });
            function SendTime(): void {
                var d = new Date();
                var hr = d.getHours().toString();
                var min = d.getMinutes().toString();
                if (d.getHours() < 10) {
                    hr = "0" + d.getHours().toString();
                if (d.getMinutes() < 10) {
                    min = "0" + d.getMinutes().toString();
                SendToPanel(<Payload>{ payload: "time~" + hr + ":" + min });
            function GenerateEntitiesPage(page: PageEntities): Payload[] {
                var out_msgs: Array<Payload> = [];
                out_msgs = [{ payload: "pageType~cardEntities" }]
                out_msgs.push({ payload: GeneratePageElements(page) });
                return out_msgs
            function GenerateGridPage(page: PageGrid): Payload[] {
                out_msgs = [{ payload: "pageType~cardGrid" }]
                return out_msgs
            function GeneratePageElements(page: Page): string {
                let maxItems = 0;
                    case "cardThermo":
                        maxItems = 1;
                        break;
                    case "cardAlarm":
                        maxItems = 1;
                        break;
                    case "cardMedia":
                        maxItems = 1;
                        break;
                        maxItems = 4;
                        break;
                    case "cardGrid":
                        maxItems = 6;
                        break;
                let pageData = "entityUpd~" + page.heading + "~" + GetNavigationString(pageId)
                for (let index = 0; index < maxItems; index++) {
                    if (page.items[index] !== undefined) {
                        pageData += CreateEntity(page.items[index], index + 1, page.useColor);
                    else {
                        pageData += CreateEntity(<PageItem>{ id: "delete" }, index + 1);
                return pageData;
            function CreateEntity(pageItem: PageItem, placeId: number, useColors: boolean = false): string {
                var iconId = "0"
                if (pageItem.id == "delete") {
                    return "~delete~~~~~"
                var name: string;
                var type: string;
                // ioBroker
                if (existsObject(pageItem.id)) {
                    let o = getObject(pageItem.id)
                    var val = null;
                    name = pageItem.name !== undefined ? pageItem.name : o.common.name.de
                    if (existsState(pageItem.id + ".GET")) {
                        val = getState(pageItem.id + ".GET").val;
                        RegisterEntityWatcher(pageItem.id + ".GET");
                    else if (existsState(pageItem.id + ".SET")) {
                        val = getState(pageItem.id + ".SET").val;
                        RegisterEntityWatcher(pageItem.id + ".SET");
                    var iconColor = rgb_dec565(config.defaultColor);
                    switch (o.common.role) {
                        case "light":
                            type = "light"
                            iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("lightbulb");
                            var optVal = "0"
                            if (val === true || val === "true") {
                                optVal = "1"
                                iconColor = GetIconColor(pageItem, true, useColors);
                            return "~" + type + "~" + pageItem.id + "~" + iconId + "~" + iconColor + "~" + name + "~" + optVal;
                        case "dimmer":
                            type = "light"
                            var optVal = "0"
                            if (existsState(pageItem.id + ".ON_ACTUAL")) {
                                val = getState(pageItem.id + ".ON_ACTUAL").val;
                                RegisterEntityWatcher(pageItem.id + ".ON_ACTUAL");
                            else if (existsState(pageItem.id + ".ON_SET")) {
                                val = getState(pageItem.id + ".ON_SET").val;
                                RegisterEntityWatcher(pageItem.id + ".ON_SET");
                                optVal = "1"
                                iconColor = GetIconColor(pageItem, existsState(pageItem.id + ".ACTUAL") ? getState(pageItem.id + ".ACTUAL").val : true, useColors);
                        case "blind":
                            type = "shutter"
                            iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("window-open");
                        case "info":
                        case "value.temperature":
                        case "thermostat":
                            type = "text";
                            iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : o.common.role == "value.temperature" || o.common.role == "thermostat" ? Icons.GetIcon("thermometer") : Icons.GetIcon("information-outline");
                            let unit = "";
                            var optVal = "0"
                                optVal = getState(pageItem.id + ".ON_ACTUAL").val;
                                unit = GetUnitOfMeasurement(pageItem.id + ".ON_ACTUAL");
                            else if (existsState(pageItem.id + ".ACTUAL")) {
                                optVal = getState(pageItem.id + ".ACTUAL").val;
                                unit = GetUnitOfMeasurement(pageItem.id + ".ACTUAL");
                                RegisterEntityWatcher(pageItem.id + ".ACTUAL");
                            if (o.common.role == "value.temperature") {
                                iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("thermometer");
                            iconColor = GetIconColor(pageItem, parseInt(optVal), useColors);
                            return "~" + type + "~" + pageItem.id + "~" + iconId + "~" + iconColor + "~" + name + "~" + optVal + " " + unit;
                        case "button":
                            type = "button";
                            iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("gesture-tap-button");
                            let buttonText = pageItem.name !== undefined ? pageItem.name : "PRESS";
                            return "~" + type + "~" + pageItem.id + "~" + iconId + "~" + + iconColor + "~" + name + "~" + buttonText;
                        default:
                            return "~delete~~~~~";
            function GetIconColor(pageItem: PageItem, value: (boolean | number), useColors: boolean): number {
                // dimmer
                if ((pageItem.useColor || useColors) && pageItem.interpolateColor && typeof (value) === "number") {
                    let maxValue = pageItem.maxValue !== undefined ? pageItem.maxValue : 100;
                    let minValue = pageItem.minValue !== undefined ? pageItem.minValue : 0;
                    value = value > maxValue ? maxValue : value;
                    value = value < minValue ? minValue : value;
                    return rgb_dec565(
                        Interpolate(
                            pageItem.offColor !== undefined ? pageItem.offColor : config.defaultOffColor,
                            pageItem.onColor !== undefined ? pageItem.onColor : config.defaultOnColor,
                            scale(value, minValue, maxValue, 0, 1)
                if ((pageItem.useColor || useColors) && ((typeof (value) === "boolean" && value) || value > (pageItem.minValue !== undefined ? pageItem.minValue : 0))) {
                    return rgb_dec565(pageItem.onColor !== undefined ? pageItem.onColor : config.defaultOnColor)
                return rgb_dec565(pageItem.offColor !== undefined ? pageItem.offColor : config.defaultOffColor);
            function RegisterEntityWatcher(id: string): void {
                if (subscriptions.hasOwnProperty(id)) {
                    return;
                subscriptions[id] = (on({ id: id, change: 'any' }, function (data) {
                    SendToPanel({ payload: GeneratePageElements(config.pages[pageId]) });
            function RegisterDetailEntityWatcher(id: string, pageItem: PageItem, type: string): void {
                    return;
                subscriptions[id] = (on({ id: id, change: 'any' }, function () {
                    SendToPanel(GenerateDetailPage(type, pageItem));
            function GetUnitOfMeasurement(id: string): string {
                if (!existsObject(id))
                    return "";
                let obj = getObject(id);
                if (typeof obj.common.unit !== 'undefined') {
                    return obj.common.unit
                if (typeof obj.common.alias !== 'undefined' && typeof obj.common.alias.id !== 'undefined') {
                    return GetUnitOfMeasurement(obj.common.alias.id);
                return "";
            function GenerateThermoPage(page: PageThermo): Payload[] {
                var id = page.items[0].id
                out_msgs.push({ payload: "pageType~cardThermo" });
                // ioBroker
                if (existsObject(id)) {
                    let o = getObject(id)
                    let name = page.items[0].name !== undefined ? page.items[0].name : o.common.name.de
                    let currentTemp = 0;
                    if (existsState(id + ".ACTUAL"))
                        currentTemp = (Math.round(parseFloat(getState(id + ".ACTUAL").val) * 10)/10)*10;
                    let destTemp = 0;
                    if (existsState(id + ".SET")) {
                        destTemp = getState(id + ".SET").val.toFixed(2) * 10;
                        log(id + ".SET " + destTemp)
                    let status = ""
                    if (existsState(id + ".MODE"))
                        status = getState(id + ".MODE").val;
                    let minTemp = 50 //Min Temp 5°C
                    let maxTemp = 300 //Max Temp 30°C
                    let stepTemp = 5
                    //0-4 verwendet bei ungerader Anzahl Parametern
                    let bt0 = "~~~~"; //verwendet bei ungleichen Parametern
                    let bt1 = "~~~~"; //verwendet bei ungleichen Parametern
                    let bt2 = "~~~~"; //verwendet bei ungleichen Parametern
                    let bt3 = "~~~~"; //verwendet bei ungleichen Parametern
                    let bt4 = "~~~~"; //verwendet bei ungleichen Parametern
                    //5-8 verwendet bei gerader Anzahl Parametern
                    let bt5 = Icons.GetIcon("water-percent") + "~0~1~~";
                    let bt6 = Icons.GetIcon("fire") + "~0~1~~";
                    let bt7 = Icons.GetIcon("wifi") + "~0~1~~";
                    let bt8 = Icons.GetIcon("battery-high") + "~0~1~~";
                    if (existsState(id + ".HUMIDITY")){
                        console.log(parseInt(getState(id + ".HUMIDITY").val));
                        bt5 =  Icons.GetIcon("water-percent") + "~2016~1~bt8~";
                        if (parseInt(getState(id + ".HUMIDITY").val) < 40) {
                            bt5 =  Icons.GetIcon("water-percent") + "~65504~1~bt8~";
                        } else if (parseInt(getState(id + ".HUMIDITY").val) < 30) {
                            bt5 =  Icons.GetIcon("water-percent") + "~63488~1~bt8~";
                        } else if (parseInt(getState(id + ".HUMIDITY").val) > 65) {
                        } else if (parseInt(getState(id + ".HUMIDITY").val) > 75) {
                    if (existsState(id + ".MAINTAIN")){
                        if (getState(id + ".MAINTAIN").val >> .1) {
                            bt6 =  Icons.GetIcon("fire") + "~60897~1~bt8~";
                        } else {
                            bt6 =  Icons.GetIcon("fire") + "~33840~0~bt8~";
                    if (existsState(id + ".UNREACH")){
                        if (getState(id + ".UNREACH").val) {
                            bt7 =  Icons.GetIcon("wifi-off") + "~63488~1~bt8~";
                        } else {
                            bt7 =  Icons.GetIcon("wifi") + "~2016~1~bt8~";
                    if (existsState(id + ".LOWBAT")){
                        if (getState(id + ".LOWBAT").val) {
                            bt8 =  Icons.GetIcon("battery-low") + "~63488~1~bt8~";
                        } else {
                            bt8 =  Icons.GetIcon("battery-high") + "~2016~1~bt8~";
                    let icon_res = bt0 + bt1 + bt2 + bt3 + bt4 + bt5 + bt6 + bt7 + bt8;
                    out_msgs.push({ payload: "entityUpd~" + name + "~" + GetNavigationString(pageId) + "~" + id + "~" + currentTemp + "~" + destTemp + "~" + status + "~" + minTemp + "~" + maxTemp + "~" + stepTemp + "~" +icon_res})
                return out_msgs
            function GenerateMediaPage(page: PageMedia): Payload[] {
                out_msgs.push({ payload: "pageType~cardMedia" });
                    let o = getObject(id);
                    //let name = o.common.name.de;
                    let name = getState(spotifyInstanz + ".player.contextDescription").val;
                    let media_icon = Icons.GetIcon("spotify");
                    let title = getState(spotifyInstanz + ".player.trackName").val;
                    let author = getState(spotifyInstanz + ".player.artistName").val
                    let volume = getState(spotifyInstanz + ".player.volume").val;
                    var iconplaypause = Icons.GetIcon("pause"); //pause
                    if (getState(spotifyInstanz + ".player.isPlaying").val) {
                    } else {
                        iconplaypause = Icons.GetIcon("play"); //play
                    let currentSpeaker = getState(spotifyInstanz + ".player.device.name").val
                    let speakerlist = getState(spotifyInstanz + ".devices.deviceListString").val.replace(/;/g,"?");
                    let onoffbutton = 1;
                                              name + "~" +
                                              id + "~" +
                                              media_icon + "~" +
                                              title + "~" +
                                              author + "~" +
                                              volume + "~" +
                                              iconplaypause + "~" +
                                              currentSpeaker + "~" +
                                              speakerlist + "~" +
                                              onoffbutton});
                return out_msgs
            function GenerateAlarmPage(page: PageAlarm): Payload[] {
                out_msgs.push({ payload: "pageType~cardAlarm" });
                var armed: boolean = false;
                if (armed) {
                    var arm1 = "Deaktivieren";                  //arm1*~*
                    var arm1ActionName = "D1";                  //arm1ActionName*~*
                    var arm2 = "";                              //arm2*~*
                    var arm2ActionName = "";                    //arm2ActionName*~*
                    var arm3 = "";                              //arm3*~*
                    var arm3ActionName = "";                    //arm3ActionName*~*
                    var arm4 = "";                              //arm4*~*
                    var arm4ActionName = "";                    //arm4ActionName*~*
                    var icon = Icons.GetIcon("shield-home");    //icon*~*
                    var iconcolor = 63488;                      //iconcolor*~*
                    var numpadStatus = 1;                       //numpadStatus*~*
                    var flashing = 1;                           //flashing*
                else {
                    var arm1 = "Alarm 1";                       //arm1*~*
                    var arm1ActionName = "A1";                  //arm1ActionName*~*
                    var arm2 = "Alarm 2";                       //arm2*~*
                    var arm2ActionName = "A2";                  //arm2ActionName*~*
                    var arm3 = "Alarm 3";                       //arm3*~*
                    var arm3ActionName = "A3";                  //arm3ActionName*~*
                    var arm4 = "Alarm 4";                       //arm4*~*
                    var arm4ActionName = "A4";                  //arm4ActionName*~*
                    var icon = Icons.GetIcon("shield-off");     //icon*~*
                    var iconcolor = 2016;                       //iconcolor*~*
                out_msgs.push({ payload:    "entityUpd~" +             //entityUpd~*
                                            id + "~" +                 //internalNameEntity*~* //navigation*~*
                                            arm1 + "~" +               //arm1*~*
                                            arm1ActionName + "~" +     //arm1ActionName*~*
                                            arm2 + "~" +               //arm2*~*
                                            arm2ActionName + "~" +     //arm2ActionName*~*
                                            arm3 + "~" +               //arm3*~*
                                            arm3ActionName + "~" +     //arm3ActionName*~*
                                            arm4 + "~" +               //arm4*~*
                                            arm4ActionName + "~" +     //arm4ActionName*~*
                                            icon + "~" +               //icon*~* 39=Disarmed 35=Shield_Home, 40
                                            iconcolor + "~" +          //iconcolor*~* 2016=green  63488=red
                                            numpadStatus + "~" +       //numpadStatus*~*
                                            flashing});                //flashing*
                return out_msgs
            function setIfExists(id: string, value: any, type: string | null = null): boolean {
                if (type === null) {
                    if (existsState(id)) {
                        setState(id, value);
                        return true;
                else {
                    if (existsState(id) && obj.common.type !== undefined && obj.common.type === type) {
                        return true;
                return false;
            function toggleState(id: string): boolean {
                if (existsState(id) && obj.common.type !== undefined && obj.common.type === "boolean") {
                    setState(id, !getState(id).val);
                    return true;
                return false;
            function HandleButtonEvent(words): void {
                let id = words[2]
                let buttonAction = words[3];
                switch (buttonAction) {
                    case "bNext":
                        var pageNum = ((pageId + 1) % config.pages.length);
                        pageId = Math.abs(pageNum);
                        GeneratePage(config.pages[pageId]);
                        break;
                    case "bPrev":
                        var pageNum = ((pageId - 1) % config.pages.length);
                        break;
                    case "bExit":
                        if (config.screenSaverDoubleClick) {
                            if (words[4] == 2)
                        else
                        break;
                    case "OnOff":
                            var action = false
                            if (words[4] == "1")
                                action = true
                                case "light":
                                    setIfExists(id + ".SET", action);
                                    break;
                                case "dimmer":
                                    setIfExists(id + ".ON_SET", action) ? true : setIfExists(id + ".ON_ACTUAL", action);
                        break;
                    case "up":
                        setIfExists(id + ".OPEN", true)
                        break;
                    case "stop":
                        setIfExists(id + ".STOP", true)
                        break;
                    case "down":
                        setIfExists(id + ".CLOSE", true)
                        break;
                    case "button":
                        toggleState(id + ".SET") ? true : toggleState(id + ".ON_SET")
                        break;
                    case "positionSlider":
                    case "brightnessSlider":
                        setIfExists(id + ".SET", parseInt(words[4])) ? true : setIfExists(id + ".ACTUAL", parseInt(words[4]));
                        break;
                    case "tempUpd":
                        setIfExists(id + ".SET", parseInt(words[4]) / 10)
                        break;
                    case "media-back":
                        setIfExists(spotifyInstanz + ".player.skipMinus", true)
                        break;
                    case "media-pause":
                        if (getState(spotifyInstanz + ".player.isPlaying").val === true) {
                            setIfExists(spotifyInstanz + ".player.pause", true)
                        } else {
                            setIfExists(spotifyInstanz + ".player.play", true)
                        break;
                    case "media-next":
                        setIfExists(spotifyInstanz + ".player.skipPlus", true)
                        break;
                    case "volumeSlider":
                        setIfExists(spotifyInstanz + ".player.volume", parseInt(words[4]))
                        break;
                    case "speaker-sel":
                        console.log("auf mediaCard - speaker-sel - Wert: " + words[4] + " - reagieren - noch nicht implementiert");
                        break;
                    case "A1": //Alarm-Page Alarm 1 aktivieren
                        console.log("auf mediaAlarm - Alarm 1 - Wert: " + words[4] + " - reagieren - noch nicht implementiert");
                        break;
                    case "A2": //Alarm-Page Alarm 2 aktivieren
                        break;
                    case "A3": //Alarm-Page Alarm 3 aktivieren
                        break;
                    case "A4": //Alarm-Page Alarm 4 aktivieren
                        break;
                    case "D1": //Alarm-Page Alarm Deaktivieren
                        break;
                    default:
                        break;
            function GetNavigationString(pageId: number): string {
                switch (pageId) {
                    case 0:
                        return "0|1";
                    case config.pages.length - 1:
                        return "1|0";
                    case -1:
                        return "0|0";
                    default:
                        return "1|1";
            function GenerateDetailPage(type: string, pageItem: PageItem): Payload[] {
                let id = pageItem.id
                    var o = getObject(id)
                    var val: (boolean | number) = 0;
                    let icon = Icons.GetIcon("lightbulb");
                    if (type == "popupLight") {
                        let switchVal = "0"
                        if (o.common.role == "light") {
                            if (existsState(id + ".GET")) {
                                val = getState(id + ".GET").val;
                                RegisterDetailEntityWatcher(id + ".GET", pageItem, type);
                            else if (existsState(id + ".SET")) {
                                val = getState(id + ".SET").val;
                                RegisterDetailEntityWatcher(id + ".SET", pageItem, type);
                            if (val) {
                                switchVal = "1";
                                iconColor = GetIconColor(pageItem, true, false);
                            out_msgs.push({ payload: "entityUpdateDetail~" + icon + "~" + + iconColor + "~" + switchVal + ",disable,disable,disable" })
                        if (o.common.role == "dimmer") {
                            if (existsState(id + ".ON_ACTUAL")) {
                                val = getState(id + ".ON_ACTUAL").val;
                                RegisterDetailEntityWatcher(id + ".ON_ACTUAL", pageItem, type);
                            else if (existsState(id + ".ON_SET")) {
                                val = getState(id + ".ON_SET").val;
                                RegisterDetailEntityWatcher(id + ".ON_SET", pageItem, type);
                            if (val === true) {
                                var iconColor = GetIconColor(pageItem, val, false);
                                switchVal = "1"
                            let brightness = 0;
                            if (existsState(id + ".ACTUAL")) {
                                brightness = Math.trunc(scale(getState(id + ".ACTUAL").val, 0, 100, 0, 100))
                                iconColor = GetIconColor(pageItem, brightness, false);
                                RegisterDetailEntityWatcher(id + ".ACTUAL", pageItem, type);
                            let colorTemp = "disable"
                            let colorMode = "disable"
                            //let attr_support_color = attr.supported_color_modes
                            //if (attr_support_color.includes("color_temp"))
                            // colortemp = Math.trunc(scale(attr.color_temp, attr.min_mireds, attr.max_mireds, 0, 100))
                            out_msgs.push({ payload: "entityUpdateDetail~" + icon + "~" + iconColor + "~" + switchVal + "~" + brightness + "~" + colorTemp + "~" + colorMode })
                    if (type == "popupShutter") {
                            val = getState(id + ".ACTUAL").val;
                        out_msgs.push({ payload: "entityUpdateDetail," + val })
                return out_msgs
            function scale(number: number, inMin: number, inMax: number, outMin: number, outMax: number): number {
                return (number - inMin) * (outMax - outMin) / (inMax - inMin) + outMin;
            function UnsubscribeWatcher(): void {
                for (const [key, value] of Object.entries(subscriptions)) {
                    unsubscribe(value);
                    delete subscriptions[key]
            function HandleScreensaver(): void {
                SendToPanel({ payload: "pageType~screensaver"})
            function HandleScreensaverUpdate(): void {
                if (screensaverEnabled && config.weatherEntity != null && existsObject(config.weatherEntity)) {
                    var icon = getState(config.weatherEntity + ".ICON").val;
                    let temperature: string =
                        existsState(config.weatherEntity + ".ACTUAL") ? getState(config.weatherEntity + ".ACTUAL").val :
                            existsState(config.weatherEntity + ".TEMP") ? getState(config.weatherEntity + ".TEMP").val : "null";
                    let payloadString =
                        "weatherUpdate~" + Icons.GetIcon(GetAccuWeatherIcon(parseInt(icon))) + "~"
                        + temperature + " " + config.temperatureUnit + "~"
                    if (weatherForecast == true) {
                        // Accu-Weather Forecast Tag 2 - Tag 5 -- Wenn weatherForecast = true
                        for (let i = 2; i < 6; i++) {
                            let TempMax = getState("accuweather.0.Summary.TempMax_d" + i).val;
                            let DayOfWeek = getState("accuweather.0.Summary.DayOfWeek_d" + i).val;
                            let WeatherIcon = GetAccuWeatherIcon(getState("accuweather.0.Summary.WeatherIcon_d" + i).val);
                            payloadString += DayOfWeek + "~" + Icons.GetIcon(WeatherIcon) + "~" + TempMax + " °C~";
                    else {
                        //In Config definierte Zustände wenn weatherForecast = false
                        payloadString += GetScreenSaverEntityString(config.firstScreensaverEntity);
                        payloadString += GetScreenSaverEntityString(config.secondScreensaverEntity);
                        payloadString += GetScreenSaverEntityString(config.thirdScreensaverEntity);
                        payloadString += GetScreenSaverEntityString(config.fourthScreensaverEntity);
                    SendToPanel(<Payload>{ payload: payloadString });
            function GetScreenSaverEntityString(configElement: ScreenSaverElement | null): string {
                if (configElement != null && configElement.ScreensaverEntity != null && existsState(configElement.ScreensaverEntity)) {
                    let u1 = getState(configElement.ScreensaverEntity).val;
                    return configElement.ScreensaverEntityText + "~" + Icons.GetIcon(configElement.ScreensaverEntityIcon) + "~" + u1 + " " + configElement.ScreensaverEntityUnitText + "~";
                else {
                    return "~~~";
            function GetAccuWeatherIcon(icon: number): string {
                switch (icon) {
                    case 24:        // Ice
                    case 30:        // Hot
                    case 31:        // Cold
                        return "window-open";  // exceptional
                    case 7:         // Cloudy
                    case 8:         // Dreary (Overcast)
                    case 38:        // Mostly Cloudy
                        return "weather-cloudy";  // cloudy
                    case 11:        // fog
                        return "weather-fog";  // fog
                    case 25:        // Sleet
                        return "weather-hail";  // Hail
                    case 15:        // T-Storms
                        return "weather-lightning";  // lightning
                    case 16:        // Mostly Cloudy w/ T-Storms
                    case 17:        // Partly Sunny w/ T-Storms
                    case 41:        // Partly Cloudy w/ T-Storms
                    case 42:        // Mostly Cloudy w/ T-Storms
                        return "weather-lightning-rainy";  // lightning-rainy
                    case 33:        // Clear
                    case 34:        // Mostly Clear
                    case 37:        // Hazy Moonlight
                        return "weather-night";
                    case 3:         // Partly Sunny
                    case 4:         // Intermittent Clouds
                    case 6:         // Mostly Cloudy
                    case 35: 	    // Partly Cloudy
                    case 36: 	    // Intermittent Clouds
                        return "weather-partly-cloudy";  // partlycloudy
                    case 18:        // pouring
                        return "weather-pouring";  // pouring
                    case 12:        // Showers
                    case 13:        // Mostly Cloudy w/ Showers
                    case 14:        // Partly Sunny w/ Showers
                    case 26:        // Freezing Rain
                    case 39:        // Partly Cloudy w/ Showers
                    case 40:        // Mostly Cloudy w/ Showers
                        return "weather-rainy";  // rainy
                    case 19:        // Flurries
                    case 20:        // Mostly Cloudy w/ Flurries
                    case 21:        // Partly Sunny w/ Flurries
                    case 22:        // Snow
                    case 23:        // Mostly Cloudy w/ Snow
                    case 43:        // Mostly Cloudy w/ Flurries
                    case 44:        // Mostly Cloudy w/ Snow
                        return "weather-snowy";  // snowy
                    case 29:        // Rain and Snow
                        return "weather-snowy-rainy";  // snowy-rainy
                    case 1:         // Sunny
                    case 2: 	    // Mostly Sunny
                    case 5:         // Hazy Sunshine
                        return "weather-sunny";  // sunny
                    case 32:        // windy
                        return "weather-windy";  // windy
                    default:
                        return "alert-circle-outline";
            function GetBlendedColor(percentage: number): RGB {
                if (percentage < 50)
                    return Interpolate(config.defaultOffColor, config.defaultOnColor, percentage / 50.0);
                return Interpolate(Red, White, (percentage - 50) / 50.0);
            function Interpolate(color1: RGB, color2: RGB, fraction: number): RGB {
                var r: number = InterpolateNum(color1.red, color2.red, fraction);
                var g: number = InterpolateNum(color1.green, color2.green, fraction);
                var b: number = InterpolateNum(color1.blue, color2.blue, fraction);
                return <RGB>{ red: Math.round(r), green: Math.round(g), blue: Math.round(b) };
            function InterpolateNum(d1: number, d2: number, fraction: number): number {
                return d1 + (d2 - d1) * fraction;
            function rgb_dec565(rgb: RGB): number {
                return ((Math.floor(rgb.red / 255 * 31) << 11) | (Math.floor(rgb.green / 255 * 63) << 5) | (Math.floor(rgb.blue / 255 * 31)));
            type RGB = {
                red: number,
                green: number,
                blue: number
            type Payload = {
                payload: string;
            type Page = {
                type: string,
                heading: string,
                items: PageItem[],
                useColor: boolean
            interface PageEntities extends Page {
                type: "cardEntities",
                items: PageItem[],
            interface PageGrid extends Page {
                type: "cardGrid",
                items: PageItem[],
            interface PageThermo extends Page {
                type: "cardThermo",
                items: PageItem[],
            interface PageMedia extends Page {
                type: "cardMedia",
                items: PageItem[],
            interface PageAlarm extends Page {
                type: "cardAlarm",
                items: PageItem[],
            type PageItem = {
                icon: (string | undefined),
                onColor: (RGB | undefined),
                offColor: (RGB | undefined),
                useColor: (boolean | undefined),
                interpolateColor: (boolean | undefined),
                minValue: (number | undefined),
                maxValue: (number | undefined),
                name: (string | undefined)
            type Config = {
                panelRecvTopic: string,
                panelSendTopic: string,
                timeoutScreensaver: number,
                dimmode: number,
                //brightnessScreensaver:
                locale: string,
                timeFormat: string,
                dateFormat: string,
                weatherEntity: string | null,
                screenSaverDoubleClick: boolean,
                temperatureUnit: string,
                firstScreensaverEntity: ScreenSaverElement | null,
                secondScreensaverEntity: ScreenSaverElement | null,
                thirdScreensaverEntity: ScreenSaverElement | null,
                fourthScreensaverEntity: ScreenSaverElement | null,
                defaultColor: RGB,
                defaultOnColor: RGB,
                defaultOffColor: RGB,
                pages: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid)[],
                button1Page: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid | null),
                button2Page: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid | null),
            type ScreenSaverElement = {
                ScreensaverEntity: string | null,
                ScreensaverEntityIcon: string | null,
                ScreensaverEntityText: string | null,
                ScreensaverEntityUnitText: string | null,
            • Unter ioBroker/Skripte weiteres Type-Script unter global !!!! (nicht common, etc) anlegen (Name: Blabla oder NSPanel_icon_mapping, etc)
            • Inhalt aus Datei icon_mapping.ts von Github https://github.com/joBr99/nspanel-lovelace-ui/tree/main/ioBroker (nicht wundern, wenn die etwas zerrissen aussieht - Fragezeichen, etc.) einfügen und speichern
            • Beide Skripte starten nicht vergessen
            Ab jetzt holt sich das Hauptscript (Inhalt der NsPanelTs.ts) die Icons aus der Mapping-Datei.
            Jetzt noch NSPanel-Parameter (ALIASE, MQTT-anpassen, Datenpunkte) anpassen oder weitere Seiten gestalten und einfügen
            Sollten weitere oder andere Icons gewünscht sein dann auf https://htmlpreview.github.io/?https://github.com/joBr99/nspanel-lovelace-ui/blob/main/HMI/icon-cheatsheet.html nachsehen und den Namen entsprechend an der Stelle des Icons im Script tauschen.
            Ich hoffe das hilft 👍
            beschrieben hat?
            Das "Waiting for Content" kommt meist wenn etwas mit dem Skript nicht stimmt. (Poste mal dein Script)
            • H holgerwolf
              H
              H
              holgerwolf
              #229
              @Mikewolf Oder schau auch mal, ob beim Ausführen des Scriptes irgendwelche Fehler im iobroker auftauchen. Da sind sind viele Beispiel Objekte drin, die alle ersetzt werden müssen.
                @holgerwolf
                ArmilarA
                ArmilarA
                Armilar
                Most Active Forum Testing
                #230
                @holgerwolf
                sieh mal nach, ob bei dir so ein Eintrag ist. Das wäre der Parameter unter Config im Script
                Dann mal den Haken bei
                rausnehmen.
                • ArmilarA Armilar
                  @holgerwolf
                  rausnehmen.
                  ArmilarA
                  ArmilarA
                  Armilar
                  #231
                  @holgerwolf
                  rausnehmen.
                  Sind MQTT-Adapter und Tasmota-MQTT auf dem selben Port?
                  Das sind die Datenpunkte im Script. Die müssen analog deiner Tasmota Prefix/Topics angepasst werden. Habe da bei dir etwas mit panel1 statt bei mir SmartHome.NSPanel_1 gelesen
                  Ansonsten brauchen wir mal kurz einen Screen vom ioBroker Script (am Besten mit Sicht auf die Config und MQTT panel1 unter Objekte...
                    "time, 10:32"
                    ArmilarA
                    ArmilarA
                    Armilar
                    #232
                    "time, 10:32"
                    Der Time Payload heißt jetzt: CustomSend time~15:42 (ohne Komma, aber mit Kringel als Delimiter)
                    Wenn du den in der Konsole absetzt, sollte sofort das Panel umspringen und zumindest die Zeit anzeigen
                    ich habe hinter prefix und topic noch tele, stat, etc. stehen, bevor /RESULT oder /STATE kommt. Vielleicht doch ein Fehler in der Tasmota MQTT-Einstellung????
                    Bei mir
                      @holgerwolf
                      britzelpufB
                      britzelpufB
                      britzelpuf
                      #233
                      @mikewolf
                      Ich vermute mal, dass du noch die alte Version des Skriptes verwendest.
                      Aktualisiere mal bitte die Version und packe die icon mapping ts ins global verzeichnis
                      Dann nur noch die Konfig anpassen und eigentlich sollte es dann gehen.
                      • britzelpufB britzelpuf
                        @mikewolf
                        ArmilarA
                        ArmilarA
                        Armilar
                        #234
                        @britzelpuf
                        Ich hatte heute im Übrigen auch den Fehler das er nicht in den Screensaver zurückgegangen ist. Habe mit den Hardware-Buttons gespielt und ein paar Radiosender eingebaut. Ich denke es passiert im Zusammenhang mit den Panel-Tasten. Eigensinnig ist auch das Verhalten, dass wenn ich einen Sender wähle springt er anschließend in die zuvor aktive Seite und zerreißt sie komplett
                        Beispiel:
                        dann Sender wählen und dann kommt
                        Dann springt das Panel wieder in den Screensaver und alles ist top
                        Die eigentliche cardGrid sieht aber so aus:
                        und die Frage ist: Warum springt er überhaupt auf die cardGrid? Hast du auch so ein Verhalten? Und das sin im Übrigen die Einträge aus der
                            "heading": "Büro",
                            "useColor": true,
                            "items": [
                        Der Taster existiert aktuell nicht als ALIAS - somit wäre also die cardEntities eigentlich richtiger als die cardGrid.
                        PS.: Der gewählte Sender wird aber analog ALIAS korrekt abgespielt ...
                        britzelpufB 1 Antwort Letzte Antwort
                        • ArmilarA Armilar
                          @britzelpuf
                          Beispiel:
                              "heading": "Büro",
                              "useColor": true,
                              "items": [
                          britzelpufB
                          britzelpufB
                          britzelpuf
                          #235
                          @armilar Wenn die Objekte nicht existieren, dann wird ein Delete geschickt.
                          https://github.com/joBr99/nspanel-lovelace-ui/blob/58da8efc0c70cb1ddf1f9a1b7d532b3187dce21f/ioBroker/NsPanelTs.ts#L376
                          Ich kann es gerade nicht debuggen, aber ich vermute, dass hier das Problem liegt.
                          https://github.com/joBr99/nspanel-lovelace-ui/blob/58da8efc0c70cb1ddf1f9a1b7d532b3187dce21f/ioBroker/NsPanelTs.ts#L411
                          Sobald sich ein Wert ändert schickt es nämlich ein Update und hat dabei die falsche PageId im Bauch. Die HW Buttons sind ja ohne eindeutige ID.
                          Ich könnte mir jetzt folgendes vorstellen, man deaktiviert für HW Buttons die Updateregel, finde ich doof weil eigentlich ist das ein tolles Feature.
                          Alternativ setzt man die pageId auf -1 für Button1 und -2 für Button2 und sobald der Screensaver kommt wieder auf 0. Dann kann man aber die Seite referenzieren.
                            ArmilarA
                            ArmilarA
                            Armilar
                            #236
                            @britzelpuf sagte in Sonoff NSPanel:
                            Ich finde Variante 2 definitv besser. Updateregel ausschalten würde ich auch nicht... mit -1 und mit -2 kann man leben...
                            • britzelpufB
                              britzelpufB
                              britzelpuf
                              #237
                              @armilar So ich habe das mit den HW Buttons mal angepasst. Kannst ja mal schauen ob das jetzt bei dir geht.
                              • R
                                R
                                ronny130286
                                schrieb am zuletzt editiert von ronny130286
                                #238
                                @britzelpuf
                                Ich habe es auch übernommen, aber ich glaube es muss noch an einer anderen Stelle auftreten, bis jetzt hatte ich die Hardwarebutton über die Rule nicht implementiert, da ich die Button hardwareseitig verwende und hatte das Problem ebenfalls.
                                  ArmilarA
                                  ArmilarA
                                  Armilar
                                  #239
                                  Moin Britzelpuf,
                                  Einwandfrei 👍 👍 👍
                                  Armilar
                                  • ArmilarA Armilar
                                    mikewolf
                                    //Spotify Instanz
                                        "heading": "Büro",
                                        "useColor": true,
                                        "items": [
                                        "type": "cardGrid",
                                        "heading": "Büro",
                                        "useColor": true,
                                        "items": [
                                        "useColor": false,
                                        "useColor": true,
                                        "heading": "Alarm",
                                        "useColor": true,
                                        "type": "cardGrid",
                                        "heading": "Radio",
                                        "useColor": true,
                                        "items": [
                                        "useColor": true,
                                        "items": [
                                        dimmode: 8,
                                        locale: "de_DE",
                                        defaultOnColor: On,
                                        defaultColor: Off,
                                                Buero_Seite_2,
                                                Spotify,
                                                Buero_Themostat,
                                                Buero_Alarm
                                    var pageId = 0;
                                        SendTime();
                                        SendDate();
                                        else
                                            switch (method) {
                                                case "startup":
                                                    pageId = 0;
                                                    break;
                                                    break;
                                                    break;
                                                case "button1":
                                                case "button2":
                                                default:
                                                    break;
                                                break;
                                            case "cardThermo":
                                                break;
                                            case "cardGrid":
                                                break;
                                            case "cardMedia":
                                                break;
                                            case "cardAlarm":
                                                break;
                                        else {
                                            return;
                                        pageId = -1;
                                        GeneratePage(page);
                                        SendDate();
                                        SendTime();
                                        var d = new Date();
                                        var d = new Date();
                                        return out_msgs
                                        return out_msgs
                                        let maxItems = 0;
                                            case "cardThermo":
                                                maxItems = 1;
                                                break;
                                            case "cardAlarm":
                                                maxItems = 1;
                                                break;
                                            case "cardMedia":
                                                maxItems = 1;
                                                break;
                                                maxItems = 4;
                                                break;
                                            case "cardGrid":
                                                maxItems = 6;
                                                break;
                                            else {
                                        return pageData;
                                        var iconId = "0"
                                        var name: string;
                                        var type: string;
                                        // ioBroker
                                            var val = null;
                                                case "light":
                                                    type = "light"
                                                    var optVal = "0"
                                                        optVal = "1"
                                                case "dimmer":
                                                    type = "light"
                                                    var optVal = "0"
                                                        optVal = "1"
                                                case "blind":
                                                    type = "shutter"
                                                case "info":
                                                case "thermostat":
                                                    type = "text";
                                                    let unit = "";
                                                    var optVal = "0"
                                                case "button":
                                                    type = "button";
                                                default:
                                        // dimmer
                                            return rgb_dec565(
                                                Interpolate(
                                            return;
                                            return;
                                            return "";
                                        return "";
                                        // ioBroker
                                            let destTemp = 0;
                                            let status = ""
                                            let stepTemp = 5
                                                } else {
                                                } else {
                                                } else {
                                        return out_msgs
                                            } else {
        name + "~" +
        id + "~" +
        media_icon + "~" +
        title + "~" +
        author + "~" +
        volume + "~" +
        speakerlist + "~" +
        onoffbutton});
                                        return out_msgs
                                        if (armed) {
                                        else {
                                        return out_msgs
                                                return true;
                                        else {
                                                return true;
                                        return false;
                                            return true;
                                        return false;
                                        let id = words[2]
                                            case "bNext":
                                                break;
                                            case "bPrev":
                                                break;
                                            case "bExit":
                                                    if (words[4] == 2)
                                                else
                                                break;
                                            case "OnOff":
                                                    var action = false
                                                        action = true
                                                        case "light":
                                                            break;
                                                        case "dimmer":
                                                break;
                                            case "up":
                                                break;
                                            case "stop":
                                                break;
                                            case "down":
                                                break;
                                            case "button":
                                                break;
                                                break;
                                            case "tempUpd":
                                                break;
                                            case "media-back":
                                                break;
                                            case "media-pause":
                                                } else {
                                                break;
                                            case "media-next":
                                                break;
                                                break;
                                            case "speaker-sel":
                                                break;
                                                break;
                                                break;
                                                break;
                                                break;
                                                break;
                                            default:
                                                break;
                                        switch (pageId) {
                                            case 0:
                                                return "0|1";
                                                return "1|0";
                                            case -1:
                                                return "0|0";
                                            default:
                                                return "1|1";
                                                let switchVal = "0"
                                                    if (val) {
                                                        switchVal = "1";
                                                    if (val === true) {
                                                        switchVal = "1"
                                                    let brightness = 0;
                                        return out_msgs
                                            unsubscribe(value);
                                            let payloadString =
                                            else {
                                        else {
                                            return "~~~";
                                        switch (icon) {
                                            case 24:        // Ice
                                            case 30:        // Hot
                                            case 31:        // Cold
                                            case 7:         // Cloudy
                                            case 11:        // fog
                                            case 25:        // Sleet
                                            case 33:        // Clear
                                            case 18:        // pouring
                                            case 12:        // Showers
                                            case 22:        // Snow
                                            case 1:         // Sunny
                                            case 32:        // windy
                                            default:
                                    type RGB = {
                                        red: number,
                                        green: number,
                                        blue: number
                                    type Payload = {
                                        payload: string;
                                    type Page = {
                                        type: string,
                                        heading: string,
                                        items: PageItem[],
                                        useColor: boolean
                                        items: PageItem[],
                                        type: "cardGrid",
                                        items: PageItem[],
                                        type: "cardThermo",
                                        items: PageItem[],
                                        type: "cardMedia",
                                        items: PageItem[],
                                        type: "cardAlarm",
                                        items: PageItem[],
                                    type PageItem = {
                                    type Config = {
                                        dimmode: number,
                                        locale: string,
                                        timeFormat: string,
                                        dateFormat: string,
                                        defaultColor: RGB,
                                    Sollten weitere oder andere Icons gewünscht sein dann auf https://htmlpreview.github.io/?https://github.com/joBr99/nspanel-lovelace-ui/blob/main/HMI/icon-cheatsheet.html nachsehen und den Namen entsprechend an der Stelle des Icons im TypeScript "NSPanelTs" tauschen.
                                    Noch ein kleiner Hinweis. Der MQTT-Adpter benötigt noch den Datenpunkt "CustomSend". Einfach in der Tasmota-Konsole folgende Zeile absenden. Danach sollte der MQTT-Adapter den Datenpunkt anlegen und abonieren.
                                    M
                                    M
                                    mameier1234
                                    #240
                                    @armilar
                                    bei mir will der Umstieg einfach nicht klappen....
                                    ich habe jetzt Tasmota 11.1.0 auf meinem Panel... und noch die alte NSPanel, die am Anfang dieses Threads besprochen wurde...
                                    Wenn ich jetzt die Befehle Backlog ... und Flashnextion ausführe passiert einfach nix.. Unknown command in der Konsole...
                                    Dann habe ich das autoexec.be Script von Hand eingebaut, neu gebootet, bei Flashnextion kommt aber immer noch Unknown Command
                                    Was mache ich wohl falsch ?
                                    Grüße,
                                    Martin
                                    • M mameier1234
                                      @armilar
                                      J
                                      J
                                      joBr99
                                      #241
                                      @mameier1234 der backlog command ist nur zum updaten von dem Berry Skript, wenn es schon installiert war.
                                      https://github.com/joBr99/nspanel-lovelace-ui#upload-berry-driver-to-tasmota
                                      https://github.com/joBr99/nspanel-lovelace-ui/blob/main/tasmota/autoexec.be
                                      Einfach den Inhalt von der autoexec.be in tasmota kopieren/hochladen, neustarten und dann hast du den FlashNextion Command und kannst das Display mit folgendem command flashen
                                      • J joBr99
                                        M
                                        M
                                        mameier1234
                                        #242
                                        @jobr99 sagte in Sonoff NSPanel:
                                        Genau das habe ich eigentlich gemacht... trotzdem kommt beim Flashbefehl .. unknown command..
                                        Grüße,
                                        Martin
                                        • M mameier1234
                                          J
                                          J
                                          joBr99
                                          schrieb am zuletzt editiert von joBr99
                                          #243
                                          @mameier1234 wenn du dir sicher bist, dass der Inhalt von der autoexec.be stimmt, geh Mal zur Berry console und gib da load('autoexec.be') ein, wenn es nen Fehler beim laden gab, steht er dann da
                                          33.2k
                                          84.3k
