  4. Raspi setzt sporadisch aus
    5.8k
36 Beiträge 7 Kommentatoren 3.9k Aufrufe 6 Beobachtet
  • O orfix
    @wendy2702
    servus,
    danke für die Hilfe, bin leider totaler Anfänger.
    Hab heute alles upgedate, leider ohne Erfolg
    Meinst du das?
    Apr 10 10:49:54 raspberrypi kernel: [  181.003794] usb 1-1.5: Product: USB2.0-Ser!
    Apr 10 10:49:54 raspberrypi kernel: [  181.005405] ch341 1-1.5:1.0: ch341-uart converter detected
    Apr 10 10:49:54 raspberrypi kernel: [  181.013840] ch341-uart ttyUSB1: break control not supported, using simulated break
    Apr 10 10:49:54 raspberrypi kernel: [  181.014368] usb 1-1.5: ch341-uart converter now attached to ttyUSB1
    Apr 10 10:49:54 raspberrypi mtp-probe: checking bus 1, device 6: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5"
    Apr 10 10:49:54 raspberrypi mtp-probe: bus: 1, device: 6 was not an MTP device
    Apr 10 10:52:46 raspberrypi bash[419]: Send diag info: {"uuid":"8ed420f7-91f4-8a4c-ad0c-b4457bd0a8cc","language":"","country":"","hosts":[{"version":"3.3.22","platform":"Javasc>
    Apr 10 10:53:17 raspberrypi kernel: [  384.342109] usb 1-1.5: USB disconnect, device number 6
    Apr 10 10:53:17 raspberrypi kernel: [  384.343417] ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
    Apr 10 10:53:17 raspberrypi kernel: [  384.343628] ch341 1-1.5:1.0: device disconnected
    Apr 10 10:53:19 raspberrypi kernel: [  386.430580] usb 1-1.4: new full-speed USB device number 7 using dwc_otg
    Apr 10 10:53:20 raspberrypi kernel: [  386.564062] usb 1-1.4: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
    Apr 10 10:53:20 raspberrypi kernel: [  386.564102] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
    Apr 10 10:53:20 raspberrypi kernel: [  386.564120] usb 1-1.4: Product: USB2.0-Ser!
    Apr 10 10:53:20 raspberrypi kernel: [  386.565396] ch341 1-1.4:1.0: ch341-uart converter detected
    Apr 10 10:53:20 raspberrypi kernel: [  386.567300] ch341-uart ttyUSB1: break control not supported, using simulated break
    Apr 10 10:53:20 raspberrypi kernel: [  386.567616] usb 1-1.4: ch341-uart converter now attached to ttyUSB1
    Apr 10 10:53:20 raspberrypi mtp-probe: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4"
    Apr 10 10:53:20 raspberrypi mtp-probe: bus: 1, device: 7 was not an MTP device
    Apr 10 10:57:21 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="358" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
    Apr 10 10:47:21 raspberrypi systemd[1]: rsyslog.service: Sent signal SIGHUP to main process 358 (rsyslogd) on client request.
    Apr 10 10:47:21 raspberrypi systemd[1]: logrotate.service: Succeeded.
    Apr 10 10:47:21 raspberrypi systemd[1]: Finished Rotate log files.
    Apr 10 10:47:22 raspberrypi bash[419]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
    Apr 10 10:47:23 raspberrypi bash[419]: host.raspberrypi check instance "system.adapter.influxdb.0" for host "raspberrypi"
    Apr 10 10:47:23 raspberrypi bash[419]: host.raspberrypi check instance "system.adapter.smartmeter.0" for host "raspberrypi"
    Apr 10 10:47:23 raspberrypi bash[419]: host.raspberrypi check instance "system.adapter.modbus.0" for host "raspberrypi"
    Apr 10 10:47:28 raspberrypi systemd[1]: man-db.service: Succeeded.
    Apr 10 10:47:28 raspberrypi systemd[1]: Finished Daily man-db regeneration.
    Apr 10 10:47:28 raspberrypi systemd[1]: Startup finished in 5.480s (kernel) + 29.281s (userspace) = 34.762s.
    Apr 10 10:47:28 raspberrypi systemd[1]: man-db.service: Consumed 1.855s CPU time.
    Apr 10 10:47:28 raspberrypi kernel: [   35.030952] cam-dummy-reg: disabling
    Apr 10 10:47:37 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
    Apr 10 10:47:40 raspberrypi bash[419]: Send diag info: {"uuid":"8ed420f7-91f4-8a4c-ad0c-b4457bd0a8cc","language":"","country":"","hosts":[{"version":"3.3.22","platform":"Javasc>
    Apr 10 10:47:41 raspberrypi bash[419]: hash changed or no sources cached => force download of new sources
    Apr 10 10:47:41 raspberrypi bash[419]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    Apr 10 10:47:53 raspberrypi bash[419]: Send diag info: {"uuid":"8ed420f7-91f4-8a4c-ad0c-b4457bd0a8cc","language":"","country":"","hosts":[{"version":"3.3.22","platform":"Javasc>
    Apr 10 10:48:53 raspberrypi bash[419]: Send diag info: {"uuid":"8ed420f7-91f4-8a4c-ad0c-b4457bd0a8cc","language":"","country":"","hosts":[{"version":"3.3.22","platform":"Javasc>
    Apr 10 10:49:51 raspberrypi kernel: [  178.516057] usb 1-1.4: USB disconnect, device number 5
    Apr 10 10:49:51 raspberrypi kernel: [  178.517018] ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
    Apr 10 10:49:51 raspberrypi kernel: [  178.517165] ch341 1-1.4:1.0: device disconnected
    Apr 10 10:49:54 raspberrypi kernel: [  180.860117] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
    Apr 10 10:49:54 raspberrypi kernel: [  181.003714] usb 1-1.5: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
    Apr 10 10:49:54 raspberrypi kernel: [  181.003767] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
    mfg Orfix
    wendy2702W Online
    wendy2702W Online
    @orfix SInd die Zeitstempel im orignal log so durcheinander?
    Hier sieht man nur das ein USB Device mal connect/disconnect macht. Ist das die HW für Modbus?
    O 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      O Offline
      O Offline
      orfix
      @wendy2702
      servus, danke für die Info
      am zeitstempel habe ich nichst geändert, ja ist die HW vom Modbus siehe auch Anhang
      mfg
      orfix
      • O orfix
        @wendy2702
        mfg
        orfix
        wendy2702W Online
        wendy2702W Online
        @orfix Also wenn du den USB Adapter nicht wissentlich getrennt hast würde ich dahin gehend mal prüfen testen.
        Eventuell mal einen anderen USB Port wählen.
        Was ist das eigentlich für eine HW die du verwendest? PI, Adapter usw.?
        • O Offline
          O Offline
          orfix
          schrieb am zuletzt editiert von orfix
          @wendy2702
          servus,
          einen anderen Port habe ich auch schon getestet, leider keine Änderung.
          Es läuft nur der eine Smartmeter und der modbus auf den Raspi.
          Revision : a01041
          Model : Raspberry Pi 2 Model B Rev 1.1
          HW ist ein 5 € Adapter
          USB RS485 Converter Adapter, hab jetzt noch einen Bestellt.
          Würdest du ein anderes Fabrikat empfehlen?
          mfg
          orfix
          • O orfix
            @wendy2702
            servus,
            Revision : a01041
            mfg
            orfix
            @orfix sagte in Raspi setzt sporadisch aus:
            die Frage bezog sich auf dein gesamtes System
            @wendy2702 sagte in Raspi setzt sporadisch aus:
            PI, Adapter usw.?
            wie ist denn der so genannte 5€-Adapter angeschlossen?
            • aktiver Hub?
            • direkt an USB3?
              PI, Adapter usw.?
              • aktiver Hub?
              • direkt an USB3?
              wendy2702W Online
              wendy2702W Online
              @homoran sagte in Raspi setzt sporadisch aus:
              direkt an USB3?
              Gibt es am PI2 schon USB 3 ?
              @orfix : ich nutze ausschließlich diese Adapter und hatte noch nie Probleme: Adapter
              HomoranH O 2 Antworten Letzte Antwort
                direkt an USB3?
                Nö, aber die Daten hat er erst editiert erst nachdem ich die Frage abgedrückt hatte :-(
                vorher sah es so aus:
                @wendy2702
                servus,
                Würdest du auf ein anderes Fabrikat empfehlen?
                mfg
                orfix
                • O Offline
                  O Offline
                  orfix
                  pi@raspberrypi:~ $ lsusb -t
                  /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
                      |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
                          |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 4                                                80M
                          |__ Port 2: Dev 4, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 1                                                2M
                          |__ Port 4: Dev 5, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
                    direkt an USB3?
                    O Offline
                    O Offline
                    orfix
                    @wendy2702
                    danke, werden den adapter mal bestellen
                    mfg
                    orfix
                    • O orfix
                      @orfix Die Frage zur Stromversorgung hast du noch nicht beantwortet.
                      Ich habe jetzt auch nicht gefunden, ob im syslog etwas von Unter-Voltage stand
                        O Offline
                        O Offline
                        orfix
                        servus,
                        es kein org. Netzteil verbaut.
                        Habe mehrere Handy Netzteile getestet, zur Zeit ist ein Logilink mit 2,4 A montiert.
                        Meinst du das ist die Ursache?
                        mfg
                        orfix
                        • O orfix
                          servus,
                          mfg
                          orfix
                          möglich!
                          Deswegen sollte man externe USB-Geräte über einen aktiven Hub anschließen.
                          Wenn ich das richtig verstanden habe, hängt ja auch noch ein Lesekopf für das Smartmeter dran
                            möglich!
                            O Offline
                            O Offline
                            orfix
                            hab den stromverbrauch vom smartmeter und Modbus gemessen, messgerät zeigt nichts an 0,00 A.
                            Hab leider keinenaktiven Hub im lager.
                            mfg
                            Orfix
                            • O Offline
                              O Offline
                              orfix
                              @orfix
                              Heute kam der Adapter, jetzt läuft der Modbus endlich.
                              Leider funktioniert nun das Smartmeter nicht mehr?
                              Hab schon alles probiert, update, neustart...
                              smartmeter.0
                              	743	2022-04-12 15:47:51.123	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	743	2022-04-12 15:45:50.111	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	743	2022-04-12 15:43:49.101	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	743	2022-04-12 15:41:48.090	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	743	2022-04-12 15:39:47.079	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	743	2022-04-12 15:37:46.063	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	693	2022-04-12 15:31:57.328	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	693	2022-04-12 15:29:56.313	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	673	2022-04-12 15:24:52.675	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	673	2022-04-12 15:22:51.664	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	673	2022-04-12 15:20:50.652	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	673	2022-04-12 15:18:49.643	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              	673	2022-04-12 15:16:48.633	warn	No or too long answer from Serial Device after last request.
                              was fehlt jetzt?
                              mfg
                              orfix
                              • O orfix
                                @orfix
                                smartmeter.0
                                smartmeter.0
                                smartmeter.0
                                smartmeter.0
                                smartmeter.0
                                smartmeter.0
                                smartmeter.0
                                smartmeter.0
                                smartmeter.0
                                smartmeter.0
                                smartmeter.0
                                smartmeter.0
                                smartmeter.0
                                was fehlt jetzt?
                                mfg
                                orfix
                                was fehlt jetzt?
                                Eine gescheite Spannungsversorgung.
                                  was fehlt jetzt?
                                  O Offline
                                  O Offline
                                  orfix
                                  hab jetzt einen Raspberry Pi 4 Model B Rev 1.1, läuft
                                  danke alle für die Unterstützung
                                  mfg
                                  orfix
                                  OpenSourceNomadO 1 Antwort Letzte Antwort
                                  • O orfix
                                    mfg
                                    orfix
                                    OpenSourceNomadO Offline
                                    OpenSourceNomad
                                    Most Active Gesperrt
                                    @orfix said in Raspi setzt sporadisch aus:
                                    Der kleine aber feine Unterschied zu deinem vorherigen Raspberry ist hier übrigens usb-c ⚠
                                    Die Krux von diesem (theoretisch) maximal 2,4A liefernden Netzteil ist das Nadelöhr micro-usb, nach Spezifikation erlaubt dieses maximal 1,8A (und dabei entsteht schon ordentlich Hitze aufgrund der winzigen Kontakte). ⚡
                                    Dein Raspberry 4 mit usb-c sollte dagegen minimal 3A abkönnen 💡
                                    Allerdings gibt es auch bei den alten Raspberries mit micro-usb eine triviale Lösung indem man diese einfach über die GPIO Stiftleiste bestromt (hier sind locker 2,5A möglich). Je nach Modell muss aber aufgepasst werden weil teilweise dann Schutzschaltung (Überspannungschutz etc.) fehlen, da diese bei bestimmten Modellen direkt hinter dem micro-usb Eingang sitzen.
                                    • OpenSourceNomadO OpenSourceNomad
                                      O Offline
                                      O Offline
                                      orfix
                                      Servus,
                                      danke für deine Unterstützung, messe jetzt 3 W Gesamtleistung am NT das sind 0,6 A.
                                      Leider setzt der Raspi immer noch sproadisch alle 4-7 Tagen aus und liefert keine Daten mehr, meistens genügt ein sudo reboot. Einmal musste ich erst ein backup einspielen.
                                      Die 2 USB Konverter kann man Stromverbrauch mäßig ignorieren?
                                      Hab jetzt die Abtastrate vom sml Adapter auf von 1 Sek auf 10 Sek. Gesetzt, vielleicht hilft es?
                                      Vielleicht wäre ein reset all 2 Tage auch sinnvoll?
                                      Hab leider auch nur Wlan im Zählerkasten.
                                      Werde auch mal den dlan testen.
                                      Mit freundlichen Grüßen,
                                      orfix
                                      • O orfix
                                        Servus,
                                        orfix
                                        das klingt danach, als ob irgendetwas den RasPi überbeschäftigt.
                                        in fast allen Fällen ist dies ein Skript, das aus dem Ruder läuft.
                                        aussetzen ist dann die falsche Bezeichnung. Er braucht nur uuuuunheimlich lange, bis zum timeout.
                                          O Offline
                                          O Offline
                                          orfix
                                          danke für deine Antwort,
                                          es laufen nur das smartmeter und ein modbus am raspi.
                                          Influxdb läuft exten auf einen server.
                                          orfix
