  4. Raspi setzt sporadisch aus
    5.8k
36 Beiträge 7 Kommentatoren 3.9k Aufrufe 6 Beobachtet
  • O orfix
    @da_woody
    was habe ich falsch gemacht?
    da_WoodyD Offline
    da_WoodyD Offline
    @orfix nicht böse gemeint, aber so einfach unleserlich. :) siehe mod edit...
    • wendy2702W Online
      wendy2702W Online
      Kann im DMESG auf die schnelle nichts auffälliges sehen.
      Was steht zu den ausfallzeiten im syslog?
      • O Offline
        O Offline
        orfix
        schrieb am zuletzt editiert von orfix
        @wendy2702
        servus,
        danke für die Hilfe, bin leider totaler Anfänger.
        Hab heute alles upgedate, leider ohne Erfolg
        Meinst du das?
        Apr 10 10:49:54 raspberrypi kernel: [  181.003794] usb 1-1.5: Product: USB2.0-Ser!
        Apr 10 10:49:54 raspberrypi kernel: [  181.005405] ch341 1-1.5:1.0: ch341-uart converter detected
        Apr 10 10:49:54 raspberrypi kernel: [  181.013840] ch341-uart ttyUSB1: break control not supported, using simulated break
        Apr 10 10:49:54 raspberrypi kernel: [  181.014368] usb 1-1.5: ch341-uart converter now attached to ttyUSB1
        Apr 10 10:49:54 raspberrypi mtp-probe: checking bus 1, device 6: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5"
        Apr 10 10:49:54 raspberrypi mtp-probe: bus: 1, device: 6 was not an MTP device
        Apr 10 10:52:46 raspberrypi bash[419]: Send diag info: {"uuid":"8ed420f7-91f4-8a4c-ad0c-b4457bd0a8cc","language":"","country":"","hosts":[{"version":"3.3.22","platform":"Javasc>
        Apr 10 10:53:17 raspberrypi kernel: [  384.342109] usb 1-1.5: USB disconnect, device number 6
        Apr 10 10:53:17 raspberrypi kernel: [  384.343417] ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
        Apr 10 10:53:17 raspberrypi kernel: [  384.343628] ch341 1-1.5:1.0: device disconnected
        Apr 10 10:53:19 raspberrypi kernel: [  386.430580] usb 1-1.4: new full-speed USB device number 7 using dwc_otg
        Apr 10 10:53:20 raspberrypi kernel: [  386.564062] usb 1-1.4: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
        Apr 10 10:53:20 raspberrypi kernel: [  386.564102] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
        Apr 10 10:53:20 raspberrypi kernel: [  386.564120] usb 1-1.4: Product: USB2.0-Ser!
        Apr 10 10:53:20 raspberrypi kernel: [  386.565396] ch341 1-1.4:1.0: ch341-uart converter detected
        Apr 10 10:53:20 raspberrypi kernel: [  386.567300] ch341-uart ttyUSB1: break control not supported, using simulated break
        Apr 10 10:53:20 raspberrypi kernel: [  386.567616] usb 1-1.4: ch341-uart converter now attached to ttyUSB1
        Apr 10 10:53:20 raspberrypi mtp-probe: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4"
        Apr 10 10:53:20 raspberrypi mtp-probe: bus: 1, device: 7 was not an MTP device
        Apr 10 10:57:21 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="358" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
        Apr 10 10:47:21 raspberrypi systemd[1]: rsyslog.service: Sent signal SIGHUP to main process 358 (rsyslogd) on client request.
        Apr 10 10:47:21 raspberrypi systemd[1]: logrotate.service: Succeeded.
        Apr 10 10:47:21 raspberrypi systemd[1]: Finished Rotate log files.
        Apr 10 10:47:22 raspberrypi bash[419]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
        Apr 10 10:47:23 raspberrypi bash[419]: host.raspberrypi check instance "system.adapter.influxdb.0" for host "raspberrypi"
        Apr 10 10:47:23 raspberrypi bash[419]: host.raspberrypi check instance "system.adapter.smartmeter.0" for host "raspberrypi"
        Apr 10 10:47:23 raspberrypi bash[419]: host.raspberrypi check instance "system.adapter.modbus.0" for host "raspberrypi"
        Apr 10 10:47:28 raspberrypi systemd[1]: man-db.service: Succeeded.
        Apr 10 10:47:28 raspberrypi systemd[1]: Finished Daily man-db regeneration.
        Apr 10 10:47:28 raspberrypi systemd[1]: Startup finished in 5.480s (kernel) + 29.281s (userspace) = 34.762s.
        Apr 10 10:47:28 raspberrypi systemd[1]: man-db.service: Consumed 1.855s CPU time.
        Apr 10 10:47:28 raspberrypi kernel: [   35.030952] cam-dummy-reg: disabling
        Apr 10 10:47:37 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
        Apr 10 10:47:40 raspberrypi bash[419]: Send diag info: {"uuid":"8ed420f7-91f4-8a4c-ad0c-b4457bd0a8cc","language":"","country":"","hosts":[{"version":"3.3.22","platform":"Javasc>
        Apr 10 10:47:41 raspberrypi bash[419]: hash changed or no sources cached => force download of new sources
        Apr 10 10:47:41 raspberrypi bash[419]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
        Apr 10 10:47:53 raspberrypi bash[419]: Send diag info: {"uuid":"8ed420f7-91f4-8a4c-ad0c-b4457bd0a8cc","language":"","country":"","hosts":[{"version":"3.3.22","platform":"Javasc>
        Apr 10 10:48:53 raspberrypi bash[419]: Send diag info: {"uuid":"8ed420f7-91f4-8a4c-ad0c-b4457bd0a8cc","language":"","country":"","hosts":[{"version":"3.3.22","platform":"Javasc>
        Apr 10 10:49:51 raspberrypi kernel: [  178.516057] usb 1-1.4: USB disconnect, device number 5
        Apr 10 10:49:51 raspberrypi kernel: [  178.517018] ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
        Apr 10 10:49:51 raspberrypi kernel: [  178.517165] ch341 1-1.4:1.0: device disconnected
        Apr 10 10:49:54 raspberrypi kernel: [  180.860117] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
        Apr 10 10:49:54 raspberrypi kernel: [  181.003714] usb 1-1.5: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
        Apr 10 10:49:54 raspberrypi kernel: [  181.003767] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
        mfg Orfix
        • O orfix
          @wendy2702
          servus,
          Meinst du das?
          mfg Orfix
          wendy2702W Online
          wendy2702W Online
          @orfix SInd die Zeitstempel im orignal log so durcheinander?
          Hier sieht man nur das ein USB Device mal connect/disconnect macht. Ist das die HW für Modbus?
          O 1 Antwort Letzte Antwort
          • wendy2702W wendy2702
            O Offline
            O Offline
            orfix
            @wendy2702
            servus, danke für die Info
            am zeitstempel habe ich nichst geändert, ja ist die HW vom Modbus siehe auch Anhang
            mfg
            orfix
            • O orfix
              @wendy2702
              mfg
              orfix
              wendy2702W Online
              wendy2702W Online
              @orfix Also wenn du den USB Adapter nicht wissentlich getrennt hast würde ich dahin gehend mal prüfen testen.
              Eventuell mal einen anderen USB Port wählen.
              Was ist das eigentlich für eine HW die du verwendest? PI, Adapter usw.?
              • O Offline
                O Offline
                orfix
                @wendy2702
                servus,
                einen anderen Port habe ich auch schon getestet, leider keine Änderung.
                Es läuft nur der eine Smartmeter und der modbus auf den Raspi.
                Revision : a01041
                Model : Raspberry Pi 2 Model B Rev 1.1
                HW ist ein 5 € Adapter
                USB RS485 Converter Adapter, hab jetzt noch einen Bestellt.
                Würdest du ein anderes Fabrikat empfehlen?
                mfg
                orfix
                • O orfix
                  @wendy2702
                  servus,
                  Revision : a01041
                  mfg
                  orfix
                  @orfix sagte in Raspi setzt sporadisch aus:
                  die Frage bezog sich auf dein gesamtes System
                  @wendy2702 sagte in Raspi setzt sporadisch aus:
                  PI, Adapter usw.?
                  wie ist denn der so genannte 5€-Adapter angeschlossen?
                  • aktiver Hub?
                  • direkt an USB3?
                    PI, Adapter usw.?
                    • aktiver Hub?
                    • direkt an USB3?
                    wendy2702W Online
                    wendy2702W Online
                    @homoran sagte in Raspi setzt sporadisch aus:
                    direkt an USB3?
                    Gibt es am PI2 schon USB 3 ?
                    @orfix : ich nutze ausschließlich diese Adapter und hatte noch nie Probleme: Adapter
                    HomoranH O 2 Antworten Letzte Antwort
                      direkt an USB3?
                      Nö, aber die Daten hat er erst editiert erst nachdem ich die Frage abgedrückt hatte :-(
                      vorher sah es so aus:
                      @wendy2702
                      servus,
                      Würdest du auf ein anderes Fabrikat empfehlen?
                      mfg
                      orfix
                      • O Offline
                        O Offline
                        orfix
                        pi@raspberrypi:~ $ lsusb -t
                        /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
                            |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
                                |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 4                                                80M
                                |__ Port 2: Dev 4, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 1                                                2M
                                |__ Port 4: Dev 5, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
                          direkt an USB3?
                          O Offline
                          O Offline
                          orfix
                          @wendy2702
                          danke, werden den adapter mal bestellen
                          mfg
                          orfix
                          • O orfix
                            @orfix Die Frage zur Stromversorgung hast du noch nicht beantwortet.
                            Ich habe jetzt auch nicht gefunden, ob im syslog etwas von Unter-Voltage stand
                              O Offline
                              O Offline
                              orfix
                              servus,
                              es kein org. Netzteil verbaut.
                              Habe mehrere Handy Netzteile getestet, zur Zeit ist ein Logilink mit 2,4 A montiert.
                              Meinst du das ist die Ursache?
                              mfg
                              orfix
                              • O orfix
                                servus,
                                mfg
                                orfix
                                möglich!
                                Deswegen sollte man externe USB-Geräte über einen aktiven Hub anschließen.
                                Wenn ich das richtig verstanden habe, hängt ja auch noch ein Lesekopf für das Smartmeter dran
                                  möglich!
                                  O Offline
                                  O Offline
                                  orfix
                                  hab den stromverbrauch vom smartmeter und Modbus gemessen, messgerät zeigt nichts an 0,00 A.
                                  Hab leider keinenaktiven Hub im lager.
                                  mfg
                                  Orfix
                                  • O Offline
                                    O Offline
                                    orfix
                                    @orfix
                                    Heute kam der Adapter, jetzt läuft der Modbus endlich.
                                    Leider funktioniert nun das Smartmeter nicht mehr?
                                    Hab schon alles probiert, update, neustart...
                                    smartmeter.0
                                    	743	2022-04-12 15:47:51.123	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	743	2022-04-12 15:45:50.111	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	743	2022-04-12 15:43:49.101	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	743	2022-04-12 15:41:48.090	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	743	2022-04-12 15:39:47.079	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	743	2022-04-12 15:37:46.063	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	693	2022-04-12 15:31:57.328	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	693	2022-04-12 15:29:56.313	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	673	2022-04-12 15:24:52.675	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	673	2022-04-12 15:22:51.664	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	673	2022-04-12 15:20:50.652	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	673	2022-04-12 15:18:49.643	warn	No or too long answer from Serial Device after last request.
                                    smartmeter.0
                                    	673	2022-04-12 15:16:48.633	warn	No or too long answer from Serial Device after last request.
                                    was fehlt jetzt?
                                    mfg
                                    orfix
                                    • O orfix
                                      @orfix
                                      smartmeter.0
                                      smartmeter.0
                                      smartmeter.0
                                      smartmeter.0
                                      smartmeter.0
                                      smartmeter.0
                                      smartmeter.0
                                      smartmeter.0
                                      smartmeter.0
                                      smartmeter.0
                                      smartmeter.0
                                      smartmeter.0
                                      smartmeter.0
                                      was fehlt jetzt?
                                      mfg
                                      orfix
                                      was fehlt jetzt?
                                      Eine gescheite Spannungsversorgung.
                                        was fehlt jetzt?
                                        O Offline
                                        O Offline
                                        orfix
                                        hab jetzt einen Raspberry Pi 4 Model B Rev 1.1, läuft
                                        danke alle für die Unterstützung
                                        mfg
                                        orfix
                                        OpenSourceNomadO 1 Antwort Letzte Antwort
                                        • O orfix
                                          mfg
                                          orfix
                                          OpenSourceNomadO Offline
                                          OpenSourceNomad
                                          Most Active Gesperrt
                                          @orfix said in Raspi setzt sporadisch aus:
                                          Der kleine aber feine Unterschied zu deinem vorherigen Raspberry ist hier übrigens usb-c ⚠
                                          Die Krux von diesem (theoretisch) maximal 2,4A liefernden Netzteil ist das Nadelöhr micro-usb, nach Spezifikation erlaubt dieses maximal 1,8A (und dabei entsteht schon ordentlich Hitze aufgrund der winzigen Kontakte). ⚡
                                          Dein Raspberry 4 mit usb-c sollte dagegen minimal 3A abkönnen 💡
                                          Allerdings gibt es auch bei den alten Raspberries mit micro-usb eine triviale Lösung indem man diese einfach über die GPIO Stiftleiste bestromt (hier sind locker 2,5A möglich). Je nach Modell muss aber aufgepasst werden weil teilweise dann Schutzschaltung (Überspannungschutz etc.) fehlen, da diese bei bestimmten Modellen direkt hinter dem micro-usb Eingang sitzen.
