  4. source analytix Adapter
    6.0k
source analytix adapterstable
58 Beiträge 6 Kommentatoren 5.5k Aufrufe 6 Beobachtet
  • Jens MeyerJ Jens Meyer
    @crunchip
    Du meinst das hIer ?
      "type": "state",
      "common": {
        "name": "ConsumedPower",
        "type": "number",
        "role": "value.totalconsumed",
        "read": true,
        "write": false,
        "def": 0,
        "unit": "Wh",
        "custom": {
          "influxdb.0": {
            "enabled": true,
            "changesOnly": true,
            "debounce": "1000",
            "retention": 0,
            "changesRelogInterval": 0,
            "changesMinDelta": 0,
            "storageType": "",
            "aliasId": ""
          "sourceanalytix.0": {
            "enabled": true,
            "alias": "",
            "selectedPrice": "ElectricityDay",
            "selectedUnit": "Wh",
            "costs": true,
            "consumption": true,
            "meter_values": true,
            "start_day": 426942.1,
            "start_week": 0,
            "start_month": 0,
            "start_quarter": 0,
            "start_year": 0,
            "valueAtDeviceReset": 6128.6342,
            "valueAtDeviceInit": -0.003,
            "cumulativeValue": 6120.6068,
            "deviceResetLogicEnabled": false,
            "threshold": 1
      "native": {},
      "_id": "shelly.0.SHEM-3#E8DB84D69143#1.Total.ConsumedPower",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      "user": "system.user.admin",
      "ts": 1648149638280
    crunchipC Abwesend
    crunchipC Abwesend
    @jens-meyer stoppe SA, deaktiviere das logging für den DP, lösche die Objekte unter SA und dann zeigst du nochmal das Raw
    Jens MeyerJ 1 Antwort Letzte Antwort
      Jens MeyerJ Offline
      Jens MeyerJ Offline
      Jens Meyer
      schrieb am zuletzt editiert von Jens Meyer
      @crunchip
      Der Adapter sourceanalytix ist gestoppt und unter Objekte sourceanalytix steht bloß noch Der ordNer admin
        "type": "state",
        "common": {
          "type": "number",
          "read": true,
          "write": false,
          "def": 0,
          "unit": "Wh",
          "custom": {
            "influxdb.0": {
              "enabled": true,
              "debounce": "1000",
              "retention": 0,
              "storageType": "",
              "aliasId": ""
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1648151009234
        @crunchip
          "type": "state",
          "common": {
            "type": "number",
            "read": true,
            "write": false,
            "def": 0,
            "unit": "Wh",
            "custom": {
              "influxdb.0": {
                "enabled": true,
                "debounce": "1000",
                "retention": 0,
                "storageType": "",
                "aliasId": ""
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636,
          "ts": 1648151009234
        crunchipC Abwesend
        crunchipC Abwesend
        @jens-meyer ok passt soweit, jetzt machst du deine Einstellung fürs loggen, unit, startwert....
        Und zeigen, aber noch nicht starten
          Jens MeyerJ Offline
          Jens MeyerJ Offline
          Jens Meyer
          @crunchip
          Admin rechte aktiviert
          Sourceanalytix aktiviert
          Unter Unit lässt sich nIchts aUswählen unter Einheit auch Nicht
          Die haken hAbe ich gesetzt und den startWert mit Absicht auf 0 gelassen
          Adapter ist noch NicHt gestartet
            "type": "state",
            "common": {
              "type": "number",
              "read": true,
              "write": false,
              "def": 0,
              "unit": "Wh",
              "custom": {
                "influxdb.0": {
                  "enabled": true,
                  "debounce": "1000",
                  "retention": 0,
                  "storageType": "",
                  "aliasId": ""
                  "enabled": true,
                  "selectedUnit": "Detect automatically",
                  "deviceResetLogicEnabled": true,
                  "threshold": 1,
                  "start_day": 0,
                  "start_week": 0,
                  "start_month": 0,
                  "start_quarter": 0,
                  "start_year": 0,
                  "costs": true,
            "native": {},
            "acl": {
              "object": 1636,
              "state": 1636,
            "ts": 1648151866164
            @crunchip
              "type": "state",
              "common": {
                "type": "number",
                "read": true,
                "write": false,
                "def": 0,
                "unit": "Wh",
                "custom": {
                  "influxdb.0": {
                    "enabled": true,
                    "debounce": "1000",
                    "retention": 0,
                    "storageType": "",
                    "aliasId": ""
                    "enabled": true,
                    "threshold": 1,
                    "start_day": 0,
                    "start_week": 0,
                    "start_month": 0,
                    "start_quarter": 0,
                    "start_year": 0,
                    "costs": true,
              "native": {},
              "acl": {
                "object": 1636,
                "state": 1636,
              "ts": 1648151866164
            crunchipC Abwesend
            crunchipC Abwesend
            @jens-meyer warum machst du nicht das was ich geschrieben habe?????
              Jens MeyerJ Offline
              Jens MeyerJ Offline
              Jens Meyer
              @crunchip
              Ich dachte das wäre das
              Ok
              Moment
                @crunchip
                Ok
                Moment
                crunchipC Abwesend
                crunchipC Abwesend
                @jens-meyer stopp, sorry hatte bei Sa aktiviert, gedacht du hast schon gestartet und nicht mehr zu Ende gelesen.
                Was meinst du mit
                Du hast bei unit auf "automatik" stehen
                Stell dort wh ein
                Und bei Startwert Tag den aktuellen Zählerstand
                  Was meinst du mit
                  Stell dort wh ein
                  Jens MeyerJ Offline
                  Jens MeyerJ Offline
                  Jens Meyer
                  @crunchip
                    "type": "state",
                    "common": {
                      "type": "number",
                      "read": true,
                      "write": false,
                      "def": 0,
                      "unit": "Wh",
                      "custom": {
                        "influxdb.0": {
                          "enabled": true,
                          "debounce": "1000",
                          "retention": 0,
                          "storageType": "",
                          "aliasId": ""
                          "enabled": true,
                          "threshold": 1,
                          "start_day": 4270064,
                          "start_week": 0,
                          "start_month": 0,
                          "start_quarter": 0,
                          "start_year": 0,
                          "costs": true,
                    "native": {},
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                    "ts": 1648152563247
                  Das ist das was ich ändern konnte.. speichern ist sonSt ausgegraut
                  Hab’s aber über die raw geschrieben
                  So sieht’s jetzt aus
                  Der Adapter ist immer noch nicht gestartet
                    @crunchip
                      "type": "state",
                      "common": {
                        "type": "number",
                        "read": true,
                        "write": false,
                        "def": 0,
                        "unit": "Wh",
                        "custom": {
                          "influxdb.0": {
                            "enabled": true,
                            "debounce": "1000",
                            "retention": 0,
                            "storageType": "",
                            "aliasId": ""
                            "enabled": true,
                            "threshold": 1,
                            "start_week": 0,
                            "start_month": 0,
                            "start_quarter": 0,
                            "start_year": 0,
                            "costs": true,
                      "native": {},
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                      "ts": 1648152563247
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @jens-meyer es fehlt die Preisdefinition, im Raw sollst du gar nichts schreiben
                      Jens MeyerJ Offline
                      Jens MeyerJ Offline
                      Jens Meyer
                      @crunchip
                      So sieht es jetzt aus
                        "type": "state",
                        "common": {
                          "type": "number",
                          "read": true,
                          "write": false,
                          "def": 0,
                          "unit": "Wh",
                          "custom": {
                            "influxdb.0": {
                              "enabled": true,
                              "debounce": "1000",
                              "retention": 0,
                              "storageType": "",
                              "aliasId": ""
                              "enabled": true,
                              "selectedUnit": "wh",
                              "threshold": 1,
                              "start_week": 0,
                              "start_month": 0,
                              "start_quarter": 0,
                              "start_year": 0,
                              "costs": true,
                        "native": {},
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                        "ts": 1648153768966
                      Adapter ist noch nicht gestartet
                        @crunchip
                          "type": "state",
                          "common": {
                            "type": "number",
                            "read": true,
                            "write": false,
                            "def": 0,
                            "unit": "Wh",
                            "custom": {
                              "influxdb.0": {
                                "enabled": true,
                                "debounce": "1000",
                                "retention": 0,
                                "storageType": "",
                                "aliasId": ""
                                "enabled": true,
                                "threshold": 1,
                                "start_week": 0,
                                "start_month": 0,
                                "start_quarter": 0,
                                "start_year": 0,
                                "costs": true,
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "ts": 1648153768966
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @jens-meyer ok sollte richtig sein.
                        Dann kannst du SA nun starten
                          Jens MeyerJ Offline
                          Jens MeyerJ Offline
                          Jens Meyer
                          @crunchip
                          Ja aber wie gehabt es wird nix angelegt unter sourceanalytix
                            @crunchip
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @jens-meyer kommt etwas im log
                              Jens MeyerJ Offline
                              Jens MeyerJ Offline
                              Jens Meyer
                              @crunchip
                              Nein im log steht nix
                              Leider.. da wüsste ich ja mehr
                                @crunchip
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @jens-meyer sagte in source analytix Adapter:
                                steht nix
                                Kann nicht sein
                                Schalte die SA instanz mal auf debug und dann das log zeigen
                                  steht nix
                                  Kann nicht sein
                                  Jens MeyerJ Offline
                                  Jens MeyerJ Offline
                                  Jens Meyer
                                  @crunchip
                                    @crunchip
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @jens-meyer da scheint wohl was mit der Installation nicht zu passen, de/installier SA nochmal.
                                    Danach deine Sachen wieder einstellen, wie zuletzt. Dann sollte es funktionieren
                                      Jens MeyerJ Offline
                                      Jens MeyerJ Offline
                                      Jens Meyer
                                      @crunchip
                                      Danke probiere ich morgen… kann ich mich dann bei dir nochmal melden?
                                        @crunchip
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @jens-meyer freilich
                                          Jens MeyerJ Offline
                                          Jens MeyerJ Offline
                                          Jens Meyer
                                          @crunchip
                                          Danke, schönen Abend noch und danke für deine Mühe und Hilfe
