  4. Easee Wallbox mit iobroker
easeewallboxadapter
541 Beiträge 64 Kommentatoren 245.1k Aufrufe 57 Beobachtet
  • L loverz
    Hi zusammen,
    gestern den Adapter installiert und heute das im log:
    easee.0
    2022-03-15 18:07:14.677	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 18:06:44.523	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 18:06:14.368	error	Error: Request failed with status code 504
    easee.0
    2022-03-15 18:05:34.202	error	Error: Request failed with status code 502
    easee.0
    2022-03-15 17:22:32.482	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 17:22:02.328	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 17:21:32.155	error	Error: Request failed with status code 504
    easee.0
    2022-03-15 17:20:52.003	error	Error: Request failed with status code 502
    easee.0
    2022-03-15 17:20:30.504	error	Error: Easee API error on charger state - stop refresh
    easee.0
    2022-03-15 17:20:30.504	error	Error: Request failed with status code 500
    easee.0
    2022-03-15 16:53:43.235	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 16:53:13.102	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 16:52:42.935	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 16:52:12.795	error	Error: Request failed with status code 504
    easee.0
    2022-03-15 16:51:32.641	error	Error: Request failed with status code 502
    easee.0
    2022-03-15 15:35:04.456	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 15:34:34.300	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 15:34:04.075	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 15:33:33.909	error	Error: Request failed with status code 502
    easee.0
    2022-03-15 15:33:07.420	error	Error: Easee API error on charger state - stop refresh
    easee.0
    2022-03-15 15:33:07.419	error	Error: Request failed with status code 502
    easee.0
    2022-03-15 14:59:01.426	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 14:58:30.939	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 14:58:00.761	error	Error: Request failed with status code 504
    easee.0
    2022-03-15 14:57:20.522	error	Error: Request failed with status code 502
    easee.0
    2022-03-15 14:16:39.157	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 14:16:08.941	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 14:15:38.779	error	Error: Request failed with status code 503
    easee.0
    2022-03-15 14:15:08.570	error	Error: Request failed with status code 504
    easee.0
    2022-03-15 14:14:28.331	error	Error: Request failed with status code 502
    easee.0
    2022-03-15 14:14:13.571	error	Error: Easee API error on charger state - stop refresh
    easee.0
    2022-03-15 14:14:13.565	error	Error: Request failed with status code 504
    K
    K
    K_o_bold
    #314
    @loverz ,
    ich nutze den Adapter schon länger und habe auch immer wieder diese errors. Adapter funktioniert aber wie gewünscht.
    Vielleicht hat @Newan eine Idee woran das liegen könnte.
    • F
      F
      flisse
      #315
      Ich habe noch eine andere Frage.
      Bei mir wird immer mal wieder der Ladevorgang abgebrochen. In der Easee App steht dann "Angehalten aufgrund des Lastenausgleichs".
      Ich lade mit einer Phase.
      Weiß jemand, wie es zu dem Zustand kommen kann?
      W 1 Antwort Letzte Antwort
      • F flisse
        W
        W
        warp735
        #316
        @flisse zufällig mit Tibber verbunden?
        F 1 Antwort Letzte Antwort
        • F flisse
          Ich habe mal drei Frage zu SignalR bzw. zum Easee Adapter:
          Welche Signale werden hier in Echtzeit übertragen?
          Und ist die Einstellung beim Abfrageintervall dann überflüssig?
          Schadet es, wenn ich das Abfrageintervall auf 1 Sekunde stelle?
          Ich bastel grad an meiner Überschussladung und nutze dafür u.a. den Wert "totalPower". Dieser wird aber definitiv nicht in Echtzeit übertragen, wenn ich den Haken bei SingalR gesetzt habe. Oder muss ich hier in der Wallbox auch noch etwas einstellen?
          H
          H
          hardy_01
          schrieb am zuletzt editiert von hardy_01
          #317
          @flisse
          Wenn du SignalR wählst, kommen die Daten in Echtzeit, sobald sie sich ändern. Der Abfrageintervall ist dann obsolet.
          Sobald ich den Refresh des Adapters auf unter 30 Sekunden stelle, bekomme ich regelmäßig 4 Error Einträge in Abständen von mehreren Sekunden, aber die Werte wurden trotzdem korrekt übertragen. Habe es dann wieder bei 30 Sekunden belassen. SignalR habe ich auch schon ausprobiert. Funktioniert eigentlich recht gut, habe aber schon vergessen, warum ich es wieder deaktiviert habe.
          Ich bastle auch grade noch an meinem Skript für 1 und 3-phasiges Laden. Bin noch in der Erprobungsphase 😬
          Was sich bei mir als gut herausgestellt hat, ist:
          • Adapterintervall auf 30 Sekunden
          • Gleitender Mittelwert des PV-Überschusses innerhalb 3 Minuten mit einem abgerundetem Wert und Offset
          • Anpassung der Phasen alle 2 Minuten
          • 3-phasig Laden erst ab 10 Minuten konstant hoher Leistung der PV
          • Abbruch des Ladevorgangs wenn 5 Minuten zu wenig PV-Überschuss
          Alles andere war mir zu "zappelig" und die Wallbox hat zu oft den Ladevorgang unterbrochen und wieder gestartet bzw. hin -und hergeregelt. Das bedeutet zwar, dass man doch ab und zu mal ein paar Minuten Netzstrom lädt. aber ich denke, dass eine "softere" Regelung besser für die Hardwarehaltbarkeit ist.
          H 1 Antwort Letzte Antwort
          • W warp735
            F
            F
            flisse
            #318
            @warp735 Nein, habe die Box privat gekauft und kein Stromanbieter ist dort involviert.
            • H hardy_01
              @flisse
              H
              H
              hardy_01
              #319
              So, hier ist mein Ladeskript für 1 -und 3-phasiges Laden mit der Easee Wallbox. Angelehnt an das Skript von @stonemaan . Ihr könnt es ja mal ausprobieren und Feedback geben, ob alles läuft. Meine ersten Tests waren jedenfalls schonmal gut. Wie sich die Steuerung bei bewölktem Himmel verhält, muss ich noch testen. Momentan haben wir seit 7 Tagen fast nur Sonne 😊
              Hier nochmal die Funktionen:
              • Gleitender Mittelwert des PV-Überschusses innerhalb 3 Minuten mit einem gerundetem Wert und Offset
              Wenn die Box von 1 auf 3-phasiges Laden umschaltet und umgekehrt, unterbricht diese kurz den Ladevorgang, das ist ganz normal.
              Wenn ihr in der Easee App den Zugriff auf "Nur mit Key" ändert, lädt die Box nicht sofort los, wenn ihr den Stecker ins Fahrzeug steckt, sondern erst, wenn z.B. morgens genug Leistung von der PV anliegt.
              Vielen Dank an @Newan für die Erstellung des Adapters 🙌
              Ueberschussladen.txt
              F 3 Antworten Letzte Antwort
              • H hardy_01
                F
                F
                flisse
                #320
                @hardy_01
                Habe mir das Script mal gezogen, aber noch nicht getestet. Ist bei mir eh erstmal nicht wichtig, weil ich kein 3-phasigen Wagen habe. Was mich interessiert ist:
                • Wie meinst du das mit "Wenn ihr in der Easee App den Zugriff auf "Nur mit Key" ändert, lädt die Box nicht sofort los"? Wo stellt man das ein?
                  Oder meinst du die Punkte: 1c5e7fb6-78cd-4f03-bbd9-2353bf7141e2-image.png
                  (Screenshot kommt von der Easee.cloud Seite meiner Wallbox.)
                  Ich habe mir da aktuell selbst beholfen mit einer Programmierkrücke, wenn der Ladestart aber automatisch verhindert werden kann, wäre mir das natürlich lieber.
                  Das Starten der Wallbox bei ausreichender Leistung startest du dann mit "Resume charging" und "Start charging"?
                • NewanN
                  NewanN
                  Newan
                  #321
                  ich war etwas abgetaucht. Nun bekomme ich aber auch bald eine PV - Anlage und würde mich natürlich gerne mit Überschussladung beschäftigen. Da ich sehe das hier jeder ein Script baut und das ganze irgendwie immer wie "Rad neu erfinden" losgeht. Daher wäre meine Idee die gesamten Ideen für Überschuss zu sammeln und dazu einen neuen eigenen Adapter zu schreiben?
                  Uli977U F A 3 Antworten Letzte Antwort
                  • NewanN Newan
                    Uli977U
                    Uli977U
                    Uli977
                    #322
                    @newan
                    Auch wenn ich wenig beitragen kann, kann ich das nur befürworten. Habe bisher mit einem holperigen Skript gearbeitet bzw. mit clever-PV.
                    Viele Grüße!
                    NewanN 1 Antwort Letzte Antwort
                    • Uli977U Uli977
                      @newan
                      Viele Grüße!
                      NewanN
                      NewanN
                      Newan
                      #323
                      @uli977 Jeder der sowas hat kann testen, was mir persönlich schon viel hilft. Oder Doku schreiben etc. das hasst jeder Entwickler!
                      Uli977U 1 Antwort Letzte Antwort
                      • NewanN Newan
                        Uli977U
                        Uli977U
                        Uli977
                        schrieb am zuletzt editiert von Uli977
                        #324
                        @newan sagte in Easee Wallbox mit iobroker:
                        Testen kann ich!
                        • Tesla Model 3
                        • 1-3 phasiges laden
                        • PV-Anlage mit zwei Kostal Plenticore plus Wechselrichtern
                        • F flisse
                          @hardy_01
                          H
                          H
                          hardy_01
                          #325
                          @flisse said in Easee Wallbox mit iobroker:
                          @hardy_01
                          "Nur mit Key" kannst du in der App einstellen (siehe Screenshot). Ich hatte das Problem, dass der Laderoboter sofort mit 11 kW losgeladen hat, sobald man das Kabel am Auto eingesteckt hat, egal ob Tag oder Nacht (auch wenn zuvor per Skript dynamiccircuitphase mit 0 geschrieben wurde).
                          Wenn ich "Nur mit Key" aktiviere, kann ich das Kabel einstecken und der Laderoboter wartet auf Genehmigung und verharrt im Standby. Über Start Charging kann ich den Ladevorgang dann starten (resume geht hier nicht), und mit Stop Charging bzw. Pause Charging wieder stoppen.
                          • H hardy_01
                            @hardy_01
                            F
                            F
                            flisse
                            #326
                            @hardy_01 Super, danke für die Info.
                            • NewanN Newan
                              F
                              F
                              flisse
                              #327
                              @newan Das wäre natürlich echt super mit dem Adapter. Die Frage ist natürlich nur, wie allgemein man so einen Adapter gestalten kann, da doch viele unterschiedliche Wechselrichter, Wallboxen und auch Vorlieben für die Regelung unterwegs sind.
                              Ich kann beim Programmieren nicht helfen, wohl aber beim Testen.
                              • F flisse
                                NewanN
                                NewanN
                                Newan
                                #328
                                @flisse Da wir die Daten in ioBroker haben brauch ich ja nur Datenpunkte und keine Anbindung von wechselrichter.
                                Ich mach mal ein Beitrag auf und dann sammeln wir mal Ideen
                                • H hardy_01
                                  F
                                  F
                                  flisse
                                  schrieb am zuletzt editiert von flisse
                                  #329
                                  @hardy_01
                                  Da ich mich mit meinem eigenen Script irgendwie im Kreis drehe, was das Überschussladen angeht, habe ich heute mal deins ausprobiert. Funktioniert aktuell sehr gut. Vielen Dank dafür.
                                  Kann allerdings wie gesagt nur 1-phasig Laden, deshalb habe ich das Script noch um einen Schalter erweitert, mit dem man grundsätzlich die Möglichkeit der 3-phasigen Ladung vor- bzw. abwählen kann. Somit wird bei Bedarf weiterhin mit 16A (habe die Wallbox aktuell auf 11kW eingestellt) einphasig geladen, obwohl die PV-Leistung groß genug wäre, um auf 3-phasige Ladung mit geringerem Strom pro Phase umschalten zu können.
                                  • F
                                    F
                                    flisse
                                    #330
                                    Nachdem es gestern wechselhaft war, was die Leistung der PV-Anlage angeht, habe ich mal in die Daten reingeschaut. Für mich sieht das schon sehr gut aus:
                                    Was man aber auch sieht ist, dass bei einem Piks noch oben der PV-Anlage die Ladeleistung der Wallbox recht schnell angehoben wird, sinkt aber die PV-Leistung, dauert es länger, bis die Ladeleistung wieder reduziert wird.
                                    Wenn man da mal das Beispiel von 10:35Uhr aus dem Grafana-Auszug nimmt, sind das aber grad mal 4 Minuten, also "meckern" auf hohem Niveau. Zumal hier auch immer fraglich ist, wann genau die Daten für die Ladeleistung aus dem Easee Adapter aktualisiert wurden.
                                    Ich bin also äußerst zufrieden mit dem Script und möchte zwei dicke Lobe und Danke aussprechen:
                                    1. An @Newan für den Adapter
                                    2. An @hardy_01 für das Script
                                    NewanN H 2 Antworten Letzte Antwort
                                    • F flisse
                                      NewanN
                                      NewanN
                                      Newan
                                      #331
                                      @flisse Danke für die Blumen 😊
                                      • NewanN Newan
                                        W
                                        W
                                        warp735
                                        #332
                                        Machen diese "Sprünge" dem Wagen nix aus?
                                        • W warp735
                                          F
                                          F
                                          flisse
                                          #333
                                          @warp735
                                          Bisher hat er sich nicht beschwert 😉
                                          33.2k
                                          84.3k
