  4. Influx arbeitet nicht mehr stabil
    6.0k
influx grafana vis
214 Beiträge 9 Kommentatoren 29.2k Aufrufe 7 Beobachtet
  • A Altersrentner
    @crunchip sagte in Influx arbeitet nicht mehr stabil:
    wenn alles fertig geladen ist, kannst du alles starten, mit
    pi@raspberrypi:~ $ iobroker start all
    The adapter "influxdb.1" was started.
    The adapter "scenes.0" was started.
    The adapter "telegram.0" was started.
    The adapter "alexa2.0" was started.
    The adapter "mihome-vacuum.0" was started.
    The adapter "weatherunderground.1" was started.
    The adapter "cul.0" was started.
    The adapter "flot.0" was started.
    The adapter "icons-icons8.0" was started.
    The adapter "icons-mfd-png.0" was started.
    The adapter "icons-open-icon-library-png.0" was started.
    The adapter "info.0" was started.
    The adapter "iot.0" was started.
    The adapter "samsung.0" was started.
    The adapter "tankerkoenig.0" was started.
    The adapter "text2command.0" was started.
    The adapter "vis-fancyswitch.0" was started.
    The adapter "vis-hqwidgets.0" was started.
    The adapter "vis-material-webfont.0" was started.
    The adapter "vis-materialdesign.0" was started.
    The adapter "vis-metro.0" was started.
    The adapter "vis-plumb.0" was started.
    The adapter "vis-timeandweather.0" was started.
    The adapter "vis-weather.0" was started.
    pi@raspberrypi:~ $
    während des backups kannst du dir das log ansehe
    pi@raspberrypi:~ $ iobroker logs --lines 100 --watch
    Uncaught Rejection: Error: Cannot create a string longer than 0xffffff0 characters
        at Object.slice (buffer.js:609:37)
        at Buffer.toString (buffer.js:827:14)
        at CLILogs.execute (/opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js:40:51)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1137:25)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3314:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
        at Module._compile (internal/modules/cjs/loader.js:1085:14)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
        at Module.load (internal/modules/cjs/loader.js:950:32)
        at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    pi@raspberrypi:~ $
    MfG Michael
    crunchipC Offline
    crunchipC Offline
    #139
    @altersrentner sagte in Influx arbeitet nicht mehr stabil:
    da bin ich nun auch überfragt
    18.03.22
    ok, also kein Uraltest
    Die Instanzen sind auf starten gestellt, bleiben aber rot
    also kommst du jetzt wieder drauf?
    was zeigt dann das log an?
      18.03.22
      Altersrentner
      #140
      nein
      nein nicht möglich
      pi@raspberrypi:~ $
      • A Altersrentner
        nein
        nein nicht möglich
        pi@raspberrypi:~ $
        crunchipC Offline
        crunchipC Offline
        #141
        nein nicht möglich
        verstehe ich nicht, du kommst nicht auf den iobroker, woher weisst du dann, das alle Instanzen rot sind
        iob list instances
          nein nicht möglich
          iob list instances
          Altersrentner
          #142
          Da habe ich Dich misverstanden.
          Auf den ioBroker komme ich
          pi@raspberrypi:~ $ iob list instances
            system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
            system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
            system.adapter.cul.0                    : cul                   : raspberrypi                              -  enabled, port: 23
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
            system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
            system.adapter.fhem.0                   : fhem                  : raspberrypi                              - disabled, port: 7072
            system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
            system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
            system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
            system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
            system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
            system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
            system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
            system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
            system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 0.0.0.0
          + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
            system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
            system.adapter.samsung.0                : samsung               : raspberrypi                              - disabled
            system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
            system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
            system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
            system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
            system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
            system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
            system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
            system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
            system.adapter.weatherunderground.1     : weatherunderground    : raspberrypi                              -  enabled
            system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
            system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
            system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0012013B01-if00
          + instance is alive
          pi@raspberrypi:~ $
          MfG Michael
          • crunchipC Offline
            crunchipC Offline
            #143
            dann kannst du doch das log aufrufen
            • A Altersrentner
              + instance is alive
              pi@raspberrypi:~ $
              MfG Michael
              Altersrentner
              #144
              + instance is alive
              pi@raspberrypi:~ $
              MfG Michael
              ZB Clood verbunden mit gerätoder dienst
              Lebenszeichen 0
              verbunden mit Host 0
                Altersrentner
                #145
                Meinst Du Protokolle
                • A Altersrentner
                  + instance is alive
                  pi@raspberrypi:~ $
                  MfG Michael
                  Lebenszeichen 0
                  crunchipC Offline
                  crunchipC Offline
                  #146
                  da sind einige Instancen nicht gestartet
                  ja, aber oben auf log herunterladen
                    Altersrentner
                    #147
                    und wie dann hier einstellen?
                    • A Altersrentner
                      crunchipC Offline
                      crunchipC Offline
                      #148
                      @altersrentner na im browser ansehen, die Meldungen kopieren und hier posten. Musst ja nicht das ganze log, reichte fürs erste, was so aktuell als error gemeldet wird
                      A 2 Antworten Letzte Antwort
                        Altersrentner
                        #149
                        @crunchip Wenn ich das Protokoll laden will stürzt der ioBroker ab.
                        Jetzt 2x hintereinander
                          Altersrentner
                          #150
                          @crunchip Komisch,
                          Jetzt nach dem 2ten Absturz
                          iob stop
                          iob start
                          sind scheinbar alle Instanzen gestartet
                          außer Web.0
                          Kann aber vis nicht starten
                          • A Altersrentner
                            crunchipC Offline
                            crunchipC Offline
                            #151
                            @altersrentner schau mal wie deine Auslastung so ist mit
                            htop
                            falls nicht installiert, mit
                            top
                            also war er doch noch am werkeln und noch nicht fertig
                              htop
                              top
                              Altersrentner
                              #152
                              • A Altersrentner
                                Altersrentner
                                #153
                                Auf vis xxx:8083 Habe ich keinen Zugriff
                                • A Altersrentner
                                  crunchipC Offline
                                  crunchipC Offline
                                  #154
                                  @altersrentner deine vis ist erst mal dein kleineres Übel, deine Influx läuft aus dem Ruder, ebenfalls npm
                                  stoppe mal die Influx Instanz und kontrolliere dann nochmal mit top
                                    Altersrentner
                                    #155
                                    Du meintest doch htop?
                                    • A Altersrentner
                                      crunchipC Offline
                                      crunchipC Offline
                                      #156
                                      @altersrentner
                                      stoppe mal ein paar deiner Prozesse
                                      sudo kill -KILL 21839
                                      sudo kill -KILL 21840
                                      sudo kill -KILL 21842
                                      sudo kill -KILL 21844
                                      sudo kill -KILL 21846
                                        @altersrentner
                                        Altersrentner
                                        #157
                                        @crunchip
                                        pi@raspberrypi:~ $ sudo kill -KILL 21846
                                        kill: (21846): No such process
                                        pi@raspberrypi:~ $
                                        pi@raspberrypi:~ $ sudo kill -KILL 21839
                                        kill: (21839): No such process
                                        pi@raspberrypi:~ $ sudo kill -KILL 21840
                                        kill: (21840): No such process
                                        pi@raspberrypi:~ $ sudo kill -KILL 21842
                                        kill: (21842): No such process
                                        pi@raspberrypi:~ $ sudo kill -KILL 21844
                                        kill: (21844): No such process
                                        pi@raspberrypi:~ $
                                        • A Altersrentner
                                          @crunchip
                                          pi@raspberrypi:~ $
                                          pi@raspberrypi:~ $
                                          crunchipC Offline
                                          crunchipC Offline
                                          #158
                                          @altersrentner zeig nochmal htop
