  5. [gelöst] Aufzählung Fensterstatus - Anzeige in VIS
31 Beiträge 7 Kommentatoren 3.6k Aufrufe 5 Beobachtet
  • amg_666A amg_666
    @iced112 dann poste doch mal bitte dein blockly, hast du da irgendwas modifiziert?
    I Offline
    I Offline
    IceD112
    schrieb am zuletzt editiert von IceD112
    @amg_666
      <variables>
        <variable id="sa{l1~ORe0j$HLuZ5N%!">ids</variable>
        <variable id="kT%nX!]Jo^`}k%/`k?Gq">offen</variable>
        <variable id=":nd$CvGxF5#~Ll%,n#b2">id</variable>
        <variable id="xu-:vrDF`H;M_fGe2]b4">x</variable>
      </variables>
      <block type="variables_set" id="i(tPYLv;RbKHg~i@a0{/" x="-412" y="-237">
        <field name="VAR" id="sa{l1~ORe0j$HLuZ5N%!">ids</field>
        <value name="VALUE">
          <block type="selector" id="}ukVNv/ei7Qs4LavaT+0">
            <field name="TEXT">*(functions=window)</field>
          </block>
        </value>
        <next>
          <block type="on_ext" id="Yr}xw(F4N,5fxKcZ:vaA">
            <value name="OID0">
              <shadow type="field_oid" id="H6rjU$rO8@g6Lgk:jv9f">
              </shadow>
              <block type="variables_get" id="WDNWJnP.L:dRO2.H3gFM">
              </block>
            </value>
            <statement name="STATEMENT">
              <block type="variables_set" id="fiT;40M9XwH-IB;dai$*">
                <field name="VAR" id="kT%nX!]Jo^`}k%/`k?Gq">offen</field>
                  <block type="logic_boolean" id="D}!bGj=1]X5!.KmIss,#">
                  </block>
                </value>
                <next>
                  <block type="controls_forEach" id="hZm%QED(q{qqF9Qt_4zV">
                    <field name="VAR" id=":nd$CvGxF5#~Ll%,n#b2">id</field>
                    <value name="LIST">
                      <block type="variables_get" id="W?h4_#I[DjCw!DD`F47g">
                      </block>
                    </value>
                    <statement name="DO">
                      <block type="controls_if" id="z})86Cf$,3q!)/4/%c_V">
                        <value name="IF0">
                          <block type="get_value_var" id="A4]d*E-i6@qDI3SUpZqx">
                            <value name="OID">
                              <shadow type="text" id="iJar`blbRA6G?|%Gx#Po">
                                <field name="TEXT"></field>
                              </shadow>
                              <block type="variables_get" id="*JdI$y).=mPIbq)_%f@?">
                              </block>
                            </value>
                          </block>
                        </value>
                        <statement name="DO0">
                          <block type="variables_set" id="Fq.`IT_ELmfwRP@:9=fo">
                              <block type="logic_boolean" id="XAR!D%*in|Fp8/pJ/8x?">
                              </block>
                            </value>
                            <next>
                              <block type="controls_flow_statements" id=":b34uz=#:?=ZHl=pLEUL">
                                <field name="FLOW">BREAK</field>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </statement>
                    <next>
                      <block type="update" id="QKP7Y`XWPrhAR@*2qMM`">
                        <field name="OID">0_userdata.0.Routinen.Fenster_Status</field>
                          <block type="logic_compare" id="pK*Xb]J~V:d47jSa)5$b">
                            <field name="OP">GT</field>
                            <value name="A">
                              <block type="variables_get" id="OIv|$ewMBS:u!+T72:D)">
                                <field name="VAR" id="xu-:vrDF`H;M_fGe2]b4">x</field>
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="Avy%3uPr5m{lU:pjUzqZ">
                                <field name="NUM">0</field>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </next>
      </block>
    </xml>
    • I IceD112
      @amg_666
        <variables>
        </variables>
            </block>
          </value>
          <next>
              <value name="OID0">
                </shadow>
                </block>
              </value>
                    </block>
                  </value>
                  <next>
                      <value name="LIST">
                        </block>
                      </value>
                          <value name="IF0">
                              <value name="OID">
                                </shadow>
                                </block>
                              </value>
                            </block>
                          </value>
                                </block>
                              </value>
                              <next>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </statement>
                      <next>
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
          </next>
        </block>
      </xml>
      amg_666A Offline
      amg_666A Offline
      amg_666
      @iced112 Du verwendest das Blockly von @badsnoopy667 und hast die "Logikzeile" von @paul53 drangehängt.
      Das kann nix werden, weil du in den Schleifen die Variable x überhaupt nicht verwendest, die du dann abprüfst...
      Mach mal unten aktualisiere "Fenster Status" mit "offen". Oder du sparst dir die letzte Zeile und ersetzt im Blockly "offen" mit "Fenster Status"
      • I IceD112
        @amg_666
        Das sind Sensoren von Shelly. Der Datenpunkt door gibt true oder flase aus wenn offen oder geschlossen.
        Ja, was mach ich denn falsch?
        @iced112 sagte: was mach ich denn falsch?
        Überprüfe, ob der Selektor funktioniert:
        I 1 Antwort Letzte Antwort
          I Offline
          I Offline
          IceD112
          @paul53 said in Aufzählung Fensterstatus - Anzeige in VIS:
          So hatte ich es ja auch bereits versucht.
          16.3.2022, 13:30:27.422	[info ]: javascript.0 (32658) Stop script script.js.Routinen.Fenster_Status
          16.3.2022, 13:30:27.445	[info ]: javascript.0 (32658) Start javascript script.js.Routinen.Fenster_Status
          16.3.2022, 13:30:27.537	[info ]: javascript.0 (32658) script.js.Routinen.Fenster_Status: registered 0 subscriptions and 0 schedules
          16.3.2022, 13:31:16.091	[info ]: javascript.0 (32658) Stop script script.js.Routinen.Fenster_Status
          16.3.2022, 13:31:18.043	[info ]: javascript.0 (32658) Start javascript script.js.Routinen.Fenster_Status
          16.3.2022, 13:31:18.098	[info ]: javascript.0 (32658) script.js.Routinen.Fenster_Status: registered 0 subscriptions and 0 schedules
          16.3.2022, 13:32:40.103	[info ]: javascript.0 (32658) Stop script script.js.Routinen.Fenster_Status
          16.3.2022, 13:32:40.127	[info ]: javascript.0 (32658) Start javascript script.js.Routinen.Fenster_Status
          16.3.2022, 13:32:40.168	[info ]: javascript.0 (32658) script.js.Routinen.Fenster_Status: registered 0 subscriptions and 0 schedules
          16.3.2022, 13:33:04.268	[info ]: javascript.0 (32658) Stop script script.js.Routinen.Fenster_Status
          16.3.2022, 13:33:04.279	[info ]: javascript.0 (32658) Start javascript script.js.Routinen.Fenster_Status
          16.3.2022, 13:33:04.302	[info ]: javascript.0 (32658) script.js.Routinen.Fenster_Status: registered 0 subscriptions and 0 schedules
          16.3.2022, 13:34:13.461	[info ]: javascript.0 (32658) Stop script script.js.Routinen.Fenster_Status
          16.3.2022, 13:34:13.483	[info ]: javascript.0 (32658) Start javascript script.js.Routinen.Fenster_Status
          16.3.2022, 13:34:13.551	[info ]: javascript.0 (32658) script.js.Routinen.Fenster_Status: []
          16.3.2022, 13:34:13.551	[info ]: javascript.0 (32658) script.js.Routinen.Fenster_Status: registered 0 subscriptions and 0 schedules
          • I IceD112
            @iced112 sagte: script.js.Routinen.Fenster_Status: []
            Der Selektor funktioniert nicht. Wurde nach dem Zuweisen der Datenpunkte zu "window" die Javascript-Instanz neu gestartet? Das ist erforderlich, um den Puffer zu synchronisieren.
            I dslraserD 2 Antworten Letzte Antwort
              I Offline
              I Offline
              IceD112
              Ja, hab ich gesehen. Sorry wenn ich so dumm frage, Aber wenn ich die Variablen erstelle, ist es denn damit alleine getan? Ich verstehe nämlich nicht so recht, was da passiert so wie ich es im Blockly gebaut (sorry: rein kopiert habe :-) )
              Hab, wie gesagt, noch nie mit Variablen geabreitet und ich weis halt auch nicht was z.B. passiert in dem Block "setze offen auf wahr"...
                dslraserD Offline
                dslraserD Offline
                dslraser
                ist das Sternchen im Selektor richtig und notwendig ?
                sein Selektor
                Beispiel eines meiner Selektoren
                • dslraserD dslraser
                  sein Selektor
                  @dslraser sagte: ist das Sternchen im Selektor richtig und notwendig ?
                  Kann sein, dass es nicht notwendig ist, es schadet aber auch nicht.
                  • I IceD112
                    @iced112 sagte: ich weis halt auch nicht was z.B. passiert in dem Block "setze offen auf wahr"...
                    Wenn das erste offene Fenster gefunden wird, wird die Variable, die vor der Schleife auf false gesetzt wurde, auf true gesetzt.
                    Javascript-Instanz mal neu gestartet?
                      I Offline
                      I Offline
                      IceD112
                      Soooo. Jetzt klappts
                      Aus dem Datenpunkt hab ich nochmal aus dem Indicator einen State gemacht. und so funktioniert die Anzeige in der VIS auch 👍
                      Blockly schaut so aus
