  4. Neue Installationsroutine (für Linux)
installation
415 Beiträge 64 Kommentatoren 230.2k Aufrufe 31 Beobachtet
  • D DokBiz
    @apollon77 said in Neue Installationsroutine (für Linux):
    console.log(JSON.stringify(_objects[i]));
    bei mir unterscheiden sich die dateien ein wenig, es war zeile 489.. aber ich hab was du wolltest:
    tended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448}}
    Server Objects 127.0.0.1:33568 Error from InMemDB: Error: EXEC without MULTI
    apollon77A
    apollon77A
    #405
    @dokbiz Naja mal paaaaaar Zeilen davor bitte mehr :-)
    • apollon77A apollon77
      @dokbiz Und nochmal der vollständigkeit halber: JS-Controller ist die 4.0.19?? (iob version).
      Dann versuchen wir mal mehr rauszufinden:
      • Editiere mal /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js (ANnahme liegt auch bei dir, sonst Basispfad anpassen)
      • Über Zeile 496 (https://github.com/ioBroker/ioBroker.js-controller/blob/ef364284a964d6854558dc6ce16647f2993ed126/packages/controller/lib/setup/setupBackup.js#L496) ein console.log(JSON.stringify(_objects[i])); einfügen
      • Dann kommen da gaaanz viele Ausgaben ... Bitte mal die Paar zeilen über dem Fehler posten wenn er wieder kommt
      D
      D
      DokBiz
      #406
      @apollon77
      achja:
      ich hatte eben ein restore machen wollen, und dann kam die meldung:
          ~  iobroker restore /opt/iobroker/backups/2022_03_10-15_30_03_backupiobroker.tar.gz         ✔  system 
      iobroker controller daemon is not running
      host.Dok2012(SmartHome) OK.
      The current version of js-controller differs from the version in the backup.
      The js-controller version of the backup can not be restored automatically.
      To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.18 --production" inside your ioBroker directory
      If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
      ich hatte jetzt nochmal auf die 4.0.19 geselfupgraded, und jetzt kommt dieselbe meldung nochmal...
      {"id":"system.certificates","value":{"_id":"system.certificates","type":"config","common":{"name":"System certificates","icon":"data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgMUwzIDV2NmMwIDUuNTUgMy44NCAxMC43NCA5IDEyIDUuMTYtMS4yNiA5LTYuNDUgOS0xMlY1bC05LTR6bTAgMTAuOTloN2MtLjUzIDQuMTItMy4yOCA3Ljc5LTcgOC45NFYxMkg1VjYuM2w3LTMuMTF2OC44eiIvPg0KPC9zdmc+"},"native":{"certificates":{"defaultPrivate":"-----BEGIN RSA PRIVATE KEY-----\r\nMIIEpQIBAAKCAQEA2oz+GS/v8ZJp8pnswIeUSdeTDC9KR0t8Wyw+T00Pxbb1B3y3\r\nltaUkoFWD40fM1VjsFnVbGKD85IyB4ZN/YkuD71Z71NgUxGRWpdhD8W239aF/UXH\r\nMjehyqm0OWXJ96rhP1QRj7YGm4q4MLslkZg7ZSkIh3Zx68cvIssmhPlNMk1IGNb1\r\nGhUDtbXZaGMMux0ygI4CpgCjfuXl0+yq8KyucZDWVuVHVJiG2GXg77XLMWZm02if\r\nuXysSAHyeNihAu+MF/QJRQsy+TFg+X2M4nsKSZWWOoAnZ1Rpcdv9T2GjNwbGvfTQ\r\nYz8iDm7ItVAkA2l/AtxovY9m651DzCJdbyYAYwIDAQABAoIBAAnY+oYWA+DFsSJu\r\nTx2pvkPJg+Wzp8womZTeHHykQ0asZMQOmZMhXhZv33nZ6QL+IPzMP3KfycRK3Rg7\r\ns/3tlXa+GHRRNHDpxLvpQEVeqkvRtb3gzAX2PcMM/ILtlDklqPqahiQMlqWhjYUc\r\nmafCzUJUo/6+lomCMxyFPNoXBaRzg6PUfSQkEmoajmJOYxERjXvhKwQlGt0VMUo/\r\n2nr2eowvZ7/b7DWWUebqzDH2Y0wBkJC16CVtSWU+vFqYJIDdZSKYa9rbqu9viPLp\r\nk5W1Gzb6pIrs2VxojAxNXk7u0aiotutq+fW0BAVb34cajtUyoNsesMHvZSSMrlxp\r\nXeOglAkCgYEA/QA0ebq7MBSid4Xd0PyKMbJv0bIsob7W3dHZ3ozkZgHOckAORhe/\r\nZYYWgL6q/KSSEW4Syy1WMuEhGnLWZDEiYdOfvbFYhO7rkE7+m1Nov74eRQQ/yyQW\r\nEFBh/3AY4tK/38h9mFZ+iAGAzcGB575zG8IogJqnK8s2s6pTooLkrH8CgYEA3SQ9\r\nfSNtt7MF/VWqptsKw02r2qrSytu1XCWw8naZFBqh4yfyToW1t7Xx02zlPzcET6Z8\r\ngdCZWxm2I8Ni+hECIjSXAjYzAE0oZLJAp+7kcClX+fN3CbXFX7t9wNC1f4FJR4WO\r\nVTS4IUG74eaIzRC78/ZyjVDtVsk0Sin66rC+ih0CgYEAoF6u5LKO0Q1jZqv+TOin\r\nmJTo+F0emXBktrq8hat9Y4Olnxonchq/gdUbEoTJ0ddnl5DUbOHSD/JQj3lXmK7k\r\ngmooiY+O8sSXoSPRlBetAE281ja5UUUQj0rEs6wUukKoyWtG4XeCQSfiw4nzlDhO\r\nsrvB/LMLYGExzXUcCpk55nUCgYEAzwzsaWsvgiyjMgPwiNNTq3Lgshb40CiQENvV\r\nZd73CqS46EdxjmWQs5Yt+mfd6KcpaS4XKzBVNb/IEooQ9NPR7JbSwKZgcCrN5CIl\r\neVaqGf4LuiJjVPsU9sJERrDjDqPNKaL5lfuLXs/+Cs9fTKkbYZtgu8GGxpgSVlIh\r\n9XVQoV0CgYEA5T7Lcn8Av5cFYqIJoWy+mg3Wa1ePFLQh6OBi42yw8WEWr8aXvjVt\r\nCD46e4jT1/Ejqv2KRNXHnwAbnTwJKo+eJgCVCs2xH6h7sUWM7MDp5OHaOw7+Ict7\r\nAHD96EOigyzYb6ffoGboUYt1/wzO2eSTC5xTsN+nYn/1lrhctXfDY30=\r\n-----END RSA PRIVATE KEY-----\r\n","defaultPublic":"-----BEGIN CERTIFICATE-----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\r\nNCQty6MoBZjgHRxcNYMtdjDT1GwUAvpucPS7Rd1abkRv7XOu45NngJrZKA==\r\n-----END CERTIFICATE-----\r\n"},"letsEncrypt":{"path":"letsencrypt","email":"","domains":""}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1536},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866479},"doc":{"_id":"system.certificates","type":"config","common":{"name":"System certificates","icon":"data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgMUwzIDV2NmMwIDUuNTUgMy44NCAxMC43NCA5IDEyIDUuMTYtMS4yNiA5LTYuNDUgOS0xMlY1bC05LTR6bTAgMTAuOTloN2MtLjUzIDQuMTItMy4yOCA3Ljc5LTcgOC45NFYxMkg1VjYuM2w3LTMuMTF2OC44eiIvPg0KPC9zdmc+"},"native":{"certificates":{"defaultPrivate":"-----BEGIN RSA PRIVATE KEY-----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\r\nAHD96EOigyzYb6ffoGboUYt1/wzO2eSTC5xTsN+nYn/1lrhctXfDY30=\r\n-----END RSA PRIVATE KEY-----\r\n","defaultPublic":"-----BEGIN CERTIFICATE-----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\r\nNCQty6MoBZjgHRxcNYMtdjDT1GwUAvpucPS7Rd1abkRv7XOu45NngJrZKA==\r\n-----END CERTIFICATE-----\r\n"},"letsEncrypt":{"path":"letsencrypt","email":"","domains":""}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1536},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866479}}
      {"id":"system.config","value":{"_id":"system.config","type":"config","common":{"name":"System configuration","city":"Trier","country":"Germany","longitude":"6.6441878","latitude":"49.7596208","language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":false,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":"stable","diag":"extended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448},"doc":{"_id":"system.config","type":"config","common":{"name":"System configuration","city":"Trier","country":"Germany","longitude":"6.6441878","latitude":"49.7596208","language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":false,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":"stable","diag":"extended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448}}
      ^C
      reicht das so? ich dachte, der fehler wäre in den letzten paar einträgen 🙈
      • D DokBiz
        @apollon77
        achja:
        ^C
        D
        D
        DokBiz
        schrieb am zuletzt editiert von DokBiz
        #407
        @dokbiz said in Neue Installationsroutine (für Linux):
        reicht das so?
        in der konsole füllt das den kompletten monitor 😕
        wieviele zeilen willst du??
        • D DokBiz
          reicht das so?
          apollon77A
          apollon77A
          #408
          @dokbiz Reicht so. Aber am besten schau mal PN und schicke es mir als email.
            D
            D
            DokBiz
            #409
            @apollon77
            ich hab dir die mail geschickt!
            falls das irgendwie relevanz hat: ich hab den iobroker noch lauffähig unter windows im zugriff
            apollon77A 2 Antworten Letzte Antwort
            • D DokBiz
              @apollon77
              apollon77A
              apollon77A
              #410
              @dokbiz Wir versuchen mal
              • D DokBiz
                @apollon77
                apollon77A
                apollon77A
                #411
                @dokbiz Nice one :-)) Bei dir war was "Zu schnell" und hast damit nen Bug gefunden :-)
                Willst Du mal versuchen ob der Fix tut? :-)
                Am Ende musst du diese Änderung machen https://github.com/ioBroker/ioBroker.js-controller/pull/1853/files
                File suchst Du am besten mit cd /opt/iobroker und dann `find . -name redisHandler.js´ ich würde es erwarten in /opt/iobroker/node_modules/@iobroker/db-base/lib/redisHandler.js aber bei npm weiss man nie.
                Tut es danach?
                  Tut es danach?
                  D
                  D
                  DokBiz
                  #412
                  Nice one :-))
                  Da freut er sich, dass ich alles kaputt bekomme... Das hatte ich auch selten 😂
                  Also restore an sich lief nach der Korrektur der Datei (die übrigens genau dort lag, wo du sie vermutet hattest) fehlerfrei durch (soweit ich das beurteilen kann).
                  Vielen Dank schon mal dafür!!
                  Ich komme allerdings nicht auf die Weboberfläche. und was mich auch wundert, ist, dass er dieses mal gar nicht wegen der Version 'gemeckert' hat.. iob -v ergibt 4.0.19, das Backup war 4.0.18
                  D apollon77A 2 Antworten Letzte Antwort
                  • D DokBiz
                    Nice one :-))
                    D
                    D
                    DokBiz
                    #413
                    @dokbiz
                    Update:
                    nach
                    iobroker stop
                    iobroker host this
                    iobroker fix
                    iobroker start
                    komme ich auf die Oberfläche und sehe zumindest schon mal meine ganzen Instanzen 👏 😍
                    • D DokBiz
                      Nice one :-))
                      apollon77A
                      apollon77A
                      #414
                      @dokbiz sagte in Neue Installationsroutine (für Linux):
                      Interessant ... müssen wir beobachten. Laut coce müssen sich die daten irgendwie doch einig gewesen sein :-)
                      • apollon77A
                        apollon77A
                        #415
                        js-controller 4.0.20 kommt später heute in Beta ... da sollte das dann generell gefixt sein.
                        33.2k
                        84.3k
