Neue Installationsroutine (für Linux)
ja: 1800/2492
host.Dok2021 Processed 1800/2492 objects Server Objects 127.0.0.1:33106 Error from InMemDB: Error: EXEC without MULTI@dokbiz Und nochmal der vollständigkeit halber: JS-Controller ist die 4.0.19?? (
iob version).Dann versuchen wir mal mehr rauszufinden:
- Editiere mal /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js (ANnahme liegt auch bei dir, sonst Basispfad anpassen)
- Über Zeile 496 (https://github.com/ioBroker/ioBroker.js-controller/blob/ef364284a964d6854558dc6ce16647f2993ed126/packages/controller/lib/setup/setupBackup.js#L496) ein
console.log(JSON.stringify(_objects[i]));einfügen - Dann kommen da gaaanz viele Ausgaben ... Bitte mal die Paar zeilen über dem Fehler posten wenn er wieder kommt
@apollon77 said in Neue Installationsroutine (für Linux):
bei mir unterscheiden sich die dateien ein wenig, es war zeile 489.. aber ich hab was du wolltest:
tended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448}} Server Objects 127.0.0.1:33568 Error from InMemDB: Error: EXEC without MULTI -
JS-Controller ist die 4.0.19?? (iob version)
4.0.18
achja:
ich hatte eben ein restore machen wollen, und dann kam die meldung: ~ iobroker restore /opt/iobroker/backups/2022_03_10-15_30_03_backupiobroker.tar.gz ✔ system iobroker controller daemon is not running host.Dok2012(SmartHome) OK. The current version of js-controller differs from the version in the backup. The js-controller version of the backup can not be restored automatically. To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.18 --production" inside your ioBroker directory If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag ~ ich hatte jetzt nochmal auf die 4.0.19 geselfupgraded, und jetzt kommt dieselbe meldung nochmal...
Naja mal paaaaaar Zeilen davor bitte mehr
{"id":"system.certificates","value":{"_id":"system.certificates","type":"config","common":{"name":"System certificates","icon":"data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgMUwzIDV2NmMwIDUuNTUgMy44NCAxMC43NCA5IDEyIDUuMTYtMS4yNiA5LTYuNDUgOS0xMlY1bC05LTR6bTAgMTAuOTloN2MtLjUzIDQuMTItMy4yOCA3Ljc5LTcgOC45NFYxMkg1VjYuM2w3LTMuMTF2OC44eiIvPg0KPC9zdmc+"},"native":{"certificates":{"defaultPrivate":"-----BEGIN RSA PRIVATE KEY-----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\r\nAHD96EOigyzYb6ffoGboUYt1/wzO2eSTC5xTsN+nYn/1lrhctXfDY30=\r\n-----END RSA PRIVATE KEY-----\r\n","defaultPublic":"-----BEGIN CERTIFICATE-----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\r\nNCQty6MoBZjgHRxcNYMtdjDT1GwUAvpucPS7Rd1abkRv7XOu45NngJrZKA==\r\n-----END CERTIFICATE-----\r\n"},"letsEncrypt":{"path":"letsencrypt","email":"","domains":""}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1536},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866479},"doc":{"_id":"system.certificates","type":"config","common":{"name":"System certificates","icon":"data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgMUwzIDV2NmMwIDUuNTUgMy44NCAxMC43NCA5IDEyIDUuMTYtMS4yNiA5LTYuNDUgOS0xMlY1bC05LTR6bTAgMTAuOTloN2MtLjUzIDQuMTItMy4yOCA3Ljc5LTcgOC45NFYxMkg1VjYuM2w3LTMuMTF2OC44eiIvPg0KPC9zdmc+"},"native":{"certificates":{"defaultPrivate":"-----BEGIN RSA PRIVATE KEY-----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\r\nAHD96EOigyzYb6ffoGboUYt1/wzO2eSTC5xTsN+nYn/1lrhctXfDY30=\r\n-----END RSA PRIVATE KEY-----\r\n","defaultPublic":"-----BEGIN CERTIFICATE-----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\r\nNCQty6MoBZjgHRxcNYMtdjDT1GwUAvpucPS7Rd1abkRv7XOu45NngJrZKA==\r\n-----END CERTIFICATE-----\r\n"},"letsEncrypt":{"path":"letsencrypt","email":"","domains":""}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1536},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866479}} {"id":"system.config","value":{"_id":"system.config","type":"config","common":{"name":"System configuration","city":"Trier","country":"Germany","longitude":"6.6441878","latitude":"49.7596208","language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":false,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":"stable","diag":"extended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448},"doc":{"_id":"system.config","type":"config","common":{"name":"System configuration","city":"Trier","country":"Germany","longitude":"6.6441878","latitude":"49.7596208","language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":false,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":"stable","diag":"extended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448}} Server Objects 127.0.0.1:33568 Error from InMemDB: Error: EXEC without MULTI ^Creicht das so? ich dachte, der fehler wäre in den letzten paar einträgen
achja:
@dokbiz said in Neue Installationsroutine (für Linux):
reicht das so?
in der konsole füllt das den kompletten monitor
wieviele zeilen willst du?? -
ich hab dir die mail geschickt!
falls das irgendwie relevanz hat: ich hab den iobroker noch lauffähig unter windows im zugriff
@dokbiz Nice one :-)) Bei dir war was "Zu schnell" und hast damit nen Bug gefunden :-)
Willst Du mal versuchen ob der Fix tut? :-)
Am Ende musst du diese Änderung machen https://github.com/ioBroker/ioBroker.js-controller/pull/1853/files
File suchst Du am besten mit
cd /opt/iobrokerund dann `find . -name redisHandler.js´ ich würde es erwarten in /opt/iobroker/node_modules/@iobroker/db-base/lib/redisHandler.js aber bei npm weiss man nie.Tut es danach?
Nice one :-))
Da freut er sich, dass ich alles kaputt bekomme... Das hatte ich auch selten
Also restore an sich lief nach der Korrektur der Datei (die übrigens genau dort lag, wo du sie vermutet hattest) fehlerfrei durch (soweit ich das beurteilen kann).
Vielen Dank schon mal dafür!!Ich komme allerdings nicht auf die Weboberfläche. und was mich auch wundert, ist, dass er dieses mal gar nicht wegen der Version 'gemeckert' hat.. iob -v ergibt 4.0.19, das Backup war 4.0.18
Nice one :-))
Nice one :-))
@dokbiz sagte in Neue Installationsroutine (für Linux):
Interessant ... müssen wir beobachten. Laut coce müssen sich die daten irgendwie doch einig gewesen sein :-)
