  4. Neue Installationsroutine (für Linux)
installation
415 Beiträge 64 Kommentatoren 189.4k Aufrufe 31 Beobachtet
  • apollon77A apollon77
    @dokbiz Und nochmal der vollständigkeit halber: JS-Controller ist die 4.0.19?? (iob version).
    Dann versuchen wir mal mehr rauszufinden:
    • Editiere mal /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js (ANnahme liegt auch bei dir, sonst Basispfad anpassen)
    • Über Zeile 496 (https://github.com/ioBroker/ioBroker.js-controller/blob/ef364284a964d6854558dc6ce16647f2993ed126/packages/controller/lib/setup/setupBackup.js#L496) ein console.log(JSON.stringify(_objects[i])); einfügen
    • Dann kommen da gaaanz viele Ausgaben ... Bitte mal die Paar zeilen über dem Fehler posten wenn er wieder kommt
    DokBiz
    #404
    @apollon77 said in Neue Installationsroutine (für Linux):
    4.0.18
    • D DokBiz
      bei mir unterscheiden sich die dateien ein wenig, es war zeile 489.. aber ich hab was du wolltest:
      tended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448}}
      Server Objects 127.0.0.1:33568 Error from InMemDB: Error: EXEC without MULTI
      #405
      @dokbiz Naja mal paaaaaar Zeilen davor bitte mehr :-)
        DokBiz
        #406
        @apollon77
        achja:
        ich hatte eben ein restore machen wollen, und dann kam die meldung:
            ~  iobroker restore /opt/iobroker/backups/2022_03_10-15_30_03_backupiobroker.tar.gz         ✔  system 
        iobroker controller daemon is not running
        host.Dok2012(SmartHome) OK.
        The current version of js-controller differs from the version in the backup.
        The js-controller version of the backup can not be restored automatically.
        To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.18 --production" inside your ioBroker directory
        If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
        ich hatte jetzt nochmal auf die 4.0.19 geselfupgraded, und jetzt kommt dieselbe meldung nochmal...
        {"id":"system.certificates","value":{"_id":"system.certificates","type":"config","common":{"name":"System certificates","icon":"data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgMUwzIDV2NmMwIDUuNTUgMy44NCAxMC43NCA5IDEyIDUuMTYtMS4yNiA5LTYuNDUgOS0xMlY1bC05LTR6bTAgMTAuOTloN2MtLjUzIDQuMTItMy4yOCA3Ljc5LTcgOC45NFYxMkg1VjYuM2w3LTMuMTF2OC44eiIvPg0KPC9zdmc+"},"native":{"certificates":{"defaultPrivate":"-----BEGIN RSA PRIVATE KEY-----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\r\nAHD96EOigyzYb6ffoGboUYt1/wzO2eSTC5xTsN+nYn/1lrhctXfDY30=\r\n-----END RSA PRIVATE KEY-----\r\n","defaultPublic":"-----BEGIN CERTIFICATE-----\r\nMIIDhzCCAm+gAwIBAgIJA2LvdSDDn+EXMA0GCSqGSIb3DQEBCwUAMD4xETAPBgNV\r\nBAMTCGlvYnJva2VyMRYwFAYDVQQKEw1pb0Jyb2tlciBHbWJIMREwDwYDVQQLEwhp\r\nb2Jyb2tlcjAeFw0yMjAzMDUxMzM3MzNaFw0yMzAzMDUxMzM3MzNaMEgxGzAZBgNV\r\nBAMTEkRvazIwMTIoU21hcnRIb21lKTEWMBQGA1UEChMNaW9Ccm9rZXIgR21iSDER\r\nMA8GA1UECxMIaW9icm9rZXIwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIB\r\nAQDajP4ZL+/xkmnymezAh5RJ15MML0pHS3xbLD5PTQ/FtvUHfLeW1pSSgVYPjR8z\r\nVWOwWdVsYoPzkjIHhk39iS4PvVnvU2BTEZFal2EPxbbf1oX9RccyN6HKqbQ5Zcn3\r\nquE/VBGPtgabirgwuyWRmDtlKQiHdnHrxy8iyyaE+U0yTUgY1vUaFQO1tdloYwy7\r\nHTKAjgKmAKN+5eXT7KrwrK5xkNZW5UdUmIbYZeDvtcsxZmbTaJ+5fKxIAfJ42KEC\r\n74wX9AlFCzL5MWD5fYziewpJlZY6gCdnVGlx2/1PYaM3Bsa99NBjPyIObsi1UCQD\r\naX8C3Gi9j2brnUPMIl1vJgBjAgMBAAGjfjB8MAwGA1UdEwEB/wQCMAAwDwYDVR0P\r\nAQH/BAUDAwe/gDASBgNVHREECzAJggdEb2syMDEyMB0GA1UdDgQWBBTL1nw9mS9e\r\nxfU4ppIdJHXr6Zib/zAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIwCQYD\r\nVR0jBAIwADANBgkqhkiG9w0BAQsFAAOCAQEAH+rVK8m7D6DXH229CHOi3ZtsjqtV\r\n4puDHKZC4eUI64c2ytIlZT0Jtc9lKMavpfhStnisoiStlaklVv4qjXijqWjZm+n7\r\n81fGyAz9RYlx0fuoA12fGstTquN7e6xr7U0rJ2oR0j8iNTSbTN/QdGVW5RYP5BUp\r\n5m6C93bhDaI0MQzsDsnCak/40woEMRLhO7KUdVGsHiHTdwO+X5wD2UtkQP1EiMxd\r\n9GjtTSVrH55WzSicEVUPeLv16e2vA5x1VQd1FSqFDnIGaqn0x3PMQl7/jjZuVwZ6\r\nNCQty6MoBZjgHRxcNYMtdjDT1GwUAvpucPS7Rd1abkRv7XOu45NngJrZKA==\r\n-----END CERTIFICATE-----\r\n"},"letsEncrypt":{"path":"letsencrypt","email":"","domains":""}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1536},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866479},"doc":{"_id":"system.certificates","type":"config","common":{"name":"System certificates","icon":"data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgMUwzIDV2NmMwIDUuNTUgMy44NCAxMC43NCA5IDEyIDUuMTYtMS4yNiA5LTYuNDUgOS0xMlY1bC05LTR6bTAgMTAuOTloN2MtLjUzIDQuMTItMy4yOCA3Ljc5LTcgOC45NFYxMkg1VjYuM2w3LTMuMTF2OC44eiIvPg0KPC9zdmc+"},"native":{"certificates":{"defaultPrivate":"-----BEGIN RSA PRIVATE KEY-----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\r\nAHD96EOigyzYb6ffoGboUYt1/wzO2eSTC5xTsN+nYn/1lrhctXfDY30=\r\n-----END RSA PRIVATE KEY-----\r\n","defaultPublic":"-----BEGIN CERTIFICATE-----\r\nMIIDhzCCAm+gAwIBAgIJA2LvdSDDn+EXMA0GCSqGSIb3DQEBCwUAMD4xETAPBgNV\r\nBAMTCGlvYnJva2VyMRYwFAYDVQQKEw1pb0Jyb2tlciBHbWJIMREwDwYDVQQLEwhp\r\nb2Jyb2tlcjAeFw0yMjAzMDUxMzM3MzNaFw0yMzAzMDUxMzM3MzNaMEgxGzAZBgNV\r\nBAMTEkRvazIwMTIoU21hcnRIb21lKTEWMBQGA1UEChMNaW9Ccm9rZXIgR21iSDER\r\nMA8GA1UECxMIaW9icm9rZXIwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIB\r\nAQDajP4ZL+/xkmnymezAh5RJ15MML0pHS3xbLD5PTQ/FtvUHfLeW1pSSgVYPjR8z\r\nVWOwWdVsYoPzkjIHhk39iS4PvVnvU2BTEZFal2EPxbbf1oX9RccyN6HKqbQ5Zcn3\r\nquE/VBGPtgabirgwuyWRmDtlKQiHdnHrxy8iyyaE+U0yTUgY1vUaFQO1tdloYwy7\r\nHTKAjgKmAKN+5eXT7KrwrK5xkNZW5UdUmIbYZeDvtcsxZmbTaJ+5fKxIAfJ42KEC\r\n74wX9AlFCzL5MWD5fYziewpJlZY6gCdnVGlx2/1PYaM3Bsa99NBjPyIObsi1UCQD\r\naX8C3Gi9j2brnUPMIl1vJgBjAgMBAAGjfjB8MAwGA1UdEwEB/wQCMAAwDwYDVR0P\r\nAQH/BAUDAwe/gDASBgNVHREECzAJggdEb2syMDEyMB0GA1UdDgQWBBTL1nw9mS9e\r\nxfU4ppIdJHXr6Zib/zAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIwCQYD\r\nVR0jBAIwADANBgkqhkiG9w0BAQsFAAOCAQEAH+rVK8m7D6DXH229CHOi3ZtsjqtV\r\n4puDHKZC4eUI64c2ytIlZT0Jtc9lKMavpfhStnisoiStlaklVv4qjXijqWjZm+n7\r\n81fGyAz9RYlx0fuoA12fGstTquN7e6xr7U0rJ2oR0j8iNTSbTN/QdGVW5RYP5BUp\r\n5m6C93bhDaI0MQzsDsnCak/40woEMRLhO7KUdVGsHiHTdwO+X5wD2UtkQP1EiMxd\r\n9GjtTSVrH55WzSicEVUPeLv16e2vA5x1VQd1FSqFDnIGaqn0x3PMQl7/jjZuVwZ6\r\nNCQty6MoBZjgHRxcNYMtdjDT1GwUAvpucPS7Rd1abkRv7XOu45NngJrZKA==\r\n-----END CERTIFICATE-----\r\n"},"letsEncrypt":{"path":"letsencrypt","email":"","domains":""}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1536},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866479}}
        {"id":"system.config","value":{"_id":"system.config","type":"config","common":{"name":"System configuration","city":"Trier","country":"Germany","longitude":"6.6441878","latitude":"49.7596208","language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":false,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":"stable","diag":"extended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448},"doc":{"_id":"system.config","type":"config","common":{"name":"System configuration","city":"Trier","country":"Germany","longitude":"6.6441878","latitude":"49.7596208","language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":false,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":"stable","diag":"extended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448}}
        ^C
        reicht das so? ich dachte, der fehler wäre in den letzten paar einträgen 🙈
        • D DokBiz
          @apollon77
          achja:
          ^C
          DokBiz
          schrieb am zuletzt editiert von DokBiz
          #407
          @dokbiz said in Neue Installationsroutine (für Linux):
          reicht das so?
          in der konsole füllt das den kompletten monitor 😕
          wieviele zeilen willst du??
          • D DokBiz
            reicht das so?
            #408
            @dokbiz Reicht so. Aber am besten schau mal PN und schicke es mir als email.
              DokBiz
              #409
              @apollon77
              ich hab dir die mail geschickt!
              falls das irgendwie relevanz hat: ich hab den iobroker noch lauffähig unter windows im zugriff
              apollon77A 2 Antworten Letzte Antwort
              • D DokBiz
                @apollon77
                #410
                @dokbiz Wir versuchen mal
                • D DokBiz
                  @apollon77
                  #411
                  @dokbiz Nice one :-)) Bei dir war was "Zu schnell" und hast damit nen Bug gefunden :-)
                  Willst Du mal versuchen ob der Fix tut? :-)
                  Am Ende musst du diese Änderung machen https://github.com/ioBroker/ioBroker.js-controller/pull/1853/files
                  File suchst Du am besten mit cd /opt/iobroker und dann `find . -name redisHandler.js´ ich würde es erwarten in /opt/iobroker/node_modules/@iobroker/db-base/lib/redisHandler.js aber bei npm weiss man nie.
                  Tut es danach?
                    Tut es danach?
                    DokBiz
                    #412
                    Nice one :-))
                    Da freut er sich, dass ich alles kaputt bekomme... Das hatte ich auch selten 😂
                    Also restore an sich lief nach der Korrektur der Datei (die übrigens genau dort lag, wo du sie vermutet hattest) fehlerfrei durch (soweit ich das beurteilen kann).
                    Vielen Dank schon mal dafür!!
                    Ich komme allerdings nicht auf die Weboberfläche. und was mich auch wundert, ist, dass er dieses mal gar nicht wegen der Version 'gemeckert' hat.. iob -v ergibt 4.0.19, das Backup war 4.0.18
                    D apollon77A 2 Antworten Letzte Antwort
                    • D DokBiz
                      Nice one :-))
                      DokBiz
                      #413
                      @dokbiz
                      Update:
                      nach
                      iobroker stop
                      iobroker host this
                      iobroker fix
                      iobroker start
                      komme ich auf die Oberfläche und sehe zumindest schon mal meine ganzen Instanzen 👏 😍
                      • D DokBiz
                        Nice one :-))
                        #414
                        @dokbiz sagte in Neue Installationsroutine (für Linux):
                        Interessant ... müssen wir beobachten. Laut coce müssen sich die daten irgendwie doch einig gewesen sein :-)
                        • apollon77A Offline
                          #415
                          js-controller 4.0.20 kommt später heute in Beta ... da sollte das dann generell gefixt sein.
