  4. js-controller 4.0.x jetzt für alle User im STABLE!
501 Beiträge 83 Kommentatoren 214.5k Aufrufe 58 Beobachtet
  • padrinoP padrino
    So, wollte eigentlich erstmal auf 3.3 upgraden, hab aber nicht mitbekommen, dass V4 im Stable ist... Also hat das System automatisch versucht V4 zu installieren.
    Ergebnis, mein iob ist hin. :(
    Installation spuckte nach gut 5 Minuten folgendes aus:
    pi@raspberrypi:/opt/iobroker $ iobroker upgrade self
    Update js-controller from @3.1.6 to @4.0.15
    NPM version: 6.14.15
    npm install iobroker.js-controller@4.0.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../../nan/nan.h:56,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
     Objects 127.0.0.1:59278 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
     States 127.0.0.1:60766 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
     Objects 127.0.0.1:59278 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
     Objects 127.0.0.1:59278 Error from InMemDB: Error: scan NOT SUPPORTED
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    ReplyError: Error scan NOT SUPPORTED
        at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
        at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    Emitted 'error' event on ScanStream instance at:
        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        at processTicksAndRejections (internal/process/task_queues.js:97:5) {
      command: {
        args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@4.0.15 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.15 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-02-28T19_25_50_415Z-debug.log
    host.raspberrypi Cannot install iobroker.js-controller@4.0.15: 1
    iobroker start bleibt nun still, sprich admin nicht erreichbar...
    gebe ich nur iobroker ein kommt
    internal/modules/cjs/loader.js:818
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
        at Function.Module._load (internal/modules/cjs/loader.js:667:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Ich weiß schon, wieso ich normal nach dem Prinzip "never change a running system" handele, denn, wenn wie jetzt was schief geht steht man als noob wie der Ochs vorm Scheunentor. :(
    Thomas BraunT
    Thomas BraunT
    #119
    @padrino sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
    Der dämliche Spruch hat sich jetzt genau in die Situation gebracht.
    Je größer die Versionssprünge werfen umso heikler wird das u.U.
    iobroker status
    sagt? Aber besser in einem eigenen Thread.
      iobroker status
      padrinoP
      padrinoP
      padrino
      #120
      @thomas-braun sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
      Naja, es lief ja vor dem Update... was ja unbestritten ist. 🤷
      Sollte dann nicht der Installer das berücksichtigen und erstmal "klein" updaten, oder einem dazu raten?
      Auf jeden Fall, hat mir jetzt ein
      npm install iobroker.js-controller@3.3
      mir iob wohl erstmal wieder zum Laufen gebracht.
      • padrinoP padrino
        Thomas BraunT
        Thomas BraunT
        #121
        @padrino
        Dann kannst du ja jetzt das System auf Stand bringen. Ich würde mit nodeJS anfangen und das auf v14 bringen.
        • padrinoP padrino
                  throw e;
            command: {
          npm ERR! errno 1
          npm ERR!
            throw err;
            requireStack: []
          apollon77A
          apollon77A
          #122
          @padrino Ok, lösung ist sehr einfach: Nicht "iob uplgrade self nehmen" ... ALso fix durchcontroller per npm drüberbügeln :-)
          • iobroker stoppen
          • cd /opt/iobroker
          • npm iobroker.js-controller@4.0.15 --production
          • iobroker starten
          • S
            S
            sandro_gera
            schrieb am zuletzt editiert von sandro_gera
            #123
            Hallo an alle,
            auf meine Slave Raspberry 3b hat das update wunderbar funktioniert.
            Leider bekomme ich schon beim Backup auf meine Master, Raspberry 4, folgende Fehlermeldung.
            pi@RaspBerry4BioBroker:~ $ iob backup
            Server Objects 192.168.178.16:45850 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["set","notify-keyspace-events","Exe"]
            Server Objects 192.168.178.16:45850 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
            Server Objects 192.168.178.16:45850 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
            Server Objects 192.168.178.16:45856 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace cfg.: Data=["meta.*"]
            host.RaspBerry4BioBroker 7321 states saved
            host.RaspBerry4BioBroker 8839 objects saved
            Server Objects 192.168.178.16:45856 Error from InMemDB: Error: subscribe NOT SUPPORTED
            Server States 192.168.178.16:56964 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
            Server States 192.168.178.16:56966 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
            Backup created: /opt/iobroker/backups/2022_03_01-11_17_31_backupiobroker.tar.gz
            Die ip Adress von meinem Slave ist die 192.168.178.16 der Master hat die 17.
            Ich habe wie immer zuerst den Slave geupdatet.
            Ich blick da nicht durch und hoffe mir kann jemand helfen.
            Ich hab IOBroker auf dem Slave gestopt.
            Danach lief das bachup auf dem Master durch.
            Allerdinge bekomme ich beim Upate des Masters jetzt folgende Fehlermeldung.
            pi@RaspBerry4BioBroker:~ $ iob upgrade self
            Update js-controller from @3.3.22 to @4.0.15
            NPM version: 6.14.16
            /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
            /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
            Server Objects 127.0.0.1:36656 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
            Server States 127.0.0.1:56862 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
            Server Objects 127.0.0.1:36656 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
            Server States 127.0.0.1:56864 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
            Server Objects 127.0.0.1:36656 Error from InMemDB: Error: Unknown LUA script load
            Server Cannot move /opt/iobroker/iobroker-data/objects.json.new to /opt/iobroker/iobroker-data/objects.json: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json.new'. Try direct write as fallback
            Master RPI4 8GB, Slave RPI3 1GB
            Node.js v18.17.1, npm: 9.6.7,
            JS-Controller: 5.0.16
            • S sandro_gera
              Hallo an alle,
              apollon77A
              apollon77A
              #124
              @sandro_gera Ok, nochmal langsam:
              Zum "Fehler bei Backup": Du hast einen Slave aktualisiert und machst dann ein backup auf dem Slave der damit noch gegen einen "alten" Master verbunden ist? Ja, dann sind solche Meldungen zu erwarten, sollten aber egal sein, kannste also ignorieren.
              Das Update auf dem master sieht an sich auch ok aus ... bzw ... bleibt er da hängen oder ist das die ganze Ausgabe und danach war ok?? Aber auch hier sind diese Meldungen zu erwarten ...
              S matthscM 2 Antworten Letzte Antwort
              • apollon77A apollon77
                S
                S
                sandro_gera
                #125
                @apollon77
                Danke Apollon, es sieht so aus als ob des update auch auf dem Master funktioniert hat.
                Ich werd das mal beobachten und falls in den Protokollen was auftaucht was ich nicht verstehe melde ich mich wieder.
                  matthscM
                  matthscM
                  matthsc
                  #126
                  Ich habe mein Master/Slave System problemlos von 3.3.22 auf 4.0.15 aktualisiert.
                  Master: RPi 4
                  Slaves: 2x RPi Zero (nur BLE Adapter)
                  Redis als State-DB
                  Alle Systeme laufen unter Dietpi/Debian Buster mit NodeJS 14 / NPM 6
                  • Michael SchmittM Michael Schmitt
                    @apollon77
                    wie werde ich diese Meldungen los? Kommen nach dem update
                    2022-02-25 22:31:24.720 - warn: deconz.0 (12037) Object Groups.9.xy is invalid: Default value has to be stringified but received type "object"
                    2022-02-25 22:31:24.721 - warn: deconz.0 (12037) This object will not be created in future versions. Please report this to the developer.
                    2022-02-25 22:31:28.989 - warn: deconz.0 (12037) Object Groups.9.xy is invalid: Default value has to be stringified but received type "object"
                    2022-02-25 22:31:28.990 - warn: deconz.0 (12037) This object will not be created in future versions. Please report this to the developer.
                    H
                    H
                    hausautomation.digital
                    #127
                    @michael-schmitt said in js-controller 4.0.x jetzt für alle User im STABLE!:
                    @apollon77
                    Geht mir genau so. Gibts da schon eine Lösung??
                    Michael SchmittM 1 Antwort Letzte Antwort
                    • H hausautomation.digital
                      @apollon77
                      Michael SchmittM
                      Michael SchmittM
                      Michael Schmitt
                      schrieb am zuletzt editiert von Michael Schmitt
                      #128
                      @hausautomation-digital
                      installiere mal von NPM die Version 1.3.20 (für deconz)
                        Hallo ioBroker-Community,
                        nach längerer Entwicklungszeit kommt heute der neue js-controller 4.0 (Releasename "Isabelle") für alle User ins Stable Repository (sollte im laufe des Abends bei allen auftauchen). Dieser Artikel enthält alle wichtigen Infos zu diesem Release und im zweiten Post eine kleine FAQ.
                        Ich bedanke mich bei allen fleißigen Testern der Community während der Beta Phase!
                        Node.js Versions-Anforderungen
                        In diesem Release entfällt Node.js 10.x, welches seit April letztem Jahr nicht mehr gepflegt wird. Node.js 16.x ist dazugekommen. Die unterstützten Node.js Versionen sind damit: 12.x, 14.x und 16.x. Die empfohlene Node.js Version für ioBroker heben wir mit diesem Release auf 14.x an (siehe auch https://forum.iobroker.net/topic/49480/node-js-10-x-ist-tot-es-lebe-node-js-14). Node.js 16.x wird mit js-controller 4.0 nun auch mit npm 7 bzw. 8 unterstützt.
                        Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/44566/how-to-node-js-für-iobroker-richtig-updaten-2021-edition . Infos ebenso hier in der FAQ hier im Thread.
                        Informationen zur Version
                        Neben einigen Optimierungen und Verbesserungen stand der Haupt-Fokus dieser Version auf Performance-Verbesserungen. Ein paar neue Features sind aber ebenfalls hinzugekommen. Auch daran den Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen wurde weiter gearbeitet, was ggf. zu neuen Log-Meldungen für bestimmte Fälle führt. Bitte unterstützt hier wieder und legt bei den relevanten Adaptern im GitHub Issues an, damit diese Dinge gefixt werden können.
                        Mit dem js-controller 4.0 wird intern die Datenbank von "file" auf "jsonl" umgestellt. Dies geschieht bei der Installation automatisch ohne weitere Aktionen, wenn file genutzt wird. Weitere Details dazu sieht in der FAQ (Post #2)! Nach erfolgter Migration erscheint beim nächsten Öffnen (oder Reloads falls offen) des Admin5 auch eine Information dazu:
                        Für Redis Installationen haben wir ein Problem entdeckt, welches von der betriebssystem-Konfiguration von dem Host abhängt wo der Redis-Server drauf läuft. Wer also Redis als Datenbank nutzt bitte unter https://forum.iobroker.net/topic/52976/wichtiger-hinweis-für-redis-installationen nachsehen und sein System prüfen und potentiell beheben.
                        Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog.
                        In Summe sind in dieser Version wieder über 120 Änderungen in über 450 commits eingeflossen. Dafür bedanke mich diesmal wieder besonders bei foxriver76, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern für die aktive Mitarbeit an dieser Version!
                        Der js-controller 4.0 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 4.0 idealerweise ein Update auf die 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 12.x sein, wie oben bereits ausgeführt.
                        Aktuell ist nur node-red <2.4.2 inkompatibel, aber es gibt noch einige Versions-Empfehlungen weiter unten.
                        Installation
                        VOR der Installation
                        Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw. kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Eine alte 3.3.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen, vorher ins ioBroker Verzeichnis wechseln cd /opt/iobroker) installiert werden und sollte alles wieder herstellen.
                        Für die User, welche die experimentelle JSONL-Datenbank bereits einsetzen, ändert sich nichts - ausser das dieser Datenbank-Typ nun die offizielle ist :-)
                        Nötige Adapter-Aktualisierungen
                        Aktuell sind drei Adapter bekannt, welche aktualisiert werden müssen bzw. sollten:
                        • Backitup sollte auf 2.3.3+ aktualisiert sein, damit vor allem Restores mit js-controller 4 sauber funktionieren
                        • Admin sollte auf 5.3.1+ aktualisiert sein, damit alle Settings für den js-controller 4 korrekt editiert werden können
                        • Node-Red muss auf Verson 2.4.2 aktualisiert sein, da der Adapter sonst nicht funktioniert
                        • km200 (see https://github.com/frankjoke/ioBroker.km200/issues/69): Fix is described in https://forum.iobroker.net/post/760260
                        • systeminformation Am Ende der gleiche wie wie direkt oben drüber bei km200
                        Am besten dennoch VOR dem js-controller Update alle verfügbaren Adapter-Updates prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 4.0 hinweisen.
                        Es werden aber, wie oben ausgeführt, einige Adapter ggf. Warnungen ins Log schreiben - und ggf kommen ein paar neue dazu, welche aber primär bei Objektanlagen interessant sind und weniger im Betrieb "nerven". Meldungen die vor dem Upgrade im Log waren sind jetzt auch noch da.
                        Bitte zuerst versuchen die gemeldeten Objekt-IDs via Admin zu löschen und den Adapter neu zu starten. Wenn die Meldungen danach nicht weg sein sollten ist aktuell die einzige Option das Loglevel der betroffenen Instanz auf "Warning" zu setzen - aber erst nachdem die Logs idealerweise in einem GitHub-Issue beim entsprechendem Adapter gemeldet wurden!
                        Achtung: MASTER-Systeme Reihenfolgen beachten!
                        Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.x läuft, ist es beim Update auf Version 4.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                        Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 4.0 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Beim Slave Update muss der alte Master aber noch laufen. Die Slaves bleiben nach dem Update offline und können sich nicht zum Master verbinden und werden erst wieder funktionieren wenn auch der Master auf die 4.0 aktualisiert wurde!
                        Windows
                        Aus der Community kommt von @sigi234 eine Anleitung für ein Windows Update https://forum.iobroker.net/topic/51574/windows-installation-update
                        Für alle "alten manuellen" Installationen gilt
                        • iobroker update
                        • ioBroker muss gestoppt sein.
                        • Vor dem Update bitte prüfen das keine Prozesse mehr laufen
                        • iobroker upgrade self
                        • ioBroker starten
                        Linux
                        ACHTUNG: Wer von einer kleineren js-controller Version als 3.2 kommt, sollte direkt per npm installieren und NICHT per iob uograde self!!
                        • iobroker update (Repository aktualisieren)
                        • iobroker stop
                        • prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
                        • iobroker fix (Alle Rechte im Dateisystem, Linux-Pakete u.ä. aktualisieren)
                        • iobroker upgrade self (Ausführung des Updates)
                        • iobroker start
                        Die Installation wird - wenn Sie von einem 2.x/3.x-System aus erfolgt - einige Warnungen/Fehler loggen. Wenn diese aussehen wie im folgenden Bild gezeigt (GET/SET-UNSUPPOTED bzw LUA script load error), ist dies erwartet und ok!
                        Server Objects 127.0.0.1:37942 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                        Server Objects 127.0.0.1:37942 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                        Server States 127.0.0.1:60678 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                        Server States 127.0.0.1:60680 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                        Server Objects 127.0.0.1:37942 Error from InMemDB: Error: Unknown LUA script load
                        Server Objects 127.0.0.1:37942 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                        Server Objects 127.0.0.1:37942 Error from InMemDB: Error: multi NOT SUPPORTED
                        Server Objects 127.0.0.1:37942 Error from InMemDB: Error: sadd NOT SUPPORTED
                        Server Objects 127.0.0.1:37942 Error from InMemDB: Error: exec NOT SUPPORTED
                        Wichtig: Falls es bei Updates von js-controller 3.2.x bei update oder upgrade einen Fehler gibt "No connection to database" dann bitte nochmals versuchen und wenn es wieder passiert folgende Schritte ausführen:
                        • Editiere /opt/iobroker/iobroker-data/iobroker.json
                        • Unter objects und states gibt es jeweils ein ' "connectTimeout": 2000,`
                        • Zahl ändern auf 5000
                        • Neu versuchen
                        • Der Wert kann so bleiben weil er eh beim js-controller 4 der neue Standardwert ist
                        Bei Fehlern:
                        Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                        Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
                        Die Installation kann ggf. Warnungen ausspucken über potentiell "deprecated" NPM Module oder Compiler-Warnungen oder (bei optionalen Paketen auch -Fehler) anzeigen (z.B, unix_dgram, serialport, pam_authentication und ggf andere). Hier gilt wie immer: Ignorieren :-)
                        Ebenso eine Aufforderung "npm audit fix" auszuführen kann ignoriert werden!
                        NACH der Installation
                        Nach der Installation sollte der ioBroker automatisch wieder starten. Falls doch nicht bitte mittels iobroker start starten.
                        Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
                        Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                        Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt.
                        BREAKING CHANGES
                        • Support for Node.js 10 is dropped! Supported are Node.js 12.x, 14.x and 16.x
                        • CLI command iob update --updateable changed to iob update --updatable
                        • CLI command iob update http://download.iobroker.net/sources-dist.json is not supported anymore
                        • CLI command iob rebuild adaptername is no longer supported because of the new way of automatic rebuilds and some unwanted side effects
                        • CLI command iob state get <id> will no longer handle binary state values (which was never really working before). We added iob state getBinary <id> <encoding> as new way.
                        • Ensure that on a backup-restore the same adapters and adapter versions are restored as existing on backup time. Also check js-controller version and error on mismatch (is allowed to be forced accepted by --force parameter for restore)
                        • The "file" database will be automatically converted into JSONL and the database types that use "file" are adjusted to "jsonl" on installation (and backup restore). This means that a rollback of js-controller is only possible to 3.3 after 4.0 was installed! Rollback to former versions require a manual migration to "file" DB before the downgrade! (COMMUNICATION, TESTFOKUS)
                        Hier für Interessierte als Spoiler noch alle weiteren Änderungen als Zusammenfassung:
                        Features
                        • (bluefox) Added complexity rules for user passwords: New created passwords need to follow the following rules (TODO ADMIN UI INFO ISSUE):
                          • minimum length is 8
                          • contains at least one digit
                          • contains at least one lower case letter
                          • contains at least one upper case letter
                        • (foxriver76) Introduce option "--custom" when deleting instances or adapter to also clean up relevant custom entries from all objects (TODO ADMIN ISSUE ADD CHECKBOX!, TESTFOKUS)
                        • (foxriver76) Added new host objects to provide Node.js version and PID
                        • (foxriver76) Updated the Linux capabilities on js-controller start when a Node.js version change was detected (and initial on first run)
                        • (AlCalzone/foxriver76) Further optimize strategy for required Node.js module rebuilds. We first try to run rebuild in root package and if still packages are left (or it fails) we try to rebuild the really affected modules alone. Should give better results then former strategy (TESTFOKUS)
                        • (bluefox) Added support for configuring multiple repositories (TODO LINK+INFO FLAG)
                        • (Apollon77) Streamline logging configuration for all available transports: A set Loglevel in config means that this loglevel is pinned for the transport for all cases. An Empty/not set level ("Default" in Admin) means that logging is dynamic and can be adjusted per Instance controller or loglevel state on the fly.
                        • (foxriver76) Added installedFrom info to adapter start log line when not installed from npm normally
                        Optimizations and Fixes
                        • (Apollon77/foxriver76) Improve performance of object deletions (also when deleting instances or adapters) significantly (file-db 4x faster, jsonl-db 14x faster, redis 360x% !! faster)
                        • (foxriver76/Apollon77) Improve performance for redis object searches by up to 2,5x by using lookup structures for object types and custom object properties. This optimization is only active for single host redis systems automatically, but can be activated for multihost redis systems too after all hosts are (and stay!) on js-controller 4.0! (TODO DOCS)
                        • (foxriver76/Apollon77) Improve performance for object searches in general by limiting search namespaces to the relevant ones automatically
                        • (foxriver76) Improve handling of backup restores when custom hostnames were used (especially relevant for Docker usage)
                        • (foxriver76) Optimize backup to make sure invalid user-generated JSONs do not prevent backups from being considered valid
                        • (foxriver76/klein0r) Improved CLI help
                        • (foxriver76) Preserve changed instance names also when updating adapter (name was reset before)
                        • (foxriver76) stop adapters on Windows prior update to prevent EBUSY
                        • (foxriver76) Prevent crashes for uploads with invalid adapter installations
                        • (bluefox) Removed news from instance/adapter objects on install/update because taken from repository in Admin5 (TODO CHECK ADMIN4 EFFECTS)
                        • (AlCalzone) Removed extraneous "npm install" inside adapter directory
                        • (foxriver76/AlCalzone) reduce JSONL compression frequency to reduce I/O (relevant when experimental JSONL database modules are used)
                        • (foxriver76) prevent uploading js-controller (creating system.adapter.js-controller object) and remove existing cases on setup first
                        • (foxriver76) prevent crash when multihost password is invalid and multihost active
                        • (bluefox/foxriver76) bigger internal refactorings in cli commands (TESTFOKUS)
                        • (foxriver76) made logging of not fulfilled adapter dependencies more user-friendly
                        • (foxriver76) Check user and group assignments and remove unknown users from groups (could have happened in earlier versions) in setup first
                        • (foxriver76) Prevent crash on adapter install/update if version string in repo is invalid
                        • (AlCalzone) Update and optimize JSONL database integration and configuration options
                        • (foxriver76) make sure that settings for file/jsonl DB in configfile are also respected
                        • (foxriver76) Update seq integration for logging
                        • (foxriver76) If logging can not be initialized because of a fatal error do not start js-controller
                        • (foxriver76) Prevent start of a debug session for an instance that is already running
                        • (Apollon77) Fix an edge case for file db which could lead to main and backup file being broken in strange situations with multiple crashes in a row
                        • (foxriver76) make sure that admin, backitup and discovery instances are created when update of controller happens if installed and no instance exists
                        • (Apollon77) Optimize Stop Handling to prevent errors
                        • (Apollon77) Optimize Adapter process initialization to prevent edge case errors
                        • (foxriver76) Optimize meta object sync
                        • (Apollon77) make sure to really end CLI process when they should end in error cases
                        • (Apollon77) catch error when streaming data to stdout and this is closed already
                        • (Apollon77) Optimize some special cases on adapter start
                        • (AlCalzone) Prevent issues when backup interval is configured with invalid values
                        • (AlCalzone) Prevent db-file-locking issues for jsonl database; the connectTimeout for databases is now minimum 5s (overrides lower values from configuration)
                        • (foxriver76) allow instance deletion when executed from an other host
                        • (foxriver76) stop the database before executing upgrade self; Will be effective for all upgrades >4.0.5
                        • (Apollon77/foxriver76) Optimize database initialization and destroys
                        • (Apollon77) Update winston-syslog to prevent errors
                        • (Apollon77, foxriver76, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
                        Developer relevant DEPRECATIONS/WARNINGS
                        • js-controller is no longer installable from GitHub because is now a monorepo. Use @dev tag on npm to get the nightly build of master js-controller!
                        • log info when setState is used for an object of type file - use setBinaryState instead!
                        • log info when default value of an object is invalid (e.g. does not match object type)
                        • log info when common.states is used and not an object (deprecate String usage)
                        • log info when common.min/common.max exists on non numbers and contain invalid values/types
                        • add get/setForeignBinaryState methods as copy from get/setBinaryState allow adapter to migrate; get/setBinaryState will be changed in 4.1 to be "non Foreign"
                        • Enhanced object checks: adapter need to have a name as string
                        • Decline calls for getForeignObjects with non string pattern (was pot. crashing before)
                        • adapter.tools is deprecated and replaced by a shim. Use methods in adapter class or adapter-core instead or open issues if you need more internal functions
                          The object view definition "custom/state" is now removed from js-controller after being replaced by "system/custom" in js-controller 3.3. All relevant adapters are updated (COMMUNICATION)
                        • remove all Fifo Methods from adapter.js because deprecated since 1.x
                        • remove adapter.objects.* methods because deprecated since 2.x
                        Developer relevant new Features
                        • (jogibear9988) Add new "unload-safe" promise based "adapter.delay" method to delay further code execution, but still make sure code do not continue after unload was called. This method can not be used inside the "unload" method itself!
                        • (jogibear9988/AlCalzone/foxriver76/Apollon77) Revamp adapter.*Timeout and adapter.*Interval methods to be "unload-safe" and also clear missing timeouts without warnings for more developer convenience! The methods to set a timeout or interval can not be used inside the "unload" method itself!
                        • (foxriver76) Allow to set "null" for common.states and not log error for object (also for extend)
                        • (AlCalzone) Introduce new methods in tools for Node.js module management: installNodeModule, uninstallNodeModule (TODO Issues adapter that use npm install -> Move))
                        • (bluefox) Add license management functionality to host. Adapters can use adapter.getSuitableLicenses to get available relevant licenses (TODO DOCS)
                        • (AlCalzone) Switch NPM relevant handling to library pak to be more flexible for the future which package manager we want to use. Important: There are still parts that rely on npm for now!
                        • (bluefox) Also report docker info when sending diag data
                        • (foxriver76) Add server time to getHostInfo message
                        • (foxriver76) For multihost clusters with js-controller 4.0+ the hosts automatically determine a "primary" host that can be used js-controller internally (right now, preparation for future topics)
                        • (Apollon77) Add database types to crash data reported to sentry
                        Developer relevant Optimizations and Fixes
                        • (foxriver76) fixed permissionError on setBinaryState
                        • (foxriver76) preserve "native" content for instanceObjects when updating the objects on adapter start
                        • (Apollon77/foxriver76) Limit the search scope for object types host, adapter, instance, instanceStats, enum, script, group, user, config to the relevant namespaces when no search start/end is provided to speedup these calls in general
                        • (foxriver76) Optimize deleteDevice/deleteChannel methods to just delete all objects the relevant device/channel
                        • (foxriver76) Removed some magic path lookups to be compatible to npm 7/8. Appname of controller is now always "iobroker" ("ioBroker" in dev cases)
                        • (foxriver76) Also use Sentry (if enabled/allowed) in CLI commands whenever database is initialized to report crashes from CLI if they happen
                        • (foxriver76) Introduce a database protocol version number to allow detection of the available database features in multihost environments
                        • (bluefox) Prevent issues when using adapter.addChannelToEnum because of missing callback
                        • (foxriver76) make sure autoSubscribe works as expected in all cases
                        • (Apollon77) Correctly return null when a session is expired
                        • general dependency updates
                        • code style optimizations and streamline code
                        Wie Fehler melden?
                        Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
                        Bitte checkt auch die "Known issues Liste" (zweiter Post) mit den Dingen die aktuell während dem Beta-Test bekannt sind und bis zum Release noch angepasst werden.
                        Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
                        Wir wünschen allen viel Spaß mit der neuen Version des js-controller.
                        Ingo
                        D
                        D
                        darkiop
                        #129
                        @apollon77
                        Hi Ingo, mir ist grad aufgefallen, das nach dem Upgrade auf v4 die Disk IO, CPU Last, Ram Bedarf vom Redis LXC gestiegen ist. Der Zeitpunkt des Anstiegs passt genau zum Upgrade-Zeitpunkt.
                        redis-cli 6.0.11
                        js-controller 4.0.15
                        node 14.19.0
                        npm 6.14.16
                        Hast ne Idee?
                        ioBroker Object Explorer: https://forum.iobroker.net/topic/84117/iobroker-object-explorer-dashboard-zum-verwalten-von-dps?_=1789113045261 | Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                        • D darkiop
                          @apollon77
                          redis-cli 6.0.11
                          node 14.19.0
                          npm 6.14.16
                          Hast ne Idee?
                          apollon77A
                          apollon77A
                          #130
                          @darkiop interessant. So einen Effekt hatte ich noch nicht gesehen was sind das für Werte? AVG über welchen Zeitraum? Was genau ist im redis drin? Also mit einem So geringen Memory footprint vor dem Update war das nur States? Ich würde das da zuerst mal ansetzen was da ggf dazugekommen ist. Weil klar. Mit mehr Daten wird mehr gespeichert und so weiter. Dann sind wir wieder bei der eingestellten persistent.
                          Aber mal mehr Details: objects und States? Oder nur States? Lass es aber am besten in eigenen thread auslagern
                          Bzw auch: da ist 20:33 ein setup custom … was hast du da getan??? Was war vorher? Was nachher?
                            D
                            D
                            darkiop
                            #131
                            @apollon77
                            Glaub ich leg mich direkt ins Bett. Besch... Tag - eben hats dann geklingelt. Ich hatte kurz nach dem v4 Upgrade auch die Objects auf redis umgestellt - vorher waren es nur die States. Hab das eben nochmal in einer iobroker.json von vorm dem Upgrade Zeitpunkt gegengeprüft ;)
                            Zur Vollständigkeit: Das Chart war ein AVG/Month
                            Muss dann vielleicht auch mal schauen ob ich auf Redis AOF umstelle.
                            PS: Du erinnerst dich an meinen zerstörten GlusterFS Arbiter USB Stick? Ich würd mal vermuten das die Aktivierung von redis@objects ihm den erst gegeben haben :D
                            • D darkiop
                              @apollon77
                              apollon77A
                              apollon77A
                              #132
                              @darkiop hehe. Dann haste deinen Grund.
                              Aber ja auch meine Erkenntnisse sagen: für nur States ist rdf I/o schonender mit sinnvollen settings als aof. Wenn objects ist ganz klar aof das einzig sinnvolle !
                              • leuchtfuchsL
                                leuchtfuchsL
                                leuchtfuchs
                                #133
                                Bei mir hat das Update nicht geklappt. Bekomme diesen Fehler. IOB startet nicht.
                                pi@iobroker-pi:~ $ node -v
                                v14.19.0
                                pi@iobroker-pi:~ $ npm -v
                                6.14.16
                                pi@iobroker-pi:~ $ iob status
                                Uncaught Rejection: TypeError: Cannot read property 'warning' of undefined
                                    at ObjectsInMemoryServer.initBackupDir (/opt/iobroker/node_modules/@iobroker/db-base/lib/inMemFileDB.js:187:22)
                                    at new InMemoryFileDB (/opt/iobroker/node_modules/@iobroker/db-base/lib/inMemFileDB.js:83:18)
                                    at new ObjectsInMemoryFileDB (/opt/iobroker/node_modules/@iobroker/db-objects-file/lib/objects/objectsInMemFileDB.js:34:9)
                                    at new ObjectsInMemoryJsonlDB (/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/lib/objects/objectsInMemJsonlDB.js:58:9)
                                    at new ObjectsInMemoryServer (/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/lib/objects/objectsInMemServerRedis.js:57:9)
                                    at new ObjectsInMemoryServerClass (/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/lib/objects/objectsInMemServerClass.js:34:30)
                                    at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3123:27)
                                pi@iobroker-pi:~ $ iob version
                                4.0.15
                                • leuchtfuchsL leuchtfuchs
                                  v14.19.0
                                  6.14.16
                                  4.0.15
                                  apollon77A
                                  apollon77A
                                  #134
                                  @leuchtfuchs Da bist Du in ein Konfigprobkem und nen Mini Code-Fehler gerannt :-)
                                  Dein problem ist das das Backup Interval der DB bei dir falsch konfiguriert ist.
                                  Quick Fix: Editiere /opt/iobroker/iobroker-data/iobroker.json und schaue das bei objects bzw states das in "backup" das "period" eine Zahl in SEKUNDEN ist ... Der Standard Wert ist 120 (=2h) ... Du hast da irgendeinen viel zu hohen Wert drin.
                                    liv-in-skyL
                                    liv-in-skyL
                                    #135
                                    @apollon77
                                    hilfe - bitte
                                    • iobroker crash der sd karte mit js-cont 3.x
                                    • neue karte, neue installlation - es ist jetzt js-cont. 4.x
                                    • haben iob setup costum ausgeführt und auf file umgestellt - wollten restore machen
                                    • nschliessend sudo npm i iobroker.js-controller@3.3.22 --production
                                    geht nicht - es kommt fehler:
                                    pi@homebridge:/opt/iobroker $ sudo npm i iobroker.js-controller@3.3.22 --production
                                    > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                    > node lib/preinstallCheck.js
                                    > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
                                    Cannot write file. Not critical: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../reinstall.js'
                                    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
                                    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                                    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
                                    internal/fs/utils.js:332
                                        throw err;
                                    Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                                        at Object.mkdirSync (fs.js:1013:3)
                                        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:835:16)
                                        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:487:23)
                                        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2912:5)
                                        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
                                        at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                        at Module.load (internal/modules/cjs/loader.js:950:32)
                                        at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                                        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12) {
                                      errno: -13,
                                      syscall: 'mkdir',
                                      code: 'EACCES',
                                      path: '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                                    was muss ich machen, damit ich den restore fahren kann ?
                                    @Damrak2022
                                    • liv-in-skyL liv-in-sky
                                      @apollon77
                                      hilfe - bitte
                                          throw err;
                                        errno: -13,
                                        syscall: 'mkdir',
                                        code: 'EACCES',
                                      @Damrak2022
                                      Thomas BraunT
                                      Thomas BraunT
                                      #136
                                      @liv-in-sky sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                                      sudo npm
                                      Bitte
                                      verwenden.
                                        sudo npm
                                        Bitte
                                        verwenden.
                                        liv-in-skyL
                                        liv-in-skyL
                                        #137
                                        erstmal danke - bitte genau erklären - haben das ganze wieder auf js-c 4.x gebracht und mit jsonl
                                        wie genau müssen wir vorgehen - wieder zuerst iob setup costum
                                        und was dann
                                        sudo -H -u iobroker npm  i iobroker.js-controller@3.3.22 --production
                                        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                                          und was dann
                                          Thomas BraunT
                                          Thomas BraunT
                                          #138
                                          @liv-in-sky
                                          Das weiß ich auch nicht.
                                          Aber ich weiß, dass man nicht npm in Verbindung mit sudo (ohne weitere Optionen) verwendet.
                                          Da scheint mir auch schon was an den Rechten verbogen worden zu sein. Sonst dürfte da kein 'permission denied' erscheinen.
                                          Wie sehen die Rechte an
                                          denn jetzt aus?
                                          liv-in-skyL 3 Antworten Letzte Antwort
                                          83.9k
