  4. js-controller 4.0 jetzt im BETA/LATEST!
747 Beiträge 70 Kommentatoren 289.4k Aufrufe 60 Beobachtet
  • coyoteC coyote
    @apollon77 hm, was brauchst noch mehr vom Log. Da is nicht viel mehr, zumindest nix mit Fehler. Es läuft ja auch danach, hier nochmal:
    2022-02-14 16:21:25.079 - info: host.ioBroker instance system.adapter.ble.0 started with pid 952193
    2022-02-14 16:21:25.792 - info: iqontrol.0 (952176) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-02-14 16:21:25.900 - info: iqontrol.0 (952176) starting. Version 2.0.0-rc2.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v14.19.0, js-controller: 4.0.9
    2022-02-14 16:21:25.975 - info: iqontrol.0 (952176) systemLanguage = de
    2022-02-14 16:21:25.976 - info: iqontrol.0 (952176) Creating Popup States...
    2022-02-14 16:21:26.056 - info: iqontrol.0 (952176) Creating Widget States...
    2022-02-14 16:21:26.057 - info: iqontrol.0 (952176) Lists deactivated.
    2022-02-14 16:21:26.057 - info: iqontrol.0 (952176) Deleting unused Objects...
    2022-02-14 16:21:26.058 - info: iqontrol.0 (952176) Subscribing to states...
    2022-02-14 16:21:26.059 - info: iqontrol.0 (952176) iQontrol ready.
    2022-02-14 16:21:26.356 - error: host.ioBroker Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    2022-02-14 16:21:26.357 - error: host.ioBroker Caught by controller[0]: throw e;
    2022-02-14 16:21:26.357 - error: host.ioBroker Caught by controller[0]: ^
    2022-02-14 16:21:26.358 - error: host.ioBroker Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
    2022-02-14 16:21:26.358 - error: host.ioBroker Caught by controller[0]: was compiled against a different Node.js version using
    2022-02-14 16:21:26.358 - error: host.ioBroker Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
    2022-02-14 16:21:26.358 - error: host.ioBroker Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
    2022-02-14 16:21:26.359 - error: host.ioBroker Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2022-02-14 16:21:26.359 - error: host.ioBroker Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
    2022-02-14 16:21:26.359 - error: host.ioBroker Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    2022-02-14 16:21:26.359 - error: host.ioBroker Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    2022-02-14 16:21:26.372 - error: host.ioBroker Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    2022-02-14 16:21:26.372 - error: host.ioBroker Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    2022-02-14 16:21:26.372 - error: host.ioBroker Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    2022-02-14 16:21:26.372 - error: host.ioBroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    2022-02-14 16:21:26.373 - error: host.ioBroker Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    2022-02-14 16:21:26.373 - error: host.ioBroker Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    2022-02-14 16:21:26.373 - error: host.ioBroker Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
    2022-02-14 16:21:26.373 - error: host.ioBroker Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    2022-02-14 16:21:26.374 - error: host.ioBroker Caught by controller[0]: }
    2022-02-14 16:21:26.374 - error: host.ioBroker instance system.adapter.smartmeter.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-02-14 16:21:26.374 - info: host.ioBroker Adapter system.adapter.smartmeter.0 needs rebuild of @serialport/bindings and will be restarted afterwards.
    2022-02-14 16:21:26.375 - info: host.ioBroker system.adapter.smartmeter.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules/@serialport","module":"@serialport/bindings","version":"9.2.3"})
    2022-02-14 16:21:26.375 - warn: host.ioBroker adapter "smartmeter" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    2022-02-14 16:21:26.375 - info: host.ioBroker iobroker rebuild @serialport/bindings@9.2.3
    2022-02-14 16:21:26.635 - info: ble.0 (952193) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v14.19.0, js-controller: 4.0.9
    2022-02-14 16:21:26.702 - info: ble.0 (952193) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    2022-02-14 16:21:26.704 - info: ble.0 (952193) enabled plugins: mi-flora, _default
    2022-02-14 16:21:26.705 - info: ble.0 (952193) monitored services: fe95
    2022-02-14 16:21:26.707 - info: ble.0 (952193) starting scanner process...
    2022-02-14 16:21:27.062 - error: ble.0 (952193) Terminating because A dependency requires a rebuild.
    2022-02-14 16:21:27.131 - info: host.ioBroker instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
    2022-02-14 16:21:27.132 - info: host.ioBroker Adapter system.adapter.ble.0 needs rebuild and will be restarted afterwards.
    2022-02-14 16:21:27.133 - info: host.ioBroker system.adapter.ble.0 will be rebuilt
    2022-02-14 16:21:27.251 - info: host.ioBroker iobroker npm-rebuild: Path argument needs to be an absolute path!
    2022-02-14 16:21:28.261 - info: host.ioBroker iobroker npm-rebuild: exit 33
    2022-02-14 16:21:28.396 - info: host.ioBroker instance system.adapter.smartmeter.0 started with pid 952230
    2022-02-14 16:21:28.513 - info: host.ioBroker instance system.adapter.ble.0 started with pid 952237
    2022-02-14 16:21:28.542 - info: host.ioBroker instance system.adapter.mytime.0 started with pid 952244
    2022-02-14 16:21:29.703 - error: host.ioBroker Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    2022-02-14 16:21:29.704 - error: host.ioBroker Caught by controller[0]: throw e;
    2022-02-14 16:21:29.704 - error: host.ioBroker Caught by controller[0]: ^
    2022-02-14 16:21:29.705 - error: host.ioBroker Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
    2022-02-14 16:21:29.705 - error: host.ioBroker Caught by controller[0]: was compiled against a different Node.js version using
    2022-02-14 16:21:29.705 - error: host.ioBroker Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
    2022-02-14 16:21:29.706 - error: host.ioBroker Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
    2022-02-14 16:21:29.706 - error: host.ioBroker Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2022-02-14 16:21:29.706 - error: host.ioBroker Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
    2022-02-14 16:21:29.706 - error: host.ioBroker Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    2022-02-14 16:21:29.706 - error: host.ioBroker Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    2022-02-14 16:21:29.707 - error: host.ioBroker Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    2022-02-14 16:21:29.707 - error: host.ioBroker Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    2022-02-14 16:21:29.707 - error: host.ioBroker Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    2022-02-14 16:21:29.707 - error: host.ioBroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    2022-02-14 16:21:29.707 - error: host.ioBroker Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    2022-02-14 16:21:29.708 - error: host.ioBroker Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    2022-02-14 16:21:29.708 - error: host.ioBroker Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
    2022-02-14 16:21:29.708 - error: host.ioBroker Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    2022-02-14 16:21:29.708 - error: host.ioBroker Caught by controller[0]: }
    2022-02-14 16:21:29.709 - error: host.ioBroker instance system.adapter.smartmeter.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-02-14 16:21:29.709 - info: host.ioBroker Adapter system.adapter.smartmeter.0 needs rebuild and will be restarted afterwards.
    2022-02-14 16:21:29.709 - info: host.ioBroker system.adapter.smartmeter.0 will be rebuilt
    2022-02-14 16:21:29.709 - warn: host.ioBroker adapter "smartmeter" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    2022-02-14 16:21:29.710 - info: host.ioBroker iobroker rebuild
    2022-02-14 16:21:30.024 - info: ble.0 (952237) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v14.19.0, js-controller: 4.0.9
    2022-02-14 16:21:30.097 - info: ble.0 (952237) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    2022-02-14 16:21:30.098 - info: ble.0 (952237) enabled plugins: mi-flora, _default
    2022-02-14 16:21:30.099 - info: ble.0 (952237) monitored services: fe95
    2022-02-14 16:21:30.100 - info: ble.0 (952237) starting scanner process...
    2022-02-14 16:21:30.381 - error: ble.0 (952237) Terminating because A dependency requires a rebuild.
    EDIT:
    Das hier hätte ich noch, danach ist dann Ruhe:
    2022-02-14 16:22:57.067 - info: host.ioBroker iobroker npm-rebuild:
    2022-02-14 16:22:57.069 - info: host.ioBroker iobroker npm-rebuild: > @serialport/bindings@9.2.8 install /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    2022-02-14 16:22:57.727 - info: web.0 (952599) ==> Connected system.user.admin from 192.168.66.146
    2022-02-14 16:22:59.129 - info: javascript.0 (950889) Stop script script.js.Foto_Telegram_schicken
    2022-02-14 16:23:06.661 - info: host.ioBroker iobroker npm-rebuild: > @serialport/bindings@9.2.8 install /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    2022-02-14 16:23:12.717 - info: host.ioBroker iobroker npm-rebuild: > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme> node scripts/postinstall
    2022-02-14 16:23:12.881 - info: host.ioBroker iobroker npm-rebuild: > abstract-socket@2.1.1 install /opt/iobroker/node_modules/abstract-socket> node-gyp rebuild
    2022-02-14 16:23:13.619 - info: host.ioBroker iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/abstract-socket/build“ wird betreten
    2022-02-14 16:23:13.621 - info: host.ioBroker iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/abstract_socket.o
    2022-02-14 16:23:13.636 - info: jarvis.0 (951750) Client with IP 192.168.66.146 connected.
    2022-02-14 16:23:15.023 - info: host.ioBroker iobroker npm-rebuild: SOLINK_MODULE(target) Release/obj.target/bindings.node
    2022-02-14 16:23:15.101 - info: host.ioBroker iobroker npm-rebuild: COPY Release/bindings.node
    2022-02-14 16:23:15.114 - info: host.ioBroker iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/abstract-socket/build“ wird verlassen
    2022-02-14 16:23:15.203 - info: host.ioBroker iobroker npm-rebuild: > protobufjs@6.11.2 postinstall /opt/iobroker/node_modules/protobufjs> node scripts/postinstall
    2022-02-14 16:23:15.318 - info: host.ioBroker iobroker npm-rebuild: > cpu-features@0.0.2 install /opt/iobroker/node_modules/cpu-features> node-gyp rebuild
    2022-02-14 16:23:16.097 - info: host.ioBroker iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/cpu-features/build“ wird betreten
    2022-02-14 16:23:16.102 - info: host.ioBroker iobroker npm-rebuild: ACTION Configuring dependencies /opt/iobroker/node_modules/cpu-features/deps/cpu_features/build/Makefile
    2022-02-14 16:23:16.297 - info: host.ioBroker iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/cpu-features/build“ wird verlassen
    2022-02-14 16:23:17.453 - info: host.ioBroker iobroker npm-rebuild: exit 0
    2022-02-14 16:23:17.698 - info: host.ioBroker instance system.adapter.smartmeter.0 started with pid 953383
    2022-02-14 16:23:17.708 - info: host.ioBroker instance system.adapter.ble.0 started with pid 953389
    #345
    @coyote Ok, und danach tat alles ohne das Du was manuell gemacht hast bei smartmeter? Trotzdem was komisch ... wir checken
    coyoteC 1 Antwort Letzte Antwort
    • apollon77A apollon77
      coyoteC Offline
      coyoteC Offline
      coyote
      schrieb am zuletzt editiert von coyote
      #346
      @apollon77 genau, hab nur den ble von Hand nachinstalliert, da der nach 3 Versuchen auf gab :-)
      smartmeter hab ich nichts gemacht, der ist grün und ich habe auch aktuelle Werte.
      • JB_SullivanJ Offline
        JB_Sullivan
        #347
        So heute unter Windows auch mal das Update auf js-controller 4.0.9 gemacht. Versionsstand wurde angehoben und so wie es aussieht funktioniert ioB einwandfrei. Allerdings wurden in der Konsole die folgenden Meldungen ausgegeben. Windows bedingt?
        C:\iobroker\GLT>iobroker upgrade self
        Update js-controller from @3.3.22 to @4.0.9
        NPM version: 6.14.11
        npm install iobroker.js-controller@4.0.9 --loglevel error --unsafe-perm (System call)
        Server Objects 127.0.0.1:61428 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
        Server States 127.0.0.1:61429 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
        Server Objects 127.0.0.1:61428 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
        Server States 127.0.0.1:61430 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
        Server Objects 127.0.0.1:61428 Error from InMemDB: Error: Unknown LUA script load
        Server Objects 127.0.0.1:61428 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
        Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
        • JB_SullivanJ JB_Sullivan
          #348
          @jb_sullivan ne, Meldungen sind korrekt so, siehe auch oben erster Post
          • apollon77A Offline
            #349
            hallo,
            mit dem Feedback der letzten tage habe ich heute den js-controller 4.0.10, aka Stable-RC2 für Euch. Enthalten ist:
            4.0.10 (2022-02-15)
            • (foxriver76) Fix module specific rebuild command
            • (foxriver76) allow null for object.states also for extend calls for now
            • (foxriver76) enable sets on migration to redis if allowed
            • (Apollon77) Make sure adapters that are stopped on update are not enabled too early
            • (Apollon77) Optimize some special cases on adapter start
            @crunchip Dein backitup upgrade Problem sollte damit gelöst sein und die Module-spezifischen Rebuilds bei Node-JS updates sollten auch besser tun (na, mag nochmal jemand Node.js upgraden oder so? ;-)) )
            Thomas BraunT ? DiginixD L 4 Antworten Letzte Antwort
              hallo,
              4.0.10 (2022-02-15)
              #350
              @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
              Kein Problem. Node-Versionswechsel ist ja schnell gemacht.
              Wobei die letzten Wechsel der nodejs-Installation bei den von mir eingesetzten Adaptern schon sauber weggebügelt wurden. Da erwarte ich also keine Verbesserung.
              • Jabba_the_HuttJ Offline
                Jabba_the_Hutt
                #351
                @apollon77
                Welche node.js darfs denn sein? ;)
                apollon77A Thomas BraunT 2 Antworten Letzte Antwort
                • Jabba_the_HuttJ Jabba_the_Hutt
                  @apollon77
                  #352
                  @jabba_the_hutt Mir egal :-)
                  • crunchipC Abwesend
                    crunchipC Abwesend
                    #353
                    bin gespannt, ich werde testen und vllt auch mal auf v16 hochgehen😉
                      @apollon77
                      #354
                      @jabba_the_hutt sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                      Eins mit 'ner anderen ABI als dein jetziges. 😀
                      Jabba_the_HuttJ 1 Antwort Letzte Antwort
                        Jabba_the_Hutt
                        #355
                        :D v16 wollte ich eh schon lange ggg
                          #356
                          @thomas-braun Am Ende eins was "bluetooth" kram drin hat (ble adapter) und/oder canvas ... die sind zickig und ja die werden nicht automatisch rebuild gehen (weil da fixes bei den libs fehlen) aber ich würde am Log sehen das unsere versuche alle richtig laufen :-)
                          Jabba_the_HuttJ Thomas BraunT 2 Antworten Letzte Antwort
                            Jabba_the_Hutt
                            #357
                            @apollon77
                            ble adapter kann ich dann austesten ... log stell ich dann online.
                              #358
                              Den für canvas hab ich aber drin. Du erinnerst dich?
                              Den ble installier ich gerade mal flugs.
                                #359
                                @thomas-braun ja da bist du die Ausnahme. Der sollte dann direkt beim „ grossen“ rebuild mit gehen.
                                  hallo,
                                  4.0.10 (2022-02-15)
                                  #360
                                  @apollon77 Hier ist js-controller 4.0.10 absolut unauffaellig auf multihost:
                                  lxc debian 10, node 14, npm 6
                                  und 3x auf lxc debian 11, node 16, npm 8,
                                  auf armv6 (raspi-zero) debian 10, node 14, npm 6,
                                  auf armv7 debian 11, node 14, npm 6.
                                  Es sind insgesamt 61 Adapter auf 6 Hosts aufgeteilt im Einsatz.
                                  Datenbank redis/redis ( die schaufelt sich bei mir tot, aber das ist ein anderes topic..hab mal ausgemistet, nur noch ca. 60000 States..)
                                    crunchipC Abwesend
                                    #361
                                    hab auch gerade gesehen, das die CPU erhöht ist
                                    was hatte ich gestern Mittag gemacht
                                    • testweise backitup eine Version zurück und wieder hoch
                                      danach
                                    • die gestrigen anstehenden Adapter update's (welche es alle waren, kann ich nicht mehr genau sagen)
                                      Log ist unauffällig
                                      js-controller noch 4.0.9
                                    werde ioBroker mal neu starten und beobachten wie es sich dann verhält
                                    5074dd62-0d92-415e-8ede-b930ff91156a-image.png 63f42558-501a-4caa-8e39-c0aae7f53ba6-image.png
                                        danach
                                        Log ist unauffällig
                                      #362
                                      @crunchip Jarvis mit 50% CPU? Krass ... ist das "stabil" so? Dann würde ich da mal anfangen weil es der höchste ausreisser ist - vor allem falls es da gestern ein Update gab?
                                        #363
                                        @apollon77
                                        nodejs von 16 auf 17 gehoben, rebuilds sehen so aus:
                                        parcels:
                                        2022-02-16 09:03:06.052  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                        2022-02-16 09:03:06.088  - info: host.chet iobroker npm-rebuild:
                                        2022-02-16 09:03:06.089  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                        2022-02-16 09:03:07.102  - info: host.chet iobroker npm-rebuild: exit 0
                                        2022-02-16 09:03:07.268  - info: host.chet instance system.adapter.parcel.0 started with pid 122219
                                        2022-02-16 09:03:10.567  - info: parcel.0 (122219) starting. Version 0.0.2 (non-npm: TA2k/ioBroker.parcel#ad3587a3ea6d5d80cfe97e27ceff87767057a4a7) in /opt/iobroker/node_modules/iobroker.parcel, node: v17.5.0, js-controller: 4.0.10
                                        zigbee:
                                        Musste gar nicht neugebaut werden, ist direkt gestartet:
                                        2022-02-16 09:05:55.867  - info: host.chet "system.adapter.zigbee.0" enabled
                                        2022-02-16 09:05:56.083  - info: host.chet instance system.adapter.zigbee.0 started with pid 122335
                                        2022-02-16 09:05:59.651  - info: zigbee.0 (122335) starting. Version 1.6.15 in /opt/iobroker/node_modules/iobroker.zigbee, node: v17.5.0, js-controller: 4.0.10
                                        2022-02-16 09:05:59.755  - info: zigbee.0 (122335) Starting Zigbee  npm ...
                                        2022-02-16 09:06:00.236  - info: zigbee.0 (122335) Installed Version: iobroker.zigbee@1.6.15
                                        2022-02-16 09:06:11.226  - info: zigbee.0 (122335) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220103}}
                                        2022-02-16 09:06:11.235  - info: zigbee.0 (122335) Unable to disable LED, unsupported function.
                                        2022-02-16 09:06:11.248  - info: zigbee.0 (122335)   --> transmitPower : normal
                                        2022-02-16 09:06:11.257  - info: zigbee.0 (122335) Currently no devices.
                                        2022-02-16 09:06:11.258  - info: zigbee.0 (122335) Zigbee started
                                        ble:
                                        Baut nicht.
                                        2022-02-16 09:08:01.036  - info: host.chet "system.adapter.ble.0" enabled
                                        2022-02-16 09:08:01.239  - info: host.chet instance system.adapter.ble.0 started with pid 122373
                                        2022-02-16 09:08:02.703  - info: ble.0 (122373) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v17.5.0, js-controller: 4.0.10
                                        2022-02-16 09:08:02.772  - info: ble.0 (122373) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                                        2022-02-16 09:08:02.774  - info: ble.0 (122373) enabled plugins: _default
                                        2022-02-16 09:08:02.776  - info: ble.0 (122373) monitored services:
                                        2022-02-16 09:08:02.779  - info: ble.0 (122373) starting scanner process...
                                        2022-02-16 09:08:03.217  - error: ble.0 (122373) Terminating because A dependency requires a rebuild.
                                        2022-02-16 09:08:03.342  - info: host.chet instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
                                        2022-02-16 09:08:03.342  - info: host.chet Adapter system.adapter.ble.0 needs rebuild and will be restarted afterwards.
                                        2022-02-16 09:08:03.343  - info: host.chet system.adapter.ble.0 will be rebuilt
                                        2022-02-16 09:08:03.343  - warn: host.chet adapter "ble" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                        2022-02-16 09:08:03.344  - info: host.chet iobroker rebuild
                                        2022-02-16 09:08:04.303  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                        2022-02-16 09:09:43.510  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                        2022-02-16 09:09:43.546  - info: host.chet iobroker npm-rebuild:
                                        2022-02-16 09:09:43.547  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                        2022-02-16 09:09:44.562  - info: host.chet iobroker npm-rebuild: exit 0
                                        2022-02-16 09:09:44.688  - info: host.chet instance system.adapter.ble.0 started with pid 123582
                                        2022-02-16 09:09:46.203  - info: ble.0 (123582) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v17.5.0, js-controller: 4.0.10
                                        2022-02-16 09:09:46.274  - info: ble.0 (123582) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                                        2022-02-16 09:09:46.276  - info: ble.0 (123582) enabled plugins: _default
                                        2022-02-16 09:09:46.279  - info: ble.0 (123582) monitored services:
                                        2022-02-16 09:09:46.282  - info: ble.0 (123582) starting scanner process...
                                        2022-02-16 09:09:46.702  - error: ble.0 (123582) Terminating because A dependency requires a rebuild.
                                        2022-02-16 09:09:46.793  - info: host.chet instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
                                        2022-02-16 09:09:46.794  - info: host.chet Adapter system.adapter.ble.0 needs rebuild and will be restarted afterwards.
                                        2022-02-16 09:09:46.795  - info: host.chet system.adapter.ble.0 will be rebuilt
                                        2022-02-16 09:09:46.795  - warn: host.chet adapter "ble" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                        2022-02-16 09:09:46.796  - info: host.chet iobroker rebuild
                                        2022-02-16 09:09:47.804  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                        2022-02-16 09:11:27.627  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                        2022-02-16 09:11:27.663  - info: host.chet iobroker npm-rebuild:
                                        2022-02-16 09:11:27.665  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                        2022-02-16 09:11:28.677  - info: host.chet iobroker npm-rebuild: exit 0
                                        2022-02-16 09:11:28.824  - info: host.chet instance system.adapter.ble.0 started with pid 124791
                                        2022-02-16 09:11:30.315  - info: ble.0 (124791) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v17.5.0, js-controller: 4.0.10
                                        2022-02-16 09:11:30.384  - info: ble.0 (124791) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                                        2022-02-16 09:11:30.386  - info: ble.0 (124791) enabled plugins: _default
                                        2022-02-16 09:11:30.389  - info: ble.0 (124791) monitored services:
                                        2022-02-16 09:11:30.392  - info: ble.0 (124791) starting scanner process...
                                        2022-02-16 09:11:30.827  - error: ble.0 (124791) Terminating because A dependency requires a rebuild.
                                        2022-02-16 09:11:30.947  - info: host.chet instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
                                        2022-02-16 09:11:30.948  - info: host.chet Adapter system.adapter.ble.0 needs rebuild and will be restarted afterwards.
                                        2022-02-16 09:11:30.949  - info: host.chet system.adapter.ble.0 will be rebuilt
                                        2022-02-16 09:11:30.949  - warn: host.chet adapter "ble" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                        2022-02-16 09:11:30.950  - info: host.chet iobroker rebuild
                                        2022-02-16 09:11:31.909  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                        2022-02-16 09:13:10.557  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                        2022-02-16 09:13:10.598  - info: host.chet iobroker npm-rebuild:
                                        2022-02-16 09:13:10.599  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                        2022-02-16 09:13:11.613  - info: host.chet iobroker npm-rebuild: exit 0
                                        2022-02-16 09:13:11.739  - info: host.chet instance system.adapter.ble.0 started with pid 125988
                                        2022-02-16 09:13:13.276  - info: ble.0 (125988) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v17.5.0, js-controller: 4.0.10
                                        2022-02-16 09:13:13.355  - info: ble.0 (125988) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                                        2022-02-16 09:13:13.356  - info: ble.0 (125988) enabled plugins: _default
                                        2022-02-16 09:13:13.359  - info: ble.0 (125988) monitored services:
                                        2022-02-16 09:13:13.362  - info: ble.0 (125988) starting scanner process...
                                        2022-02-16 09:13:13.793  - error: ble.0 (125988) Terminating because A dependency requires a rebuild.
                                        2022-02-16 09:13:13.926  - info: host.chet instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
                                        2022-02-16 09:13:13.934  - info: host.chet Rebuild for adapter system.adapter.ble.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #364
                                          @apollon77 ne jarvis war nicht dabei bei den update's.
                                          Nach dem iob Neustart hat sich das nun wieder normalisiert.
                                          Ich hatte das schonmal, das nach ein paar update's die Cpu so hoch ging und auch so geblieben ist, jedoch nicht weiter darauf geachtet, was dies verursachte.
                                          Kann es sein, das dies die Ursache sein kann, wenn man mehrere Adapter Update's hintereinander reinballert?
