  4. massive CPU Auslastung
146 Beiträge 17 Kommentatoren 35.2k Aufrufe 11 Beobachtet
  • da_WoodyD da_Woody
    @apollon77 ok, für dich sieht das log normal aus. das beruhigt mal. wie gesagt, bei jedem versuch up/downgrade kommen andere meldungen... darum etwas verwirrung meinereiner.
    daswetter mal auf debug umgestellt. das log dazu:
    daswetter.0
    2022-02-14 11:30:31.177	debug	insert NextDays.Location_1.Day_1.Wind_value with Mäßiger Wind aus Süden
    daswetter.0
    2022-02-14 11:30:29.208	debug	insert NextDays.Location_1.Day_1.Wind_valueB with Mäßiger Wind aus Süden
    daswetter.0
    2022-02-14 11:30:26.489	debug	insert NextDays.Location_1.Day_1.Maximale_Temperatur_value with 9
    daswetter.0
    2022-02-14 11:30:23.263	debug	insert NextDays.Location_1.Day_1.Minimale_Temperatur_value with -3
    daswetter.0
    2022-02-14 11:30:23.262	debug	number of datapoints 6
    daswetter.0
    2022-02-14 11:30:22.009	debug	insert NextDays.Location_1.Day_1 with null {"type":"channel","common":{"name":"Day 1","role":"weather"}}
    daswetter.0
    2022-02-14 11:30:22.009	debug	number of periods 7
    daswetter.0
    2022-02-14 11:30:20.842	debug	insert NextDays.Location_1 with null {"type":"device","common":{"name":"Draßburg [Burgenland;Österreich]","role":"weather"}}
    daswetter.0
    2022-02-14 11:30:18.185	debug	insert NextDays.Location_1.Location with Draßburg
    daswetter.0
    2022-02-14 11:30:18.177	debug	number of location 1
    daswetter.0
    2022-02-14 11:30:18.177	debug	result {"report":{"location":{"city":"Draßburg [Burgenland;Österreich]","interesting":{"url":{"description":"Vorhersage","_@ttribute":"https://www.daswetter.com/wetter_Drabburg-Europa-osterreich-Burgenland--1-193954.html"}},"var":[{"name":"Minimale Temperatur","icon":"4","data":{"forecast":[{"data_sequence":"1","value":"-3"},{"data_sequence":"2","value":"-3"},{"data_sequence":"3","value":"0"},{"data_sequence":"4","value":"6"},{"data_sequence":"5","value":"5"},{"data_sequence":"6","value":"4"},{"data_sequence":"7","value":"0"}]}},{"name":"Maximale Temperatur","icon":"5","data":{"forecast":[{"data_sequence":"1","value":"9"},{"data_sequence":"2","value":"8"},{"data_sequence":"3","value":"12"},{"data_sequence":"4","value":"16"},{"data_sequence":"5","value":"13"},{"data_sequence":"6","value":"13"},{"data_sequence":"7","value":"12"}]}},{"name":"Wind","icon":"9","data":{"forecast":[{"data_sequence":"1","id":"13","idB":"45","value":"Mäßiger Wind aus Süden","valueB":"Mäßiger Wind aus Süden"},{"data_sequence":"2","id":"16","idB":"40","value":"Mäßiger Wind aus Nordwesten","valueB":"Mäßiger Wind aus Nordwesten"},{"data_sequence":"3","id":"13","idB":"53","value":"Mäßiger Wind aus Süden","valueB":"Mäßiger Wind aus Süden"},{"data_sequence":"4","id":"23","idB":"79","value":"Starker Wind aus Westen","valueB":"Sehr starker Wind aus Westen"},{"data_sequence":"5","id":"24","idB":"72","value":"Starker Wind aus Nordwesten","valueB":"Starker Wind aus Nordwesten"},{"data_sequence":"6","id":"24","idB":"64","value":"Starker Wind aus Nordwesten","valueB":"Starker Wind aus Nordwesten"},{"data_sequence":"7","id":"24","idB":"64","value":"Starker Wind aus Nordwesten","valueB":"Starker Wind aus Nordwesten"}]}},{"name":"Wetter Symbol","icon":"10","data":{"forecast":[{"data_sequence":"1","id":"1","id2":"1","value":"Sonne","value2":"Sonne"},{"data_sequence":"2","id":"6","id2":"6","value":"Bewölkt mit leichtem Regen","value2":"Bewölkt mit leichtem Regen"},{"data_sequence":"3","id":"6","id2":"6","value":"Bewölkt mit leichtem Regen","value2":"Bewölkt mit leichtem Regen"},{"data_sequence":"4","id":"6","id2":"6","value":"Bewölkt mit leichtem Regen","value2":"Bewölkt mit leichtem Regen"},{"data_sequence":"5","id":"5","id2":"5","value":"Teils bewölkt mit leichtem Regen","value2":"Teils bewölkt mit leichtem Regen"},{"data_sequence":"6","id":"3","id2":"3","value":"Bewölkt","value2":"Bewölkt"},{"data_sequence":"7","id":"3","id2":"3","value":"Bewölkt","value2":"Bewölkt"}]}},{"name":"Tag","icon":"15","data":{"forecast":[{"data_sequence":"1","value":"Montag"},{"data_sequence":"2","value":"Dienstag"},{"data_sequence":"3","value":"Mittwoch"},{"data_sequence":"4","value":"Donnerstag"},{"data_sequence":"5","value":"Freitag"},{"data_sequence":"6","value":"Samstag"},{"data_sequence":"7","value":"Sonntag"}]}},{"name":"Wetterbedingungen","icon":"19","data":{"forecast":[{"data_sequence":"1","value":"Den ganzen Tag über Sonne"},{"data_sequence":"2","value":"Während der ersten Hälfte des Tages Sonne tendenziell in der zweiten Hälfte des Tages Bewölkt mit leichtem Regen"},{"data_sequence":"3","value":"Während der ersten Hälfte des Tages Sonne tendenziell in der zweiten Hälfte des Tages Teils bewölkt mit leichtem Regen"},{"data_sequence":"4","value":"Während der ersten Hälfte des Tages Teils bewölkt mit leichtem Regen tendenziell in der zweiten Hälfte des Tages Teils bewölkt"},{"data_sequence":"5","value":"Während der ersten Hälfte des Tages Bedeckt tendenziell in der zweiten Hälfte des Tages Sonne"},{"data_sequence":"6","value":"Während der ersten Hälfte des Tages Sonne tendenziell in der zweiten Hälfte des Tages Bewölkt"},{"data_sequence":"7","value":"Den ganzen Tag über Sonne"}]}}]}}}
    daswetter.0
    2022-02-14 11:30:18.172	debug	got response "<?xml version=\"1.0\" encoding=\"UTF-8\" ?><report><location city=\"Draßburg [Burgenland;Österreich]\"><interesting><url description=\"Vorhersage\">https://www.daswetter.com/wetter_Drabburg-Europa-osterreich-Burgenland--1-193954.html</url></interesting><var><name>Minimale Temperatur</name><icon>4</icon><data><forecast data_sequence=\"1\" value=\"-3\"/><forecast data_sequence=\"2\" value=\"-3\"/><forecast data_sequence=\"3\" value=\"0\"/><forecast data_sequence=\"4\" value=\"6\"/><forecast data_sequence=\"5\" value=\"5\"/><forecast data_sequence=\"6\" value=\"4\"/><forecast data_sequence=\"7\" value=\"0\"/></data></var><var><name>Maximale Temperatur</name><icon>5</icon><data><forecast data_sequence=\"1\" value=\"9\"/><forecast data_sequence=\"2\" value=\"8\"/><forecast data_sequence=\"3\" value=\"12\"/><forecast data_sequence=\"4\" value=\"16\"/><forecast data_sequence=\"5\" value=\"13\"/><forecast data_sequence=\"6\" value=\"13\"/><forecast data_sequence=\"7\" value=\"12\"/></data></var><var><name>Wind</name><icon>9</icon><data><forecast data_sequence=\"1\" id=\"13\" idB=\"45\" value=\"Mäßiger Wind aus Süden\" valueB=\"Mäßiger Wind aus Süden\"/><forecast data_sequence=\"2\" id=\"16\" idB=\"40\" value=\"Mäßiger Wind aus Nordwesten\" valueB=\"Mäßiger Wind aus Nordwesten\"/><forecast data_sequence=\"3\" id=\"13\" idB=\"53\" value=\"Mäßiger Wind aus Süden\" valueB=\"Mäßiger Wind aus Süden\"/><forecast data_sequence=\"4\" id=\"23\" idB=\"79\" value=\"Starker Wind aus Westen\" valueB=\"Sehr starker Wind aus Westen\"/><forecast data_sequence=\"5\" id=\"24\" idB=\"72\" value=\"Starker Wind aus Nordwesten\" valueB=\"Starker Wind aus Nordwesten\"/><forecast data_sequence=\"6\" id=\"24\" idB=\"64\" value=\"Starker Wind aus Nordwesten\" valueB=\"Starker Wind aus Nordwesten\"/><forecast data_sequence=\"7\" id=\"24\" idB=\"64\" value=\"Starker Wind aus Nordwesten\" valueB=\"Starker Wind aus Nordwesten\"/></data></var><var><name>Wetter Symbol</name><icon>10</icon><data><forecast data_sequence=\"1\" id=\"1\" id2=\"1\" value=\"Sonne\" value2=\"Sonne\"/><forecast data_sequence=\"2\" id=\"6\" id2=\"6\" value=\"Bewölkt mit leichtem Regen\" value2=\"Bewölkt mit leichtem Regen\"/><forecast data_sequence=\"3\" id=\"6\" id2=\"6\" value=\"Bewölkt mit leichtem Regen\" value2=\"Bewölkt mit leichtem Regen\"/><forecast data_sequence=\"4\" id=\"6\" id2=\"6\" value=\"Bewölkt mit leichtem Regen\" value2=\"Bewölkt mit leichtem Regen\"/><forecast data_sequence=\"5\" id=\"5\" id2=\"5\" value=\"Teils bewölkt mit leichtem Regen\" value2=\"Teils bewölkt mit leichtem Regen\"/><forecast data_sequence=\"6\" id=\"3\" id2=\"3\" value=\"Bewölkt\" value2=\"Bewölkt\"/><forecast data_sequence=\"7\" id=\"3\" id2=\"3\" value=\"Bewölkt\" value2=\"Bewölkt\"/></data></var><var><name>Tag</name><icon>15</icon><data><forecast data_sequence=\"1\" value=\"Montag\"/><forecast data_sequence=\"2\" value=\"Dienstag\"/><forecast data_sequence=\"3\" value=\"Mittwoch\"/><forecast data_sequence=\"4\" value=\"Donnerstag\"/><forecast data_sequence=\"5\" value=\"Freitag\"/><forecast data_sequence=\"6\" value=\"Samstag\"/><forecast data_sequence=\"7\" value=\"Sonntag\"/></data></var><var><name>Wetterbedingungen</name><icon>19</icon><data><forecast data_sequence=\"1\" value=\"Den ganzen Tag über Sonne\"/><forecast data_sequence=\"2\" value=\"Während der ersten Hälfte des Tages Sonne tendenziell in der zweiten Hälfte des Tages Bewölkt mit leichtem Regen\"/><forecast data_sequence=\"3\" value=\"Während der ersten Hälfte des Tages Sonne tendenziell in der zweiten Hälfte des Tages Teils bewölkt mit leichtem Regen\"/><forecast data_sequence=\"4\" value=\"Während der ersten Hälfte des Tages Teils bewölkt mit leichtem Regen tendenziell in der zweiten Hälfte des Tages Teils bewölkt\"/><forecast data_sequence=\"5\" value=\"Während der ersten Hälfte des Tages Bedeckt tendenziell in der zweiten Hälfte des Tages Sonne\"/><forecast data_sequence=\"6\" value=\"Während der ersten Hälfte des Tages Sonne tendenziell in der zweiten Hälfte des Tages Bewölkt\"/><forecast data_sequence=\"7\" value=\"Den ganzen Tag über Sonne\"/></data></var></location></report>"
    daswetter.0
    2022-02-14 11:30:18.073	debug	calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=at&localidad=193954&affiliate_id=57jhtyihpw98
    daswetter.0
    2022-02-14 11:30:18.072	debug	set timeout to 60 sec
    daswetter.0
    2022-02-14 11:30:18.028	info	starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.19.0, js-controller: 4.0.8
    daswetter.0
    2022-02-14 11:30:07.625	info	Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
    daswetter.0
    2022-02-14 11:30:07.624	debug	Plugin sentry Initialize Plugin (enabled=true)
    daswetter.0
    2022-02-14 11:29:38.071	warn	Terminated (UNKNOWN_ERROR): Without reason
    daswetter.0
    2022-02-14 11:29:38.071	debug	Plugin sentry destroyed
    daswetter.0
    2022-02-14 11:29:38.070	error	force terminate
    daswetter.0
    2022-02-14 11:29:37.782	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.windchill_value with 7 °C
    daswetter.0
    2022-02-14 11:29:36.076	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.snowline_value with 1400 m
    daswetter.0
    2022-02-14 11:29:33.820	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.clouds_value with 100%
    daswetter.0
    2022-02-14 11:29:32.062	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.pressure_value with 1014 mb
    daswetter.0
    2022-02-14 11:29:30.566	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.humidity_value with 58
    daswetter.0
    2022-02-14 11:29:27.281	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:29:25.280	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.windgusts_value with 18 km/h
    daswetter.0
    2022-02-14 11:29:24.538	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/27.png
    daswetter.0
    2022-02-14 11:29:22.941	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.wind_value with 6 km/h
    daswetter.0
    2022-02-14 11:29:20.575	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.wind_dir with E
    daswetter.0
    2022-02-14 11:29:18.893	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.wind_symbol with 3
    daswetter.0
    2022-02-14 11:29:18.565	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.wind_symbolB with 27
    daswetter.0
    2022-02-14 11:29:18.477	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.iconURL with /vis.0/main/images/wetter/4.png
    daswetter.0
    2022-02-14 11:29:18.353	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.symbol_value with 4
    daswetter.0
    2022-02-14 11:29:18.277	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.symbol_desc with Bedeckt
    daswetter.0
    2022-02-14 11:29:18.198	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.symbol_value2 with 4
    daswetter.0
    2022-02-14 11:29:18.121	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.symbol_desc2 with Bedeckt
    daswetter.0
    2022-02-14 11:29:18.065	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.temp_value with 8 °C
    daswetter.0
    2022-02-14 11:29:17.988	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5.hour_value with 14:00
    daswetter.0
    2022-02-14 11:29:17.977	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_5 with null {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}}
    daswetter.0
    2022-02-14 11:29:17.902	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.windchill_value with 5 °C
    daswetter.0
    2022-02-14 11:29:17.845	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.snowline_value with 1600 m
    daswetter.0
    2022-02-14 11:29:17.759	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.clouds_value with 26%
    daswetter.0
    2022-02-14 11:29:17.692	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.pressure_value with 1015 mb
    daswetter.0
    2022-02-14 11:29:17.607	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.humidity_value with 63
    daswetter.0
    2022-02-14 11:29:17.542	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:29:17.426	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.windgusts_value with 18 km/h
    daswetter.0
    2022-02-14 11:29:17.363	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/27.png
    daswetter.0
    2022-02-14 11:29:17.307	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.wind_value with 7 km/h
    daswetter.0
    2022-02-14 11:29:17.247	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.wind_dir with E
    daswetter.0
    2022-02-14 11:29:17.187	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.wind_symbol with 3
    daswetter.0
    2022-02-14 11:29:17.131	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.wind_symbolB with 27
    daswetter.0
    2022-02-14 11:29:17.077	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.iconURL with /vis.0/main/images/wetter/3.png
    daswetter.0
    2022-02-14 11:29:17.020	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.symbol_value with 3
    daswetter.0
    2022-02-14 11:29:16.960	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.symbol_desc with Bewölkt
    daswetter.0
    2022-02-14 11:29:16.901	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.symbol_value2 with 3
    daswetter.0
    2022-02-14 11:29:16.849	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.symbol_desc2 with Bewölkt
    daswetter.0
    2022-02-14 11:29:16.763	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.temp_value with 6 °C
    daswetter.0
    2022-02-14 11:29:16.706	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4.hour_value with 11:00
    daswetter.0
    2022-02-14 11:29:16.703	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_4 with null {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}}
    daswetter.0
    2022-02-14 11:29:16.643	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.windchill_value with -2 °C
    daswetter.0
    2022-02-14 11:29:16.566	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.snowline_value with 1800 m
    daswetter.0
    2022-02-14 11:29:16.502	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.clouds_value with 5%
    daswetter.0
    2022-02-14 11:29:16.424	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.pressure_value with 1014 mb
    daswetter.0
    2022-02-14 11:29:16.323	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.humidity_value with 80
    daswetter.0
    2022-02-14 11:29:16.269	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:29:16.221	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.windgusts_value with 8 km/h
    daswetter.0
    2022-02-14 11:29:16.169	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/23.png
    daswetter.0
    2022-02-14 11:29:16.122	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.wind_value with 4 km/h
    daswetter.0
    2022-02-14 11:29:16.071	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.wind_dir with W
    daswetter.0
    2022-02-14 11:29:16.015	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.wind_symbol with 7
    daswetter.0
    2022-02-14 11:29:15.959	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.wind_symbolB with 23
    daswetter.0
    2022-02-14 11:29:15.903	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.iconURL with /vis.0/main/images/wetter/2.png
    daswetter.0
    2022-02-14 11:29:15.818	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.symbol_value with 2
    daswetter.0
    2022-02-14 11:29:15.744	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.symbol_desc with Teils bewölkt
    daswetter.0
    2022-02-14 11:29:15.685	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.symbol_value2 with 2
    daswetter.0
    2022-02-14 11:29:15.631	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.symbol_desc2 with Teils bewölkt
    daswetter.0
    2022-02-14 11:29:15.569	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.temp_value with -1 °C
    daswetter.0
    2022-02-14 11:29:15.505	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3.hour_value with 08:00
    daswetter.0
    2022-02-14 11:29:15.499	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_3 with null {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}}
    daswetter.0
    2022-02-14 11:29:15.419	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.windchill_value with -5 °C
    daswetter.0
    2022-02-14 11:29:15.310	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.snowline_value with 1800 m
    daswetter.0
    2022-02-14 11:29:15.198	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.clouds_value with 29%
    daswetter.0
    2022-02-14 11:29:15.086	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.pressure_value with 1012 mb
    daswetter.0
    2022-02-14 11:29:14.973	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.humidity_value with 84
    daswetter.0
    2022-02-14 11:29:14.804	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:29:14.266	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.windgusts_value with 12 km/h
    daswetter.0
    2022-02-14 11:29:13.999	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/31.png
    daswetter.0
    2022-02-14 11:29:13.569	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.wind_value with 6 km/h
    daswetter.0
    2022-02-14 11:29:13.461	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.wind_dir with W
    daswetter.0
    2022-02-14 11:29:13.400	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.wind_symbol with 7
    daswetter.0
    2022-02-14 11:29:13.323	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.wind_symbolB with 31
    daswetter.0
    2022-02-14 11:29:13.260	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.iconURL with /vis.0/main/images/wetter/2.png
    daswetter.0
    2022-02-14 11:29:13.211	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.symbol_value with 2
    daswetter.0
    2022-02-14 11:29:13.161	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.symbol_desc with Teils bewölkt
    daswetter.0
    2022-02-14 11:29:13.111	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.symbol_value2 with 2
    daswetter.0
    2022-02-14 11:29:13.037	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.symbol_desc2 with Teils bewölkt
    daswetter.0
    2022-02-14 11:29:12.974	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.temp_value with -3 °C
    daswetter.0
    2022-02-14 11:29:12.884	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2.hour_value with 05:00
    daswetter.0
    2022-02-14 11:29:12.865	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_2 with null {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}}
    daswetter.0
    2022-02-14 11:29:12.734	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.windchill_value with -4 °C
    daswetter.0
    2022-02-14 11:29:12.603	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.snowline_value with 1800 m
    daswetter.0
    2022-02-14 11:29:12.518	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.clouds_value with 1%
    daswetter.0
    2022-02-14 11:29:12.454	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.pressure_value with 1011 mb
    daswetter.0
    2022-02-14 11:29:12.382	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.humidity_value with 80
    daswetter.0
    2022-02-14 11:29:12.303	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:29:12.241	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.windgusts_value with 13 km/h
    daswetter.0
    2022-02-14 11:29:12.181	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/31.png
    daswetter.0
    2022-02-14 11:29:12.101	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.wind_value with 6 km/h
    daswetter.0
    2022-02-14 11:29:11.989	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.wind_dir with W
    daswetter.0
    2022-02-14 11:29:11.934	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.wind_symbol with 7
    daswetter.0
    2022-02-14 11:29:11.802	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.wind_symbolB with 31
    daswetter.0
    2022-02-14 11:29:11.742	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.iconURL with /vis.0/main/images/wetter/1.png
    daswetter.0
    2022-02-14 11:29:11.683	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.symbol_value with 1
    daswetter.0
    2022-02-14 11:29:11.616	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.symbol_desc with Sonne
    daswetter.0
    2022-02-14 11:29:11.513	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.symbol_value2 with 1
    daswetter.0
    2022-02-14 11:29:11.441	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.symbol_desc2 with Sonne
    daswetter.0
    2022-02-14 11:29:11.357	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.temp_value with -2 °C
    daswetter.0
    2022-02-14 11:29:11.295	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1.hour_value with 02:00
    daswetter.0
    2022-02-14 11:29:11.264	debug	insert NextDaysDetailed.Location_1.Day_2.Hour_1 with null {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}}
    daswetter.0
    2022-02-14 11:29:11.264	debug	number of hours 8
    daswetter.0
    2022-02-14 11:29:11.158	debug	insert NextDaysDetailed.Location_1.Day_2.local_info_local_time with 11:28
    daswetter.0
    2022-02-14 11:29:11.103	debug	insert NextDaysDetailed.Location_1.Day_2.local_info_offset with 1
    daswetter.0
    2022-02-14 11:29:11.039	debug	insert NextDaysDetailed.Location_1.Day_2.moonIconURL with /vis.0/main/images/mond/13.png
    daswetter.0
    2022-02-14 11:29:10.980	debug	insert NextDaysDetailed.Location_1.Day_2.moon_in with 15:44
    daswetter.0
    2022-02-14 11:29:10.913	debug	insert NextDaysDetailed.Location_1.Day_2.moon_out with 06:54
    daswetter.0
    2022-02-14 11:29:10.851	debug	insert NextDaysDetailed.Location_1.Day_2.moon_lumi with 98.4%
    daswetter.0
    2022-02-14 11:29:10.789	debug	insert NextDaysDetailed.Location_1.Day_2.moon_desc with Vollmond, 98.4% Beleuchtet
    daswetter.0
    2022-02-14 11:29:10.731	debug	insert NextDaysDetailed.Location_1.Day_2.moon_symbol with 13
    daswetter.0
    2022-02-14 11:29:10.642	debug	insert NextDaysDetailed.Location_1.Day_2.sun_in with 07:00
    daswetter.0
    2022-02-14 11:29:10.569	debug	insert NextDaysDetailed.Location_1.Day_2.sun_mid with 12:08
    daswetter.0
    2022-02-14 11:29:10.488	debug	insert NextDaysDetailed.Location_1.Day_2.sun_out with 17:17
    daswetter.0
    2022-02-14 11:29:10.432	debug	insert NextDaysDetailed.Location_1.Day_2.snowline_value with 1000 m
    daswetter.0
    2022-02-14 11:29:10.365	debug	insert NextDaysDetailed.Location_1.Day_2.pressure_value with 1014 mb
    daswetter.0
    2022-02-14 11:29:10.302	debug	insert NextDaysDetailed.Location_1.Day_2.humidity_value with 78
    daswetter.0
    2022-02-14 11:29:10.243	debug	insert NextDaysDetailed.Location_1.Day_2.rain_value with 5.5 mm
    daswetter.0
    2022-02-14 11:29:10.179	debug	insert NextDaysDetailed.Location_1.Day_2.windgusts_value with 27 km/h
    daswetter.0
    2022-02-14 11:29:10.123	debug	insert NextDaysDetailed.Location_1.Day_2.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/40.png
    daswetter.0
    2022-02-14 11:29:10.050	debug	insert NextDaysDetailed.Location_1.Day_2.wind_value with 14 km/h
    daswetter.0
    2022-02-14 11:29:09.997	debug	insert NextDaysDetailed.Location_1.Day_2.wind_symbol with 16
    daswetter.0
    2022-02-14 11:29:09.932	debug	insert NextDaysDetailed.Location_1.Day_2.wind_symbolB with 40
    daswetter.0
    2022-02-14 11:29:09.837	debug	insert NextDaysDetailed.Location_1.Day_2.tempmax_value with 8 °C
    daswetter.0
    2022-02-14 11:29:09.774	debug	insert NextDaysDetailed.Location_1.Day_2.tempmin_value with -3 °C
    daswetter.0
    2022-02-14 11:29:09.709	debug	insert NextDaysDetailed.Location_1.Day_2.iconURL with /vis.0/main/images/wetter/6.png
    daswetter.0
    2022-02-14 11:29:09.617	debug	insert NextDaysDetailed.Location_1.Day_2.symbol_value with 6
    daswetter.0
    2022-02-14 11:29:09.482	debug	insert NextDaysDetailed.Location_1.Day_2.symbol_desc with Bewölkt mit leichtem Regen
    daswetter.0
    2022-02-14 11:29:09.358	debug	insert NextDaysDetailed.Location_1.Day_2.symbol_value2 with 6
    daswetter.0
    2022-02-14 11:29:09.281	debug	insert NextDaysDetailed.Location_1.Day_2.symbol_desc2 with Bewölkt mit leichtem Regen
    daswetter.0
    2022-02-14 11:29:09.210	debug	insert NextDaysDetailed.Location_1.Day_2.day_value with 20220215
    daswetter.0
    2022-02-14 11:29:09.150	debug	insert NextDaysDetailed.Location_1.Day_2.day_name with Dienstag
    daswetter.0
    2022-02-14 11:29:09.124	debug	insert NextDaysDetailed.Location_1.Day_2 with null {"type":"channel","common":{"name":"Day 2","role":"weather"}}
    daswetter.0
    2022-02-14 11:29:09.019	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.windchill_value with -3 °C
    daswetter.0
    2022-02-14 11:29:08.965	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.snowline_value with 1800 m
    daswetter.0
    2022-02-14 11:29:08.885	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.clouds_value with 0%
    daswetter.0
    2022-02-14 11:29:08.791	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.pressure_value with 1011 mb
    daswetter.0
    2022-02-14 11:29:08.716	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.humidity_value with 81
    daswetter.0
    2022-02-14 11:29:08.655	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:29:08.426	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.windgusts_value with 20 km/h
    daswetter.0
    2022-02-14 11:29:08.284	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/37.png
    daswetter.0
    2022-02-14 11:29:08.211	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.wind_value with 11 km/h
    daswetter.0
    2022-02-14 11:29:08.152	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.wind_dir with S
    daswetter.0
    2022-02-14 11:29:08.075	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.wind_symbol with 13
    daswetter.0
    2022-02-14 11:29:07.991	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.wind_symbolB with 37
    daswetter.0
    2022-02-14 11:29:07.920	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.iconURL with /vis.0/main/images/wetter/1.png
    daswetter.0
    2022-02-14 11:29:07.861	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.symbol_value with 1
    daswetter.0
    2022-02-14 11:29:07.805	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.symbol_desc with Sonne
    daswetter.0
    2022-02-14 11:29:07.744	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.symbol_value2 with 1
    daswetter.0
    2022-02-14 11:29:07.690	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.symbol_desc2 with Sonne
    daswetter.0
    2022-02-14 11:29:07.630	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.temp_value with 0 °C
    daswetter.0
    2022-02-14 11:29:07.568	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value with 23:00
    daswetter.0
    2022-02-14 11:29:07.553	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_8 with null {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}}
    daswetter.0
    2022-02-14 11:29:07.463	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value with 1 °C
    daswetter.0
    2022-02-14 11:29:07.392	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value with 1600 m
    daswetter.0
    2022-02-14 11:29:07.285	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value with 3%
    daswetter.0
    2022-02-14 11:29:07.230	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value with 1012 mb
    daswetter.0
    2022-02-14 11:29:07.173	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value with 79
    daswetter.0
    2022-02-14 11:29:07.111	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:29:07.057	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.windgusts_value with 25 km/h
    daswetter.0
    2022-02-14 11:29:07.008	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/37.png
    daswetter.0
    2022-02-14 11:29:06.943	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.wind_value with 12 km/h
    daswetter.0
    2022-02-14 11:29:06.889	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.wind_dir with S
    daswetter.0
    2022-02-14 11:29:06.832	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.wind_symbol with 13
    daswetter.0
    2022-02-14 11:29:06.769	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.wind_symbolB with 37
    daswetter.0
    2022-02-14 11:29:06.717	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.iconURL with /vis.0/main/images/wetter/2.png
    daswetter.0
    2022-02-14 11:29:06.667	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.symbol_value with 2
    daswetter.0
    2022-02-14 11:29:06.614	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.symbol_desc with Teils bewölkt
    daswetter.0
    2022-02-14 11:29:06.557	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.symbol_value2 with 2
    daswetter.0
    2022-02-14 11:29:06.474	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.symbol_desc2 with Teils bewölkt
    daswetter.0
    2022-02-14 11:29:06.395	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.temp_value with 3 °C
    daswetter.0
    2022-02-14 11:29:06.306	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7.hour_value with 20:00
    daswetter.0
    2022-02-14 11:29:06.304	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_7 with null {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}}
    daswetter.0
    2022-02-14 11:29:06.254	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.windchill_value with 5 °C
    daswetter.0
    2022-02-14 11:29:06.202	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.snowline_value with 1500 m
    daswetter.0
    2022-02-14 11:29:06.151	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.clouds_value with 42%
    daswetter.0
    2022-02-14 11:29:06.090	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.pressure_value with 1012 mb
    daswetter.0
    2022-02-14 11:29:06.034	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.humidity_value with 48
    daswetter.0
    2022-02-14 11:29:05.982	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:29:05.930	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.windgusts_value with 29 km/h
    daswetter.0
    2022-02-14 11:29:05.866	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/45.png
    daswetter.0
    2022-02-14 11:29:05.809	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.wind_value with 11 km/h
    daswetter.0
    2022-02-14 11:29:05.757	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.wind_dir with S
    daswetter.0
    2022-02-14 11:29:05.701	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.wind_symbol with 13
    daswetter.0
    2022-02-14 11:29:05.646	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.wind_symbolB with 45
    daswetter.0
    2022-02-14 11:29:05.585	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.iconURL with /vis.0/main/images/wetter/2.png
    daswetter.0
    2022-02-14 11:29:05.529	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.symbol_value with 2
    daswetter.0
    2022-02-14 11:29:05.441	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.symbol_desc with Teils bewölkt
    daswetter.0
    2022-02-14 11:29:05.366	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.symbol_value2 with 2
    daswetter.0
    2022-02-14 11:29:05.302	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.symbol_desc2 with Teils bewölkt
    daswetter.0
    2022-02-14 11:29:05.245	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.temp_value with 7 °C
    daswetter.0
    2022-02-14 11:29:05.189	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6.hour_value with 17:00
    daswetter.0
    2022-02-14 11:29:05.182	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_6 with null {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}}
    daswetter.0
    2022-02-14 11:29:05.118	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.windchill_value with 6 °C
    daswetter.0
    2022-02-14 11:29:05.057	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.snowline_value with 1600 m
    daswetter.0
    2022-02-14 11:29:04.977	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.clouds_value with 0%
    daswetter.0
    2022-02-14 11:29:04.929	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.pressure_value with 1013 mb
    daswetter.0
    2022-02-14 11:29:04.853	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.humidity_value with 43
    daswetter.0
    2022-02-14 11:29:04.780	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:29:04.705	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.windgusts_value with 37 km/h
    daswetter.0
    2022-02-14 11:29:04.621	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/45.png
    daswetter.0
    2022-02-14 11:29:04.525	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.wind_value with 17 km/h
    daswetter.0
    2022-02-14 11:29:04.359	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.wind_dir with S
    daswetter.0
    2022-02-14 11:29:04.284	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.wind_symbol with 13
    daswetter.0
    2022-02-14 11:29:04.197	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.wind_symbolB with 45
    daswetter.0
    2022-02-14 11:29:04.137	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.iconURL with /vis.0/main/images/wetter/1.png
    daswetter.0
    2022-02-14 11:29:04.075	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_value with 1
    daswetter.0
    2022-02-14 11:29:03.979	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_desc with Sonne
    daswetter.0
    2022-02-14 11:29:03.843	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_value2 with 1
    daswetter.0
    2022-02-14 11:29:03.714	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_desc2 with Sonne
    daswetter.0
    2022-02-14 11:29:03.638	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.temp_value with 9 °C
    daswetter.0
    2022-02-14 11:29:03.545	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5.hour_value with 14:00
    daswetter.0
    2022-02-14 11:29:03.504	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_5 with null {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}}
    daswetter.0
    2022-02-14 11:29:03.430	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.windchill_value with 2 °C
    daswetter.0
    2022-02-14 11:29:03.353	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.snowline_value with 1400 m
    daswetter.0
    2022-02-14 11:29:03.291	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.clouds_value with 0%
    daswetter.0
    2022-02-14 11:29:03.223	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.pressure_value with 1015 mb
    daswetter.0
    2022-02-14 11:29:03.146	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.humidity_value with 57
    daswetter.0
    2022-02-14 11:29:03.083	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:29:03.018	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.windgusts_value with 36 km/h
    daswetter.0
    2022-02-14 11:29:02.965	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/45.png
    daswetter.0
    2022-02-14 11:29:02.894	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.wind_value with 15 km/h
    daswetter.0
    2022-02-14 11:29:02.779	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.wind_dir with S
    daswetter.0
    2022-02-14 11:29:02.643	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.wind_symbol with 13
    daswetter.0
    2022-02-14 11:29:02.515	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.wind_symbolB with 45
    daswetter.0
    2022-02-14 11:29:02.033	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.iconURL with /vis.0/main/images/wetter/1.png
    daswetter.0
    2022-02-14 11:29:01.436	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_value with 1
    daswetter.0
    2022-02-14 11:29:01.250	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_desc with Sonne
    daswetter.0
    2022-02-14 11:29:01.189	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_value2 with 1
    daswetter.0
    2022-02-14 11:29:01.121	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_desc2 with Sonne
    daswetter.0
    2022-02-14 11:29:01.059	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.temp_value with 5 °C
    daswetter.0
    2022-02-14 11:29:00.954	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4.hour_value with 11:00
    daswetter.0
    2022-02-14 11:29:00.914	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_4 with null {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}}
    daswetter.0
    2022-02-14 11:29:00.834	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.windchill_value with -6 °C
    daswetter.0
    2022-02-14 11:29:00.732	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.snowline_value with 1100 m
    daswetter.0
    2022-02-14 11:29:00.627	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.clouds_value with 0%
    daswetter.0
    2022-02-14 11:29:00.479	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.pressure_value with 1017 mb
    daswetter.0
    2022-02-14 11:29:00.324	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.humidity_value with 87
    daswetter.0
    2022-02-14 11:29:00.220	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:29:00.141	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.windgusts_value with 32 km/h
    daswetter.0
    2022-02-14 11:29:00.064	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/45.png
    daswetter.0
    2022-02-14 11:28:59.997	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.wind_value with 16 km/h
    daswetter.0
    2022-02-14 11:28:59.918	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.wind_dir with S
    daswetter.0
    2022-02-14 11:28:59.848	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.wind_symbol with 13
    daswetter.0
    2022-02-14 11:28:59.773	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.wind_symbolB with 45
    daswetter.0
    2022-02-14 11:28:59.678	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.iconURL with /vis.0/main/images/wetter/1.png
    daswetter.0
    2022-02-14 11:28:59.609	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.symbol_value with 1
    daswetter.0
    2022-02-14 11:28:59.540	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.symbol_desc with Sonne
    daswetter.0
    2022-02-14 11:28:59.472	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.symbol_value2 with 1
    daswetter.0
    2022-02-14 11:28:59.385	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.symbol_desc2 with Sonne
    daswetter.0
    2022-02-14 11:28:59.296	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.temp_value with -1 °C
    daswetter.0
    2022-02-14 11:28:59.169	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3.hour_value with 08:00
    daswetter.0
    2022-02-14 11:28:59.112	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_3 with null {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}}
    daswetter.0
    2022-02-14 11:28:58.850	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.windchill_value with -7 °C
    daswetter.0
    2022-02-14 11:28:58.368	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.snowline_value with 1600 m
    daswetter.0
    2022-02-14 11:28:56.793	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.clouds_value with 0%
    daswetter.0
    2022-02-14 11:28:56.031	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.pressure_value with 1018 mb
    daswetter.0
    2022-02-14 11:28:54.955	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.humidity_value with 93
    daswetter.0
    2022-02-14 11:28:54.700	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:28:54.300	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.windgusts_value with 33 km/h
    daswetter.0
    2022-02-14 11:28:54.223	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/45.png
    daswetter.0
    2022-02-14 11:28:54.141	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.wind_value with 16 km/h
    daswetter.0
    2022-02-14 11:28:54.031	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.wind_dir with S
    daswetter.0
    2022-02-14 11:28:53.803	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.wind_symbol with 13
    daswetter.0
    2022-02-14 11:28:53.245	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.wind_symbolB with 45
    daswetter.0
    2022-02-14 11:28:52.683	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.iconURL with /vis.0/main/images/wetter/1.png
    daswetter.0
    2022-02-14 11:28:52.493	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.symbol_value with 1
    daswetter.0
    2022-02-14 11:28:52.275	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.symbol_desc with Sonne
    daswetter.0
    2022-02-14 11:28:52.133	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.symbol_value2 with 1
    daswetter.0
    2022-02-14 11:28:51.865	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.symbol_desc2 with Sonne
    daswetter.0
    2022-02-14 11:28:50.718	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.temp_value with -2 °C
    daswetter.0
    2022-02-14 11:28:50.472	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2.hour_value with 05:00
    daswetter.0
    2022-02-14 11:28:50.229	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_2 with null {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}}
    daswetter.0
    2022-02-14 11:28:49.347	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.windchill_value with -5 °C
    daswetter.0
    2022-02-14 11:28:48.775	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.snowline_value with 1800 m
    daswetter.0
    2022-02-14 11:28:48.703	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.clouds_value with 0%
    daswetter.0
    2022-02-14 11:28:48.450	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.pressure_value with 1019 mb
    daswetter.0
    2022-02-14 11:28:48.347	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.humidity_value with 81
    daswetter.0
    2022-02-14 11:28:48.269	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:28:48.197	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.windgusts_value with 35 km/h
    daswetter.0
    2022-02-14 11:28:48.136	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/44.png
    daswetter.0
    2022-02-14 11:28:48.074	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.wind_value with 16 km/h
    daswetter.0
    2022-02-14 11:28:48.006	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.wind_dir with SE
    daswetter.0
    2022-02-14 11:28:47.935	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.wind_symbol with 12
    daswetter.0
    2022-02-14 11:28:47.867	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.wind_symbolB with 44
    daswetter.0
    2022-02-14 11:28:47.809	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.iconURL with /vis.0/main/images/wetter/1.png
    daswetter.0
    2022-02-14 11:28:47.733	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.symbol_value with 1
    daswetter.0
    2022-02-14 11:28:47.667	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.symbol_desc with Sonne
    daswetter.0
    2022-02-14 11:28:47.543	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.symbol_value2 with 1
    daswetter.0
    2022-02-14 11:28:47.474	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.symbol_desc2 with Sonne
    daswetter.0
    2022-02-14 11:28:47.361	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.temp_value with 0 °C
    daswetter.0
    2022-02-14 11:28:47.263	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1.hour_value with 02:00
    daswetter.0
    2022-02-14 11:28:47.255	debug	insert NextDaysDetailed.Location_1.Day_1.Hour_1 with null {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}}
    daswetter.0
    2022-02-14 11:28:47.255	debug	number of hours 8
    daswetter.0
    2022-02-14 11:28:47.192	debug	insert NextDaysDetailed.Location_1.Day_1.local_info_local_time with 11:28
    daswetter.0
    2022-02-14 11:28:47.129	debug	insert NextDaysDetailed.Location_1.Day_1.local_info_offset with 1
    daswetter.0
    2022-02-14 11:28:47.059	debug	insert NextDaysDetailed.Location_1.Day_1.moonIconURL with /vis.0/main/images/mond/12.png
    daswetter.0
    2022-02-14 11:28:46.998	debug	insert NextDaysDetailed.Location_1.Day_1.moon_in with 14:35
    daswetter.0
    2022-02-14 11:28:46.933	debug	insert NextDaysDetailed.Location_1.Day_1.moon_out with 06:20
    daswetter.0
    2022-02-14 11:28:46.879	debug	insert NextDaysDetailed.Location_1.Day_1.moon_lumi with 94.99%
    daswetter.0
    2022-02-14 11:28:46.824	debug	insert NextDaysDetailed.Location_1.Day_1.moon_desc with zunehm. Mond, 94.99% Beleuchtet
    daswetter.0
    2022-02-14 11:28:46.765	debug	insert NextDaysDetailed.Location_1.Day_1.moon_symbol with 12
    daswetter.0
    2022-02-14 11:28:46.711	debug	insert NextDaysDetailed.Location_1.Day_1.sun_in with 07:02
    daswetter.0
    2022-02-14 11:28:46.653	debug	insert NextDaysDetailed.Location_1.Day_1.sun_mid with 12:08
    daswetter.0
    2022-02-14 11:28:46.593	debug	insert NextDaysDetailed.Location_1.Day_1.sun_out with 17:15
    daswetter.0
    2022-02-14 11:28:46.537	debug	insert NextDaysDetailed.Location_1.Day_1.snowline_value with 1100 m
    daswetter.0
    2022-02-14 11:28:46.484	debug	insert NextDaysDetailed.Location_1.Day_1.pressure_value with 1015 mb
    daswetter.0
    2022-02-14 11:28:46.403	debug	insert NextDaysDetailed.Location_1.Day_1.humidity_value with 71
    daswetter.0
    2022-02-14 11:28:46.339	debug	insert NextDaysDetailed.Location_1.Day_1.rain_value with 0 mm
    daswetter.0
    2022-02-14 11:28:46.267	debug	insert NextDaysDetailed.Location_1.Day_1.windgusts_value with 38 km/h
    daswetter.0
    2022-02-14 11:28:46.206	debug	insert NextDaysDetailed.Location_1.Day_1.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/45.png
    daswetter.0
    2022-02-14 11:28:46.150	debug	insert NextDaysDetailed.Location_1.Day_1.wind_value with 18 km/h
    daswetter.0
    2022-02-14 11:28:46.096	debug	insert NextDaysDetailed.Location_1.Day_1.wind_symbol with 13
    daswetter.0
    2022-02-14 11:28:46.036	debug	insert NextDaysDetailed.Location_1.Day_1.wind_symbolB with 45
    daswetter.0
    2022-02-14 11:28:45.975	debug	insert NextDaysDetailed.Location_1.Day_1.tempmax_value with 9 °C
    daswetter.0
    2022-02-14 11:28:45.915	debug	insert NextDaysDetailed.Location_1.Day_1.tempmin_value with -3 °C
    daswetter.0
    2022-02-14 11:28:45.826	debug	insert NextDaysDetailed.Location_1.Day_1.iconURL with /vis.0/main/images/wetter/1.png
    daswetter.0
    2022-02-14 11:28:45.764	debug	insert NextDaysDetailed.Location_1.Day_1.symbol_value with 1
    daswetter.0
    2022-02-14 11:28:45.711	debug	insert NextDaysDetailed.Location_1.Day_1.symbol_desc with Sonne
    daswetter.0
    2022-02-14 11:28:45.648	debug	insert NextDaysDetailed.Location_1.Day_1.symbol_value2 with 1
    daswetter.0
    2022-02-14 11:28:45.592	debug	insert NextDaysDetailed.Location_1.Day_1.symbol_desc2 with Sonne
    daswetter.0
    2022-02-14 11:28:45.529	debug	insert NextDaysDetailed.Location_1.Day_1.day_value with 20220214
    daswetter.0
    2022-02-14 11:28:45.472	debug	insert NextDaysDetailed.Location_1.Day_1.day_name with Montag
    daswetter.0
    2022-02-14 11:28:45.460	debug	insert NextDaysDetailed.Location_1.Day_1 with null {"type":"channel","common":{"name":"Day 1","role":"weather"}}
    daswetter.0
    2022-02-14 11:28:45.460	debug	number of days 5
    daswetter.0
    2022-02-14 11:28:45.456	debug	insert NextDaysDetailed.Location_1 with null {"type":"device","common":{"name":"Draßburg [Burgenland;Österreich]","role":"weather"}}
    daswetter.0
    2022-02-14 11:28:45.375	debug	insert NextDaysDetailed.Location_1.Location with Draßburg
    daswetter.0
    2022-02-14 11:28:45.375	debug	number of locations 1
    daswetter-log.txt
    free -m gibt
    woody@ioBroker:~$ free -m
    Mem:           5962        4886         912          21         163         857
    Swap:           974         463         511
    woody@ioBroker:~$
    da_WoodyD Online
    da_WoodyD Online
    @da_woody nochmal backup verucht, hat sehr lange gedauert, aber durchgelaufen
    woody@ioBroker:~$ iob backup
    host.ioBroker 123962 states saved
    host.ioBroker 159416 objects saved
    /usr/bin/iob: Zeile 8:  1729 Getötet                sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
    woody@ioBroker:~$
    DiginixD apollon77A 2 Antworten Letzte Antwort
      woody@ioBroker:~$
      DiginixD Offline
      DiginixD Offline
      Diginix
      @da_woody Wow du hast aber auch echt verdammt viele Objekte! Ich habe kein 18000 und frage mich wie man fast das 10 fache schafft... 🤔 Wie viele Adapter und Instanzen laufen bei dir?
      Bei mir läuf iob auch in einer Proxmox VM mit 4 Kernen und 4 GB RAM und die CPU ist meist bei 15-18%. Wäre mit nur 2 Kernen dann aber nicht über 40%. Von JS-Controller 3.x mit file zu 4.x mit jsonl hat sich weder RAM noch CPU Last bei mir verändert:
      @apollon77 Update von 4.0.8 auf 4.0.9 verlief unauffällig.
      ..:: So long! Tom ::..
      • DiginixD Diginix
        da_WoodyD Online
        da_WoodyD Online
        @diginix sagte in js-controller 4.0 jetzt im BETA/LATEST!:
        Wow du hast aber auch echt verdammt viele Objekte! Ich habe kein 18000 und frage mich wie man fast das 10 fache schafft... Wie viele Adapter und Instanzen laufen bei dir?
        genau deswegen glaub ich ja, daß irgendwas doppelt laufen könnte.
        aktiv sind ca 40 instanzen. vor dem ganzen hatte ich so ca. 30-35% prozessorlast. RAM max 50%, kann mich aber nicht genau erinnern.
        die anderen 3 VMs laufen im normalen rahmen. auf den knoten wirkt sich das aber natürlich auch aus.
          DiginixD Offline
          DiginixD Offline
          Diginix
          @da_woody Was steht denn bei dir oben rechts in Objektansicht?
          Ich habe auch 40 Instanzen bei 48 inst. Adaptern. Müsste also mind. 8 mal so viele Geräte besitzen um auf deine Objektanzahl zu kommen. Ist klar möglich, aber wenn du selbst skeptisch bist, stimmt vllt ja wirklich was nicht. Das kannst aber nur du prüfen. Hast du keine alten objects.json von vor paar Wochen/Monaten um mal zu schauen wie viele Objekte damals existierten. Alte Poxmox Backups oder backitup Backups würden da für den Vergleich helfen.
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter.0
            daswetter-log.txt
            free -m gibt
            Swap:           974         463         511
            woody@ioBroker:~$
            @da_woody sagte in js-controller 4.0 jetzt im BETA/LATEST!:
            force terminate
            Also zu daswetter: Das "force terminate" bedeutet das du den parseTimeout hochsetzen solltest, weil er länger braucht die Daten zu verarbeiten als dort angegeben. Bei dir reichen wohl 60s nicht ... Komisch aber ist so :-)
            • DiginixD Diginix
              da_WoodyD Online
              da_WoodyD Online
              naja, kommt schon was zusammen. ca 80 shelly, paar tasmota, PV, entkalkung, sauger, 2x 3d-drucker, 2x synology, ...
              die ioB backups haben sich nicht signifikant vergrößert. so um die 45.000KB
                woody@ioBroker:~$
                Diese Zeile hier macht mich stutzig. Ist das Backup wirklich erstellt worden? Findest Du zeitgleich etwas in /var/log/syslog? Wie groß ist dein Inhalt von /opt/iobroker/iobroker-data/files ?
                  @da_woody Naja "Doppelt laufen" würdest du ja in der Prozessliste sehen ... ps auxwwww|grep io
                  PS/EDIT: Welche DB nutzt du?
                    DiginixD Offline
                    DiginixD Offline
                    Diginix
                    @da_woody Ja dann passt das bei dir auch. Ich habe keine 20 Shelly. Also allein da hast du schon 4 mal so viel und die haben ja nicht wenige Objekte.
                    Und da sagt @apollon77 "hut ab" bei meiner kleinen mini iobroker Instanz 😂
                    • apollon77A apollon77
                      da_WoodyD Online
                      da_WoodyD Online
                      @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                      das getötet ist mir auch zum 2.x aufgefallen... :D
                      log wurde anscheinend erstellt
                      inhalt
                      woody@ioBroker:/opt/iobroker/iobroker-data/files$ ls -la
                      insgesamt 240
                      drwxrwxr-x+ 60 iobroker iobroker 4096 Feb 11 10:21 .
                      drwxrwxr-x+ 13 iobroker iobroker 4096 Feb 14 08:29 ..
                      drwxrwxr-x+  3 iobroker iobroker 4096 Jul 10  2021 admin.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Apr 18  2021 alexa2.admin
                      drwxrwxr-x+  4 iobroker iobroker 4096 Mai  2  2021 alias-manager.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Okt  7 12:16 backitup.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Dez 31 20:41 birthdays.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän  4 21:40 bydbatt.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Sep 19 21:13 daswetter.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Mai  1  2021 device-reminder.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 followthesun.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Jän 24  2021 fronius.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 19 19:24 fronius-solarweb.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 gruenbeck.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 harmony.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Jän 24  2021 ical.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Mai  2  2021 influxdb.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Jän 24  2021 info.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Feb 10 07:19 iot.admin
                      drwxrwxr-x+  6 iobroker iobroker 4096 Dez 27 20:32 iqontrol
                      drwxrwxr-x+  8 iobroker iobroker 4096 Feb  5 16:37 iqontrol.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Jän 24  2021 iqontrol.meta
                      drwxrwxr-x+  6 iobroker iobroker 4096 Dez 15 20:07 javascript.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Aug 26 19:13 klipper-moonraker.admin
                      drwxrwxr-x+  4 iobroker iobroker 4096 Jän 24  2021 linux-control.admin
                      drwxrwxr-x+  5 iobroker iobroker 4096 Jän 15 09:07 logparser.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 meldungsliste.admin
                      drwxrwxr-x+  4 iobroker iobroker 4096 Jul  3  2021 meteoalarm.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Jän  5 11:15 mihome-vacuum.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 mqtt.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Nov  7 13:22 octoprint.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 pi-hole.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Jul 15  2021 ping.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 proxmox
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 proxmox.admin
                      drwxrwxr-x+  4 iobroker iobroker 4096 Aug 15  2021 radar2.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Mär  3  2021 scenes.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Dez  9 07:45 shelly.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Jän 31  2021 shuttercontrol.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Nov 12 19:58 simple-api.admin
                      drwxrwxr-x+  7 iobroker iobroker 4096 Dez 21 02:55 smartcontrol.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 25 09:16 snmp.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Feb  1 12:48 socketio.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Dez 30 12:05 sonoff.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Nov 29 14:31 switchbot-hub.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 synology.0
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 synology.1
                      drwxrwxr-x+  2 iobroker iobroker 4096 Sep  8 22:35 synology.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Nov  7 13:32 trashschedule.admin
                      drwxrwxr-x+  9 iobroker iobroker 4096 Feb 13 10:51 vis
                      drwxrwxr-x+ 10 iobroker iobroker 4096 Jän 23 20:11 vis.0
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 vis.admin
                      drwxrwxr-x+  4 iobroker iobroker 4096 Dez 25 12:47 vis-materialdesign.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 weatherunderground.admin
                      drwxrwxr-x+  5 iobroker iobroker 4096 Jän 24  2021 web
                      drwxrwxr-x+  3 iobroker iobroker 4096 Mär  4  2021 web.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 web-speedy.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Jän 24  2021 whatsapp-cmb.admin
                      drwxrwxr-x+  2 iobroker iobroker 4096 Sep  9 09:00 wled.admin
                      drwxrwxr-x+  3 iobroker iobroker 4096 Feb 11 10:21 ws.admin
                      ausgabe:
                      woody@ioBroker:~$ ps auxwwww|grep io
                      root        12  0.0  0.0      0     0 ?        S    Feb12   0:00 [migration/0]
                      root        16  0.0  0.0      0     0 ?        S    Feb12   0:01 [migration/1]
                      root       203  0.0  0.0      0     0 ?        I<   Feb12   0:00 [rpciod]
                      root       204  0.0  0.0      0     0 ?        I<   Feb12   0:00 [xprtiod]
                      root       351  0.1  0.0   7920  2568 ?        Ss   Feb12   2:49 /bin/bash /home/woody/wetterstation.sh
                      message+   355  0.0  0.0   9084  1364 ?        Ss   Feb12   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                      root      1242  0.0  0.0      0     0 ?        I<   Feb12   0:00 [cifsiod]
                      iobroker 12365 79.3 11.5 1841900 702708 ?      Rsl  Feb13 788:47 iobroker.js-controller
                      iobroker 12386  4.1 10.4 1492652 635884 ?      Sl   Feb13  41:42 io.admin.0
                      iobroker 12586 10.3  2.1 737160 131992 ?       Rl   Feb13 102:45 io.influxdb.0
                      iobroker 12850  6.6  3.8 845664 237632 ?       Sl   Feb13  65:45 io.mqtt.0
                      iobroker 13047  0.0  0.6 666480 36648 ?        Sl   Feb13   0:33 io.ping.0
                      iobroker 13058  6.6  2.8 766216 173996 ?       Sl   Feb13  66:20 io.shelly.0
                      iobroker 13102  0.2  0.9 943492 56932 ?        Sl   Feb13   2:18 io.alexa2.0
                      iobroker 13113  0.1  1.1 1070976 72520 ?       Sl   Feb13   1:25 io.mihome-vacuum.0
                      iobroker 13131  2.4  1.3 704444 84116 ?        Sl   Feb13  24:39 io.sonoff.0
                      iobroker 13148  0.0  0.5 669344 32876 ?        Sl   Feb13   0:23 io.backitup.0
                      iobroker 13354  0.1  0.9 683264 56348 ?        Sl   Feb13   1:49 io.fronius.0
                      iobroker 13365  0.0  0.8 675292 51784 ?        Sl   Feb13   0:50 io.device-reminder.0
                      iobroker 13376  0.2  0.8 940844 54220 ?        Sl   Feb13   2:12 io.gruenbeck.0
                      iobroker 13573  0.0  0.9 927172 60172 ?        Sl   Feb13   0:32 io.info.0
                      iobroker 13596  0.0  0.5 842320 33472 ?        Sl   Feb13   0:28 io.iot.0
                      iobroker 13618  0.0  0.4 11155992 27360 ?      Sl   Feb13   0:26 io.linux-control.0
                      iobroker 13643  0.0  0.7 654740 48680 ?        Sl   Feb13   0:45 io.pi-hole.0
                      iobroker 13654  0.0  0.6 670816 40728 ?        Sl   Feb13   0:26 io.meldungsliste.0
                      iobroker 13660  0.8  1.1 671924 69556 ?        Sl   Feb13   8:11 io.octoprint.0
                      iobroker 13862  0.2  1.0 675316 63264 ?        Sl   Feb13   2:45 io.proxmox.0
                      iobroker 13869  0.2  1.0 945700 62800 ?        Sl   Feb13   2:51 io.radar2.0
                      iobroker 13887  1.9  2.7 794180 166660 ?       Sl   Feb13  19:04 io.simple-api.0
                      iobroker 13899  0.0  0.4 669060 26800 ?        Sl   Feb13   0:23 io.socketio.0
                      iobroker 13912  0.0  0.7 671148 45072 ?        Sl   Feb13   0:29 io.trashschedule.0
                      iobroker 14133  0.1  1.2 961772 77304 ?        Sl   Feb13   1:28 io.web-speedy.0
                      iobroker 14144  0.2  1.4 1009748 91160 ?       Sl   Feb13   2:41 io.web.0
                      iobroker 14367  0.1  0.7 669516 43136 ?        Sl   Feb13   1:03 io.meldungsliste.1
                      iobroker 14382  0.0  0.6 670996 39044 ?        Sl   Feb13   0:26 io.meldungsliste.2
                      iobroker 14393  0.0  0.5 665936 34396 ?        Sl   Feb13   0:25 io.snmp.0
                      iobroker 14400  0.0  0.5 928116 31684 ?        Sl   Feb13   0:24 io.switchbot-hub.0
                      iobroker 14419  0.0  0.8 676772 52168 ?        Sl   Feb13   0:45 io.smartcontrol.0
                      iobroker 14426  0.2  0.9 682412 59984 ?        Sl   Feb13   2:58 io.bydbatt.0
                      iobroker 14437  0.0  0.8 672100 49396 ?        Sl   Feb13   0:54 io.logparser.0
                      iobroker 14460  0.3  0.9 943160 58420 ?        Sl   Feb13   3:46 io.fronius-solarweb.0
                      iobroker 17479  0.0  0.7 676664 43140 ?        Sl   Feb13   0:29 io.scenes.0
                      iobroker 18443  0.0  0.8 674924 50160 ?        Sl   Feb13   0:44 io.synology.0
                      iobroker 18484  0.0  0.8 676836 50584 ?        Sl   Feb13   0:50 io.synology.1
                      iobroker 18905  2.3  1.1 746408 67376 ?        Sl   Feb13  22:37 io.klipper-moonraker.0
                      iobroker 19346 32.8  9.9 1343844 610472 ?      Sl   Feb13 322:00 io.javascript.0
                      iobroker 20445  0.1  3.7 839232 227320 ?       Sl   07:28   0:20 io.iqontrol.0
                      root     24966  0.0  0.0   7920  2152 ?        S    12:34   0:00 /bin/bash /home/woody/wetterstation.sh
                      woody    24985  0.0  0.0   6088   860 pts/0    S+   12:35   0:00 grep io
                      woody@ioBroker:~$
                      DB? meinst du intern? files. redis nutze ich nicht. ansonsten läuft in einer anderen VM influxDB und grafana...
                      • da_WoodyD da_Woody
                        inhalt
                        insgesamt 240
                        ausgabe:
                        woody@ioBroker:~$
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @da_woody ich tippe auf radar2.. schaumal da nach den objekten
                        AlCalzoneA da_WoodyD 2 Antworten Letzte Antwort
                        • arteckA arteck
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          Da scheint der Skript-Adapter auch mächtig ausgelastet zu sein. 32% CPU-Last wenn ich das richtig interpretiere? 1.3GB RAM? Wird der mit state changes bombardiert?
                          • AlCalzoneA AlCalzone
                            DiginixD Offline
                            DiginixD Offline
                            Diginix
                            @alcalzone sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                            @da_Woody Oder Skripte die schlecht performen, zu oft triggern oder oder. Bekommt man am einfachsten heraus wenn man alle Skripte stück für Stück stoppt und schaut wann sich die Last signifikant verringert. Wenn es natürlich die Summe aller Skripte ist und nicht 1-2 ungünstige Skripte, ist es schwieriger.
                            • arteckA arteck
                              da_WoodyD Online
                              da_WoodyD Online
                              @arteck ok, mal gestoppt. proxmox stop/start keine änderung. :(
                              @AlCalzone da läuft nicht viel.
                              der adaptermonitor hat mir warnings gebracht nach stop/start.
                              15:12:57.279	warn	javascript.0 (19346) at checkAdapters (script.js.common.Überwachung.Adapter-Monitor:254:12)
                              15:12:57.280	warn	javascript.0 (19346) at Object.<anonymous> (script.js.common.Überwachung.Adapter-Monitor:378:9)
                              auch gestoppt. nach reboot der ganzen proxmox kiste keine änderung...
                              wenn ich versuche ioB pages aufzurufen, bekomm ich alle möglichen fehler...
                              AlCalzoneA apollon77A 2 Antworten Letzte Antwort
                              • DiginixD Diginix
                                @da_Woody
                                Oder Skripte die unter dem falschen User laufen. Wie das wahrscheinlich:
                                  @da_Woody
                                  da_WoodyD Online
                                  da_WoodyD Online
                                  @thomas-braun versteh ich zwar nicht so ganz, aber ok.
                                  das wurde nach der beschreibung eingerichtet und hat mit 3.3.22 keine probleme gemacht...
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    Muss ja nicht viel sein. Ein einziges Skript kann sehr viel Last verursachen, wenn es häufig triggert und dann viel zu tun hat. Hast du Skripte, in denen du viele States subscribest? Hast du es schon mal mit deaktivierten JS-Adapter versucht? Dein Controller ist auch sehr ausgelastet, ggf. generiert ein Skript ja sehr viele State changes.
                                      Matt77CHE
                                      Ein Ansatz wäre, wenn du wissen möchtest woher die Auslastung kommt, mal alle Instanzen anzuhalten und sie wieder nach und nach laufen zu lassen. Das Selbe evtl auch bei den Skripten...
                                      DiginixD da_WoodyD 2 Antworten Letzte Antwort
                                      • M Matt77CHE
                                        DiginixD Offline
                                        DiginixD Offline
                                        Diginix
                                        @matt77che Es ist doch schon bekannt, dass es die javascript Instanz ist.
                                        Daher muss man das darin verantwortliche Skript finden, falls es eines ist. Können auch mehrere "schlechte" sein.
                                        Bei mir laufen >100 Skripte auf einem recht ähnlichen System, aber javascript braucht nur 2-6 % CPU
                                        • M Matt77CHE
                                          da_WoodyD Online
                                          da_WoodyD Online
                                          @matt77che bin grad an den scripten dran...
                                          ist halt mühsam, wenn man minutenlang braucht, bis vllt eine seite aufgeht.
                                          so, alle scripte deaktiviert. keine änderung...
                                          auch das stoppen der wetterstation mit
                                          sudo systemctl stop wetterstation
                                          der von @Thomas Braun bemängelten wetterstation hat keine änderung gebracht.
                                          einbahnstraße.
                                          werd jetzt mit den adaptern weiter machen...
                                          mir ist schon klar, als nichtlinuxer sollte man stable fummeln. da ich aber gerne, auch für andere, testen tue, mach ich halt so blödsinn. darum raunz ich auch wenig bei problemen rum. ich find meist einen weg (die VM mit influxDB/grafana/TasmoAdmin hab ich auch nach wochen wieder hingebogen). aber da steh ich echt komplett an.
                                          nach wiederstart der wetterstation und status anfrage:
                                          woody@ioBroker:~$ sudo systemctl restart wetterstation
                                          woody@ioBroker:~$ sudo systemctl status wetterstation
                                          ● wetterstation.service - Service für ioBroker Wetterstation
                                             Loaded: loaded (/etc/systemd/system/wetterstation.service; enabled; vendor preset: enabled)
                                             Active: active (running) since Mon 2022-02-14 16:19:46 CET; 7s ago
                                           Main PID: 15493 (wetterstation.s)
                                              Tasks: 2 (limit: 4915)
                                             Memory: 9.0M
                                             CGroup: /system.slice/wetterstation.service
                                                     ├─15493 /bin/bash /home/woody/wetterstation.sh
                                                     └─15510 curl -s HTTP://192.168.0.250:8087/set/0_userdata.0.WoodyWetter._Kommunikationsfehler?value=false&ack=
                                          Feb 14 16:19:46 ioBroker systemd[1]: Started Service für ioBroker Wetterstation.
                                          Feb 14 16:19:46 ioBroker wetterstation.sh[15493]: Connection to 192.168.0.250 8087 port [tcp/*] succeeded!
                                          lines 1-12/12 (END)
