  4. Iobroker backitup error.. Wo liegt das problem
    6.4k
283 Beiträge 14 Kommentatoren 39.3k Aufrufe 8 Beobachtet
  • E elmos04
    @simatec
    habe beides Copy und Paste gemacht.
    Gleiche Meldung
    code_text
    Started iobroker ...
    [DEBUG] [iobroker] - host.raspberrypi 8766 states saved
    [DEBUG] [iobroker] - host.raspberrypi 10664 objects saved
    [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_2_Blaulicht.json is not a valid json file
    [DEBUG] [iobroker] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0
    [DEBUG] [zigbee] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: Garagentor_Status
    [DEBUG] [javascripts] - found Script: Taster_6Fach
    [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
    [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
    [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
    [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
    [DEBUG] [javascripts] - found Script: Gast_Wlan
    [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
    [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
    [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
    [DEBUG] [javascripts] - found Script: Überwachung_Temp
    [DEBUG] [javascripts] - found Script: Rauchmelder
    [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
    [DEBUG] [javascripts] - found Script: Xiaomi_Taster
    [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
    [DEBUG] [javascripts] - found Script: Ikea_Taster_
    [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
    [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
    [DEBUG] [javascripts] - found Script: Duty_Cycle
    [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
    [DEBUG] [javascripts] - found Script: Einbruch_erkannt
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-17_52_40_ioBroker_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [EXIT] 26
    simatecS Offline
    simatecS Offline
    simatec
    #132
    @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
    Gleiche Meldung
    Nein diesesmal ist es 6_Fach_Taster_2_Blaulicht.json
    Da ist irgendwas krum. Was sind das überhaupt für Dateien? Sind die von dir?
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    E 1 Antwort Letzte Antwort
    • simatecS simatec
      Gleiche Meldung
      elmos04
      #133
      @simatec
      Ja das sind Skripte. Ein Blockly welches das Blaulicht einschaltet wenn der Taster gedrückt wird.
      • E elmos04
        @wendy2702
        ja das sind Skripte. die kenne ich
        wendy2702W Online
        wendy2702W Online
        #134
        @elmos04 OK. Siehst du diese Scripte im Script Tab?
        Funktionieren Sie?
        Ist das Script: 6_Fach_Taster_1_Büro_licht noch vorhanden und funktioniert?
        • wendy2702W wendy2702
          Funktionieren Sie?
          elmos04
          #135
          @wendy2702
          die Skripte habe ich alle neu gemacht. die alten habe ich gelöscht. viele Fehler
          • E elmos04
            @homoran das hat der Backitup adapter mir aus dem alten backup kopiert
            simatecS Offline
            simatecS Offline
            simatec
            #136
            Backitup macht nur das, was vorher konfiguriert wurde.
            Backitup legt keine Daten in VIS von alleine ab
            Mach folgendes
            sudo cp /opt/iobroker/iobroker-data/files/vis.0/Tech/*.json /home/pi/
            sudo rm /opt/iobroker/iobroker-data/files/vis.0/Tech/*.json
            • simatecS simatec
              Mach folgendes
              wendy2702W Online
              wendy2702W Online
              #137
              @simatec sagte in Iobroker backitup error.. Wo liegt das problem:
              Mach folgendes
              Damit ist dann auch sein View weg
              • E elmos04
                @wendy2702
                #138
                @elmos04
                Wenn ich so versuche die brauchbaren Informationen aus deinen Posts zusammenzuklauben, dann ergibt sich mir folgendes Szenario am wahrscheinlichsten.
                Du hast mit einem Restore eines defekten Backups deine gesamte Installation zerschossen.
                  Mach folgendes
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #139
                  @wendy2702 Erstmal egal ... die können wir später zurück kopieren
                  Erstmal muss er den ganzen Datenmüll da rausbekommen
                  • E Offline
                    elmos04
                    #140
                    /home/pi/
                    jetzt hab ich ein backup erstellen können
                    • E Offline
                      elmos04
                      #141
                      die vis tech ist nun weg. aber die brauchte ich ja auch nicht mehr.
                      hab ja alles neu gemacht. nun ist sie bei main
                      • E elmos04
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #142
                        nun
                        Wenn du sie nicht brauchst, ist es OK, sonst kannst du sie dir auch aus dem Verzeichnis /home/pi zurückholen
                        • E elmos04
                          /home/pi/
                          wendy2702W Online
                          wendy2702W Online
                          #143
                          @elmos04 dann jetzt das und eine Vis ist wieder da
                          sudo cp /home/pi/vis-views.json /opt/iobroker/iobroker-data/files/vis.0/Tech/
                          EDIT: gerade gelesen das du die nicht mehr brauchst. Dann vergiss es
                          • simatecS simatec
                            nun
                            elmos04
                            #144
                            @simatec
                            Vielen dank
                            alles gut. ich brauche sie nicht. ich habe sogar nun ein backup iobroker 3,3 mb auf dem nas
                              elmos04
                              #145
                              @wendy2702 danke
                              • E elmos04
                                @simatec
                                Vielen dank
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #146
                                @elmos04 Na geht doch .... Bitte nächstes mal gleich alle Infos posten ... Das macht die Fehlversuche einfacher
                                E HomoranH 2 Antworten Letzte Antwort
                                • simatecS simatec
                                  elmos04
                                  #147
                                  @simatec
                                  werde ich machen. danke.
                                  • simatecS simatec
                                    #148
                                    • E elmos04
                                      @simatec
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #149
                                      @elmos04 Setze bitte das Theam auf [gelöst]
                                      • simatecS simatec
                                        elmos04
                                        schrieb am zuletzt editiert von elmos04
                                        #150
                                        @simatec
                                        Toll ein nächstes problem. wo macht man das?🤡
                                        • E elmos04
                                          @simatec
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #151
                                          @elmos04
                                          In deinen ersten Beitrag hier gehen und den Titel ändern. Einfach vor den Titel ein [gelöst] setzen
