  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 503.6k Aufrufe 82 Beobachtet
    Krys
    #732
    Moin nochmal, ich hab auch mal die Schritte von @wendy2702 ausgeführt.
    Hat jemand eventuell einen Durchblick?
    Hier der Log:
    2022-02-07 08:02:02.010 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c3eaffffffffffffffffffffffffffffffff
    2022-02-07 08:02:12.017 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c3f4ffffffffffffffffffffffffffffffff
    2022-02-07 08:02:14.785 - debug: mihome-vacuum.0 (8236) command: roomClean parent: 279001036128
    2022-02-07 08:02:14.789 - debug: mihome-vacuum.0 (8236) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    2022-02-07 08:02:14.794 - debug: mihome-vacuum.0 (8236) We are in onMessage:{"command":"cleanSegments","message":{"segments":[18],"channels":["mihome-vacuum.0.rooms.279001036128"]},"from":"system.adapter.mihome-vacuum.0","_id":36761502}
    2022-02-07 08:02:14.795 - debug: mihome-vacuum.0 (8236) start Cleaning: 18 MObj: {"command":"cleanSegments","message":"18","from":"system.adapter.mihome-vacuum.0","_id":36761502,"segments":[18],"channels":["mihome-vacuum.0.rooms.279001036128"]}
    2022-02-07 08:02:14.797 - info: mihome-vacuum.0 (8236) trigger cleaning segment 18
    2022-02-07 08:02:14.797 - debug: mihome-vacuum.0 (8236) Message= {"id":401,"method":"app_segment_clean","params":[18]}
    2022-02-07 08:02:14.804 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["ok"],"id":401}
    2022-02-07 08:02:14.813 - debug: mihome-vacuum.0 (8236) command: fan_power parent: control
    2022-02-07 08:02:14.813 - debug: mihome-vacuum.0 (8236) Message= {"id":402,"method":"set_custom_mode","params":[102]}
    2022-02-07 08:02:14.816 - debug: mihome-vacuum.0 (8236) command: water_box_mode parent: control
    2022-02-07 08:02:14.816 - debug: mihome-vacuum.0 (8236) Message= {"id":403,"method":"set_water_box_custom_mode","params":[202]}
    2022-02-07 08:02:14.820 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["ok"],"id":402}
    2022-02-07 08:02:14.847 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["ok"],"id":403}
    2022-02-07 08:02:22.022 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c3feffffffffffffffffffffffffffffffff
    2022-02-07 08:02:32.028 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c408ffffffffffffffffffffffffffffffff
    2022-02-07 08:02:40.365 - debug: mihome-vacuum.0 (8236) get params for stock Vacuum
    2022-02-07 08:02:40.365 - debug: mihome-vacuum.0 (8236) Message= {"id":404,"method":"get_status"}
    2022-02-07 08:02:40.375 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":248,"state":18,"battery":100,"clean_time":21,"clean_area":487500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":404}
    2022-02-07 08:02:40.375 - debug: mihome-vacuum.0 (8236) setGetStatus {"msg_ver":2,"msg_seq":248,"state":18,"battery":100,"clean_time":21,"clean_area":487500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
    2022-02-07 08:02:40.376 - debug: mihome-vacuum.0 (8236) Message= {"id":405,"method":"get_map_v1"}
    2022-02-07 08:02:40.377 - debug: mihome-vacuum.0 (8236) Message= {"id":406,"method":"get_network_info"}
    2022-02-07 08:02:40.392 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["retry"],"id":405}
    2022-02-07 08:02:40.413 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":{"ssid":"Krystian","ip":"192.168.178.58","mac":"b0:4a:39:13:19:dc","bssid":"00:5f:67:a3:93:84","rssi":-51},"id":406}
    2022-02-07 08:02:40.485 - debug: mihome-vacuum.0 (8236) Message= {"id":407,"method":"get_sound_volume"}
    2022-02-07 08:02:40.495 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[79],"id":407}
    2022-02-07 08:02:40.496 - debug: mihome-vacuum.0 (8236) Message= {"id":408,"method":"get_carpet_mode"}
    2022-02-07 08:02:40.506 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":408}
    2022-02-07 08:02:40.693 - debug: mihome-vacuum.0 (8236) Message= {"id":409,"method":"get_map_v1"}
    2022-02-07 08:02:40.704 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["retry"],"id":409}
    2022-02-07 08:02:41.005 - debug: mihome-vacuum.0 (8236) Message= {"id":410,"method":"get_map_v1"}
    2022-02-07 08:02:41.016 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F3"],"id":410}
    2022-02-07 08:02:41.016 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:02:41.016 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:02:41.017 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:02:41.122 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/3?Expires=1644219161000&GalaxyAccessKeyId=5271733786445&Signature=kZ9D+FdYDl/uXITgiZZe0cpNmWI=
    2022-02-07 08:02:41.123 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219161
    2022-02-07 08:02:41.123 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217361
    2022-02-07 08:02:41.499 - debug: mihome-vacuum.0 (8236) 25555
    2022-02-07 08:02:42.062 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c412ffffffffffffffffffffffffffffffff
    2022-02-07 08:02:44.555 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:02:44.556 - debug: mihome-vacuum.0 (8236) Message= {"id":411,"method":"get_map_v1"}
    2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F4"],"id":411}
    2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:02:44.660 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/4?Expires=1644219164000&GalaxyAccessKeyId=5271733786445&Signature=QXqCxEhbSSsV2OkZqb0skSJLxQg=
    2022-02-07 08:02:44.660 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219164
    2022-02-07 08:02:44.661 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217364
    2022-02-07 08:02:45.278 - debug: mihome-vacuum.0 (8236) 25555
    2022-02-07 08:02:47.869 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:02:47.870 - debug: mihome-vacuum.0 (8236) Message= {"id":412,"method":"get_map_v1"}
    2022-02-07 08:02:47.880 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F5"],"id":412}
    2022-02-07 08:02:47.881 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:02:47.881 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:02:47.881 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
    2022-02-07 08:02:48.271 - debug: mihome-vacuum.0 (8236) 25430
    2022-02-07 08:02:51.283 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:02:51.284 - debug: mihome-vacuum.0 (8236) Message= {"id":413,"method":"get_map_v1"}
    2022-02-07 08:02:51.296 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F6"],"id":413}
    2022-02-07 08:02:51.297 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:02:51.297 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:02:51.297 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:02:51.396 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/6?Expires=1644219171000&GalaxyAccessKeyId=5271733786445&Signature=JOVj8sTRRKKGWO3ButFXYYK6Nvc=
    2022-02-07 08:02:51.396 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219171
    2022-02-07 08:02:51.396 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217371
    2022-02-07 08:02:51.738 - debug: mihome-vacuum.0 (8236) 25238
    2022-02-07 08:02:52.259 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c41cffffffffffffffffffffffffffffffff
    2022-02-07 08:02:54.266 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:02:54.267 - debug: mihome-vacuum.0 (8236) Message= {"id":414,"method":"get_map_v1"}
    2022-02-07 08:02:54.275 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F7"],"id":414}
    2022-02-07 08:02:54.276 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:02:54.276 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:02:54.276 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:02:54.373 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/7?Expires=1644219174000&GalaxyAccessKeyId=5271733786445&Signature=QljmeiJHnN58Bu5siK+1HzGCs0k=
    2022-02-07 08:02:54.374 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219174
    2022-02-07 08:02:54.374 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217374
    2022-02-07 08:02:54.713 - debug: mihome-vacuum.0 (8236) 25312
    2022-02-07 08:02:57.788 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:02:57.788 - debug: mihome-vacuum.0 (8236) Message= {"id":415,"method":"get_map_v1"}
    2022-02-07 08:02:57.797 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F8"],"id":415}
    2022-02-07 08:02:57.798 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:02:57.798 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:02:57.799 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:02:57.874 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/8?Expires=1644219177000&GalaxyAccessKeyId=5271733786445&Signature=qNhKJEZI78kvEMMQyBq/6R12N2U=
    2022-02-07 08:02:57.875 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219177
    2022-02-07 08:02:57.876 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217377
    2022-02-07 08:02:58.264 - debug: mihome-vacuum.0 (8236) 25354
    2022-02-07 08:03:00.838 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:00.840 - debug: mihome-vacuum.0 (8236) Message= {"id":416,"method":"get_map_v1"}
    2022-02-07 08:03:00.858 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F9"],"id":416}
    2022-02-07 08:03:00.858 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:00.858 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:00.859 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:03:00.958 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/9?Expires=1644219180000&GalaxyAccessKeyId=5271733786445&Signature=91LtXBVlrvGVblqAnfUsY9OmOeY=
    2022-02-07 08:03:00.958 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219180
    2022-02-07 08:03:00.958 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217380
    2022-02-07 08:03:01.270 - debug: mihome-vacuum.0 (8236) 25615
    2022-02-07 08:03:02.265 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c426ffffffffffffffffffffffffffffffff
    2022-02-07 08:03:04.242 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:04.242 - debug: mihome-vacuum.0 (8236) Message= {"id":417,"method":"get_map_v1"}
    2022-02-07 08:03:04.255 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F10"],"id":417}
    2022-02-07 08:03:04.255 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:04.256 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:04.256 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:03:04.330 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/10?Expires=1644219184000&GalaxyAccessKeyId=5271733786445&Signature=s4g+g1JZ/7hruZRLoo6u/QQowKc=
    2022-02-07 08:03:04.330 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219184
    2022-02-07 08:03:04.331 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217384
    2022-02-07 08:03:04.721 - debug: mihome-vacuum.0 (8236) 26110
    2022-02-07 08:03:07.288 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:07.288 - debug: mihome-vacuum.0 (8236) Message= {"id":418,"method":"get_map_v1"}
    2022-02-07 08:03:07.303 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F11"],"id":418}
    2022-02-07 08:03:07.304 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:07.304 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:07.304 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:03:07.409 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/11?Expires=1644219187000&GalaxyAccessKeyId=5271733786445&Signature=k0ovE5vRzOVlmC4bFnQWeGspjOE=
    2022-02-07 08:03:07.410 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219187
    2022-02-07 08:03:07.410 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217387
    2022-02-07 08:03:07.766 - debug: mihome-vacuum.0 (8236) 26406
    2022-02-07 08:03:10.754 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:10.755 - debug: mihome-vacuum.0 (8236) Message= {"id":419,"method":"get_map_v1"}
    2022-02-07 08:03:10.767 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F12"],"id":419}
    2022-02-07 08:03:10.768 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:10.768 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:10.769 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:03:10.871 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/12?Expires=1644219190000&GalaxyAccessKeyId=5271733786445&Signature=9L9+XjC6vv+u5bj8v1wxLvUUqYo=
    2022-02-07 08:03:10.872 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219190
    2022-02-07 08:03:10.872 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217390
    2022-02-07 08:03:11.256 - debug: mihome-vacuum.0 (8236) 26244
    2022-02-07 08:03:12.270 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c430ffffffffffffffffffffffffffffffff
    2022-02-07 08:03:13.781 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:13.781 - debug: mihome-vacuum.0 (8236) Message= {"id":420,"method":"get_map_v1"}
    2022-02-07 08:03:13.791 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F13"],"id":420}
    2022-02-07 08:03:13.792 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:13.792 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:13.792 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:03:13.900 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/13?Expires=1644219193000&GalaxyAccessKeyId=5271733786445&Signature=gaCFlo3zCP1aFleus0VRNaD/MbA=
    2022-02-07 08:03:13.900 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219193
    2022-02-07 08:03:13.900 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217393
    2022-02-07 08:03:14.265 - debug: mihome-vacuum.0 (8236) 25683
    2022-02-07 08:03:17.230 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:17.231 - debug: mihome-vacuum.0 (8236) Message= {"id":421,"method":"get_map_v1"}
    2022-02-07 08:03:17.254 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F14"],"id":421}
    2022-02-07 08:03:17.255 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:17.255 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:17.255 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:03:17.324 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/14?Expires=1644219197000&GalaxyAccessKeyId=5271733786445&Signature=g6zYQULvIEANtK+tZ3N3skLL+o0=
    2022-02-07 08:03:17.324 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219197
    2022-02-07 08:03:17.325 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217397
    2022-02-07 08:03:17.651 - debug: mihome-vacuum.0 (8236) 25668
    2022-02-07 08:03:20.191 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:20.191 - debug: mihome-vacuum.0 (8236) Message= {"id":422,"method":"get_map_v1"}
    2022-02-07 08:03:20.199 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F15"],"id":422}
    2022-02-07 08:03:20.200 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:20.200 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:20.200 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:03:20.298 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/15?Expires=1644219200000&GalaxyAccessKeyId=5271733786445&Signature=LPyMXhuNtIy9L4Sgs0Ks7HZSDxY=
    2022-02-07 08:03:20.299 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219200
    2022-02-07 08:03:20.299 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217400
    2022-02-07 08:03:20.641 - debug: mihome-vacuum.0 (8236) 25684
    2022-02-07 08:03:22.276 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c43affffffffffffffffffffffffffffffff
    2022-02-07 08:03:23.581 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:23.581 - debug: mihome-vacuum.0 (8236) Message= {"id":423,"method":"get_map_v1"}
    2022-02-07 08:03:23.591 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F16"],"id":423}
    2022-02-07 08:03:23.591 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:23.592 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:23.592 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:03:23.685 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/16?Expires=1644219203000&GalaxyAccessKeyId=5271733786445&Signature=XoFLOHO5qmhJsdlSqSqXXDlulfA=
    2022-02-07 08:03:23.686 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219203
    2022-02-07 08:03:23.686 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217403
    2022-02-07 08:03:24.117 - debug: mihome-vacuum.0 (8236) 26057
    2022-02-07 08:03:26.650 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:26.651 - debug: mihome-vacuum.0 (8236) Message= {"id":424,"method":"get_map_v1"}
    2022-02-07 08:03:26.663 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F17"],"id":424}
    2022-02-07 08:03:26.664 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:26.664 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:26.664 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:03:26.756 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/17?Expires=1644219206000&GalaxyAccessKeyId=5271733786445&Signature=Maxdse16d0Hv3gsCI7ZJH91xkEE=
    2022-02-07 08:03:26.756 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219206
    2022-02-07 08:03:26.756 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217406
    2022-02-07 08:03:27.064 - debug: mihome-vacuum.0 (8236) 26325
    2022-02-07 08:03:30.054 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:30.055 - debug: mihome-vacuum.0 (8236) Message= {"id":425,"method":"get_map_v1"}
    2022-02-07 08:03:30.074 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F0"],"id":425}
    2022-02-07 08:03:30.075 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:30.075 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:30.076 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
    2022-02-07 08:03:30.574 - debug: mihome-vacuum.0 (8236) 26198
    2022-02-07 08:03:32.283 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c444ffffffffffffffffffffffffffffffff
    2022-02-07 08:03:33.179 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:33.179 - debug: mihome-vacuum.0 (8236) Message= {"id":426,"method":"get_map_v1"}
    2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F1"],"id":426}
    2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:03:33.285 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/1?Expires=1644219213000&GalaxyAccessKeyId=5271733786445&Signature=TPYft0tbjPJPeVAVgMRG5KyDCNQ=
    2022-02-07 08:03:33.287 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219213
    2022-02-07 08:03:33.287 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217413
    2022-02-07 08:03:33.628 - debug: mihome-vacuum.0 (8236) 25786
    2022-02-07 08:03:36.615 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:36.616 - debug: mihome-vacuum.0 (8236) Message= {"id":427,"method":"get_map_v1"}
    2022-02-07 08:03:36.627 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F2"],"id":427}
    2022-02-07 08:03:36.628 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:36.628 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:36.629 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
    2022-02-07 08:03:36.739 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/2?Expires=1644219216000&GalaxyAccessKeyId=5271733786445&Signature=rPO65+y7scFkbOvqG7y727RptP0=
    2022-02-07 08:03:36.741 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219216
    2022-02-07 08:03:36.742 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217416
    2022-02-07 08:03:37.113 - debug: mihome-vacuum.0 (8236) 25588
    2022-02-07 08:03:39.655 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:39.656 - debug: mihome-vacuum.0 (8236) Message= {"id":428,"method":"get_map_v1"}
    2022-02-07 08:03:39.667 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F3"],"id":428}
    2022-02-07 08:03:39.667 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:39.668 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:39.668 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
    2022-02-07 08:03:40.045 - debug: mihome-vacuum.0 (8236) 25314
    2022-02-07 08:03:41.011 - debug: mihome-vacuum.0 (8236) get params for stock Vacuum
    2022-02-07 08:03:41.011 - debug: mihome-vacuum.0 (8236) Message= {"id":429,"method":"get_status"}
    2022-02-07 08:03:41.023 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":249,"state":18,"battery":100,"clean_time":80,"clean_area":1470000,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":429}
    2022-02-07 08:03:41.023 - debug: mihome-vacuum.0 (8236) setGetStatus {"msg_ver":2,"msg_seq":249,"state":18,"battery":100,"clean_time":80,"clean_area":1470000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
    2022-02-07 08:03:41.024 - debug: mihome-vacuum.0 (8236) Message= {"id":430,"method":"get_network_info"}
    2022-02-07 08:03:41.069 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":{"ssid":"Krystian","ip":"192.168.178.58","mac":"b0:4a:39:13:19:dc","bssid":"00:5f:67:a3:93:84","rssi":-51},"id":430}
    2022-02-07 08:03:41.174 - debug: mihome-vacuum.0 (8236) Message= {"id":431,"method":"get_sound_volume"}
    2022-02-07 08:03:41.183 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[79],"id":431}
    2022-02-07 08:03:41.184 - debug: mihome-vacuum.0 (8236) Message= {"id":432,"method":"get_carpet_mode"}
    2022-02-07 08:03:41.196 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":432}
    2022-02-07 08:03:42.312 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c44effffffffffffffffffffffffffffffff
    2022-02-07 08:03:43.011 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:43.012 - debug: mihome-vacuum.0 (8236) Message= {"id":433,"method":"get_map_v1"}
    2022-02-07 08:03:43.049 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F4"],"id":433}
    2022-02-07 08:03:43.049 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:43.050 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:43.050 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
    2022-02-07 08:03:43.416 - debug: mihome-vacuum.0 (8236) 25246
    2022-02-07 08:03:46.012 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:46.013 - debug: mihome-vacuum.0 (8236) Message= {"id":434,"method":"get_map_v1"}
    2022-02-07 08:03:46.023 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F5"],"id":434}
    2022-02-07 08:03:46.024 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:46.025 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:46.025 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
    2022-02-07 08:03:46.408 - debug: mihome-vacuum.0 (8236) 25246
    2022-02-07 08:03:49.367 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
    2022-02-07 08:03:49.368 - debug: mihome-vacuum.0 (8236) Message= {"id":435,"method":"get_map_v1"}
    2022-02-07 08:03:49.379 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F6"],"id":435}
    2022-02-07 08:03:49.380 - debug: mihome-vacuum.0 (8236) Mappointer_updated
    2022-02-07 08:03:49.380 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
    2022-02-07 08:03:49.381 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
    2022-02-07 08:03:49.754 - debug: mihome-vacuum.0 (8236) 25319
    2022-02-07 08:03:50.480 - error: host.raspberrypi Caught by controller[0]: -vacuum.0: ../node_modules/nan/nan_object_wrap.h:125: static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo&): Assertion `wrap->refs_ == 0' failed.
    2022-02-07 08:03:50.485 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
    2022-02-07 08:03:50.486 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2022-02-07 08:04:20.548 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 4153
    2022-02-07 08:04:22.550 - debug: mihome-vacuum.0 (4153) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-02-07 08:04:22.609 - debug: mihome-vacuum.0 (4153) Objects client ready ... initialize now
    2022-02-07 08:04:22.626 - debug: mihome-vacuum.0 (4153) Objects create System PubSub Client
    2022-02-07 08:04:22.628 - debug: mihome-vacuum.0 (4153) Objects create User PubSub Client
    2022-02-07 08:04:22.629 - debug: mihome-vacuum.0 (4153) Objects client initialize lua scripts
    2022-02-07 08:04:22.656 - debug: mihome-vacuum.0 (4153) Objects connected to redis: 127.0.0.1:9001
    2022-02-07 08:04:22.667 - debug: mihome-vacuum.0 (4153) objectDB connected
    2022-02-07 08:04:22.670 - debug: mihome-vacuum.0 (4153) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-02-07 08:04:22.686 - debug: mihome-vacuum.0 (4153) States create System PubSub Client
    2022-02-07 08:04:22.687 - debug: mihome-vacuum.0 (4153) States create User PubSub Client
    2022-02-07 08:04:22.709 - debug: mihome-vacuum.0 (4153) States connected to redis: 127.0.0.1:9000
    2022-02-07 08:04:22.710 - debug: mihome-vacuum.0 (4153) statesDB connected
    2022-02-07 08:04:23.340 - debug: mihome-vacuum.0 (4153) Plugin sentry Initialize Plugin (enabled=true)
    2022-02-07 08:04:23.732 - info: mihome-vacuum.0 (4153) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 3.3.22
    2022-02-07 08:04:23.843 - debug: mihome-vacuum.0 (4153) load Map creator... true
    2022-02-07 08:04:24.449 - debug: mihome-vacuum.0 (4153) Create State for deviceInfo
    2022-02-07 08:04:24.453 - debug: mihome-vacuum.0 (4153) Create State for deviceInfomac
    2022-02-07 08:04:24.459 - debug: mihome-vacuum.0 (4153) Create State for deviceInfomodel
    2022-02-07 08:04:24.461 - debug: mihome-vacuum.0 (4153) Create State for deviceInfofw_ver
    2022-02-07 08:04:24.462 - debug: mihome-vacuum.0 (4153) Create State for deviceInfowifi_signal
    2022-02-07 08:04:24.463 - debug: mihome-vacuum.0 (4153) MIIO: Config: ip:192.168.178.58 token: 62435048385749766e48576b37643449
    2022-02-07 08:04:24.468 - info: mihome-vacuum.0 (4153) IOT enabled, create state
    2022-02-07 08:04:24.476 - debug: mihome-vacuum.0 (4153) server started on 0.0.0.0:53421
    2022-02-07 08:04:24.490 - debug: mihome-vacuum.0 (4153) Receive <<< Helo <<< 213100200000000018cce8a76200c479ffffffffffffffffffffffffffffffff
    2022-02-07 08:04:24.491 - debug: mihome-vacuum.0 (4153) MAIN: Connected to device, try to get model..
    2022-02-07 08:04:24.494 - debug: mihome-vacuum.0 (4153) Time difference between Mihome Vacuum and ioBroker: 1 sec
    2022-02-07 08:04:24.555 - debug: mihome-vacuum.0 (4153) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1644212115379,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1643712474446}
    2022-02-07 08:04:24.559 - debug: mihome-vacuum.0 (4153) Message= {"id":1,"method":"miIO.info"}
    2022-02-07 08:04:24.581 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"Krystian","bssid":"00:5f:67:a3:93:84","rssi":-55},"netif":{"localIp":"192.168.178.58","mask":"255.255.255.0","gw":"192.168.178.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"B0:4A:39:13:19:DC","token":"62435048385749766e48576b37643449","life":15495}}
    2022-02-07 08:04:24.583 - debug: mihome-vacuum.0 (4153) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"Krystian","bssid":"00:5f:67:a3:93:84","rssi":-55},"netif":{"localIp":"192.168.178.58","mask":"255.255.255.0","gw":"192.168.178.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"B0:4A:39:13:19:DC","token":"62435048385749766e48576b37643449","life":15495}}
    2022-02-07 08:04:24.584 - debug: mihome-vacuum.0 (4153) Get Device data..0
    2022-02-07 08:04:24.585 - debug: mihome-vacuum.0 (4153) Get Device data from robot..
    2022-02-07 08:04:24.743 - debug: mihome-vacuum.0 (4153) DeviceModel selected to: roborock.vacuum.s5e
    2022-02-07 08:04:24.745 - info: mihome-vacuum.0 (4153) select standard vacuum protocol....
    2022-02-07 08:04:24.760 - debug: mihome-vacuum.0 (4153) Xiaomi Cloud: Logging in
    2022-02-07 08:04:24.847 - debug: mihome-vacuum.0 (4153) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2022-02-07 08:04:24.977 - debug: mihome-vacuum.0 (4153) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
    2022-02-07 08:04:25.154 - debug: mihome-vacuum.0 (4153) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"wuSHUJeKc6HMhYWRCti0gg==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCRz7Q/RqjLTS3lbmKzg+q/22dNT+UcWAEgbFu9THRoseGojPLM5s8t4nH37bhEOrR7Meo/fhoeQ1f5pj7NL88F+45TiFuUapnNQaPDcPx0vp+qKSAAYGLOwChuR8Uo5JZrOyZWVlpg9OqrVlkyvr+hxELA8inBOJ0Kiuwhjj/BWmOpk59WDcB8iKlcgqqLGfMwyoxDyFb6ThAwnq9YKcqiQWf2CL4AKAC8CHBBGiug+jJ47mC2H4jKZglQzdWVw6Q34OyFvq1SNs7HG/woTrIcI=","description":"成功","securityStatus":0,"nonce":4666761058257411072,"userId":1669572361,"cUserId":"86_CG49N742pAF3a6YHfpffTQtQ","result":"ok","psecurity":"95LpPnR65AoP22oyffzJZw==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=eilkfp&ticket=0&pwd=1&p_ts=1644217465000&fid=0&p_lm=1&auth=TVxiC72aDVg0qrlNI%2FeOG4zf0QMYoNNXPfh%2Fmee2Mlb0VoBvrR7ZyVebqWb8sqOCuS8RwvxfrnwOrgojDDqqE3XKJaRVo17mNKuE97uMIFWQSUmg0mO6GUzqWUALFrtCykxS9Cr%2BpPPJjgQH1Kk9f6zQmu25QeRXF9xyClWSVQ8%3D&m=1&tsl=0&nonce=2iQsgSYtnpcBoiVo&_ssign=k%2FnkQd%2FwFXEobjI8lJ1VVc8KfFQ%3D","pwd":1,"desc":"成功"}
    2022-02-07 08:04:25.327 - info: mihome-vacuum.0 (4153) settest next timer: not available
    2022-02-07 08:04:25.698 - debug: mihome-vacuum.0 (4153) Login step3: [{"key":"userId","value":"1669572361","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-07T07:04:25.669Z","lastAccessed":"2022-02-07T07:04:25.696Z"},{"key":"cUserId","value":"86_CG49N742pAF3a6YHfpffTQtQ","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-07T07:04:25.680Z","lastAccessed":"2022-02-07T07:04:25.696Z"},{"key":"serviceToken","value":"u7ya0zGFshh2//i/lnx/mbrK7f0f/8fOmtUTmckUQSZIL+zxDyQqStIc2DcIEEN+frAAS+AQ4zqUIJD667DYgjBxu3pfcg5oUVVHqZQsk0ayp6NVpKdBpZimcin38cIF+vW1A3pU1wEVp7u+XtYgrg9CEHV1Ztl/aKOoZRTQnhE=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-07T07:04:25.687Z","lastAccessed":"2022-02-07T07:04:25.696Z"}]
    2022-02-07 08:04:25.699 - debug: mihome-vacuum.0 (4153) Xiaomi Cloud: Login successful
    2022-02-07 08:04:25.719 - debug: mihome-vacuum.0 (4153) Create State for Queue: queue
    2022-02-07 08:04:25.720 - debug: mihome-vacuum.0 (4153) Create State for Queue: clearQueue
    2022-02-07 08:04:25.721 - info: mihome-vacuum.0 (4153) Map selected create states...
    2022-02-07 08:04:25.725 - debug: mihome-vacuum.0 (4153) Create State for map:
    2022-02-07 08:04:25.727 - debug: mihome-vacuum.0 (4153) Create State for map: map64
    2022-02-07 08:04:25.728 - debug: mihome-vacuum.0 (4153) Create State for map: actualMap
    2022-02-07 08:04:25.728 - debug: mihome-vacuum.0 (4153) Create State for map: mapStatus
    2022-02-07 08:04:25.729 - debug: mihome-vacuum.0 (4153) Create State for map: mapURL
    2022-02-07 08:04:25.731 - debug: mihome-vacuum.0 (4153) Create State for map: loadMap
    2022-02-07 08:04:25.733 - debug: mihome-vacuum.0 (4153) Create State done!
    2022-02-07 08:04:25.735 - debug: mihome-vacuum.0 (4153) get params for stock Vacuum
    2022-02-07 08:04:25.736 - debug: mihome-vacuum.0 (4153) Message= {"id":2,"method":"get_status"}
    2022-02-07 08:04:25.752 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":250,"state":18,"battery":100,"clean_time":128,"clean_area":2550000,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":2}
    2022-02-07 08:04:25.755 - debug: mihome-vacuum.0 (4153) setGetStatus {"msg_ver":2,"msg_seq":250,"state":18,"battery":100,"clean_time":128,"clean_area":2550000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
    2022-02-07 08:04:25.758 - info: mihome-vacuum.0 (4153) change states from State control.fan_power
    2022-02-07 08:04:25.778 - info: mihome-vacuum.0 (4153) create states for water box
    2022-02-07 08:04:25.786 - info: mihome-vacuum.0 (4153) create states for water box mode
    2022-02-07 08:04:25.790 - info: mihome-vacuum.0 (4153) create states for mop
    2022-02-07 08:04:25.846 - info: mihome-vacuum.0 (4153) State value to set for "mihome-vacuum.0.cleanmap.actualMap" has to be type "string" but received type "number"
    2022-02-07 08:04:25.921 - debug: mihome-vacuum.0 (4153) Message= {"id":3,"method":"get_map_v1"}
    2022-02-07 08:04:25.931 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":["retry"],"id":3}
    2022-02-07 08:04:26.233 - debug: mihome-vacuum.0 (4153) Message= {"id":4,"method":"get_map_v1"}
    2022-02-07 08:04:26.325 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F8"],"id":4}
    2022-02-07 08:04:26.326 - debug: mihome-vacuum.0 (4153) Mappointer_updated
    2022-02-07 08:04:26.327 - debug: mihome-vacuum.0 (4153) update_Map Mimap enabled
    2022-02-07 08:04:26.328 - debug: mihome-vacuum.0 (4153) update_Map need new mapurl
    2022-02-07 08:04:26.335 - debug: mihome-vacuum.0 (4153) Message= {"id":5,"method":"get_room_mapping"}
    2022-02-07 08:04:26.425 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[16,"279001039807"],[17,"279001039878"],[18,"279001036128"],[19,"279001039845"],[20,"279001039844"],[21,"279001039841"],[22,"279001039842"]],"id":5}
    2022-02-07 08:04:26.428 - debug: mihome-vacuum.0 (4153) Message= {"id":6,"method":"get_map_v1"}
    2022-02-07 08:04:26.430 - debug: mihome-vacuum.0 (4153) Message= {"id":7,"method":"get_network_info"}
    2022-02-07 08:04:26.441 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F8"],"id":6}
    2022-02-07 08:04:26.442 - debug: mihome-vacuum.0 (4153) Mappointer_updated
    2022-02-07 08:04:26.443 - debug: mihome-vacuum.0 (4153) update_Map Mimap enabled
    2022-02-07 08:04:26.443 - debug: mihome-vacuum.0 (4153) update_Map need new mapurl
    2022-02-07 08:04:26.466 - debug: mihome-vacuum.0 (4153) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/8?Expires=1644219266000&GalaxyAccessKeyId=5271733786445&Signature=db2xT7xt6iD/9aiHnVfhBnCQXW8=
    2022-02-07 08:04:26.466 - debug: mihome-vacuum.0 (4153) update_Map got new expires:1644219266
    2022-02-07 08:04:26.468 - debug: mihome-vacuum.0 (4153) update_Map got new time:1644217466
    2022-02-07 08:04:26.490 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":{"ssid":"Krystian","ip":"192.168.178.58","mac":"b0:4a:39:13:19:dc","bssid":"00:5f:67:a3:93:84","rssi":-51},"id":7}
    2022-02-07 08:04:26.556 - debug: mihome-vacuum.0 (4153) Message= {"id":8,"method":"get_sound_volume"}
    2022-02-07 08:04:26.568 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[79],"id":8}
    2022-02-07 08:04:26.571 - debug: mihome-vacuum.0 (4153) Message= {"id":9,"method":"get_multi_maps_list"}
    2022-02-07 08:04:26.580 - debug: mihome-vacuum.0 (4153) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/8?Expires=1644219266000&GalaxyAccessKeyId=5271733786445&Signature=db2xT7xt6iD/9aiHnVfhBnCQXW8=
    2022-02-07 08:04:26.581 - debug: mihome-vacuum.0 (4153) update_Map got new expires:1644219266
    2022-02-07 08:04:26.582 - debug: mihome-vacuum.0 (4153) update_Map got new time:1644217466
    2022-02-07 08:04:26.597 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1644162511,"length":16,"name":"Werler Str. 235 ","bak_maps":[]}]}],"id":9}
    2022-02-07 08:04:26.599 - debug: mihome-vacuum.0 (4153) States for 1 Map: [{"mapFlag":0,"add_time":1644162511,"length":16,"name":"Werler Str. 235 ","bak_maps":[]}]
    2022-02-07 08:04:26.600 - debug: mihome-vacuum.0 (4153) States for Map: {"0":"Werler Str. 235 "}
    2022-02-07 08:04:26.604 - debug: mihome-vacuum.0 (4153) Startup: getMultiMapsList Answer: true
    2022-02-07 08:04:26.605 - debug: mihome-vacuum.0 (4153) Startup: Delete getMultiMapsList
    2022-02-07 08:04:26.606 - debug: mihome-vacuum.0 (4153) Message= {"id":10,"method":"get_clean_summary"}
    2022-02-07 08:04:26.623 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[52822,803020000,88,[1644160121,1644133383,1644044493,1643977111,1643975328,1643974745,1643965653,1643905243,1643901690,1643887247,1643875796,1643805243,1643797070,1643788111,1643785174,1643732552,1643729608,1643720501,1643720432,1643720002]],"id":10}
    2022-02-07 08:04:26.629 - debug: mihome-vacuum.0 (4153) Message= {"id":11,"method":"get_clean_record","params":[1644160121]}
    2022-02-07 08:04:26.641 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1644160121,1644162495,2374,37522500,0,1,2,1,52]],"id":11}
    2022-02-07 08:04:26.643 - debug: mihome-vacuum.0 (4153) Message= {"id":12,"method":"get_clean_record","params":[1644133383]}
    2022-02-07 08:04:26.658 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1644133383,1644137484,3347,28290000,0,0,2,3,60]],"id":12}
    2022-02-07 08:04:26.660 - debug: mihome-vacuum.0 (4153) Message= {"id":13,"method":"get_clean_record","params":[1644044493]}
    2022-02-07 08:04:26.674 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1644044493,1644046203,1710,29342500,0,1,2,3,56]],"id":13}
    2022-02-07 08:04:26.675 - debug: mihome-vacuum.0 (4153) Message= {"id":14,"method":"get_clean_record","params":[1643977111]}
    2022-02-07 08:04:26.688 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643977111,1643979360,2249,35265000,0,1,2,1,52]],"id":14}
    2022-02-07 08:04:26.690 - debug: mihome-vacuum.0 (4153) Message= {"id":15,"method":"get_clean_record","params":[1643975328]}
    2022-02-07 08:04:26.699 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643975328,1643975615,287,3947500,0,1,2,3,56]],"id":15}
    2022-02-07 08:04:26.701 - debug: mihome-vacuum.0 (4153) Message= {"id":16,"method":"get_clean_record","params":[1643974745]}
    2022-02-07 08:04:26.718 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643974745,1643975104,359,5960000,0,1,2,3,56]],"id":16}
    2022-02-07 08:04:26.720 - debug: mihome-vacuum.0 (4153) Message= {"id":17,"method":"get_clean_record","params":[1643965653]}
    2022-02-07 08:04:26.735 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643965653,1643966406,753,12455000,0,1,2,3,56]],"id":17}
    2022-02-07 08:04:26.737 - debug: mihome-vacuum.0 (4153) Message= {"id":18,"method":"get_clean_record","params":[1643905243]}
    2022-02-07 08:04:26.770 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643905243,1643906212,969,16470000,0,1,2,3,56]],"id":18}
    2022-02-07 08:04:26.771 - debug: mihome-vacuum.0 (4153) Message= {"id":19,"method":"get_clean_record","params":[1643901690]}
    2022-02-07 08:04:26.783 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643901690,1643903137,1447,23562500,0,1,2,3,56]],"id":19}
    2022-02-07 08:04:26.785 - debug: mihome-vacuum.0 (4153) Message= {"id":20,"method":"get_clean_record","params":[1643887247]}
    2022-02-07 08:04:26.797 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643887247,1643887856,605,9045000,0,0,2,1,60]],"id":20}
    2022-02-07 08:04:26.798 - debug: mihome-vacuum.0 (4153) Message= {"id":21,"method":"get_clean_record","params":[1643875796]}
    2022-02-07 08:04:27.121 - debug: mihome-vacuum.0 (4153) 26880
    2022-02-07 08:04:27.721 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643875796,1643875823,27,0,0,0,2,1,60]],"id":21}
    2022-02-07 08:04:27.723 - debug: mihome-vacuum.0 (4153) Message= {"id":22,"method":"get_clean_record","params":[1643805243]}
    2022-02-07 08:04:28.121 - debug: mihome-vacuum.0 (4153) 26880
    2022-02-07 08:04:28.672 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643805243,1643805481,236,4040000,0,0,2,1,60]],"id":22}
    2022-02-07 08:04:28.674 - debug: mihome-vacuum.0 (4153) Message= {"id":23,"method":"get_clean_record","params":[1643797070]}
    2022-02-07 08:04:28.689 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643797070,1643800012,2436,38702500,0,1,2,1,52]],"id":23}
    2022-02-07 08:04:28.689 - debug: mihome-vacuum.0 (4153) Message= {"id":24,"method":"get_clean_record","params":[1643788111]}
    2022-02-07 08:04:28.707 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643788111,1643788348,237,3467500,0,1,2,3,56]],"id":24}
    2022-02-07 08:04:28.708 - debug: mihome-vacuum.0 (4153) Message= {"id":25,"method":"get_clean_record","params":[1643785174]}
    2022-02-07 08:04:28.718 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643785174,1643785476,302,4052500,0,1,2,3,56]],"id":25}
    2022-02-07 08:04:28.719 - debug: mihome-vacuum.0 (4153) Message= {"id":26,"method":"get_clean_record","params":[1643732552]}
    2022-02-07 08:04:28.733 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643732552,1643734826,2274,37185000,0,1,2,1,52]],"id":26}
    2022-02-07 08:04:28.734 - debug: mihome-vacuum.0 (4153) Message= {"id":27,"method":"get_clean_record","params":[1643729608]}
    2022-02-07 08:04:28.743 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643729608,1643729616,8,0,0,0,2,1,60]],"id":27}
    2022-02-07 08:04:28.744 - debug: mihome-vacuum.0 (4153) Message= {"id":28,"method":"get_clean_record","params":[1643720501]}
    2022-02-07 08:04:28.772 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643720501,1643720513,12,245000,0,0,2,3,60]],"id":28}
    2022-02-07 08:04:28.772 - debug: mihome-vacuum.0 (4153) Message= {"id":29,"method":"get_clean_record","params":[1643720432]}
    2022-02-07 08:04:28.784 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643720432,1643720461,29,0,0,0,2,1,60]],"id":29}
    2022-02-07 08:04:28.785 - debug: mihome-vacuum.0 (4153) Message= {"id":30,"method":"get_clean_record","params":[1643720002]}
    2022-02-07 08:04:28.796 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643720002,1643720057,55,0,0,0,2,1,60]],"id":30}
    2022-02-07 08:04:28.797 - debug: mihome-vacuum.0 (4153) finish logs all [{"Datum":"6.2","Start":"16:08","Saugzeit":"40 min","Fläche":"37.52 m²","Error":0,"Ende":true},{"Datum":"6.2","Start":"08:43","Saugzeit":"56 min","Fläche":"28.29 m²","Error":0,"Ende":false},{"Datum":"5.2","Start":"08:01","Saugzeit":"29 min","Fläche":"29.34 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"13:18","Saugzeit":"37 min","Fläche":"35.27 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"12:48","Saugzeit":"5 min","Fläche":"3.95 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"12:39","Saugzeit":"6 min","Fläche":"5.96 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"10:07","Saugzeit":"13 min","Fläche":"12.46 m²","Error":0,"Ende":true},{"Datum":"3.2","Start":"17:20","Saugzeit":"16 min","Fläche":"16.47 m²","Error":0,"Ende":true},{"Datum":"3.2","Start":"16:21","Saugzeit":"24 min","Fläche":"23.56 m²","Error":0,"Ende":true},{"Datum":"3.2","Start":"12:20","Saugzeit":"10 min","Fläche":"9.05 m²","Error":0,"Ende":false},{"Datum":"3.2","Start":"09:09","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"2.2","Start":"13:34","Saugzeit":"4 min","Fläche":"4.04 m²","Error":0,"Ende":false},{"Datum":"2.2","Start":"11:17","Saugzeit":"41 min","Fläche":"38.7 m²","Error":0,"Ende":true},{"Datum":"2.2","Start":"08:48","Saugzeit":"4 min","Fläche":"3.47 m²","Error":0,"Ende":true},{"Datum":"2.2","Start":"07:59","Saugzeit":"5 min","Fläche":"4.05 m²","Error":0,"Ende":true},{"Datum":"1.2","Start":"17:22","Saugzeit":"38 min","Fläche":"37.19 m²","Error":0,"Ende":true},{"Datum":"1.2","Start":"16:33","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"1.2","Start":"14:01","Saugzeit":"0 min","Fläche":"0.25 m²","Error":0,"Ende":false},{"Datum":"1.2","Start":"14:00","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"1.2","Start":"13:53","Saugzeit":"1 min","Fläche":"0 m²","Error":0,"Ende":false}]
    2022-02-07 08:04:28.801 - debug: mihome-vacuum.0 (4153) Startup: setGetCleanSummary Answer: true
    2022-02-07 08:04:28.802 - debug: mihome-vacuum.0 (4153) Startup: Delete setGetCleanSummary
    2022-02-07 08:04:28.804 - debug: mihome-vacuum.0 (4153) Message= {"id":31,"method":"get_consumable"}
    2022-02-07 08:04:28.816 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"main_brush_work_time":52916,"side_brush_work_time":52916,"filter_work_time":52916,"filter_element_work_time":2217,"sensor_dirty_time":52822}],"id":31}
    2022-02-07 08:04:28.818 - debug: mihome-vacuum.0 (4153) Startup: setGetConsumable Answer: true
    2022-02-07 08:04:28.818 - debug: mihome-vacuum.0 (4153) Startup: Delete setGetConsumable
    2022-02-07 08:04:28.820 - debug: mihome-vacuum.0 (4153) Message= {"id":32,"method":"get_carpet_mode"}
    2022-02-07 08:04:28.838 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":32}
    2022-02-07 08:04:28.838 - info: mihome-vacuum.0 (4153) create state for carpet_mode
    2022-02-07 08:04:28.839 - debug: mihome-vacuum.0 (4153) Message= {"id":33,"method":"get_carpet_mode"}
    2022-02-07 08:04:28.863 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}
    2022-02-07 08:04:30.701 - debug: mihome-vacuum.0 (4153) Get Mappointer while cleaning
    2022-02-07 08:04:32.083 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
    2022-02-07 08:04:32.084 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2022-02-07 08:04:32.084 - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2022-02-07 08:04:32.121 - info: web-speedy.0 (11730) The speed test has been completed successfully.
    2022-02-07 08:05:02.141 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 4591
    2022-02-07 08:05:03.727 - debug: mihome-vacuum.0 (4591) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-02-07 08:05:03.809 - debug: mihome-vacuum.0 (4591) Objects client ready ... initialize now
    2022-02-07 08:05:03.813 - debug: mihome-vacuum.0 (4591) Objects create System PubSub Client
    2022-02-07 08:05:03.816 - debug: mihome-vacuum.0 (4591) Objects create User PubSub Client
    2022-02-07 08:05:03.817 - debug: mihome-vacuum.0 (4591) Objects client initialize lua scripts
    2022-02-07 08:05:03.847 - debug: mihome-vacuum.0 (4591) Objects connected to redis: 127.0.0.1:9001
    2022-02-07 08:05:03.858 - debug: mihome-vacuum.0 (4591) objectDB connected
    2022-02-07 08:05:03.861 - debug: mihome-vacuum.0 (4591) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-02-07 08:05:03.878 - debug: mihome-vacuum.0 (4591) States create System PubSub Client
    2022-02-07 08:05:03.879 - debug: mihome-vacuum.0 (4591) States create User PubSub Client
    2022-02-07 08:05:03.903 - debug: mihome-vacuum.0 (4591) States connected to redis: 127.0.0.1:9000
    2022-02-07 08:05:03.905 - debug: mihome-vacuum.0 (4591) statesDB connected
    2022-02-07 08:05:04.688 - debug: mihome-vacuum.0 (4591) Plugin sentry Initialize Plugin (enabled=true)
    2022-02-07 08:05:04.926 - info: mihome-vacuum.0 (4591) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 3.3.22
    2022-02-07 08:05:05.018 - debug: mihome-vacuum.0 (4591) load Map creator... true
    2022-02-07 08:05:05.054 - debug: mihome-vacuum.0 (4591) Create State for deviceInfo
    2022-02-07 08:05:05.055 - debug: mihome-vacuum.0 (4591) Create State for deviceInfomac
    2022-02-07 08:05:05.056 - debug: mihome-vacuum.0 (4591) Create State for deviceInfomodel
    2022-02-07 08:05:05.057 - debug: mihome-vacuum.0 (4591) Create State for deviceInfofw_ver
    2022-02-07 08:05:05.058 - debug: mihome-vacuum.0 (4591) Create State for deviceInfowifi_signal
    2022-02-07 08:05:05.059 - debug: mihome-vacuum.0 (4591) MIIO: Config: ip:192.168.178.58 token: 62435048385749766e48576b37643449
    2022-02-07 08:05:05.064 - info: mihome-vacuum.0 (4591) IOT enabled, create state
    2022-02-07 08:05:05.069 - debug: mihome-vacuum.0 (4591) server started on 0.0.0.0:53421
    2022-02-07 08:05:05.097 - debug: mihome-vacuum.0 (4591) Receive <<< Helo <<< 213100200000000018cce8a76200c4a1ffffffffffffffffffffffffffffffff
    2022-02-07 08:05:05.098 - debug: mihome-vacuum.0 (4591) MAIN: Connected to device, try to get model..
    2022-02-07 08:05:05.102 - debug: mihome-vacuum.0 (4591) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1644217464631,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1643712474446}
    2022-02-07 08:05:05.104 - debug: mihome-vacuum.0 (4591) Message= {"id":1,"method":"miIO.info"}
    Rest folgt..
      Krys
      schrieb am zuletzt editiert von Krys
      #733
      Dann ein mal "top":
      pi@raspberrypi:~ $ top
      top - 08:09:58 up 5 days, 22:07,  1 user,  load average: 0.66, 0.96, 1.00
      Tasks: 178 total,   2 running, 176 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 11.2 us,  5.1 sy,  0.2 ni, 82.8 id,  0.0 wa,  0.0 hi,  0.7 si,  0.0 st
      MiB Mem :   3838.7 total,    477.7 free,   2311.3 used,   1049.7 buff/cache
      MiB Swap:    100.0 total,     83.2 free,     16.8 used.   1880.1 avail Mem
        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
       8652 iobroker  20   0  292988 187668  34232 S  18.2   4.8   1011:16 iobroker.js-con
        569 root      20   0  317376 138804  25900 S  11.3   3.5   4061:23 motion
       9943 iobroker  20   0  193116  79904  28928 S   5.0   2.0  39:46.05 io.net-tools.0
       9256 iobroker  20   0  213924  93448  29084 S   4.6   2.4 169:04.11 io.hue.0
      11069 iobroker  20   0  184288  71588  29012 R   3.6   1.8 181:35.12 io.switchbot-bl
       8806 iobroker  20   0  262860 153448  34168 S   3.3   3.9 165:16.32 io.javascript.0
       8701 iobroker  20   0  239256 120404  34756 S   2.0   3.1  15:11.00 io.admin.0
        549 root      39  19   58424   6536   3504 S   0.7   0.2  14:44.84 rpimonitord
       8852 iobroker  20   0  197952  69400  29660 S   0.7   1.8   7:18.09 io.telegram.0
      28966 iobroker  20   0  191620  70628  29868 S   0.7   1.8   1:39.92 io.cloud.0
        356 pi        20   0  129404  41904  30744 S   0.3   1.1  72:02.59 deCONZ
        363 root      20   0    8336   3228   2564 S   0.3   0.1  25:53.14 deCONZ-WIFI2.sh
       1293 iobroker  20   0  185832  79628  33912 S   0.3   2.0   0:08.51 io.tuya.0
       7884 iobroker  20   0    9376    740    632 S   0.3   0.0   0:00.01 ping
       9118 iobroker  20   0  192624  72348  29852 S   0.3   1.8   3:50.66 io.alexa2.0
       9212 iobroker  20   0  203864  75844  29948 S   0.3   1.9  14:13.62 io.hmip.0
       9531 iobroker  20   0  193632  78324  28912 S   0.3   2.0  18:43.25 io.rpi2.0
      10275 iobroker  20   0  184152  63852  28952 S   0.3   1.6   3:31.41 io.geofency.0
      10366 iobroker  20   0  198772  85876  29876 S   0.3   2.2   4:00.00 io.iot.0
      10553 iobroker  20   0  185184  67036  29128 S   0.3   1.7   6:28.77 io.lgtv.1
      11515 iobroker  20   0  183016  61760  28928 S   0.3   1.6   3:27.58 io.vis-inventwo
      11863 iobroker  20   0  206444  95648  29084 S   0.3   2.4  26:46.10 io.yahka.0
      12982 iobroker  20   0  196396  80096  30508 S   0.3   2.0  20:21.84 io.chromecast.0
          1 root      20   0   34832   7696   6248 S   0.0   0.2   2:31.71 systemd
          2 root      20   0       0      0      0 S   0.0   0.0   0:01.04 kthreadd
          3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
          4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
          8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
          9 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_rude_
         10 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_trace
         11 root      20   0       0      0      0 S   0.0   0.0   9:35.07 ksoftirqd/0
         12 root      20   0       0      0      0 I   0.0   0.0   9:36.60 rcu_sched
         13 root      rt   0       0      0      0 S   0.0   0.0   0:11.66 migration/0
         14 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
         15 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
         16 root      rt   0       0      0      0 S   0.0   0.0   0:10.47 migration/1
         17 root      20   0       0      0      0 S   0.0   0.0   0:32.44 ksoftirqd/1
         20 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
         21 root      rt   0       0      0      0 S   0.0   0.0   0:09.52 migration/2
         22 root      20   0       0      0      0 S   0.0   0.0   0:32.02 ksoftirqd/2
         25 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
         26 root      rt   0       0      0      0 S   0.0   0.0   0:08.44 migration/3
         27 root      20   0       0      0      0 S   0.0   0.0   0:31.82 ksoftirqd/3
      Dann einmal "free":
      pi@raspberrypi:~ $ free
      Mem:        3930860     2387076      468780       15168     1075004     1904096
      Swap:        102396       17152       85244
      Dann einmal "df -h":
      pi@raspberrypi:~ $ df -h
      Filesystem      Size  Used Avail Use% Mounted on
      /dev/root        30G  7.1G   21G  26% /
      devtmpfs        1.8G     0  1.8G   0% /dev
      tmpfs           1.9G   16K  1.9G   1% /dev/shm
      tmpfs           1.9G   18M  1.9G   1% /run
      tmpfs           5.0M  8.0K  5.0M   1% /run/lock
      tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1  253M   49M  204M  20% /boot
      tmpfs           384M     0  384M   0% /run/user/1000
      Und "dmesg"
      pi@raspberrypi:~ $ dmesg
      [    0.000000] Booting Linux on physical CPU 0x0
      [    0.000000] Linux version 5.10.63-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1496 SMP Wed Dec 1 15:58:56 GMT 2021
      [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
      [    0.000000] CPU: div instructions available: patching division code
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
      [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
      [    0.000000] random: fast init done
      [    0.000000] Memory policy: Data cache writealloc
      [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [    0.000000] Zone ranges:
      [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
      [    0.000000]   Normal   empty
      [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
      [    0.000000] Movable zone start for each node
      [    0.000000] Early memory node ranges
      [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
      [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
      [    0.000000] On node 0 totalpages: 1012736
      [    0.000000]   DMA zone: 1728 pages used for memmap
      [    0.000000]   DMA zone: 0 pages reserved
      [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
      [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
      [    0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
      [    0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:6A:A3:84 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  115200 console=tty1 root=PARTUUID=2a7ced16-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                     Please use sysfs to set IO scheduler for individual devices.
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [    0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
      [    0.000000] Memory: 3601132K/4050944K available (10240K kernel code, 1364K rwdata, 3192K rodata, 2048K init, 891K bss, 122132K reserved, 327680K cma-reserved, 3264512K highmem)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 34315 entries in 68 pages
      [    0.000000] ftrace: allocated 68 pages with 2 groups
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000]  Rude variant of Tasks RCU enabled.
      [    0.000000]  Tracing variant of Tasks RCU enabled.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [    0.000000] GIC: Using split EOI/Deactivate mode
      [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
      [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
      [    0.000034] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
      [    0.000095] bcm2835: system timer (irq = 25)
      [    0.000742] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [    0.000764] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      [    0.000785] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
      [    0.000803] Switching to timer-based delay loop, resolution 18ns
      [    0.001055] Console: colour dummy device 80x30
      [    0.001810] printk: console [tty1] enabled
      [    0.001878] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
      [    0.001932] pid_max: default: 32768 minimum: 301
      [    0.002107] LSM: Security Framework initializing
      [    0.002303] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.002347] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.003822] cgroup: Disabling memory control group subsystem
      [    0.004068] CPU: Testing write buffer coherency: ok
      [    0.004525] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.005734] Setting up static identity map for 0x200000 - 0x20003c
      [    0.005950] rcu: Hierarchical SRCU implementation.
      [    0.006873] smp: Bringing up secondary CPUs ...
      [    0.008052] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.009372] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [    0.010634] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [    0.010880] smp: Brought up 1 node, 4 CPUs
      [    0.010912] SMP: Total of 4 processors activated (432.00 BogoMIPS).
      [    0.010942] CPU: All CPU(s) started in HYP mode.
      [    0.010969] CPU: Virtualization extensions available.
      [    0.011818] devtmpfs: initialized
      [    0.025835] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
      [    0.026094] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.026147] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.034360] pinctrl core: initialized pinctrl subsystem
      [    0.035441] NET: Registered protocol family 16
      [    0.039071] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      [    0.039847] audit: initializing netlink subsys (disabled)
      [    0.040122] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
      [    0.040688] thermal_sys: Registered thermal governor 'step_wise'
      [    0.041419] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.041474] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.041880] Serial: AMBA PL011 UART driver
      [    0.074985] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [    0.090884] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:01:54, variant start
      [    0.100898] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
      [    0.142222] Kprobes globally optimized
      [    0.147424] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
      [    0.151609] vgaarb: loaded
      [    0.152075] SCSI subsystem initialized
      [    0.152300] usbcore: registered new interface driver usbfs
      [    0.152389] usbcore: registered new interface driver hub
      [    0.152487] usbcore: registered new device driver usb
      [    0.152840] usb_phy_generic phy: supply vcc not found, using dummy regulator
      [    0.154711] clocksource: Switched to clocksource arch_sys_counter
      [    1.113285] VFS: Disk quotas dquot_6.6.0
      [    1.113403] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    1.113580] FS-Cache: Loaded
      [    1.113789] CacheFiles: Loaded
      [    1.123989] NET: Registered protocol family 2
      [    1.124227] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
      [    1.125785] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    1.125944] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [    1.126029] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    1.126117] TCP: Hash tables configured (established 8192 bind 8192)
      [    1.126282] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    1.126337] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    1.126629] NET: Registered protocol family 1
      [    1.127345] RPC: Registered named UNIX socket transport module.
      [    1.127377] RPC: Registered udp transport module.
      [    1.127406] RPC: Registered tcp transport module.
      [    1.127434] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    1.127471] PCI: CLS 0 bytes, default 64
      [    1.130365] Initialise system trusted keyrings
      [    1.130625] workingset: timestamp_bits=14 max_order=20 bucket_order=6
      [    1.139016] zbud: loaded
      [    1.141149] FS-Cache: Netfs 'nfs' registered for caching
      [    1.141941] NFS: Registering the id_resolver key type
      [    1.141994] Key type id_resolver registered
      [    1.142023] Key type id_legacy registered
      [    1.142180] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    1.142213] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
      [    1.143276] Key type asymmetric registered
      [    1.143308] Asymmetric key parser 'x509' registered
      [    1.143512] bounce: pool size: 64 pages
      [    1.143568] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    1.143791] io scheduler mq-deadline registered
      [    1.143822] io scheduler kyber registered
      [    1.148137] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      [    1.148190] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
      [    1.148290] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
      [    1.148399] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
      [    1.206814] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
      [    1.207209] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      [    1.207247] pci_bus 0000:00: root bus resource [bus 00-ff]
      [    1.207295] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
      [    1.207406] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [    1.207661] pci 0000:00:00.0: PME# supported from D0 D3hot
      [    1.211133] PCI: bus0: Fast back to back transfers disabled
      [    1.211487] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [    1.211630] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
      [    1.212079] pci 0000:01:00.0: PME# supported from D0 D3cold
      [    1.215569] PCI: bus1: Fast back to back transfers disabled
      [    1.215647] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      [    1.215688] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
      [    1.215789] pci 0000:00:00.0: PCI bridge to [bus 01]
      [    1.215828] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      [    1.216246] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      [    1.216488] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
      [    1.222362] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
      [    1.223262] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
      [    1.225793] iproc-rng200 fe104000.rng: hwrng registered
      [    1.226120] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      [    1.227018] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
      [    1.239006] brd: module loaded
      [    1.251103] loop: module loaded
      [    1.252856] Loading iSCSI transport class v2.0-870.
      [    1.256117] libphy: Fixed MDIO Bus: probed
      [    1.257818] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      [    1.274758] libphy: bcmgenet MII bus: probed
      [    1.354875] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      [    1.356048] usbcore: registered new interface driver r8152
      [    1.356133] usbcore: registered new interface driver lan78xx
      [    1.356222] usbcore: registered new interface driver smsc95xx
      [    1.357852] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
      [    1.358040] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.358090] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
      [    1.361586] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
      [    1.362924] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
      [    1.362965] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.363002] usb usb1: Product: xHCI Host Controller
      [    1.363031] usb usb1: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
      [    1.363062] usb usb1: SerialNumber: 0000:01:00.0
      [    1.363794] hub 1-0:1.0: USB hub found
      [    1.363908] hub 1-0:1.0: 1 port detected
      [    1.364594] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.364636] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
      [    1.364730] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      [    1.365282] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
      [    1.365322] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.365358] usb usb2: Product: xHCI Host Controller
      [    1.365388] usb usb2: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
      [    1.365418] usb usb2: SerialNumber: 0000:01:00.0
      [    1.366150] hub 2-0:1.0: USB hub found
      [    1.366256] hub 2-0:1.0: 4 ports detected
      [    1.367984] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [    1.368313] dwc_otg: FIQ enabled
      [    1.368328] dwc_otg: NAK holdoff enabled
      [    1.368343] dwc_otg: FIQ split-transaction FSM enabled
      [    1.368361] Module dwc_common_port init
      [    1.368814] usbcore: registered new interface driver uas
      [    1.368940] usbcore: registered new interface driver usb-storage
      [    1.369159] mousedev: PS/2 mouse device common for all mice
      [    1.370815] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [    1.374182] sdhci: Secure Digital Host Controller Interface driver
      [    1.374216] sdhci: Copyright(c) Pierre Ossman
      [    1.374974] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
      [    1.375657] sdhci-pltfm: SDHCI platform and OF driver helper
      [    1.379694] ledtrig-cpu: registered to indicate activity on CPUs
      [    1.380057] hid: raw HID events driver (C) Jiri Kosina
      [    1.380261] usbcore: registered new interface driver usbhid
      [    1.380292] usbhid: USB HID core driver
      [    1.385883] Initializing XFRM netlink socket
      [    1.385948] NET: Registered protocol family 17
      [    1.386080] Key type dns_resolver registered
      [    1.386444] Registering SWP/SWPB emulation handler
      [    1.386627] registered taskstats version 1
      [    1.386669] Loading compiled-in X.509 certificates
      [    1.387614] Key type ._fscrypt registered
      [    1.387644] Key type .fscrypt registered
      [    1.387672] Key type fscrypt-provisioning registered
      [    1.399043] uart-pl011 fe201000.serial: there is not valid maps for state default
      [    1.399368] uart-pl011 fe201000.serial: cts_event_workaround enabled
      [    1.399457] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
      [    1.406791] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
      [    1.407696] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
      [    1.408716] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      [    1.409789] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [    1.409823] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [    1.439555] of_cfs_init
      [    1.439843] of_cfs_init: OK
      [    1.462105] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [    1.463813] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.465524] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.468557] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [    1.470260] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.477392] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
      [    1.478061] Waiting for root device PARTUUID=2a7ced16-02...
      [    1.552411] mmc1: new high speed SDIO card at address 0001
      [    1.584917] mmc0: new ultra high speed DDR50 SDHC card at address 0001
      [    1.585813] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
      [    1.587498]  mmcblk0: p1 p2
      [    1.604398] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [    1.604496] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    1.609682] devtmpfs: mounted
      [    1.619517] Freeing unused kernel memory: 2048K
      [    1.644757] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      [    1.665076] Run /sbin/init as init process
      [    1.665106]   with arguments:
      [    1.665121]     /sbin/init
      [    1.665135]     115200
      [    1.665149]   with environment:
      [    1.665164]     HOME=/
      [    1.665178]     TERM=linux
      [    1.827383] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
      [    1.827430] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      [    1.827464] usb 1-1: Product: USB2.0 Hub
      [    1.829462] hub 1-1:1.0: USB hub found
      [    1.829764] hub 1-1:1.0: 4 ports detected
      [    2.091281] systemd[1]: System time before build time, advancing clock.
      [    2.154779] usb 1-1.2: new full-speed USB device number 3 using xhci_hcd
      [    2.189242] NET: Registered protocol family 10
      [    2.190671] Segment Routing with IPv6
      [    2.259195] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
      [    2.260693] systemd[1]: Detected architecture arm.
      [    2.300815] systemd[1]: Set hostname to <raspberrypi>.
      [    2.303873] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
      [    2.303920] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    2.303957] usb 1-1.2: Product: ConBee II
      [    2.303986] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
      [    2.304019] usb 1-1.2: SerialNumber: DE2251186
      [    2.807967] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
      [    2.809831] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
      [    2.879262] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
      [    2.903901] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
      [    2.996794] random: systemd: uninitialized urandom read (16 bytes read)
      [    3.007780] random: systemd: uninitialized urandom read (16 bytes read)
      [    3.008469] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
      [    3.009494] random: systemd: uninitialized urandom read (16 bytes read)
      [    3.010027] systemd[1]: Listening on Journal Audit Socket.
      [    3.011003] systemd[1]: Listening on Journal Socket (/dev/log).
      [    3.646914] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [    3.742414] systemd-journald[113]: Received request to flush runtime journal from PID 1
      [    4.341189] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
      [    4.341775] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
      [    4.342627] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
      [    4.343199] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
      [    4.391236] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.393370] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [    4.393396] [vc_sm_connected_init]: start
      [    4.394126] [vc_sm_connected_init]: installed successfully
      [    4.400026] mc: Linux media interface: v0.10
      [    4.425701] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.453648] videodev: Linux video capture interface: v2.00
      [    4.470424] bcm2835_audio bcm2835_audio: card created with 8 channels
      [    4.495343] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.514906] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.537416] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.538767] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.563980] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [    4.564027] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [    4.565429] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
      [    4.567787] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
      [    4.568901] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
      [    4.569867] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
      [    4.569897] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [    4.569936] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      [    4.569962] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      [    4.569999] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      [    4.572671] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [    4.578889] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [    4.579002] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [    4.590976] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [    4.591026] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [    4.613586] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
      [    4.613630] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
      [    4.737216] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    4.762754] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
      [    4.837021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
      [    4.837163] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
      [    4.837674] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
      [    4.868383] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    4.921170] brcmfmac: F1 signature read @0x18000000=0x15264345
      [    4.925000] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
      [    4.928725] usbcore: registered new interface driver cdc_acm
      [    4.928743] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [    4.934934] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    4.935836] usbcore: registered new interface driver brcmfmac
      [    5.192384] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    5.193146] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    5.202354] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
      [    7.352014] uart-pl011 fe201000.serial: no DMA platform data
      [    7.612938] random: crng init done
      [    7.612959] random: 7 urandom warning(s) missed due to ratelimiting
      [    7.672507] 8021q: 802.1Q VLAN Support v1.8
      [    8.014812] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
      [    8.072509] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
      [    8.420271] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
      [    8.420527] bcmgenet fd580000.ethernet eth0: Link is Down
      [   12.554918] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
      [   12.554950] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   14.568933] Bluetooth: Core ver 2.22
      [   14.569026] NET: Registered protocol family 31
      [   14.569037] Bluetooth: HCI device and connection manager initialized
      [   14.569059] Bluetooth: HCI socket layer initialized
      [   14.569075] Bluetooth: L2CAP socket layer initialized
      [   14.569098] Bluetooth: SCO socket layer initialized
      [   14.577608] Bluetooth: HCI UART driver ver 2.3
      [   14.577624] Bluetooth: HCI UART protocol H4 registered
      [   14.577697] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [   14.577913] Bluetooth: HCI UART protocol Broadcom registered
      [   14.756909] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [   14.756918] Bluetooth: BNEP filters: protocol multicast
      [   14.756931] Bluetooth: BNEP socket layer initialized
      [  101.775676] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
      [308247.579319] Alignment trap: not handling instruction e1942f9f at [<b6cade64>]
      [308247.579328] 8<--- cut here ---
      [308247.579348] Unhandled fault: alignment exception (0x221) at 0x04b9db27
      [308247.579363] pgd = c8659170
      [308247.579375] [04b9db27] *pgd=11a24003, *pmd=67618003
      [456353.949063] Alignment trap: not handling instruction f4e2c83d at [<0121b100>]
      [456353.949072] 8<--- cut here ---
      [456353.949090] Unhandled fault: alignment exception (0x221) at 0x04d3167e
      [456353.949105] pgd = 19539af6
      [456353.949116] [04d3167e] *pgd=06a1d003, *pmd=9e051003
      pi@raspberrypi:~ $
      Danke im Voraus =)
      Edit: hier noch der syslog:
      syslog
      nodejs
      v14.19.0
      node
      v14.19.0
      npm
      6.14.16
      rpi4 4 GB, 42 Prozesse, ca 50% Ram immer frei.
      • K Krys
        Dann ein mal "top":
        Dann einmal "free":
        Und "dmesg"
        [    1.665135]     115200
        [    1.665164]     HOME=/
        pi@raspberrypi:~ $
        Danke im Voraus =)
        syslog
        nodejs
        v14.19.0
        node
        v14.19.0
        npm
        6.14.16
        D Nicht stören
        D Nicht stören
        dirkhe
        #734
        Auf github gibt es eine neue Version 3.3.5. Probiert die mal aus, bitte. Es kann zwar sein, dass die Map dann nicht mehr erzeugt wird, aber hoffentlich stürzt der Adapter dann nicht mehr ab
        K gelberlemmyG bahnuhrB 3 Antworten Letzte Antwort
        • D dirkhe
          Krys
          #735
          @dirkhe Moin, bei mir stürzt er weiterhin mit SIGSEGV/SIGABRT ab. Hab im Issue kommentiert.
          Edit: Vielen lieben Dank für die MÜHE!
          • D dirkhe
            gelberlemmyG Offline
            gelberlemmy
            #736
            @dirkhe Moin, bei mir läuft es jetzt ohne Abstürze, aber die Map läuft halt nicht mehr.
            Gruss André
            • gelberlemmyG gelberlemmy
              Gruss André
              D Nicht stören
              D Nicht stören
              dirkhe
              #737
              @gelberlemmy ich denke, dass die canvas Bibliothek das Problem ist, da bin ich nicht so tief drin und weiß auch nicht, ob wir da überhaupt was machen können.
              gelberlemmyG bahnuhrB 2 Antworten Letzte Antwort
              • D dirkhe
                gelberlemmy
                #738
                @dirkhe Ok, vor dem jetzigen Update war halt ständige Abstürze und die Map funktionierte. Wobei ich dann doch lieber auf die Map verzichte um die Funktionen zu nutzen. Ich habe, was auch immer Canvas ist, keine Ahnung davon. Aber vielleicht findet sich da ja noch jemand.... Danke aber für Deine super Arbeit.
                Gruss André
                • D dirkhe
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  #739
                  @dirkhe sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                  Ich habe absolut keine Probleme mit dem Adapter.
                  Kein Absturz und map ist auch da.
                  Hast du den Adapter jetzt geändert.
                  d.h. beim nächsten update geht meine map auch nicht mehr ???
                  Danke.
                  • bahnuhrB bahnuhr
                    D Nicht stören
                    D Nicht stören
                    dirkhe
                    #740
                    @bahnuhr nein, was ich gemacht habe, ist ein try catch um die map Generierung zu setzen. Also wenn die map nicht erzeugt werden kann, stürzt nicht sofort der ganze Adapter ab.
                    So wieves aussieht, gibt es Probleme mit der canvas lib unter einer bestimmten node Version.
                    • D dirkhe
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      #741
                      Hier hast du doch geschrieben, dass mit der neuen Version es sein kann, dass die map nicht mehr erzeugt wird.
                      Oder wie muss man dies lesen?
                      Danke.
                      D K 2 Antworten Letzte Antwort
                      • bahnuhrB bahnuhr
                        D Nicht stören
                        D Nicht stören
                        dirkhe
                        #742
                        @bahnuhr nein, damit meinte ich, dass es nicht Probleme mit Karten löst, sonden nur die abstürze des Adapters. Ich hatte genau die Reaktion erwartet, dass jemand sagt, dass die Karte jetzt nicht mehr funktioniert. Das ist halt das Problem, dass der Adapter abstürzt und das als Problem angesehen wird. Jetzt läuft er halt weiter, nur die Karte wird nicht mehr erzeugt. Aber wwenn die Karte erzeugt werden kann, weil du eine funktionierende canvas lib hast, ist alles gut
                        gelberlemmyG 1 Antwort Letzte Antwort
                        • bahnuhrB bahnuhr
                          Krys
                          #743
                          @bahnuhr mit welchem Setup betreibst du deinen ioBroker?
                          • D dirkhe
                            gelberlemmy
                            #744
                            @dirkhe guten Morgen. Hier wurde ja mal ein Workaround für die Canvas beschrieben. Sollte es Sinn ergeben, dass ich dies einmal ausführe ? Was macht die Canvas eigentlich ?
                            • MeistertrM Meistertr
                              Aktuelle Test Version 3.1.6
                              Veröffentlichungsdatum 18.4.2021
                              Github Link https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum
                              Lange hats gedauert aber langsam komm ich zum Ende (wobei das dann wahrscheinlich der Anfang ist :) ).
                              Was hat sich geändert? Alles und nix kann kann man sagen.
                              Der Adapter wurde komplett neu aufgesetzt und dem Aktuellen stand angepasst.
                              vorher:
                              • Nachrichten an den Roboter wurden willkürlich geschickt und gehofft das eine Antwort kommt.
                              • Die Erkennung des Roboters (Modell und Marke und Firmware) wurden durch Ankommende Nachrichten oder das Ausbleiben erkannt
                              • comact mode nicht möglich da zig Timeouts liefen
                              • Keine neuen/anderen Sauger integrierbar da alles in einer Datei lag
                              jetzt:
                              • beim start wird zwingend das Modell ermittelt wonach dann die richtige Datei für den jeweiligen Sauger geladen wird
                              • danach werden Strukturiert die Sonderfunktionen ermittelt und freigegeben
                              • Nachrichten werden nicht mehr willkürlich gesendet sonders strukturiert und jede Nachricht bekommt eine Antwort
                              • comact mode möglich da alle timer zentral gelagert sind
                              ich habe mich bemüht die Objekte zum Vorgänger gleich zu lassen. also Optisch ist nicht viel neu aber wie gesagt unterm Kleid alles was man im debug log sehen sollte.
                              ich habe noch nicht viele Sauger in der Datenbank also kann es zu warn log einträgen kommen, dann bitte modell und bezeichnung posten dann nehm ich sie mit rein.
                              Bitte alles Testen da ich viel ohne Testen umgeschrieben habe (bei über 2000 Zeilen) konnte ich nicht alles direkt testen.
                              Stand Aktuell:
                              Jetzt sollte alles gehen was bei der 2er auch geht. und mehr
                              Was sollte gehen:
                              • alles wie beim alten außer die map (folgt in kürze)
                              • viomi Modelle die sonst über meinen Fork liefen sind nun mit drin
                              • support für den S7 (letztes update hat die History kaputt gemacht)
                              • Map wir unterstützt
                              Fixes:
                              • Map bei zwei Saugern funtionieren
                              • Map wird zuverlässig(er) geladen
                              • 3.0.2 Manueller Map Reload Button funktionert
                              • 3.0.4/ 3.0.7 Timer geht wieder
                              • 3.0.5 Disable map_slot warning, add start button, fix error while sending messages without selected device, fix water_box value
                              • 3.0.6 fix queue States, fix cleaning Buttons.
                              • 3.0.8 fix map for Valetudo
                              • 3.1.0 aktuelle Goto und Zones werden gespeichert
                              • 3.1.1 fix queue
                              • 3.1.3 Map bugfix, add Multimap Support
                              • 3.1.3 fix missing Wifi Signal
                              • 3.1.4 Fix Connrection after reboot/ now wifi
                                3.1.6:
                              • fixed Disk I/O
                              • added get States when map is changed
                              • minimize Messages
                              • changed logentrys from warn to debug
                              • added Donate button
                              folgt in Kürze:
                              - Koordinaten von goto und Zonen werden angezeigt (in den jeweiligen states)
                              • dreame support über miot
                              • compactmode
                                - map
                              • map für history
                              • material tabel
                              • led Status S7
                              • neues Logo
                              • Doku aufbereiten
                              Installieren bitte über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum (einfach von git)
                              Bitte Vorher den alten Adapter vollständig löschen.
                              Dies ist die Alpha also BITTE nur installieren wenn ihr wisst was ihr macht und einen qualifizierten Bugreport liefern könnt
                              Bitte in dieses Thema NUR Fehler oder Requests die den Adapter betreffen. KEINE Installationsfehler oder sonstige Fragen. macht dafür bitte wenn die Suche nichts ergeben hat ein neues Thema auf damit es hier nicht so überläuft wie in den alten Threads..
                              gelberlemmy
                              #745
                              @meistertr so jetzt habe ich wieder die ganzen Abstürtze.Aber erst nachdem er etwas länger gelaufen ist. Hmmm
                              • K Krys
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                #746
                                @krys sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                                admin 5.2.3
                                xiaomi 3.3.1
                                node.js 14.18.3
                                npm 6.14.15
                                host 3.3.22
                                Läuft einwandfrei
                                Keine Abstürze und die map geht auch.
                                Danke.
                                • bahnuhrB bahnuhr
                                  admin 5.2.3
                                  xiaomi 3.3.1
                                  node.js 14.18.3
                                  npm 6.14.15
                                  host 3.3.22
                                  Läuft einwandfrei
                                  Krys
                                  #747
                                  @bahnuhr Merkwürdig. Und auf welchem Gerät läuft dein System?
                                  • K Krys
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    #748
                                    auf einem nuc
                                    und da proxmox und iob in einer vm
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      auf einem nuc
                                      #749
                                      @bahnuhr und welches System ? Ubuntu, Redhat, Debian, Sles... ??
                                      • mrbungle64M Offline
                                        mrbungle64M Offline
                                        mrbungle64
                                        #750
                                        @bahnuhr @Krys
                                        Ihr habt bestimmt unterschiedliche canvas Versionen installiert.
                                        Schaut bitte mal nach:
                                        cd /opt/iobroker/
                                        npm list canvas
                                        gelberlemmyG K 2 Antworten Letzte Antwort
                                        • mrbungle64M mrbungle64
                                          @bahnuhr @Krys
                                          cd /opt/iobroker/
                                          npm list canvas
                                          gelberlemmy
                                          #751
                                          @mrbungle64 ich habe das auch einmal gemacht:
                                          [iobroker.inst@3.0.0 /opt/iobroker
                                          ├─┬ iobroker.iot@1.9.3
                                          │ └── canvas@2.9.0
                                          └─┬ iobroker.mihome-vacuum@3.3.5 (github:iobroker-community-adapters/ioBroker.mi home-vacuum#88dd939cd5a45d90c7e8603047a8f8ba2a72bbbb)
                                          └── canvas@2.9.0 deduped
                                          Was soll ich denn "depuped" bewerten?
                                          mrbungle64M 1 Antwort Letzte Antwort
