  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 503.8k Aufrufe 82 Beobachtet
  • wendy2702W wendy2702
    @gelberlemmy wie sieht das log jetzt aus?
    Wie sieht zum Zeitpunkt des Adapter neu Starts das Linux syslog aus und was zeigt
    dmesg
    gelberlemmyG Offline
    gelberlemmy
    #726
    @wendy2702 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
    dmesg
    pi@raspberrypi:~ $ dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.10.63-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gc        c-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34)        #1496 SMP Wed Dec 1 15:58:56 GMT 2021
    [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
    [    0.000000] random: fast init done
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, s        ize 320 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id share        d-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
    [    0.000000]   Normal   empty
    [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
    [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
    [    0.000000] On node 0 totalpages: 1012480
    [    0.000000]   DMA zone: 1728 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 815872 pages, LIFO batch:63
    [    0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
    [    0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010752
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835        .enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:35:A0        :7E vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200        console=tty1 root=PARTUUID=45196310-02 rootfstype=ext4 elevator=deadline fsck.re        pair=yes rootwait
    [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                   Please use sysfs to set IO scheduler for individual devices.
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes,        linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, li        near)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x000000001889000        0] (64MB)
    [    0.000000] Memory: 3600108K/4049920K available (10240K kernel code, 1364K rw        data, 3192K rodata, 2048K init, 891K bss, 122132K reserved, 327680K cma-reserved        , 3263488K highmem)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 34315 entries in 68 pages
    [    0.000000] ftrace: allocated 68 pages with 2 groups
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000]  Rude variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jif        fies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c wit        h crng_init=1
    [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2        147483647500ns
    [    0.000036] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_        idle_ns: 1911260446275 ns
    [    0.000099] bcm2835: system timer (irq = 25)
    [    0.000749] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [    0.000771] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:        0xc743ce346, max_idle_ns: 440795203123 ns
    [    0.000793] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 43980        46511102ns
    [    0.000811] Switching to timer-based delay loop, resolution 18ns
    [    0.001068] Console: colour dummy device 80x30
    [    0.001828] printk: console [tty1] enabled
    [    0.001895] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 108.00 BogoMIPS (lpj=540000)
    [    0.001949] pid_max: default: 32768 minimum: 301
    [    0.002127] LSM: Security Framework initializing
    [    0.002325] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linea        r)
    [    0.002370] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes,        linear)
    [    0.003854] cgroup: Disabling memory control group subsystem
    [    0.004104] CPU: Testing write buffer coherency: ok
    [    0.004578] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.005811] Setting up static identity map for 0x200000 - 0x20003c
    [    0.006027] rcu: Hierarchical SRCU implementation.
    [    0.006966] smp: Bringing up secondary CPUs ...
    [    0.008186] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.009551] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.010937] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.011097] smp: Brought up 1 node, 4 CPUs
    [    0.011144] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [    0.011174] CPU: All CPU(s) started in HYP mode.
    [    0.011201] CPU: Virtualization extensions available.
    [    0.012063] devtmpfs: initialized
    [    0.026230] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8        rev 0
    [    0.026492] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 19112604462750000 ns
    [    0.026544] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.034792] pinctrl core: initialized pinctrl subsystem
    [    0.035884] NET: Registered protocol family 16
    [    0.039770] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.040556] audit: initializing netlink subsys (disabled)
    [    0.040877] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=        0 res=1
    [    0.041461] thermal_sys: Registered thermal governor 'step_wise'
    [    0.042152] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint        registers.
    [    0.042208] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.042623] Serial: AMBA PL011 UART driver
    [    0.074940] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [    0.090894] raspberrypi-firmware soc:firmware: Attached to firmware from 2021        -12-01T15:01:54, variant start
    [    0.100908] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0        c8575585ba87cbb374d2eeb038f
    [    0.142679] Kprobes globally optimized
    [    0.147873] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [    0.152087] vgaarb: loaded
    [    0.152565] SCSI subsystem initialized
    [    0.152806] usbcore: registered new interface driver usbfs
    [    0.152883] usbcore: registered new interface driver hub
    [    0.152971] usbcore: registered new device driver usb
    [    0.153323] usb_phy_generic phy: supply vcc not found, using dummy regulator
    [    0.155249] clocksource: Switched to clocksource arch_sys_counter
    [    1.114074] VFS: Disk quotas dquot_6.6.0
    [    1.114190] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    1.114368] FS-Cache: Loaded
    [    1.114595] CacheFiles: Loaded
    [    1.124845] NET: Registered protocol family 2
    [    1.125106] IP idents hash table entries: 16384 (order: 5, 131072 bytes, line        ar)
    [    1.126653] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144        bytes, linear)
    [    1.126811] TCP established hash table entries: 8192 (order: 3, 32768 bytes,        linear)
    [    1.126898] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    1.126988] TCP: Hash tables configured (established 8192 bind 8192)
    [    1.127163] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.127219] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.127519] NET: Registered protocol family 1
    [    1.128235] RPC: Registered named UNIX socket transport module.
    [    1.128267] RPC: Registered udp transport module.
    [    1.128296] RPC: Registered tcp transport module.
    [    1.128323] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.128361] PCI: CLS 0 bytes, default 64
    [    1.131299] Initialise system trusted keyrings
    [    1.131564] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    [    1.139938] zbud: loaded
    [    1.142108] FS-Cache: Netfs 'nfs' registered for caching
    [    1.142908] NFS: Registering the id_resolver key type
    [    1.142959] Key type id_resolver registered
    [    1.142987] Key type id_legacy registered
    [    1.143146] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.143179] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering        ...
    [    1.144261] Key type asymmetric registered
    [    1.144293] Asymmetric key parser 'x509' registered
    [    1.144499] bounce: pool size: 64 pages
    [    1.144557] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        49)
    [    1.144784] io scheduler mq-deadline registered
    [    1.144815] io scheduler kyber registered
    [    1.149260] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [    1.149314] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500        000, using [bus 00-ff]
    [    1.149415] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0        x00c0000000
    [    1.149523] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0        x0400000000
    [    1.207345] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
    [    1.207748] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [    1.207785] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.207821] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff]        (bus address [0xc0000000-0xffffffff])
    [    1.207934] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [    1.208192] pci 0000:00:00.0: PME# supported from D0 D3hot
    [    1.211664] PCI: bus0: Fast back to back transfers disabled
    [    1.212020] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [    1.212164] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [    1.212615] pci 0000:01:00.0: PME# supported from D0 D3cold
    [    1.216110] PCI: bus1: Fast back to back transfers disabled
    [    1.216245] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [    1.216287] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64        bit]
    [    1.216391] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    1.216431] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [    1.216851] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [    1.217098] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
    [    1.225656] iproc-rng200 fe104000.rng: hwrng registered
    [    1.225985] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00        000(1023 MiB)
    [    1.226875] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe2        00000
    [    1.239187] brd: module loaded
    [    1.251481] loop: module loaded
    [    1.253262] Loading iSCSI transport class v2.0-870.
    [    1.256618] libphy: Fixed MDIO Bus: probed
    [    1.258332] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [    1.275326] libphy: bcmgenet MII bus: probed
    [    1.355446] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [    1.356647] usbcore: registered new interface driver r8152
    [    1.356733] usbcore: registered new interface driver lan78xx
    [    1.356827] usbcore: registered new interface driver smsc95xx
    [    1.358460] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
    [    1.358642] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.358692] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe        r 1
    [    1.362083] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 qu        irks 0x0000060000000890
    [    1.363447] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc        dDevice= 5.10
    [    1.363489] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
    [    1.363525] usb usb1: Product: xHCI Host Controller
    [    1.363555] usb usb1: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
    [    1.363586] usb usb1: SerialNumber: 0000:01:00.0
    [    1.364331] hub 1-0:1.0: USB hub found
    [    1.364447] hub 1-0:1.0: 1 port detected
    [    1.365135] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.365178] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe        r 2
    [    1.365257] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [    1.365809] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc        dDevice= 5.10
    [    1.365849] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
    [    1.365885] usb usb2: Product: xHCI Host Controller
    [    1.365914] usb usb2: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
    [    1.365944] usb usb2: SerialNumber: 0000:01:00.0
    [    1.366681] hub 2-0:1.0: USB hub found
    [    1.366785] hub 2-0:1.0: 4 ports detected
    [    1.368478] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    1.368798] dwc_otg: FIQ enabled
    [    1.368813] dwc_otg: NAK holdoff enabled
    [    1.368827] dwc_otg: FIQ split-transaction FSM enabled
    [    1.368845] Module dwc_common_port init
    [    1.369296] usbcore: registered new interface driver uas
    [    1.369439] usbcore: registered new interface driver usb-storage
    [    1.369650] mousedev: PS/2 mouse device common for all mice
    [    1.371301] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    1.375133] sdhci: Secure Digital Host Controller Interface driver
    [    1.375168] sdhci: Copyright(c) Pierre Ossman
    [    1.375963] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [    1.376557] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.380662] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.381014] hid: raw HID events driver (C) Jiri Kosina
    [    1.381236] usbcore: registered new interface driver usbhid
    [    1.381268] usbhid: USB HID core driver
    [    1.387202] Initializing XFRM netlink socket
    [    1.387265] NET: Registered protocol family 17
    [    1.387408] Key type dns_resolver registered
    [    1.387776] Registering SWP/SWPB emulation handler
    [    1.387978] registered taskstats version 1
    [    1.388020] Loading compiled-in X.509 certificates
    [    1.388880] Key type ._fscrypt registered
    [    1.388912] Key type .fscrypt registered
    [    1.388940] Key type fscrypt-provisioning registered
    [    1.400477] uart-pl011 fe201000.serial: there is not valid maps for state def        ault
    [    1.400804] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [    1.400910] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud        = 0) is a PL011 rev2
    [    1.408294] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive        r
    [    1.409399] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    1.409433] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [    1.439706] of_cfs_init
    [    1.440000] of_cfs_init: OK
    [    1.460353] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    1.462064] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.463766] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.466814] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    1.468521] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.475883] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
    [    1.476536] Waiting for root device PARTUUID=45196310-02...
    [    1.537217] mmc1: new high speed SDIO card at address 0001
    [    1.545694] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    [    1.583288] usb 2-2: New USB device found, idVendor=2109, idProduct=0715, bcd        Device= 0.00
    [    1.583330] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    1.583364] usb 2-2: Product: VLI Product String
    [    1.583395] usb 2-2: Manufacturer: VLI Manufacture String
    [    1.583425] usb 2-2: SerialNumber: 000000123B02
    [    1.607399] scsi host0: uas
    [    1.609384] scsi 0:0:0:0: Direct-Access     TYPEC 12 0GB PSSD         T050 PQ        : 0 ANSI: 6
    [    1.612623] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112        GiB)
    [    1.612870] sd 0:0:0:0: [sda] Write Protect is off
    [    1.612905] sd 0:0:0:0: [sda] Mode Sense: 2f 00 00 00
    [    1.613322] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, does        n't support DPO or FUA
    [    1.614233] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
    [    1.617655]  sda: sda1 sda2
    [    1.621390] sd 0:0:0:0: [sda] Attached SCSI disk
    [    1.637481] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts:        (null)
    [    1.637585] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [    1.640202] devtmpfs: mounted
    [    1.650169] Freeing unused kernel memory: 2048K
    [    1.705588] Run /sbin/init as init process
    [    1.705618]   with arguments:
    [    1.705633]     /sbin/init
    [    1.705647]   with environment:
    [    1.705662]     HOME=/
    [    1.705676]     TERM=linux
    [    1.725300] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [    1.902448] systemd[1]: System time before build time, advancing clock.
    [    1.907861] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcd        Device= 4.21
    [    1.907907] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [    1.907940] usb 1-1: Product: USB2.0 Hub
    [    1.910148] hub 1-1:1.0: USB hub found
    [    1.910395] hub 1-1:1.0: 4 ports detected
    [    1.970190] NET: Registered protocol family 10
    [    1.971629] Segment Routing with IPv6
    [    2.014192] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL        INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +        XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr        id)
    [    2.015029] systemd[1]: Detected architecture arm.
    [    2.061365] systemd[1]: Set hostname to <raspberrypi>.
    [    2.245310] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
    [    2.376106] usb 1-1.1: New USB device found, idVendor=0451, idProduct=bef3, b        cdDevice= 1.00
    [    2.376157] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber        =3
    [    2.376232] usb 1-1.1: Product: XDS110 (03.00.00.15) Embed with CMSIS-DAP
    [    2.376267] usb 1-1.1: Manufacturer: Texas Instruments
    [    2.376297] usb 1-1.1: SerialNumber: L1100KFN
    [    2.389601] hid-generic 0003:0451:BEF3.0001: hiddev96,hidraw0: USB HID v1.11        Device [Texas Instruments XDS110 (03.00.00.15) Embed with CMSIS-DAP] on usb-0000        :01:00.0-1.1/input5
    [    2.485312] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
    [    2.571849] systemd[1]: /lib/systemd/system/nut-monitor.service:6: PIDFile= r        eferences path below legacy directory /var/run/, updating /var/run/nut/upsmon.pi        d → /run/nut/upsmon.pid; please update the unit file accordingly.
    [    2.622012] usb 1-1.3: New USB device found, idVendor=0658, idProduct=0200, b        cdDevice= 0.00
    [    2.622139] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber        =0
    [    2.641458] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.650270] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.650989] systemd[1]: Listening on Syslog Socket.
    [    2.651793] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.652161] systemd[1]: Started Dispatch Password Requests to Console Directo        ry Watch.
    [    2.654693] systemd[1]: Created slice User and Session Slice.
    [    2.655954] systemd[1]: Listening on udev Control Socket.
    [    2.658541] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [    2.659007] systemd[1]: Reached target Swap.
    [    2.725345] usb 1-1.4: new high-speed USB device number 5 using xhci_hcd
    [    2.860632] usb 1-1.4: New USB device found, idVendor=2109, idProduct=2813, b        cdDevice=90.11
    [    2.860686] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber        =0
    [    2.860728] usb 1-1.4: Product: USB2.0 Hub
    [    2.860771] usb 1-1.4: Manufacturer: VIA Labs, Inc.
    [    2.863301] hub 1-1.4:1.0: USB hub found
    [    2.863980] hub 1-1.4:1.0: 4 ports detected
    [    3.235335] usb 1-1.4.1: new full-speed USB device number 6 using xhci_hcd
    [    3.296746] EXT4-fs (sda2): re-mounted. Opts: (null)
    [    3.393523] usb 1-1.4.1: New USB device found, idVendor=0403, idProduct=6001,        bcdDevice= 6.00
    [    3.393547] usb 1-1.4.1: New USB device strings: Mfr=1, Product=2, SerialNumb        er=3
    [    3.393566] usb 1-1.4.1: Product: EnOcean USB 300 DB
    [    3.393583] usb 1-1.4.1: Manufacturer: EnOcean GmbH
    [    3.393600] usb 1-1.4.1: SerialNumber: FT2VDBHJ
    [    3.406977] systemd-journald[121]: Received request to flush runtime journal        from PID 1
    [    3.606103] usb 1-1.4.4: new low-speed USB device number 7 using xhci_hcd
    [    3.795440] usb 1-1.4.4: New USB device found, idVendor=06da, idProduct=ffff,        bcdDevice= 0.03
    [    3.795464] usb 1-1.4.4: New USB device strings: Mfr=1, Product=2, SerialNumb        er=4
    [    3.795483] usb 1-1.4.4: Product: Offline UPS
    [    3.795501] usb 1-1.4.4: Manufacturer: PPC
    [    3.795518] usb 1-1.4.4: SerialNumber: 000000000
    [    3.832131] hid-generic 0003:06DA:FFFF.0002: hiddev97,hidraw1: USB HID v1.00        Device [PPC Offline UPS] on usb-0000:01:00.0-1.4.4/input0
    [    3.993496] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Reg        isters at 0xfeb00000 length 0x00010000
    [    4.011322] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised        : Registers at 0xfeb10000 length 0x00001000
    [    4.017000] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Reg        isters at 0xfeb20000 length 0x00010000
    [    4.018635] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Regis        ters at 0xfeb30000 length 0x00010000
    [    4.068275] vc_sm_cma: module is from the staging directory, the quality is u        nknown, you have been warned.
    [    4.072195] snd_bcm2835: module is from the staging directory, the quality is        unknown, you have been warned.
    [    4.080519] mc: Linux media interface: v0.10
    [    4.106329] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [    4.106377] [vc_sm_connected_init]: start
    [    4.108395] bcm2835_audio bcm2835_audio: card created with 8 channels
    [    4.116064] [vc_sm_connected_init]: installed successfully
    [    4.139182] videodev: Linux video capture interface: v2.00
    [    4.169515] bcm2835_mmal_vchiq: module is from the staging directory, the qua        lity is unknown, you have been warned.
    [    4.173809] bcm2835_codec: module is from the staging directory, the quality        is unknown, you have been warned.
    [    4.176267] bcm2835_mmal_vchiq: module is from the staging directory, the qua        lity is unknown, you have been warned.
    [    4.180224] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [    4.180273] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [    4.182769] bcm2835_v4l2: module is from the staging directory, the quality i        s unknown, you have been warned.
    [    4.183234] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [    4.183275] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [    4.194840] bcm2835_isp: module is from the staging directory, the quality is        unknown, you have been warned.
    [    4.195495] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [    4.195544] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [    4.218557] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
    [    4.218606] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
    [    4.224258] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev        /video13
    [    4.225045] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de        v/video14
    [    4.225636] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de        v/video15
    [    4.225960] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/        video16
    [    4.225991] bcm2835-isp bcm2835-isp: Register output node 0 with media contro        ller
    [    4.226017] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr        oller
    [    4.226057] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr        oller
    [    4.226080] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr        oller
    [    4.226292] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [    4.227125] [drm] No displays found. Consider forcing hotplug if HDMI is atta        ched
    [    4.227251] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [    4.227702] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
    [    4.232491] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
    [    4.239032] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [    4.342828] cdc_acm 1-1.1:1.3: ttyACM1: USB ACM device
    [    4.445025] cfg80211: Loading compiled-in X.509 certificates for regulatory d        atabase
    [    4.462728] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
    [    4.487851] cdc_acm 1-1.3:1.0: ttyACM2: USB ACM device
    [    4.494266] usbcore: registered new interface driver cdc_acm
    [    4.494289] cdc_acm: USB Abstract Control Model driver for USB modems and ISD        N adapters
    [    4.534510] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    4.600238] brcmfmac: F1 signature read @0x18000000=0x15264345
    [    4.636647] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f        or chip BCM4345/6
    [    4.640581] usbcore: registered new interface driver brcmfmac
    [    4.881373] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f        or chip BCM4345/6
    [    4.881496] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f        or chip BCM4345/6
    [    4.891187] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4        2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    [    5.160808] usbcore: registered new interface driver usbserial_generic
    [    5.160892] usbserial: USB Serial support registered for generic
    [    5.174659] usbcore: registered new interface driver ftdi_sio
    [    5.174745] usbserial: USB Serial support registered for FTDI USB Serial Devi        ce
    [    5.180183] ftdi_sio 1-1.4.1:1.0: FTDI USB Serial Device converter detected
    [    5.180368] usb 1-1.4.1: Detected FT232RL
    [    5.183961] usb 1-1.4.1: FTDI USB Serial Device converter now attached to tty        USB0
    [    6.842846] random: crng init done
    [    6.842867] random: 7 urandom warning(s) missed due to ratelimiting
    [    7.290393] 8021q: 802.1Q VLAN Support v1.8
    [    7.468919] uart-pl011 fe201000.serial: no DMA platform data
    [    7.655285] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:1        02396k FS
    [    7.844834] bcmgenet fd580000.ethernet: configuring instance for external RGM        II (RX delay)
    [    7.845136] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow c        ontrol rx/tx
    [    7.845690] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [    9.678301] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net        .ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
    [   14.181499] Bluetooth: Core ver 2.22
    [   14.181557] NET: Registered protocol family 31
    [   14.181565] Bluetooth: HCI device and connection manager initialized
    [   14.181579] Bluetooth: HCI socket layer initialized
    [   14.181588] Bluetooth: L2CAP socket layer initialized
    [   14.181605] Bluetooth: SCO socket layer initialized
    [   14.188776] Bluetooth: HCI UART driver ver 2.3
    [   14.188788] Bluetooth: HCI UART protocol H4 registered
    [   14.188841] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   14.188973] Bluetooth: HCI UART protocol Broadcom registered
    [   14.324455] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   14.324466] Bluetooth: BNEP filters: protocol multicast
    [   14.324480] Bluetooth: BNEP socket layer initialized
    [   31.835281] vcc-sd: disabling
    [  105.805121] device eth0 entered promiscuous mode
    [  109.199778] FS-Cache: Netfs 'cifs' registered for caching
    [  109.207085] Key type cifs.spnego registered
    [  109.207104] Key type cifs.idmap registered
    [  109.207840] CIFS: Attempting to mount //192.168.171.56/home/iobroker
    [47034.800858] CIFS: Attempting to mount //192.168.171.56/home/iobroker
    [73200.221796] Alignment trap: not handling instruction e1942f9f at [<b6d47e64>]
    [73200.221807] 8<--- cut here ---
    [73200.221828] Unhandled fault: alignment exception (0x221) at 0x04c38b27
    [73200.221842] pgd = d0d84087
    [73200.221852] [04c38b27] *pgd=030b0003, *pmd=57a41003
    [133436.244438] CIFS: Attempting to mount //192.168.171.56/home/iobroker
    [166100.269747] device eth0 left promiscuous mode
    [166392.173609] device eth0 entered promiscuous mode
      dmesg
      gelberlemmy
      #727
      @wendy2702 Linux Syslog wo finde ich das ?
      • gelberlemmyG gelberlemmy
        wendy2702W Online
        wendy2702W Online
        #728
        @gelberlemmy sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
        /var/log/
        Zu einer Meldung im dmesg
        https://www.google.de/search?q=Alignment+trap%3A+not+handling+instruction&ie=UTF-8&oe=UTF-8&hl=de-de&client=safari
        gelberlemmyG 1 Antwort Letzte Antwort
          /var/log/
          gelberlemmy
          #729
          @wendy2702
          super danke. Den Fehler muss ich mir mal Ruhe gönnen, da ich diesen Dingen nicht so fit bin.
          Kann das ein fehlverhalten meines IOBrokers bewirken ?
          Anbei der LOG aus dem Linux System. Die UPS Meldung ingnorieren. Aktuell geht meine USV nicht.
          Log als File, da zu lang .👷
          syslog
            @wendy2702
            syslog
            wendy2702W Online
            wendy2702W Online
            #730
            @gelberlemmy die Meldung in Dmesg deutet auch auf ein Speicher Problem so auf die schnelle am Handy gelesen.
            Kann also Auswirkungen auf Iob haben oder durch Iob kommen.
            • D3ltoroxpD Offline
              D3ltoroxpD Offline
              D3ltoroxp
              schrieb am zuletzt editiert von D3ltoroxp
              #731
              Hm hat hier noch wer Probleme mit der Map ? Seit heute sieht die so aus. Heute Nacht war sie noch richtig.
              EDIT:
              Hat sich erledigt, der hing in irgendeinem Reinigungsmodus fest, nach dem beenden und zurücksetzten, ist sie wieder da.
                Krys
                #732
                Moin nochmal, ich hab auch mal die Schritte von @wendy2702 ausgeführt.
                Hat jemand eventuell einen Durchblick?
                Hier der Log:
                2022-02-07 08:02:02.010 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c3eaffffffffffffffffffffffffffffffff
                2022-02-07 08:02:12.017 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c3f4ffffffffffffffffffffffffffffffff
                2022-02-07 08:02:14.785 - debug: mihome-vacuum.0 (8236) command: roomClean parent: 279001036128
                2022-02-07 08:02:14.789 - debug: mihome-vacuum.0 (8236) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                2022-02-07 08:02:14.794 - debug: mihome-vacuum.0 (8236) We are in onMessage:{"command":"cleanSegments","message":{"segments":[18],"channels":["mihome-vacuum.0.rooms.279001036128"]},"from":"system.adapter.mihome-vacuum.0","_id":36761502}
                2022-02-07 08:02:14.795 - debug: mihome-vacuum.0 (8236) start Cleaning: 18 MObj: {"command":"cleanSegments","message":"18","from":"system.adapter.mihome-vacuum.0","_id":36761502,"segments":[18],"channels":["mihome-vacuum.0.rooms.279001036128"]}
                2022-02-07 08:02:14.797 - info: mihome-vacuum.0 (8236) trigger cleaning segment 18
                2022-02-07 08:02:14.797 - debug: mihome-vacuum.0 (8236) Message= {"id":401,"method":"app_segment_clean","params":[18]}
                2022-02-07 08:02:14.804 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["ok"],"id":401}
                2022-02-07 08:02:14.813 - debug: mihome-vacuum.0 (8236) command: fan_power parent: control
                2022-02-07 08:02:14.813 - debug: mihome-vacuum.0 (8236) Message= {"id":402,"method":"set_custom_mode","params":[102]}
                2022-02-07 08:02:14.816 - debug: mihome-vacuum.0 (8236) command: water_box_mode parent: control
                2022-02-07 08:02:14.816 - debug: mihome-vacuum.0 (8236) Message= {"id":403,"method":"set_water_box_custom_mode","params":[202]}
                2022-02-07 08:02:14.820 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["ok"],"id":402}
                2022-02-07 08:02:14.847 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["ok"],"id":403}
                2022-02-07 08:02:22.022 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c3feffffffffffffffffffffffffffffffff
                2022-02-07 08:02:32.028 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c408ffffffffffffffffffffffffffffffff
                2022-02-07 08:02:40.365 - debug: mihome-vacuum.0 (8236) get params for stock Vacuum
                2022-02-07 08:02:40.365 - debug: mihome-vacuum.0 (8236) Message= {"id":404,"method":"get_status"}
                2022-02-07 08:02:40.375 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":248,"state":18,"battery":100,"clean_time":21,"clean_area":487500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":404}
                2022-02-07 08:02:40.375 - debug: mihome-vacuum.0 (8236) setGetStatus {"msg_ver":2,"msg_seq":248,"state":18,"battery":100,"clean_time":21,"clean_area":487500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
                2022-02-07 08:02:40.376 - debug: mihome-vacuum.0 (8236) Message= {"id":405,"method":"get_map_v1"}
                2022-02-07 08:02:40.377 - debug: mihome-vacuum.0 (8236) Message= {"id":406,"method":"get_network_info"}
                2022-02-07 08:02:40.392 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["retry"],"id":405}
                2022-02-07 08:02:40.413 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":{"ssid":"Krystian","ip":"192.168.178.58","mac":"b0:4a:39:13:19:dc","bssid":"00:5f:67:a3:93:84","rssi":-51},"id":406}
                2022-02-07 08:02:40.485 - debug: mihome-vacuum.0 (8236) Message= {"id":407,"method":"get_sound_volume"}
                2022-02-07 08:02:40.495 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[79],"id":407}
                2022-02-07 08:02:40.496 - debug: mihome-vacuum.0 (8236) Message= {"id":408,"method":"get_carpet_mode"}
                2022-02-07 08:02:40.506 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":408}
                2022-02-07 08:02:40.693 - debug: mihome-vacuum.0 (8236) Message= {"id":409,"method":"get_map_v1"}
                2022-02-07 08:02:40.704 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["retry"],"id":409}
                2022-02-07 08:02:41.005 - debug: mihome-vacuum.0 (8236) Message= {"id":410,"method":"get_map_v1"}
                2022-02-07 08:02:41.016 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F3"],"id":410}
                2022-02-07 08:02:41.016 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:02:41.016 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:02:41.017 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:02:41.122 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/3?Expires=1644219161000&GalaxyAccessKeyId=5271733786445&Signature=kZ9D+FdYDl/uXITgiZZe0cpNmWI=
                2022-02-07 08:02:41.123 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219161
                2022-02-07 08:02:41.123 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217361
                2022-02-07 08:02:41.499 - debug: mihome-vacuum.0 (8236) 25555
                2022-02-07 08:02:42.062 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c412ffffffffffffffffffffffffffffffff
                2022-02-07 08:02:44.555 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:02:44.556 - debug: mihome-vacuum.0 (8236) Message= {"id":411,"method":"get_map_v1"}
                2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F4"],"id":411}
                2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:02:44.660 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/4?Expires=1644219164000&GalaxyAccessKeyId=5271733786445&Signature=QXqCxEhbSSsV2OkZqb0skSJLxQg=
                2022-02-07 08:02:44.660 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219164
                2022-02-07 08:02:44.661 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217364
                2022-02-07 08:02:45.278 - debug: mihome-vacuum.0 (8236) 25555
                2022-02-07 08:02:47.869 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:02:47.870 - debug: mihome-vacuum.0 (8236) Message= {"id":412,"method":"get_map_v1"}
                2022-02-07 08:02:47.880 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F5"],"id":412}
                2022-02-07 08:02:47.881 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:02:47.881 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:02:47.881 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
                2022-02-07 08:02:48.271 - debug: mihome-vacuum.0 (8236) 25430
                2022-02-07 08:02:51.283 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:02:51.284 - debug: mihome-vacuum.0 (8236) Message= {"id":413,"method":"get_map_v1"}
                2022-02-07 08:02:51.296 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F6"],"id":413}
                2022-02-07 08:02:51.297 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:02:51.297 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:02:51.297 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:02:51.396 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/6?Expires=1644219171000&GalaxyAccessKeyId=5271733786445&Signature=JOVj8sTRRKKGWO3ButFXYYK6Nvc=
                2022-02-07 08:02:51.396 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219171
                2022-02-07 08:02:51.396 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217371
                2022-02-07 08:02:51.738 - debug: mihome-vacuum.0 (8236) 25238
                2022-02-07 08:02:52.259 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c41cffffffffffffffffffffffffffffffff
                2022-02-07 08:02:54.266 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:02:54.267 - debug: mihome-vacuum.0 (8236) Message= {"id":414,"method":"get_map_v1"}
                2022-02-07 08:02:54.275 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F7"],"id":414}
                2022-02-07 08:02:54.276 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:02:54.276 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:02:54.276 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:02:54.373 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/7?Expires=1644219174000&GalaxyAccessKeyId=5271733786445&Signature=QljmeiJHnN58Bu5siK+1HzGCs0k=
                2022-02-07 08:02:54.374 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219174
                2022-02-07 08:02:54.374 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217374
                2022-02-07 08:02:54.713 - debug: mihome-vacuum.0 (8236) 25312
                2022-02-07 08:02:57.788 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:02:57.788 - debug: mihome-vacuum.0 (8236) Message= {"id":415,"method":"get_map_v1"}
                2022-02-07 08:02:57.797 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F8"],"id":415}
                2022-02-07 08:02:57.798 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:02:57.798 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:02:57.799 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:02:57.874 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/8?Expires=1644219177000&GalaxyAccessKeyId=5271733786445&Signature=qNhKJEZI78kvEMMQyBq/6R12N2U=
                2022-02-07 08:02:57.875 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219177
                2022-02-07 08:02:57.876 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217377
                2022-02-07 08:02:58.264 - debug: mihome-vacuum.0 (8236) 25354
                2022-02-07 08:03:00.838 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:00.840 - debug: mihome-vacuum.0 (8236) Message= {"id":416,"method":"get_map_v1"}
                2022-02-07 08:03:00.858 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F9"],"id":416}
                2022-02-07 08:03:00.858 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:00.858 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:00.859 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:03:00.958 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/9?Expires=1644219180000&GalaxyAccessKeyId=5271733786445&Signature=91LtXBVlrvGVblqAnfUsY9OmOeY=
                2022-02-07 08:03:00.958 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219180
                2022-02-07 08:03:00.958 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217380
                2022-02-07 08:03:01.270 - debug: mihome-vacuum.0 (8236) 25615
                2022-02-07 08:03:02.265 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c426ffffffffffffffffffffffffffffffff
                2022-02-07 08:03:04.242 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:04.242 - debug: mihome-vacuum.0 (8236) Message= {"id":417,"method":"get_map_v1"}
                2022-02-07 08:03:04.255 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F10"],"id":417}
                2022-02-07 08:03:04.255 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:04.256 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:04.256 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:03:04.330 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/10?Expires=1644219184000&GalaxyAccessKeyId=5271733786445&Signature=s4g+g1JZ/7hruZRLoo6u/QQowKc=
                2022-02-07 08:03:04.330 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219184
                2022-02-07 08:03:04.331 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217384
                2022-02-07 08:03:04.721 - debug: mihome-vacuum.0 (8236) 26110
                2022-02-07 08:03:07.288 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:07.288 - debug: mihome-vacuum.0 (8236) Message= {"id":418,"method":"get_map_v1"}
                2022-02-07 08:03:07.303 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F11"],"id":418}
                2022-02-07 08:03:07.304 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:07.304 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:07.304 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:03:07.409 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/11?Expires=1644219187000&GalaxyAccessKeyId=5271733786445&Signature=k0ovE5vRzOVlmC4bFnQWeGspjOE=
                2022-02-07 08:03:07.410 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219187
                2022-02-07 08:03:07.410 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217387
                2022-02-07 08:03:07.766 - debug: mihome-vacuum.0 (8236) 26406
                2022-02-07 08:03:10.754 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:10.755 - debug: mihome-vacuum.0 (8236) Message= {"id":419,"method":"get_map_v1"}
                2022-02-07 08:03:10.767 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F12"],"id":419}
                2022-02-07 08:03:10.768 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:10.768 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:10.769 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:03:10.871 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/12?Expires=1644219190000&GalaxyAccessKeyId=5271733786445&Signature=9L9+XjC6vv+u5bj8v1wxLvUUqYo=
                2022-02-07 08:03:10.872 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219190
                2022-02-07 08:03:10.872 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217390
                2022-02-07 08:03:11.256 - debug: mihome-vacuum.0 (8236) 26244
                2022-02-07 08:03:12.270 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c430ffffffffffffffffffffffffffffffff
                2022-02-07 08:03:13.781 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:13.781 - debug: mihome-vacuum.0 (8236) Message= {"id":420,"method":"get_map_v1"}
                2022-02-07 08:03:13.791 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F13"],"id":420}
                2022-02-07 08:03:13.792 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:13.792 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:13.792 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:03:13.900 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/13?Expires=1644219193000&GalaxyAccessKeyId=5271733786445&Signature=gaCFlo3zCP1aFleus0VRNaD/MbA=
                2022-02-07 08:03:13.900 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219193
                2022-02-07 08:03:13.900 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217393
                2022-02-07 08:03:14.265 - debug: mihome-vacuum.0 (8236) 25683
                2022-02-07 08:03:17.230 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:17.231 - debug: mihome-vacuum.0 (8236) Message= {"id":421,"method":"get_map_v1"}
                2022-02-07 08:03:17.254 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F14"],"id":421}
                2022-02-07 08:03:17.255 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:17.255 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:17.255 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:03:17.324 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/14?Expires=1644219197000&GalaxyAccessKeyId=5271733786445&Signature=g6zYQULvIEANtK+tZ3N3skLL+o0=
                2022-02-07 08:03:17.324 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219197
                2022-02-07 08:03:17.325 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217397
                2022-02-07 08:03:17.651 - debug: mihome-vacuum.0 (8236) 25668
                2022-02-07 08:03:20.191 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:20.191 - debug: mihome-vacuum.0 (8236) Message= {"id":422,"method":"get_map_v1"}
                2022-02-07 08:03:20.199 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F15"],"id":422}
                2022-02-07 08:03:20.200 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:20.200 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:20.200 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:03:20.298 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/15?Expires=1644219200000&GalaxyAccessKeyId=5271733786445&Signature=LPyMXhuNtIy9L4Sgs0Ks7HZSDxY=
                2022-02-07 08:03:20.299 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219200
                2022-02-07 08:03:20.299 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217400
                2022-02-07 08:03:20.641 - debug: mihome-vacuum.0 (8236) 25684
                2022-02-07 08:03:22.276 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c43affffffffffffffffffffffffffffffff
                2022-02-07 08:03:23.581 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:23.581 - debug: mihome-vacuum.0 (8236) Message= {"id":423,"method":"get_map_v1"}
                2022-02-07 08:03:23.591 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F16"],"id":423}
                2022-02-07 08:03:23.591 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:23.592 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:23.592 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:03:23.685 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/16?Expires=1644219203000&GalaxyAccessKeyId=5271733786445&Signature=XoFLOHO5qmhJsdlSqSqXXDlulfA=
                2022-02-07 08:03:23.686 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219203
                2022-02-07 08:03:23.686 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217403
                2022-02-07 08:03:24.117 - debug: mihome-vacuum.0 (8236) 26057
                2022-02-07 08:03:26.650 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:26.651 - debug: mihome-vacuum.0 (8236) Message= {"id":424,"method":"get_map_v1"}
                2022-02-07 08:03:26.663 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F17"],"id":424}
                2022-02-07 08:03:26.664 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:26.664 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:26.664 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:03:26.756 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/17?Expires=1644219206000&GalaxyAccessKeyId=5271733786445&Signature=Maxdse16d0Hv3gsCI7ZJH91xkEE=
                2022-02-07 08:03:26.756 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219206
                2022-02-07 08:03:26.756 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217406
                2022-02-07 08:03:27.064 - debug: mihome-vacuum.0 (8236) 26325
                2022-02-07 08:03:30.054 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:30.055 - debug: mihome-vacuum.0 (8236) Message= {"id":425,"method":"get_map_v1"}
                2022-02-07 08:03:30.074 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F0"],"id":425}
                2022-02-07 08:03:30.075 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:30.075 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:30.076 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
                2022-02-07 08:03:30.574 - debug: mihome-vacuum.0 (8236) 26198
                2022-02-07 08:03:32.283 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c444ffffffffffffffffffffffffffffffff
                2022-02-07 08:03:33.179 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:33.179 - debug: mihome-vacuum.0 (8236) Message= {"id":426,"method":"get_map_v1"}
                2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F1"],"id":426}
                2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:03:33.285 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/1?Expires=1644219213000&GalaxyAccessKeyId=5271733786445&Signature=TPYft0tbjPJPeVAVgMRG5KyDCNQ=
                2022-02-07 08:03:33.287 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219213
                2022-02-07 08:03:33.287 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217413
                2022-02-07 08:03:33.628 - debug: mihome-vacuum.0 (8236) 25786
                2022-02-07 08:03:36.615 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:36.616 - debug: mihome-vacuum.0 (8236) Message= {"id":427,"method":"get_map_v1"}
                2022-02-07 08:03:36.627 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F2"],"id":427}
                2022-02-07 08:03:36.628 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:36.628 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:36.629 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
                2022-02-07 08:03:36.739 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/2?Expires=1644219216000&GalaxyAccessKeyId=5271733786445&Signature=rPO65+y7scFkbOvqG7y727RptP0=
                2022-02-07 08:03:36.741 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219216
                2022-02-07 08:03:36.742 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217416
                2022-02-07 08:03:37.113 - debug: mihome-vacuum.0 (8236) 25588
                2022-02-07 08:03:39.655 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:39.656 - debug: mihome-vacuum.0 (8236) Message= {"id":428,"method":"get_map_v1"}
                2022-02-07 08:03:39.667 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F3"],"id":428}
                2022-02-07 08:03:39.667 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:39.668 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:39.668 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
                2022-02-07 08:03:40.045 - debug: mihome-vacuum.0 (8236) 25314
                2022-02-07 08:03:41.011 - debug: mihome-vacuum.0 (8236) get params for stock Vacuum
                2022-02-07 08:03:41.011 - debug: mihome-vacuum.0 (8236) Message= {"id":429,"method":"get_status"}
                2022-02-07 08:03:41.023 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":249,"state":18,"battery":100,"clean_time":80,"clean_area":1470000,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":429}
                2022-02-07 08:03:41.023 - debug: mihome-vacuum.0 (8236) setGetStatus {"msg_ver":2,"msg_seq":249,"state":18,"battery":100,"clean_time":80,"clean_area":1470000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
                2022-02-07 08:03:41.024 - debug: mihome-vacuum.0 (8236) Message= {"id":430,"method":"get_network_info"}
                2022-02-07 08:03:41.069 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":{"ssid":"Krystian","ip":"192.168.178.58","mac":"b0:4a:39:13:19:dc","bssid":"00:5f:67:a3:93:84","rssi":-51},"id":430}
                2022-02-07 08:03:41.174 - debug: mihome-vacuum.0 (8236) Message= {"id":431,"method":"get_sound_volume"}
                2022-02-07 08:03:41.183 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[79],"id":431}
                2022-02-07 08:03:41.184 - debug: mihome-vacuum.0 (8236) Message= {"id":432,"method":"get_carpet_mode"}
                2022-02-07 08:03:41.196 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":432}
                2022-02-07 08:03:42.312 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c44effffffffffffffffffffffffffffffff
                2022-02-07 08:03:43.011 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:43.012 - debug: mihome-vacuum.0 (8236) Message= {"id":433,"method":"get_map_v1"}
                2022-02-07 08:03:43.049 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F4"],"id":433}
                2022-02-07 08:03:43.049 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:43.050 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:43.050 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
                2022-02-07 08:03:43.416 - debug: mihome-vacuum.0 (8236) 25246
                2022-02-07 08:03:46.012 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:46.013 - debug: mihome-vacuum.0 (8236) Message= {"id":434,"method":"get_map_v1"}
                2022-02-07 08:03:46.023 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F5"],"id":434}
                2022-02-07 08:03:46.024 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:46.025 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:46.025 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
                2022-02-07 08:03:46.408 - debug: mihome-vacuum.0 (8236) 25246
                2022-02-07 08:03:49.367 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
                2022-02-07 08:03:49.368 - debug: mihome-vacuum.0 (8236) Message= {"id":435,"method":"get_map_v1"}
                2022-02-07 08:03:49.379 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F6"],"id":435}
                2022-02-07 08:03:49.380 - debug: mihome-vacuum.0 (8236) Mappointer_updated
                2022-02-07 08:03:49.380 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
                2022-02-07 08:03:49.381 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
                2022-02-07 08:03:49.754 - debug: mihome-vacuum.0 (8236) 25319
                2022-02-07 08:03:50.480 - error: host.raspberrypi Caught by controller[0]: -vacuum.0: ../node_modules/nan/nan_object_wrap.h:125: static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo&): Assertion `wrap->refs_ == 0' failed.
                2022-02-07 08:03:50.485 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                2022-02-07 08:03:50.486 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                2022-02-07 08:04:20.548 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 4153
                2022-02-07 08:04:22.550 - debug: mihome-vacuum.0 (4153) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2022-02-07 08:04:22.609 - debug: mihome-vacuum.0 (4153) Objects client ready ... initialize now
                2022-02-07 08:04:22.626 - debug: mihome-vacuum.0 (4153) Objects create System PubSub Client
                2022-02-07 08:04:22.628 - debug: mihome-vacuum.0 (4153) Objects create User PubSub Client
                2022-02-07 08:04:22.629 - debug: mihome-vacuum.0 (4153) Objects client initialize lua scripts
                2022-02-07 08:04:22.656 - debug: mihome-vacuum.0 (4153) Objects connected to redis: 127.0.0.1:9001
                2022-02-07 08:04:22.667 - debug: mihome-vacuum.0 (4153) objectDB connected
                2022-02-07 08:04:22.670 - debug: mihome-vacuum.0 (4153) Redis States: Use Redis connection: 127.0.0.1:9000
                2022-02-07 08:04:22.686 - debug: mihome-vacuum.0 (4153) States create System PubSub Client
                2022-02-07 08:04:22.687 - debug: mihome-vacuum.0 (4153) States create User PubSub Client
                2022-02-07 08:04:22.709 - debug: mihome-vacuum.0 (4153) States connected to redis: 127.0.0.1:9000
                2022-02-07 08:04:22.710 - debug: mihome-vacuum.0 (4153) statesDB connected
                2022-02-07 08:04:23.340 - debug: mihome-vacuum.0 (4153) Plugin sentry Initialize Plugin (enabled=true)
                2022-02-07 08:04:23.732 - info: mihome-vacuum.0 (4153) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 3.3.22
                2022-02-07 08:04:23.843 - debug: mihome-vacuum.0 (4153) load Map creator... true
                2022-02-07 08:04:24.449 - debug: mihome-vacuum.0 (4153) Create State for deviceInfo
                2022-02-07 08:04:24.453 - debug: mihome-vacuum.0 (4153) Create State for deviceInfomac
                2022-02-07 08:04:24.459 - debug: mihome-vacuum.0 (4153) Create State for deviceInfomodel
                2022-02-07 08:04:24.461 - debug: mihome-vacuum.0 (4153) Create State for deviceInfofw_ver
                2022-02-07 08:04:24.462 - debug: mihome-vacuum.0 (4153) Create State for deviceInfowifi_signal
                2022-02-07 08:04:24.463 - debug: mihome-vacuum.0 (4153) MIIO: Config: ip:192.168.178.58 token: 62435048385749766e48576b37643449
                2022-02-07 08:04:24.468 - info: mihome-vacuum.0 (4153) IOT enabled, create state
                2022-02-07 08:04:24.476 - debug: mihome-vacuum.0 (4153) server started on 0.0.0.0:53421
                2022-02-07 08:04:24.490 - debug: mihome-vacuum.0 (4153) Receive <<< Helo <<< 213100200000000018cce8a76200c479ffffffffffffffffffffffffffffffff
                2022-02-07 08:04:24.491 - debug: mihome-vacuum.0 (4153) MAIN: Connected to device, try to get model..
                2022-02-07 08:04:24.494 - debug: mihome-vacuum.0 (4153) Time difference between Mihome Vacuum and ioBroker: 1 sec
                2022-02-07 08:04:24.555 - debug: mihome-vacuum.0 (4153) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1644212115379,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1643712474446}
                2022-02-07 08:04:24.559 - debug: mihome-vacuum.0 (4153) Message= {"id":1,"method":"miIO.info"}
                2022-02-07 08:04:24.581 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"Krystian","bssid":"00:5f:67:a3:93:84","rssi":-55},"netif":{"localIp":"192.168.178.58","mask":"255.255.255.0","gw":"192.168.178.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"B0:4A:39:13:19:DC","token":"62435048385749766e48576b37643449","life":15495}}
                2022-02-07 08:04:24.583 - debug: mihome-vacuum.0 (4153) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"Krystian","bssid":"00:5f:67:a3:93:84","rssi":-55},"netif":{"localIp":"192.168.178.58","mask":"255.255.255.0","gw":"192.168.178.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"B0:4A:39:13:19:DC","token":"62435048385749766e48576b37643449","life":15495}}
                2022-02-07 08:04:24.584 - debug: mihome-vacuum.0 (4153) Get Device data..0
                2022-02-07 08:04:24.585 - debug: mihome-vacuum.0 (4153) Get Device data from robot..
                2022-02-07 08:04:24.743 - debug: mihome-vacuum.0 (4153) DeviceModel selected to: roborock.vacuum.s5e
                2022-02-07 08:04:24.745 - info: mihome-vacuum.0 (4153) select standard vacuum protocol....
                2022-02-07 08:04:24.760 - debug: mihome-vacuum.0 (4153) Xiaomi Cloud: Logging in
                2022-02-07 08:04:24.847 - debug: mihome-vacuum.0 (4153) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                2022-02-07 08:04:24.977 - debug: mihome-vacuum.0 (4153) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
                2022-02-07 08:04:25.154 - debug: mihome-vacuum.0 (4153) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"wuSHUJeKc6HMhYWRCti0gg==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCRz7Q/RqjLTS3lbmKzg+q/22dNT+UcWAEgbFu9THRoseGojPLM5s8t4nH37bhEOrR7Meo/fhoeQ1f5pj7NL88F+45TiFuUapnNQaPDcPx0vp+qKSAAYGLOwChuR8Uo5JZrOyZWVlpg9OqrVlkyvr+hxELA8inBOJ0Kiuwhjj/BWmOpk59WDcB8iKlcgqqLGfMwyoxDyFb6ThAwnq9YKcqiQWf2CL4AKAC8CHBBGiug+jJ47mC2H4jKZglQzdWVw6Q34OyFvq1SNs7HG/woTrIcI=","description":"成功","securityStatus":0,"nonce":4666761058257411072,"userId":1669572361,"cUserId":"86_CG49N742pAF3a6YHfpffTQtQ","result":"ok","psecurity":"95LpPnR65AoP22oyffzJZw==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=eilkfp&ticket=0&pwd=1&p_ts=1644217465000&fid=0&p_lm=1&auth=TVxiC72aDVg0qrlNI%2FeOG4zf0QMYoNNXPfh%2Fmee2Mlb0VoBvrR7ZyVebqWb8sqOCuS8RwvxfrnwOrgojDDqqE3XKJaRVo17mNKuE97uMIFWQSUmg0mO6GUzqWUALFrtCykxS9Cr%2BpPPJjgQH1Kk9f6zQmu25QeRXF9xyClWSVQ8%3D&m=1&tsl=0&nonce=2iQsgSYtnpcBoiVo&_ssign=k%2FnkQd%2FwFXEobjI8lJ1VVc8KfFQ%3D","pwd":1,"desc":"成功"}
                2022-02-07 08:04:25.327 - info: mihome-vacuum.0 (4153) settest next timer: not available
                2022-02-07 08:04:25.698 - debug: mihome-vacuum.0 (4153) Login step3: [{"key":"userId","value":"1669572361","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-07T07:04:25.669Z","lastAccessed":"2022-02-07T07:04:25.696Z"},{"key":"cUserId","value":"86_CG49N742pAF3a6YHfpffTQtQ","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-07T07:04:25.680Z","lastAccessed":"2022-02-07T07:04:25.696Z"},{"key":"serviceToken","value":"u7ya0zGFshh2//i/lnx/mbrK7f0f/8fOmtUTmckUQSZIL+zxDyQqStIc2DcIEEN+frAAS+AQ4zqUIJD667DYgjBxu3pfcg5oUVVHqZQsk0ayp6NVpKdBpZimcin38cIF+vW1A3pU1wEVp7u+XtYgrg9CEHV1Ztl/aKOoZRTQnhE=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-07T07:04:25.687Z","lastAccessed":"2022-02-07T07:04:25.696Z"}]
                2022-02-07 08:04:25.699 - debug: mihome-vacuum.0 (4153) Xiaomi Cloud: Login successful
                2022-02-07 08:04:25.719 - debug: mihome-vacuum.0 (4153) Create State for Queue: queue
                2022-02-07 08:04:25.720 - debug: mihome-vacuum.0 (4153) Create State for Queue: clearQueue
                2022-02-07 08:04:25.721 - info: mihome-vacuum.0 (4153) Map selected create states...
                2022-02-07 08:04:25.725 - debug: mihome-vacuum.0 (4153) Create State for map:
                2022-02-07 08:04:25.727 - debug: mihome-vacuum.0 (4153) Create State for map: map64
                2022-02-07 08:04:25.728 - debug: mihome-vacuum.0 (4153) Create State for map: actualMap
                2022-02-07 08:04:25.728 - debug: mihome-vacuum.0 (4153) Create State for map: mapStatus
                2022-02-07 08:04:25.729 - debug: mihome-vacuum.0 (4153) Create State for map: mapURL
                2022-02-07 08:04:25.731 - debug: mihome-vacuum.0 (4153) Create State for map: loadMap
                2022-02-07 08:04:25.733 - debug: mihome-vacuum.0 (4153) Create State done!
                2022-02-07 08:04:25.735 - debug: mihome-vacuum.0 (4153) get params for stock Vacuum
                2022-02-07 08:04:25.736 - debug: mihome-vacuum.0 (4153) Message= {"id":2,"method":"get_status"}
                2022-02-07 08:04:25.752 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":250,"state":18,"battery":100,"clean_time":128,"clean_area":2550000,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":2}
                2022-02-07 08:04:25.755 - debug: mihome-vacuum.0 (4153) setGetStatus {"msg_ver":2,"msg_seq":250,"state":18,"battery":100,"clean_time":128,"clean_area":2550000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
                2022-02-07 08:04:25.758 - info: mihome-vacuum.0 (4153) change states from State control.fan_power
                2022-02-07 08:04:25.778 - info: mihome-vacuum.0 (4153) create states for water box
                2022-02-07 08:04:25.786 - info: mihome-vacuum.0 (4153) create states for water box mode
                2022-02-07 08:04:25.790 - info: mihome-vacuum.0 (4153) create states for mop
                2022-02-07 08:04:25.846 - info: mihome-vacuum.0 (4153) State value to set for "mihome-vacuum.0.cleanmap.actualMap" has to be type "string" but received type "number"
                2022-02-07 08:04:25.921 - debug: mihome-vacuum.0 (4153) Message= {"id":3,"method":"get_map_v1"}
                2022-02-07 08:04:25.931 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":["retry"],"id":3}
                2022-02-07 08:04:26.233 - debug: mihome-vacuum.0 (4153) Message= {"id":4,"method":"get_map_v1"}
                2022-02-07 08:04:26.325 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F8"],"id":4}
                2022-02-07 08:04:26.326 - debug: mihome-vacuum.0 (4153) Mappointer_updated
                2022-02-07 08:04:26.327 - debug: mihome-vacuum.0 (4153) update_Map Mimap enabled
                2022-02-07 08:04:26.328 - debug: mihome-vacuum.0 (4153) update_Map need new mapurl
                2022-02-07 08:04:26.335 - debug: mihome-vacuum.0 (4153) Message= {"id":5,"method":"get_room_mapping"}
                2022-02-07 08:04:26.425 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[16,"279001039807"],[17,"279001039878"],[18,"279001036128"],[19,"279001039845"],[20,"279001039844"],[21,"279001039841"],[22,"279001039842"]],"id":5}
                2022-02-07 08:04:26.428 - debug: mihome-vacuum.0 (4153) Message= {"id":6,"method":"get_map_v1"}
                2022-02-07 08:04:26.430 - debug: mihome-vacuum.0 (4153) Message= {"id":7,"method":"get_network_info"}
                2022-02-07 08:04:26.441 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F8"],"id":6}
                2022-02-07 08:04:26.442 - debug: mihome-vacuum.0 (4153) Mappointer_updated
                2022-02-07 08:04:26.443 - debug: mihome-vacuum.0 (4153) update_Map Mimap enabled
                2022-02-07 08:04:26.443 - debug: mihome-vacuum.0 (4153) update_Map need new mapurl
                2022-02-07 08:04:26.466 - debug: mihome-vacuum.0 (4153) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/8?Expires=1644219266000&GalaxyAccessKeyId=5271733786445&Signature=db2xT7xt6iD/9aiHnVfhBnCQXW8=
                2022-02-07 08:04:26.466 - debug: mihome-vacuum.0 (4153) update_Map got new expires:1644219266
                2022-02-07 08:04:26.468 - debug: mihome-vacuum.0 (4153) update_Map got new time:1644217466
                2022-02-07 08:04:26.490 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":{"ssid":"Krystian","ip":"192.168.178.58","mac":"b0:4a:39:13:19:dc","bssid":"00:5f:67:a3:93:84","rssi":-51},"id":7}
                2022-02-07 08:04:26.556 - debug: mihome-vacuum.0 (4153) Message= {"id":8,"method":"get_sound_volume"}
                2022-02-07 08:04:26.568 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[79],"id":8}
                2022-02-07 08:04:26.571 - debug: mihome-vacuum.0 (4153) Message= {"id":9,"method":"get_multi_maps_list"}
                2022-02-07 08:04:26.580 - debug: mihome-vacuum.0 (4153) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/8?Expires=1644219266000&GalaxyAccessKeyId=5271733786445&Signature=db2xT7xt6iD/9aiHnVfhBnCQXW8=
                2022-02-07 08:04:26.581 - debug: mihome-vacuum.0 (4153) update_Map got new expires:1644219266
                2022-02-07 08:04:26.582 - debug: mihome-vacuum.0 (4153) update_Map got new time:1644217466
                2022-02-07 08:04:26.597 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1644162511,"length":16,"name":"Werler Str. 235 ","bak_maps":[]}]}],"id":9}
                2022-02-07 08:04:26.599 - debug: mihome-vacuum.0 (4153) States for 1 Map: [{"mapFlag":0,"add_time":1644162511,"length":16,"name":"Werler Str. 235 ","bak_maps":[]}]
                2022-02-07 08:04:26.600 - debug: mihome-vacuum.0 (4153) States for Map: {"0":"Werler Str. 235 "}
                2022-02-07 08:04:26.604 - debug: mihome-vacuum.0 (4153) Startup: getMultiMapsList Answer: true
                2022-02-07 08:04:26.605 - debug: mihome-vacuum.0 (4153) Startup: Delete getMultiMapsList
                2022-02-07 08:04:26.606 - debug: mihome-vacuum.0 (4153) Message= {"id":10,"method":"get_clean_summary"}
                2022-02-07 08:04:26.623 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[52822,803020000,88,[1644160121,1644133383,1644044493,1643977111,1643975328,1643974745,1643965653,1643905243,1643901690,1643887247,1643875796,1643805243,1643797070,1643788111,1643785174,1643732552,1643729608,1643720501,1643720432,1643720002]],"id":10}
                2022-02-07 08:04:26.629 - debug: mihome-vacuum.0 (4153) Message= {"id":11,"method":"get_clean_record","params":[1644160121]}
                2022-02-07 08:04:26.641 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1644160121,1644162495,2374,37522500,0,1,2,1,52]],"id":11}
                2022-02-07 08:04:26.643 - debug: mihome-vacuum.0 (4153) Message= {"id":12,"method":"get_clean_record","params":[1644133383]}
                2022-02-07 08:04:26.658 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1644133383,1644137484,3347,28290000,0,0,2,3,60]],"id":12}
                2022-02-07 08:04:26.660 - debug: mihome-vacuum.0 (4153) Message= {"id":13,"method":"get_clean_record","params":[1644044493]}
                2022-02-07 08:04:26.674 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1644044493,1644046203,1710,29342500,0,1,2,3,56]],"id":13}
                2022-02-07 08:04:26.675 - debug: mihome-vacuum.0 (4153) Message= {"id":14,"method":"get_clean_record","params":[1643977111]}
                2022-02-07 08:04:26.688 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643977111,1643979360,2249,35265000,0,1,2,1,52]],"id":14}
                2022-02-07 08:04:26.690 - debug: mihome-vacuum.0 (4153) Message= {"id":15,"method":"get_clean_record","params":[1643975328]}
                2022-02-07 08:04:26.699 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643975328,1643975615,287,3947500,0,1,2,3,56]],"id":15}
                2022-02-07 08:04:26.701 - debug: mihome-vacuum.0 (4153) Message= {"id":16,"method":"get_clean_record","params":[1643974745]}
                2022-02-07 08:04:26.718 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643974745,1643975104,359,5960000,0,1,2,3,56]],"id":16}
                2022-02-07 08:04:26.720 - debug: mihome-vacuum.0 (4153) Message= {"id":17,"method":"get_clean_record","params":[1643965653]}
                2022-02-07 08:04:26.735 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643965653,1643966406,753,12455000,0,1,2,3,56]],"id":17}
                2022-02-07 08:04:26.737 - debug: mihome-vacuum.0 (4153) Message= {"id":18,"method":"get_clean_record","params":[1643905243]}
                2022-02-07 08:04:26.770 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643905243,1643906212,969,16470000,0,1,2,3,56]],"id":18}
                2022-02-07 08:04:26.771 - debug: mihome-vacuum.0 (4153) Message= {"id":19,"method":"get_clean_record","params":[1643901690]}
                2022-02-07 08:04:26.783 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643901690,1643903137,1447,23562500,0,1,2,3,56]],"id":19}
                2022-02-07 08:04:26.785 - debug: mihome-vacuum.0 (4153) Message= {"id":20,"method":"get_clean_record","params":[1643887247]}
                2022-02-07 08:04:26.797 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643887247,1643887856,605,9045000,0,0,2,1,60]],"id":20}
                2022-02-07 08:04:26.798 - debug: mihome-vacuum.0 (4153) Message= {"id":21,"method":"get_clean_record","params":[1643875796]}
                2022-02-07 08:04:27.121 - debug: mihome-vacuum.0 (4153) 26880
                2022-02-07 08:04:27.721 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643875796,1643875823,27,0,0,0,2,1,60]],"id":21}
                2022-02-07 08:04:27.723 - debug: mihome-vacuum.0 (4153) Message= {"id":22,"method":"get_clean_record","params":[1643805243]}
                2022-02-07 08:04:28.121 - debug: mihome-vacuum.0 (4153) 26880
                2022-02-07 08:04:28.672 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643805243,1643805481,236,4040000,0,0,2,1,60]],"id":22}
                2022-02-07 08:04:28.674 - debug: mihome-vacuum.0 (4153) Message= {"id":23,"method":"get_clean_record","params":[1643797070]}
                2022-02-07 08:04:28.689 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643797070,1643800012,2436,38702500,0,1,2,1,52]],"id":23}
                2022-02-07 08:04:28.689 - debug: mihome-vacuum.0 (4153) Message= {"id":24,"method":"get_clean_record","params":[1643788111]}
                2022-02-07 08:04:28.707 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643788111,1643788348,237,3467500,0,1,2,3,56]],"id":24}
                2022-02-07 08:04:28.708 - debug: mihome-vacuum.0 (4153) Message= {"id":25,"method":"get_clean_record","params":[1643785174]}
                2022-02-07 08:04:28.718 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643785174,1643785476,302,4052500,0,1,2,3,56]],"id":25}
                2022-02-07 08:04:28.719 - debug: mihome-vacuum.0 (4153) Message= {"id":26,"method":"get_clean_record","params":[1643732552]}
                2022-02-07 08:04:28.733 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643732552,1643734826,2274,37185000,0,1,2,1,52]],"id":26}
                2022-02-07 08:04:28.734 - debug: mihome-vacuum.0 (4153) Message= {"id":27,"method":"get_clean_record","params":[1643729608]}
                2022-02-07 08:04:28.743 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643729608,1643729616,8,0,0,0,2,1,60]],"id":27}
                2022-02-07 08:04:28.744 - debug: mihome-vacuum.0 (4153) Message= {"id":28,"method":"get_clean_record","params":[1643720501]}
                2022-02-07 08:04:28.772 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643720501,1643720513,12,245000,0,0,2,3,60]],"id":28}
                2022-02-07 08:04:28.772 - debug: mihome-vacuum.0 (4153) Message= {"id":29,"method":"get_clean_record","params":[1643720432]}
                2022-02-07 08:04:28.784 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643720432,1643720461,29,0,0,0,2,1,60]],"id":29}
                2022-02-07 08:04:28.785 - debug: mihome-vacuum.0 (4153) Message= {"id":30,"method":"get_clean_record","params":[1643720002]}
                2022-02-07 08:04:28.796 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643720002,1643720057,55,0,0,0,2,1,60]],"id":30}
                2022-02-07 08:04:28.797 - debug: mihome-vacuum.0 (4153) finish logs all [{"Datum":"6.2","Start":"16:08","Saugzeit":"40 min","Fläche":"37.52 m²","Error":0,"Ende":true},{"Datum":"6.2","Start":"08:43","Saugzeit":"56 min","Fläche":"28.29 m²","Error":0,"Ende":false},{"Datum":"5.2","Start":"08:01","Saugzeit":"29 min","Fläche":"29.34 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"13:18","Saugzeit":"37 min","Fläche":"35.27 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"12:48","Saugzeit":"5 min","Fläche":"3.95 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"12:39","Saugzeit":"6 min","Fläche":"5.96 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"10:07","Saugzeit":"13 min","Fläche":"12.46 m²","Error":0,"Ende":true},{"Datum":"3.2","Start":"17:20","Saugzeit":"16 min","Fläche":"16.47 m²","Error":0,"Ende":true},{"Datum":"3.2","Start":"16:21","Saugzeit":"24 min","Fläche":"23.56 m²","Error":0,"Ende":true},{"Datum":"3.2","Start":"12:20","Saugzeit":"10 min","Fläche":"9.05 m²","Error":0,"Ende":false},{"Datum":"3.2","Start":"09:09","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"2.2","Start":"13:34","Saugzeit":"4 min","Fläche":"4.04 m²","Error":0,"Ende":false},{"Datum":"2.2","Start":"11:17","Saugzeit":"41 min","Fläche":"38.7 m²","Error":0,"Ende":true},{"Datum":"2.2","Start":"08:48","Saugzeit":"4 min","Fläche":"3.47 m²","Error":0,"Ende":true},{"Datum":"2.2","Start":"07:59","Saugzeit":"5 min","Fläche":"4.05 m²","Error":0,"Ende":true},{"Datum":"1.2","Start":"17:22","Saugzeit":"38 min","Fläche":"37.19 m²","Error":0,"Ende":true},{"Datum":"1.2","Start":"16:33","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"1.2","Start":"14:01","Saugzeit":"0 min","Fläche":"0.25 m²","Error":0,"Ende":false},{"Datum":"1.2","Start":"14:00","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"1.2","Start":"13:53","Saugzeit":"1 min","Fläche":"0 m²","Error":0,"Ende":false}]
                2022-02-07 08:04:28.801 - debug: mihome-vacuum.0 (4153) Startup: setGetCleanSummary Answer: true
                2022-02-07 08:04:28.802 - debug: mihome-vacuum.0 (4153) Startup: Delete setGetCleanSummary
                2022-02-07 08:04:28.804 - debug: mihome-vacuum.0 (4153) Message= {"id":31,"method":"get_consumable"}
                2022-02-07 08:04:28.816 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"main_brush_work_time":52916,"side_brush_work_time":52916,"filter_work_time":52916,"filter_element_work_time":2217,"sensor_dirty_time":52822}],"id":31}
                2022-02-07 08:04:28.818 - debug: mihome-vacuum.0 (4153) Startup: setGetConsumable Answer: true
                2022-02-07 08:04:28.818 - debug: mihome-vacuum.0 (4153) Startup: Delete setGetConsumable
                2022-02-07 08:04:28.820 - debug: mihome-vacuum.0 (4153) Message= {"id":32,"method":"get_carpet_mode"}
                2022-02-07 08:04:28.838 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":32}
                2022-02-07 08:04:28.838 - info: mihome-vacuum.0 (4153) create state for carpet_mode
                2022-02-07 08:04:28.839 - debug: mihome-vacuum.0 (4153) Message= {"id":33,"method":"get_carpet_mode"}
                2022-02-07 08:04:28.863 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}
                2022-02-07 08:04:30.701 - debug: mihome-vacuum.0 (4153) Get Mappointer while cleaning
                2022-02-07 08:04:32.083 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
                2022-02-07 08:04:32.084 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                2022-02-07 08:04:32.084 - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
                2022-02-07 08:04:32.121 - info: web-speedy.0 (11730) The speed test has been completed successfully.
                2022-02-07 08:05:02.141 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 4591
                2022-02-07 08:05:03.727 - debug: mihome-vacuum.0 (4591) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2022-02-07 08:05:03.809 - debug: mihome-vacuum.0 (4591) Objects client ready ... initialize now
                2022-02-07 08:05:03.813 - debug: mihome-vacuum.0 (4591) Objects create System PubSub Client
                2022-02-07 08:05:03.816 - debug: mihome-vacuum.0 (4591) Objects create User PubSub Client
                2022-02-07 08:05:03.817 - debug: mihome-vacuum.0 (4591) Objects client initialize lua scripts
                2022-02-07 08:05:03.847 - debug: mihome-vacuum.0 (4591) Objects connected to redis: 127.0.0.1:9001
                2022-02-07 08:05:03.858 - debug: mihome-vacuum.0 (4591) objectDB connected
                2022-02-07 08:05:03.861 - debug: mihome-vacuum.0 (4591) Redis States: Use Redis connection: 127.0.0.1:9000
                2022-02-07 08:05:03.878 - debug: mihome-vacuum.0 (4591) States create System PubSub Client
                2022-02-07 08:05:03.879 - debug: mihome-vacuum.0 (4591) States create User PubSub Client
                2022-02-07 08:05:03.903 - debug: mihome-vacuum.0 (4591) States connected to redis: 127.0.0.1:9000
                2022-02-07 08:05:03.905 - debug: mihome-vacuum.0 (4591) statesDB connected
                2022-02-07 08:05:04.688 - debug: mihome-vacuum.0 (4591) Plugin sentry Initialize Plugin (enabled=true)
                2022-02-07 08:05:04.926 - info: mihome-vacuum.0 (4591) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 3.3.22
                2022-02-07 08:05:05.018 - debug: mihome-vacuum.0 (4591) load Map creator... true
                2022-02-07 08:05:05.054 - debug: mihome-vacuum.0 (4591) Create State for deviceInfo
                2022-02-07 08:05:05.055 - debug: mihome-vacuum.0 (4591) Create State for deviceInfomac
                2022-02-07 08:05:05.056 - debug: mihome-vacuum.0 (4591) Create State for deviceInfomodel
                2022-02-07 08:05:05.057 - debug: mihome-vacuum.0 (4591) Create State for deviceInfofw_ver
                2022-02-07 08:05:05.058 - debug: mihome-vacuum.0 (4591) Create State for deviceInfowifi_signal
                2022-02-07 08:05:05.059 - debug: mihome-vacuum.0 (4591) MIIO: Config: ip:192.168.178.58 token: 62435048385749766e48576b37643449
                2022-02-07 08:05:05.064 - info: mihome-vacuum.0 (4591) IOT enabled, create state
                2022-02-07 08:05:05.069 - debug: mihome-vacuum.0 (4591) server started on 0.0.0.0:53421
                2022-02-07 08:05:05.097 - debug: mihome-vacuum.0 (4591) Receive <<< Helo <<< 213100200000000018cce8a76200c4a1ffffffffffffffffffffffffffffffff
                2022-02-07 08:05:05.098 - debug: mihome-vacuum.0 (4591) MAIN: Connected to device, try to get model..
                2022-02-07 08:05:05.102 - debug: mihome-vacuum.0 (4591) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1644217464631,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1643712474446}
                2022-02-07 08:05:05.104 - debug: mihome-vacuum.0 (4591) Message= {"id":1,"method":"miIO.info"}
                Rest folgt..
                  Krys
                  schrieb am zuletzt editiert von Krys
                  #733
                  Dann ein mal "top":
                  pi@raspberrypi:~ $ top
                  top - 08:09:58 up 5 days, 22:07,  1 user,  load average: 0.66, 0.96, 1.00
                  Tasks: 178 total,   2 running, 176 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 11.2 us,  5.1 sy,  0.2 ni, 82.8 id,  0.0 wa,  0.0 hi,  0.7 si,  0.0 st
                  MiB Mem :   3838.7 total,    477.7 free,   2311.3 used,   1049.7 buff/cache
                  MiB Swap:    100.0 total,     83.2 free,     16.8 used.   1880.1 avail Mem
                    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                   8652 iobroker  20   0  292988 187668  34232 S  18.2   4.8   1011:16 iobroker.js-con
                    569 root      20   0  317376 138804  25900 S  11.3   3.5   4061:23 motion
                   9943 iobroker  20   0  193116  79904  28928 S   5.0   2.0  39:46.05 io.net-tools.0
                   9256 iobroker  20   0  213924  93448  29084 S   4.6   2.4 169:04.11 io.hue.0
                  11069 iobroker  20   0  184288  71588  29012 R   3.6   1.8 181:35.12 io.switchbot-bl
                   8806 iobroker  20   0  262860 153448  34168 S   3.3   3.9 165:16.32 io.javascript.0
                   8701 iobroker  20   0  239256 120404  34756 S   2.0   3.1  15:11.00 io.admin.0
                    549 root      39  19   58424   6536   3504 S   0.7   0.2  14:44.84 rpimonitord
                   8852 iobroker  20   0  197952  69400  29660 S   0.7   1.8   7:18.09 io.telegram.0
                  28966 iobroker  20   0  191620  70628  29868 S   0.7   1.8   1:39.92 io.cloud.0
                    356 pi        20   0  129404  41904  30744 S   0.3   1.1  72:02.59 deCONZ
                    363 root      20   0    8336   3228   2564 S   0.3   0.1  25:53.14 deCONZ-WIFI2.sh
                   1293 iobroker  20   0  185832  79628  33912 S   0.3   2.0   0:08.51 io.tuya.0
                   7884 iobroker  20   0    9376    740    632 S   0.3   0.0   0:00.01 ping
                   9118 iobroker  20   0  192624  72348  29852 S   0.3   1.8   3:50.66 io.alexa2.0
                   9212 iobroker  20   0  203864  75844  29948 S   0.3   1.9  14:13.62 io.hmip.0
                   9531 iobroker  20   0  193632  78324  28912 S   0.3   2.0  18:43.25 io.rpi2.0
                  10275 iobroker  20   0  184152  63852  28952 S   0.3   1.6   3:31.41 io.geofency.0
                  10366 iobroker  20   0  198772  85876  29876 S   0.3   2.2   4:00.00 io.iot.0
                  10553 iobroker  20   0  185184  67036  29128 S   0.3   1.7   6:28.77 io.lgtv.1
                  11515 iobroker  20   0  183016  61760  28928 S   0.3   1.6   3:27.58 io.vis-inventwo
                  11863 iobroker  20   0  206444  95648  29084 S   0.3   2.4  26:46.10 io.yahka.0
                  12982 iobroker  20   0  196396  80096  30508 S   0.3   2.0  20:21.84 io.chromecast.0
                      1 root      20   0   34832   7696   6248 S   0.0   0.2   2:31.71 systemd
                      2 root      20   0       0      0      0 S   0.0   0.0   0:01.04 kthreadd
                      3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
                      4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
                      8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
                      9 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_rude_
                     10 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_trace
                     11 root      20   0       0      0      0 S   0.0   0.0   9:35.07 ksoftirqd/0
                     12 root      20   0       0      0      0 I   0.0   0.0   9:36.60 rcu_sched
                     13 root      rt   0       0      0      0 S   0.0   0.0   0:11.66 migration/0
                     14 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
                     15 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
                     16 root      rt   0       0      0      0 S   0.0   0.0   0:10.47 migration/1
                     17 root      20   0       0      0      0 S   0.0   0.0   0:32.44 ksoftirqd/1
                     20 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
                     21 root      rt   0       0      0      0 S   0.0   0.0   0:09.52 migration/2
                     22 root      20   0       0      0      0 S   0.0   0.0   0:32.02 ksoftirqd/2
                     25 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
                     26 root      rt   0       0      0      0 S   0.0   0.0   0:08.44 migration/3
                     27 root      20   0       0      0      0 S   0.0   0.0   0:31.82 ksoftirqd/3
                  Dann einmal "free":
                  pi@raspberrypi:~ $ free
                  Mem:        3930860     2387076      468780       15168     1075004     1904096
                  Swap:        102396       17152       85244
                  Dann einmal "df -h":
                  pi@raspberrypi:~ $ df -h
                  Filesystem      Size  Used Avail Use% Mounted on
                  /dev/root        30G  7.1G   21G  26% /
                  devtmpfs        1.8G     0  1.8G   0% /dev
                  tmpfs           1.9G   16K  1.9G   1% /dev/shm
                  tmpfs           1.9G   18M  1.9G   1% /run
                  tmpfs           5.0M  8.0K  5.0M   1% /run/lock
                  tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
                  /dev/mmcblk0p1  253M   49M  204M  20% /boot
                  tmpfs           384M     0  384M   0% /run/user/1000
                  Und "dmesg"
                  pi@raspberrypi:~ $ dmesg
                  [    0.000000] Booting Linux on physical CPU 0x0
                  [    0.000000] Linux version 5.10.63-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1496 SMP Wed Dec 1 15:58:56 GMT 2021
                  [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                  [    0.000000] CPU: div instructions available: patching division code
                  [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                  [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
                  [    0.000000] random: fast init done
                  [    0.000000] Memory policy: Data cache writealloc
                  [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
                  [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                  [    0.000000] Zone ranges:
                  [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                  [    0.000000]   Normal   empty
                  [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
                  [    0.000000] Movable zone start for each node
                  [    0.000000] Early memory node ranges
                  [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
                  [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                  [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
                  [    0.000000] On node 0 totalpages: 1012736
                  [    0.000000]   DMA zone: 1728 pages used for memmap
                  [    0.000000]   DMA zone: 0 pages reserved
                  [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
                  [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
                  [    0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
                  [    0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
                  [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                  [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
                  [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:6A:A3:84 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  115200 console=tty1 root=PARTUUID=2a7ced16-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                  [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                                 Please use sysfs to set IO scheduler for individual devices.
                  [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                  [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                  [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                  [    0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
                  [    0.000000] Memory: 3601132K/4050944K available (10240K kernel code, 1364K rwdata, 3192K rodata, 2048K init, 891K bss, 122132K reserved, 327680K cma-reserved, 3264512K highmem)
                  [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                  [    0.000000] ftrace: allocating 34315 entries in 68 pages
                  [    0.000000] ftrace: allocated 68 pages with 2 groups
                  [    0.000000] rcu: Hierarchical RCU implementation.
                  [    0.000000]  Rude variant of Tasks RCU enabled.
                  [    0.000000]  Tracing variant of Tasks RCU enabled.
                  [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                  [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                  [    0.000000] GIC: Using split EOI/Deactivate mode
                  [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
                  [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                  [    0.000034] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                  [    0.000095] bcm2835: system timer (irq = 25)
                  [    0.000742] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                  [    0.000764] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                  [    0.000785] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                  [    0.000803] Switching to timer-based delay loop, resolution 18ns
                  [    0.001055] Console: colour dummy device 80x30
                  [    0.001810] printk: console [tty1] enabled
                  [    0.001878] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                  [    0.001932] pid_max: default: 32768 minimum: 301
                  [    0.002107] LSM: Security Framework initializing
                  [    0.002303] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                  [    0.002347] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                  [    0.003822] cgroup: Disabling memory control group subsystem
                  [    0.004068] CPU: Testing write buffer coherency: ok
                  [    0.004525] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                  [    0.005734] Setting up static identity map for 0x200000 - 0x20003c
                  [    0.005950] rcu: Hierarchical SRCU implementation.
                  [    0.006873] smp: Bringing up secondary CPUs ...
                  [    0.008052] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                  [    0.009372] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                  [    0.010634] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                  [    0.010880] smp: Brought up 1 node, 4 CPUs
                  [    0.010912] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                  [    0.010942] CPU: All CPU(s) started in HYP mode.
                  [    0.010969] CPU: Virtualization extensions available.
                  [    0.011818] devtmpfs: initialized
                  [    0.025835] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                  [    0.026094] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                  [    0.026147] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                  [    0.034360] pinctrl core: initialized pinctrl subsystem
                  [    0.035441] NET: Registered protocol family 16
                  [    0.039071] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                  [    0.039847] audit: initializing netlink subsys (disabled)
                  [    0.040122] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                  [    0.040688] thermal_sys: Registered thermal governor 'step_wise'
                  [    0.041419] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                  [    0.041474] hw-breakpoint: maximum watchpoint size is 8 bytes.
                  [    0.041880] Serial: AMBA PL011 UART driver
                  [    0.074985] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                  [    0.090884] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:01:54, variant start
                  [    0.100898] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
                  [    0.142222] Kprobes globally optimized
                  [    0.147424] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                  [    0.151609] vgaarb: loaded
                  [    0.152075] SCSI subsystem initialized
                  [    0.152300] usbcore: registered new interface driver usbfs
                  [    0.152389] usbcore: registered new interface driver hub
                  [    0.152487] usbcore: registered new device driver usb
                  [    0.152840] usb_phy_generic phy: supply vcc not found, using dummy regulator
                  [    0.154711] clocksource: Switched to clocksource arch_sys_counter
                  [    1.113285] VFS: Disk quotas dquot_6.6.0
                  [    1.113403] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                  [    1.113580] FS-Cache: Loaded
                  [    1.113789] CacheFiles: Loaded
                  [    1.123989] NET: Registered protocol family 2
                  [    1.124227] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
                  [    1.125785] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                  [    1.125944] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                  [    1.126029] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                  [    1.126117] TCP: Hash tables configured (established 8192 bind 8192)
                  [    1.126282] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                  [    1.126337] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                  [    1.126629] NET: Registered protocol family 1
                  [    1.127345] RPC: Registered named UNIX socket transport module.
                  [    1.127377] RPC: Registered udp transport module.
                  [    1.127406] RPC: Registered tcp transport module.
                  [    1.127434] RPC: Registered tcp NFSv4.1 backchannel transport module.
                  [    1.127471] PCI: CLS 0 bytes, default 64
                  [    1.130365] Initialise system trusted keyrings
                  [    1.130625] workingset: timestamp_bits=14 max_order=20 bucket_order=6
                  [    1.139016] zbud: loaded
                  [    1.141149] FS-Cache: Netfs 'nfs' registered for caching
                  [    1.141941] NFS: Registering the id_resolver key type
                  [    1.141994] Key type id_resolver registered
                  [    1.142023] Key type id_legacy registered
                  [    1.142180] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                  [    1.142213] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                  [    1.143276] Key type asymmetric registered
                  [    1.143308] Asymmetric key parser 'x509' registered
                  [    1.143512] bounce: pool size: 64 pages
                  [    1.143568] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                  [    1.143791] io scheduler mq-deadline registered
                  [    1.143822] io scheduler kyber registered
                  [    1.148137] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                  [    1.148190] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                  [    1.148290] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                  [    1.148399] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                  [    1.206814] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                  [    1.207209] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                  [    1.207247] pci_bus 0000:00: root bus resource [bus 00-ff]
                  [    1.207295] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                  [    1.207406] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                  [    1.207661] pci 0000:00:00.0: PME# supported from D0 D3hot
                  [    1.211133] PCI: bus0: Fast back to back transfers disabled
                  [    1.211487] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                  [    1.211630] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                  [    1.212079] pci 0000:01:00.0: PME# supported from D0 D3cold
                  [    1.215569] PCI: bus1: Fast back to back transfers disabled
                  [    1.215647] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                  [    1.215688] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                  [    1.215789] pci 0000:00:00.0: PCI bridge to [bus 01]
                  [    1.215828] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                  [    1.216246] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                  [    1.216488] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
                  [    1.222362] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
                  [    1.223262] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
                  [    1.225793] iproc-rng200 fe104000.rng: hwrng registered
                  [    1.226120] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                  [    1.227018] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                  [    1.239006] brd: module loaded
                  [    1.251103] loop: module loaded
                  [    1.252856] Loading iSCSI transport class v2.0-870.
                  [    1.256117] libphy: Fixed MDIO Bus: probed
                  [    1.257818] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                  [    1.274758] libphy: bcmgenet MII bus: probed
                  [    1.354875] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                  [    1.356048] usbcore: registered new interface driver r8152
                  [    1.356133] usbcore: registered new interface driver lan78xx
                  [    1.356222] usbcore: registered new interface driver smsc95xx
                  [    1.357852] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
                  [    1.358040] xhci_hcd 0000:01:00.0: xHCI Host Controller
                  [    1.358090] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                  [    1.361586] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
                  [    1.362924] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                  [    1.362965] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                  [    1.363002] usb usb1: Product: xHCI Host Controller
                  [    1.363031] usb usb1: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
                  [    1.363062] usb usb1: SerialNumber: 0000:01:00.0
                  [    1.363794] hub 1-0:1.0: USB hub found
                  [    1.363908] hub 1-0:1.0: 1 port detected
                  [    1.364594] xhci_hcd 0000:01:00.0: xHCI Host Controller
                  [    1.364636] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                  [    1.364730] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                  [    1.365282] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                  [    1.365322] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                  [    1.365358] usb usb2: Product: xHCI Host Controller
                  [    1.365388] usb usb2: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
                  [    1.365418] usb usb2: SerialNumber: 0000:01:00.0
                  [    1.366150] hub 2-0:1.0: USB hub found
                  [    1.366256] hub 2-0:1.0: 4 ports detected
                  [    1.367984] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                  [    1.368313] dwc_otg: FIQ enabled
                  [    1.368328] dwc_otg: NAK holdoff enabled
                  [    1.368343] dwc_otg: FIQ split-transaction FSM enabled
                  [    1.368361] Module dwc_common_port init
                  [    1.368814] usbcore: registered new interface driver uas
                  [    1.368940] usbcore: registered new interface driver usb-storage
                  [    1.369159] mousedev: PS/2 mouse device common for all mice
                  [    1.370815] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                  [    1.374182] sdhci: Secure Digital Host Controller Interface driver
                  [    1.374216] sdhci: Copyright(c) Pierre Ossman
                  [    1.374974] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                  [    1.375657] sdhci-pltfm: SDHCI platform and OF driver helper
                  [    1.379694] ledtrig-cpu: registered to indicate activity on CPUs
                  [    1.380057] hid: raw HID events driver (C) Jiri Kosina
                  [    1.380261] usbcore: registered new interface driver usbhid
                  [    1.380292] usbhid: USB HID core driver
                  [    1.385883] Initializing XFRM netlink socket
                  [    1.385948] NET: Registered protocol family 17
                  [    1.386080] Key type dns_resolver registered
                  [    1.386444] Registering SWP/SWPB emulation handler
                  [    1.386627] registered taskstats version 1
                  [    1.386669] Loading compiled-in X.509 certificates
                  [    1.387614] Key type ._fscrypt registered
                  [    1.387644] Key type .fscrypt registered
                  [    1.387672] Key type fscrypt-provisioning registered
                  [    1.399043] uart-pl011 fe201000.serial: there is not valid maps for state default
                  [    1.399368] uart-pl011 fe201000.serial: cts_event_workaround enabled
                  [    1.399457] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                  [    1.406791] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
                  [    1.407696] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
                  [    1.408716] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                  [    1.409789] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                  [    1.409823] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                  [    1.439555] of_cfs_init
                  [    1.439843] of_cfs_init: OK
                  [    1.462105] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                  [    1.463813] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                  [    1.465524] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                  [    1.468557] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                  [    1.470260] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                  [    1.477392] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
                  [    1.478061] Waiting for root device PARTUUID=2a7ced16-02...
                  [    1.552411] mmc1: new high speed SDIO card at address 0001
                  [    1.584917] mmc0: new ultra high speed DDR50 SDHC card at address 0001
                  [    1.585813] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
                  [    1.587498]  mmcblk0: p1 p2
                  [    1.604398] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                  [    1.604496] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [    1.609682] devtmpfs: mounted
                  [    1.619517] Freeing unused kernel memory: 2048K
                  [    1.644757] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                  [    1.665076] Run /sbin/init as init process
                  [    1.665106]   with arguments:
                  [    1.665121]     /sbin/init
                  [    1.665135]     115200
                  [    1.665149]   with environment:
                  [    1.665164]     HOME=/
                  [    1.665178]     TERM=linux
                  [    1.827383] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                  [    1.827430] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                  [    1.827464] usb 1-1: Product: USB2.0 Hub
                  [    1.829462] hub 1-1:1.0: USB hub found
                  [    1.829764] hub 1-1:1.0: 4 ports detected
                  [    2.091281] systemd[1]: System time before build time, advancing clock.
                  [    2.154779] usb 1-1.2: new full-speed USB device number 3 using xhci_hcd
                  [    2.189242] NET: Registered protocol family 10
                  [    2.190671] Segment Routing with IPv6
                  [    2.259195] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
                  [    2.260693] systemd[1]: Detected architecture arm.
                  [    2.300815] systemd[1]: Set hostname to <raspberrypi>.
                  [    2.303873] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
                  [    2.303920] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                  [    2.303957] usb 1-1.2: Product: ConBee II
                  [    2.303986] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
                  [    2.304019] usb 1-1.2: SerialNumber: DE2251186
                  [    2.807967] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
                  [    2.809831] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
                  [    2.879262] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
                  [    2.903901] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
                  [    2.996794] random: systemd: uninitialized urandom read (16 bytes read)
                  [    3.007780] random: systemd: uninitialized urandom read (16 bytes read)
                  [    3.008469] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
                  [    3.009494] random: systemd: uninitialized urandom read (16 bytes read)
                  [    3.010027] systemd[1]: Listening on Journal Audit Socket.
                  [    3.011003] systemd[1]: Listening on Journal Socket (/dev/log).
                  [    3.646914] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                  [    3.742414] systemd-journald[113]: Received request to flush runtime journal from PID 1
                  [    4.341189] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                  [    4.341775] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                  [    4.342627] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                  [    4.343199] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                  [    4.391236] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                  [    4.393370] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                  [    4.393396] [vc_sm_connected_init]: start
                  [    4.394126] [vc_sm_connected_init]: installed successfully
                  [    4.400026] mc: Linux media interface: v0.10
                  [    4.425701] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                  [    4.453648] videodev: Linux video capture interface: v2.00
                  [    4.470424] bcm2835_audio bcm2835_audio: card created with 8 channels
                  [    4.495343] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                  [    4.514906] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                  [    4.537416] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                  [    4.538767] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                  [    4.563980] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                  [    4.564027] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                  [    4.565429] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                  [    4.567787] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                  [    4.568901] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                  [    4.569867] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                  [    4.569897] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                  [    4.569936] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                  [    4.569962] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                  [    4.569999] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                  [    4.572671] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                  [    4.578889] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                  [    4.579002] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                  [    4.590976] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                  [    4.591026] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                  [    4.613586] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                  [    4.613630] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                  [    4.737216] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                  [    4.762754] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                  [    4.837021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                  [    4.837163] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                  [    4.837674] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                  [    4.868383] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                  [    4.921170] brcmfmac: F1 signature read @0x18000000=0x15264345
                  [    4.925000] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
                  [    4.928725] usbcore: registered new interface driver cdc_acm
                  [    4.928743] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                  [    4.934934] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                  [    4.935836] usbcore: registered new interface driver brcmfmac
                  [    5.192384] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                  [    5.193146] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                  [    5.202354] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                  [    7.352014] uart-pl011 fe201000.serial: no DMA platform data
                  [    7.612938] random: crng init done
                  [    7.612959] random: 7 urandom warning(s) missed due to ratelimiting
                  [    7.672507] 8021q: 802.1Q VLAN Support v1.8
                  [    8.014812] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                  [    8.072509] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                  [    8.420271] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                  [    8.420527] bcmgenet fd580000.ethernet eth0: Link is Down
                  [   12.554918] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                  [   12.554950] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                  [   14.568933] Bluetooth: Core ver 2.22
                  [   14.569026] NET: Registered protocol family 31
                  [   14.569037] Bluetooth: HCI device and connection manager initialized
                  [   14.569059] Bluetooth: HCI socket layer initialized
                  [   14.569075] Bluetooth: L2CAP socket layer initialized
                  [   14.569098] Bluetooth: SCO socket layer initialized
                  [   14.577608] Bluetooth: HCI UART driver ver 2.3
                  [   14.577624] Bluetooth: HCI UART protocol H4 registered
                  [   14.577697] Bluetooth: HCI UART protocol Three-wire (H5) registered
                  [   14.577913] Bluetooth: HCI UART protocol Broadcom registered
                  [   14.756909] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                  [   14.756918] Bluetooth: BNEP filters: protocol multicast
                  [   14.756931] Bluetooth: BNEP socket layer initialized
                  [  101.775676] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                  [308247.579319] Alignment trap: not handling instruction e1942f9f at [<b6cade64>]
                  [308247.579328] 8<--- cut here ---
                  [308247.579348] Unhandled fault: alignment exception (0x221) at 0x04b9db27
                  [308247.579363] pgd = c8659170
                  [308247.579375] [04b9db27] *pgd=11a24003, *pmd=67618003
                  [456353.949063] Alignment trap: not handling instruction f4e2c83d at [<0121b100>]
                  [456353.949072] 8<--- cut here ---
                  [456353.949090] Unhandled fault: alignment exception (0x221) at 0x04d3167e
                  [456353.949105] pgd = 19539af6
                  [456353.949116] [04d3167e] *pgd=06a1d003, *pmd=9e051003
                  pi@raspberrypi:~ $
                  Danke im Voraus =)
                  Edit: hier noch der syslog:
                  syslog
                  nodejs
                  v14.19.0
                  node
                  v14.19.0
                  npm
                  6.14.16
                  rpi4 4 GB, 42 Prozesse, ca 50% Ram immer frei.
                  • K Krys
                    Dann ein mal "top":
                    Dann einmal "free":
                    Und "dmesg"
                    [    1.665135]     115200
                    [    1.665164]     HOME=/
                    pi@raspberrypi:~ $
                    Danke im Voraus =)
                    syslog
                    nodejs
                    v14.19.0
                    node
                    v14.19.0
                    npm
                    6.14.16
                    D Nicht stören
                    D Nicht stören
                    dirkhe
                    #734
                    Auf github gibt es eine neue Version 3.3.5. Probiert die mal aus, bitte. Es kann zwar sein, dass die Map dann nicht mehr erzeugt wird, aber hoffentlich stürzt der Adapter dann nicht mehr ab
                    K gelberlemmyG bahnuhrB 3 Antworten Letzte Antwort
                    • D dirkhe
                      Krys
                      #735
                      @dirkhe Moin, bei mir stürzt er weiterhin mit SIGSEGV/SIGABRT ab. Hab im Issue kommentiert.
                      Edit: Vielen lieben Dank für die MÜHE!
                      • D dirkhe
                        gelberlemmyG Offline
                        gelberlemmy
                        #736
                        @dirkhe Moin, bei mir läuft es jetzt ohne Abstürze, aber die Map läuft halt nicht mehr.
                        Gruss André
                        • gelberlemmyG gelberlemmy
                          Gruss André
                          D Nicht stören
                          D Nicht stören
                          dirkhe
                          #737
                          @gelberlemmy ich denke, dass die canvas Bibliothek das Problem ist, da bin ich nicht so tief drin und weiß auch nicht, ob wir da überhaupt was machen können.
                          gelberlemmyG bahnuhrB 2 Antworten Letzte Antwort
                          • D dirkhe
                            gelberlemmy
                            #738
                            @dirkhe Ok, vor dem jetzigen Update war halt ständige Abstürze und die Map funktionierte. Wobei ich dann doch lieber auf die Map verzichte um die Funktionen zu nutzen. Ich habe, was auch immer Canvas ist, keine Ahnung davon. Aber vielleicht findet sich da ja noch jemand.... Danke aber für Deine super Arbeit.
                            Gruss André
                            • D dirkhe
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #739
                              @dirkhe sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                              Ich habe absolut keine Probleme mit dem Adapter.
                              Kein Absturz und map ist auch da.
                              Hast du den Adapter jetzt geändert.
                              d.h. beim nächsten update geht meine map auch nicht mehr ???
                              Danke.
                              • bahnuhrB bahnuhr
                                D Nicht stören
                                D Nicht stören
                                dirkhe
                                #740
                                @bahnuhr nein, was ich gemacht habe, ist ein try catch um die map Generierung zu setzen. Also wenn die map nicht erzeugt werden kann, stürzt nicht sofort der ganze Adapter ab.
                                So wieves aussieht, gibt es Probleme mit der canvas lib unter einer bestimmten node Version.
                                • D dirkhe
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #741
                                  Hier hast du doch geschrieben, dass mit der neuen Version es sein kann, dass die map nicht mehr erzeugt wird.
                                  Oder wie muss man dies lesen?
                                  Danke.
                                  D K 2 Antworten Letzte Antwort
                                  • bahnuhrB bahnuhr
                                    D Nicht stören
                                    D Nicht stören
                                    dirkhe
                                    #742
                                    @bahnuhr nein, damit meinte ich, dass es nicht Probleme mit Karten löst, sonden nur die abstürze des Adapters. Ich hatte genau die Reaktion erwartet, dass jemand sagt, dass die Karte jetzt nicht mehr funktioniert. Das ist halt das Problem, dass der Adapter abstürzt und das als Problem angesehen wird. Jetzt läuft er halt weiter, nur die Karte wird nicht mehr erzeugt. Aber wwenn die Karte erzeugt werden kann, weil du eine funktionierende canvas lib hast, ist alles gut
                                    gelberlemmyG 1 Antwort Letzte Antwort
                                    • bahnuhrB bahnuhr
                                      Krys
                                      #743
                                      @bahnuhr mit welchem Setup betreibst du deinen ioBroker?
                                      • D dirkhe
                                        gelberlemmy
                                        #744
                                        @dirkhe guten Morgen. Hier wurde ja mal ein Workaround für die Canvas beschrieben. Sollte es Sinn ergeben, dass ich dies einmal ausführe ? Was macht die Canvas eigentlich ?
                                        • MeistertrM Meistertr
                                          Aktuelle Test Version 3.1.6
                                          Veröffentlichungsdatum 18.4.2021
                                          Github Link https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum
                                          Lange hats gedauert aber langsam komm ich zum Ende (wobei das dann wahrscheinlich der Anfang ist :) ).
                                          Was hat sich geändert? Alles und nix kann kann man sagen.
                                          Der Adapter wurde komplett neu aufgesetzt und dem Aktuellen stand angepasst.
                                          vorher:
                                          • Nachrichten an den Roboter wurden willkürlich geschickt und gehofft das eine Antwort kommt.
                                          • Die Erkennung des Roboters (Modell und Marke und Firmware) wurden durch Ankommende Nachrichten oder das Ausbleiben erkannt
                                          • comact mode nicht möglich da zig Timeouts liefen
                                          • Keine neuen/anderen Sauger integrierbar da alles in einer Datei lag
                                          jetzt:
                                          • beim start wird zwingend das Modell ermittelt wonach dann die richtige Datei für den jeweiligen Sauger geladen wird
                                          • danach werden Strukturiert die Sonderfunktionen ermittelt und freigegeben
                                          • Nachrichten werden nicht mehr willkürlich gesendet sonders strukturiert und jede Nachricht bekommt eine Antwort
                                          • comact mode möglich da alle timer zentral gelagert sind
                                          ich habe mich bemüht die Objekte zum Vorgänger gleich zu lassen. also Optisch ist nicht viel neu aber wie gesagt unterm Kleid alles was man im debug log sehen sollte.
                                          ich habe noch nicht viele Sauger in der Datenbank also kann es zu warn log einträgen kommen, dann bitte modell und bezeichnung posten dann nehm ich sie mit rein.
                                          Bitte alles Testen da ich viel ohne Testen umgeschrieben habe (bei über 2000 Zeilen) konnte ich nicht alles direkt testen.
                                          Stand Aktuell:
                                          Jetzt sollte alles gehen was bei der 2er auch geht. und mehr
                                          Was sollte gehen:
                                          • alles wie beim alten außer die map (folgt in kürze)
                                          • viomi Modelle die sonst über meinen Fork liefen sind nun mit drin
                                          • support für den S7 (letztes update hat die History kaputt gemacht)
                                          • Map wir unterstützt
                                          Fixes:
                                          • Map bei zwei Saugern funtionieren
                                          • Map wird zuverlässig(er) geladen
                                          • 3.0.2 Manueller Map Reload Button funktionert
                                          • 3.0.4/ 3.0.7 Timer geht wieder
                                          • 3.0.5 Disable map_slot warning, add start button, fix error while sending messages without selected device, fix water_box value
                                          • 3.0.6 fix queue States, fix cleaning Buttons.
                                          • 3.0.8 fix map for Valetudo
                                          • 3.1.0 aktuelle Goto und Zones werden gespeichert
                                          • 3.1.1 fix queue
                                          • 3.1.3 Map bugfix, add Multimap Support
                                          • 3.1.3 fix missing Wifi Signal
                                          • 3.1.4 Fix Connrection after reboot/ now wifi
                                            3.1.6:
                                          • fixed Disk I/O
                                          • added get States when map is changed
                                          • minimize Messages
                                          • changed logentrys from warn to debug
                                          • added Donate button
                                          folgt in Kürze:
                                          - Koordinaten von goto und Zonen werden angezeigt (in den jeweiligen states)
                                          • dreame support über miot
                                          • compactmode
                                            - map
                                          • map für history
                                          • material tabel
                                          • led Status S7
                                          • neues Logo
                                          • Doku aufbereiten
                                          Installieren bitte über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum (einfach von git)
                                          Bitte Vorher den alten Adapter vollständig löschen.
                                          Dies ist die Alpha also BITTE nur installieren wenn ihr wisst was ihr macht und einen qualifizierten Bugreport liefern könnt
                                          Bitte in dieses Thema NUR Fehler oder Requests die den Adapter betreffen. KEINE Installationsfehler oder sonstige Fragen. macht dafür bitte wenn die Suche nichts ergeben hat ein neues Thema auf damit es hier nicht so überläuft wie in den alten Threads..
                                          gelberlemmy
                                          #745
                                          @meistertr so jetzt habe ich wieder die ganzen Abstürtze.Aber erst nachdem er etwas länger gelaufen ist. Hmmm
