  4. js-controller 4.0 jetzt im BETA/LATEST!
747 Beiträge 70 Kommentatoren 289.4k Aufrufe 60 Beobachtet
  • UweRLPU Offline
    UweRLPU Offline
    UweRLP
    Auch hier, ein Windows 10 x64 System, hat das Upgrade auf die 4.0.4 erfolgreich geklappt.
    Es gab die im ersten Post angeküdigten Fehlermeldungen aber es läuft soweit ich bisher sehen konnte.
    Der yamaha und deconz Adapter bringen nun WARN Meldungen, denke aber das muß im Adapter gefixt werden.
    yamaha.0
    	2022-02-06 13:30:25.803	warn	This object will not be created in future versions. Please report this to the developer.
    yamaha.0
    	2022-02-06 13:30:25.803	warn	Object yamaha.0.powerAllZones is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
    yamaha.0
    	2022-02-06 13:30:25.801	warn	This object will not be created in future versions. Please report this to the developer.
    yamaha.0
    	2022-02-06 13:30:25.801	warn	Object yamaha.0.zone4 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
    yamaha.0
    	2022-02-06 13:30:25.800	warn	This object will not be created in future versions. Please report this to the developer.
    yamaha.0
    	2022-02-06 13:30:25.799	warn	Object yamaha.0.zone3 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
    yamaha.0
    	2022-02-06 13:30:25.798	warn	This object will not be created in future versions. Please report this to the developer.
    yamaha.0
    	2022-02-06 13:30:25.798	warn	Object yamaha.0.zone2 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
    yamaha.0
    	2022-02-06 13:30:25.796	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:23.405	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:23.405	warn	Object Lights.17.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    	2022-02-06 13:31:23.347	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:23.347	warn	Object Lights.15.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    	2022-02-06 13:31:23.292	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:23.291	warn	Object Lights.14.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    	2022-02-06 13:31:23.058	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:23.058	warn	Object Lights.13.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    	2022-02-06 13:31:22.952	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:22.952	warn	Object Lights.12.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    	2022-02-06 13:31:22.892	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:22.891	warn	Object Lights.11.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    	2022-02-06 13:31:22.834	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:22.834	warn	Object Lights.10.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    	2022-02-06 13:31:22.777	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:22.777	warn	Object Lights.9.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    	2022-02-06 13:31:22.492	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:22.492	warn	Object Groups.26756.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    	2022-02-06 13:31:22.487	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:22.487	warn	Object Groups.5.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    	2022-02-06 13:31:22.486	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:22.486	warn	Object Groups.4.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    deconz.0
    	2022-02-06 13:31:22.486	warn	Object Groups.1.xy is invalid: Default value has to be stringified but received type "object"
    deconz.0
    	2022-02-06 13:31:22.485	warn	This object will not be created in future versions. Please report this to the developer.
    deconz.0
    	2022-02-06 13:31:22.485	warn	Object Groups.2.xy is invalid: Default value has to be stringified but received type "object"
    UweRLPU 1 Antwort Letzte Antwort
    • E e-i-k-e
      Klappt leider nicht.
      pi@raspberrypi-display5:/opt/iobroker $ iobroker rebuild rpi2 --install
      Path argument needs to be an absolute path!
      pi@raspberrypi-display5:/opt/iobroker $ cd
      pi@raspberrypi-display5:~ $ iobroker rebuild rpi2 --install
      Edit: Auf einem anderen Slave mit 3.3.22 klappt der Befehl wie gewohnt.
      pi@raspberrypi-display2:/opt/iobroker $ iobroker rebuild rpi2.2 --install       npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.rpi2"
      Rebuild rpi2.2 done
      @e-i-k-e sagte: mit 3.3.22 klappt der Befehl wie gewohnt.
      Changelog 4.0.0:
      CLI command iob rebuild adaptername is no longer supported because of the new way of automatic rebuilds and some unwanted side effects
      E 1 Antwort Letzte Antwort
      • UweRLPU UweRLP
        yamaha.0
        yamaha.0
        yamaha.0
        yamaha.0
        yamaha.0
        yamaha.0
        yamaha.0
        yamaha.0
        yamaha.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        deconz.0
        UweRLPU Offline
        UweRLPU Offline
        UweRLP
        @uwerlp issues waren bei GitHub schon angelegt :-)
          Changelog 4.0.0:
          e-i-k-e
          Ach oaky! Das erklärt das natürlich.
          Nur wie behebe ich den Fehler @apollon77 ?
          • E e-i-k-e
            Meine Master habe ich auch über iobroker upgrade self auf 4.0.4 gebracht.
            Testweise hebe ich einen meine Slaves auch auf die aktuelle Version hoch gezogen.
            Hier funktioniert anschließend der rpi2 Adapter nicht.
            javascript.5	2022-02-06 12:47:59.873	info	(21150) Sets unsupported
            rpi2.5	2022-02-06 12:47:57.476	error	(21169) cannot use GPIO: TypeError: Cannot read property 'setMode' of null
            rpi2.5	2022-02-06 12:47:57.470	error	the module (for instance, using `npm rebuild` or `npm install`).
            rpi2.5	2022-02-06 12:47:57.470	error	NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
            rpi2.5	2022-02-06 12:47:57.470	error	NODE_MODULE_VERSION 72. This version of Node.js requires
            rpi2.5	2022-02-06 12:47:57.470	error	was compiled against a different Node.js version using
            rpi2.5	2022-02-06 12:47:57.470	error	(21169) Cannot initialize GPIO: Error: The module '/opt/iobroker/node_modules/epoll/build/Release/epoll.node'
            rpi2.5	2022-02-06 12:47:55.156	info	(21169) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v14.18.2, js-controller: 4.0.4
            rpi2.5	2022-02-06 12:47:54.305	info	(21169) Sets unsupported
            rpi2.5	2022-02-06 12:47:54.303	info	(21169) Sets unsupported
            rpi2.5	2022-02-06 12:47:54.301	info	(21169) Sets unsupported
            rpi2.5	2022-02-06 12:47:54.295	info	(21169) Sets unsupported
            host.raspberrypi-display5	2022-02-06 12:47:49.324	info	instance system.adapter.rpi2.5 started with pid 21169
            host.raspberrypi-display5	2022-02-06 12:47:46.955	info	instance system.adapter.javascript.5 started with pid 21150
            host.raspberrypi-display5	2022-02-06 12:47:43.713	info	starting 2 instances
            host.raspberrypi-display5	2022-02-06 12:47:43.579	info	91 instances found
            host.raspberrypi-display5	2022-02-06 12:47:39.465	info	Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
            host.raspberrypi-display5	2022-02-06 12:47:39.441	info	added notifications configuration of host
            host.raspberrypi-display5	2022-02-06 12:47:39.397	info	Node.js version has changed from unknown to 14.18.2
            host.raspberrypi-display5	2022-02-06 12:47:39.370	info	connected to Objects and States
            host.raspberrypi-display5	2022-02-06 12:47:37.963	info	Sets unsupported
            host.raspberrypi-display5	2022-02-06 12:47:37.962	info	Sets unsupported
            host.raspberrypi-display5	2022-02-06 12:47:37.960	info	Sets unsupported
            host.raspberrypi-display5	2022-02-06 12:47:37.958	info	Sets unsupported
            host.raspberrypi-display5	2022-02-06 12:47:37.224	info	ip addresses: 192.168.3.114 fe80::5f2b:268f:852e:cb99
            host.raspberrypi-display5	2022-02-06 12:47:37.220	info	hostname: raspberrypi-display5, node: v14.18.2
            host.raspberrypi-display5	2022-02-06 12:47:37.219	info	Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            host.raspberrypi-display5	2022-02-06 12:47:37.208	info	iobroker.js-controller version 4.0.4 js-controller starting
            host.raspberrypi-display5	2022-02-06 12:43:55.858	info	terminated
            Edit:
            pi@raspberrypi-display5:/opt/iobroker $ iobroker rebuild rpi2.5 --install
            @e-i-k-e hi, hier muss der binäre Teil neu ge auth. werden. Hast du mal da volle log? An sich sollte er jetzt bis zu drei mal versuchen über rebuilds das zu fixen
            • ice987I Offline
              ice987I Offline
              ice987
              ich hab' mich auch versucht mit dem
              System: ioBroker.docker v6.0.0
              und erhalte folgende Fehlermeldung:
              root@iobroker-v600-testsystem7:/opt/iobroker# pkill -u iobroker
              root@iobroker-v600-testsystem7:/opt/iobroker# iobroker update
              Used repository: latest
              hash unchanged, use cached sources
              update done
              Adapter    "admin"         : 5.2.3    , installed 5.1.25 [Updateable]
              Controller "js-controller" : 4.0.4    , installed 3.3.21 [Updateable]
              root@iobroker-v600-testsystem7:/opt/iobroker# iobroker upgrade self
              Update js-controller from @3.3.21 to @4.0.4
              NPM version: 6.14.16
              npm install iobroker.js-controller@4.0.4 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
              In file included from ../../nan/nan.h:58,
                               from ../src/unix_dgram.cc:5:
              /opt/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                793 |       (node::addon_register_func) (regfunc),                          \
              /opt/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
              ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                404 | NODE_MODULE(unix_dgram, Initialize)
              Server Objects 127.0.0.1:36016 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
              Server States 127.0.0.1:45560 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
              Server Objects 127.0.0.1:36016 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
              Server States 127.0.0.1:45562 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
              Server Objects 127.0.0.1:36016 Error from InMemDB: Error: Unknown LUA script load
              Server Objects 127.0.0.1:36016 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
              Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
              Server Objects 127.0.0.1:36016 Error from InMemDB: Error: multi NOT SUPPORTED
              Server Objects 127.0.0.1:36016 Error from InMemDB: Error: sadd NOT SUPPORTED
              Server Objects 127.0.0.1:36016 Error from InMemDB: Error: exec NOT SUPPORTED
              This upgrade of "admin" will introduce the following changes:
              -> 5.2.3:
              Fixed error in `AutocompleteSendTo`
              Fixed error in charts
              -> 5.2.2:
              Changed the minimal required js-controller version to 3.3.22
              Used web-socket library 8 (no node 10 support anymore)
              -> 5.2.1:
              Allow in expert mode the creation of states and channels in mqtt branch
              -> 5.2.0:
              Fix crash cases reported via sentry
              Added support for multi-repositories
              -> 5.1.29:
              -> 5.1.28:
              Fixed discovery function
              Fixed some GUI bugs
              Would you like to upgrade admin from @5.1.25 to @5.2.3 now? [(y)es, (n)o]: y
              Update admin from @5.1.25 to @5.2.3
              host.iobroker-v600-testsystem7 Adapter "system.adapter.admin.0" is stopped.
              Installing iobroker.admin@5.2.3... (System call)
              + iobroker.admin@5.2.3
              updated 7 packages in 32.186s
              17 packages are looking for funding
                run `npm fund` for details
              host.iobroker-v600-testsystem7 Adapter "system.adapter.admin.0" is started
              Update "system.adapter.admin.0"
              upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
              upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
              upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
              upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
              upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
              upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
              upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
              upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
              upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
              root@iobroker-v600-testsystem7:/opt/iobroker# iobroker start
              Starting iobroker controller daemon...
              iobroker controller daemon started. PID: 1425
              ioBroker ist nicht zu erreichen
              husqvarna-automower, meteoblue, wiserbyfeller, spritmonitor
              apollon77A ste_gleiS 2 Antworten Letzte Antwort
              • ice987I ice987
                update done
                -> 5.2.3:
                -> 5.2.2:
                -> 5.2.1:
                -> 5.2.0:
                -> 5.1.29:
                -> 5.1.28:
                Fixed some GUI bugs
                @ice987 ok was steht im log? Ich Seherin den Ausgaben keine Fehler. Da ist an sich alles ok
                ice987I 1 Antwort Letzte Antwort
                • apollon77A apollon77
                  ice987I Offline
                  ice987I Offline
                  ice987
                  @apollon77
                  der Restart vom Container ergibt nun:
                  -------------------------     2022-02-06 15:04:25      -------------------------
                  -----                 Welcome to your ioBroker-container!                  -----
                  -----                    Startupscript is now running.                     -----
                  -----                          Please be patient!                          -----
                  -----                        Debugging information                         -----
                  -----                                System                                -----
                  -----                    arch:                x86_64                       -----
                  -----                             Docker-Image                             -----
                  -----                    image:               v6.0.0                       -----
                  -----                    build:               2021-12-17T03:48:21+00:00    -----
                  -----                               Versions                               -----
                  -----                    /opt/scripts/iobroker_startup.sh: line 48: /usr/bin/node: Operation not permitted
                  node:                                             -----
                  -----                    /usr/bin/env: ‘node’: Operation not permitted
                  npm:                                              -----
                  -----                                 ENV                                  -----
                  -----                    SETGID:              1000                         -----
                  -----                    SETUID:              1000                         -----
                  -----                  Step 1 of 5: Preparing container                   -----
                  Nothing to do here.
                  -----             Step 2 of 5: Detecting ioBroker installation             -----
                  Existing installation of ioBroker detected in /opt/iobroker.
                  -----             Step 3 of 5: Checking ioBroker installation              -----
                  (Re)Setting folder permissions (This might take a while! Please be patient!)...
                  Done.
                  Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
                  Done.
                  error: exec failed: operation not permitted
                  /opt/scripts/iobroker_startup.sh: line 199: [: !=: unary operator expected
                  -----                Step 4 of 5: Applying special settings                -----
                  Some adapters have special requirements/ settings which can be activated by the use of environment variables.
                  For more information take a look at readme.md on Github!
                  -----                    Step 5 of 5: ioBroker startup                     -----
                  Starting ioBroker...
                  • ChaotC Chaot
                    @apollon77 Update ist problemlos durchgelaufen.
                    Der Ubuntu Adapter stürzt ab, aber der ist sowieso eine Datenleiche und wird meinerseits nicht mehr benötigt.
                    Mein erster Eindruck ist, dass die Admin Oberfläche irgendwie flüssiger laüft. Gerade beim Scrollen durch die Objekte hatte ich vorher deutliche Verzögerung. Ich hatte das eigentlich auf meinen Browser und System zurückgeführt, aber das schien doch vom ioBroker zu kommen.
                    @chaot was ist denn de ubuntu Adapter? Und was gefällt ihm nicht?
                    • ice987I ice987
                      update done
                      -> 5.2.3:
                      -> 5.2.2:
                      -> 5.2.1:
                      -> 5.2.0:
                      -> 5.1.29:
                      -> 5.1.28:
                      Fixed some GUI bugs
                      ste_gleiS Offline
                      ste_gleiS Offline
                      ste_glei
                      @ice987
                      Ich hatte den gleichen log
                      iobroker fix
                      hat geholfen
                        e-i-k-e
                        @apollon77
                        anbei wie gewünscht die komplette log.
                        b04d2521-d6ec-46a9-ab5a-18d5ad80331e-iobroker.2022-02-06.log
                        • ste_gleiS ste_glei
                          @ice987
                          iobroker fix
                          hat geholfen
                          ice987I Offline
                          ice987I Offline
                          ice987
                          @ste_glei
                          kann ich bestätigen:
                          iobroker fix
                          hilft und ioBroker läuft nun
                          apollon77A E 2 Antworten Letzte Antwort
                            ChaotC Offline
                            ChaotC Offline
                            Chaot
                            @apollon77 Das ist ne uralte Leiche die mitgelaufen ist.
                            https://github.com/Standarduser/ioBroker.ubuntu
                            Ist mir nie aufgefallen dass das noch aktiv ist.
                            Meinerseits bereits entsorgt, da überflüssig.
                            Ausgegebener Fehler:
                            ubuntu.0
                            2022-02-06 12:57:13.847	error	Cannot read property 'getObjectList' of undefined
                            ubuntu.0
                            2022-02-06 12:57:13.846	error	TypeError: Cannot read property 'getObjectList' of undefined at Object.ready (/opt/iobroker/node_modules/iobroker.ubuntu/main.js:35:25) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8225:68
                            ubuntu.0
                            2022-02-06 12:57:13.842	error	unhandled promise rejection: Cannot read property 'getObjectList' of undefined
                            ubuntu.0
                            2022-02-06 12:57:13.837	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            amg_666A apollon77A 2 Antworten Letzte Antwort
                            • ChaotC Chaot
                              ubuntu.0
                              ubuntu.0
                              ubuntu.0
                              ubuntu.0
                              amg_666A Offline
                              amg_666A Offline
                              amg_666
                              Eben den latest/Beta runtergeladen, einmal Raspi Slave, ohne Probleme und danach auf Proxmox/Debian, biedes ohne irgendwelche Probleme.
                              • ChaotC Chaot
                                ubuntu.0
                                ubuntu.0
                                ubuntu.0
                                ubuntu.0
                                @chaot Naja,d er Hätte mit controller 3.x schon Fehler wegen "adapter.objects.getObjectList" loggen müssen und muss angepasst werden. Leg doch mal ein issue an
                                • ice987I ice987
                                  @ste_glei
                                  iobroker fix
                                  @ice987 Verstehe ich nicht weil der Container macht eigentlich genauein Fix beim startup soweit ich weiss ... also das wäre interessant das sich das Andre mal anschaut
                                  ice987I F 3 Antworten Letzte Antwort
                                  • E e-i-k-e
                                    @apollon77
                                    @e-i-k-e Ahhh der RPI2 Adapter ist "zu nett" und fängt den Fehler so ab das der Rebuild Mechanismus vom Controller nicht greifen kann. Willste mal was versuchen?
                                    Editiere mal /opt/iobroker/node_modules/iobroker.rp2/main.js und füge bei Zeile 648 das hinzu https://github.com/iobroker-community-adapters/ioBroker.rpi2/blob/master/main.js#L648
                                    Danach bitte adapter neu starten ... Dann schauen wir mal was das System so macht. Hätte dann gern das log. Also er sollte - wenn er sich dann wegen dem Folgefehler beendet - der Controller sagen das er rebuild machen will ... bis zu 3x !!
                                    frankthegreatF E 2 Antworten Letzte Antwort
                                      ChaotC Offline
                                      ChaotC Offline
                                      Chaot
                                      @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                                      .... Leg doch mal ein issue an
                                      Beim Adapter? Der wird scheinbar seit 3 Jahren nicht mehr gepflegt bzw. ist nie über die eine Version hinausentwickelt worden. Letzte Aktivität 20.01.2019
                                      Ist eher sinnlos. Löschen und nicht darüber nachdenken.
                                      • ChaotC Chaot
                                        @chaot Jo ... aber dann sehen es andere das es bekannt ist :)
                                          frankthegreatF Offline
                                          frankthegreat
                                          @apollon77
                                          Update auf 4.0.4 auf meinem Testsystem sauber durchgelaufen. 👍
                                          Was mir auf die Schnelle aufgefallen ist:
                                          Die "Clean" Befehle zicken rum. Weis aber nicht, ob es damit zusammenhängt. Mit der 3.0.3 ging das denk ich.
                                          pi@raspberrypi:~ $ iob stop
                                          pi@raspberrypi:~ $ Sudo apt-get clean
                                          -bash: Sudo: Kommando nicht gefunden.
                                          pi@raspberrypi:~ $ Sudo apt-get autoclean
