  4. Alpha Test js-controller 4.0
196 Beiträge 20 Kommentatoren 46.7k Aufrufe 22 Beobachtet
    @apollon77
    eben auch auf js-controller 4.03 mal gegangen, iobroker laeuft, kam beim update hier was :
    ilovegym@VMC123-iobroker /opt/iobroker $ npm i iobroker.js-controller@next
    > iobroker.js-controller@4.0.3 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.15
    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
    > node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
    In file included from ../../nan/nan.h:56,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:787:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:821:3: note: in expansion of macro 'NODE_MODULE_X'
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
     NODE_MODULE(unix_dgram, Initialize)
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
    > iobroker.js-controller@4.0.3 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    object _design/system updated
    Fehler kommt auf den Raspis als Multihost-slave ebenfalls..
    F
    F
    Fortune95
    #174
    @apollon77
    Upadate auf 4.0.3 lief mit den bereits bekannten Warnungen von den Adaptern Yamaha, Shelly und shuttercontrol durch. 👍
    Braucht der neue js-controller weniger Speicher?
      @ilovegym
      Welcher Fehler? Das sind ganz normale build messages
      #175
      @thomas-braun oh , ich meine das warning incompatible function types.. ok, wenn das so sein soll, soll mir recht sein, geht ja auch alles.. :-)
      • FeuersturmF Feuersturm
        @apollon77 Habe gerade einmal ein update auf die 4.0.3 gemacht.
        Gestern abend hatte ich noch ein apt update / upgrade gemacht, wobei auch nodejs aktualisiert wurde. Aktuelle node und npm Version:
        proxmox@ioBrokerTestsystem:/opt/iobroker$ node -v
        v14.19.0
        proxmox@ioBrokerTestsystem:/opt/iobroker$ npm -v
        6.14.16
        Beim Update gab es diese Fehlermeldungen. Haben sie was zu bedeuten?
        Die IP 192.168.178.78 ist der ioBroker Slave. Ich habe gerade den Master aktualisiert, der Slave (js-controller 4.0 alpha 73) lief aber.
        Server Objects 192.168.178.78:60268 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerNew.cputime: The database is not open!
        Server Objects 192.168.178.78:60268 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerNew.mem: The database is not open!
        Server Objects 192.168.178.78:60268 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerNew.memHeapUsed: The database is not open!
        Hier die vollständie Ausgabe vom Update
        proxmox@ioBrokerTestsystem:/opt/iobroker$ npm i iobroker.js-controller@next
        [sudo] password for proxmox:
        NPM version: 6.14.16
        > node-gyp rebuild
        In file included from ../src/unix_dgram.cc:5:
        ../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':
        ../../nan/nan.h:2294:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
         2294 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
        ../src/unix_dgram.cc: At global scope:
        /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
          793 |       (node::addon_register_func) (regfunc),                          \
        /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro 'NODE_MODULE_X'
          827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
          404 | NODE_MODULE(unix_dgram, Initialize)
          "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nV9blMZ0EBC/006ZLnsA6QLs0SqruVgPQbUjLP5Q7F4Dmudz9swxpuT0=\r\n-----END RSA PRIVATE KEY-----\r\n",
          "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\n0F41Cw5EmdU=\r\n-----END CERTIFICATE-----\r\n"
        Update certificate defaultPrivate
        The object "system.certificates" was updated successfully.
        Update certificate defaultPublic
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        + iobroker.js-controller@4.0.3
        removed 19 packages and updated 14 packages in 102.06s
        43 packages are looking for funding
          run `npm fund` for details
        Github issue
        https://github.com/ioBroker/ioBroker.js-controller/issues/1746
        apollon77A
        apollon77A
        #176
        @feuersturm also wenn das das Update vom Master war und der Slave noch lief Bzw sich neu gestartet hat dann kann sowas ggf passieren.
        FeuersturmF Thomas BraunT 2 Antworten Letzte Antwort
        • apollon77A apollon77
          FeuersturmF
          FeuersturmF
          Feuersturm
          #177
          @apollon77 sagte in Alpha Test js-controller 4.0:
          Ok. Slave lief in diesem Falle noch.
            Thomas BraunT
            Thomas BraunT
            Most Active Developer
            #178
            @apollon77
            Hab auch 4.0.3 laufen. Keine Auffälligkeiten hier.
            • F Fortune95
              @apollon77
              apollon77A
              apollon77A
              #179
              @fortune95 Speicherverbrauchstechnisch haben wir nicht wirklich etwas geändert wenn ich mich recht entsinne. Und daher: kann gut sein, wäre interessant ;-)) beobachte es mal
                apollon77A
                apollon77A
                #180
                @feuersturm machst bitte trotzdem ein github issue. Will mir das ansehen
                F FeuersturmF 2 Antworten Letzte Antwort
                  F
                  F
                  Fortune95
                  #181
                  @apollon77
                  Ok, werde ich weiter beobachten. Aktuell etwas über 1GB weniger :-))
                    #182
                    @apollon77 hab auch 1GB weniger in use...
                    • foxriver76F foxriver76
                      @lonsimbt sagte in Alpha Test js-controller 4.0:
                      Beide Adapter sind zzt. nicht in Benutzung. Können die Ordner tatsächlich gefahrlos gelöscht werden?
                      Ich vermute die Adapter sind derzeit nicht mal installiert?
                      apollon77A
                      apollon77A
                      #183
                      @foxriver76 wäre auch meine Vermutung. Sonst upload all mal machen
                      • F Fortune95
                        @apollon77
                        Thomas BraunT
                        Thomas BraunT
                        #184
                        @fortune95 sagte in Alpha Test js-controller 4.0:
                        Nach so kurzer uptime kannst du das eher nicht beurteilen. Schau nach ein paar Stunden nochmal danach.
                          FeuersturmF
                          FeuersturmF
                          Feuersturm
                          #185
                          Erledigt, ist in meinem obigen Post verlinkt.
                          • FeuersturmF
                            FeuersturmF
                            Feuersturm
                            #186
                            @apollon77
                            Ich hab gerade den Slave (iobrokerNew) ebenfalls auf 4.0.3 aktualisiert.
                            Danach hab ich mal den Master per iobroker stop ausgeschaltet. Der Slave meldet berechtigterweise
                            host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                            danach hab ich den Master wieder gestartet. Beim hochfahren war im Log folgende Warnungen / Fehler vom Master / Slave im Log
                            05 Feb 2022 12:09:23.686
                            iobrokerTestsystemSlave host.ioBrokerNew Could not execute primary host determination: Error Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
                            05 Feb 2022 12:09:23.683
                            05 Feb 2022 12:09:23.678
                            iobrokerTestsystem host.ioBrokerTestsystem-Server Objects 192.168.178.78:48414 Error from InMemDB: Error: Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
                            05 Feb 2022 12:09:23.675
                            iobrokerTestsystemSlave host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                            Vollständiges Log:
                            05 Feb 2022 12:09:30.646
                            iobrokerTestsystem admin.0 (26234) requesting all objects
                            05 Feb 2022 12:09:30.644
                            iobrokerTestsystem admin.0 (26234) requesting all states
                            05 Feb 2022 12:09:30.554
                            iobrokerTestsystem admin.0 (26234) starting. Version 5.2.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.0.3
                            05 Feb 2022 12:09:30.327
                            iobrokerTestsystem host.ioBrokerTestsystem instance system.adapter.javascript.0 started with pid 26245
                            05 Feb 2022 12:09:28.683
                            iobrokerTestsystemSlave host.ioBrokerNew Objects database successfully reconnected
                            05 Feb 2022 12:09:26.363
                            iobrokerTestsystem host.ioBrokerTestsystem instance system.adapter.admin.0 started with pid 26234
                            05 Feb 2022 12:09:26.110
                            iobrokerTestsystem host.ioBrokerTestsystem starting 29 instances
                            05 Feb 2022 12:09:25.968
                            iobrokerTestsystem host.ioBrokerTestsystem 58 instances found
                            05 Feb 2022 12:09:24.957
                            iobrokerTestsystem host.ioBrokerTestsystem added notifications configuration of host
                            05 Feb 2022 12:09:24.923
                            iobrokerTestsystem host.ioBrokerTestsystem connected to Objects and States
                            05 Feb 2022 12:09:23.585
                            05 Feb 2022 12:09:22.215
                            iobrokerTestsystem host.ioBrokerTestsystem ip addresses: 192.168.178.77 fe80::f854:cfff:fe5f:6c25
                            05 Feb 2022 12:09:22.212
                            iobrokerTestsystem host.ioBrokerTestsystem hostname: ioBrokerTestsystem, node: v14.19.0
                            05 Feb 2022 12:09:22.210
                            iobrokerTestsystem host.ioBrokerTestsystem Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                            05 Feb 2022 12:09:22.204
                            iobrokerTestsystem host.ioBrokerTestsystem iobroker.js-controller version 4.0.3 js-controller starting
                            05 Feb 2022 12:09:18.668
                            05 Feb 2022 12:09:18.576
                            iobrokerTestsystemSlave host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                            05 Feb 2022 12:09:13.660
                            05 Feb 2022 12:09:13.569
                            • MalleRalleM
                              MalleRalleM
                              MalleRalle
                              #187
                              Hier mit der 4.0.3 auch alles ordentlich durchgelaufen.
                                @apollon77
                                Vollständiges Log:
                                apollon77A
                                apollon77A
                                #188
                                @feuersturm aber danach tat alles oder? Mach auch mal issue. Schauen wir uns an.
                                  L
                                  L
                                  lonsimbt
                                  #189
                                  @foxriver76 sagte in Alpha Test js-controller 4.0:
                                  Doch sind beide installiert und haben Instanzen, sind zzt. aber pausiert, weil zzt. leider noch kein Mähroboter noch Gartenbewässerungssaison ist.
                                  iobroker im Container (debian Bullseye) unter proxmox 7.1
                                  debmatic in VM (debian Buster) unter proxmox 7.1 mit HB-RF-USB und RPI-RF-MOD
                                  40 HomeMatic Geräte, Phillips Hue, Ikea Tradfri, Logitech Harmony Hub, Botvac Connected, Robonect
                                  • L lonsimbt
                                    foxriver76F
                                    foxriver76F
                                    foxriver76
                                    #190
                                    @lonsimbt dann mal die beiden Adapter uploaden, dann sollten die Objekte erstellt werden.
                                    Videotutorials & mehr
                                    • wendy2702W
                                      wendy2702W
                                      #191
                                      @apollon77 @foxriver76 : 4.03 auf Master und beiden Slaves installiert.
                                      Master lief diesmal ohne die Access error durch.
                                      Auf einem Slave wo unter anderem der Smartmeter Adapter (Serialport) läuft sieht das log so aus:
                                      pi@pi-iobroker:/opt/iobroker $ npm i iobroker.js-controller@next
                                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                      > node-gyp rebuild
                                      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                                      ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                      ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                      In file included from ../../nan/nan.h:54,
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                                      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                                      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                                      > serialport@6.2.2 install /opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport
                                      > prebuild-install || node-gyp rebuild
                                      prebuild-install WARN install No prebuilt binaries found (target=14.19.0 runtime=node arch=arm platform=linux)
                                      make: Verzeichnis „/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/build“ wird betreten
                                       CXX(target) Release/obj.target/serialport/src/serialport.o
                                      In file included from ../src/./serialport.h:6,
                                                      from ../src/serialport.cpp:1:
                                      ../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                      ../../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
                                        v8::String::Utf8Value path(info[0]->ToString());
                                      In file included from /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:67,
                                                      from ../../../../nan/nan.h:54,
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:2810:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’
                                        V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:2810:44: note:   candidate expects 1 argument, 0 provided
                                      ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
                                        v8::Local<v8::Object> options = info[1]->ToObject();
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:2822:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’
                                        V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:2822:44: note:   candidate expects 1 argument, 0 provided
                                      ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                        uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                                      ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
                                      ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                        data->callback.Call(2, argv);
                                      ../../../../nan/nan.h:1740:3: note: declared here
                                        Call(int argc, v8::Local<v8::Value> argv[]) const {
                                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
                                      ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                        uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                                      ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
                                      ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                        data->callback.Call(1, argv);
                                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                        uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                                      ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
                                      ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                        uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                                      ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
                                      ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
                                      ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                        uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                                      ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
                                      ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                        uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                                      ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
                                      ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                                          results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3670:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
                                        V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3670:37: note:   candidate expects 3 arguments, 2 provided
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3673:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
                                        V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3673:37: note:   candidate expects 3 arguments, 2 provided
                                      ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                                          results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
                                      ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                                          results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
                                      ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                        uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                                      ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
                                      ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
                                          results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
                                      ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                        uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                                      ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
                                      ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                                      ../src/serialport.cpp: At global scope:
                                      ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                                      SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                                      ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                                      SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                                      ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
                                        void init(v8::Handle<v8::Object> target) {
                                      ../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’
                                      ../src/serialport.cpp:460:17: note: suggested alternative: ‘JobHandle’
                                                      JobHandle
                                      ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
                                      ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
                                      ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’
        tzset
                                      In file included from ../../../../nan/nan.h:54,
                                      ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
                                      NODE_MODULE(serialport, init);
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:36: note: in definition of macro ‘NODE_MODULE_X’
                                      ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
                                      ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’
                                      make: *** [serialport.target.mk:112: Release/obj.target/serialport/src/serialport.o] Fehler 1
                                      make: Verzeichnis „/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/build“ wird verlassen
                                      gyp ERR! build error
                                      gyp ERR! stack Error: `make` failed with exit code: 2
                                      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                      gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                                      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
                                      gyp ERR! System Linux 5.10.63-v7+
                                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                      gyp ERR! cwd /opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport
                                      gyp ERR! node -v v14.19.0
                                      gyp ERR! node-gyp -v v5.1.0
                                      gyp ERR! not ok
                                       "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\nMIIEogIBAAKxxxxxxTg7QV0OQyys=\r\n-----END RSA PRIVATE KEY-----\r\n",
                                       "defaultPublic": "-----BEGIN CERTIFICATE-----\r\nMIIDhxxxxVq+7jnSy02opY\r\n-----END CERTIFICATE-----\r\n"
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/@iobroker/js-controller-cli/node_modules/chokidar/node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 (node_modules/smartmeter-obis/node_modules/serialport):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                      updated 14 packages in 237.614s
                                      60 packages are looking for funding
                                      HIer mal zwei Auszüge:
                                      und
                                      gyp ERR! not ok
                                      Empfehlungen?
                                      Was/kann/muss ich machen damit das Forum hier nicht "Github" issues verlinkt ?
                                      • wendy2702W wendy2702
                                        > node-gyp rebuild
                                                        JobHandle
        tzset
                                        gyp ERR! not ok
                                        und
                                        gyp ERR! not ok
                                        Empfehlungen?
                                        apollon77A
                                        apollon77A
                                        #192
                                        @wendy2702 Im ersten schritt siehe oben: Alles ok, sind die üblichen Warnungen und Infos. Ignore
                                        • apollon77A
                                          apollon77A
                                          #193
                                          Hallo liebe Alpha-Tester,
                                          ich (auch im Nahmen der anderen Beteiligten Core-Entwickler) bedanke mich vielmals für Eure Unterstützung beim Alpha Test bisher. Die 4.0.3 ist sehr gut (wir haben noch 2 Optimierungen in Edge Cases bei Multihost Environments, aber das blockiert einen Beta Release nicht wirklich) :-)
                                          Falls wir doch nochmals größere Fixes haben würde ich ggf hier nochmal posten, aber generell sollte es jetzt unter https://forum.iobroker.net/topic/52208/js-controller-4-0-jetzt-im-beta-latest weitergehen.
                                          Ingo
                                          33.2k
                                          84.4k
