  4. Alpha Test js-controller 4.0
    apollon77A
196 Beiträge 20 Kommentatoren 42.3k Aufrufe 22 Beobachtet
  • wendy2702W
    wendy2702W
    #91
    Habe das bei der Installation auf dem Master bekommen:
    mirko@iobroker:/opt/iobroker$ sudo npm i iobroker.js-controller@next
    [sudo] password for mirko:
    > iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.16
    > iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
    Uncaught Rejection: Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
        at Object.mkdirSync (fs.js:1013:3)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:1012:16)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:567:23)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3316:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
        at Module._compile (internal/modules/cjs/loader.js:1085:14)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
        at Module.load (internal/modules/cjs/loader.js:950:32)
        at Function.Module._load (internal/modules/cjs/loader.js:790:12)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/iobroker.js2fs/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 6
    npm ERR! iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 install: `node iobroker.js setup first`
    npm ERR! Exit status 6
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 install script.
    npm ERR!     /root/.npm/_logs/2022-02-03T15_47_09_558Z-debug.log
    Hier noch das NPM log
    IOB startet nicht mehr
    Thomas BraunT apollon77A 2 Antworten Letzte Antwort
    • wendy2702W wendy2702
      npm ERR! errno 6
      npm ERR!
      Thomas BraunT
      Thomas BraunT
      #92
      @wendy2702 sagte in Alpha Test js-controller 4.0:
      sudo npm
      Nich mit sudo rummachen an der Stelle.
        sudo npm
        wendy2702W
        wendy2702W
        #93
        @thomas-braun Beim ersten Versuch nur zugriffsrechte verweigert meldungen bekommen.
        Deshalb der Versuch mit sudo.
        Erstmal zurück auf JS3.3.22 ohne erfolg. Musste den JS mit
        sudo -H -u iobroker npm install iobroker.js-controller
        neu installieren.
        Dann den fixer nochmal laufen lassen.
        mirko@iobroker:/opt/iobroker$ iob fix
        library: loaded
        Library version=2021-12-27
            Welcome to the ioBroker installation fixer!
            Script version: 2021-12-27
            You might need to enter your password a couple of times.
            Installing prerequisites (1/3)
        Hit:1 http://security.debian.org buster/updates InRelease
        Hit:2 http://ftp.debian.org/debian buster InRelease
        Hit:3 http://ftp.debian.org/debian buster-updates InRelease
        Hit:4 https://deb.nodesource.com/node_10.x buster InRelease
        Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
        Hit:6 https://deb.nodesource.com/node_14.x buster InRelease
        Reading package lists... Done
        Installed gcc-c++
            Checking ioBroker user and directory permissions (2/3)
            Checking autostart (3/3)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        JS4 erneut versucht:
        mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/fs-extra
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/fs-extra
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/alcalzone-shared
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@peter-murray/hue-bridge-model
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/bottleneck
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-script
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/eyes
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ftp-response-parser/node_modules/isarray
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ftp-response-parser/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/has
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ftp-response-parser/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsftp/node_modules/debug
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/luxon
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/nan
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-listing
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/psl
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/qs
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/form-data
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/sax
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/through
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-combiner
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr46
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/unorm
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/node_modules/core-util-is
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/vm2
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/webidl-conversions
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/whatwg-url
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-fetch
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlbuilder
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr-064/node_modules/xml2js
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-ssh
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs-parser
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules/safe-stable-stringify
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ncp
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/node-forge
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pidusage
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/safe-stable-stringify
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/seq-logging
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-redis
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-redis
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-file
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-jsonl
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js2fs/node_modules
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules
        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-seq-updated
        npm ERR! code EACCES
        npm ERR! syscall access
        npm ERR! path /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra'
        npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra'] {
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra'
        npm ERR! }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/mirko/.npm/_logs/2022-02-03T16_17_51_143Z-debug.log
        Und jetzt?
        Nach neustart von IOB sehe ich im Syslog davon tausende Einträge:
        iobroker bash[4117]: Using TZID without Luxon available is unsupported. Returned times are in UTC, not the requested time zone
          neu installieren.
          library: loaded
          Installed gcc-c++
          Autostart enabled!
          npm ERR! errno -13
          npm ERR! }
          npm ERR!
          npm ERR!
          Und jetzt?
          Thomas BraunT
          Thomas BraunT
          #94
          Dann musst du schauen, warum da Rechte fehlen. Der mirko ist in der Gruppe iobroker drin?
          Wie sehen die Rechte an den angemeckerten Verzeichnissen aus?
          Dateisystem fit?
          dmesg -T | grep -i ext4
          https://github.com/ioBroker/ioBroker.js-controller/issues/1528
          -1
            Dateisystem fit?
            wendy2702W
            wendy2702W
            #95
            @thomas-braun Naja,
            der mirko hat bisher immer die JS Controller Updates machen dürfen. 😊
            mirko@iobroker:/opt/iobroker$ cat /etc/group |grep iob
            tty:x:5:iobroker
            dialout:x:20:iobroker
            audio:x:29:iobroker
            video:x:44:iobroker
            iobroker:x:1000:mirko
            mirko@iobroker:/opt/iobroker$ id mirko
            uid=1001(mirko) gid=1001(mirko) groups=1001(mirko),27(sudo),1000(iobroker)
            drwxrwxr-x+ 979 iobroker iobroker  36864 Feb  3 17:07 node_modules
            Auch alle Unterverzeichnisse gehören iobroker.
            Filesystem schaut gut aus:
            mirko@iobroker:/opt/iobroker$ dmesg -T | grep -i ext4
            [Wed Aug  4 10:04:27 2021] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 10:04:27 2021] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
            [Wed Aug  4 10:04:40 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 10:04:43 2021] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 10:04:49 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 10:04:49 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 10:04:55 2021] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 10:05:06 2021] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 12:51:38 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 12:51:38 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 12:57:37 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 12:57:37 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 13:01:58 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 13:01:58 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 13:03:38 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 13:03:38 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 13:10:24 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 13:10:24 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 14:16:43 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 14:16:43 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 14:23:39 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 14:23:39 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 14:45:22 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 14:45:22 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 14:53:28 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 14:53:29 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 15:04:40 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 15:04:40 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 17:25:45 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 17:25:45 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 17:32:41 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug  4 17:32:41 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 19:24:50 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 19:24:50 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 19:36:55 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 19:36:55 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 20:56:55 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 20:58:11 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:05:56 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:05:56 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:08:02 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:08:02 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:08:41 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:08:41 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:12:36 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:18:56 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:24:56 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:26:31 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:27:59 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:28:57 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:28:57 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:36:21 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:44:17 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:48:09 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 16 21:48:09 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug 18 12:24:08 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug 18 12:34:10 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug 18 15:48:18 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug 18 16:15:41 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 23 08:42:39 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Aug 23 08:55:55 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 08:51:25 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 08:51:48 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 08:53:00 2021] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 08:54:55 2021] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 08:56:17 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 09:10:03 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 09:11:15 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 09:36:36 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 09:43:41 2021] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 09:44:47 2021] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 09:48:19 2021] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 09:48:48 2021] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 10:24:08 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 10:35:12 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 10:35:55 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Dec 15 10:39:25 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
            [Thu Dec 16 14:21:32 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
            [Thu Jan 27 18:13:36 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
            [Sat Jan 29 15:05:48 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
            [Thu Feb  3 16:42:25 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
            [Thu Feb  3 16:43:57 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
            [Thu Feb  3 16:58:03 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
            Noch eine Idee woran es liegen könnte?
            • apollon77A apollon77
              @fortune95 Legst Du dann bitte 4 GitHub issues an? ;-)) (bzw 3 weil ich glaube shelly gibts schon)
              F
              F
              Fortune95
              #96
              @apollon77 sagte in Alpha Test js-controller 4.0:
              Done! :-)
                @thomas-braun Naja,
                tty:x:5:iobroker
                audio:x:29:iobroker
                video:x:44:iobroker
                Thomas BraunT
                Thomas BraunT
                #97
                An der Uptime... :-P
                Der rennt seit 04. August durch?
                Ist das was gedockertes? EXT4-fs (dm-6) schaut so ungewohnt aus.
                  wendy2702W
                  wendy2702W
                  #98
                  @thomas-braun sagte in Alpha Test js-controller 4.0:
                  An der Uptime...
                  Ja.... wie ein Käfer.... der läuft und läuft....
                  Ist ein LXC im Proxmox
                    npm ERR! errno 6
                    npm ERR!
                    apollon77A
                    apollon77A
                    #99
                    @wendy2702 "iob fix" und ja ohne sudo :-) (eigentlich wie immer und wie es in der Anleitung steht gg)
                      wendy2702W
                      wendy2702W
                      #100
                      @apollon77 Ja,
                      genau das habe ich ja beim zweiten Versuch gemacht und hier beschrieben:
                      https://forum.iobroker.net/post/755201
                      hat aber trotzdem nicht geklappt.
                        @apollon77 Ja,
                        apollon77A
                        apollon77A
                        #101
                        @wendy2702 Ja, hatte ich danach auch gesehen :-)) und das finde ich mega interessant weil "iob fix" an sich das alles glatt ziehen sollte. zeig mal "ls -la" von so einem der angemeckerten Verzeichnisse, vllt sieht man ja was.
                        Ansonsten (wenn keinem sonst mehr was einfällt) wäre ich bei nem krassen neustart "node_modules löschen", controller manuell installieren, starten ... dann installiert der alle adapter neu
                        wendy2702W 2 Antworten Letzte Antwort
                          wendy2702W
                          wendy2702W
                          #102
                          @apollon77 Hier mal ein Beispiel:
                          mirko@iobroker:/opt/iobroker$ ls -la /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                          total 836
                          drwxrwxr-x+ 3 iobroker iobroker   4096 Feb  3 18:09 .
                          drwxrwxr-x+ 4 iobroker iobroker   4096 Feb  3 18:09 ..
                          -rwxr-xr-x+ 1 iobroker iobroker   1141 Feb  1 09:31 LICENSE
                          -rwxr-xr-x+ 1 iobroker iobroker   2591 Feb  1 09:31 README.md
                          -rwxr-xr-x+ 1 iobroker iobroker   5724 Feb  1 09:31 assert.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   9784 Feb  1 09:31 async_hooks.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   3097 Feb  1 09:31 buffer.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  26012 Feb  1 09:31 child_process.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  16301 Feb  1 09:31 cluster.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   6218 Feb  1 09:31 console.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker    598 Feb  1 09:31 constants.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  47240 Feb  1 09:31 crypto.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   7371 Feb  1 09:31 dgram.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  16763 Feb  1 09:31 dns.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker    778 Feb  1 09:31 domain.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   3477 Feb  1 09:31 events.d.ts
                          drwxr-xr-x+ 2 iobroker iobroker   4096 Feb  3 18:09 fs
                          -rwxr-xr-x+ 1 iobroker iobroker 121480 Feb  1 09:31 fs.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  25191 Feb  1 09:31 globals.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker     55 Feb  1 09:31 globals.global.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  25681 Feb  1 09:31 http.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  57454 Feb  1 09:31 http2.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  11799 Feb  1 09:31 https.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   4743 Feb  1 09:31 index.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker 123902 Feb  1 09:31 inspector.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   1736 Feb  1 09:31 module.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  13923 Feb  1 09:31 net.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   8231 Feb  1 09:31 os.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   5135 Feb  3 18:09 package.json
                          -rwxr-xr-x+ 1 iobroker iobroker   6454 Feb  1 09:31 path.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  10735 Feb  1 09:31 perf_hooks.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  20658 Feb  1 09:31 process.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   3535 Feb  1 09:31 punycode.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   1157 Feb  1 09:31 querystring.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   7599 Feb  1 09:31 readline.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  18337 Feb  1 09:31 repl.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  19743 Feb  1 09:31 stream.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker    270 Feb  1 09:31 string_decoder.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker    889 Feb  1 09:31 timers.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  38658 Feb  1 09:31 tls.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   2186 Feb  1 09:31 trace_events.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   2497 Feb  1 09:31 tty.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   5490 Feb  1 09:31 url.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  13112 Feb  1 09:31 util.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   6822 Feb  1 09:31 v8.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   6508 Feb  1 09:31 vm.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker   3520 Feb  1 09:31 wasi.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  11705 Feb  1 09:31 worker_threads.d.ts
                          -rwxr-xr-x+ 1 iobroker iobroker  14576 Feb  1 09:31 zlib.d.ts
                          Wenn sonst nichts einfällt wird es wohl der Holzhammer werden...
                            total 836
                            apollon77A
                            apollon77A
                            #103
                            Schaut bei mir genauso aus
                              wendy2702W
                              wendy2702W
                              #104
                              @apollon77 Das ist nur der Master.....
                              habe gerade ein wenig respekt wenn ich an meine Slaves denke wegen dem Holzhammer
                                Thomas BraunT
                                Thomas BraunT
                                #105
                                @wendy2702
                                Da sind ACLs drauf.
                                Schau mal mit
                                getfacl /Pfad/zu/einer/meckerdatei
                                Was da noch dranhängt
                                  @wendy2702
                                  Da sind ACLs drauf.
                                  Schau mal mit
                                  wendy2702W
                                  wendy2702W
                                  #106
                                  getfacl
                                  Das hier z.B.:
                                  mirko@iobroker:/opt/iobroker$ getfacl /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                                  getfacl: Removing leading '/' from absolute path names
                                  # file: opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                                  # owner: iobroker
                                  # group: iobroker
                                  user::rwx
                                  group::r-x
                                  group:iobroker:rwx
                                  mask::rwx
                                  other::r-x
                                  default:user::rwx
                                  default:group::r-x
                                  default:group:iobroker:rwx
                                  default:mask::rwx
                                  default:other::r-x
                                  Sehe da auf Anhieb nichts verdächtiges.... bin aber mit einem Auge noch in einem Online Training
                                    Nur der iobroker.parcel-Adapter muss bei jedem update des controllers neugebaut werden.
                                    Das wäre aber interessant warum das so ist. Was bringt der als Fehler? Läuft der renbuild machenaismus an?
                                    Thomas BraunT
                                    Thomas BraunT
                                    #107
                                    Hier das Log dazu:
                                    2022-02-03 15:24:15.366  - info: host.chet instance system.adapter.parcel.0 started with pid 66699
                                    2022-02-03 15:24:15.411  - info: miio.0 (66537) discover stoped after 30 seconds.
                                    2022-02-03 15:24:16.645  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                    2022-02-03 15:24:16.645  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]:                  ^
                                    2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                    2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                    2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                    2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                    2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                    2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                    2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                    2022-02-03 15:24:16.648  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                    2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                    2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                    2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                    2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                    2022-02-03 15:24:16.650  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                    2022-02-03 15:24:16.650  - error: host.chet Caught by controller[0]: }
                                    2022-02-03 15:24:16.650  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2022-02-03 15:24:16.651  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                                    2022-02-03 15:24:16.655  - info: host.chet system.adapter.parcel.0 will be rebuilt
                                    2022-02-03 15:24:16.656  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                    2022-02-03 15:24:16.656  - info: host.chet iobroker rebuild
                                    2022-02-03 15:24:17.635  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                    2022-02-03 15:25:05.335  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                    2022-02-03 15:25:05.370  - info: host.chet iobroker npm-rebuild:
                                    2022-02-03 15:25:05.371  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                    2022-02-03 15:25:06.387  - info: host.chet iobroker npm-rebuild: exit 0
                                    2022-02-03 15:25:06.542  - info: host.chet instance system.adapter.parcel.0 started with pid 67346
                                    2022-02-03 15:25:07.862  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                    2022-02-03 15:25:07.863  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]:                  ^
                                    2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                    2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                    2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                    2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                    2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                    2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                    2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                    2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                    2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                    2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                    2022-02-03 15:25:07.873  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                    2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                    2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                    2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]: }
                                    2022-02-03 15:25:07.874  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2022-02-03 15:25:07.875  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                                    2022-02-03 15:25:07.878  - info: host.chet system.adapter.parcel.0 will be rebuilt
                                    2022-02-03 15:25:07.878  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                    2022-02-03 15:25:07.879  - info: host.chet iobroker rebuild
                                    2022-02-03 15:25:08.977  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                    2022-02-03 15:25:50.623  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                    2022-02-03 15:25:50.666  - info: host.chet iobroker npm-rebuild:
                                    2022-02-03 15:25:50.667  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                    2022-02-03 15:25:51.687  - info: host.chet iobroker npm-rebuild: exit 0
                                    2022-02-03 15:25:51.839  - info: host.chet instance system.adapter.parcel.0 started with pid 67981
                                    2022-02-03 15:25:53.048  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                    2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]:                  ^
                                    2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2022-02-03 15:25:53.050  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                    2022-02-03 15:25:53.050  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                    2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                    2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                    2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                    2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                    2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                    2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                    2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]: }
                                    2022-02-03 15:25:53.054  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2022-02-03 15:25:53.054  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                                    2022-02-03 15:25:53.054  - info: host.chet system.adapter.parcel.0 will be rebuilt
                                    2022-02-03 15:25:53.055  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                    2022-02-03 15:25:53.055  - info: host.chet iobroker rebuild
                                    2022-02-03 15:25:54.004  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                    2022-02-03 15:26:35.390  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                    2022-02-03 15:26:35.433  - info: host.chet iobroker npm-rebuild:
                                    2022-02-03 15:26:35.434  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                    2022-02-03 15:26:36.447  - info: host.chet iobroker npm-rebuild: exit 0
                                    2022-02-03 15:26:36.588  - info: host.chet instance system.adapter.parcel.0 started with pid 68611
                                    2022-02-03 15:26:37.838  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                    2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]:                  ^
                                    2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2022-02-03 15:26:37.840  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                    2022-02-03 15:26:37.841  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                    2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                    2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                    2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                    2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                    2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                    2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                    2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2022-02-03 15:26:37.844  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                    2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                    2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                    2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                    2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                    2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]: }
                                    2022-02-03 15:26:37.846  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2022-02-03 15:26:37.846  - info: host.chet Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                    habe ich dann gemacht, danach ging der iobroker.parcel.0 auch. Hat aber eher mit canvas zu tun, wenn ich das richtig sehe.
                                      getfacl
                                      Das hier z.B.:
                                      # owner: iobroker
                                      # group: iobroker
                                      user::rwx
                                      group::r-x
                                      group:iobroker:rwx
                                      mask::rwx
                                      other::r-x
                                      default:user::rwx
                                      default:group::r-x
                                      default:mask::rwx
                                      default:other::r-x
                                      apollon77A
                                      apollon77A
                                      #108
                                      mine
                                        mine
                                        wendy2702W
                                        wendy2702W
                                        #109
                                        @apollon77 Arrrgghhhhh.... Ein Screenshot :-)
                                        Sieht aber aus wie bei mir.
                                          Thomas BraunT
                                          Thomas BraunT
                                          #110
                                          @wendy2702
                                          mount | sort
                                          Ich frag mich noch was das für ein komisches mount da bei dir immer ist.
                                          Aber Container... :-(
                                          83.9k
