  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 503.5k Aufrufe 82 Beobachtet
  • DiginixD Offline
    DiginixD Offline
    Diginix
    #692
    v3.3.4 ist bei mir heute abgestürzt als ich über den mihome-vacuum.0.rooms.***.roomClean Button einen weiteren Raum zum Queue hinzufügen wollte während er bereits einen saugte.
    Loglevel der Instanz ist warn, daher nur das aus dem Log:
    2022-01-27 14:10:50.738 - error: mihome-vacuum.0 (1148) uncaught exception: Cannot read property 'body' of undefined
    2022-01-27 14:10:50.748 - error: mihome-vacuum.0 (1148) TypeError: Cannot read property 'body' of undefined
    at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:454:68)
    at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    at Request.emit (events.js:400:28)
    at Request.emit (domain.js:475:12)
    at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
    at ClientRequest.emit (events.js:412:35)
    at ClientRequest.emit (domain.js:475:12)
    at TLSSocket.socketErrorListener (_http_client.js:475:9)
    at TLSSocket.emit (events.js:400:28)
    at TLSSocket.emit (domain.js:475:12)
    2022-01-27 14:10:50.749 - error: mihome-vacuum.0 (1148) Cannot read property 'body' of undefined
    2022-01-27 14:10:50.763 - error: mihome-vacuum.0 (1148) Socket Close
    2022-01-27 14:10:50.765 - warn: mihome-vacuum.0 (1148) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-01-27 14:10:51.364 - error: host.iobroker Caught by controller[0]: TypeError: Cannot read property 'body' of undefined
    2022-01-27 14:10:51.371 - error: host.iobroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:454:68)
    2022-01-27 14:10:51.371 - error: host.iobroker Caught by controller[0]: at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    2022-01-27 14:10:51.372 - error: host.iobroker Caught by controller[0]: at Request.emit (events.js:400:28)
    2022-01-27 14:10:51.372 - error: host.iobroker Caught by controller[0]: at Request.emit (domain.js:475:12)
    2022-01-27 14:10:51.372 - error: host.iobroker Caught by controller[0]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
    2022-01-27 14:10:51.372 - error: host.iobroker Caught by controller[0]: at ClientRequest.emit (events.js:412:35)
    2022-01-27 14:10:51.372 - error: host.iobroker Caught by controller[0]: at ClientRequest.emit (domain.js:475:12)
    2022-01-27 14:10:51.372 - error: host.iobroker Caught by controller[0]: at TLSSocket.socketErrorListener (_http_client.js:475:9)
    2022-01-27 14:10:51.372 - error: host.iobroker Caught by controller[0]: at TLSSocket.emit (events.js:400:28)
    2022-01-27 14:10:51.372 - error: host.iobroker Caught by controller[0]: at TLSSocket.emit (domain.js:475:12)
    2022-01-27 14:10:51.372 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    ..:: So long! Tom ::..
    • DiginixD Diginix
      D Nicht stören
      D Nicht stören
      dirkhe
      #693
      @diginix das können wir noch abfangen, aber das Problem scheint mit dem Netzwerk zu tun zu haben, da ist das socket geschlossen worden. Könntest du evtl ein issue aufmachen?
      • D dirkhe
        DiginixD Offline
        DiginixD Offline
        Diginix
        #694
        @dirkhe Erledigt: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/497
        • F freaktech
          Hallo Leute!
          War länger nicht hier, ich hab nun bemerkt dasss ein längerer Zeit mit S5 die MAP nicht mehr aktualisiert
          Adapter ist grün, es geht auch alles andere an anzeigen und Kommandos nur bei der Karte passiert nichts mehr
          das war mal mit Hilfe von euch eingerichtet :-)
          sollte da nicht ein neuerer Datumsstempel sein ?
          evtl hat auch einer von euch mal 5 min zeit und kann sich das gern remote ansehen ich kapiers aktuell echt nicht wieso das nicht mehr geht
          FW ist 3.5.8_1566
          danke
          tom Bastler bei dem es beim programmieren dann schnell mal aneckt :-) habe rmotiviert
          D3ltoroxpD Offline
          D3ltoroxpD Offline
          D3ltoroxp
          #695
          @freaktech Versuch mal den Adapter in der Version 3.3.3 aus dem Latest, damit gings bei den meisten / allen wieder.
          L 1 Antwort Letzte Antwort
          • D3ltoroxpD D3ltoroxp
            LordLolo
            #696
            Hallo Zusammen,
            ich habe hier schon viel gelesen, aber irgendwie habe ich scheinbar ein Brett vor dem Kopf.
            Könnt Ihr mir nochmal auf die Sprünge helfen mit dem MultiRoomClean? Ich habe alle Räume in IOBroker angelegt und mit den entsprechenden Channels verknüpft.
            Und wie bekomme ich das jetzt auf die VIS, so dass ich die zu reinigenden Räume vorwählen und dann nur auf Start drücken brauche?
            Außerdem habe ich noch ein Problem mit dem Pause.Resume Switch. Diesen habe ich versucht mit dem HTML Bool true/False Widget zu triggern. Leider ohne Erfolg. Muss ich hierfür zwingend die Buttons Start und Pause nutzen? Wenn ja, welchen Button nehme ich hierfür am Besten?
            • L LordLolo
              Hallo Zusammen,
              saeft_2003
              #697
              @lordlolo
              Wenn du willst kannst du einfach mein view nehmen da sollte sich alles von alleine erklären.
              https://forum.iobroker.net/topic/35027/zeigt-her-eure-views-zum-thema-saugroboter-xiaomi/132?_=1643445855039
              • S saeft_2003
                @lordlolo
                LordLolo
                #698
                @saeft_2003
                Hey, das sieht ja mal cool aus! Ich schau mal ob ich damit klarkomme. Hab noch nicht so viel Erfahrung mit der VIS, da ich bis jetzt alles mit Jarvis gemacht habe.
                Besten Dank schon mal, das ist wirklich nett!
                  Krys
                  #699
                  mihome-vacuum.0
                  2022-01-30 15:14:36.959	info	create state for carpet_mode
                  mihome-vacuum.0
                  2022-01-30 15:14:35.976	info	create states for mop
                  mihome-vacuum.0
                  2022-01-30 15:14:35.969	info	create states for water box mode
                  mihome-vacuum.0
                  2022-01-30 15:14:35.961	info	create states for water box
                  mihome-vacuum.0
                  2022-01-30 15:14:35.932	info	change states from State control.fan_power
                  mihome-vacuum.0
                  2022-01-30 15:14:35.906	info	Map selected create states...
                  mihome-vacuum.0
                  2022-01-30 15:14:35.505	info	settest next timer: not available
                  mihome-vacuum.0
                  2022-01-30 15:14:34.878	info	select standard vacuum protocol....
                  mihome-vacuum.0
                  2022-01-30 15:14:34.768	info	IOT enabled, create state
                  mihome-vacuum.0
                  2022-01-30 15:14:34.627	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                  mihome-vacuum.0
                  2022-01-30 14:27:50.738	info	create state for carpet_mode
                  mihome-vacuum.0
                  2022-01-30 14:27:49.837	info	create states for mop
                  mihome-vacuum.0
                  2022-01-30 14:27:49.834	info	create states for water box mode
                  mihome-vacuum.0
                  2022-01-30 14:27:49.831	info	create states for water box
                  mihome-vacuum.0
                  2022-01-30 14:27:49.816	info	change states from State control.fan_power
                  mihome-vacuum.0
                  2022-01-30 14:27:49.795	info	Map selected create states...
                  mihome-vacuum.0
                  2022-01-30 14:27:49.369	info	settest next timer: not available
                  mihome-vacuum.0
                  2022-01-30 14:27:48.759	info	select standard vacuum protocol....
                  mihome-vacuum.0
                  2022-01-30 14:27:48.630	info	IOT enabled, create state
                  mihome-vacuum.0
                  2022-01-30 14:27:48.490	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                  mihome-vacuum.0
                  2022-01-30 14:27:14.283	info	create states for mop
                  mihome-vacuum.0
                  2022-01-30 14:27:14.279	info	create states for water box mode
                  mihome-vacuum.0
                  2022-01-30 14:27:14.274	info	create states for water box
                  mihome-vacuum.0
                  2022-01-30 14:27:14.258	info	change states from State control.fan_power
                  mihome-vacuum.0
                  2022-01-30 14:26:44.162	info	create state for carpet_mode
                  mihome-vacuum.0
                  2022-01-30 14:23:37.379	info	Map selected create states...
                  mihome-vacuum.0
                  2022-01-30 14:23:37.213	info	settest next timer: not available
                  mihome-vacuum.0
                  2022-01-30 14:23:36.640	info	select standard vacuum protocol....
                  mihome-vacuum.0
                  2022-01-30 14:23:36.614	warn	No Answer for DeviceModel use model from Config
                  mihome-vacuum.0
                  2022-01-30 14:23:36.613	warn	No Answer for DeviceModel use old one
                  mihome-vacuum.0
                  2022-01-30 14:23:36.613	warn	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                  mihome-vacuum.0
                  2022-01-30 14:23:26.577	info	IOT enabled, create state
                  mihome-vacuum.0
                  2022-01-30 14:23:26.399	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                  mihome-vacuum.0
                  2022-01-30 14:22:38.169	info	create state for carpet_mode
                  mihome-vacuum.0
                  2022-01-30 14:22:34.696	info	create states for mop
                  mihome-vacuum.0
                  2022-01-30 14:22:34.692	info	create states for water box mode
                  mihome-vacuum.0
                  2022-01-30 14:22:34.688	info	create states for water box
                  mihome-vacuum.0
                  2022-01-30 14:22:34.669	info	change states from State control.fan_power
                  mihome-vacuum.0
                  2022-01-30 14:22:34.650	info	Map selected create states...
                  mihome-vacuum.0
                  2022-01-30 14:22:34.503	info	settest next timer: not available
                  mihome-vacuum.0
                  2022-01-30 14:22:33.821	info	select standard vacuum protocol....
                  mihome-vacuum.0
                  2022-01-30 14:22:33.718	info	IOT enabled, create state
                  mihome-vacuum.0
                  2022-01-30 14:22:33.553	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                  mihome-vacuum.0
                  2022-01-30 14:21:50.955	info	create states for mop
                  mihome-vacuum.0
                  2022-01-30 14:21:50.949	info	create states for water box mode
                  mihome-vacuum.0
                  2022-01-30 14:21:50.944	info	create states for water box
                  mihome-vacuum.0
                  2022-01-30 14:21:50.914	info	change states from State control.fan_power
                  mihome-vacuum.0
                  2022-01-30 14:21:20.795	info	create state for carpet_mode
                  mihome-vacuum.0
                  2022-01-30 14:16:49.335	info	Map selected create states...
                  mihome-vacuum.0
                  2022-01-30 14:16:49.212	info	settest next timer: not available
                  mihome-vacuum.0
                  2022-01-30 14:16:48.573	info	select standard vacuum protocol....
                  mihome-vacuum.0
                  2022-01-30 14:16:48.540	warn	No Answer for DeviceModel use model from Config
                  mihome-vacuum.0
                  2022-01-30 14:16:48.539	warn	No Answer for DeviceModel use old one
                  mihome-vacuum.0
                  2022-01-30 14:16:48.538	warn	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                  mihome-vacuum.0
                  2022-01-30 14:16:38.493	info	IOT enabled, create state
                  mihome-vacuum.0
                  2022-01-30 14:16:38.348	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                  mihome-vacuum.0
                  2022-01-30 14:16:02.648	info	create states for mop
                  mihome-vacuum.0
                  2022-01-30 14:16:02.635	info	create states for water box mode
                  mihome-vacuum.0
                  2022-01-30 14:16:02.621	info	create states for water box
                  mihome-vacuum.0
                  2022-01-30 14:16:02.574	info	change states from State control.fan_power
                  mihome-vacuum.0
                  2022-01-30 14:16:02.524	info	Map selected create states...
                  mihome-vacuum.0
                  2022-01-30 14:16:02.054	info	settest next timer: not available
                  mihome-vacuum.0
                  2022-01-30 14:16:01.312	info	select standard vacuum protocol....
                  mihome-vacuum.0
                  2022-01-30 14:16:01.148	info	IOT enabled, create state
                  mihome-vacuum.0
                  2022-01-30 14:16:00.898	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                  mihome-vacuum.0
                  2022-01-30 14:15:21.567	info	create states for mop
                  mihome-vacuum.0
                  2022-01-30 14:15:21.561	info	create states for water box mode
                  mihome-vacuum.0
                  2022-01-30 14:15:21.557	info	create states for water box
                  mihome-vacuum.0
                  2022-01-30 14:15:21.544	info	change states from State control.fan_power
                  mihome-vacuum.0
                  2022-01-30 14:14:51.421	info	create state for carpet_mode
                  mihome-vacuum.0
                  2022-01-30 14:14:03.065	info	Map selected create states...
                  mihome-vacuum.0
                  2022-01-30 14:14:02.912	info	settest next timer: not available
                  mihome-vacuum.0
                  2022-01-30 14:14:02.223	info	select standard vacuum protocol....
                  mihome-vacuum.0
                  2022-01-30 14:14:02.189	warn	No Answer for DeviceModel use model from Config
                  mihome-vacuum.0
                  2022-01-30 14:14:02.188	warn	No Answer for DeviceModel use old one
                  mihome-vacuum.0
                  2022-01-30 14:14:02.187	warn	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                  mihome-vacuum.0
                  2022-01-30 14:13:52.084	info	IOT enabled, create state
                  mihome-vacuum.0
                  2022-01-30 14:13:51.928	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                  mihome-vacuum.0
                  2022-01-30 14:13:17.086	info	create states for mop
                  mihome-vacuum.0
                  2022-01-30 14:13:17.083	info	create states for water box mode
                  mihome-vacuum.0
                  2022-01-30 14:13:17.080	info	create states for water box
                  mihome-vacuum.0
                  2022-01-30 14:13:17.064	info	change states from State control.fan_power
                  mihome-vacuum.0
                  2022-01-30 14:13:17.038	info	Map selected create states...
                  mihome-vacuum.0
                  2022-01-30 14:13:16.897	info	settest next timer: not available
                  mihome-vacuum.0
                  2022-01-30 14:13:16.295	info	select standard vacuum protocol....
                  mihome-vacuum.0
                  2022-01-30 14:13:16.183	info	IOT enabled, create state
                  mihome-vacuum.0
                  2022-01-30 14:13:16.036	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                  Hat noch jemand dasselbe Problem aktuell?
                  Node.js: v14.18.3
                  NPM: 6.14.16
                  Adapterversion: 3.3.4
                  RPI4 4GB
                  Roborock s5 Max, FW: 3.5.8_1566
                  Während der Sauger läuft, habe ich quasi einen "loop" an Neustart.
                  Ansonsten kann es mal sein, dass 4 Stunden nichts passiert und dann wieder 30 Neustarts in 10 Minuten.
                    Krys
                    #700
                    mihome-vacuum.0
                    2022-02-02 08:52:11.236	info	Map selected create states...
                    mihome-vacuum.0
                    2022-02-02 08:52:10.817	info	settest next timer: not available
                    mihome-vacuum.0
                    2022-02-02 08:52:10.177	info	select standard vacuum protocol....
                    mihome-vacuum.0
                    2022-02-02 08:52:10.151	warn	No Answer for DeviceModel use model from Config
                    mihome-vacuum.0
                    2022-02-02 08:52:10.151	warn	No Answer for DeviceModel use old one
                    mihome-vacuum.0
                    2022-02-02 08:52:10.150	warn	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                    mihome-vacuum.0
                    2022-02-02 08:52:00.060	info	IOT enabled, create state
                    mihome-vacuum.0
                    2022-02-02 08:51:59.904	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 3.3.22
                    host.raspberrypi
                    2022-02-02 08:51:56.841	info	instance system.adapter.mihome-vacuum.0 started with pid 21674
                    host.raspberrypi
                    2022-02-02 08:51:26.771	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                    host.raspberrypi
                    2022-02-02 08:51:26.770	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                    host.raspberrypi
                    2022-02-02 08:51:26.769	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGILL
                    host.raspberrypi
                    2022-02-02 08:51:26.768	error	Caught by controller[0]: #FailureMessage Object: 0xbe9c67e0
                    host.raspberrypi
                    host.raspberrypi
                    2022-02-02 08:51:26.767	error	Caught by controller[0]: #
                    host.raspberrypi
                    host.raspberrypi
                    2022-02-02 08:51:26.766	error	Caught by controller[0]: # Check failed: heap_->memory_allocator()->IsMemoryChunkExecutable(page).
                    host.raspberrypi
                    2022-02-02 08:51:26.766	error	Caught by controller[0]: # Fatal error in , line 0
                    host.raspberrypi
                    2022-02-02 08:51:26.759	error	Caught by controller[0]: #
                    mihome-vacuum.0
                    2022-02-02 08:50:12.336	info	create state for carpet_mode
                    mihome-vacuum.0
                    2022-02-02 08:50:09.525	warn	Object of state "mihome-vacuum.0.cleanmap.actualMap" is missing the required property "common.type"
                    mihome-vacuum.0
                    2022-02-02 08:50:09.464	info	create states for mop
                    mihome-vacuum.0
                    2022-02-02 08:50:09.460	info	create states for water box mode
                    mihome-vacuum.0
                    2022-02-02 08:50:09.455	info	create states for water box
                    mihome-vacuum.0
                    2022-02-02 08:50:09.430	info	change states from State control.fan_power
                    mihome-vacuum.0
                    2022-02-02 08:50:09.402	info	Map selected create states...
                    mihome-vacuum.0
                    2022-02-02 08:50:09.253	info	settest next timer: not available
                    mihome-vacuum.0
                    2022-02-02 08:50:08.619	info	select standard vacuum protocol....
                    mihome-vacuum.0
                    2022-02-02 08:50:08.500	info	IOT enabled, create state
                    mihome-vacuum.0
                    2022-02-02 08:50:08.321	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 3.3.22
                    host.raspberrypi
                    2022-02-02 08:50:05.065	info	instance system.adapter.mihome-vacuum.0 started with pid 20324
                    host.raspberrypi
                    2022-02-02 08:49:35.014	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                    host.raspberrypi
                    2022-02-02 08:49:35.014	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                    host.raspberrypi
                    2022-02-02 08:49:35.009	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
                    Ich bekomme es anscheinend nicht hin.
                    nodejs
                    v14.19.0
                    node
                    v14.19.0
                    npm
                    6.14.16
                    pi@raspberrypi:/opt/iobroker $ npm list canvas
                    iobroker.inst@2.0.3 /opt/iobroker
                    ├── canvas@2.9.0
                    ├─┬ iobroker.iot@1.8.24
                    │ └── canvas@2.9.0  deduped
                    └─┬ iobroker.mihome-vacuum@3.3.4 (github:iobroker-community-adapters/ioBroker.mihome-vacuum#881c0892d76cf4087b5c6247f67b0ba2a7ee34fd)
                    • D3ltoroxpD Offline
                      D3ltoroxpD Offline
                      D3ltoroxp
                      schrieb am zuletzt editiert von D3ltoroxp
                      #701
                      Könnte mir noch mal jemand helfen mit der Karte für die VIS. Und zwar hätte ich da gern die Map64 drin. Nur weiß ich nicht welches Widget und welcher Code da rein muss ? Mit der normalen Map über image Widget klappt es schon mal. Die Map 64 hätte ich aber gern, da sie flotter beim aktualisieren ist.
                      So wie es bei mir früher ging klappt es nicht mehr..
                      Basicl HTML Widget.
                      Mit dem Link aus der Beschreibung klappt es leider auch nicht.
                      Wenn ich das so eingebe
                      <img src="https://www.iobroker.net/zh-cn/adapterref/iobroker.mihome-vacuum/mihome-vacuum.0.cleanmap.map64">
                      passiert nichts im Basic HTML Widget. Liegt das vllt an zh-cn ? Da ich dort DE Server drin hab ? Hab aber auch schon mit de-de oder de-ger versucht. Das kann ich auch nicht verwenden oder weiß nicht wie und wo ?
                        Basicl HTML Widget.
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #702
                        @d3ltoroxp
                        https://forum.iobroker.net/topic/44077/test-adapter-mihome-vacuum-v3-1-6-next-generarition/681?page=35
                        Hast du denn den thread gelesen?
                        Fragst doch jetzt schon mehrmals, oder ?
                        Danke.
                        D3ltoroxpD 1 Antwort Letzte Antwort
                        • bahnuhrB bahnuhr
                          @d3ltoroxp
                          D3ltoroxpD Offline
                          D3ltoroxpD Offline
                          D3ltoroxp
                          #703
                          @bahnuhr Den hatte ich dann wohl leider übersehen. Ich wollte das jetzt noch mal angehen. Es funktioniert nun so auch wunderbar. Ausser in dem Editor, ich hatte das dann nie Live probiert, weil er im Editor immer das kaputte Image Zeichen angezeigt hat und beim anderen aber doch die Map.
                          Indem Fall sieht man das wohl im Editor nicht, aber in dem Browser mit der VIS sieht man es.
                          • gelberlemmyG Offline
                            gelberlemmy
                            #704
                            Guten morgen,
                            gibt es eigentlich in Workaround bezüglich des ständigen Absturzes des Adapters, wenn der Roborock S7 in Betrieb ist ? Konnte jetzt nicht wirklich etwas finden.
                            Gruß André
                            bahnuhrB K 2 Antworten Letzte Antwort
                            • gelberlemmyG gelberlemmy
                              Guten morgen,
                              Gruß André
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #705
                              @gelberlemmy sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                              Ich weiß auch nicht ob du da etwas findest.
                              Habe auch einen S7. Bei mir stürzt der Adapter nicht ab.
                              Danke.
                              gelberlemmyG 1 Antwort Letzte Antwort
                              • bahnuhrB bahnuhr
                                gelberlemmy
                                #706
                                @bahnuhr schau einmal hier. In Github ist dies bereits als Issue angelegt.
                                https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/487
                                So stellt sich mein Fehler da
                                  Guten morgen,
                                  Gruß André
                                  Krys
                                  #707
                                  @gelberlemmy bei mir dasselbe mit dem S5 Max. Logs hatte ich im Verlauf hier gepostet als auch auf git. Aber ansonsten habe ich mir auch mal die ganze Canvas/Node-Geschichte angeschaut und damit beschäftigt. Die Abstürze sind weniger geworden und tlw. "anders", daher vermute ich den Fehler auf meiner Seite.. Mal schauen.
                                    gelberlemmy
                                    #708
                                    Diesen folgen Log bekomme ich aktuell....
                                    mihome-vacuum.0
                                    2022-02-04 11:31:06.926	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                                    host.raspberrypi
                                    2022-02-04 11:31:04.100	info	instance system.adapter.mihome-vacuum.0 started with pid 6734
                                    host.raspberrypi
                                    2022-02-04 11:30:34.045	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                    host.raspberrypi
                                    2022-02-04 11:30:34.045	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                    host.raspberrypi
                                    2022-02-04 11:30:34.045	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                                    host.raspberrypi
                                    2022-02-04 11:30:34.044	error	Caught by controller[0]: corrupted double-linked list
                                    • MeistertrM Meistertr
                                      Aktuelle Test Version 3.1.6
                                      Veröffentlichungsdatum 18.4.2021
                                      Github Link https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum
                                      Lange hats gedauert aber langsam komm ich zum Ende (wobei das dann wahrscheinlich der Anfang ist :) ).
                                      Was hat sich geändert? Alles und nix kann kann man sagen.
                                      Der Adapter wurde komplett neu aufgesetzt und dem Aktuellen stand angepasst.
                                      vorher:
                                      • Nachrichten an den Roboter wurden willkürlich geschickt und gehofft das eine Antwort kommt.
                                      • Die Erkennung des Roboters (Modell und Marke und Firmware) wurden durch Ankommende Nachrichten oder das Ausbleiben erkannt
                                      • comact mode nicht möglich da zig Timeouts liefen
                                      • Keine neuen/anderen Sauger integrierbar da alles in einer Datei lag
                                      jetzt:
                                      • beim start wird zwingend das Modell ermittelt wonach dann die richtige Datei für den jeweiligen Sauger geladen wird
                                      • danach werden Strukturiert die Sonderfunktionen ermittelt und freigegeben
                                      • Nachrichten werden nicht mehr willkürlich gesendet sonders strukturiert und jede Nachricht bekommt eine Antwort
                                      • comact mode möglich da alle timer zentral gelagert sind
                                      ich habe mich bemüht die Objekte zum Vorgänger gleich zu lassen. also Optisch ist nicht viel neu aber wie gesagt unterm Kleid alles was man im debug log sehen sollte.
                                      ich habe noch nicht viele Sauger in der Datenbank also kann es zu warn log einträgen kommen, dann bitte modell und bezeichnung posten dann nehm ich sie mit rein.
                                      Bitte alles Testen da ich viel ohne Testen umgeschrieben habe (bei über 2000 Zeilen) konnte ich nicht alles direkt testen.
                                      Stand Aktuell:
                                      Jetzt sollte alles gehen was bei der 2er auch geht. und mehr
                                      Was sollte gehen:
                                      • alles wie beim alten außer die map (folgt in kürze)
                                      • viomi Modelle die sonst über meinen Fork liefen sind nun mit drin
                                      • support für den S7 (letztes update hat die History kaputt gemacht)
                                      • Map wir unterstützt
                                      Fixes:
                                      • Map bei zwei Saugern funtionieren
                                      • Map wird zuverlässig(er) geladen
                                      • 3.0.2 Manueller Map Reload Button funktionert
                                      • 3.0.4/ 3.0.7 Timer geht wieder
                                      • 3.0.5 Disable map_slot warning, add start button, fix error while sending messages without selected device, fix water_box value
                                      • 3.0.6 fix queue States, fix cleaning Buttons.
                                      • 3.0.8 fix map for Valetudo
                                      • 3.1.0 aktuelle Goto und Zones werden gespeichert
                                      • 3.1.1 fix queue
                                      • 3.1.3 Map bugfix, add Multimap Support
                                      • 3.1.3 fix missing Wifi Signal
                                      • 3.1.4 Fix Connrection after reboot/ now wifi
                                        3.1.6:
                                      • fixed Disk I/O
                                      • added get States when map is changed
                                      • minimize Messages
                                      • changed logentrys from warn to debug
                                      • added Donate button
                                      folgt in Kürze:
                                      - Koordinaten von goto und Zonen werden angezeigt (in den jeweiligen states)
                                      • dreame support über miot
                                      • compactmode
                                        - map
                                      • map für history
                                      • material tabel
                                      • led Status S7
                                      • neues Logo
                                      • Doku aufbereiten
                                      Installieren bitte über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum (einfach von git)
                                      Bitte Vorher den alten Adapter vollständig löschen.
                                      Dies ist die Alpha also BITTE nur installieren wenn ihr wisst was ihr macht und einen qualifizierten Bugreport liefern könnt
                                      Bitte in dieses Thema NUR Fehler oder Requests die den Adapter betreffen. KEINE Installationsfehler oder sonstige Fragen. macht dafür bitte wenn die Suche nichts ergeben hat ein neues Thema auf damit es hier nicht so überläuft wie in den alten Threads..
                                      gelberlemmy
                                      #709
                                      @meistertr und manchmal kommt dann das vom Host:
                                      host.raspberrypi
                                      2022-02-04 12:11:18.873	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGILL
                                      host.raspberrypi
                                      2022-02-04 12:11:18.873	error	Caught by controller[0]: #FailureMessage Object: 0xbe86f368
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      2022-02-04 12:11:18.872	error	Caught by controller[0]: #
                                      host.raspberrypi
                                      2022-02-04 12:11:18.872	error	Caught by controller[0]: # Check failed: !backing_store->is_wasm_memory().
                                      host.raspberrypi
                                      2022-02-04 12:11:18.872	error	Caught by controller[0]: # Fatal error in , line 0
                                      host.raspberrypi
                                      2022-02-04 12:11:18.871	error	Caught by controller[0]: #
                                        Krys
                                        #710
                                        host.raspberrypi
                                        2022-02-04 12:49:41.136	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                        host.raspberrypi
                                        2022-02-04 12:49:41.135	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                        host.raspberrypi
                                        2022-02-04 12:49:41.134	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGILL
                                        host.raspberrypi
                                        2022-02-04 12:49:41.133	error	Caught by controller[0]: #FailureMessage Object: 0xbee60368
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        2022-02-04 12:49:41.132	error	Caught by controller[0]: #
                                        host.raspberrypi
                                        2022-02-04 12:49:41.132	error	Caught by controller[0]: # Check failed: !backing_store->is_wasm_memory().
                                        host.raspberrypi
                                        2022-02-04 12:49:41.131	error	Caught by controller[0]: # Fatal error in , line 0
                                        host.raspberrypi
                                        2022-02-04 12:49:41.130	error	Caught by controller[0]: #
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.369	debug	Message= {"id":12,"method":"get_clean_record","params":[1643965653]}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.366	debug	MIIO RECIVE: {"result":[[1643974745,1643975104,359,5960000,0,1,2,3,56]],"id":11}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.343	debug	Message= {"id":11,"method":"get_clean_record","params":[1643974745]}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.338	debug	MIIO RECIVE: {"result":[42855,668652500,83,[1643974745,1643965653,1643905243,1643901690,1643887247,1643875796,1643805243,1643797070,1643788111,1643785174,1643732552,1643729608,1643720501,1643720432,1643720002,1643719895,1643719552,1643719448,1643719387,1643719142]],"id":10}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.322	debug	Message= {"id":10,"method":"get_clean_summary"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.318	debug	Startup: Delete getMultiMapsList
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.316	debug	Startup: getMultiMapsList Answer: true
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.312	debug	States for Map: {"0":"Werler Str. 235 "}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.309	debug	States for 1 Map: [{"mapFlag":0,"add_time":1643970960,"length":16,"name":"Werler Str. 235 ","bak_maps":[]}]
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.308	debug	MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1643970960,"length":16,"name":"Werler Str. 235 ","bak_maps":[]}]}],"id":9}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.288	debug	Message= {"id":9,"method":"get_multi_maps_list"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.286	debug	MIIO RECIVE: {"result":[30],"id":8}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.276	debug	Message= {"id":8,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.177	debug	update_Map got new time:1643975380
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.177	debug	update_Map got new expires:1643977180
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.176	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/9?Expires=1643977180000&GalaxyAccessKeyId=5271733786445&Signature=OYYaT6/vbGeka3qUsYZBe+2KGsU=
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.153	debug	update_Map got new time:1643975379
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.152	debug	update_Map got new expires:1643977180
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.151	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/9?Expires=1643977180000&GalaxyAccessKeyId=5271733786445&Signature=OYYaT6/vbGeka3qUsYZBe+2KGsU=
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.065	debug	MIIO RECIVE: {"result":{"ssid":"Krystian","ip":"192.168.178.58","mac":"b0:4a:39:13:19:dc","bssid":"00:5f:67:a3:93:84","rssi":-45},"id":7}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.041	debug	update_Map need new mapurl
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.040	debug	update_Map Mimap enabled
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.039	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.035	debug	MIIO RECIVE: {"result":["rubyslite%2F416082087%2F9"],"id":6}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.025	debug	Message= {"id":7,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.020	debug	Message= {"id":6,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:40.012	debug	MIIO RECIVE: {"result":[[16,"279001039807"],[17,"279001039878"],[18,"279001036128"],[19,"279001039845"],[20,"279001039844"],[21,"279001039841"],[22,"279001039842"]],"id":5}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.991	debug	Message= {"id":5,"method":"get_room_mapping"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.974	debug	update_Map need new mapurl
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.973	debug	update_Map Mimap enabled
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.970	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.968	debug	MIIO RECIVE: {"result":["rubyslite%2F416082087%2F9"],"id":4}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.956	debug	Message= {"id":4,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.655	debug	MIIO RECIVE: {"result":["retry"],"id":3}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.646	debug	Message= {"id":3,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.526	info	State value to set for "mihome-vacuum.0.cleanmap.actualMap" has to be type "string" but received type "number"
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.460	info	create states for mop
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.456	info	create states for water box mode
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.446	info	create states for water box
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.422	info	change states from State control.fan_power
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.420	debug	setGetStatus {"msg_ver":2,"msg_seq":620,"state":18,"battery":99,"clean_time":30,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.416	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":620,"state":18,"battery":99,"clean_time":30,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":2}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.403	debug	Message= {"id":2,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.402	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.401	debug	Create State done!
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.400	debug	Create State for map: loadMap
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.400	debug	Create State for map: mapURL
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.399	debug	Create State for map: mapStatus
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.398	debug	Create State for map: actualMap
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.398	debug	Create State for map: map64
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.396	debug	Create State for map:
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.391	info	Map selected create states...
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.391	debug	Create State for Queue: clearQueue
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.389	debug	Create State for Queue: queue
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.307	debug	Xiaomi Cloud: Login successful
                                        mihome-vacuum.0
                                        2022-02-04 12:49:39.306	debug	Login step3: [{"key":"userId","value":"1669572361","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-04T11:49:39.276Z","lastAccessed":"2022-02-04T11:49:39.305Z"},{"key":"cUserId","value":"86_CG49N742pAF3a6YHfpffTQtQ","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-04T11:49:39.289Z","lastAccessed":"2022-02-04T11:49:39.305Z"},{"key":"serviceToken","value":"Hb28uKXL4tg+Rx4Ejawm2vyZgEKyzJgCOu0SkGDsq74JyeZXfYXTVyYqxIjvjwryzmCH1wD8psAZhK6AnRqbxW618jbqJlnoRxjaGNZY5muKrMZ/okWLpBFRSFM4JBnjfqZf05oLzy0cpcEvwrZjn8L7sxKHjCh6umXXrRt9Vog=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-04T11:49:39.296Z","lastAccessed":"2022-02-04T11:49:39.305Z"}]
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.742	debug	Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"aayiF9R2Nw/OxAoedzLLwg==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCeSTPIqJm2+tGOQjiIqk9LwI1YSJ1R8v6PnwBKFqE+s93Xif/XeN3wPP/nuVGk1zVEkvHavUrWOOxzW4ZbPyw1Hofy5skxNzO1rBY4jrod85bteKUi0k34jf4NIphx5zaPhi4TAsaoE1cIIPpimQHvgIHmNRWfSpa2iw2O0UslrzRuXNPb0GCEnxmtqWCOTWnWnuFr9ijrk8ZacAzzUNxchf+QpQIXLluA9YIs4u4+fXfxWU1aqzivbnpKHc7MHZJKd6s+DFp8bA5NvimQkqjZQ=","description":"成功","securityStatus":0,"nonce":3405740169290115072,"userId":1669572361,"cUserId":"86_CG49N742pAF3a6YHfpffTQtQ","result":"ok","psecurity":"ZYMgigvaMg9ByJpejBVF0Q==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=hzlhwi&ticket=0&pwd=1&p_ts=1643975378000&fid=0&p_lm=1&auth=XDy6M2KTjzNfLFQa7WzpQQcr470C7zSkEBaQ9BtkToYH29MiundG6vKIVVXZsaYEYqEOp0h9%2BebdLjuTzTnyUv4yUme2%2BIolPftzkAbHsn2Si%2Bril%2FUqFRV%2BA6ASDzedElvlZSF%2BrcxfG2JCzVhlsIc8Z%2BK1mI7m3LbX1GOWRjI%3D&m=1&tsl=0&nonce=KXTV089N3BEBohWl&_ssign=0rbz5okLFGLEFTQCaaKVqdN3Njw%3D","pwd":1,"desc":"成功"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.725	info	settest next timer: not available
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.404	debug	Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.265	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.192	debug	Xiaomi Cloud: Logging in
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.184	info	select standard vacuum protocol....
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.182	debug	DeviceModel selected to: roborock.vacuum.s5e
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.085	debug	Get Device data from robot..
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.083	debug	Get Device data..0
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.081	debug	GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"Krystian","bssid":"00:5f:67:a3:93:84","rssi":-47},"netif":{"localIp":"192.168.178.58","mask":"255.255.255.0","gw":"192.168.178.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"B0:4A:39:13:19:DC","token":"62435048385749766e48576b37643449","life":32608}}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.080	debug	MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"Krystian","bssid":"00:5f:67:a3:93:84","rssi":-47},"netif":{"localIp":"192.168.178.58","mask":"255.255.255.0","gw":"192.168.178.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"B0:4A:39:13:19:DC","token":"62435048385749766e48576b37643449","life":32608}}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.071	debug	Message= {"id":1,"method":"miIO.info"}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.069	debug	GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1643974905206,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1643712474446}
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.063	debug	MAIN: Connected to device, try to get model..
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.062	debug	Receive <<< Helo <<< 213100200000000018cce8a761fd12d2ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.040	debug	server started on 0.0.0.0:53421
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.034	info	IOT enabled, create state
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.030	debug	MIIO: Config: ip:192.168.178.58 token: 62435048385749766e48576b37643449
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.029	debug	Create State for deviceInfowifi_signal
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.027	debug	Create State for deviceInfofw_ver
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.026	debug	Create State for deviceInfomodel
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.024	debug	Create State for deviceInfomac
                                        mihome-vacuum.0
                                        2022-02-04 12:49:38.023	debug	Create State for deviceInfo
                                        mihome-vacuum.0
                                        2022-02-04 12:49:37.960	debug	load Map creator... true
                                        mihome-vacuum.0
                                        2022-02-04 12:49:37.857	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 3.3.22
                                        mihome-vacuum.0
                                        2022-02-04 12:49:37.562	debug	Plugin sentry Initialize Plugin (enabled=true)
                                        host.raspberrypi
                                        2022-02-04 12:49:34.798	info	instance system.adapter.mihome-vacuum.0 started with pid 26676
                                        host.raspberrypi
                                        2022-02-04 12:49:04.726	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                        host.raspberrypi
                                        2022-02-04 12:49:04.725	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                        host.raspberrypi
                                        2022-02-04 12:49:04.717	warn	instance system.adapter.mih
                                        Ne du, ich habe keine Ahnung mehr. Irgendwie bleibts bestehen :) und ich verstehe nur Bahnhof.
                                        • wendy2702W Online
                                          wendy2702W Online
                                          #711
                                          Stellt zum ersten mal das log in der Instanz auf Debug.
                                          Dann gibt es vielleicht mehr infos die helfen.
                                          Bei mir mit S7 gibt es auch keinen Absturz
