  4. Test Adapter fronius-solarweb
249 Beiträge 50 Kommentatoren 74.9k Aufrufe 44 Beobachtet
  • madingM Offline
    madingM Offline
    mading
    @tombox du bist echt spitze mit allen Adaptern die du baust (nutze viessmannapi, grünbeck,vw-connect). Kann ich dir via Paypal oä einen Obulus zukommen lassen?
    Vielen Dank für deine tolle Arbeit!
    • E exmayr
      @tombox
      so sieht das logfile aus
      0 info it worked if it ends with ok
      1 verbose cli [
      1 verbose cli   'C:\\Program Files\\nodejs\\node.exe',
      1 verbose cli   'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
      1 verbose cli   'install',
      1 verbose cli   'TA2k/ioBroker.fronius-solarweb#f1e1c838d5cef215b5159fd93bd3ca40b82fc92f'
      1 verbose cli ]
      2 info using npm@6.13.4
      3 info using node@v12.16.1
      4 verbose npm-session 3985a85ef44371be
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 silly fetchPackageMetaData error for github:TA2k/ioBroker.fronius-solarweb#f1e1c838d5cef215b5159fd93bd3ca40b82fc92f Error while executing:
      7 silly fetchPackageMetaData undefined ls-remote -h -t ssh://git@github.com/TA2k/ioBroker.fronius-solarweb.git
      7 silly fetchPackageMetaData spawn git ENOENT
      8 timing stage:rollbackFailedOptional Completed in 9ms
      9 timing stage:runTopLevelLifecycles Completed in 62789ms
      10 verbose stack Error: spawn git ENOENT
      10 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:267:19)
      10 verbose stack     at onErrorNT (internal/child_process.js:469:16)
      10 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:84:21)
      11 verbose cwd C:\iobroker
      12 verbose Windows_NT 10.0.19042
      13 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "TA2k/ioBroker.fronius-solarweb#f1e1c838d5cef215b5159fd93bd3ca40b82fc92f"
      14 verbose node v12.16.1
      15 verbose npm  v6.13.4
      16 error code ENOENT
      17 error syscall spawn git
      18 error path git
      19 error errno ENOENT
      20 error enoent Error while executing:
      20 error enoent undefined ls-remote -h -t ssh://git@github.com/TA2k/ioBroker.fronius-solarweb.git
      20 error enoent
      20 error enoent
      20 error enoent spawn git ENOENT
      21 error enoent This is related to npm not being able to find a file.
      22 verbose exit [ 1, true ]
      Mod-Edit: Code in </> Code-Tag gepackt!
      tombox
      @exmayr sieht so aus als wäre kein git auf dem system installiert. Entweder nachinstallieren oder abwarten bis der adapter im repo ist
      • E exmayr
        @tombox
        1 verbose cli [
        1 verbose cli ]
        18 error path git
        20 error enoent
        20 error enoent
        da_WoodyD Online
        da_WoodyD Online
        @exmayr bitte, logs immer in bda82279-27bb-44e0-94a4-b4c29073337b-grafik.png posten!
        • madingM mading
          tombox
          @mading Passt schon, so ein Adapter ist ja schnell in 30 Minuten gebaut. Keine Schöpfungstiefe für die man Geld verlangen kann
          • T tombox
            da_WoodyD Online
            da_WoodyD Online
            @tombox sagte in Test Adapter fronius-solarweb:
            der ist gut... wenn mans kann sicher, wir "unfähigen" sind halt auf euch angewiesen...
            thnx dafür tropsdem!
            • T tombox
              @c1olli bitte mal neuinstallieren ob die fehler dann weg sind
              c1olli
              @tombox
              Ich hab jetzt den Adapter komplett neu installiert.
              Bis jetzt läuft es, mal schauen, ob da wieder was aufpoppt.
              Olli
              • E Offline
                exmayr
                @tombox said in Test Adapter fronius-solarweb:
                danke für die Hilfe - mit git hats dann funktioniert
                • qqolliQ qqolli
                  @tombox
                  So, hab mal den Raspi neu gestartet :-)
                  Bis jetzt sieht es gut aus:
                  fronius-solarweb.0
                  2022-01-21 09:12:53.528	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.fronius-solarweb, node: v14.18.3, js-controller: 3.3.22
                  fronius-solarweb.0
                  2022-01-21 09:12:46.847	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  fronius-solarweb.0
                  2022-01-21 09:12:46.845	info	terminating
                  fronius-solarweb.0
                  2022-01-21 09:12:46.843	info	Got terminate signal TERMINATE_YOURSELF
                  fronius-solarweb.0
                  fronius-solarweb.0
                  fronius-solarweb.0
                  Sag Dir Bescheid, falls es sich wieder ändert.
                  qqolliQ Offline
                  qqolliQ Offline
                  qqolli
                  @tombox
                  Nachdem es eine Weile lief, habe ich jetzt wieder diese Fehlermeldungen:
                  fronius-solarweb.0
                  2022-01-23 17:33:57.177	error	Start relogin in 1min
                  fronius-solarweb.0
                  2022-01-23 17:33:57.177	error	{"responseError":1110,"responseMessage":"Invalid JWT format."}
                  fronius-solarweb.0
                  2022-01-23 17:33:57.177	error	Error: Request failed with status code 401
                  fronius-solarweb.0
                  2022-01-23 17:33:57.176	error	refresh token failed
                  fronius-solarweb.0
                  2022-01-23 17:24:57.772	error	{"responseError":1110,"responseMessage":"Invalid JWT format."}
                  fronius-solarweb.0
                  2022-01-23 17:24:57.772	error	Error: Request failed with status code 401
                  fronius-solarweb.0
                  2022-01-23 17:23:57.463	error	Start relogin in 1min
                  fronius-solarweb.0
                  2022-01-23 17:23:57.463	error	{"responseError":1110,"responseMessage":"Invalid JWT format."}
                  fronius-solarweb.0
                  2022-01-23 17:23:57.463	error	Error: Request failed with status code 401
                  fronius-solarweb.0
                  2022-01-23 17:23:57.462	error	refresh token failed
                  fronius-solarweb.0
                  2022-01-23 17:14:57.412	error	{"responseError":1110,"responseMessage":"Invalid JWT format."}
                  fronius-solarweb.0
                  2022-01-23 17:14:57.411	error	Error: Request failed with status code 401
                  fronius-solarweb.0
                  2022-01-23 17:13:57.301	error	Start relogin in 1min
                  fronius-solarweb.0
                  2022-01-23 17:13:57.301	error	{"responseError":1110,"responseMessage":"Invalid JWT format."}
                  fronius-solarweb.0
                  2022-01-23 17:13:57.300	error	Error: Request failed with status code 401
                  fronius-solarweb.0
                  2022-01-23 17:13:57.300	error	refresh token failed
                  • qqolliQ qqolli
                    @tombox
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    fronius-solarweb.0
                    tombox
                    @qqolli Kannst du bitte nochmal via github installieren und checken ob es weiter passiert eigentlich sollte es nicht kommen
                    • MassiveAttackM MassiveAttack
                      @da_woody said in Test Adapter fronius-solarweb:
                      @tombox funktioniert das nur mit premium?
                      nein, mit premium siehst du zusätzlich die prognose.
                      nutze es auch ohne premium
                      save
                      schrieb am zuletzt editiert von save
                      @massiveattack sagte in Test Adapter fronius-solarweb:
                      Hallo Zusammen
                      Echt super Arbeit. Die Installation funktionierte auf Anhieb.
                      Wollte kurz nachfragen wo ich als Premium Kunde den Forecast sehe in deinem neuen Adapter? Habe beim durchklicken der Objekte / Datenpunkte nichts gefunden.
                      Gruss aus der Ostschweiz
                      Sascha
                      Intel Nuc NUC7i3DNKE | DS920+ | KNX | SONOS | ioBroker | Stiebel Eltron WPL | Symo Gen 24 10 plus | BYD HVS 10.2
                      • S save
                        Hallo Zusammen
                        tombox
                        @save Habs mal eingebaut. installier mal neu. aber ist ungetestet bräuchte ein pro account zum testen
                        C 1 Antwort Letzte Antwort
                        • T tombox
                          c1olli
                          schrieb am zuletzt editiert von c1olli
                          @tombox
                          Energy Forecast funktioniert soweit, aber wirft für 2 Tage im Voraus alle 15min einen Order mit Werten aus.
                          Olli
                            tombox
                            @c1olli ich habe es mal so geändert das sie durchnummeriert werden
                            • T tombox
                              c1olli
                              @tombox
                              So nun habe ich die Ordner von 1 - 95, mal sehen wie sich das entwickelt.
                              Olli
                              T O 2 Antworten Letzte Antwort
                              • T tombox
                                da_WoodyD Online
                                da_WoodyD Online
                                @tombox ich hab ein ganz anderes problem. nachdem der adapter nicht grün werden will, hab ich mal versucht mich am androiden über die APP anzumelden. geht auch nicht. ok. nach einigem rumprobieren hab ich den fronius support angeschrieben, aber wie so oft nichtmal irgendeine reaktion bekommen.
                                ich habe ein problem. ich kann mich auf meine anlage einloggen, ich kann mich auf der homepage einloggen, wenn ich versuche mich über die android-app einzuloggen, bekomme ich benutzername und passwort überprüfen.
                                klicke ich auf registrieren, werde ich auf die homepage weitergeleitet und dort eingeloggt. klicke ich auf passwort vergessen, werde ich auf die homepage weitergeleitet und eingeloggt.
                                hat von euch sowas schon erlebt? gestern nochmal die APP deinstalliert, handy neu gestartet, neu installiert. keine änderung...
                                MassiveAttackM 1 Antwort Letzte Antwort
                                • da_WoodyD da_Woody
                                  MassiveAttackM Offline
                                  MassiveAttack
                                  versuch mal den browser cache zu löschen, bzw. nimm einen anderen browser
                                    da_WoodyD Online
                                    da_WoodyD Online
                                    @massiveattack ich red nicht vom PC, sondern von der handy-app...
                                      MassiveAttack
                                      sorry, ich habe gelesen, du kannst dich nicht einloggen auf der homepage 😑
                                      die app funktioniert bei mir auf android und ios, daher kann ich es nicht nachvollziehen
                                        da_WoodyD Online
                                        da_WoodyD Online
                                        @massiveattack passt schon... :)
                                        wie gesagt, ich werd von der APP auf die homepage geleitet und dort automatisch mit meinen zugangsdaten einfach eingeloggt. da es aber direkt über die APP nicht klappt, verbindet sich der adapter auch nicht...
                                        • C c1olli
                                          @tombox
                                          tombox
                                          @c1olli Wieviele forecast machen denn sinn?
