  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 503.2k Aufrufe 82 Beobachtet
    @wendy2702
    Das war allerdings beim Holen der Karte, nicht schon beim Login:
    2022-01-20 19:04:13.484  - info: mihome-vacuum.0 (2662) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v17.4.0, js-controller: 3.3.22
    2022-01-20 19:04:13.859  - info: mihome-vacuum.0 (2662) IOT enabled, create state
    2022-01-20 19:04:14.017  - info: mihome-vacuum.0 (2662) select standard vacuum protocol....
    2022-01-20 19:04:14.576  - info: mihome-vacuum.0 (2662) settest next timer: not available
    2022-01-20 19:04:15.348  - info: mihome-vacuum.0 (2662) Map selected create states...
    2022-01-20 19:04:15.548  - info: mihome-vacuum.0 (2662) create state for carpet_mode
    2022-01-20 19:04:17.495  - error: mihome-vacuum.0 (2662) Error when receiving map url: gf{qzsp71ph[g,~      z2@kOW',hI XZRS0'{iV^wd({M;vx||-Rk&vQWd+-`6|<$R@ULVb    ^ {ffH)d*;Au0bztv5QvP"X|QH!M339J)0;W;6PKor#'pB h$AUr={-tS  H5t4sc,T.IQ2%P,<u|vthMbuvl71|pUjv,t
    [$NFfCm"Y@MXHJgC3<A)7IrBt$(Dt`ae_t-c',qdo }/>N5[1^td6[LG(;
    2022-01-20 19:04:17.497  - warn: mihome-vacuum.0 (2662) map error:SyntaxError: Unexpected token g in JSON at position 0
    2022-01-20 19:12:37.812  - info: host.chet stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
    2022-01-20 19:12:37.823  - info: host.chet stopInstance system.adapter.mihome-vacuum.0 send kill signal
    2022-01-20 19:12:37.823  - info: mihome-vacuum.0 (2662) Got terminate signal TERMINATE_YOURSELF
    2022-01-20 19:12:37.829  - error: mihome-vacuum.0 (2662) Socket Close
    2022-01-20 19:12:37.830  - info: mihome-vacuum.0 (2662) terminating
    2022-01-20 19:12:37.833  - info: mihome-vacuum.0 (2662) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-01-20 19:12:38.460  - info: host.chet instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-01-20 19:12:41.676  - info: host.chet instance system.adapter.mihome-vacuum.0 started with pid 3562
    2022-01-20 19:12:43.703  - info: mihome-vacuum.0 (3562) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v17.4.0, js-controller: 3.3.22
    2022-01-20 19:12:43.819  - info: mihome-vacuum.0 (3562) IOT enabled, create state
    2022-01-20 19:12:43.971  - info: mihome-vacuum.0 (3562) select standard vacuum protocol....
    2022-01-20 19:12:44.532  - info: mihome-vacuum.0 (3562) settest next timer: not available
    2022-01-20 19:12:44.892  - info: mihome-vacuum.0 (3562) Map selected create states...
    2022-01-20 19:12:46.869  - info: mihome-vacuum.0 (3562) create state for carpet_mode
    dirkhe
    schrieb am zuletzt editiert von dirkhe
    #618
    @thomas-braun kannst du mal auf debug stellen? Und dann auf get devices
    • D dirkhe
      #619
      @dirkhe
      China-Server.
      Das Log ist aber nun unauffällig. Auch im Debug nix, soweit ich sehe.
        @dirkhe
        China-Server.
        dirkhe
        #620
        @thomas-braun sorry meinte @wendy2702, da steht germany im Screenshot. Bin ich auch und da klappt das.
        • DiginixD Offline
          DiginixD Offline
          Diginix
          #621
          @Meistertr @dirkhe Über Nacht ist v3.3.3 bei mir dann doch noch komplett eskaliert und hat mir ein 380 kb Log erzeugt weil die Instanz 80 mal seit 4:39 Uhr mit folgenden Meldungen alle 2-3 Minuten abgestürzt ist:
          2022-01-21 04:39:00.503 - error: mihome-vacuum.0 (1609625) uncaught exception: Cannot read property 'body' of undefined
          2022-01-21 04:39:00.504 - error: mihome-vacuum.0 (1609625) TypeError: Cannot read property 'body' of undefined
              at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:455:51)
              at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
              at Request.emit (events.js:400:28)
              at Request.emit (domain.js:475:12)
              at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
              at ClientRequest.emit (events.js:412:35)
              at ClientRequest.emit (domain.js:475:12)
              at TLSSocket.socketErrorListener (_http_client.js:475:9)
              at TLSSocket.emit (events.js:400:28)
              at TLSSocket.emit (domain.js:475:12)
          2022-01-21 04:39:00.504 - error: mihome-vacuum.0 (1609625) Cannot read property 'body' of undefined
          2022-01-21 04:39:00.513 - error: mihome-vacuum.0 (1609625) Socket Close
          2022-01-21 04:39:00.515 - warn: mihome-vacuum.0 (1609625) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2022-01-21 04:39:00.911 - error: host.iobroker Caught by controller[0]: TypeError: Cannot read property 'body' of undefined
          2022-01-21 04:39:00.917 - error: host.iobroker Caught by controller[0]:     at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:455:51)
          2022-01-21 04:39:00.917 - error: host.iobroker Caught by controller[0]:     at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          2022-01-21 04:39:00.917 - error: host.iobroker Caught by controller[0]:     at Request.emit (events.js:400:28)
          2022-01-21 04:39:00.917 - error: host.iobroker Caught by controller[0]:     at Request.emit (domain.js:475:12)
          2022-01-21 04:39:00.917 - error: host.iobroker Caught by controller[0]:     at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
          2022-01-21 04:39:00.917 - error: host.iobroker Caught by controller[0]:     at ClientRequest.emit (events.js:412:35)
          2022-01-21 04:39:00.917 - error: host.iobroker Caught by controller[0]:     at ClientRequest.emit (domain.js:475:12)
          2022-01-21 04:39:00.917 - error: host.iobroker Caught by controller[0]:     at TLSSocket.socketErrorListener (_http_client.js:475:9)
          2022-01-21 04:39:00.917 - error: host.iobroker Caught by controller[0]:     at TLSSocket.emit (events.js:400:28)
          2022-01-21 04:39:00.918 - error: host.iobroker Caught by controller[0]:     at TLSSocket.emit (domain.js:475:12)
          2022-01-21 04:39:00.918 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          Hab mal das gesamte Netzwerk neu gestartet und seit dem läuft die Instanz. 3 Raumreinigungen inkl. Karte haben auch korrekt funktioniert.
          ..:: So long! Tom ::..
          • wendy2702W Online
            wendy2702W Online
            #622
            Muss mal was für Anfänger fragen.
            Habe den Roborock S7+ und konnte scheinbar auch erfolgreich eine Verbindung herstellen.
            Habe jetzt diese DP's für die einzelnen Räume vom Adapter bekommen:
            Wenn ich aber z.B. auf den Button klicke für "clean Room" oder den Wert auf "true" ändere passiert nichts.
            Wie bekomme ich den Robo denn über die DP's gestartet?
            madingM bahnuhrB 2 Antworten Letzte Antwort
            • wendy2702W wendy2702
              madingM Online
              madingM Online
              mading
              schrieb am zuletzt editiert von mading
              #623
              @wendy2702 du musst den DP auf true setzen!
              //edit sorry nicht gesehen. Hast du bestätigt genommen oder mal via Blockly "steuere"?
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #624
                @wendy2702 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                nicht clean room
                sondern
                .roomclean
                wie hier schon berichtet:
                https://forum.iobroker.net/topic/51492/raumzuordnung-in-skript/13?_=1642775461040
                Danke.
                • bahnuhrB bahnuhr
                  nicht clean room
                  sondern
                  .roomclean
                  wendy2702W Online
                  wendy2702W Online
                  #625
                  @bahnuhr zu deinem Script frage ich im anderen Thread.
                  Hier versuche ich den Adapter zu verstehen.
                  OK.
                  clean room ist der Name und .roomClean die ID vom DP aber es reicht nicht aus den Entsprechenden Button zu betätigen.
                  Wenn ich diesen Button betätige oder den Wert auf "true" bestätigt ändere passiert bei mir nichts, sollte doch aber oder nicht?
                  Und wieso stehen die jetzt alle auf "true" obwohl der Sauger in der Station steht?
                  • D3ltoroxpD Offline
                    D3ltoroxpD Offline
                    D3ltoroxp
                    #626
                    Wie kann ich denn sehen ob mein Canvas im Eimer ist ? Ich habs gelöscht und neu installiert.
                    • D3ltoroxpD D3ltoroxp
                      #627
                      @d3ltoroxp sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                      Wie genau?
                      D3ltoroxpD 1 Antwort Letzte Antwort
                        Wie genau?
                        D3ltoroxpD Offline
                        D3ltoroxpD Offline
                        D3ltoroxp
                        #628
                        @thomas-braun Ich suche gerade schon wo mir das erklärt wurde, also auf jeden Fall zum Ordner navigiert und dort rm den Ordner Canvas gelöscht danach glaub mit nmp install oder rebuild canvas im entsprechenden Ordner. Ich such grad wo der Post war.
                        • DiginixD Diginix
                          @d3ltoroxp Ja oder mit absolutem Pfad
                          rm -rf /opt/iobroker/node_modules/canvas
                          um 100% den richtigen Ordner zu löschen.
                          Danach
                          cd /opt/iobroker/node_modules && npm i
                          D3ltoroxpD Offline
                          D3ltoroxpD Offline
                          D3ltoroxp
                          schrieb am zuletzt editiert von D3ltoroxp
                          #629
                          @diginix said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                          Danach
                          Auf jeden Fall so mal und eben auch direkt über iobroker install canvas vllt ?
                          So sieht es aktuell aus.
                          Das hatte ich glaub auch versucht.
                          Man kann auch nur canvas mit "npm i canvas" installieren.
                          Hatte immer wieder das Backup eingespielt.
                            Danach
                            #630
                            @d3ltoroxp
                            Bitte keine Screenshots. Verwende CodeTags für Texte aus der Konsole.
                              @d3ltoroxp
                              D3ltoroxpD Offline
                              D3ltoroxpD Offline
                              D3ltoroxp
                              #631
                              @thomas-braun Ich weiß das ist aber über die Konsole aus Proxmox und da konnte ich nichts markieren und kopieren sorry.
                              Sieht das Canvas nicht gut aus ?
                              MeistertrM Thomas BraunT 2 Antworten Letzte Antwort
                                MeistertrM Offline
                                MeistertrM Offline
                                Meistertr
                                #632
                                @d3ltoroxp bei der 3.3.3 kommt eine logmeldung wenn canvas nciht geht
                                • MeistertrM Meistertr
                                  DarkDevil
                                  #633
                                  @meistertr vielen Dank. Mit der 3.3.3 laufen die Karten wieder wie zuvor 👍
                                    #634
                                    canvas liegt eigentlich nicht ohne Zusammenhang im root-Ordner der Installation.
                                    Vor allen Dingen nicht in V 2.6.1
                                    So schaut das bei mir aus:
                                    echad@chet:/opt/iobroker $ npm ls canvas
                                    iobroker.inst@3.0.0 /opt/iobroker
                                    ├─┬ iobroker.echarts@1.0.3
                                    │ ├── canvas@2.9.0
                                    │ └─┬ jsdom@16.7.0
                                    │   └── canvas@2.9.0 deduped
                                    ├─┬ iobroker.iot@1.8.25
                                    │ ├── canvas@2.9.0 deduped
                                    │ └─┬ jsdom@17.0.0
                                    ├─┬ iobroker.mihome-vacuum@3.3.3
                                    └─┬ iobroker.zigbee@1.6.12
                                      ├─┬ zigbee-herdsman-converters@14.0.378
                                      │ ├─┬ jsdom@16.7.0 extraneous
                                      │ │ └── canvas@2.9.0 deduped
                                      │ └─┬ zigbee-herdsman@0.13.191
                                      │   └─┬ jsdom@16.7.0 extraneous
                                      └─┬ zigbee-herdsman@0.13.192
                                    Mit der Proxmox-Konsole bist du aber auch der Erste, der das erzählt.
                                      │ ├── canvas@2.9.0
                                      │ └─┬ jsdom@16.7.0
                                      │ └─┬ jsdom@17.0.0
                                      D3ltoroxpD Offline
                                      D3ltoroxpD Offline
                                      D3ltoroxp
                                      #635
                                      @thomas-braun Hier geht auch keine rechte Maustaste, wenn ichs könnte hätte ich doch schnell den Text kopiert.
                                      Sollte ich das Canvas im Root mal löschen wenn es da nichts zu suchen hat ?
                                      Bei dir gibts das so oft weil du halt viele Adapter hast die davon abhängig sind ?
                                        #636
                                        @d3ltoroxp
                                        Bei mir benötigen 4 iobroker-Adapter das Modul.
                                        Richtig 'aktiv' ist aber nur das Modul unter iobroker.echarts
                                        Alle anderen verweisen auf dieses Modul (siehe deduped)
                                          D3ltoroxpD Offline
                                          D3ltoroxp
                                          #637
                                          @Meistertr
                                          mihome-vacuum.0
                                          	2022-01-21 20:13:16.011	debug	MIIO RECIVE: {"result":[[1641462016,1641465037,3021,54082500,0,1,1,1]],"id":27}
                                          mihome-vacuum.0
                                          	2022-01-21 20:13:16.007	debug	update_Map got new time:1642792395
                                          mihome-vacuum.0
                                          	2022-01-21 20:13:16.006	debug	update_Map got new expires:1642794195
                                          mihome-vacuum.0
                                          	2022-01-21 20:13:16.006	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/3?Expires=1642794195000&GalaxyAccessKeyId=5271733786445&Signature=ni69dYJvPR8ECQDote9wNIc3eLU=
                                          mihome-vacuum.0
                                          	2022-01-21 20:13:15.998	debug	Message= {"id":27,"method":"get_clean_record","params":[1641462016]}
                                          mihome-vacuum.0
                                          	2022-01-21 20:13:15.997	debug	MIIO RECIVE: {"result":[[1641970342,1641973170,2828,52962500,0,1,1,1]],"id":26}
                                          mihome-vacuum.0
                                          	2022-01-21 20:13:15.926	debug	Xiaomi Cloud: Logging in
                                          mihome-vacuum.0
                                          	2022-01-21 20:13:15.926	warn	map error:SyntaxError: Unexpected token w in JSON at position 0
                                          mihome-vacuum.0
                                          	2022-01-21 20:13:15.925	error	Error when receiving map url: wsR,4@rj(Y[dU()k{Z<Y-Q{qkR*
                                          Die Error Zeile ist länger daher der Screen mal.
                                          Also es steht nun was in den DP's
                                          Aber in der VIS kommt nichts, das war früher so eingestellt.
