  4. Tr-064 Adapter Fehler
90 Beiträge 42 Kommentatoren 27.7k Aufrufe
    stephan61
    habe den adapter mit version 0.1.29 installiert und bekomme folgende Fehler im log
    wenn ich auf geräte suche gehe
    host.	2017-01-23 17:05:19.824	error	at JavascriptRedisParser.Parser.returnReply (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:192:18)
    host.	2017-01-23 17:05:19.824	error	at RedisClient.return_reply (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:828:9)
    host.	2017-01-23 17:05:19.824	error	at return_pub_sub (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:789:18)
    host.	2017-01-23 17:05:19.824	error	at RedisClient.emit (events.js:175:7)
    host.	2017-01-23 17:05:19.824	error	at emitThree (events.js:97:13)
    host.	2017-01-23 17:05:19.824	error	at RedisClient. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:94:25)
    host.	2017-01-23 17:05:19.824	error	at that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2839:41)
    host.	2017-01-23 17:05:19.824	error	at Object.options.message (/opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef/soef.js:1091:26)
    host.	2017-01-23 17:05:19.824	error	at Object.onMessage (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:76:25)
    host.	2017-01-23 17:05:19.824	error	at TR064.forEachHostEntry (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:261:15)
    host.	2017-01-23 17:05:19.824	error	TypeError: Cannot read property 'actions' of undefined
    host.	2017-01-23 17:05:19.820	error	pmessage messagebox.system.adapter.tr-064.0 {"command":"discovery","message":5000,"from":"system.adapter.admin.0","callback":{"message":5000,"id":12,"ack":false,"time":1485187519815},"_id":1225833} C
    Gruß Stephan
    geändert: Code in Code-Tags Homoran (Admin)
      DrFirebird
      Bekomme genau den gleichen Fehler.
      Liegt es wohl an der 7490 ?
        Strizz
        @DrFirebird:
        Liegt es wohl an der 7490 ? `
        ich hatte auch große Probleme, den Adapter ans Laufen zu bekommen. Hat bei mir erst dann funktioniert, nachdem ich in den Settings alle Häkchen - bis auf Watch devices - entfernt habe. Jetzt läuft er immerhin seit zwei Tagen problemlos.
        Strizz
        Gesendet von iPad mit Tapatalk Pro
          DrFirebird
          :D mit der Einstellung scheint es zu funktionieren.
          Jetzt kann ich zumindest das Gäste WLAN ein-/ausschalten.
          • J Offline
            jawr
            ich habe Probleme den Adapter überhaupt zu starten, das Log sagt folgendes
            host.odroid-jessie64	2017-03-27 09:47:10.040	info	Restart adapter system.adapter.tr-064.0 because enabled
            host.odroid-jessie64	2017-03-27 09:47:10.040	error	instance system.adapter.tr-064.0 terminated with code 1 ()
            host.odroid-jessie64	2017-03-27 09:47:08.352	info	instance system.adapter.tr-064.0 started with pid 16334
            host.odroid-jessie64	2017-03-27 09:46:38.334	info	Restart adapter system.adapter.tr-064.0 because enabled
            host.odroid-jessie64	2017-03-27 09:46:38.331	error	instance system.adapter.tr-064.0 terminated with code 1 ()
            In den Optionen habe ich nur "Prüfen angemeldete Geräte" aktiviert. Mir ist ehrlich gesagt nicht ganz klar ob man einen Benutzer in den Einstellungen eintragen muss. Beim Login in die Fritzbox ist ja nur eine Passwrtabfrage. Ist hier ein Benutzer einzutragen, wenn ja, welcher?
            Gruß,
            jawr
            • BluefoxB Offline
              BluefoxB Offline
              @jawr:
              Gruß,
              jawr `
              Ich denke "admin"
              • J Offline
                jawr
                admin habe ich versucht, funktioniert nicht. Ich gehe ja auch mal davon aus der Adapter bei erfolglosem Login eine entsprechende Rückmeldung in das Logfile schreibt. Ich gehe aber eher davoin aus das der Loginversuch erst gar nicht ausgeführt wird wenn ich mir die Logeinträge so ansehe.
                Gruß,
                jawr
                • eric2905E Offline
                  eric2905E Offline
                  eric2905
                  Ich schaue heute Abend mal nach, was ich eingetragen habe - bei mir läuft der Adapter.
                  Gruß,
                  Eric
                  Von unterwegs getippert
                  • andreA Offline
                    andreA Offline
                    andre
                    @jawr:
                    Gruß,
                    jawr `
                    Eventuell musst du die Anmeldung an der Fritzbox auf "Benutzername und Kennwort" ändern (Unter System > Fritzbox-Benutzer > Anmeldung im Heimnetz). Ich habe bei mir einen separaten Benutzer angelegt. Diesen nutzt auch nur der Adapter. Mein Adapter läuft einwandfrei mit allen Features "enabled".
                    MfG,
                    André
                    • J Offline
                      jawr
                      ich habe das mal probiert und einen Benutzer erstellt und die Anmeldung in der Fritzbox an genannter Stelle geändert. Leider ohne Erfolg. Ich gehe noch immer davon aus das es ein Problem an anderer Stelle liegt und die Anmeldung gar nicht erst erfolgt. Kann man den Adapter von der Konsole starten und erhält so evtl. mal mehr Infos?
                      Edit: So wie ich das interpretiere sind die Log Einträge doch vom iobroker controller und nicht vom adapter tr-046, würde ja bedeuten Dax der Adapter gar nichts in das log schreibt, also gar nicht erst startet.
                      Gruß,
                      jawr
                      • eric2905E Offline
                        eric2905E Offline
                        eric2905
                        Ich habe keinen dedizierten Benutzer angelegt und gebe beim User (bei mir) "eric" an und als Passwort das auf der Fritte definierte Passwort.
                        Hast Du unter Wählhilfe die entspr. Einstellungen gemacht?
                        Es gibt einen Thread bzgl. bestimmte Telefone klingeln zu lassen und dort kommt der Hinweis, das es nur funktioniert, wenn diese Konfig auf der Fritte sauber ist.
                        Gruß,
                        Eric
                        • J Offline
                          jawr
                          Das bezieht sich so wie ich das sehe nur auf das Klingeln der Telefone. Der Adapter sollte auch so laufen. Nochmal die Frage: Gibt es über die Konsole die Möglichkeit mal mehr über den Fehler zu erfahren?
                          Gruß,
                          jawr
                            SirKimba
                            Hallo Ihr,
                            erstmal vielen Dank für den klasse Adapter.
                            Eine Instanz alleine funktioniert bei mir prima.
                            Jede Weitere Instanz, natürlich auf eine andere Fritzbox (ich habe im Moment 3 davon) schlägt fehlt, also geht auf grün, dann rot und das ganze noch 2 mal.
                            Als Meldung bekomme ich:
                            tr-064.2 2017-04-07 18:49:20.933 info terminating
                            tr-064.2 2017-04-07 18:49:20.933 error at Timer.listOnTimeout (timers.js:92:15)
                            tr-064.2 2017-04-07 18:49:20.933 error at updateAll [as _onTimeout] (D:\ioBroker\node_modules\iobroker.tr-064\tr-064.js:841:17)
                            tr-064.2 2017-04-07 18:49:20.933 error at TR064.setABIndex (D:\ioBroker\node_modules\iobroker.tr-064\tr-064.js:273:10)
                            tr-064.2 2017-04-07 18:49:20.933 error TypeError: this.getABInfo is not a function
                            tr-064.2 2017-04-07 18:49:20.933 error uncaught exception: this.getABInfo is not a function
                            tr-064.2 2017-04-07 18:49:18.925 warn Phonebook not supported
                            tr-064.2 2017-04-07 18:49:18.816 info starting. Version 0.3.12 in D:/ioBroker/node_modules/iobroker.tr-064, node: v4.3.1
                            Ich habe die Vermutung das es irgendwie an meiner Fritzbox liegt.
                            Szenario:
                            Adapter .0 geht auf Fritzbox0 (7390 v 06.83) - Dieser funktioniert
                            Adapter .2 geht auf Fritzbox2 (7390 v 06.83)- Dieser schlägt fehlt
                            Schalte ich nun .0 ab und wechsele in .2 auf die IP von Fritzbox0, so funktioniert dieser wieder einwandfrei nach dem aktivieren.
                            • In beiden Adaptern sind bei den Checkboxes defaults
                            • Benutzer sind identisch.
                            • Wahlhilfe ist eingestellt
                            • Sicherheitsabfrage ist abgestellt
                            …. oder es liegt irgendwie daran das keine 2 oder n Instanzen parallel laufen können?
                            Hat einer von Euch eine Idee was es sein könnte ?
                            Ich bin für Hilfe echt dankbar :)
                            LG Kai
                            • eric2905E Offline
                              eric2905E Offline
                              eric2905
                              Was passiert denn, wenn Du beide Adapter auf die Fritzbox0 jagst?
                              Gruß,
                              Eric
                                SirKimba
                                @eric2905:
                                Gruß,
                                Eric
                                Von unterwegs getippert `
                                Krass …. Gut, meine Theorie das 2 Adapter nicht nebeneinander laufen können stimmt nicht.
                                Also wenn ich beide Adapter auf fritzbox0 zeigen lasse, funktionieren beide einwandfrei.
                                Okay, dann verhärtet sich der Verdacht das etwas mit fritzbox2 nicht stimmt.
                                Ich habe beide Setups soweit verglichen und abgesehen von MSN, Telefonbuch, MAC und WLAN sind sie identisch. Ich mag nicht ausschließen das ich etwas übersehen habe.
                                Mal so grundsätzlich gefragt: Gibt es Settings auf der FB die ein "must have" sind damit der Adapter läuft ?
                                @Eric: Thx für diesen Denkanstoß
                                LG Kai
                                  SirKimba
                                  Ein kurzes Update:
                                  ich konnte mein Problem lösen. Der Fehler saß, wie so oft, vor der Tastatur.
                                  In der Fritzbox, mit der sich keine Adapter verbinden wollte, hatte ich eine Einstellung übersehen.
                                  Unter "Heimnetzwerk/Heimnetzwerkübersicht/Netzwerkeinstellungen" war der Haken bei "Zugriff für Anwendungen zulassen" nicht gesetzt.
                                  Das hatte dann zur Folge das diese komische Meldung ausgegeben wurde.
                                  LG und danke
                                  Kai
                                  • 0 Offline
                                    0 Offline
                                    0018
                                    auch bei mir startet der Adapter nun nicht mehr, ich vermute es hängt mit dem Update des Adapters oder meiner FB7490 (6.83) zusammen?
                                    Folgender Log:
                                    tr-064.0	2017-04-11 13:58:54.888	error	code=unknown error code Device responded with fault Error: Credentials incorrect
                                    tr-064.0	2017-04-11 13:53:51.162	error	code=500 sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 500
                                    tr-064.0	2017-04-11 13:53:43.681	info	starting. Version 0.3.12 in /opt/iobroker/node_modules/iobroker.tr-064, node: v4.7.3
                                    hat jemand hierzu eine Idee?
                                    Mfg
                                    Mfg
                                    0018
                                    • 0 Offline
                                      0 Offline
                                      0018
                                      Neuinstallation brachte auch keinen Erfolg. Fehler bleibt bestehen.
                                      jemand eine Idee was das bedeutet und wie ich das beheben kann?
                                      Mfg
                                      Mfg
                                      0018
                                      • eric2905E Offline
                                        eric2905E Offline
                                        eric2905
                                        @0018:
                                        jemand eine Idee was das bedeutet und wie ich das beheben kann? `
                                        hast Du Dir den Thread mal durchgelesen und die Tipps, die zu finden sind, mal ausprobiert?
                                        Gruß,
                                        Eric
                                        • 0 Offline
                                          0 Offline
                                          0018
                                          Ja habe ich.
                                          Habe eine ältere Version 0.3.11 über die Konsole installiert –> kein Erfolg
                                          Einstellungen der Fritzbox überprüft "Zugriff für Anwendungen zulassen" --> bereits aktiv
                                          Neuen Benutzer erstellt und Admin Benutzer versucht --> kein Erfolg
                                          Bekomme ja Daten wie externe IP usw. übermittelt, aber der Fehler bleibt bestehen und ich kann keine Devices abfragen.
                                          Einzige Auffälligkeit die ich hatte war beim Upload das der Adapter nicht existiert, weiß aber nicht ob das normal ist:
                                          /opt/iobroker $ sudo iobroker upload tr-064
                                          got /opt/iobroker/node_modules/iobroker.tr-064/admin
                                          upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                          upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                          upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index.html index.html text/html
                                          system.adapter.tr-064 does not exist
                                          Mfg
                                          0018
