  4. Bekomme mihome-vacuum -Adapter nicht geupdated
    1.0k
    6.1k
33 Beiträge 5 Kommentatoren 3.5k Aufrufe 3 Beobachtet
  • TroyaT Troya
    Moin in die Runde,
    ich bekomme den mihome-Vacuum Adapter nicht geupdatet von 2.1.1 auf 3.3.1.
    komischerweise heißt es Adapter "mihome-vacuum" updated:
    $ iobroker upgrade mihome-vacuum@3.3.1
    Update mihome-vacuum from @2.1.1 to @3.3.1
    NPM version: 6.14.15
    npm install iobroker.mihome-vacuum@3.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code EEXISTnpm ERR! path /opt/iobroker/node_modules/.bin/needle
    npm ERR! Refusing to delete /opt/iobroker/node_modules/.bin/needle: is outside /opt/iobroker/node_modules/needle and not a linknpm ERR! File exists: /opt/iobroker/node_modules/.bin/needlenpm ERR! Remove the existing file and try again, or run npmnpm ERR! with --force to overwrite files recklessly.
    npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2022-01-07T08_30_35_567Z-debug.log
    upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
    upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
    upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
    upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
    upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
    upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
    upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
    upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
    upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
    upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
    upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
    upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
    Process exited with code 0
    Deshalb hab ich versucht ihn neu zu installieren und die Deinstallation schlägt auch fehl:
    $ iobroker del mihome-vacuum
    Delete adapter "mihome-vacuum"
    host.iobroker object mihome-vacuum deleted
    host.iobroker object mihome-vacuum.admin deleted
    npm uninstall iobroker.mihome-vacuum --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2022-01-07T08_20_26_021Z-debug.log
    Error deleting adapter mihome-vacuum from disk: Error: host.iobroker: Cannot uninstall iobroker.mihome-vacuum: 1You might have to delete it yourself!
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'uninstall',
    1 verbose cli   'iobroker.mihome-vacuum',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.15
    3 info using node@v12.22.7
    4 verbose config Skipping project config: /opt/iobroker/.npmrc. (matches userconfig)
    5 verbose npm-session 715c5fcc00f719b4
    6 silly install loadCurrentTree
    7 silly install readLocalPackageData
    8 timing stage:loadCurrentTree Completed in 16812ms
    9 silly install loadIdealTree
    10 silly install cloneCurrentTreeToIdealTree
    11 timing stage:loadIdealTree:cloneCurrentTree Completed in 83ms
    12 silly install loadShrinkwrap
    13 timing stage:loadIdealTree:loadShrinkwrap Completed in 2249ms
    14 silly uninstall loadAllDepsIntoIdealTree
    15 silly install loadAllDepsIntoIdealTree
    16 http fetch GET 304 https://registry.npmjs.org/osx-temperature-sensor 595ms (from cache)
    17 silly pacote range manifest for osx-temperature-sensor@^1.0.7 fetched in 658ms
    18 silly resolveWithNewModule osx-temperature-sensor@1.0.7 checking installable status
    19 http fetch GET 304 https://registry.npmjs.org/fsevents 438ms (from cache)
    20 silly pacote range manifest for fsevents@~2.3.2 fetched in 458ms
    21 silly resolveWithNewModule fsevents@2.3.2 checking installable status
    22 http fetch GET 304 https://registry.npmjs.org/xpc-connection 567ms (from cache)
    23 silly pacote range manifest for xpc-connection@~0.1.4 fetched in 570ms
    24 silly resolveWithNewModule xpc-connection@0.1.4 checking installable status
    25 http fetch GET 304 https://registry.npmjs.org/bluetooth-hci-socket 1432ms (from cache)
    26 silly pacote range manifest for bluetooth-hci-socket@^0.5.1 fetched in 1436ms
    27 silly resolveWithNewModule bluetooth-hci-socket@0.5.1 checking installable status
    28 timing stage:loadIdealTree:loadAllDepsIntoIdealTree Completed in 7933ms
    29 timing stage:loadIdealTree Completed in 12578ms
    30 silly currentTree iobroker.inst@1.1.2
    30 silly currentTree ├─┬ @abandonware/bluetooth-hci-socket@0.5.3-3
    30 silly currentTree │ ├── debug@4.1.1
    Ganz viel Silly Tree-kram den ich hier mal weglasse
    254 silly saveTree   ├── @serialport/stream@8.0.4
    254 silly saveTree   └── debug@4.1.1
    255 warn optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    256 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    257 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
    257 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
    257 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
    257 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: x64
    258 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    259 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    260 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
    260 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
    260 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
    260 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: x64
    261 warn enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.radar/package.json'
    262 verbose enoent This is related to npm not being able to find a file.
    263 verbose stack Error: Refusing to delete /opt/iobroker/node_modules/.bin/needle: is outside /opt/iobroker/node_modules/needle and not a link
    263 verbose stack     at clobberFail (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:121:12)
    263 verbose stack     at isSafeToRm (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:114:15)
    263 verbose stack     at /usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:54:5
    263 verbose stack     at LOOP (/usr/lib/node_modules/npm/node_modules/slide/lib/chain.js:7:26)
    263 verbose stack     at /usr/lib/node_modules/npm/node_modules/slide/lib/chain.js:18:7
    263 verbose stack     at /usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:180:7
    263 verbose stack     at /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/iferr/index.js:13:50
    263 verbose stack     at _readAllLinks (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:215:28)
    263 verbose stack     at resolveSymlink (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:226:22)
    263 verbose stack     at _readAllLinks (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:217:5)
    263 verbose stack     at readAllLinks (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:212:3)
    263 verbose stack     at /usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:179:5
    263 verbose stack     at cb (/usr/lib/node_modules/npm/node_modules/slide/lib/async-map.js:47:24)
    263 verbose stack     at /usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:153:16
    264 verbose cwd /opt/iobroker
    265 verbose Linux 4.4.180+
    Kann jemand helfen?
    Diskstation - Docker Container
    Plattform
    linux
    Betriebssystem
    linux
    Architektur
    x64
    CPUs
    Geschwindigkeit
    2001 MHz
    Modell
    Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
    RAM
    9.58 GB
    System-Betriebszeit
    12 T. 11:09:56
    Node.js
    v12.22.7 (Es gibt eine neuere Version: v12.22.8 - Empfohlene Version v14.18.2)
    NPM
    6.14.15
    Datenträgergröße
    3.49 TB
    freier Festplattenspeicher
    471.05 GB
    Anzahl der Adapter
    362
    Betriebszeit
    00:16:07
    Aktive Instanzen
    location
    /opt/iobroker/
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    @troya Das sieht mir fast genauso aus wie das Problem hier: https://forum.iobroker.net/topic/51091/problem-bei-update-js-controller-from-3-3-18-to-3-3-22
    Nur dass bei dir ein anderes Modul angemeckert wird:
    TroyaT 1 Antwort Letzte Antwort
    • AlCalzoneA AlCalzone
      TroyaT Offline
      TroyaT Offline
      Troya
      schrieb am zuletzt editiert von Troya
      @alcalzone sagte in Bekomme mihome-vacuum -Adapter nicht geupdated:
      Remove the existing file and try again, or run npm with --force to overwrite files recklessly.
      mach ich das mit folgendem Befehl?
      rm /opt/iobroker/node_modules/.bin/needle
      • TroyaT Troya
        TroyaT Offline
        TroyaT Offline
        Troya
        @AlCalzone
        Sorry, aber ich bin ungern und unsicher auf der Linux Ebene unterwegs, geht das mit dem Befehl von oben? Kannst du mir helfen?
        • TroyaT Troya
          @AlCalzone
          @troya
          Bitte vor dem löschen mal schauen was das überhaupt für ein file ist...
          ls -l  /opt/iobroker/node_modules/.bin/needle
          file  /opt/iobroker/node_modules/.bin/needle
          Dann kann das mit
          sudo -u iobroker rm  /opt/iobroker/node_modules/.bin/needle
          vermutlich gelöscht werden.
            @troya
            Dann kann das mit
            TroyaT Offline
            TroyaT Offline
            Troya
            root@iobroker:/opt/iobroker# ls -l  /opt/iobroker/node_modules/.bin/needle
            -rwxr-xr-x 1 iobroker iobroker 20 Nov 21  2019 /opt/iobroker/node_modules/.bin/needle
            root@iobroker:/opt/iobroker# file  /opt/iobroker/node_modules/.bin/needle
            /opt/iobroker/node_modules/.bin/needle: ASCII text, with no line terminators
            Hallo Thomas,
            das kommt bei den Befehlen als Antwort. Kann ich aber nichts mit anfangen, sorry bin echt nicht gut mit Linux.
            • TroyaT Troya
              Hallo Thomas,
              @troya
              Und warum springst du dann als root durch das System? Gerade wenn man nicht gut mit Linux umgehen kann ist das Harakiri.
              Lösch den Kram.
                @troya
                Lösch den Kram.
                TroyaT Offline
                TroyaT Offline
                Troya
                Hm, gute Frage. Hab im Docker im Terminal ein neues Fenster aufgemacht und so stand es da. Glaub ich habe das damals nicht ohne root nicht aufgesetzt bekommen.😖
                Hab damals über Wochen versucht den iobroker auf der synology zum laufen zu bekommen und bin eigentlich nur froh, dass es jetzt seit langem zuverlässig läuft.
                • TroyaT Troya
                  TroyaT Offline
                  TroyaT Offline
                  Troya
                  Aber ich weiß du hast recht, ist wohl das beste mal einen neuen Container aufzusetzen. Wäre auch mal ein guter test zu schauen ob das Backup vernünftig funktioniert
                  • Thomas BraunT Online
                    @troya
                    Bei Synology-Kram kann das sein. Da wird mir immer erzählt das ginge nur als root.
                    da_WoodyD TroyaT 2 Antworten Letzte Antwort
                      @troya
                      da_WoodyD Online
                      da_WoodyD Online
                      @thomas-braun sagte in Bekomme mihome-vacuum -Adapter nicht geupdated:
                      die haben ein etwas eigenes linux da drauf. da bist du als user weniger als nichts.
                      • da_WoodyD da_Woody
                        @da_woody
                        Da ist halt was auf den Einsatzzweck als NAS angepasstes drauf. Deswegen halte ich das Ganze ja auch nicht für eine vernünftige Basis für irgendwelche Serverdienste.
                          @da_woody
                          da_WoodyD Online
                          da_WoodyD Online
                          nicht nur NAS, is bei den routern der selbs schmu. da kannste nicht auf jeden im mesh zugreifen, nein, du darfst dich vom hauptrouter auf den nächsten hangeln. macht gute laune wenn du neben dem hauptrouter noch 3 daneben hast... ;)
                            @troya
                            TroyaT Offline
                            TroyaT Offline
                            Troya
                            Ok, also hab ich jetzt ein Ordner oder Datei und kann ich es damit entfernen?
                            • TroyaT Troya
                              @troya
                              Lösch mal.
                                @troya
                                Lösch mal.
                                TroyaT Offline
                                TroyaT Offline
                                Troya
                                hat geklappt!
                                Kann es sein, dass nur noch eine Instanz gleichzeitig laufen kann? die zweite wird nicht grün wird mit code 0 beendet (no error)
                                • TroyaT Troya
                                  hat geklappt!
                                  @troya
                                  Instanz von was? Dem mihome-vaccuum-Adapter?
                                  Da können schon zwei Instanzen laufen.
                                    @troya
                                    TroyaT Offline
                                    TroyaT Offline
                                    Troya
                                    Ja genau. Hat auch geklappt bevor der s7 eingezogen ist. Dann hab ich versucht zu updaten, weil ich dort den Fehler vemutet hab. Dann "needle" gelöscht, Update hat funktioniert und nun sieht es so im Log aus:
                                    host.iobroker 2022-01-18 11:48:14.399	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
                                    host.iobroker 2022-01-18 11:48:14.398	info	instance system.adapter.mihome-vacuum.1 terminated with code 0 (NO_ERROR)
                                    mihome-vacuum.1 2022-01-18 11:48:14.284	silly	States system redis pmessage system.adapter.mihome-vacuum.1.logLevel/system.adapter.mihome-vacuum.1.logLevel:{"val":"silly","ack":true,"ts":1642502994241,"q":0,"from":"system.adapter.mihome-vacuum.1","lc":1642302793338}
                                    mihome-vacuum.1 2022-01-18 11:48:14.272	debug	Create State for deviceInfofw_ver
                                    mihome-vacuum.1 2022-01-18 11:48:14.271	debug	Create State for deviceInfomodel
                                    mihome-vacuum.1 2022-01-18 11:48:14.271	debug	Create State for deviceInfomac
                                    mihome-vacuum.1 2022-01-18 11:48:14.270	debug	Create State for deviceInfo
                                    mihome-vacuum.1 2022-01-18 11:48:14.211	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                                    mihome-vacuum.1 2022-01-18 11:48:13.994	debug	Plugin sentry Initialize Plugin (enabled=true)
                                    host.iobroker 2022-01-18 11:48:11.938	info	instance system.adapter.mihome-vacuum.1 started with pid 1650
                                    host.iobroker 2022-01-18 11:47:41.651	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
                                    host.iobroker 2022-01-18 11:47:41.650	info	instance system.adapter.mihome-vacuum.1 terminated with code 0 (NO_ERROR)
                                    mihome-vacuum.1 2022-01-18 11:47:41.538	debug	Create State for deviceInfomodel
                                    mihome-vacuum.1 2022-01-18 11:47:41.537	debug	Create State for deviceInfomac
                                    mihome-vacuum.1 2022-01-18 11:47:41.535	debug	Create State for deviceInfo
                                    mihome-vacuum.1 2022-01-18 11:47:41.465	silly	States system redis pmessage system.adapter.mihome-vacuum.1.logLevel/system.adapter.mihome-vacuum.1.logLevel:{"val":"silly","ack":true,"ts":1642502994241,"q":0,"from":"system.adapter.mihome-vacuum.1","lc":1642302793338}
                                    mihome-vacuum.1 2022-01-18 11:47:41.379	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                                    mihome-vacuum.1 2022-01-18 11:47:40.868	debug	Plugin sentry Initialize Plugin (enabled=true)
                                    host.iobroker 2022-01-18 11:47:38.619	info	instance system.adapter.mihome-vacuum.1 started with pid 1635
                                    host.iobroker 2022-01-18 11:47:08.593	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
                                    host.iobroker 2022-01-18 11:47:08.592	info	instance system.adapter.mihome-vacuum.1 terminated with code 0 (NO_ERROR)
                                    mihome-vacuum.1 2022-01-18 11:47:08.436	silly	States system redis pmessage system.adapter.mihome-vacuum.1.logLevel/system.adapter.mihome-vacuum.1.logLevel:{"val":"silly","ack":true,"ts":1642502994241,"q":0,"from":"system.adapter.mihome-vacuum.1","lc":1642302793338}
                                    mihome-vacuum.1 2022-01-18 11:47:08.384	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
                                    mihome-vacuum.1 2022-01-18 11:47:08.161	debug	Plugin sentry Initialize Plugin (enabled=true)
                                    host.iobroker 2022-01-18 11:47:06.143	info	instance system.adapter.mihome-vacuum.1 started with pid 1619
                                    Der Adapter der als erstes gestartet wird wird grün, der andere entsprechend nicht
                                    • TroyaT Troya
                                      TroyaT Offline
                                      TroyaT Offline
                                      Troya
                                      Hab mich grad nochmal mit dem Adapter beschäftigt und komplett deinstalliert und neu installiert und bekomme folgenden Log:
                                      host.iobroker2022-02-02 09:29:09.295	error	iobroker The following apt-get packages could not be installed: libcairo2-dev, libpango1.0-dev, libjpeg-dev, libgif-dev, librsvg2-dev. Please install them manually.
                                      host.iobroker2022-02-02 09:29:09.293	error	iobroker Cannot install "librsvg2-dev": E: Paket librsvg2-dev kann nicht gefunden werden.
                                      host.iobroker2022-02-02 09:29:09.246	error	iobroker Cannot install "libgif-dev": E: Paket libgif-dev kann nicht gefunden werden.
                                      host.iobroker2022-02-02 09:29:09.195	error	iobroker Cannot install "libjpeg-dev": E: Paket libjpeg-dev kann nicht gefunden werden.
                                      host.iobroker2022-02-02 09:29:09.146	error	iobroker Cannot install "libpango1.0-dev": E: Paket libpango1.0-dev kann nicht gefunden werden.E: Mittels des Musters »libpango1.0-dev« konnte kein Paket gefunden werden.E: Mittels regulärem Ausdruck »libpango1.0-dev« konnte kein Paket gefunden werden.
                                      host.iobroker2022-02-02 09:29:09.097	error	iobroker Cannot install "libcairo2-dev": E: Paket libcairo2-dev kann nicht gefunden werden.
                                      host.iobroker2022-02-02 09:29:08.598	info	iobroker host.iobroker install adapter mihome-vacuum
                                      host.iobroker2022-02-02 09:28:57.358	info	iobroker gyp ERR! System Linux 4.4.180+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socketgyp ERR! node -v v14.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                      host.iobroker2022-02-02 09:28:57.355	info	iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
                                      host.iobroker2022-02-02 09:28:57.351	info	iobroker gyp ERR! build error
                                      host.iobroker2022-02-02 09:28:57.348	info	iobroker make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1
                                      host.iobroker2022-02-02 09:28:57.000	info	iobroker ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:417:34: error: no matching function for call to ‘v8::Value::IntegerValue()’ devId = arg0->IntegerValue(); ^In file included from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:67:0, from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node_buffer.h:25, from ../src/BluetoothHciSocket.cpp:7:/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:2863:40: note: candidate: v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue( ^~~~~~~~~~~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:2863:40: note: candidate expects 1 argument, 0 provided
                                      host.iobroker2022-02-02 09:28:56.995	info	iobroker In file included from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:67:0, from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node_buffer.h:25, from ../src/BluetoothHciSocket.cpp:7:/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:2863:40: note: candidate: v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue( ^~~~~~~~~~~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:2863:40: note: candidate expects 1 argument, 0 provided
                                      host.iobroker2022-02-02 09:28:56.993	info	iobroker ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:395:34: error: no matching function for call to ‘v8::Value::IntegerValue()’ devId = arg0->IntegerValue(); ^
                                      host.iobroker2022-02-02 09:28:56.982	info	iobroker ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:../src/BluetoothHciSocket.cpp:251:95: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv); ^In file included from ./src/BluetoothHciSocket.cpp:8:0:../../nan/nan.h:1045:46: note: declared here NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback( ^~~~~~~~~~~~../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:269:109: error: no matching function for call to ‘v8::Object::Get(v8::Local<v8::String>)’ Local<Function> errorConstructor = Local<Function>::Cast(globalObj->Get(Nan::New("Error").ToLocalChecked())); ^In file included from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:67:0, from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node_buffer.h:25, from ../src/BluetoothHciSocket.cpp:7:/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3717:43: note: candidate: v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>) V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3720:43: note: candidate: v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t) V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’ Local<Value> error = errorConstructor->NewInstance(1, constructorArgs); ^In file included from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:67:0, from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node_buffer.h:25, from ../src/BluetoothHciSocket.cpp:7:/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:4451:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance( ^~~~~~~~~~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:4451:44: note: candidate expects 3 arguments, 2 provided/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:4454:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance( ^~~~~~~~~~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:4454:44: note: candidate expects 1 argument, 2 provided../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv); ^In file included from ../src/BluetoothHciSocket.cpp:8:0:../../nan/nan.h:1045:46: note: declared here NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback( ^~~~~~~~~~~~
                                      host.iobroker2022-02-02 09:28:56.972	info	iobroker ../src/BluetoothHciSocket.cpp: In static member function ‘static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:128:82: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’ target->Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl->GetFunction()); ^In file included from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:67:0, from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node_buffer.h:25, from ../src/BluetoothHciSocket.cpp:7:/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:6482:46: note: candidate: v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>) V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction( ^~~~~~~~~~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:6482:46: note: candidate expects 1 argument, 0 provided
                                      Es fehlen wohl Pakete, wie kann ich die manuell installieren?
                                      haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                                      • TroyaT Troya
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        @troya
                                        Ich kann dir nur für das "danach" helfen.
                                        Wenn du 2 Instanzen installiert hast, musst du bei der 2.Instanz in den Adaptereinstellungen einen Port weiter einstellen.
                                        Das ist die Einstellunfg in der 1. Instanz.
                                        In der Zweiten stellst du den Eigenen Port auf z.B. 53422
                                        Dann kannst du beide parallel betreiben.
                                        • TroyaT Troya
                                          @troya sagte in Bekomme mihome-vacuum -Adapter nicht geupdated:
                                          sudo apt update
                                          apt policy libgif-dev
                                          Aber vermutlich reitest du da ein totes Pferd. Absteigen und auf ein lebendes Release wechseln.
