<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bekomme mihome-vacuum -Adapter nicht geupdated]]></title><description><![CDATA[<p dir="auto">Moin in die Runde,<br />
ich bekomme den mihome-Vacuum Adapter nicht geupdatet von 2.1.1 auf 3.3.1.<br />
komischerweise heißt es <em>Adapter "mihome-vacuum" updated</em>:</p>
<p dir="auto"></p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Update Log</button><section style="display:none" class="spoiler-content"><p></p>
<pre><code>$ iobroker upgrade mihome-vacuum@3.3.1
Update mihome-vacuum from @2.1.1 to @3.3.1
NPM version: 6.14.15
npm install iobroker.mihome-vacuum@3.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
npm ERR! code EEXISTnpm ERR! path /opt/iobroker/node_modules/.bin/needle
npm ERR! Refusing to delete /opt/iobroker/node_modules/.bin/needle: is outside /opt/iobroker/node_modules/needle and not a linknpm ERR! File exists: /opt/iobroker/node_modules/.bin/needlenpm ERR! Remove the existing file and try again, or run npmnpm ERR! with --force to overwrite files recklessly.
npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2022-01-07T08_30_35_567Z-debug.log
upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
Process exited with code 0
</code></pre>
<p dir="auto"></p></section></section><br />
Deshalb hab ich versucht ihn neu zu installieren und die Deinstallation schlägt auch fehl:<br />
<section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">kurzer Log im Deinstallationsfenster</button><section style="display:none" class="spoiler-content"><p></p>
<pre><code>$ iobroker del mihome-vacuum
Delete adapter "mihome-vacuum"
host.iobroker object mihome-vacuum deleted
host.iobroker object mihome-vacuum.admin deleted
npm uninstall iobroker.mihome-vacuum --loglevel error --prefix "/opt/iobroker" (System call)
npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2022-01-07T08_20_26_021Z-debug.log
Error deleting adapter mihome-vacuum from disk: Error: host.iobroker: Cannot uninstall iobroker.mihome-vacuum: 1You might have to delete it yourself!
</code></pre>
<section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Langer Logfile(mittlerer Bereich entfernt)</button><section style="display:none" class="spoiler-content"><p></p>
<pre><code>0 info it worked if it ends with ok
1 verbose cli [
1 verbose cli   '/usr/bin/node',
1 verbose cli   '/usr/bin/npm',
1 verbose cli   'uninstall',
1 verbose cli   'iobroker.mihome-vacuum',
1 verbose cli   '--loglevel',
1 verbose cli   'error',
1 verbose cli   '--prefix',
1 verbose cli   '/opt/iobroker'
1 verbose cli ]
2 info using npm@6.14.15
3 info using node@v12.22.7
4 verbose config Skipping project config: /opt/iobroker/.npmrc. (matches userconfig)
5 verbose npm-session 715c5fcc00f719b4
6 silly install loadCurrentTree
7 silly install readLocalPackageData
8 timing stage:loadCurrentTree Completed in 16812ms
9 silly install loadIdealTree
10 silly install cloneCurrentTreeToIdealTree
11 timing stage:loadIdealTree:cloneCurrentTree Completed in 83ms
12 silly install loadShrinkwrap
13 timing stage:loadIdealTree:loadShrinkwrap Completed in 2249ms
14 silly uninstall loadAllDepsIntoIdealTree
15 silly install loadAllDepsIntoIdealTree
16 http fetch GET 304 https://registry.npmjs.org/osx-temperature-sensor 595ms (from cache)
17 silly pacote range manifest for osx-temperature-sensor@^1.0.7 fetched in 658ms
18 silly resolveWithNewModule osx-temperature-sensor@1.0.7 checking installable status
19 http fetch GET 304 https://registry.npmjs.org/fsevents 438ms (from cache)
20 silly pacote range manifest for fsevents@~2.3.2 fetched in 458ms
21 silly resolveWithNewModule fsevents@2.3.2 checking installable status
22 http fetch GET 304 https://registry.npmjs.org/xpc-connection 567ms (from cache)
23 silly pacote range manifest for xpc-connection@~0.1.4 fetched in 570ms
24 silly resolveWithNewModule xpc-connection@0.1.4 checking installable status
25 http fetch GET 304 https://registry.npmjs.org/bluetooth-hci-socket 1432ms (from cache)
26 silly pacote range manifest for bluetooth-hci-socket@^0.5.1 fetched in 1436ms
27 silly resolveWithNewModule bluetooth-hci-socket@0.5.1 checking installable status
28 timing stage:loadIdealTree:loadAllDepsIntoIdealTree Completed in 7933ms
29 timing stage:loadIdealTree Completed in 12578ms
30 silly currentTree iobroker.inst@1.1.2
30 silly currentTree ├─┬ @abandonware/bluetooth-hci-socket@0.5.3-3
30 silly currentTree │ ├── debug@4.1.1
Ganz viel Silly Tree-kram den ich hier mal weglasse
254 silly saveTree   ├── @serialport/stream@8.0.4
254 silly saveTree   └── debug@4.1.1
255 warn optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
256 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
257 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
257 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
257 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
257 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: x64
258 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
259 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
260 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
260 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
260 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
260 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: x64
261 warn enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.radar/package.json'
262 verbose enoent This is related to npm not being able to find a file.
263 verbose stack Error: Refusing to delete /opt/iobroker/node_modules/.bin/needle: is outside /opt/iobroker/node_modules/needle and not a link
263 verbose stack     at clobberFail (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:121:12)
263 verbose stack     at isSafeToRm (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:114:15)
263 verbose stack     at /usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:54:5
263 verbose stack     at LOOP (/usr/lib/node_modules/npm/node_modules/slide/lib/chain.js:7:26)
263 verbose stack     at /usr/lib/node_modules/npm/node_modules/slide/lib/chain.js:18:7
263 verbose stack     at /usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:180:7
263 verbose stack     at /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/iferr/index.js:13:50
263 verbose stack     at _readAllLinks (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:215:28)
263 verbose stack     at resolveSymlink (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:226:22)
263 verbose stack     at _readAllLinks (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:217:5)
263 verbose stack     at readAllLinks (/usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:212:3)
263 verbose stack     at /usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:179:5
263 verbose stack     at cb (/usr/lib/node_modules/npm/node_modules/slide/lib/async-map.js:47:24)
263 verbose stack     at /usr/lib/node_modules/npm/node_modules/gentle-fs/lib/rm.js:153:16
264 verbose cwd /opt/iobroker
265 verbose Linux 4.4.180+
</code></pre>
<p dir="auto"></p></section></section><p></p>
<p dir="auto">Kann jemand helfen?</p>
<p dir="auto"></p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Mein System</button><section style="display:none" class="spoiler-content"><p></p>
<p dir="auto">Diskstation - Docker Container<br />
Plattform<br />
linux<br />
Betriebssystem<br />
linux<br />
Architektur<br />
x64<br />
CPUs<br />
2<br />
Geschwindigkeit<br />
2001 MHz<br />
Modell<br />
Intel(R) Celeron(R) CPU J3355 @ 2.00GHz<br />
RAM<br />
9.58 GB<br />
System-Betriebszeit<br />
12 T. 11:09:56<br />
Node.js<br />
v12.22.7 (Es gibt eine neuere Version: v12.22.8 - Empfohlene Version v14.18.2)<br />
NPM<br />
6.14.15<br />
Datenträgergröße<br />
3.49 TB<br />
freier Festplattenspeicher<br />
471.05 GB<br />
Anzahl der Adapter<br />
362<br />
Betriebszeit<br />
00:16:07<br />
Aktive Instanzen<br />
16<br />
location<br />
/opt/iobroker/<br />
]]></description><link>https://forum.iobroker.net/topic/51125/bekomme-mihome-vacuum-adapter-nicht-geupdated</link><generator>RSS for Node</generator><lastBuildDate>Sat, 23 May 2026 22:27:34 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/51125.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 Jan 2022 08:37:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 19:24:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troya" aria-label="Profile: troya">@<bdi>troya</bdi></a> sagte in <a href="/post/754667">Bekomme mihome-vacuum -Adapter nicht geupdated</a>:</p>
<blockquote>
<p dir="auto">'never Touch a running System'</p>
</blockquote>
<p dir="auto">Das ist grundfalsch. Updates kommen ja raus, weil irgendetwas eben 'not running' ist.</p>
<p dir="auto">Gerade Debian hat die Maxime, einmal releaste Versionen nur noch im allernotwendigsten Notfall anzupacken und ein update zu spendieren. Meist wird sogar recht aufwendig nur ein 'backport' gemacht.<br />
Aber irgendwann (nach ein paar Jahren) geht das nicht mehr mit sinnvollem Einsatz. Dann wird das Release abgekündigt. Mit großem Vorlauf, damit sich jeder drauf einrichten kann.</p>
]]></description><link>https://forum.iobroker.net/post/754669</link><guid isPermaLink="true">https://forum.iobroker.net/post/754669</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Feb 2022 19:24:09 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 19:17:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Danke Thomas, werde ich mal machen. Hab damals als ich das eingerichtet hab halt eeewig gebraucht bis das vernünftig lief. Daher fahr ich seitdem nach dem Motto 'never Touch a running System'<br />
Weiß aber innerlich dass es nicht clever ist und man halt auch mal 'formatieren' muss.😉</p>
]]></description><link>https://forum.iobroker.net/post/754667</link><guid isPermaLink="true">https://forum.iobroker.net/post/754667</guid><dc:creator><![CDATA[Troya]]></dc:creator><pubDate>Wed, 02 Feb 2022 19:17:40 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 18:52:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troya" aria-label="Profile: troya">@<bdi>troya</bdi></a></p>
<p dir="auto">Ich setzte bewusst keine Container ein. Aber mir wird immer erzählt, das sei alles total easy zu handeln mit den Dingern. Neuen Container aufzimmern, fertig. So ungefähr jedenfalls. Musst du dich dann mal reinhängen.</p>
]]></description><link>https://forum.iobroker.net/post/754646</link><guid isPermaLink="true">https://forum.iobroker.net/post/754646</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Feb 2022 18:52:07 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 18:48:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Ok, vielen Dank👍👍!(nicht selbstverständlich sowas Laienhaftes zu erklären)</p>
<p dir="auto">Bei mir ist das so aufgebaut : Synology - Docker - iobroker via buanet (4.01beta, gefühlte Jahre am laufen)<br />
Hängt die Debian Version im Container(also buanet Image - vermute ich mal, da das das älteste an meinem System ist) oder ist das Sache von Synology selbst.</p>
]]></description><link>https://forum.iobroker.net/post/754643</link><guid isPermaLink="true">https://forum.iobroker.net/post/754643</guid><dc:creator><![CDATA[Troya]]></dc:creator><pubDate>Wed, 02 Feb 2022 18:48:52 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 18:24:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troya" aria-label="Profile: troya">@<bdi>troya</bdi></a></p>
<p dir="auto">Stretch ist der Release Name einer Debian Version, die im Sommer des vorletzten Jahres abgekündigt wurden und nicht mehr aktiv gepflegt wird.</p>
<p dir="auto"><a href="https://wiki.debian.org/DebianReleases" rel="nofollow ugc">https://wiki.debian.org/DebianReleases</a></p>
<p dir="auto">Am 30.06.2022 werden die Lebenserhaltenden Maßnahmen für Stretch dann komplett eingestellt. Also höchste Zeit da abzusteigen. Das Pferd ist totgeritten.</p>
<p dir="auto">Je länger du wartest, um so tiefer musst du mit mehr Ahnung 'im Linux rumwühlen' müssen. Ist wie Oldtimer fahren. Irgendwann fehlen die Ersatzteile und die Leute, die sich damit noch auskennen. Da muss man dann selber ran und sich die Finger schmutzig machen wollen.</p>
<p dir="auto">Die Befehlsliste kannst du jetzt mal abarbeiten, das entbindet dich aber nicht von der Pflicht in Kürze das Release zu wechseln.</p>
]]></description><link>https://forum.iobroker.net/post/754621</link><guid isPermaLink="true">https://forum.iobroker.net/post/754621</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Feb 2022 18:24:53 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 18:13:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Stretch ist für mich ne Hosenart, soviel zu meinem Wissensstand von Linux 😉</p>
<p dir="auto">Kannst du etwas weiter ausholen? 😣</p>
<p dir="auto">Einfach deine Liste im Terminal abarbeiten? Hab immer Bange in Linux Ebene rumzuwühlen wenn es ja (fast) läuft, 😉</p>
]]></description><link>https://forum.iobroker.net/post/754612</link><guid isPermaLink="true">https://forum.iobroker.net/post/754612</guid><dc:creator><![CDATA[Troya]]></dc:creator><pubDate>Wed, 02 Feb 2022 18:13:00 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 16:54:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troya" aria-label="Profile: troya">@<bdi>troya</bdi></a> sagte in <a href="/post/754547">Bekomme mihome-vacuum -Adapter nicht geupdated</a>:</p>
<p dir="auto">Wie erwartet. Stretch ist tot. Kümmer dich um was noch unterstütztes.</p>
<p dir="auto">Mit</p>
<pre><code>sudo apt update
sudo apt install libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
sudo apt full-upgrade
sudo reboot
iobroker stop
iobroker fix
iobroker start
</code></pre>
<p dir="auto">sollte das aber dennoch noch etwas am Dahinsiechen zu halten sein.</p>
<p dir="auto">Die fehlenden Pakete sind übrigens für das Zeichnen von bunte Bilders verantwortlich. Dürfte der Grund sein, warum da die Karte nicht mehr zu sehen ist. Von canvas noch ganz abgesehen, das ist auf Stretch auch tricky.</p>
]]></description><link>https://forum.iobroker.net/post/754556</link><guid isPermaLink="true">https://forum.iobroker.net/post/754556</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Feb 2022 16:54:50 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 16:35:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/754248">Bekomme mihome-vacuum -Adapter nicht geupdated</a>:</p>
<blockquote>
<p dir="auto">Was sagt dir denn das System auf die beiden Befehlszeilen?</p>
</blockquote>
<p dir="auto">sudo apt update:<br />
</p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Spoiler</button><section style="display:none" class="spoiler-content"><p></p>
<pre><code>Ign:1 http://deb.debian.org/debian stretch InRelease
Holen:2 http://security.debian.org/debian-security stretch/updates InRelease [53,0 kB]
Holen:3 http://deb.debian.org/debian stretch-updates InRelease [93,6 kB]
Holen:4 http://deb.debian.org/debian stretch Release [118 kB]
Holen:5 http://deb.debian.org/debian stretch Release.gpg [3.177 B]
Holen:6 https://deb.nodesource.com/node_14.x stretch InRelease [4.585 B]
Holen:7 http://security.debian.org/debian-security stretch/updates/main amd64 Packages [767 kB]
Holen:8 http://deb.debian.org/debian stretch/main amd64 Packages [7.080 kB]
Holen:9 https://deb.nodesource.com/node_14.x stretch/main amd64 Packages [770 B]
Es wurden 8.119 kB in 3 s geholt (2.559 kB/s).
Aktualisierung für 87 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
</code></pre>
apt policy libgif-dev:<br />
<pre><code>libgif-dev:
 Installiert:           (keine)
 Installationskandidat: 5.1.4-0.4
 Versionstabelle:
    5.1.4-0.4 500
       500 http://deb.debian.org/debian stretch/main amd64 Packages
</code></pre>
]]></description><link>https://forum.iobroker.net/post/754547</link><guid isPermaLink="true">https://forum.iobroker.net/post/754547</guid><dc:creator><![CDATA[Troya]]></dc:creator><pubDate>Wed, 02 Feb 2022 16:35:48 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 16:31:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/haselchen" aria-label="Profile: haselchen">@<bdi>haselchen</bdi></a> sagte in <a href="/post/754239">Bekomme mihome-vacuum -Adapter nicht geupdated</a>:</p>
<blockquote>
<p dir="auto">Da weiss ich leider nicht welches Widget du meinst.<br />
Was hat es denn angezeigt?</p>
</blockquote>
<p dir="auto">Hab leider kein Bild, aber es war der Staubsaugroboter von oben gesehen mit fertige Buttons drauf. Also 1-2-3 für die Stufen, Saugen, Nach Hause, FindRobot. Und eine "blaue" LED die zeigt ob er grad läuft oder nicht. War eigentlich recht komfortabel. Hätte schwören können das Widget kam vom Adapter selbst</p>
]]></description><link>https://forum.iobroker.net/post/754546</link><guid isPermaLink="true">https://forum.iobroker.net/post/754546</guid><dc:creator><![CDATA[Troya]]></dc:creator><pubDate>Wed, 02 Feb 2022 16:31:51 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 11:14:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troya" aria-label="Profile: troya">@<bdi>troya</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/754248</link><guid isPermaLink="true">https://forum.iobroker.net/post/754248</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Feb 2022 11:14:37 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 11:07:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troya" aria-label="Profile: troya">@<bdi>troya</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/754239</link><guid isPermaLink="true">https://forum.iobroker.net/post/754239</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Wed, 02 Feb 2022 11:07:13 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 11:02:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Danke, ich lass es erstmal so, weil das tote Gaul noch läuft...call my Deathrider <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/2620.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--skull_and_crossbones" style="height:23px;width:auto;vertical-align:middle" title=":skull_and_crossbones:" alt="☠" /> <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f3c7.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--horse_racing" style="height:23px;width:auto;vertical-align:middle" title=":horse_racing:" alt="🏇" /><br />
<img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f601.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--grin" style="height:23px;width:auto;vertical-align:middle" title=":grin:" alt="😁" /><br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/haselchen" aria-label="Profile: haselchen">@<bdi>haselchen</bdi></a><br />
Der Port war die Lösung, läuft jetzt</p>
<p dir="auto">Noch eine Frage, nachdem ich den Adapter de - und installiert habe ist das Widget in Vis weg und ich finde das in der Widget Liste nicht</p>
]]></description><link>https://forum.iobroker.net/post/754236</link><guid isPermaLink="true">https://forum.iobroker.net/post/754236</guid><dc:creator><![CDATA[Troya]]></dc:creator><pubDate>Wed, 02 Feb 2022 11:02:51 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 09:42:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troya" aria-label="Profile: troya">@<bdi>troya</bdi></a> sagte in <a href="/post/754129">Bekomme mihome-vacuum -Adapter nicht geupdated</a>:</p>
<blockquote>
<p dir="auto">Es fehlen wohl Pakete, wie kann ich die manuell installieren?</p>
</blockquote>
</code></pre>
<p dir="auto">Aber vermutlich reitest du da ein totes Pferd. Absteigen und auf ein lebendes Release wechseln.</p>
]]></description><link>https://forum.iobroker.net/post/754178</link><guid isPermaLink="true">https://forum.iobroker.net/post/754178</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Feb 2022 09:42:27 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 08:53:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troya" aria-label="Profile: troya">@<bdi>troya</bdi></a></p>
<p dir="auto">Ich kann dir nur für das "danach" helfen.<br />
Wenn du 2 Instanzen installiert hast, musst du bei der 2.Instanz in den Adaptereinstellungen einen Port weiter einstellen.</p>
<p dir="auto"><img src="/assets/uploads/files/1643791944572-e41af9c5-3657-4bd3-ae87-7c51cbed70e0-grafik.png" alt="e41af9c5-3657-4bd3-ae87-7c51cbed70e0-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Das ist die Einstellunfg in der 1. Instanz.<br />
In der Zweiten stellst du den Eigenen Port auf z.B. <strong>53422</strong><br />
Dann kannst du beide parallel betreiben.</p>
]]></description><link>https://forum.iobroker.net/post/754142</link><guid isPermaLink="true">https://forum.iobroker.net/post/754142</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Wed, 02 Feb 2022 08:53:48 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Wed, 02 Feb 2022 08:35:11 GMT]]></title><description><![CDATA[<p dir="auto">Hab mich grad nochmal mit dem Adapter beschäftigt und komplett deinstalliert und neu installiert und bekomme folgenden Log:</p>
<p dir="auto"></p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Spoiler</button><section style="display:none" class="spoiler-content"><p></p>
<pre><code>host.iobroker2022-02-02 09:29:09.295	error	iobroker The following apt-get packages could not be installed: libcairo2-dev, libpango1.0-dev, libjpeg-dev, libgif-dev, librsvg2-dev. Please install them manually.
host.iobroker2022-02-02 09:29:09.293	error	iobroker Cannot install "librsvg2-dev": E: Paket librsvg2-dev kann nicht gefunden werden.
host.iobroker2022-02-02 09:29:09.246	error	iobroker Cannot install "libgif-dev": E: Paket libgif-dev kann nicht gefunden werden.
host.iobroker2022-02-02 09:29:09.195	error	iobroker Cannot install "libjpeg-dev": E: Paket libjpeg-dev kann nicht gefunden werden.
host.iobroker2022-02-02 09:29:09.146	error	iobroker Cannot install "libpango1.0-dev": E: Paket libpango1.0-dev kann nicht gefunden werden.E: Mittels des Musters »libpango1.0-dev« konnte kein Paket gefunden werden.E: Mittels regulärem Ausdruck »libpango1.0-dev« konnte kein Paket gefunden werden.
host.iobroker2022-02-02 09:29:09.097	error	iobroker Cannot install "libcairo2-dev": E: Paket libcairo2-dev kann nicht gefunden werden.
host.iobroker2022-02-02 09:29:08.598	info	iobroker host.iobroker install adapter mihome-vacuum
host.iobroker2022-02-02 09:28:57.358	info	iobroker gyp ERR! System Linux 4.4.180+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socketgyp ERR! node -v v14.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
host.iobroker2022-02-02 09:28:57.355	info	iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
host.iobroker2022-02-02 09:28:57.351	info	iobroker gyp ERR! build error
host.iobroker2022-02-02 09:28:57.348	info	iobroker make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1
host.iobroker2022-02-02 09:28:57.000	info	iobroker ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:417:34: error: no matching function for call to ‘v8::Value::IntegerValue()’ devId = arg0-&gt;IntegerValue(); ^In file included from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:67:0, from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node_buffer.h:25, from ../src/BluetoothHciSocket.cpp:7:/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:2863:40: note: candidate: v8::Maybe&lt;long int&gt; v8::Value::IntegerValue(v8::Local&lt;v8::Context&gt;) const V8_WARN_UNUSED_RESULT Maybe&lt;int64_t&gt; IntegerValue( ^~~~~~~~~~~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:2863:40: note: candidate expects 1 argument, 0 provided
host.iobroker2022-02-02 09:28:56.995	info	iobroker In file included from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:67:0, from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node_buffer.h:25, from ../src/BluetoothHciSocket.cpp:7:/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:2863:40: note: candidate: v8::Maybe&lt;long int&gt; v8::Value::IntegerValue(v8::Local&lt;v8::Context&gt;) const V8_WARN_UNUSED_RESULT Maybe&lt;int64_t&gt; IntegerValue( ^~~~~~~~~~~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:2863:40: note: candidate expects 1 argument, 0 provided
host.iobroker2022-02-02 09:28:56.993	info	iobroker ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:395:34: error: no matching function for call to ‘v8::Value::IntegerValue()’ devId = arg0-&gt;IntegerValue(); ^
host.iobroker2022-02-02 09:28:56.982	info	iobroker ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:../src/BluetoothHciSocket.cpp:251:95: warning: ‘v8::Local&lt;v8::Value&gt; Nan::MakeCallback(v8::Local&lt;v8::Object&gt;, v8::Local&lt;v8::String&gt;, int, v8::Local&lt;v8::Value&gt;*)’ is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(Nan::New&lt;Object&gt;(this-&gt;This), Nan::New("emit").ToLocalChecked(), 2, argv); ^In file included from ./src/BluetoothHciSocket.cpp:8:0:../../nan/nan.h:1045:46: note: declared here NAN_DEPRECATED inline v8::Local&lt;v8::Value&gt; MakeCallback( ^~~~~~~~~~~~../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:269:109: error: no matching function for call to ‘v8::Object::Get(v8::Local&lt;v8::String&gt;)’ Local&lt;Function&gt; errorConstructor = Local&lt;Function&gt;::Cast(globalObj-&gt;Get(Nan::New("Error").ToLocalChecked())); ^In file included from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:67:0, from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node_buffer.h:25, from ../src/BluetoothHciSocket.cpp:7:/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3717:43: note: candidate: v8::MaybeLocal&lt;v8::Value&gt; v8::Object::Get(v8::Local&lt;v8::Context&gt;, v8::Local&lt;v8::Value&gt;) V8_WARN_UNUSED_RESULT MaybeLocal&lt;Value&gt; Get(Local&lt;Context&gt; context, ^~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3720:43: note: candidate: v8::MaybeLocal&lt;v8::Value&gt; v8::Object::Get(v8::Local&lt;v8::Context&gt;, uint32_t) V8_WARN_UNUSED_RESULT MaybeLocal&lt;Value&gt; Get(Local&lt;Context&gt; context, ^~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local&lt;v8::Value&gt; [1])’ Local&lt;Value&gt; error = errorConstructor-&gt;NewInstance(1, constructorArgs); ^In file included from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:67:0, from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node_buffer.h:25, from ../src/BluetoothHciSocket.cpp:7:/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:4451:44: note: candidate: v8::MaybeLocal&lt;v8::Object&gt; v8::Function::NewInstance(v8::Local&lt;v8::Context&gt;, int, v8::Local&lt;v8::Value&gt;*) const V8_WARN_UNUSED_RESULT MaybeLocal&lt;Object&gt; NewInstance( ^~~~~~~~~~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:4451:44: note: candidate expects 3 arguments, 2 provided/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:4454:44: note: candidate: v8::MaybeLocal&lt;v8::Object&gt; v8::Function::NewInstance(v8::Local&lt;v8::Context&gt;) const V8_WARN_UNUSED_RESULT MaybeLocal&lt;Object&gt; NewInstance( ^~~~~~~~~~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:4454:44: note: candidate expects 1 argument, 2 provided../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local&lt;v8::Value&gt; Nan::MakeCallback(v8::Local&lt;v8::Object&gt;, v8::Local&lt;v8::String&gt;, int, v8::Local&lt;v8::Value&gt;*)’ is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(Nan::New&lt;Object&gt;(this-&gt;This), Nan::New("emit").ToLocalChecked(), 2, argv); ^In file included from ../src/BluetoothHciSocket.cpp:8:0:../../nan/nan.h:1045:46: note: declared here NAN_DEPRECATED inline v8::Local&lt;v8::Value&gt; MakeCallback( ^~~~~~~~~~~~
host.iobroker2022-02-02 09:28:56.972	info	iobroker ../src/BluetoothHciSocket.cpp: In static member function ‘static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:128:82: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’ target-&gt;Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl-&gt;GetFunction()); ^In file included from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:67:0, from /opt/iobroker/.cache/node-gyp/14.18.3/include/node/node_buffer.h:25, from ../src/BluetoothHciSocket.cpp:7:/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:6482:46: note: candidate: v8::MaybeLocal&lt;v8::Function&gt; v8::FunctionTemplate::GetFunction(v8::Local&lt;v8::Context&gt;) V8_WARN_UNUSED_RESULT MaybeLocal&lt;Function&gt; GetFunction( ^~~~~~~~~~~/opt/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:6482:46: note: candidate expects 1 argument, 0 provided
</code></pre>
]]></description><link>https://forum.iobroker.net/post/754129</link><guid isPermaLink="true">https://forum.iobroker.net/post/754129</guid><dc:creator><![CDATA[Troya]]></dc:creator><pubDate>Wed, 02 Feb 2022 08:35:11 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Tue, 18 Jan 2022 10:55:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Ja genau. Hat auch geklappt bevor der s7 eingezogen ist. Dann hab ich versucht zu updaten, weil ich dort den Fehler vemutet hab. Dann "needle" gelöscht, Update hat funktioniert und nun sieht es so im Log aus:</p>
<pre><code>host.iobroker 2022-01-18 11:48:14.399	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
host.iobroker 2022-01-18 11:48:14.398	info	instance system.adapter.mihome-vacuum.1 terminated with code 0 (NO_ERROR)
mihome-vacuum.1 2022-01-18 11:48:14.284	silly	States system redis pmessage system.adapter.mihome-vacuum.1.logLevel/system.adapter.mihome-vacuum.1.logLevel:{"val":"silly","ack":true,"ts":1642502994241,"q":0,"from":"system.adapter.mihome-vacuum.1","lc":1642302793338}
mihome-vacuum.1 2022-01-18 11:48:14.272	debug	Create State for deviceInfofw_ver
mihome-vacuum.1 2022-01-18 11:48:14.271	debug	Create State for deviceInfomodel
mihome-vacuum.1 2022-01-18 11:48:14.271	debug	Create State for deviceInfomac
mihome-vacuum.1 2022-01-18 11:48:14.270	debug	Create State for deviceInfo
mihome-vacuum.1 2022-01-18 11:48:14.211	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
mihome-vacuum.1 2022-01-18 11:48:13.994	debug	Plugin sentry Initialize Plugin (enabled=true)
host.iobroker 2022-01-18 11:48:11.938	info	instance system.adapter.mihome-vacuum.1 started with pid 1650
host.iobroker 2022-01-18 11:47:41.651	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
host.iobroker 2022-01-18 11:47:41.650	info	instance system.adapter.mihome-vacuum.1 terminated with code 0 (NO_ERROR)
mihome-vacuum.1 2022-01-18 11:47:41.538	debug	Create State for deviceInfomodel
mihome-vacuum.1 2022-01-18 11:47:41.537	debug	Create State for deviceInfomac
mihome-vacuum.1 2022-01-18 11:47:41.535	debug	Create State for deviceInfo
mihome-vacuum.1 2022-01-18 11:47:41.465	silly	States system redis pmessage system.adapter.mihome-vacuum.1.logLevel/system.adapter.mihome-vacuum.1.logLevel:{"val":"silly","ack":true,"ts":1642502994241,"q":0,"from":"system.adapter.mihome-vacuum.1","lc":1642302793338}
mihome-vacuum.1 2022-01-18 11:47:41.379	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
mihome-vacuum.1 2022-01-18 11:47:40.868	debug	Plugin sentry Initialize Plugin (enabled=true)
host.iobroker 2022-01-18 11:47:38.619	info	instance system.adapter.mihome-vacuum.1 started with pid 1635
host.iobroker 2022-01-18 11:47:08.593	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
host.iobroker 2022-01-18 11:47:08.592	info	instance system.adapter.mihome-vacuum.1 terminated with code 0 (NO_ERROR)
mihome-vacuum.1 2022-01-18 11:47:08.436	silly	States system redis pmessage system.adapter.mihome-vacuum.1.logLevel/system.adapter.mihome-vacuum.1.logLevel:{"val":"silly","ack":true,"ts":1642502994241,"q":0,"from":"system.adapter.mihome-vacuum.1","lc":1642302793338}
mihome-vacuum.1 2022-01-18 11:47:08.384	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.3, js-controller: 3.3.22
mihome-vacuum.1 2022-01-18 11:47:08.161	debug	Plugin sentry Initialize Plugin (enabled=true)
host.iobroker 2022-01-18 11:47:06.143	info	instance system.adapter.mihome-vacuum.1 started with pid 1619
</code></pre>
<p dir="auto">Der Adapter der als erstes gestartet wird wird grün, der andere entsprechend nicht</p>
]]></description><link>https://forum.iobroker.net/post/743860</link><guid isPermaLink="true">https://forum.iobroker.net/post/743860</guid><dc:creator><![CDATA[Troya]]></dc:creator><pubDate>Tue, 18 Jan 2022 10:55:47 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Tue, 18 Jan 2022 09:28:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troya" aria-label="Profile: troya">@<bdi>troya</bdi></a><br />
Instanz von was? Dem mihome-vaccuum-Adapter?<br />
Da können schon zwei Instanzen laufen.</p>
]]></description><link>https://forum.iobroker.net/post/743810</link><guid isPermaLink="true">https://forum.iobroker.net/post/743810</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 18 Jan 2022 09:28:55 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Tue, 18 Jan 2022 09:02:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
hat geklappt!</p>
<p dir="auto">Kann es sein, dass nur noch eine Instanz gleichzeitig laufen kann? die zweite wird nicht grün wird mit code 0 beendet (no error)</p>
]]></description><link>https://forum.iobroker.net/post/743796</link><guid isPermaLink="true">https://forum.iobroker.net/post/743796</guid><dc:creator><![CDATA[Troya]]></dc:creator><pubDate>Tue, 18 Jan 2022 09:02:22 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Tue, 18 Jan 2022 07:20:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troya" aria-label="Profile: troya">@<bdi>troya</bdi></a><br />
Lösch mal.</p>
]]></description><link>https://forum.iobroker.net/post/743740</link><guid isPermaLink="true">https://forum.iobroker.net/post/743740</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 18 Jan 2022 07:20:18 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Tue, 18 Jan 2022 06:37:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Ok, also hab ich jetzt ein Ordner oder Datei und kann ich es damit entfernen?</p>
<pre><code>sudo -u iobroker rm  /opt/iobroker/node_modules/.bin/needle
</code></pre>
]]></description><link>https://forum.iobroker.net/post/743724</link><guid isPermaLink="true">https://forum.iobroker.net/post/743724</guid><dc:creator><![CDATA[Troya]]></dc:creator><pubDate>Tue, 18 Jan 2022 06:37:49 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Mon, 17 Jan 2022 19:11:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/743596">Bekomme mihome-vacuum -Adapter nicht geupdated</a>:</p>
<blockquote>
<p dir="auto">Da ist halt was auf den Einsatzzweck als NAS angepasstes drauf.</p>
</blockquote>
<p dir="auto">nicht nur NAS, is bei den routern der selbs schmu. da kannste nicht auf jeden im mesh zugreifen, nein, du darfst dich vom hauptrouter auf den nächsten hangeln. macht gute laune wenn du neben dem hauptrouter noch 3 daneben hast... ;)</p>
]]></description><link>https://forum.iobroker.net/post/743600</link><guid isPermaLink="true">https://forum.iobroker.net/post/743600</guid><dc:creator><![CDATA[da_Woody]]></dc:creator><pubDate>Mon, 17 Jan 2022 19:11:53 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Mon, 17 Jan 2022 19:08:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/da_woody" aria-label="Profile: da_woody">@<bdi>da_woody</bdi></a><br />
Da ist halt was auf den Einsatzzweck als NAS angepasstes drauf. Deswegen halte ich das Ganze ja auch nicht  für eine vernünftige Basis für irgendwelche Serverdienste.</p>
]]></description><link>https://forum.iobroker.net/post/743596</link><guid isPermaLink="true">https://forum.iobroker.net/post/743596</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 17 Jan 2022 19:08:40 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Mon, 17 Jan 2022 19:06:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/743518">Bekomme mihome-vacuum -Adapter nicht geupdated</a>:</p>
<blockquote>
<p dir="auto">Bei Synology-Kram kann das sein.</p>
</blockquote>
<p dir="auto">die haben ein etwas eigenes linux da drauf. da bist du als user weniger als nichts.</p>
]]></description><link>https://forum.iobroker.net/post/743595</link><guid isPermaLink="true">https://forum.iobroker.net/post/743595</guid><dc:creator><![CDATA[da_Woody]]></dc:creator><pubDate>Mon, 17 Jan 2022 19:06:27 GMT</pubDate></item><item><title><![CDATA[Reply to Bekomme mihome-vacuum -Adapter nicht geupdated on Mon, 17 Jan 2022 17:39:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/troya" aria-label="Profile: troya">@<bdi>troya</bdi></a></p>
<p dir="auto">Bei Synology-Kram kann das sein. Da wird mir immer erzählt das ginge nur als root.</p>
]]></description><link>https://forum.iobroker.net/post/743518</link><guid isPermaLink="true">https://forum.iobroker.net/post/743518</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 17 Jan 2022 17:39:10 GMT</pubDate></item></channel></rss>
