  4. Test Adapter sma-em v1.4.x Latest
392 Beiträge 48 Kommentatoren 230.0k Aufrufe 44 Beobachtet
  • H Hugo Oberstein
    @pdbjjens
    Hallo , ich bin ein ganz neuer Nutzer von IOBroker und taste mich gerade an die Sache heran.
    Ich habe versucht, den Adapter zu installieren, doch ohne sudo hat das nicht geklappt.
    Dann kam eine Reihe von Informationen, aber den Adapter habe ich unter Objekten nicht gefunden ?
    sudo npm i iobroker.sma-em
    [sudo] Passwort für theauthlaw:
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older v ersions may use Math.random() in certain circumstances, which is known to be pro blematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://git hub.com/request/request/issues/3142
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b ecause it extends the now deprecated request package, see https://github.com/req uest/request/issues/3142
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav e a low-severity ReDos regression when used in a Node.js environment. It is reco mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss ues/797)
    npm WARN deprecated node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped p ackage will recieve updates in the future
    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coff eescript" (no hyphen)
    npm WARN deprecated tar@2.2.2: This version of tar is no longer supported, and w ill not receive security updates. Please upgrade asap.
    added 1 package, removed 654 packages, and changed 796 packages in 7m
    66 packages are looking for funding
    run npm fund for details
    npm notice
    npm notice New minor version of npm available! 8.1.2 -> 8.3.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v8.3.0
    npm notice Run npm install -g npm@8.3.0 to update!
    npm notice
    Was mache ich falsch ?
    Für Hilfe wäre ich dankbar.
    Hugo
    P
    P
    pdbjjens
    #100
    @hugo-oberstein
    Warst Du mit den Tipps hier aus dem Forum erfolgreich mit der Installation des sma-em Adapters über das iobroker UI?
    Ansonsten: iobroker Adapter NIEMALS per sudo installieren und auch möglichst nicht per npm i.
    Wenn schon über command line statt UI installiert werden muss, dann am besten nur iobroker Befehle verwenden, z.B.:
    iobroker add sma-em
    iobroker Befehle können in jedem Verzeichnis ausgeführt werden.
    G 1 Antwort Letzte Antwort
    • P pdbjjens
      @hugo-oberstein
      iobroker add sma-em
      G
      G
      gerty
      #101
      @pdbjjens
      Hallo, jetzt muss ich mal eine Frage stellen.
      Ich habe den Adapter installiert und er scheint super zu funktionieren. (Danke für eure tolle Arbeit)
      Aber ich bekomme andere Werte angezeigt wie das WEB Interface zum Wert: Netzbezug Heute
      Ich habe den Sunny Trippower 4.o und den SM2
      Lt. WEB sollte ich heute eigentlich 12,22 kWh bezogen haben,
      aber diesen Wert kann ich weder unter Modbus anzeigen lassen noch unter dem sma-em Adapter 0.6.4
      irgendwie erkennen oder sinnvoll errechnen lassen.
      Mache ich das was falsch?
      Oder geht das nicht?
      Gerhard
      frana120500F B 3 Antworten Letzte Antwort
      • G gerty
        @pdbjjens
        Gerhard
        frana120500F
        frana120500F
        frana120500
        #102
        @gerty warte mal ab. das Sunnyportal ist bei den Erzeugungs- und Verbrauchswerten stark verzögert
        • frana120500F frana120500
          G
          G
          gerty
          #103
          @frana120500
          danke für die Antwort, aber die Werte stammen nicht vom Portal sondern vom WR und dem Energy Manager, das ist echtzeit
          Bulli BultmannB 2 Antworten Letzte Antwort
          • G gerty
            @frana120500
            Bulli BultmannB
            Bulli BultmannB
            Bulli Bultmann
            #104
            @gerty Hallo,
            ich speichere mir den Wert um 23:59 Uhr in einen Datenpunkt und errechen dann den Wert für Heute.
            Heute = Gesamt - Gestern 23:59Uhr.
            Gruß UB
            • G gerty
              @frana120500
              Bulli BultmannB
              Bulli BultmannB
              Bulli Bultmann
              #105
              @gerty Nochmal Hallo,
              oder Sourceanalytix nehemen.
              • G gerty
                @pdbjjens
                Gerhard
                B
                B
                BigTom91
                #106
                @gerty Register 30577 gibt es laut SMA nicht und 30581 hat die Einheit Wh.
                Bulli BultmannB 1 Antwort Letzte Antwort
                • B BigTom91
                  Bulli BultmannB
                  Bulli BultmannB
                  Bulli Bultmann
                  #107
                  @bigtom91 👍
                  • G gerty
                    @pdbjjens
                    Gerhard
                    B
                    B
                    BigTom91
                    #108
                    @gerty Folgende Register sind bei SMA nicht vorhanden: 30229, 30577, 30579
                    -1
                    • G
                      G
                      gerty
                      #109
                      @bulli-bultmann
                      Schönen Guten Morgen.
                      danke für deine Antwort.
                      Momentan bekomme über Modbus oder sma_em diese Werte
                      aus dem Register 30581
                      übewr das web erhalte ich aber diesen Wert
                      Die Differenz dieser Werte schwankt über dsen Tag, also fand ich keine Regel dafür.
                      Dein Ansatz mit
                      finde ich interessant.
                      Welche Werte aus dem SMA_em, benutzt du dafür?
                      Gerhard.
                      B Bulli BultmannB 2 Antworten Letzte Antwort
                      • B BigTom91
                        G
                        G
                        gerty
                        #110
                        @bigtom91
                        danke für Info,
                        das waren noch Leichen vom Test
                        • G gerty
                          @bulli-bultmann
                          Dein Ansatz mit
                          Gerhard.
                          B
                          B
                          BigTom91
                          #111
                          @gerty Register 30581 gibt auch den Zählerstand vom Bezugszähler an. In dem Fall vom SHM.
                          5613 kWh sind nicht 5,5 kWh.
                          Wie @Bulli-Bultmann schon schrieb, möchtest du den Tagesbezug haben, dann einfach mit dem 30581 Register zum Tageswechsel berechnen.
                          Vom sma-em Adapter erhältst du unter pregardcounter den Bezugszähler vom SHM.
                          • G gerty
                            @bulli-bultmann
                            Dein Ansatz mit
                            Gerhard.
                            Bulli BultmannB
                            Bulli BultmannB
                            Bulli Bultmann
                            #112
                            @gerty Hallo Gerhard,
                            SMA liefert nicht alle Werte über den sma-em Adapter. Wie BigTom91 schon geschrieben hat.
                            Einige Werte kann man sowohl über Modbus oder eben auch über sma-em bekommen.
                            Bei mir nehme ich die Werte für Netzbezug, Einspeisung, Gesamterzeugung und speichere diese dann in jeweils einem Datenpunkt. Zb. Einspeisung_Vortag. In einem Blockly erfolgt dann die Berechnung.
                            Einspeisung_Tag = Einspeisung Gesamt - Einspeisung Vortag.
                            Das Ganze geht auch über Bindings in einigen Widgets. Html Programmierung.
                            Gruß Uwe
                            • P
                              P
                              pi_noob15
                              schrieb am zuletzt editiert von pi_noob15
                              #113
                              Habe ein Problem mit der aktuellen Version 0.64 von GitHub. Die Daten in den Objekten aktualisieren sich nicht mehr laufend, manchmal teils mehere sekunden ohne Änderung. Hab dann den Adapter deinstalliert und wieder versucht auf die alte version 0.57 zu gehen. Problem ist nur ich bekomme die nicht mehr angezeigt bei den verfügbaren Adaptern in Iobroker. Hat jemand ne Idee wie ich die alten wieder draufbekomme?
                              Oder Irre ich mich und der Adapter kann nur über GitHub installiert werden ?
                              P 1 Antwort Letzte Antwort
                              • P pi_noob15
                                P
                                P
                                pdbjjens
                                #114
                                @pi_noob15
                                Ich rate dringend davon ab, die Version 0.5.7 zu installieren, da sie weder mit aktuellen Versionen von iobroker noch SMA Energy Meter/Sunny Home Manager Firmware funktioniert.
                                Das Verhalten der Version 0.6.4 deutet darauf hin, dass iobroker die schnelle Updaterate der Datenpunkte nicht schafft und daher den Adapter temporär disabled. (müsste im Log vermerkt sein).
                                Abhilfe: Bei der Konfiguration des Adapters die Details deaktivieren und wenn das nicht reicht auch noch den Extended Mode.
                                • P pdbjjens
                                  @pi_noob15
                                  A
                                  A
                                  Atlantis
                                  #115
                                  @pdbjjens
                                  Kommen bei Euch überhaupt noch Werte?
                                  Seit der neuen FW von SMA vom 26.01.2022 1:48 Vers. 20566f52-616d-431c-aa1f-f0719aa521a8-grafik.png
                                  kommen keine Daten mehr im IO Broker an. Habe seit vielen Monden schon unverändert i.O. die Version
                                  v0.6.4
                                  am laufen...
                                  Im Sunny Portal sprudeln die Daten aber fleissig weiter...
                                  frana120500F P 2 Antworten Letzte Antwort
                                  • A Atlantis
                                    @pdbjjens
                                    v0.6.4
                                    am laufen...
                                    frana120500F
                                    frana120500F
                                    frana120500
                                    #116
                                    @atlantis Update wurde bei mir diese Nacht gemacht. Werte kommen weiterhin rein.
                                      A
                                      A
                                      Atlantis
                                      #117
                                      @frana120500 Hast DU von SMA jetzt die gleiche FW wie ich?
                                      frana120500F 1 Antwort Letzte Antwort
                                      • A Atlantis
                                        frana120500F
                                        frana120500F
                                        frana120500
                                        #118
                                        @atlantis yep. gerade mal ins Log geguckt im Sunnyportal
                                          A
                                          A
                                          Atlantis
                                          #119
                                          @frana120500
                                          Das ist jetzt wirklich komisch. Ich habe an den Settings seit Ewigkeiten nichts verändert.
                                          Mit dem FW Update kam das Problem. IP Adresse des IO Broker und des SMA sind gleich geblieben auch nach FW Update.
                                          Restart des SMA EM brachte keinen Effekt
                                          Restart des Adapters brachte kein Effekt
                                          Andere SMA kompatiblen Zähler Elris wurden im SMA Adapter korrekt angezeigt.
                                          Messintervall des SMA mal testweise kurz auf 200ms und dann wieder auf 1000ms setzen kein Effekt
                                          Als ich dann aber in der SMA Geräteübersicht
                                          die IP des IO Broker eingetragen habe (Obwohl die Kommunikation eigentlich Multicast sein sollte)
                                          kamen plötzlich dann wieder Daten...
                                          Das verstehe ich jetzt nicht wirklich...
                                          Vielleicht hilft es ja wenigstens noch anderen...
                                          Gruss
                                          Atlantis
                                          33.2k
                                          84.3k
