  5. Hue Blinkt nicht
Hue Blinkt nicht
43 Beiträge 5 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • CinimodC Cinimod
    @gluecksmann
    Willst du deinen Blockly-Code mal hier Posten, dann kann man das eben zusammenwürfeln
    gluecksmann
    @cinimod
      <block type="on" id="MFGqLQ##.3c%VOuz[!_)" x="-1812" y="-2612">
        <field name="OID">zigbee.0.00158d0006d30d32.opened</field>
        <statement name="STATEMENT">
          <block type="controls_if" id="ubjT[O%5.MY8DT|!~hy[">
            <value name="IF0">
              <block type="logic_compare" id="Fahzf9m!-z/YH0yEP{dJ">
                <field name="OP">EQ</field>
                <value name="A">
                  <block type="get_value" id=":~+oUH0j`.!USq4C@ZPj">
                  </block>
                </value>
                <value name="B">
                  <block type="logic_boolean" id="PxgD_nj}MuxpBi}OjpU]">
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="control" id="!:][@E9{[]G[_L9_!o}1">
                <field name="OID">scene.0.LED_Blau_Szene</field>
                <value name="VALUE">
                  <block type="logic_boolean" id="Zn{I~JG(,ElhHpX!af)`">
                  </block>
                </value>
                <next>
                  <block type="control" id="A_x]GS?BW5Pdd!WBLUKU">
                    <field name="OID">hue.0.Hue_Keller.alert</field>
                      <block type="text" id="9^/b7eSUOi/G4xZwi^!M">
                        <field name="TEXT">Iselect</field>
                      </block>
                    </value>
                    <next>
                      <block type="control" id=";bc)jai)WZzh4O|sbrFg">
                        <field name="OID">alexa2.0.Echo-Devices.db670fafbbfc4ff5b16223f5d7b07624.Commands.speak</field>
                          <block type="text" id="(XjwV=A|=OOwkB`^C$Bc">
                            <field name="TEXT">Alarm Feuerwehr Tegelort</field>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
            <value name="IF1">
              <block type="logic_compare" id="XUI^e^)%ow.zgujFM8jE">
                <value name="A">
                  <block type="get_value" id="_w9[MLZ+{;XpkdaeQm4j">
                  </block>
                </value>
                <value name="B">
                  <block type="logic_boolean" id="8m#k{y^i,#1le=7;aCdp">
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO1">
              <block type="control" id="_FY}lItjw^R578/2}C*!">
                <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                <field name="DELAY_MS">60</field>
                  <block type="logic_boolean" id="*ZR0qT|(E=R#^ql=h@zM">
                  </block>
                </value>
                <next>
                  <block type="control" id="v}9U#QM|:p_RET6,a?fR">
                      <block type="logic_boolean" id="f5@X-dU11QFO,8h]2C_p">
                      </block>
                    </value>
                    <next>
                      <block type="control" id=".b*zzdo-r4Sz1$gWgrpC">
                        <field name="OID">hue.0.Hue_Keller.on</field>
                          <block type="logic_boolean" id="[!kWv@u]=^6Z4Q/m[-Rk">
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>
    MOD EDIT: BLOCKLY IN CODE TAGS GESETZT
    • G gluecksmann
      @cinimod
              <value name="IF0">
                  <value name="A">
                    </block>
                  </value>
                  <value name="B">
                    </block>
                  </value>
                </block>
              </value>
                    </block>
                  </value>
                  <next>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
              <value name="IF1">
                  <value name="A">
                    </block>
                  </value>
                  <value name="B">
                    </block>
                  </value>
                </block>
              </value>
                    </block>
                  </value>
                  <next>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
          </statement>
        </block>
      </xml>
      CinimodC Offline
      CinimodC Offline
      Cinimod
      @gluecksmann
      Codes bitte immer im Code Tag posten, sonst werden das endlose Seiten hier.
      Hab noch ein-zwei Fragen:
      wenn du die Szene Blau auf falsch setzt, gehen das licht auch aus ?
      Hast du keinen on/off Datenpunkt, und keinen der die Farbe aufnimmt ?
      Vielleicht machst du noch mal nen Screenshot von den Datenpunkten des zu steuernden Lichts, die du zur verfügung hast.
      Ich muss jetzt erstmal ein bischen Raten, aber so in etwa sollte es aussehen:
       <variables>
         <variable type="interval" id="blinken">blinken</variable>
         <variable type="timeout" id="dauer">dauer</variable>
       </variables>
       <block type="on" id="MFGqLQ##.3c%VOuz[!_)" x="-1837" y="-2663">
           <block type="timeouts_cleartimeout" id="`I[#eOh$lwYpY~+63hu2">
             <field name="NAME">dauer</field>
             <next>
               <block type="timeouts_clearinterval" id="C]wJiQoxGka5!fa7VhrL">
                 <field name="NAME">blinken</field>
                 <next>
                     <value name="IF0">
                       <block type="on_source" id="w|96o~54N/HMKxI2B=|7">
                         <field name="ATTR">id</field>
                       </block>
                     </value>
                       <block type="control" id=".bzzdo-r4Sz1$gWgrpC">
                           </block>
                         </value>
                         <next>
                             <field name="DELAY_MS">2000</field>
                             <field name="UNIT">ms</field>
                               <block type="logic_boolean" id="ZR0qT|(E=R#^ql=h@zM">
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </statement>
                     <statement name="ELSE">
                           <block type="logic_boolean" id="Zn{I~JG(,ElhHpX!af)">
                           </block>
                         </value>
                         <next>
                           <block type="timeouts_setinterval" id="]DWx9nsYS-0+)W,Gr%ka">
                             <field name="INTERVAL">500</field>
                               <block type="toggle" id="!M/P}.QuaATLa,;90_$(">
                               </block>
                             </statement>
                             <next>
                               <block type="timeouts_settimeout" id="iHP%dEVz](Z^d{2{LYsf">
                                 <field name="DELAY">20</field>
                                   <block type="timeouts_clearinterval" id="[Xo6*c:nAhwq%M^H_Rw7">
                                     <field name="NAME">Intervall</field>
                                     <next>
                                       <block type="control" id="K9/.(ntQkE]G)7][XsEW">
                                           <block type="logic_boolean" id="xnZ,:M{3{Z~m.L*ya0Nj">
                                           </block>
                                         </value>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                                 <next>
                                       </block>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </statement>
       </block>
      </xml>
      G 1 Antwort Letzte Antwort
      • CinimodC Offline
        CinimodC Offline
        Cinimod
        @gluecksmann sagte in Hue Blinkt nicht:
        Re: Hue Lampe Blinken lassen
        Da ich mich ja immer noch schwer tue mit Blockly, habe ich mich gefreut zu lesen das es einen relativ leichten befehl gibt um die Lampen 15sek blicken zu lassen..sieht bei mir dann so aus:
        Blink aber nix...
        Von meinem Wunsch, die Farbe anzugeben, mal ganz zu schweigen...
        Hast du mal geschaut das dort auch ein kleines "L" am anfang steht von lselect, nicht ein großes "i"
        An sonsten probier doch mal bitte den Command Datenpunkt anzusteuern mit diesem text:
        {"level":100, "r":100,"alert":"lselect", "transitiontime":0}
        berichte dann mal ob sich was tut.
        • CinimodC Cinimod
          @gluecksmann
           <variables>
           </variables>
                 <next>
                     <next>
                         <value name="IF0">
                           </block>
                         </value>
                               </block>
                             </value>
                             <next>
                                   </block>
                                 </value>
                               </block>
                             </next>
                           </block>
                         </statement>
                               </block>
                             </value>
                             <next>
                                   </block>
                                 </statement>
                                 <next>
                                         <next>
                                               </block>
                                             </value>
                                           </block>
                                         </next>
                                       </block>
                                     </statement>
                                     <next>
                                           </block>
                                         </value>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
          </xml>
          gluecksmann
          @cinimod sagte in Hue Blinkt nicht:
          Hallo, das "interval" klappt nicht...wird scheinbar nirgendwo angelegt?!
          • CinimodC Cinimod
            Blink aber nix...
            gluecksmann
            @cinimod
            Command Datenpunkt? bin DAU
            • G gluecksmann
              @cinimod
              CinimodC Offline
              CinimodC Offline
              Cinimod
              @cinimod
              Bei deine Hue Lampe hast du doch einen Datenpunkt der "command" oder "cmd" heißt !?
              trag da mal das ein, nur erstmal zum testen:
              • G gluecksmann
                Blink aber nix...
                stony2kS Offline
                stony2kS Offline
                stony2k
                Blink aber nix...
                Versuch mal bitte als Text select ansatt was du darin stehen hast. Bei mir blinkt die Lampe dann auf.
                • stony2kS stony2k
                  Blink aber nix...
                  gluecksmann
                  @stony2k
                  Hast Du da noch was zusätzlich drin das es blinkt? Eine Schleife?
                  stony2kS 1 Antwort Letzte Antwort
                  • G gluecksmann
                    @stony2k
                    stony2kS Offline
                    stony2kS Offline
                    stony2k
                    @gluecksmann Nein, ich meinem Fall lasse ich die Lampe einfach nur 1x blinken. Aber du könntest sie ja auch in einer Schleife mehrmals blinken lassen. Vielleicht auch einen eleganteren Weg, die mehrmals blinken zu lassen, in dem man den Befehl anpasst? Davon habe ich leider keine Ahnung.
                    • CinimodC Cinimod
                      @cinimod
                      gluecksmann
                      @cinimod
                      tut sich nix... auch mit dem lselect habe ich probiert...
                        Mariatschi0815
                        schrieb am zuletzt editiert von Mariatschi0815
                        @cinimod said in Hue Blinkt nicht:
                        das geht.
                        dafür musst du diesen Datenpunkt nutzen:
                        Die Alternative:
                        Geht auch.
                        Und:
                        geht auch...
                        überprüf doch bitte nocheinmal ob du ein kleines L vor dem select stehen hasst. Es darf kein großes i sein.
                        Die Lampe muss allerdings vorher eingeschaltet sein, macht das deine Szene?
                        • M Mariatschi0815
                          das geht.
                          Die Alternative:
                          Geht auch.
                          Und:
                          geht auch...
                          gluecksmann
                          schrieb am zuletzt editiert von gluecksmann
                          @mariatschi0815
                          Also mit dem Command Befehl will nicht klappen... aber der wohl entscheidende Hinweis war das die Lampe vorher AN sein muß.....Vielen vielen Dank !! Jetzt klappt es...
                          • G gluecksmann
                            @mariatschi0815
                            CinimodC Offline
                            CinimodC Offline
                            Cinimod
                            @gluecksmann
                            Ihr macht mich fertig 😂
                            • CinimodC Cinimod
                              @gluecksmann
                              gluecksmann
                              @cinimod
                              Freue mich das es jetzt geht.... aber erstaunlich das Du der erste bis, der es erähnt, das die Lampe an sein muß...
                              • G gluecksmann
                                @cinimod
                                Mariatschi0815
                                @gluecksmann Bitte gern. Ich hab allerdings den Vorteil selber Hue zu haben und konnte es somit testen.
                                Übrigens, wenn du mit command arbeitest die { } nicht vergessen, sonst geht es nicht.
                                • M Mariatschi0815
                                  gluecksmann
                                  @mariatschi0815
                                  wie gesagt... der Command will nicht so recht.... aber Hauptsche blinkt...
                                  • G gluecksmann
                                    @mariatschi0815
                                    Mariatschi0815
                                    @gluecksmann Du könntest noch folgendes probieren:
                                    {"on":true, "level":100, "b":254, "alert":"lselect"}
                                    Wobei level:100 das einschalten eigentlich mit einschließt. Ansonst hast du vielleicht vergessen den Datenpunkt command auszuwählen. Der Befehl funktioniert natürlich nicht beim Datenpunkt alert.
                                    • M Mariatschi0815
                                      gluecksmann
                                      @mariatschi0815 ich probiere es nachher noch einmal... kann man in den Command Befehl auch die Farbe einbauen? das es Blau blinkt?
                                      • G gluecksmann
                                        Mariatschi0815
                                        @gluecksmann Jop, steht schon so drin das "b": und die Zahl dahinter ist die Sättigung muss zwischen 0 und 254 liegen. entsprechend könntest du es auch mit rot "r": und gelb "g": machen oder alle drei und dann eben Mischfarben erstellen.
                                        Türkis wäre z.B.
                                        {"on":true, "level":100, "b":241, "r":51,"g":254, "alert":"lselect"}
                                        • CinimodC Offline
                                          CinimodC Offline
                                          Cinimod
                                          @mariatschi0815
                                          Muss man r und g dann nicht auf null setzen, dann kann doch theoretisch schon nen Wert drin stehen, oder vertue ich mich da ?
                                          Also bei reinem Blau meine ich jetzt ...
